Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/testsuites
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @14da2e7   10/29/09 04:51:39 Ralf Corsepius 2009-10-29 Ralf Corsépius <ralf.corsepius@…> * psx10/init.c: … 4.104.115
(edit) @cf980b19   10/29/09 04:51:38 Ralf Corsepius 2009-10-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @edfc0f9   10/29/09 03:21:40 Ralf Corsepius 2009-10-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @51d7b75   10/28/09 02:29:19 Ralf Corsepius 2009-10-28 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @b3051ac   10/28/09 02:29:18 Ralf Corsepius 2009-10-28 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @b3acedb5   10/27/09 14:13:13 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @01f1a20e   10/27/09 14:12:59 Ralf Corsepius Add PRIxpthread_t. 4.104.115
(edit) @e1a7627   10/27/09 14:11:03 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @39615f4   10/27/09 14:10:54 Ralf Corsepius Use PRIxpthread_t to print pthread_t's. 4.104.115
(edit) @749eae97   10/27/09 12:12:59 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp29/init.c: … 4.104.115
(edit) @7dcba14   10/27/09 12:12:48 Ralf Corsepius Include "tmacros.h". Misc. changes related to rtems_intervals. 4.104.115
(edit) @ae218607   10/27/09 11:58:41 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp14/asr.c: … 4.104.115
(edit) @26a0d29b   10/27/09 11:58:34 Ralf Corsepius Add PRIxrtems_signal_set. Use PRIxrtems_signal_set to print … 4.104.115
(edit) @2b5b8064   10/27/09 11:54:37 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp13/task3.c: … 4.104.115
(edit) @fda2929   10/27/09 11:54:22 Ralf Corsepius Use PRIu32 to print "count". 4.104.115
(edit) @5306b49   10/27/09 11:43:46 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @1466425   10/27/09 11:43:29 Ralf Corsepius Fix parity_table_Entry type. Correct parity_table initialization. Add … 4.104.115
(edit) @72cbbad1   10/27/09 11:32:11 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @b1c89648   10/27/09 11:32:04 Ralf Corsepius Segment sizes are uintptr_t's. 4.104.115
(edit) @cce4d0da   10/27/09 11:29:03 Ralf Corsepius Use size_t for "size". 4.104.115
(edit) @f60b6325   10/27/09 11:14:26 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp62/init.c: … 4.104.115
(edit) @01dd894   10/27/09 11:14:19 Ralf Corsepius segment sizes are uintptr_t's. 4.104.115
(edit) @35435d80   10/27/09 09:05:49 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp25/task1.c: … 4.104.115
(edit) @92dc3432   10/27/09 09:04:54 Ralf Corsepius Use PRIuPTR to print segment_size's. 4.104.115
(edit) @d19ee726   10/27/09 09:03:52 Ralf Corsepius Add PRIurtems_device_major_number. 4.104.115
(edit) @443f1845   10/27/09 08:16:02 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @cdfa0e63   10/27/09 08:15:55 Ralf Corsepius Remove cast in call to fatal_posix_service_status_errno. 4.104.115
(edit) @69c6619   10/27/09 08:14:04 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp11/task1.c, … 4.104.115
(edit) @f15fc6a   10/27/09 08:13:58 Ralf Corsepius Use PRIxrtems_event_set to print rtems_event_set's. 4.104.115
(edit) @d0f47c22   10/27/09 08:12:25 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @acf5212   10/27/09 07:51:51 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @2b48505   10/27/09 07:30:34 Ralf Corsepius Remove extraneous argument to print. 4.104.115
(edit) @94418bd   10/27/09 07:27:55 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @44c6b5b   10/27/09 07:27:43 Ralf Corsepius Use PRIu32 to print sys_req. 4.104.115
(edit) @e8d1720   10/27/09 07:12:25 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp37/init.c: … 4.104.115
(edit) @79c49e1   10/27/09 07:12:05 Ralf Corsepius Add missing argument to printf. 4.104.115
(edit) @bf3a0a04   10/27/09 06:59:32 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @073dff3   10/27/09 06:59:20 Ralf Corsepius Use PRIdrtems_task_argument to print rtems_task_argument's. 4.104.115
(edit) @6fa28e90   10/27/09 06:57:49 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp44/init.c, … 4.104.115
(edit) @7354b34   10/27/09 06:53:15 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @15b7644   10/27/09 06:53:07 Ralf Corsepius Add PRIdThread_Entry_numeric_type. Add PRIdrtems_task_argument. 4.104.115
(edit) @e292c661   10/27/09 05:17:55 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * sp25/task1.c: … 4.104.115
(edit) @4ee0bda5   10/27/09 05:17:31 Ralf Corsepius segment_size is uintptr_t. 4.104.115
(edit) @b9547ee   10/27/09 05:15:19 Ralf Corsepius Add missing return. 4.104.115
(edit) @13910fc   10/27/09 05:13:56 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @dd06f5c   10/27/09 05:13:49 Ralf Corsepius Add missing args in calls to execl, execlp, execle. 4.104.115
(edit) @f32b613   10/27/09 05:04:01 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @0e3f3fb   10/27/09 05:03:29 Ralf Corsepius Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME. 4.104.115
(edit) @15a4f37c   10/27/09 05:02:34 Ralf Corsepius Use HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. 4.104.115
(edit) @8c3c4822   10/27/09 05:01:14 Ralf Corsepius Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME, HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. 4.104.115
(edit) @90c8051a   10/27/09 04:59:10 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @7a6c4c51   10/27/09 04:58:47 Ralf Corsepius Add AC_CHECK_DECLS pthread_getcputime, pthread_setcputime. 4.104.115
(edit) @b064c98   10/27/09 04:12:25 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @e295d46   10/27/09 04:12:06 Ralf Corsepius Duplicate code from rtems_name_to_characters to convert rtems_name's … 4.104.115
(edit) @a20539f1   10/27/09 04:05:12 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @9197aef   10/27/09 04:04:39 Ralf Corsepius Comment out unused return status. 4.104.115
(edit) @d23649d2   10/27/09 04:03:41 Ralf Corsepius Use PRIu32 to print uint32_t's. 4.104.115
(edit) @cdc371f   10/27/09 04:00:15 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * tmck/task1.c: … 4.104.115
(edit) @2441f74   10/27/09 03:58:10 Ralf Corsepius 2009-10-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @17c7533   10/27/09 03:57:28 Ralf Corsepius Use %ld to print *.tv_nsec. 4.104.115
(edit) @669ad957   10/27/09 03:53:39 Ralf Corsepius Misc. warning fixes. 4.104.115
(edit) @1d355518   10/26/09 17:13:18 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp31/task1.c: … 4.104.115
(edit) @c784b7fe   10/26/09 17:13:09 Ralf Corsepius Use PRIdWatchdog_Interval to print Watchdog_Interval's. 4.104.115
(edit) @3e0396ff   10/26/09 17:04:50 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp20/task1.c, … 4.104.115
(edit) @c0c2d49   10/26/09 17:04:39 Ralf Corsepius Use PRIdrtems_interval to print rtems_interval's. 4.104.115
(edit) @e693be45   10/26/09 17:02:40 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @2d4d5159   10/26/09 16:53:46 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp13/task1.c: … 4.104.115
(edit) @c21011a   10/26/09 16:53:35 Ralf Corsepius Misc. uint32_t fixes. 4.104.115
(edit) @7db3ba6   10/26/09 16:52:14 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp20/task1.c: … 4.104.115
(edit) @a6d0b15   10/26/09 15:16:04 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp47/init.c: … 4.104.115
(edit) @afd0fe59   10/26/09 15:15:56 Ralf Corsepius Add PRIXModes_Control, PRIXrtems_mode. Use PRIXrtems_mode to print … 4.104.115
(edit) @bc863a81   10/26/09 15:15:36 Ralf Corsepius Add PRIxModes_Control, PRIxrtems_mode. Use PRIxrtems_mode to print … 4.104.115
(edit) @43c9b4d5   10/26/09 14:58:47 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp19/first.c, … 4.104.115
(edit) @51b81fd   10/26/09 14:58:36 Ralf Corsepius Add missing PRI*32's. 4.104.115
(edit) @2f8ec242   10/26/09 14:22:33 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @729b212   10/26/09 14:22:22 Ralf Corsepius Use PRIdPriority_Control to print Priority_Control's. 4.104.115
(edit) @ddff7ef   10/26/09 14:20:43 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @185584e   10/26/09 14:08:01 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @dfd856aa   10/26/09 14:07:51 Ralf Corsepius Use PRIdrtems_task_priority to print rtems_task_priority's. 4.104.115
(edit) @899fb904   10/26/09 13:59:05 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp07/task1.c, … 4.104.115
(edit) @bb7411e   10/26/09 13:58:56 Ralf Corsepius Change Priority_Test_driver to use rtems_task_priority argument. 4.104.115
(edit) @621b786   10/26/09 13:58:42 Ralf Corsepius Change Priority_Test_driver to use rtems_task_priority argument. Use … 4.104.115
(edit) @c42e77a1   10/26/09 13:58:06 Ralf Corsepius Use PRIdrtems_task_priority to print rtems_task_priority's. 4.104.115
(edit) @f5c70d3   10/26/09 13:51:34 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @20fd4a5   10/26/09 13:51:25 Ralf Corsepius Add PRIdrtems_task_priority. 4.104.115
(edit) @c526f75   10/26/09 13:37:51 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @8fe17b4   10/26/09 13:37:31 Ralf Corsepius Add missing argument to printf. 4.104.115
(edit) @e23c697f   10/26/09 13:36:13 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @ee875ad3   10/26/09 13:36:07 Ralf Corsepius Use PRIu32 to print uint32_t's. 4.104.115
(edit) @b3b09bc   10/26/09 13:35:06 Ralf Corsepius Use %zu instead of %d to print size_t's. 4.104.115
(edit) @75c13bef   10/26/09 11:36:15 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @73ae9de8   10/26/09 11:36:09 Ralf Corsepius Use PRIxrtems_id to print rtems_ids. 4.104.115
(edit) @5726131b   10/26/09 11:34:38 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @732276e   10/26/09 11:34:27 Ralf Corsepius Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. 4.104.115
(edit) @b9deb1c3   10/26/09 11:32:44 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @fa06ce1   10/26/09 11:32:35 Ralf Corsepius Add -I$(top_srcdir)/../support/include. 4.104.115
(edit) @1190fd5   10/26/09 11:29:47 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * sp02/task1.c, … 4.104.115
(edit) @fde1456   10/26/09 11:29:24 Ralf Corsepius Use PRIxrtems_id to print rtems_ids. 4.104.115
(edit) @e71c81b3   10/26/09 10:37:25 Ralf Corsepius 2009-10-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @47f20ce5   10/26/09 10:37:20 Ralf Corsepius Add PRIxrtems_id. 4.104.115
