@18b32d76
09/08/17 13:25:47 |
Sebastian Huber |
posix: Ignore pshared for semaphores
Since we have only one process, …
5
@fae59c9
09/06/17 08:12:06 |
Sebastian Huber |
dosfs: Support a cluster size of 64KiB
Close #3003.
5
@d85d2676
08/27/17 19:11:43 |
joel |
psxconfig01/init.c: Fix printf() format warnings
5
@8b29f9b9
08/27/17 19:11:24 |
joel |
sp25/task1.c: Fix printf() format warnings
5
@37f0023f
08/27/17 19:09:34 |
joel |
spstkalloc02/init.c: Fix printf() format warnings
5
@02b007e
08/25/17 12:39:38 |
Sebastian Huber |
Include missing <limits.h>
Update #2132.
5
@80a13ec4
08/24/17 06:42:57 |
Sebastian Huber |
samples/fileio: Give command availability hint
Close #3088.
5
@a8f4fd2
08/10/17 12:29:55 |
Sebastian Huber |
smptests: Fix format specifier
Update #3082.
5
@3ebbabb
07/28/17 20:53:21 |
joel |
psximfs02/init.c: Increase size of buffer to avoid overwrite
5
@bed7ec1
07/28/17 16:21:18 |
joel |
psxmmap01/init.c: Correct printf() format specifier
5
@77cbb2a
07/28/17 11:53:18 |
Sebastian Huber |
psxtests/psxmmap01: Fix warning
Update #2859.
5
@9d1522ed
07/28/17 11:25:25 |
Sebastian Huber |
Fix IO control request type
5
@7f1e6fa
07/28/17 10:19:05 |
Sebastian Huber |
libtests/block08: Fix format warning
5
@3fd0197
07/27/17 22:29:24 |
joel |
psxmmap01/test_helper.c: Use correct printf format for size_t
5
@3a3d85c
07/27/17 22:29:02 |
joel |
psxmmap01/test_driver.c: Fix mmap_h handler type mismatch
5
@146adb1
07/17/17 05:30:46 |
Sebastian Huber |
sparc: Add lazy floating point switch
The SPARC ABI is a bit special …
5
@600d88d
07/19/17 07:07:17 |
Sebastian Huber |
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT
Add new fatal error …
5
@1c256e6
07/20/17 09:32:53 |
Sebastian Huber |
tmtests/tmcontext01: Prevent GCC 7.1 optimizations
It is getting …
5
@5f1ae90e
07/19/17 14:00:48 |
Sebastian Huber |
sptests/sptls02: Use standard test IO
Update #3076.
5
@0ea7ca9
07/19/17 13:51:28 |
Sebastian Huber |
sptests/spcache01: Use standard test IO
Update #3076.
5
@a0271a7
07/19/17 13:50:57 |
Sebastian Huber |
tests: Use floating point task
These tests directly or indirectly use …
5
@96ce1ec
07/19/17 11:03:13 |
Sebastian Huber |
smptests/smpscheduler02: Remove invalid assert
Update #3059.
5
@7ad8239
07/19/17 10:58:55 |
Sebastian Huber |
smptests/smpscheduler01: Use right scheduler
Update #3063.
5
@6f46848
07/19/17 09:57:01 |
Sebastian Huber |
5
@07e1780
07/18/17 11:07:26 |
Sebastian Huber |
5
@533ac112
07/18/17 11:02:30 |
Sebastian Huber |
tests: Use more integer print functions
This avoids an unnecessary …
5
@1549beb
06/29/17 14:36:44 |
kevin-kirspel |
psxtests: Add a mmap dedicated test case
Updates #2859
5
@ecabd384
07/11/17 07:51:43 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor_set
Update #3070.
5
@548d65a5
07/11/17 05:24:39 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor()
Update #3069.
5
@4a1bdd30
07/07/17 06:30:20 |
Sebastian Huber |
score: Fix set scheduler
Ensure that the thread processor affinity …
5
@34487537
07/04/17 07:57:30 |
Sebastian Huber |
score: Add simple affinity support to EDF SMP
Update #3059.
5
@e745ec5
07/04/17 07:48:52 |
Sebastian Huber |
smptests/smpstrongapa01: Simplify
Update #3059.
5
@16347a6
07/07/17 05:36:52 |
Sebastian Huber |
score: Fix default set affinity
The set of online processors must be …
5
@76d1198
07/07/17 05:45:57 |
Sebastian Huber |
score: Introduce _SMP_Get_online_processors()
Update #3059.
5
@0232b28
07/04/17 06:59:37 |
Sebastian Huber |
score: Use processor mask for set affinity
Update #3059.
5
@7851555
07/03/17 12:05:26 |
Sebastian Huber |
score: Move processor affinity to Thread_Control
Update #3059.
5
@3dfe55ee
07/03/17 09:46:12 |
Sebastian Huber |
score: Use <sys/bitset.h> for Processor_mask
Implement the …
5
@9b07f5e
06/26/17 06:20:15 |
Sebastian Huber |
newlib01: Use fopen() instead of freopen()
With global stdio streams, …
5
@7adf4941
06/29/17 13:21:30 |
Sebastian Huber |
smptests/smpschededf01: New test
Update #3056.
5
@7f7a3e8f
06/29/17 12:36:26 |
Sebastian Huber |
tests: Move busy loop to test support
Update #3056.
5
@f3d9f228
06/26/17 08:35:45 |
Sebastian Huber |
score: Add SMP EDF scheduler
Update #3056.
5
@1dbce41
06/26/17 08:27:23 |
Sebastian Huber |
smptests: Split smpscheduler03
Split smpscheduler03 to run the tests …
5
@b8b4b7d
06/15/17 17:42:59 |
joel |
psxstat/test.c: Avoid potential string overflow
5
@9d945b5f
06/15/17 17:42:26 |
joel |
psximfs02/init.c: Avoid potential string overflow
5
@d6cb813
06/15/17 17:41:26 |
joel |
dl03/dl-cache.c: Fix duplicate const warning
5
@d93181a0
06/12/17 16:49:51 |
joel |
malloctest/init.c: Disable check maximum size warning to allow error …
5
@5700d8ba
06/12/17 02:05:42 |
joel |
top/task1.c: Fix sprintf() buffer overflow
5
@a5d31fe
06/12/17 01:47:18 |
joel |
rbheap01/init.c: Fix PAGE_SIZE redefined warning
5
@4000836c
06/13/17 11:01:03 |
Sebastian Huber |
tests: Fix build dependencies
See also:
5
@f7d0f5e
06/09/17 05:50:41 |
Sebastian Huber |
spcpuset01: Update due to CPU_CMP() changes
Close #3036.
5
@b06dbb26
06/07/17 06:47:47 |
Sebastian Huber |
spcpuset01: Update due to CPU_NAND_S() changes
Close #3032.
5
@836f454
06/07/17 06:14:30 |
Sebastian Huber |
Fix CPU_COPY() usage
The original CPU_COPY() support of Newlib …
5
@787f51f
06/06/17 09:08:16 |
Sebastian Huber |
Do not include <sys/ioctl.h> in kernel-space
Update #2833.
5
@93531e9b
06/06/17 06:03:45 |
Sebastian Huber |
Move RTEMS-specific Termios API content
Remove obsolete support for …
5
@7ec982bf
05/26/17 00:35:17 |
Chris Johns |
build-system: Fix the targets support for the parallel build.
5
@30eeb0d
05/25/17 05:11:45 |
Chris Johns |
testsuite: Fix excluding tests that a substring of another test.
Fix …
5
@86ae03c
05/24/17 02:39:19 |
Chris Johns |
testsuite: Add fsjffs2gc01 to the disable JFFS tests.
5
@7396e39
05/23/17 23:22:28 |
Chris Johns |
testusite: Fix the parallel build test excludes.
5
@6bc63df1
05/12/17 07:53:35 |
Sebastian Huber |
confdefs.h: Add SMP enabled field to configuration
Do not use the …
5
@00d98208
05/12/17 08:08:34 |
Sebastian Huber |
sptests/spprivenv01: Use default task mode
There is no need to run …
5
@f778b7f3
05/12/17 06:35:36 |
Sebastian Huber |
confdefs.h: Use SMP scheduler only if necessary
Update #3001.
5
@13097181
05/11/17 09:03:00 |
Sebastian Huber |
confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATION
Enable the SMP …
5
@900c407
05/10/17 03:36:55 |
Chris Johns |
testsuites: Build the tests in parallel if make is asked too.
5
@6130a47
05/10/17 03:34:55 |
Chris Johns |
testsuites: Fix build dependences for generated files.
5
@87de70a2
03/15/17 18:31:00 |
Gedare Bloom |
posix/mman: add mmap support for shm objects
Update #2859.
5
@78eb6132
04/26/17 15:53:40 |
joel |
dhrystone/dhry_1.c: Move assignment to before start of timer
5
@b73b952
04/26/17 03:11:55 |
joel |
block08/bdbuf_tests.c: Add include of <rtems/inttypes.h>
5
@9e6ef36
04/26/17 01:14:28 |
joel |
rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum
5
@786c365
04/25/17 16:40:21 |
joel |
psxtests/Makefile.am: Disable tests which should not be built when …
5
@55b967a
04/25/17 16:22:25 |
joel |
devnullfatal01/testcase.h: Avoid redefinition of TESTS_USE_PRINTK
5
@e4633241
04/23/17 16:51:22 |
joel |
linpack/linpack-pc.c: Fix no return statement warning
5
@906e67f
04/23/17 16:50:46 |
joel |
dhrystone/dhry_1.c: Fix may be used uninitialized warning
5
@438ca2f
04/22/17 19:15:22 |
joel |
rtems/inttypes.h: Add blksize_t and blkcnt_t
5
@d420b67
04/14/17 20:18:56 |
joel |
Merge tmacros.h PRIxxx constants from testsuites/ into …
5
@18f63c0
04/15/17 23:51:57 |
Chris Johns |
testsuite: Fix rtems-test-check not excluding tests.
The include file …
5
@9b91c84
04/05/17 09:29:02 |
Sebastian Huber |
smpcache01: Fix test to run on QorIQ T4240
5
@75e71b2
04/05/17 07:55:45 |
Sebastian Huber |
spcache01: Instruction cache invalidate workaround
On some systems, …
5
@662b301
04/05/17 05:23:09 |
Sebastian Huber |
dhrystone: Fix warnings
Close #2977.
5
@281cf07
04/04/17 22:14:11 |
joel |
psxstrsignal01: Remove warnings
5
@258bda3
04/03/17 22:11:24 |
Chris Johns |
testsuite: Add a common test configuration. Fix configure.ac and …
5
@bba48d9
03/30/17 00:06:24 |
Chris Johns |
libdl: Support link ordered loading of ELF sections.
The ARM C++ …
5
@a1c60b56
03/28/17 12:04:44 |
Sebastian Huber |
benchmarks/whetstone: Port to RTEMS
Update #2958.
5
@3785f937
03/28/17 11:14:00 |
Sebastian Huber |
benchmarks/whetstone: Import
Import whetstone sources from:
5
@0a16d5f
03/28/17 12:38:07 |
Sebastian Huber |
benchmarks/linpack: Port to RTEMS
Close #2958.
5
@8783660
03/28/17 11:15:04 |
Sebastian Huber |
benchmarks/linpack: Import
Import linpack sources from:
5
@954ca41
03/28/17 11:44:45 |
Sebastian Huber |
benchmarks/dhrystone: Port to RTEMS
Update #2958.
5
@317c1f4
03/28/17 11:13:07 |
Sebastian Huber |
benchmarks/dhrystone: Import
Import dhrystone sources from:
5
@0027682
03/28/17 11:11:22 |
Sebastian Huber |
benchmarks: Add benchmark templates
Update #2958.
5
@1c6926c1
03/21/17 19:39:48 |
kevin-kirspel |
termios: Synchronize with latest FreeBSD headers
Adding modified …
5
@d50ab079
03/16/17 14:12:20 |
Sebastian Huber |
dosfs: Fix file name search
Do not use our long file name entry count …
5
@e69ee36
03/13/17 14:20:20 |
Sebastian Huber |
dosfs: Fix fat_file_write()
Remove forced overwrite which leads to …
5
@1becaa9
03/14/17 12:59:09 |
Sebastian Huber |
dosfs: Fix msdos_utf8_normalize_and_fold()
It is all right in case …
5
@66fac03
03/16/17 10:54:29 |
Sebastian Huber |
libio: Fix deadlock in location management
Perform a …
5
@191d39a
03/15/17 17:59:47 |
joel |
psxstrsignal01: New test
5
@eb73320
03/09/17 05:14:16 |
Chris Johns |
Fix rtems-test-check with a BSD sed.
BSD sed does not support '\t' …
5
@cb056d0
03/03/17 08:04:12 |
Sebastian Huber |
cdtest: Print begin of test only once
5
@902ffed
02/24/17 13:56:51 |
Sebastian Huber |
termios09: Test send callback
5
@36635433
02/24/17 13:44:04 |
Sebastian Huber |
termios: Implement non-blocking write
5
@a165a96
02/23/17 14:43:41 |
Sebastian Huber |
termios: Make write POSIX compatible
Currently only blocking …
5
@5244d31e
02/23/17 13:04:24 |
Sebastian Huber |
termios: Simplify oproc()
Call rtems_termios_puts() only once. …
5
