@382d653
08/10/18 13:23:01 |
joel |
libtests/POSIX: Fix warnings and style.
5
@fd27bae
08/07/18 04:25:47 |
Sebastian Huber |
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Make …
5
@97417bb
08/07/18 05:09:55 |
Sebastian Huber |
tests: Remove CONFIGURE_MAXIMUM_DRIVERS
This configuration is …
5
@0b038bd4
08/04/18 08:38:48 |
Sebastian Huber |
libblock: Add RTEMS_DEPRECATED
Close #3358.
5
@b152d33
08/06/18 04:26:50 |
Sebastian Huber |
fileio: Avoid deprecated rtems_disk_obtain()
Update #3358.
5
@dd66fda
08/04/18 08:47:56 |
Sebastian Huber |
tests: Avoid deprecated rtems_disk_io_initialize()
Update #3358.
5
@bf80279
08/03/18 20:30:55 |
Sebastian Huber |
libtests/block15: Use rtems_blkdev_create()
Update #3358.
5
@fa12e06d
08/03/18 20:28:31 |
Sebastian Huber |
libtests/block14: Use rtems_blkdev_create()
Update #3358.
5
@3278d20
08/03/18 20:25:40 |
Sebastian Huber |
libtests/block13: Use rtems_blkdev_create()
Update #3358.
5
@5e4bab7
08/03/18 20:21:20 |
Sebastian Huber |
libtests/block12: Use rtems_blkdev_create()
Update #3358.
5
@6f34f13
08/03/18 20:16:32 |
Sebastian Huber |
libtests/block10: Use rtems_blkdev_create()
Update #3358.
5
@5005bfc
08/03/18 19:19:19 |
Sebastian Huber |
libtests/block09: Use rtems_blkdev_create()
Update #3358.
5
@117f7b1
08/03/18 16:18:56 |
Sebastian Huber |
libtests/block08: Use rtems_blkdev_create()
Update #3358.
5
@bde8be2
08/01/18 04:38:41 |
Sebastian Huber |
libtests/block06: Use rtems_blkdev_create()
Update #3358.
5
@6782771
08/04/18 12:24:05 |
Sebastian Huber |
libtests/block05: Avoid uninitialized variable
Update #3358.
5
@0fe7133
07/31/18 14:01:17 |
Sebastian Huber |
flashdisk: Use rtems_blkdev_create()
Update #3358.
5
@16f3f10
07/31/18 13:54:29 |
Sebastian Huber |
nvdisk: Use rtems_blkdev_create()
Update #3358.
5
@24b94c4
07/30/18 04:39:09 |
Sebastian Huber |
ramdisk: Use rtems_blkdev_create()
Update #3358.
5
@d906ce3
07/30/18 05:51:39 |
Sebastian Huber |
libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE
Using …
5
@65f52d0
07/25/18 09:25:30 |
Sebastian Huber |
samples/minimum: Use default interrupt stack size
Update #3433.
5
@a1f7d7d
07/24/18 07:00:18 |
Sebastian Huber |
score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Add …
5
@4678d1a
07/24/18 08:50:39 |
Sebastian Huber |
bsps: bsp_start_on_secondary_processor()
Pass current processor …
5
@91f39a5
07/24/18 09:56:25 |
Sebastian Huber |
smptests: Fix format warnings
5
@bf199e0c
07/24/18 10:47:26 |
Sebastian Huber |
block05: Remove unused variable
5
@bded3f05
07/24/18 10:46:32 |
Sebastian Huber |
psxthreadname01: Fix out of bounds memory access
5
@001b9925
07/24/18 10:46:02 |
Sebastian Huber |
psxtimer02: Fix parameter type cast
5
@f133386
07/24/18 10:45:43 |
Sebastian Huber |
sptests/sp20: Remove unused variable
5
@c192109f
07/24/18 08:06:20 |
Sebastian Huber |
samples: Fix warnings
5
@3a646426
07/19/18 10:53:34 |
Sebastian Huber |
score: Add _CPU_Instruction_illegal()
On some …
5
@b74353e
07/20/18 06:06:46 |
Sebastian Huber |
score: Add _CPU_Instruction_no_operation()
This helps to reduce the …
5
@42f2fdfd
07/20/18 05:56:43 |
Sebastian Huber |
score: Move context validation declarations
The context validation …
5
@ffd4617
07/17/18 13:33:49 |
Sebastian Huber |
score: Fix _Scheduler_EDF_SMP_Set_affinity()
Commit …
5
@6ec7f21
07/16/18 06:31:05 |
Sebastian Huber |
posix: Fix rwlock auto initialization
Add more test cases.
5
@22d9575
07/04/18 14:12:14 |
Sebastian Huber |
linux: Add rbtree_postorder_for_each_entry_safe()
Update #3465.
5
@6539bea
06/29/18 18:00:28 |
Sebastian Huber |
score: Add postorder tree iteration support
Update #3465.
5
@2086948a
05/11/18 04:54:59 |
Sebastian Huber |
riscv: Add dummy SMP support
Update #3433.
5
@511dc4b
06/19/18 07:09:51 |
Sebastian Huber |
Rework initialization and interrupt stack support
Statically …
5
@ebc5cfd
06/18/18 05:06:01 |
Sebastian Huber |
spmisc01: Add test cases for basedefs.h stuff
5
@fe46647e
06/15/18 14:53:27 |
Sebastian Huber |
score: Macros to declare and define global symbols
Add …
5
@4c7b18e3
05/22/18 07:14:07 |
Sebastian Huber |
Add RTEMS_SYSINIT_CPU_COUNTER
Add initialization step for the CPU …
5
@e8b28ba
06/07/18 04:37:39 |
Sebastian Huber |
tools: Remove packhex
All tools should be removed from the RTEMS …
5
@ea092ccc
06/07/18 04:13:38 |
Sebastian Huber |
tools: Remove rtems-bin2c
This tool is now included in the RTEMS …
5
@de9b7d7
06/01/18 05:04:45 |
Sebastian Huber |
Add RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE
An invalid heap usage such …
5
@c934365f
06/05/18 06:06:15 |
Sebastian Huber |
Update rtems_fatal_source_text()
Add RTEMS_FATAL_SOURCE_PANIC to …
5
@75933d5d
06/04/18 05:33:55 |
Sebastian Huber |
capture: Use unlimited objects
Avoid resource allocation problems …
5
@baee0dc5
05/15/18 09:21:55 |
martinerikwerner.aac |
Fix and extend error message in posix timer test
_Timespec_Equal_to() …
5
@877f5d6
05/25/18 08:35:39 |
Sebastian Huber |
sptests: Remove CONFIGURE_MILLISECONDS_PER_TICK
This configuration …
5
@df71100c
05/21/18 22:57:50 |
joel |
dltests-broken-on-this-bsp.tcfg: Add dl06
5
@70502b48
03/20/18 15:07:14 |
Sebastian Huber |
libtests/block05: Use rtems_blkdev_create()
Update #3358.
5
@30c3898
03/03/18 12:24:42 |
Sebastian Huber |
libblock: Init deps in rtems_blkdev_create()
Update #3358.
5
@02c46f85
05/04/18 13:25:46 |
Sebastian Huber |
spcpucounter01: Enable floating-point output
5
@fea9a7a
04/30/18 07:48:13 |
Sebastian Huber |
ftpfs: Always build FTP client
Move FTP client filesystem to separate …
5
@dd8e4b7
04/30/18 07:09:27 |
Sebastian Huber |
libdebugger: Move to separate library
Always build remote TCP support …
5
@97a48209
04/27/18 04:18:41 |
Sebastian Huber |
tests: Move rtems-test-check.py
Remove shell script variant.
5
@397df7a
04/26/18 14:15:01 |
Sebastian Huber |
tests: Remove difftest and sorttimes tools
Close #3418.
5
@b422aa3f
04/26/18 14:05:45 |
Sebastian Huber |
tests: Remove configure feature checks
Update #3409.
5
@c77cd426
04/30/18 22:18:49 |
joel |
Drop executable permissions on .[ch] files
5
@8b5a801
04/27/18 05:20:27 |
Sebastian Huber |
smptests/smpschededf02: Add test case
5
@adb85dd
04/21/18 08:22:08 |
Sebastian Huber |
bsps: Move make/custom/* files to bsps
Adjust various build files. …
5
@5e8a24ca
04/23/18 08:35:35 |
Sebastian Huber |
smptests/smpschedaffinity02: Fix configuration
5
@ad071b68
04/22/18 13:54:56 |
Sebastian Huber |
sptests/sp36: Remove obsolete test program
It tests the (never really …
5
@234f0a2d
04/20/18 12:41:05 |
Sebastian Huber |
build: Remove subdir-objects from Ada tests
Somehow it does not work. …
5
@9964895
04/20/18 08:35:35 |
Sebastian Huber |
bsps: Move startup files to bsps
Adjust build support files to new …
5
@1b2681fe
04/12/18 15:13:48 |
joel |
Multiple BSP tcfg: Disable iconv files.
5
@696b9121
04/12/18 07:48:28 |
Chris Johns |
libdl: Fix the tests loading the correct files
5
@86e79d7
04/12/18 04:52:36 |
Chris Johns |
testsuites/dl06: Add a test for RAP format.
This test loads a RAP …
5
@af6168c6
04/11/18 05:45:38 |
Chris Johns |
build: Add support for automake's silent build support.
5
@b8c59353
04/11/18 03:26:58 |
Chris Johns |
build: Fix make clean.
Update #3254.
5
@aa567bc1
04/10/18 06:06:39 |
Chris Johns |
configure: Add subdir-objects to all automake flags.
This option …
5
@7ff743d
04/10/18 00:32:25 |
Chris Johns |
Generate an error if a BSP in the --enable-rtemsbsp list is not valid
5
@9e8df1fe
04/10/18 05:02:01 |
Chris Johns |
fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes.
Add …
5
@2eaea422
04/10/18 10:38:10 |
Sebastian Huber |
sptests: Fix AM_CONDITIONAL
Update #3382.
5
@ee3d7dcb
04/09/18 03:46:17 |
Chris Johns |
testsuites: Remove the test check from the subdir support.
Leave the …
5
@cc14545e
04/09/18 03:45:48 |
Chris Johns |
testsuite/tmtests: Merged nested Makefile.am files into one …
5
@bc06753
04/09/18 03:45:15 |
Chris Johns |
testsuite/sptests: Merged nested Makefile.am files into one …
5
@8074fa0b
04/09/18 03:44:37 |
Chris Johns |
testsuite/smptests: Merged nested Makefile.am files into one …
5
@d027e6bb
04/09/18 03:44:01 |
Chris Johns |
testsuite/samples: Merged nested Makefile.am files into one …
5
@590a5809
04/09/18 03:43:30 |
Chris Johns |
testsuite/irhealstone: Merged nested Makefile.am files into one …
5
@dfc57eb
04/09/18 03:42:49 |
Chris Johns |
testsuite/psxtmtests: Merged nested Makefile.am files into one …
5
@2a99a6a
04/09/18 03:42:02 |
Chris Johns |
testsuite/psxtests: Merged nested Makefile.am files into one …
5
@3206879f
04/09/18 03:41:08 |
Chris Johns |
testsuite/mptests: Merged nested Makefile.am files into one …
5
@8967e5f
04/09/18 03:40:29 |
Chris Johns |
testsuite/fstests: Merged nested Makefile.am files into one …
5
@5c65b988
04/09/18 03:39:19 |
Chris Johns |
testsuite/libtests: Merged nested Makefile.am files into one …
5
@32f2629b
04/09/18 03:35:17 |
Chris Johns |
testsuite/benchmarks: Merged nested Makefile.am files into one …
5
@18f77699
04/08/18 22:18:46 |
Chris Johns |
testsuite: Autoconf test check support.
The autoconf function checks …
5
@9edb72e
04/05/18 04:56:26 |
Sebastian Huber |
build: Remove DISTCLEANFILES
A "make distclean" is not supported. So, …
5
@2d0bc83
03/30/18 18:42:21 |
Sebastian Huber |
build: Remove EXTRA_DIST
A "make dist" is not supported. So, it makes …
5
@6fadb7af
03/08/18 05:33:24 |
Sebastian Huber |
config: Use new scheduler configuration defines
Update #3325.
5
@828049cb
03/08/18 07:48:28 |
Sebastian Huber |
sptests/sp19: Fix test output methods
Do not use fprintf() in non-fp …
5
@a4151d0
03/07/18 12:00:44 |
Sebastian Huber |
libtests/capture01: Fix configuration
5
@ff281a6f
03/07/18 09:31:10 |
Sebastian Huber |
smptests: Fix obsolete FIXME comments/code
5
@337a186
02/21/18 11:40:18 |
Sebastian Huber |
Add a simple task console driver
Close #3320.
5
@8b2d5b8
02/28/18 12:02:55 |
Sebastian Huber |
spglobalcon02: New test
Update #3319.
5
@0d44e251
02/22/18 15:37:26 |
Sebastian Huber |
ada/sp04: Fix test failure due to compiler opti
The SPTEST.RUN_COUNT …
5
@a3eec5c
02/09/18 12:17:45 |
Sebastian Huber |
fsclose01: Fix task mode, use attribute
Update #1971.
5
@48aa4b5d
02/09/18 12:14:18 |
Sebastian Huber |
fsclose01: Use floating-point task
The tmpfile() uses sprintf().
5
@dc8fd01
02/09/18 07:56:20 |
Sebastian Huber |
tests: Support %g print format specifier
5
@d9800ac
01/03/18 05:36:10 |
Sebastian Huber |
libdl: Use self-contained recursive mutex
Update #2843.
5
@53b6484
02/05/18 08:57:45 |
Sebastian Huber |
termios: Remove obsolete configuration options
Update #2843.
5
@4ac5ffbb
02/05/18 08:31:32 |
Sebastian Huber |
fsclose01: Add tmpfile() test case
Close #1971.
5
