@441dc1c
10/22/14 18:47:25 |
Jennifer Averett |
smp02: Resolve unused method warnings.
4.115
@4375b3b6
10/22/14 18:45:38 |
Jennifer Averett |
smp03: Remove set but not used warning.
Added status validation.
4.115
@689cba2
10/22/14 18:44:02 |
Jennifer Averett |
smpschedsem01: Remove unused variable warning.
4.115
@15e371f
10/22/14 13:42:59 |
Jennifer Averett |
smpschedaffinity02: Remove unused prototype.
4.115
@7e5c9b89
11/25/14 13:58:13 |
Sebastian Huber |
rtems: Move rtems_cache_aligned_malloc()
Make sure also the size is …
4.115
@7981a88
11/25/14 07:39:46 |
Sebastian Huber |
sptest/spcache01: New test cases
4.115
@44da98f
10/24/14 19:37:24 |
Jennifer Averett |
smpcapture01: New test.
4.115
@11b3ba1
10/03/14 13:47:14 |
Jennifer Averett |
capture01: Use capture engine print methods.
4.115
@f7d2795
11/24/14 19:57:21 |
Joel Sherrill |
testsuites/.../tmacros.h: Add parentheses to fix warning
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
smp: Fix scheduler helping protocol
New test case for …
4.115
@6570876
11/23/14 16:40:14 |
Joel Sherrill |
termio05: Remove unreferenced files
The functionality was …
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@db44590c
11/11/14 16:21:02 |
Jennifer Averett |
smpschedaffinity05: Change semaphore attributes.
Change semaphore …
4.115
@1960dcb9
11/12/14 14:42:13 |
Jennifer Averett |
smpschedaffinity04: Change semaphore attributes.
Change semaphore …
4.115
@bc95f816
11/12/14 14:42:48 |
Jennifer Averett |
smpschedaffinity02: Change semaphore attributes.
Change semaphore …
4.115
@163519a0
11/19/14 19:57:37 |
Joel Sherrill |
libtests/malloctest/init.c: Fix warning
posix_memalign() is …
4.115
@a634feb
11/20/14 08:15:19 |
Sebastian Huber |
dl01,dl02: Avoid non-runnable $(EXEEXT) files
4.115
@e02d5dd9
11/17/14 12:35:58 |
Sebastian Huber |
Ensure security of default user environment
4.115
@fa028bb
11/17/14 10:55:27 |
Sebastian Huber |
shell: Do chroot() after successful login
4.115
@065d72ce
11/17/14 09:19:00 |
Sebastian Huber |
shell: Get supplementary group IDs in login check
4.115
@b8bd90f6
11/17/14 08:01:53 |
Sebastian Huber |
Add supplementary groups to user environment
4.115
@0b3fcf5
11/18/14 09:42:45 |
Sebastian Huber |
samples/fileio: Use unlimited objects
4.115
@ab085c9
11/18/14 09:42:34 |
Sebastian Huber |
samples/fileio: Fix warning
4.115
@ffa71f1
11/17/14 06:53:01 |
Sebastian Huber |
libcsupport: Implement getgroups()
4.115
@395e5d4
11/14/14 14:33:57 |
Sebastian Huber |
libcsupport: Use POSIX key for getgrent()
4.115
@acf9a8d
11/14/14 13:31:54 |
Sebastian Huber |
shell: Use crypt_r() in rtems_shell_login_check()
Use '*" to disable …
4.115
@002f351
11/14/14 13:30:36 |
Sebastian Huber |
libcsupport: Minimal /etc/passwd and /etc/group
Create a minimal …
4.115
@6935428
11/14/14 10:30:50 |
Sebastian Huber |
libcsupport: Avoid TOCTOU and format errors
4.115
@4466321
11/13/14 14:13:24 |
Sebastian Huber |
Add crypt_r(), etc.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), …
4.115
@1bcd0378
11/13/14 12:18:24 |
Sebastian Huber |
Add SHA256 and SHA512 support
4.115
@0510cfd8
11/11/14 11:41:58 |
Sebastian Huber |
Add NXP PCA9548A 8-channel switch I2C driver
4.115
@67ac69fc
11/07/14 12:50:01 |
Sebastian Huber |
Add NXP PCA9535 16-bit GPIO I2C driver
4.115
@cce46780
11/07/14 12:49:29 |
Sebastian Huber |
Add generic EEPROM I2C device driver
4.115
@41c5f1b7
11/07/14 12:47:39 |
Sebastian Huber |
Add I2C driver framework
This I2C driver framework has some major …
4.115
@3eade710
11/20/14 07:52:50 |
Sebastian Huber |
libtests/top: End test after some time if no input
4.115
@f98abbe
11/06/14 02:08:48 |
Chris Johns |
libdl: Disable building libdl for the NIOS2. No relocation support.
4.115
@540b7b41
11/04/14 05:31:50 |
Chris Johns |
libtests: Add libdl test dl02.
Loads 2 interdependent ELF object files.
4.115
@d52c9e4d
11/04/14 05:30:08 |
Chris Johns |
libtests: Update dl01 documentation.
4.115
@c58f90b
11/03/14 00:54:55 |
Joel Sherrill |
dl01/dl-load.c: Add missing const
4.115
@ae5fe7e6
10/27/14 01:09:41 |
Chris Johns |
cpukit: Add libdl with the Runtime Loader (RTL) code.
This is a merge …
4.115
@410bcdfe
09/29/14 19:31:18 |
Jennifer Averett |
top: Add new test.
4.115
@254b7db0
09/08/14 14:47:13 |
Jennifer Averett |
capture01: Remove capture task tracking.
This involved adding a new …
4.115
@d412e2f
10/24/14 07:18:38 |
Sebastian Huber |
smptests/smpfatal03: Wait for end of test msg
4.115
@092b8c5
10/24/14 05:21:51 |
Sebastian Huber |
tests/smptests: Normal use of test extension
4.115
@17889b2
10/23/14 15:15:47 |
Sebastian Huber |
tests/smptests: Use barriers in smpfatal0{12}
Call the test extension …
4.115
@3e739ae
10/23/14 07:42:18 |
Sebastian Huber |
testsuites: Move include for C++ compatibility
4.115
@66c1ef9
10/17/14 12:46:13 |
Sebastian Huber |
Revert "fstests/mdosfs_fstime: Remove test"
This reverts commit …
4.115
@43633ae
10/14/14 10:12:32 |
Sebastian Huber |
testsuites: Avoid clock driver
4.115
@945f31b9
10/13/14 16:13:11 |
Joel Sherrill |
nsecs/init.c: Use long to avoid overflow on 16-bit targets
4.115
@a38ced2
10/10/14 07:09:19 |
Sebastian Huber |
score: Rework global construction
Ensure that the global construction …
4.115
@78a38fa2
10/08/14 22:38:12 |
Joel Sherrill |
Eliminate use of /*PAGE and clean up formatting
4.115
@eb7f306d
10/07/14 22:43:35 |
Joel Sherrill |
samples/base_sp: Fix printf() warning
4.115
@51a95ff9
10/07/14 22:43:18 |
Joel Sherrill |
samples/unlimited: Fix printf() warning and clean up
4.115
@22cd282
10/08/14 09:24:36 |
Sebastian Huber |
IMFS: Avoid NULL pointer access
Avoid NULL pointer access in …
4.115
@b9f95225
10/08/14 08:31:36 |
Sebastian Huber |
posix: Add auto initializaton for rwlock
4.115
@7fd5e89
10/07/14 14:28:04 |
Sebastian Huber |
termios: Partially hide rtems_termios_tty
Move interrupt lock to …
4.115
@a830cb8
10/07/14 14:27:51 |
Sebastian Huber |
termios: Separate flow control from normal handler
4.115
@805360b
09/23/14 12:20:35 |
Sebastian Huber |
pppd: Fix warnings
4.115
@6f1e1b3
09/19/14 12:18:00 |
Sebastian Huber |
sptests/spintrcritical22: New test
4.115
@8f0a2c9
09/17/14 08:28:13 |
Sebastian Huber |
smptests/smpload01: Report profiling only once
Rely on test extension …
4.115
@8fbe2e6
09/04/14 13:59:49 |
Joel Sherrill |
Use correct prototype of benchmark_timer_read()
This change starts …
4.115
@7f8a978
09/16/14 13:43:15 |
Sebastian Huber |
sptests/sp07: Minimize thread dispatch latency
Do not use sprintf() …
4.115
@6e1206a
09/11/14 15:55:34 |
cederman |
smptests/smpcache01: Remove invalidation of data cache lines from test …
4.115
@f9eca790
09/12/14 14:04:40 |
Sebastian Huber |
sptests/spintrcritical_support: Optimize busy loop
4.115
@73b5d8bf
09/12/14 14:04:01 |
Sebastian Huber |
sptests/spintrcritical10: Avoid undefined memory
4.115
@f3508c44
09/11/14 05:33:16 |
Sebastian Huber |
tmtests/tmcontext01: Improve cache dirty function
Increment by cache …
4.115
@e09f8b08
09/10/14 12:46:03 |
Sebastian Huber |
sptests/spfatal07: Fix end of test message
4.115
@4984ee4
09/09/14 15:13:51 |
Sebastian Huber |
sptests/sp39: Convert to sptests/spintrcritical21
Use interrupt …
4.115
@b5f9ad2
09/09/14 14:49:20 |
Sebastian Huber |
psxtests/psxonce01: Use test extension
4.115
@8028089
09/08/14 13:18:07 |
Sebastian Huber |
tests: Rework interrupt critical tests
This avoids test durations of …
4.115
@6821a629
09/08/14 08:19:42 |
Sebastian Huber |
Add -std=gnu++11 to CXXFLAGS if SMP is enabled
This is necessary to …
4.115
@8d30713d
09/05/14 11:33:57 |
Sebastian Huber |
4.115
@07b4594
09/05/14 07:27:41 |
Sebastian Huber |
sptests/spcontext01: Fix warning
4.115
@b2356837
09/05/14 06:24:52 |
Sebastian Huber |
tmtests/tmcontext01: Plot a legend
4.115
@a864016f
09/03/14 15:21:21 |
Joel Sherrill |
spcpuset01: Use %zd for size_t to eliminate warning
4.115
@de549c3
09/03/14 15:16:43 |
Joel Sherrill |
Misc psxtmtests: Use uint32_t not long for end_time to match printf() …
4.115
@9aa6ddf
09/03/14 15:07:28 |
Joel Sherrill |
spfreechain01/init.c: Use %zd for size_t to eliminate warning
4.115
@e1462e1
09/02/14 17:30:25 |
Joel Sherrill |
sp19: Eliminate warnings
4.115
@be4992b1
09/02/14 23:00:44 |
Joel Sherrill |
raspberrypi: Use shared bspreset.c
4.115
@8ae6f26
09/01/14 15:16:53 |
Sebastian Huber |
samples/iostream: Produce proper begin/end message
4.115
@5689d72
09/01/14 14:12:42 |
Sebastian Huber |
smptests/smplock01: Update screen file
4.115
@5cb5342
09/01/14 11:28:30 |
Sebastian Huber |
libtests/capture01: Fix test name
4.115
@979d95e
09/01/14 08:08:12 |
Sebastian Huber |
libtests/capture01: Force error if SMP enabled
This prevents infinite …
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@c147a139
09/01/14 06:45:23 |
Sebastian Huber |
smptests/smpfatal08: Fix link error
4.115
@96ec8ee8
08/22/14 15:09:36 |
Sebastian Huber |
rtems: Add more clock tick functions
Add rtems_clock_tick_later(), …
4.115
@23b14f87
08/22/14 20:20:16 |
Hesham Almatary |
sptests/spcache01: Make inline assembly conditional to account for …
4.115
@9a9ab85
07/03/14 14:42:24 |
cederman |
smptests/smpcache01: Test the SMP cache manager
Invokes SMP cache …
4.115
@bba3507
08/19/14 15:43:36 |
Sebastian Huber |
score: PR2179: Fix initially locked PI mutex
4.115
@0b9fe3ec
08/07/14 17:41:25 |
Sebastian Huber |
sptests/sprbtree01: Add random ops test case
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@d472d21
08/05/14 12:07:07 |
Sebastian Huber |
sptests/sprbtree01: Check tree layout
4.115
@888edf6
08/05/14 11:52:45 |
Sebastian Huber |
sptests/sprbtree01: Reduce stack usage
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
