@63e2ca1b
10/31/16 08:13:35 |
Sebastian Huber |
score: Simplify yield and unblock scheduler ops
Update #2556.
5
@2dd098a
10/31/16 07:33:11 |
Sebastian Huber |
score: Introduce Thread_Scheduler_control::home
Replace …
5
@1cafc46
10/31/16 05:19:43 |
Sebastian Huber |
score: Delete Resource Handler
Update #2556.
5
@6771359f
10/27/16 04:42:06 |
Sebastian Huber |
score: Second part of new MrsP implementation
Update #2556.
5
@9c238e1
10/21/16 12:33:01 |
Sebastian Huber |
score: Simplify update priority scheduler op
Remove unused return status.
5
@3a27248
10/21/16 07:23:58 |
Sebastian Huber |
score: First part of new MrsP implementation
Update #2556.
5
@6a82f1ae
10/10/16 09:46:07 |
Sebastian Huber |
score: Yield support for new SMP helping protocol
Update #2556.
5
@351c14d
09/27/16 09:33:36 |
Sebastian Huber |
score: Add new SMP scheduler helping protocol
Update #2556.
5
@72e0bdb
10/10/16 12:50:19 |
Sebastian Huber |
score: Pass scheduler node to unblock operation
Changed for …
5
@e382a1b
10/10/16 12:33:17 |
Sebastian Huber |
score: Pass scheduler node to block operation
Changed for consistency …
5
@2df4abc
10/10/16 12:01:55 |
Sebastian Huber |
score: Pass scheduler node to yield operation
5
@501043a
09/30/16 12:38:04 |
Sebastian Huber |
score: Pass scheduler node to update priority op
This enables to call …
5
@b7694c8c
10/31/16 15:04:11 |
Sebastian Huber |
sptests/sp35: Remove dead code
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@7eec247
10/31/16 09:50:54 |
Sebastian Huber |
smptests/smplock01: Use test support
Convert output to XML.
5
@826f3afa
10/11/16 22:15:23 |
Chris Johns |
libmisc/xz: Add xz decompression.
Add support to untar XZ compressed …
5
@be57318
09/23/16 04:45:07 |
Sebastian Huber |
score: More robust linker sets
Update #2408.
Update #2790.
5
@ed19002
10/12/16 08:37:07 |
Sebastian Huber |
smpschedaffinity05: Fix configuration
5
@475faef5
10/10/16 06:47:26 |
Sebastian Huber |
tmfine01: Add self-contained mutex test case
This demonstrates the …
5
@938ee19c
09/23/16 08:09:57 |
Sebastian Huber |
sptests/spsem03: Fix compile error
5
@f6142c19
09/09/16 09:00:06 |
Sebastian Huber |
score: Scheduler node awareness for thread queues
Maintain the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@6ae309ec
09/09/16 08:01:06 |
Sebastian Huber |
smptests/smpmutex01: Use test case functions
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@610b9ef1
09/19/16 05:51:07 |
Sebastian Huber |
libtests/devfs: Use printk()
This avoids problems with console …
5
@caf4064
09/16/16 12:54:12 |
Sebastian Huber |
fstests: Use printk() for IMFS configuration tests
This avoids …
5
@29770e12
09/16/16 12:21:30 |
Sebastian Huber |
tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
Avoid unnecessary use …
5
@a42be52
09/12/16 13:00:46 |
alexander.krutwig |
Add SPI bus framework
User API is compatible to Linux userspace API. …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@3709987
08/10/16 06:21:54 |
Sebastian Huber |
score: Add _Chain_Initialize_one()
5
@83b0229
06/28/16 04:59:29 |
Sebastian Huber |
score: Add _RBTree_Initialize_one()
5
@1c18ebf0
08/31/16 08:56:09 |
Chris Johns |
libmisc/capture: Remove the reserved _t in the types.
5
@6da06c5
08/30/16 06:46:25 |
Chris Johns |
libmisc/capture: Fix the capture engine on SMP.
This patches some …
5
@5d1fc66
08/12/16 13:54:46 |
Sebastian Huber |
psxtests: Adjust sporadic server tests
According to POSIX priority …
5
@381c42b
08/12/16 09:18:38 |
Chris Johns |
testsuite: Add libdl/dl04 cache test.
5
@97d395b
08/12/16 08:55:53 |
Chris Johns |
testsuite: Add libdl/dl03 cache test.
5
@55faa44
08/12/16 09:16:45 |
Sebastian Huber |
score: Improve _RBTree_Insert_inline()
Return if the inserted node is …
5
@03c1038
08/10/16 03:28:50 |
Chris Johns |
librtems++: Remove from RTEMS.
This is old and there are better …
5
@9a4eca5
08/10/16 03:07:29 |
Chris Johns |
build-system: Always enable C++ if the compiler is present.
We always …
5
@21d73655
08/10/16 07:54:13 |
Sebastian Huber |
sptests/splinkersets01: Fix for small-data area
5
@b0f08c8
08/01/16 01:02:13 |
Chris Johns |
libmisc/untar: Set the perms to the value in the tar file.
This patch …
5
@5c09e9d
08/08/16 07:47:06 |
Sebastian Huber |
sptests/splinkersets01: Fix warnings
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@5fe6d07a
08/01/16 11:16:57 |
Christian.Mauderer |
linker set: Allow adding any variable into content
The newly created …
5
@d79df38
07/26/16 08:34:21 |
Sebastian Huber |
score: Add deadlock detection
The mutex objects use the owner field …
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@6a174c02
07/25/16 13:34:43 |
alexander.krutwig |
Add Untar_FromGzChunk_Print() + Test
5
@1a8fe67a
07/13/16 07:22:35 |
alexander.krutwig |
Add Untar_FromChunk_Print() + Test
5
@c1b815ab
07/26/16 07:26:19 |
Sebastian Huber |
sptests/spextensions01: Avoid NULL pointer access
5
@6e98ea91
06/09/16 15:40:35 |
Gedare Bloom |
posix: add clock_nanosleep and tests
updates #2732
5
@57a00bc6
07/05/16 09:30:14 |
Sebastian Huber |
smptests/smpmutex02: New test
Update #2765.
5
@0fd6f255
07/08/16 14:58:48 |
Sebastian Huber |
score: Relax thread begin extension environment
Update #2752.
5
@059529e
07/21/16 08:15:02 |
Sebastian Huber |
score: Add debug support to chains
* double …
5
@6f6cf785
07/05/16 07:04:15 |
Sebastian Huber |
score: Postpone SMP shutdown in _Terminate()
This enables fatal …
5
@2e3ba71
07/01/16 13:16:10 |
Sebastian Huber |
net: Fix byte order issue for getnameinfo()
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@4280dff7
06/30/16 09:01:05 |
Sebastian Huber |
smptests/smpstrongapa01: Simplify
5
@4fe0e97f
06/30/16 07:50:41 |
Sebastian Huber |
smptests/smpstrongapa01: Add test cases
5
@195d412
05/02/16 12:49:33 |
libnetworking: Add minimal getnameinfo()
This implementation just …
5
@187a0744
05/02/16 12:49:35 |
libcsupport: Add dummy for setgroups().
The dummy for setgroups() …
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@9f61ad60
06/23/16 11:43:38 |
Sebastian Huber |
testsuites: Increase invalid priority values
Increase the invalid …
5
@50a56dff
06/24/16 09:16:35 |
Sebastian Huber |
score: Move SCHEDULER_EDF_PRIO_MSB
This is an implementation detail …
5
@b364d38
06/24/16 06:26:55 |
Sebastian Huber |
sptests/spintrcritical23: Explicity set scheduler
This test uses …
5
@b679b492
06/23/16 07:09:55 |
Sebastian Huber |
sptests/sp42: Relax priority requirements
5
@ec5d95e1
06/23/16 08:31:04 |
Sebastian Huber |
smptests/smpmrsp01: Fix due to API changes
Commit …
5
@9bfad8c
06/08/16 20:22:46 |
Sebastian Huber |
score: Add thread priority to scheduler nodes
The thread priority is …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@c82835a
06/21/16 15:12:40 |
Sebastian Huber |
rtems: Rework RTEMS API to SuperCore? priority
Use same structure as …
5
@ce6e9ec2
06/14/16 04:50:38 |
Sebastian Huber |
posix: pthread_mutexattr_setprioceiling()
Accept all priority values …
5
@3d9fd2ce
06/21/16 12:30:13 |
Sebastian Huber |
sptests/sp20: Use printer task
This avoids test failures due to slow …
5
@506bfc8
06/21/16 11:30:15 |
Sebastian Huber |
Move printer initialization to separate header
The RTEMS print user …
5
@ede1a41
06/21/16 11:12:31 |
Sebastian Huber |
Make rtems/print.h independent of rtems/bspIo.h
5
@e8020d1
06/21/16 11:28:01 |
Sebastian Huber |
Rename and move RTEMS_PRINTF_ATTRIBUTE()
Rename …
5
@7222a65
06/21/16 07:45:39 |
Sebastian Huber |
sptests/spcpucounter01: Resurrect workaround
Resurrect workaround …
5
@3e2a3c4
06/20/16 11:55:37 |
Sebastian Huber |
sptests/spcpucounter01: Add some statistics
5
@bc47ec1c
06/20/16 04:50:12 |
Sebastian Huber |
score: Refine system initialization order
5
@6a6a225
06/20/16 06:10:51 |
Sebastian Huber |
sptests/spsysinit01: Move begin of test message
5
@6131b84
03/09/16 21:15:37 |
joel |
Add pthread_condattr_getclock() and pthread_condattr_setclock()
5
@018cf74
05/04/16 14:32:07 |
joel |
mptests/mp03/task1.c: Make method static to fix warning
5
@07ac1735
04/22/16 01:15:40 |
joel |
samples/base_mp/apptask.c: Fix warning and clean up
5
@661e0e63
06/15/16 09:18:10 |
Sebastian Huber |
psxtests/psx12: Use and print proper rounded ms
Update #2738.
5
@917884c
06/15/16 08:39:09 |
Sebastian Huber |
posix: Fix poradic server initial CPU budget
Update #2738.
5
@d6467102
06/15/16 07:04:29 |
Sebastian Huber |
psxtests/psx12: Use one file and simplify
5
@6a631da
06/14/16 09:13:22 |
Sebastian Huber |
posix: sched_get_priority_max()
Enable for all configurations since …
5
@ea02782a
06/14/16 09:12:19 |
Sebastian Huber |
posix: sched_get_priority_min()
5
@0c34dbf3
06/13/16 13:22:47 |
Sebastian Huber |
posix: Add pthread_setschedprio()
Close #2734.
5
@fc30ac5
06/13/16 13:10:31 |
Sebastian Huber |
posix: Fix pthread_setschedparam()
Close #2735.
5
@23b1bb38
06/13/16 04:53:27 |
Sebastian Huber |
posix: Fix pthread_getschedparam()
Return the unmodified thread …
5
@05b7eec
06/08/16 13:18:14 |
Sebastian Huber |
score: Add an SMP sequence lock implementation
5
@4c19e59b
06/08/16 08:01:44 |
Sebastian Huber |
smptests/smpatomic01: Fix seqlock write
5
@cc8bb9e3
06/07/16 13:26:52 |
Sebastian Huber |
smptests/smpatomic01: Add seqlock test case
5
@3ad5f86
06/03/16 06:15:21 |
Sebastian Huber |
rtems: Fix no protocol mutex release
The Classic binary semaphores …
5
@d84e346b
05/18/16 23:18:21 |
Chris Johns |
libmisc/untar: Support directory create and overwrites. Share the …
5
@a9cc6a84
06/01/16 07:50:44 |
Sebastian Huber |
smptests/smpatomic01: New test cases
Demonstrate that a …
5
@73f2ddb
05/30/16 08:43:31 |
Sebastian Huber |
rtems: Fix semaphore field name
5
@09c5ca4
05/26/16 20:29:56 |
Sebastian Huber |
score: Simplify CORE mutex
Remove superfluous support for simple …
5
