@654fa58a
01/19/18 09:50:44 |
Sebastian Huber |
block06: Use floating-point task
This test uses sprintf().
5
@5b7f922
01/19/18 09:49:01 |
Sebastian Huber |
fstests: Use floating-point task
The fstests use snprintf().
5
@32d50688
01/19/18 09:05:24 |
Sebastian Huber |
psxpasswd02: Use floating-point task
5
@e9588d5f
01/19/18 09:03:53 |
Sebastian Huber |
psxstat: Use floating-point task
5
@d2f9d10f
01/19/18 09:00:15 |
Sebastian Huber |
psximfs02: Use floating-point task
5
@32e8fc3
01/19/18 08:57:05 |
Sebastian Huber |
spassoc01: Use floating-point task
5
@3205fd6
01/19/18 08:53:34 |
Sebastian Huber |
tests: Use vprintk() in locked_printf()
This avoids blocking output …
5
@047e8aa
01/19/18 08:53:18 |
Sebastian Huber |
tests: Remove unused locked_printk()
5
@e6d89860
01/19/18 08:52:23 |
Sebastian Huber |
smpmigration01: Enable floating-point output
5
@9c270ac
01/19/18 08:47:39 |
Sebastian Huber |
5
@030ce68
01/02/18 08:03:19 |
Sebastian Huber |
tests: Fix canonical-target-name.m4
Update #3109.
5
@1307e75
12/08/17 18:15:12 |
joel |
tm08: Do not use RTEMS_INTERRUPT_MASK for no reschedule case
Updates …
5
@21e96d66
12/08/17 18:14:20 |
joel |
sp08: Disable RTEMS_INTERRUPT_MASK testing when SMP enabled
Updates #3000.
5
@2fe3687
12/06/17 14:56:50 |
Christian.Mauderer |
dosfs: Allow creating a file with similar name.
If there is already a …
5
@e9e0f1d4
12/05/17 15:56:47 |
joel |
smpunsupported01: Add missing error check for rtems_task_mode
Update …
5
@9e339a8
12/06/17 18:17:03 |
Sebastian Huber |
sptests/sp51: Delete semaphore after use
This ensures that the …
5
@bc5b56a
12/04/17 07:56:00 |
Sebastian Huber |
libio: Use API mutex
5
@ca835e56
11/28/17 15:42:00 |
dosfs: Fix files with same name as volume name.
Take care that a file …
5
@fd5471b
12/01/17 21:37:06 |
Sebastian Huber |
ada: Check C and POSIX types
Update #3256.
5
@6c2b8a4b
11/29/17 05:23:27 |
Sebastian Huber |
score: Use self-contained API mutex
Use a self-contained recursive …
5
@3d7d2a37
12/04/17 09:52:01 |
Sebastian Huber |
ada/sp09: Fix timer server test case
A priority of zero is valid for …
5
@535d0183
12/04/17 09:51:33 |
Sebastian Huber |
ada/sp09: Fix region test cases
5
@6e05265f
12/04/17 09:50:49 |
Sebastian Huber |
ada: Fix work_space_size() test support
5
@215fa231
12/04/17 08:38:25 |
Sebastian Huber |
ada/tm04: Account for task delete behaviour change
5
@76bd25e
12/02/17 19:15:29 |
Sebastian Huber |
ada/sp19: Add missing FP attribute
5
@dda8142f
12/01/17 14:22:02 |
Sebastian Huber |
ada/sp07: Fix uninitialized variable
Bug was introduced by …
5
@5e05fa0
12/01/17 14:21:34 |
Sebastian Huber |
ada: Fix user extension support
5
@c589775a
12/01/17 12:56:50 |
Sebastian Huber |
ada: Use CONFIGURE_DISABLE_SMP_CONFIGURATION
Most Ada tests fail …
5
@2178978a
12/01/17 12:18:14 |
Sebastian Huber |
ada/tm20: Account for optional heap protection
Reduce size of the big …
5
@a01e169
12/01/17 10:26:10 |
Sebastian Huber |
ada/spname01: Fix several issues
5
@f6c9334d
12/01/17 07:51:17 |
Sebastian Huber |
ada: Add standard test begin/end message
5
@6899a8d
12/01/17 07:38:05 |
Sebastian Huber |
ada: Delete superfluous CONFIGURE_SPTEST
5
@d6c5a97
11/29/17 16:30:43 |
joel |
block06/init.c: Fix printf() format warning
5
@e58e29fd
11/24/17 06:58:55 |
Sebastian Huber |
Remove coverhd.h
This header file contained timing overhead values …
5
@57f96b9
11/24/17 14:26:38 |
Sebastian Huber |
libtests/malloctest: Fix 64-bit targets
Update #3082.
5
@54e7b81
11/24/17 14:18:14 |
Sebastian Huber |
libtests/stringto01: Fix 64-bit targets
Update #3082.
5
@2e7c3f6
11/24/17 14:12:20 |
Sebastian Huber |
sptests/splinkersets01: Fix 64-bit targets
Update #3082.
5
@83ad1c5
11/24/17 12:50:58 |
Sebastian Huber |
ada/sp04: Fix clock get
Update #2676.
5
@c59479f
11/22/17 08:26:02 |
Sebastian Huber |
tests: Use exponential backoff in locked_vprintf()
Without the …
5
@15e19273
11/21/17 10:29:01 |
Sebastian Huber |
sapi: New implementation of rtems_panic()
The previous rtems_panic() …
5
@cd3e220
11/20/17 05:30:26 |
Sebastian Huber |
INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
Delete superfluous …
5
@a7dcef97
11/17/17 05:36:54 |
Sebastian Huber |
score: Simplify global construction
Update #3243.
5
@c597fb1
11/09/17 15:21:37 |
Sebastian Huber |
score: Optimize scheduler priority updates
Thread priority changes …
5
@1358d4c
11/13/17 08:21:30 |
getentropy: Add test.
Update #3239.
5
@ddc339c
11/13/17 08:21:28 |
cpukit: Add _arc4random_getentropy_fail.
Add a default implementation …
5
@727cf48
11/16/17 05:16:12 |
Sebastian Huber |
sptests/spversion01: Simplify configuration
Update #3199.
5
@e24d64b
11/16/17 14:26:24 |
Sebastian Huber |
psx05: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION
Update #3020.
5
@ec771f2
11/16/17 14:04:21 |
Sebastian Huber |
score: Fix priority ceiling updates
We must not clear the priority …
5
@9c30c31e
11/16/17 13:38:07 |
Sebastian Huber |
score: Fix _Thread_queue_Flush_critical()
The thread queue extract …
5
@79a998d
11/16/17 13:08:20 |
Sebastian Huber |
rtems: rtems_semaphore_flush() with prio inherit
The …
5
@62119d2
11/15/17 06:55:43 |
Sebastian Huber |
dl01, dl02, dl05: Fix unresolved printf symbol
The link time wrap of …
5
@cb40687
11/10/17 07:39:23 |
Sebastian Huber |
Change RTEMS_API from 5.0 to 5
This fixes the legacy Makefile based …
5
@e6df806
11/08/17 02:27:25 |
Chris Johns |
tests: Use ld to map (wrap) printf, puts and putchar to tester …
5
@bcd0c06c
11/07/17 21:25:36 |
Chris Johns |
tests: Use rtems_test_begin and rtems_test_end.
Add a tests enum and …
5
@6f3fb8a
11/07/17 05:43:11 |
Chris Johns |
cpukit: Add a Version API.
Provide functions to get the version …
5
@748a126
11/09/17 21:06:19 |
joel |
pppd/Makefile.am: Add support/include
5
@4a147518
10/17/17 11:44:22 |
Sebastian Huber |
Upgrade to 5.0.0
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
5
@64ba1a96
11/08/17 14:29:14 |
Sebastian Huber |
posix: Change created_with_explicit_scheduler
Remove …
5
@7147dc4
11/08/17 13:37:35 |
Sebastian Huber |
posix: Remove POSIX_API_Control::schedpolicy
Use the thread CPU …
5
@8d0a0aa
11/03/17 20:16:09 |
Sebastian Huber |
sptests/spconsole01: New test
5
@791469bd
11/06/17 13:49:32 |
Sebastian Huber |
termios: Fix canonical mode
In canonical mode, input is made …
5
@1055ff20
11/07/17 06:07:35 |
Sebastian Huber |
tests: Use normal console for user input tests
5
@32ceb385
11/07/17 07:30:59 |
Sebastian Huber |
tests: Use <tmacros.h>
Update #3170.
Update #3199.
5
@0c286e3
10/25/17 14:00:17 |
Sebastian Huber |
score: _Chain_Insert_ordered_unprotected()
Change the chain order …
5
@7b00c2fa
11/06/17 06:56:17 |
Sebastian Huber |
tests: Use <tmacros.h> in all tests
Update #3170.
Update #3199.
5
@d71542c
11/06/17 08:05:30 |
Sebastian Huber |
fsjffs2gc01: Fix sporadic test failures
5
@c4b8b147
11/03/17 07:35:38 |
Sebastian Huber |
tests: Use simple console driver
Update #3170.
Update #3199.
5
@1082798
10/23/17 11:30:44 |
Sebastian Huber |
score: Add _IO_Printf() and _IO_Vprintf()
The previous vprintk() …
5
@a54d10d
11/03/17 11:53:51 |
Sebastian Huber |
smpscheduler02: Avoid sporadic test failures
5
@3e81d52
10/29/17 19:29:05 |
Sebastian Huber |
posix: Use far future for very long timeouts
Close #3205.
5
@8c1f4064
11/02/17 12:56:12 |
Sebastian Huber |
tests: Use printf() instead of fprintf()
Update #3170.
Update #3199.
5
@0d796d6
11/02/17 13:08:02 |
Sebastian Huber |
tests: Delete obsolete TESTS_USE_PRINTF
Update #3170.
Update #3199.
5
@81fd79d
10/27/17 06:52:41 |
Sebastian Huber |
smppsxaffinity02: Fix thread attribute usage
The pthread_getattr_np() …
5
@2126438a
10/30/17 05:30:11 |
Chris Johns |
testsuite: Add bspIo for a local printk.
Update #3170.
Update #3199.
5
@af43554
10/26/17 11:59:11 |
Sebastian Huber |
tests: Remove TEST_INIT
The TEST_EXTERN is a used only by the …
5
@acc9d064
10/26/17 11:59:10 |
Sebastian Huber |
tests: Remove obsolete TESTS_USE_PRINTK
Update #3170.
Update #3199.
5
@7e102915
10/26/17 11:59:09 |
Sebastian Huber |
tests: Use rtems_test_printer in general
Update #3170.
Update #3199.
5
@46ddc3c5
10/26/17 11:59:08 |
Sebastian Huber |
tests: Use rtems_print_printer_fprintf_putc()
Use …
5
@73d892d8
10/26/17 11:59:07 |
Sebastian Huber |
Update #3170.
Update #3199.
5
@f703e7f
10/26/17 11:59:05 |
Sebastian Huber |
tests: Move rtems_test_printer definition
Statically initialize it to …
5
@0719fc6
10/27/17 07:04:54 |
Sebastian Huber |
sptests/spscheduler01: Test POSIX set/get affinity
5
@8744498
10/27/17 07:04:53 |
Sebastian Huber |
score: Fix _Scheduler_Set_affinity()
5
@0f1fa19
10/26/17 11:19:57 |
Sebastian Huber |
smptests: Fix format warnings
5
@1510ce4
10/26/17 11:17:21 |
Sebastian Huber |
psxtests/psxstat: Fix format warnings
5
@b31ccb5
10/26/17 11:08:27 |
Sebastian Huber |
psxtests/psxclockrealtime01: Fix warnings
Update #3182.
5
@e3ef14b
10/25/17 05:57:58 |
Sebastian Huber |
smptests: Remove duplicate Makefile targets
Close #3187.
5
@34799c3b
10/24/17 07:35:06 |
Sebastian Huber |
rtems: rtems_clock_get_ticks_per_second()
Add macro implementation …
5
@4c70110
10/24/17 21:32:53 |
Chris Johns |
testsuite: Fix build
Updates #3170.
5
@c3105894
10/19/17 11:47:57 |
Sebastian Huber |
score: Move thread queue timeout handling
Update #3117.
Update #3182.
5
@cea5ff7
10/20/17 13:35:14 |
Sebastian Huber |
score: Add _Watchdog_Nanoseconds_per_tick
Move it from the …
5
@7ed377b
10/20/17 06:43:15 |
Sebastian Huber |
score: _Watchdog_Is_far_future_monotonic_timespec
Update #3117. …
5
@27cfe7c
10/20/17 06:31:36 |
Sebastian Huber |
score: Add _Watchdog_Ticks_per_second
This value is frequently used. …
5
@d85c94c0
10/13/17 06:00:46 |
Sebastian Huber |
psxclockrealtime01: New test
Update #3182.
5
@0e1ad7fa
10/24/17 07:27:06 |
Sebastian Huber |
tmtests/tmfine01: Reduce test context size
Reduce test context size …
5
@88e84c22
10/23/17 11:48:56 |
Sebastian Huber |
Updates #3170.
5
@36d974ba
10/22/17 22:57:52 |
Chris Johns |
testsuite: Remove warnings.
5
@98c6d50
10/19/17 05:39:16 |
Chris Johns |
testsuite: Use printk for all test output where possible.
- Remove …
5
@a05861d
10/21/17 10:16:21 |
Sebastian Huber |
libtests/tar01: Fix build dependencies
5
@205d8d71
10/17/17 09:46:14 |
sptests/sptimecounter04: New test
Ensure that the time flow of …
5
@6087f33e
10/18/17 06:50:17 |
Sebastian Huber |
tmtests/tmfine01: Add test cases
Update #2674.
Update #3112.
Update …
5
