@1ac4a85
02/25/21 18:08:52 |
Sebastian Huber |
score: Fix thread initialization
Close the thread object if a thread …
@c96644e8
02/24/21 13:45:47 |
Sebastian Huber |
libtest: Print SHA256 hash in base64url
@74eff26c
02/23/21 18:47:02 |
Sebastian Huber |
libtest: Report target hash
Update #4267.
@bc6ffc3
02/24/21 12:25:46 |
Sebastian Huber |
Add system initialization step for target hash
Update #4267.
@5f8bc83
02/23/21 12:25:00 |
Sebastian Huber |
score: Add _IO_Base64url()
Update #4267.
@006c702
02/21/21 16:48:04 |
Sebastian Huber |
validation: Simplify message queue construct tests
@fd838603
02/19/21 20:31:34 |
Sebastian Huber |
validation: Add missing barrier create test case
@3e7d658
02/15/21 13:02:49 |
Sebastian Huber |
validation: Add signal manager tests
Update #4244.
@f38c0de4
02/15/21 08:14:41 |
Sebastian Huber |
validation: Add Validation1 test suite
Update #4244.
@fafc923
02/05/21 09:15:48 |
Sebastian Huber |
validation: Tweak construct error tests
Unify the state names across …
@e59efd8
02/04/21 12:35:27 |
Sebastian Huber |
validation: Tests for barrier manager
@c9ceff9
02/03/21 16:21:23 |
Sebastian Huber |
validation: Add tests for rtems_build_name()
@8a95e6f8
02/02/21 13:23:52 |
Sebastian Huber |
rtems: Rework object services API
Add a "Constraints" paragraph to …
@a6689fb1
01/22/21 15:01:46 |
Sebastian Huber |
Improve file header comment in generated files
@70c34fb
01/23/21 19:01:43 |
Sebastian Huber |
splinkersets01: Fix declaration
GCC 11 produced warnings like this:
@8ee22b2
01/20/21 09:31:18 |
Sebastian Huber |
mrsp: Change error status for a nested seize
Return STATUS_DEADLOCK …
@f867e7b
12/04/20 08:10:47 |
niteesh.gs |
libtests/ofw01: Added a test for RTEMS OFW
This commit adds a basic …
@0e779a4c
12/09/20 07:20:44 |
Sebastian Huber |
smptests/smpipi01: Fix sporadic test failure
@2b56f5a
12/02/20 16:27:22 |
kinsey.moore |
samples/unlimited: Prevent compile error
For architectures with …
@13bab34
11/23/20 16:22:10 |
Sebastian Huber |
score: Return a status in _Objects_Set_name()
@9c20b987
11/26/20 18:53:25 |
Sebastian Huber |
rtems: Add <rtems/rtems/clockimpl.h>
@06386fc7
11/19/20 15:07:20 |
Sebastian Huber |
Use CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Update #4181.
@657e30c1
11/19/20 15:07:04 |
Sebastian Huber |
config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
In order to better …
@bc175a1
11/19/20 14:30:17 |
Sebastian Huber |
Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
Replace a runtime …
@99c73303
11/23/20 15:34:26 |
Sebastian Huber |
rtems: Improve rtems_interrupt_server_create()
Also start interrupt …
@c5af8aa0
11/19/20 07:40:13 |
Sebastian Huber |
config: Simplify task stack allocator init
Replace runtime checks …
@d6f13a46
11/11/20 16:14:53 |
Sebastian Huber |
validation/ts-performance-0: Add partition tests
@35c52a51
11/11/20 14:40:39 |
Sebastian Huber |
validation/ts-performance-0: Add test suite
Share a default test …
@eae22cc0
11/10/20 09:23:10 |
Sebastian Huber |
libtest: Make test case allocator configurable
@ced13022
11/11/20 07:15:02 |
Sebastian Huber |
Improve automatically generated warning
@dfe6b84
11/10/20 12:04:55 |
Sebastian Huber |
smpmulticast01: Fix NULL pointer access
@0a761a58
10/12/20 14:41:51 |
frank.kuehndel |
fsdosfsname01: Fix string truncation warning
This patch fixes a …
@ec13365
10/12/20 13:49:07 |
frank.kuehndel |
testsuites/samples/fileio - Increase of stack size
When I use the …
@4763ef8
10/05/20 14:23:01 |
frank.kuehndel |
psxndbm01 - Fixing string truncation warning
This fixes the following …
@0007d65
10/05/20 14:25:19 |
frank.kuehndel |
testsuits/dl10 : Prototype missing
Fix a compiler warning about a …
@558a19d3
10/08/20 08:14:14 |
Chris Johns |
testsuite/rcxx01: Add examples for use in the User manual
@69a35fb
10/08/20 11:25:47 |
Sebastian Huber |
validation: Improve file header comment
@cf95826
10/03/20 06:13:24 |
Chris Johns |
cpukit/librcxx: Add a C++ thread interface with attributes
@97e9728
09/30/20 12:21:32 |
Sebastian Huber |
rtems: Add RTEMS_PARTITION_ALIGNMENT
Update #4105.
@232fc52
10/02/20 19:18:06 |
kinsey.moore |
spmsgq_err01: Use correct max values and fix 64bit
Fix spmsgq_err01 …
@71689a07
09/30/20 14:22:04 |
Sebastian Huber |
rtems: Canonicalize name and id checks
Check the name followed by the …
@2d8802b
09/26/20 09:53:07 |
Sebastian Huber |
tests: Add and use <rtems/testopts.h>
Add the build option …
@2da7e94
09/30/20 10:53:33 |
Sebastian Huber |
libtests/sha: Fix test if -O0 is used
@febc6604
09/25/20 09:05:06 |
Sebastian Huber |
validation: Test rtems_message_queue_construct()
Update #4007.
@4a4f41e
09/23/20 14:47:58 |
Sebastian Huber |
rtems: Add rtems_message_queue_construct()
In contrast to message …
@69b4fe59
09/23/20 08:33:51 |
Sebastian Huber |
score: Simplify CORE_message_queue_Buffer
Merge …
@5bc7c37
09/23/20 08:09:37 |
Sebastian Huber |
score: Improve _CORE_message_queue_Initialize()
Return a status code …
@3dd4cbb
09/11/20 13:45:34 |
Sebastian Huber |
validation: rtems_task_construct() errors
This is the first test case …
@139ffa2
09/11/20 08:33:19 |
Sebastian Huber |
validation: Add general purpose test suite
Add a general purpose test …
@6942e5f
04/09/20 10:12:13 |
Sebastian Huber |
rtems: Add rtems_task_construct()
In contrast to rtems_task_create() …
@c312f31
09/10/20 14:35:09 |
Sebastian Huber |
CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Add this application …
@46477898
07/31/20 08:15:59 |
Sebastian Huber |
irqs01/smpirqs01: New tests
Close #4034.
@f3f0370f
07/19/19 11:09:43 |
Sebastian Huber |
build: Alternative build system based on waf
Update #3818.
@5959b1e
09/10/20 17:29:11 |
joel |
Remove tmoverhd which existed to produce the obsolete coverhd.h
@64d989d1
09/10/20 12:39:08 |
Sebastian Huber |
spintrcritical08: Increase clock tick interval
On some simulators, a …
@354c2b5
04/08/20 09:30:32 |
Sebastian Huber |
score: Add <rtems/score/freechainimpl.h>
Hide implementation details. …
@c7e3085
06/24/20 11:54:23 |
Sebastian Huber |
rtems: Add _RTEMS_Name_to_id()
Simplify object name to identifier …
@1a506170
08/21/20 11:46:21 |
Sebastian Huber |
spintrcritical22: Use right thread wait flags
@cd74bd0
08/21/20 11:43:34 |
Sebastian Huber |
spintrcritical16: Use right thread wait flags
@1bb2800
08/21/20 07:18:02 |
Sebastian Huber |
mp03: Include missing header file
@79fb536
08/20/20 06:31:47 |
Sebastian Huber |
spintrcritical23: Fix unused variable warnings
@218053d
08/20/20 06:31:30 |
Sebastian Huber |
sp37: Fix unused variable warnings
@65e027c9
08/18/20 15:52:56 |
aschref.ben-thabet |
psxkey01: Fix configuration
Key_ID array must have the right size, it …
@c7289484
08/14/20 07:56:51 |
Sebastian Huber |
libtest: Add T_push_plan() and T_pop_plan()
Update #3199.
@72960bc7
08/13/20 09:33:47 |
Sebastian Huber |
libtest: Change T_step() and T_assert_step()
Normally, the expected …
@5383d4db
08/13/20 07:59:19 |
Sebastian Huber |
libtest: Add fixture steps
Support a new test plan for each nested …
@5a8114c6
08/12/20 14:57:39 |
Sebastian Huber |
libtest: Change fixture scope method
Return the produced character …
@01677dd
08/11/20 08:03:25 |
Sebastian Huber |
spintrcritical23: Restore runner priority
@5d7ab6b
08/11/20 07:45:53 |
libtests/dl10: Delete unused functions
@c1354f0
08/07/20 18:30:39 |
Sebastian Huber |
libtest: Add T_thread_switch_record()
Add support to record thread …
@32f1f747
08/06/20 17:12:55 |
Sebastian Huber |
libtest: Fix T_interrupt_test() in SMP configs
Update #3199.
@6c4ca83
08/05/20 11:54:33 |
psxhdrs/strncpy/stpncpy: Fix string turncation warning
Since we need …
@81631de
08/04/20 10:27:54 |
Sebastian Huber |
smpschededf02: Document reset() function
@699f465c
07/30/20 12:47:03 |
psxhdrs/strncat: Fix string truncation warning
@4444094d
07/24/20 05:31:24 |
Sebastian Huber |
spmisc01: Include missing header file
Update #4032.
@6f94a83
04/08/20 08:20:51 |
Sebastian Huber |
score: Add RTEMS_WEAK
Update #4032.
@b2ff5fe
07/21/20 06:45:03 |
Sebastian Huber |
spintrcritical_support: Remove
This test support was replaced by …
@6b795cd7
07/20/20 05:45:51 |
Sebastian Huber |
spintrcritical24: Use T_interrupt_test()
@23b9debe
07/21/20 05:32:10 |
Sebastian Huber |
spintrcritical23: Use T_interrupt_test()
@1414e71
07/18/20 20:55:51 |
Sebastian Huber |
spintrcritical22: Use T_interrupt_test()
@59ee3020
07/20/20 10:51:49 |
Sebastian Huber |
spintrcritical21: Use T_interrupt_test()
@38636e23
07/21/20 05:19:30 |
Sebastian Huber |
spintrcritical20: Use T_interrupt_test()
@aebdd1da
07/20/20 13:57:08 |
Sebastian Huber |
spintrcritical18: Use T_interrupt_test()
@031e824
07/20/20 17:18:16 |
Sebastian Huber |
spintrcritical16: Use T_interrupt_test()
@1c2e05d4
07/20/20 15:44:42 |
Sebastian Huber |
spintrcritical15: Use T_interrupt_test()
@5020a28
07/20/20 14:35:04 |
Sebastian Huber |
spintrcritical13/14: Use T_interrupt_test()
@8cbba449
07/20/20 13:24:21 |
Sebastian Huber |
spintrcritical11/12: Use T_interrupt_test()
@be2f9d7
07/18/20 20:22:16 |
Sebastian Huber |
spintrcritical10: Use T_interrupt_test()
@a231276
07/20/20 14:12:02 |
Sebastian Huber |
spintrcritical09: Use T_interrupt_test()
@5f66ac86
07/20/20 12:00:31 |
Sebastian Huber |
spintrcritical08: Use T_interrupt_test()
@28313958
07/20/20 10:13:06 |
Sebastian Huber |
spintrcritical06/spintrcritical07: Remove tests
These two tests check …
@21f7333
07/20/20 11:07:46 |
Sebastian Huber |
spintrcritical01/2/3/4/5: Use T_interrupt_test()
@857a65d
07/20/20 09:50:53 |
Sebastian Huber |
psxintrcritical01: Use T_interrupt_test()
@cc3fd8fc
07/17/20 17:42:32 |
Sebastian Huber |
libtest: Add T_interrupt_test()
Update #3199.
@d702c9f4
07/18/20 12:41:36 |
Sebastian Huber |
libtest: Make check message optional
This macro magic is in line with …
@cb3c6bdc
06/09/20 13:55:22 |
Sebastian Huber |
libtest: Add push/pop fixture support
Update #3199.
@6b27e32
06/08/20 08:04:55 |
Sebastian Huber |
libtest: Support custom scope messages via fixture
Update #3199.
@af92665
07/17/20 12:49:42 |
Sebastian Huber |
libtest: Add T_get_one_clock_tick_busy()
Update #3199.
@e3e3b871
07/17/20 12:40:36 |
Sebastian Huber |
libtest: Add T_busy()
Update #3199.
@361404e8
07/17/20 11:46:24 |
Sebastian Huber |
libtest: Move <t.h> to <rtems/test.h>
Update #3199.
