@33b72fd
03/06/15 15:13:40 |
alexander.krutwig |
testsupport: Add cascade option to parallel test
4.115
@7d6e94b
03/04/15 07:02:19 |
Sebastian Huber |
score: Implement fine-grained locking for events
Use the ISR lock of …
4.115
@222dc775
02/26/15 09:32:08 |
Sebastian Huber |
score: Add and use _Thread_Do_dispatch()
The _Thread_Dispatch() …
4.115
@b8a5abf
02/26/15 09:33:36 |
Sebastian Huber |
score: Update _Thread_Heir only if necessary
Previously, the …
4.115
@d0061287
03/05/15 09:11:23 |
Sebastian Huber |
tests: Fix warnings
4.115
@7f577d3
03/05/15 08:06:44 |
alexander.krutwig |
tests: Refactor parallel test execution
4.115
@461a930
03/04/15 20:53:36 |
Joel Sherrill |
capture01: Update screen file
4.115
@57a914a3
03/03/15 21:15:00 |
Joel Sherrill |
Add simple test for scandir() on all file systems tested
updates 1394
4.115
@56c7192
03/03/15 16:08:51 |
Gedare Bloom |
psxtests/psxclock01: use clock() and CLOCKS_PER_SEC
Closes #2182
4.115
@e50297e
03/04/15 09:15:02 |
Sebastian Huber |
score: ISR lock C/C++ compatiblity issue
Empty structures are …
4.115
@c5436ff4
03/04/15 10:56:25 |
Sebastian Huber |
smptests/smpcapture01: Avoid livelock condition
4.115
@0324410
02/26/15 09:26:49 |
Sebastian Huber |
smptests: Do not use Giant directly
This ensures that thread …
4.115
@6357e14a
02/26/15 11:55:43 |
Sebastian Huber |
psxtests/psx05: Adjust test case
Update #2170.
4.115
@bd1c9248
02/26/15 09:19:38 |
Sebastian Huber |
sptests/sp76: Check that the right task executes
4.115
@83fe4468
02/23/15 14:59:49 |
Gedare Bloom |
psxtests: add string param to printf. closes #2241
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@a3316f47
02/19/15 10:12:01 |
Sebastian Huber |
sptests: Add missing test extension
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@f785492
02/14/15 19:07:19 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR
4.115
@249766c5
02/13/15 20:26:17 |
Sebastian Huber |
IMFS: Rename CONFIGURE_IMFS_DISABLE_FCHMOD
Rename …
4.115
@40a18d7f
02/13/15 20:11:55 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_MKNOD_FILE
4.115
@12eee4fd
02/13/15 19:53:41 |
Sebastian Huber |
IMFS: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
Resurrect …
4.115
@b57a6a7
02/11/15 19:59:29 |
Joel Sherrill |
psxhdrs: Reorganize into subdirectories per .h file and rename files
4.115
@86076f3
02/11/15 19:31:30 |
Joel Sherrill |
psxhdrs: Remove test of pthread_attr_[gs]et_cputime
These methods are …
4.115
@eedaf9b
02/11/15 20:00:35 |
Joel Sherrill |
psxhdrs: Add tests for <sys/socket.h> API compliance
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@60cf8a5
02/06/15 15:32:39 |
Sebastian Huber |
IMFS: Add root directory to FS info
Fix memory leak in IMFS_fsunmount().
4.115
@24ec25d
02/05/15 15:14:59 |
Sebastian Huber |
IMFS: Introduce IMFS_mknod_control
Drop IMFS_node_control::node_size …
4.115
@8d8573ac
02/04/15 09:04:05 |
cederman |
smpcapture02: Add test of functionality to add custom entries to …
4.115
@16939b18
02/09/15 18:09:23 |
Sebastian Huber |
Filesystem: Simplify FIFO and pipe configuration
4.115
@b4e52ce9
02/06/15 20:12:38 |
Sebastian Huber |
fstests/fsrename: Avoid double initialization
4.115
@efd2965a
02/02/15 14:25:26 |
Sebastian Huber |
Filesystem: Statically initialize rtems_libio_iops
4.115
@cf36b70
12/31/14 09:56:05 |
Sebastian Huber |
IMFS: Replace node union with individual struct
This reduces the …
4.115
@80bfd3a
01/23/15 15:46:48 |
Joel Sherrill |
psx07: Add missing parameter to printf() call
Close 2241.
Conflicts: …
4.115
@ffb1a45
01/23/15 11:49:44 |
Sebastian Huber |
psxtests/psx07: Fix printf() statement
Close #2240.
4.115
@c625a641
12/21/14 19:12:28 |
Sebastian Huber |
Filesystem: Delete node type operation
Use the fstat handler instead.
4.115
@f87ede5
01/15/15 13:13:19 |
Sebastian Huber |
libnetworking: Fix close of active sockets
Send a special event to …
4.115
@8a7048a
01/19/15 12:53:51 |
Marcos Diaz |
Fixed dl01 and dl02 makefiles
4.115
@77c5ddd4
01/14/15 06:34:44 |
Sebastian Huber |
smptests/smpmrsp01: Fix task delete race condition
Do not supsend …
4.115
@7f28f237
12/23/14 10:05:21 |
Sebastian Huber |
powerpc: Delete _CPU_IRQ_info
4.115
@b3ed66a
12/22/14 06:15:49 |
Sebastian Huber |
libtests/crypt01: Increase stack size
4.115
@e7d175af
01/08/15 09:43:56 |
Sebastian Huber |
smptests/smpwakeafter01: Fix task count
4.115
@ad0743db
12/22/14 14:10:32 |
Sebastian Huber |
smptests/smpmrsp01: Update run indicator only once
On the Freescale …
4.115
@864d3475
12/17/14 14:11:00 |
Sebastian Huber |
smp: Fix timeout for MrsP semaphores
The previous timeout handling …
4.115
@a0b1b5ed
12/15/14 13:19:43 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define was …
4.115
@f42d429
12/15/14 02:26:31 |
Nick Withers |
Enable WebSocket? support in the Mongoose HTTP server
4.115
@7bdb765
12/12/14 07:46:30 |
Sebastian Huber |
Add POSIX key value pairs to resource snapshot
4.115
@172e953
12/12/14 12:16:11 |
Sebastian Huber |
posix: Delete key/value if value is set to NULL
4.115
@9d9c426
03/07/14 03:23:30 |
Nick Withers |
Teach rtems_tarfs_load() about symlinks
4.115
@f3730d56
12/08/14 08:47:58 |
Sebastian Huber |
libtests/complex: Avoid multiple definitions
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@e870941
12/04/14 08:38:27 |
Sebastian Huber |
libmisc: More useful default configuration
The dummy.c was a de-facto …
4.115
@0104056
12/03/14 10:14:42 |
Sebastian Huber |
sptests: Add get_one_tick_busy_value()
Extract this function from …
4.115
@f54e503
12/02/14 09:35:13 |
Sebastian Huber |
libtests: Omit libdl tests if no RTEMS tools
4.115
@e7e92da
06/04/14 14:02:11 |
Daniel Hellstrom |
DEVFS04: make test work on LEON3-FT GR712RC
The LEON3 BSP have …
4.115
@9e8d8b5c
11/11/14 13:17:55 |
Daniel Hellstrom |
spcpuset01: fix test comments
4.115
@80d99aa
12/01/14 07:20:55 |
Sebastian Huber |
libtests/complex,math: Prevent optimizations
For constant arguments …
4.115
@01557b0
11/27/14 10:44:48 |
Sebastian Huber |
libcsupport: Delete malloc statistics
Use the heap handler statistics …
4.115
@0ff1c29
11/27/14 07:45:10 |
Sebastian Huber |
smptests/smpmrsp01: Use busy waits
Use busy waits instead of sleeps …
4.115
@5bd822a7
11/26/14 10:51:34 |
Sebastian Huber |
smp: Fix scheduler helping protocol
Ensure that scheduler nodes in …
4.115
@038faca1
11/25/14 15:47:20 |
Sebastian Huber |
rtems: Add rtems_cache_coherent_allocate()
Add …
4.115
@39af57c3
11/24/14 20:49:28 |
Jennifer Averett |
smp09: Resolve missing prototype warning.
4.115
@6291e962
11/24/14 20:48:58 |
Jennifer Averett |
smp07: Resolve missing prototype warning.
4.115
@2c474a0
11/24/14 20:48:31 |
Jennifer Averett |
smp05: Resolve missing prototype warning.
4.115
@441dc1c
10/22/14 18:47:25 |
Jennifer Averett |
smp02: Resolve unused method warnings.
4.115
@4375b3b6
10/22/14 18:45:38 |
Jennifer Averett |
smp03: Remove set but not used warning.
Added status validation.
4.115
@689cba2
10/22/14 18:44:02 |
Jennifer Averett |
smpschedsem01: Remove unused variable warning.
4.115
@15e371f
10/22/14 13:42:59 |
Jennifer Averett |
smpschedaffinity02: Remove unused prototype.
4.115
@7e5c9b89
11/25/14 13:58:13 |
Sebastian Huber |
rtems: Move rtems_cache_aligned_malloc()
Make sure also the size is …
4.115
@7981a88
11/25/14 07:39:46 |
Sebastian Huber |
sptest/spcache01: New test cases
4.115
@44da98f
10/24/14 19:37:24 |
Jennifer Averett |
smpcapture01: New test.
4.115
@11b3ba1
10/03/14 13:47:14 |
Jennifer Averett |
capture01: Use capture engine print methods.
4.115
@f7d2795
11/24/14 19:57:21 |
Joel Sherrill |
testsuites/.../tmacros.h: Add parentheses to fix warning
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
New test case for …
4.115
@6570876
11/23/14 16:40:14 |
Joel Sherrill |
termio05: Remove unreferenced files
The functionality was …
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@db44590c
11/11/14 16:21:02 |
Jennifer Averett |
smpschedaffinity05: Change semaphore attributes.
Change semaphore …
4.115
@1960dcb9
11/12/14 14:42:13 |
Jennifer Averett |
smpschedaffinity04: Change semaphore attributes.
Change semaphore …
4.115
@bc95f816
11/12/14 14:42:48 |
Jennifer Averett |
smpschedaffinity02: Change semaphore attributes.
Change semaphore …
4.115
@163519a0
11/19/14 19:57:37 |
Joel Sherrill |
libtests/malloctest/init.c: Fix warning
posix_memalign() is …
4.115
@a634feb
11/20/14 08:15:19 |
Sebastian Huber |
dl01,dl02: Avoid non-runnable $(EXEEXT) files
4.115
@e02d5dd9
11/17/14 12:35:58 |
Sebastian Huber |
Ensure security of default user environment
4.115
@fa028bb
11/17/14 10:55:27 |
Sebastian Huber |
shell: Do chroot() after successful login
4.115
@065d72ce
11/17/14 09:19:00 |
Sebastian Huber |
shell: Get supplementary group IDs in login check
4.115
@b8bd90f6
11/17/14 08:01:53 |
Sebastian Huber |
Add supplementary groups to user environment
4.115
@0b3fcf5
11/18/14 09:42:45 |
Sebastian Huber |
samples/fileio: Use unlimited objects
4.115
@ab085c9
11/18/14 09:42:34 |
Sebastian Huber |
samples/fileio: Fix warning
4.115
@ffa71f1
11/17/14 06:53:01 |
Sebastian Huber |
libcsupport: Implement getgroups()
4.115
@395e5d4
11/14/14 14:33:57 |
Sebastian Huber |
libcsupport: Use POSIX key for getgrent()
4.115
@acf9a8d
11/14/14 13:31:54 |
Sebastian Huber |
shell: Use crypt_r() in rtems_shell_login_check()
Use '*" to disable …
4.115
@002f351
11/14/14 13:30:36 |
Sebastian Huber |
libcsupport: Minimal /etc/passwd and /etc/group
Create a minimal …
4.115
@6935428
11/14/14 10:30:50 |
Sebastian Huber |
libcsupport: Avoid TOCTOU and format errors
4.115
@4466321
11/13/14 14:13:24 |
Sebastian Huber |
Add crypt_r(), etc.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), …
4.115
@1bcd0378
11/13/14 12:18:24 |
Sebastian Huber |
Add SHA256 and SHA512 support
4.115
@0510cfd8
11/11/14 11:41:58 |
Sebastian Huber |
Add NXP PCA9548A 8-channel switch I2C driver
4.115
@67ac69fc
11/07/14 12:50:01 |
Sebastian Huber |
Add NXP PCA9535 16-bit GPIO I2C driver
4.115
@cce46780
11/07/14 12:49:29 |
Sebastian Huber |
Add generic EEPROM I2C device driver
4.115
@41c5f1b7
11/07/14 12:47:39 |
Sebastian Huber |
Add I2C driver framework
This I2C driver framework has some major …
4.115
