@03e86553
12/05/18 07:05:54 |
Sebastian Huber |
tests: Fix rtems_test_spin_until_next_tick()
This bug surfaced due to …
5
@fcd577a
12/07/18 04:29:42 |
joel |
psxtests/Makefile.am: Fix ticket number for ucontext.h
5
@17c32e5d
12/07/18 02:48:46 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ucontext.h (GCI 2018)
5
@bf763d3e
12/06/18 21:23:16 |
mcomajoancara |
Implement POSIX API Signature Compliance Tests for inttypes.h
This …
5
@9feff78
12/06/18 19:10:59 |
shashvatjain2002 |
psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018)
5
@1e455d4
12/06/18 18:24:13 |
shashvatjain2002 |
Includes …
5
@b24c098
12/06/18 19:06:29 |
himanshuwindows8.1 |
psxhdrs: Add POSIX API Signature Compliance Tests for string.h (GCI 2018)
5
@a803bd9e
12/06/18 16:49:32 |
zenon.hans.taneka |
Added POSIX Compliance Test for <ctype.h> (GCI 2018)
5
@5886a701
12/06/18 17:30:23 |
joel |
psxtmtests_plan.csv: Add preemption cases for pthread_setschedprio
5
@be9a83d
12/06/18 16:34:16 |
mcomajoancara |
psxtmtests/psxtmtests_plan.csv: Fix typos (GCI 2018)
Two quotation …
5
@c078065
12/06/18 16:28:23 |
mcomajoancara |
psxtmtests: Identified a Timing Test missing (GCI 2018)
5
@9598f83e
12/06/18 13:08:12 |
shashvatjain2002 |
psxhdrs: Add POSIX Conformance Tests for math.h (GCI 2018)
Includes …
5
@da262164
12/06/18 11:16:25 |
abhimanyuraghuvanshi29 |
POSIX Signature Test for fenv.h (GCI 2018)
Updates #2971.
5
@187ef31
12/06/18 06:44:41 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for wctype.h (GCI 2018)
5
@bf135a9
12/06/18 04:08:31 |
POSIX Compliance Signature Test for glob.h (GCI 2018)
5
@65b3fba
12/05/18 23:02:39 |
zenon.hans.taneka |
Added POSIX Compliance Test for complex.h, and adding lines to define …
5
@95095be
12/06/18 00:33:33 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ftw.h (GCI 2018)
5
@cbb08b61
12/05/18 22:07:33 |
joel |
psxhdrs: Fix spacing
5
@36e1b82
12/05/18 21:23:58 |
joel |
psxtmcleanup01/init.c: Fix warnings
5
@70966985
12/05/18 21:23:40 |
joel |
psxhdrs/strings/strncasecmp_l.c: Fix warning
5
@a115818
12/05/18 20:03:13 |
psxhdrs: added POSIX API Signature Compliance Tests for stdio.h File …
5
@cf2e6dde
12/05/18 19:14:42 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for sys/utsname.h (GCI 2018)
5
@7b5379d
12/05/18 17:38:50 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018)
5
@9abe98b3
12/05/18 17:59:31 |
joel |
testsuites/psxtests/Makefile.am: Disable psxhdrs for dirfd.c and …
5
@e517fe68
12/05/18 17:58:59 |
joel |
psxhdrs: Fix warnings
5
@e15ae5a3
12/05/18 15:28:39 |
psxhdrs: Align the code properly to left hand margin
5
@7fe5922a
12/05/18 17:14:17 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for langinfo.h (GCI 2018)
5
@5bb1f3b2
12/04/18 23:00:09 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for monetary.h …
5
@55719ba
12/04/18 22:55:53 |
joel |
5
@b0b095c
12/04/18 22:29:37 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018)
5
@99de42c
12/04/18 22:05:10 |
mcomajoancara |
Capitalize Rtems to RTEMS
5
@0446f680
12/03/18 20:37:32 |
mcomajoancara |
Spelling and grammar fixes in source code comments (GCI 2018)
5
@e25acd8
12/04/18 16:43:59 |
zenon.hans.taneka |
psxhdrs: Added POSIX Compliance Test fot sys/time.h (GCI 2018)
5
@adc11af9
12/04/18 04:42:01 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h …
5
@8f79854
12/04/18 02:57:47 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h …
5
@b055da27
12/03/18 17:04:04 |
psxhdrs: add POSIX API Signature Compliance Tests for regex.h (GCI 2018)
5
@b9ffb624
11/30/18 12:57:04 |
Sebastian Huber |
Convert CPU counter ticks to/from sbintime_t
The sbintime_t is an …
5
@7383632c
12/03/18 01:36:54 |
shashvatjain2002 |
psxhdrs:Add POSIX conformance test for utime.h (GCI 2018)
5
@0888bfd5
12/02/18 11:01:18 |
psxhdrs: add POSIX API Signature Compliance Tests for locale.h (GCI 2018)
5
@903c57a
12/01/18 18:41:19 |
psxhdrs: add POSIX API Signature Compliance Tests for dlfcn.h File …
5
@e3086c9c
12/01/18 17:53:06 |
psxhdrs: add POSIX API signature tests for strings.h file (GCI 2018)
5
@e54a266e
11/30/18 14:33:45 |
joel |
psxmsgq01/init.c: Disable signal usage when POSIX disabled
closes #3626.
5
@7ea4c02
11/29/18 17:03:19 |
psxtests : Add POSIX API Signature Compliance Tests for semaphore.h …
5
@93ccf479
11/28/18 08:04:34 |
psxtests: add POSIX API signature compliance tests for mqueue.h file …
5
@aa5c462
11/28/18 09:32:46 |
Chris Johns |
testsuite: Parse TCFG path based on OS path separator.
5
@27a8fc5
11/27/18 17:10:30 |
psxtests: add POSIX API signature compliance tests for dirent.h file …
5
@06331e4
11/27/18 10:56:01 |
Sebastian Huber |
dosfs: Fix device identifier
Update #3358.
5
@0a75a4aa
11/26/18 13:04:59 |
Sebastian Huber |
Remove rtems_cache_*_processor_set() functions
The following …
5
@eaa5ea84
11/20/18 15:22:56 |
Sebastian Huber |
score: Introduce <rtems/score/heapinfo.h>
Move Heap_Information_block …
5
@183b0ae
11/25/18 15:49:30 |
psxtmtests: add psxtmmqrcvblock02 (GCI 2018)
5
@16d5e394
11/24/18 20:11:50 |
psxtests/psxhdrs patch (GCI 2018)
5
@03139d5b
11/20/18 03:56:11 |
Chris Johns |
libdl: Add object file dependencies to track references
Tracking …
5
@69812aa
11/21/18 16:00:35 |
psxtmbarrierattr01: Added new POSIX timing suite (GCI 2018)
5
@bde6ac20
11/20/18 15:45:51 |
kualeyidxa |
Misc: Minor English fixes (GCI 2018)
5
@edae517
11/20/18 01:11:58 |
psxtmutexattr01: Added new POSIX timing suite (GCI 2018)
5
@edd366c
11/17/18 17:09:05 |
psxtmcleanup01: new POSIX timing suite (GCI 2018)
5
@f06c436
11/16/18 17:17:13 |
shashvatjain2002 |
psxtmtests_plan.csv: Update to reflect psxtmmqrcvblock01 (GCI 2018)
5
@ccf11ce
11/15/18 18:55:11 |
shashvatjain2002 |
psxtmmqrcvblock01: Add new POSIX timing test (GCI 2018)
5
@841b54e
11/15/18 22:31:21 |
psxtmthreadattr01: Correct mistakes in previous merge (GCI 2018)
Joel …
5
@8abb230b
11/15/18 06:18:48 |
psxtmthreadattr01: Add new test (GCI 2018)
5
@68c8a197
11/14/18 23:30:57 |
joel |
testsuites/psxtests/psxhdrs: Fix comment so copyright block is separate
5
@6efc831
11/09/18 11:11:11 |
Sebastian Huber |
Add rtems_malloc() and rtems_calloc()
Close #3583.
5
@bdd4eb87
11/08/18 08:13:59 |
Sebastian Huber |
rtems: Remove Modes_Control
Use rtems_mode directly. This is in line …
5
@bfcf1473
11/08/18 15:21:48 |
Sebastian Huber |
m32c: Remove this target
Update #3599.
5
@62954aaf
11/11/18 15:12:51 |
joel |
psxtmtests_plan.csv: Add pthread cleanup and attr test cases
5
@06ced25
11/07/18 05:09:07 |
Chris Johns |
testsuite: Add python verison support to rtems-test-check.py
Closes #3579
5
@942d52a
11/08/18 12:59:27 |
Sebastian Huber |
build: Fix library order
Update #3551.
5
@e9f15be
11/07/18 18:09:00 |
joel |
psxtmtests_plan.csv: Add psxtmonce01
5
@98cc00e6
11/07/18 18:07:53 |
joel |
psxtmonce01/init.c: Use static and Simple Console
5
@e71c097a
11/06/18 11:57:42 |
Sebastian Huber |
spconfig02: Check object methods in default config
Ensure that the …
5
@a818d13c
11/07/18 06:43:38 |
Sebastian Huber |
build: Remove superfluous psxtmonce01/Makefile.am
5
@99d6172
11/07/18 00:50:38 |
zenon.hans.taneka |
Correct minor spelling and grammar errors
This work was performed as …
5
@9bb39516
11/06/18 18:29:10 |
psxtmonce01: New test written by Himanshu40 as part of GCI2018
5
@bb3484c9
10/29/18 07:59:45 |
Sebastian Huber |
posix: Enable more sptests test cases by default
Update #2514.
5
@8dc1ed1
10/25/18 12:08:26 |
Sebastian Huber |
posix: Enable more psxtests by default
Update #2514.
5
@24f3e8f
10/25/18 12:02:23 |
Sebastian Huber |
posix: Enable more smptests tests by default
Update #2514.
5
@ef16a11
10/25/18 09:05:12 |
Sebastian Huber |
posix: Enable psxtmtests tests by default
Update #2514.
5
@55b69ed
10/15/18 06:33:45 |
Sebastian Huber |
Move default config to librtemsdefaultconfig.a
An RTEMS application …
5
@24b5807
10/24/18 05:35:51 |
Sebastian Huber |
config: Modify CONFIGURE_INTERRUPT_STACK_SIZE
Use …
5
@522d4b91
10/24/18 05:16:46 |
Sebastian Huber |
malloctest: Hide NULL pointer from compiler
Disabling a warning does …
5
@8ba76b9
10/12/18 15:20:39 |
Sebastian Huber |
tmonetoone: Add yield test case
5
@1ad26cd
10/18/18 10:38:58 |
Sebastian Huber |
Support O_NOFOLLOW open() flag
Close #3546.
5
@3825926
10/18/18 09:51:32 |
Sebastian Huber |
Support O_CLOEXEC open() flag
Make sure this flag is ignored and does …
5
@92e0eed
10/22/18 05:58:44 |
Sebastian Huber |
psxreaddir: Adjust test due to opendir() changes
Update #3545.
5
@4af18b3
10/11/18 08:51:21 |
Sebastian Huber |
Support O_DIRECTORY open() flag
Close #3545.
5
@632bb17
10/14/18 21:55:38 |
joel |
libtests/Makefile.am: Add CPU_CFLAGS to rtems-ld invocation
closes …
5
@cca7c40
10/12/18 12:48:45 |
Sebastian Huber |
tmtests: Fix unused variable warnings
5
@47b32a0
10/12/18 12:45:24 |
Sebastian Huber |
fsclose01: Fix uninitialized variable warning
5
@ca056e3
10/11/18 04:12:16 |
Sebastian Huber |
tmtests/tmonetoone: New test program
5
@26b58b7e
10/10/18 11:12:50 |
Sebastian Huber |
telnetd: Add server port to configuration
Close #3543.
5
@0dc303f
10/10/18 08:40:21 |
Sebastian Huber |
telnetd: Create sessions at start
Update #3543.
5
@629faf9
10/09/18 12:47:02 |
Sebastian Huber |
telnetd: Remove keep stdio feature
The Telnet service started via …
5
@477bca2
10/06/18 08:59:10 |
Sebastian Huber |
build: Remove local.am
5
@9da5d5fd
10/06/18 08:12:21 |
Sebastian Huber |
build: Directly reference libraries in tests
Remove use of …
5
@acb53d5
10/09/18 06:43:08 |
Sebastian Huber |
posix: Remove static assertion
Standard C does not allow pointer …
5
@dcf42bb2
10/05/18 12:39:46 |
Sebastian Huber |
ftpd: Remove FTPD_SessionInfo_t::pass member
There is no need to keep …
5
@51b3cbca
10/04/18 13:23:25 |
Sebastian Huber |
tests: Use rtems_task_exit()
Update #3533.
5
@8776bb9
09/26/18 04:34:54 |
Sebastian Huber |
score: Remove CPU_PROVIDES_IDLE_THREAD_BODY
Remove the …
5
@8352d41
10/05/18 05:30:29 |
Sebastian Huber |
spthreadlife01: A task exit must not return
Update #3533.
5
@e50e3f70
10/01/18 07:25:06 |
Sebastian Huber |
rtems: Add rtems_task_exit()
Update #3533.
5
