# # ChangeLog for testsuites in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 17:36:55 Mon, 07 Jan 2013 15:01:45 GMT Sebastian Huber [f2f39b62] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/fatalsrcdesc.c (added) * doc/user/fatal.t (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) sapi: Add rtems_fatal_source_description() Wed, 02 Jan 2013 17:56:35 GMT Sebastian Huber [57f125d] * cpukit/rtems/src/eventtimeout.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical10/spintrcritical10.scn (modified) rtems: Critical fix for events Commit ... Sun, 30 Dec 2012 04:55:11 GMT Cynthia Rempel [3169affa] * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) tmoverhd.doc Hi, Adding test documentation... Wed, 02 Jan 2013 17:37:07 GMT Christopher Kerl [3106d7c] * testsuites/fstests/imfs_fserror/imfs_fserror.scn (added) * testsuites/fstests/imfs_fslink/imfs_fslink.scn (added) * testsuites/fstests/imfs_fspatheval/imfs_fspathenval.scn (added) * testsuites/fstests/imfs_fspermission/imfs_fspermission.scn (added) * testsuites/fstests/imfs_fsrdwr/imfs_fsrdwr.scn (added) * testsuites/fstests/imfs_fstime/imfs_fstime.scn (added) IMFS: Generating .scn (Screen Shots) #2 Sun, 23 Dec 2012 13:13:46 GMT Sebastian Huber [355ca1ad] * testsuites/sptests/spintrcritical16/init.c (modified) sptests/spintrcritical16: Fix NULL pointer access Sat, 22 Dec 2012 16:29:15 GMT Sebastian Huber [fe62f3a] * testsuites/libtests/rbheap01/init.c (modified) libtests/rbheap01: Add test cases Sat, 22 Dec 2012 15:48:45 GMT Sebastian Huber [11c10b8b] * testsuites/sptests/speventsystem01/init.c (modified) sptests/speventsystem01: Add test cases Sat, 22 Dec 2012 15:38:45 GMT Sebastian Huber [aaee3a9] * testsuites/libtests/malloctest/init.c (modified) libtests/malloctest: Add test case Sat, 22 Dec 2012 15:28:26 GMT Sebastian Huber [d8efe3d] * testsuites/libtests/malloctest/init.c (modified) libtests/malloctest: Add test case Tue, 18 Dec 2012 13:44:42 GMT Sebastian Huber [72c6861] * cpukit/libblock/src/bdpart-register.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) libblock: Use rtems_blkdev_create_partition() Use ... Fri, 21 Dec 2012 11:21:11 GMT Sebastian Huber [3b91605] * cpukit/libfs/src/imfs/imfs_creat.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) IMFS: Fix resource leak in IMFS_allocate_node() Fri, 21 Dec 2012 09:59:04 GMT Sebastian Huber [c5d2760] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (added) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxconfig01/psxconfig01.scn (modified) libcsupport: Add rtems_resource_snapshot_take() Add ... Fri, 21 Dec 2012 09:17:34 GMT Sebastian Huber [fe1dc22] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/src/objectactivecount.c (added) * testsuites/sptests/spobjgetnext/init.c (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.doc (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.scn (modified) score: Add _Objects_Active_count() Fri, 21 Dec 2012 08:50:15 GMT Sebastian Huber [cbd07e4] * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/src/chainnodecount.c (added) * doc/user/chains.t (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spchain/spchain.scn (modified) score: Add rtems_chain_node_count_unprotected() Sun, 16 Dec 2012 20:34:13 GMT Sebastian Huber [c40f36b0] * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/md501/md501.doc (modified) libtests/md501: Use test cases of RFC 2202 Sun, 16 Dec 2012 16:33:57 GMT Sebastian Huber [f95d74a4] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/md501/Makefile.am (added) * testsuites/libtests/md501/init.c (added) * testsuites/libtests/md501/md501.doc (added) * testsuites/libtests/md501/md501.scn (added) libtests/md501: New test Thu, 13 Dec 2012 10:08:03 GMT Sebastian Huber [4b8e01f] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) dosfs: Add sync_device option for msdos_format() Wed, 12 Dec 2012 16:42:24 GMT Ralf Kirchner [465b0865] * cpukit/libfs/src/dosfs/msdos_format.c (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) dosfs: Bugfix for disks of for example 100MB size Wed, 12 Dec 2012 08:25:03 GMT Sebastian Huber [b0da5796] * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios02/init.c (modified) * testsuites/libtests/termios02/termios02.scn (modified) termios: Implement tcflush() New IO control RTEMS_IO_TCFLUSH. Wed, 12 Dec 2012 08:36:02 GMT Sebastian Huber [ad13ebe] * cpukit/libcsupport/src/tcflow.c (modified) * testsuites/libtests/termios02/init.c (modified) termios: Fix tcflow() error status Thu, 06 Dec 2012 16:47:30 GMT Sebastian Huber [48bff53b] * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/src/exinit.c (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/support.t (modified) * doc/user/init.t (modified) * testsuites/sptests/spinternalerror01/init.c (modified) score: rtems_initialize_start_multitasking() Do not return from ... Mon, 03 Dec 2012 10:35:43 GMT Sebastian Huber [f9340ed7] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/psignal.h (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxsignal05/init.c (modified) posix: Add and use This file contains ... Wed, 05 Dec 2012 12:43:34 GMT Ralf Kirchner [42a22f08] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsdosfswrite01/Makefile.am (added) * testsuites/fstests/fsdosfswrite01/fsdosfswrite01.doc (added) * testsuites/fstests/fsdosfswrite01/fsdosfswrite01.scn (added) * testsuites/fstests/fsdosfswrite01/init.c (added) dosfs: Cluster write optimization Separate cluster write from ... Wed, 28 Nov 2012 13:43:32 GMT Ralf Kirchner [a20fbe7] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) dosfs: Block size optimization Change block size of bdbuf to the ... Tue, 30 Oct 2012 12:41:11 GMT Ralf Kirchner [5877a10f] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsdosfsformat01/Makefile.am (added) * testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc (added) * testsuites/fstests/fsdosfsformat01/fsdosfsformat01.scn (added) * testsuites/fstests/fsdosfsformat01/init.c (added) fstests/fsdosfsformat01: New test Wed, 05 Dec 2012 12:58:19 GMT Ralf Kirchner [a0bc1dc] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) dosfs: Delete fattype parameter for msdos_format() Delete fattype ... Wed, 05 Dec 2012 13:11:26 GMT Ralf Kirchner [5b8d935a] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) dosfs: Add skip_alignment for msdos_format() Add skip_alignment ... Wed, 05 Dec 2012 09:54:17 GMT Ralf Kirchner [7fab7fc] * cpukit/Makefile.am (modified) * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/sparse-disk.h (added) * cpukit/libblock/src/sparse-disk.c (added) * cpukit/preinstall.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/sparsedisk01/Makefile.am (added) * testsuites/libtests/sparsedisk01/init.c (added) * testsuites/libtests/sparsedisk01/sparsedisk01.doc (added) * testsuites/libtests/sparsedisk01/sparsedisk01.scn (added) libblock: Add sparse disk Sun, 25 Nov 2012 16:48:11 GMT Sebastian Huber [815994f] * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (added) * cpukit/score/cpu/arm/armv7m-exception-frame-print.c (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/avr-exception-frame-print.c (added) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (added) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/h8300/h8300-exception-frame-print.c (added) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (added) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (added) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m32r/m32r-exception-frame-print.c (added) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (added) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (added) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (added) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * doc/user/fatal.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal26/Makefile.am (added) * testsuites/sptests/spfatal26/init.c (added) * testsuites/sptests/spfatal26/spfatal26.doc (added) * testsuites/sptests/spfatal26/spfatal26.scn (added) score: Add CPU_Exception_frame Add CPU port type ... Mon, 26 Nov 2012 00:53:39 GMT Joel Sherrill [d82a931] * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmtests_plan.csv: Identify Conditional Variable Cases Thu, 22 Nov 2012 16:28:41 GMT Sebastian Huber [acec386] * cpukit/libfs/src/defaults/default_statvfs.c (modified) * testsuites/psxtests/psxstat/psxstat.scn (modified) * testsuites/psxtests/psxstat/test.c (modified) Filesystem: PR1619: Use ENOSYS for default statvfs POSIX does not ... Thu, 22 Nov 2012 13:51:25 GMT Sebastian Huber [3be0c9a] * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/userextaddset.c (modified) * cpukit/score/src/userextiterate.c (modified) * cpukit/score/src/userextremoveset.c (modified) * cpukit/score/src/userextthreadswitch.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Add and use This file contains ... Thu, 22 Nov 2012 13:09:03 GMT Sebastian Huber [0268adb3] * testsuites/fstests/fsfseeko01/init.c (modified) fstests/fsfseeko01: Add test cases Wed, 21 Nov 2012 14:27:43 GMT Sebastian Huber [fe0f24e] * cpukit/libnetworking/lib/ftpfs.c (modified) * testsuites/libtests/ftp01/ftp01.scn (modified) * testsuites/libtests/ftp01/init.c (modified) ftpfs: Use SIZE command Wed, 21 Nov 2012 09:59:32 GMT Sebastian Huber [c1e350c] * testsuites/sptests/spcbssched02/task_periodic.c (modified) sptests/spcbssched02: PR2081: Workaround Avoid uninitialized stack ... Fri, 16 Nov 2012 13:17:31 GMT Sebastian Huber [3fbcadf] * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * testsuites/libtests/mghttpd01/init.c (modified) libnetworking: Use rtems_clock_get_uptime_seconds This reduces the ... Fri, 16 Nov 2012 13:14:03 GMT Sebastian Huber [90733a86] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (added) * doc/user/clock.t (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) rtems: Add rtems_clock_get_uptime_seconds() Fri, 16 Nov 2012 13:02:12 GMT Sebastian Huber [bfddb047] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (added) * doc/user/clock.t (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) rtems: Add rtems_clock_get_uptime_timeval() Wed, 14 Nov 2012 14:10:46 GMT Sebastian Huber [a12f7e9] * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/libtests/stackchk/init.c (modified) score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER Wed, 14 Nov 2012 13:54:09 GMT Sebastian Huber [a0c7aa55] * cpukit/libcsupport/src/__assert.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal11/testcase.h (modified) score: Add RTEMS_FATAL_SOURCE_ASSERT Wed, 14 Nov 2012 08:59:10 GMT Sebastian Huber [a052181] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) score: Add RTEMS_FATAL_SOURCE_EXIT Include ... Tue, 13 Nov 2012 16:53:43 GMT Sebastian Huber [b31a960] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/sapi/src/interrdesc.c (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR Use ... Tue, 13 Nov 2012 16:40:33 GMT Sebastian Huber [dc6e830] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/interrdesc.c (added) * doc/user/Makefile.am (modified) * doc/user/fatal.t (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror02/Makefile.am (added) * testsuites/sptests/spinternalerror02/init.c (added) * testsuites/sptests/spinternalerror02/spinternalerror02.doc (added) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (added) sapi: Add and use rtems_internal_error_description Thu, 15 Nov 2012 14:02:54 GMT Sebastian Huber [f48d06a6] * testsuites/sptests/spfatal24/testcase.h (modified) sptests/spfatal24: Fix NULL pointer access Wed, 14 Nov 2012 10:51:45 GMT Sebastian Huber [dc0eed7] * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) testsuites: Include Include for proper BSP specific ... Mon, 12 Nov 2012 16:58:48 GMT Sebastian Huber [8f548ce] * testsuites/sptests/spintrcritical09/init.c (modified) sptests/spintrcritical09: Fix check order The critical section ... Mon, 12 Nov 2012 13:58:13 GMT Sebastian Huber [8f1b6cde] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsrfsbitmap01/Makefile.am (added) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.scn (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) * testsuites/fstests/mrfs_fsrfsbitmap01/Makefile.am (deleted) fstests/fsrfsbitmap01: Fix NULL pointer access Move test files into ... Mon, 12 Nov 2012 12:54:12 GMT Sebastian Huber [b5b1f44] * testsuites/samples/fileio/system.h (modified) samples/fileio: Add DOSFS and RFS on demand Wed, 07 Nov 2012 11:31:27 GMT Sebastian Huber [44633fd] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spinternalerror01/Makefile.am (added) * testsuites/sptests/spinternalerror01/init.c (added) * testsuites/sptests/spinternalerror01/spinternalerror01.doc (added) * testsuites/sptests/spinternalerror01/spinternalerror01.scn (added) sptests/spinternalerror01: New test Wed, 07 Nov 2012 12:48:31 GMT Sebastian Huber [3cd79b0] * testsuites/libtests/devfs03/init.c (modified) libtests/devfs03: Initialize nodes Tue, 06 Nov 2012 11:11:49 GMT Sebastian Huber [dd40e143] * testsuites/sptests/spfatal08/testcase.h (modified) sptests/spfatal08: Simplify Tue, 06 Nov 2012 10:27:19 GMT Sebastian Huber [3dd120f0] * testsuites/sptests/spfatal07/testcase.h (modified) sptests/spfatal07: Use confdefs.h to trigger test Wed, 31 Oct 2012 10:54:39 GMT Sebastian Huber [9f0a68c] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) libblock: Block device transfer request API change Add and use ... Fri, 26 Oct 2012 08:05:07 GMT Sebastian Huber [0edf263] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/systemeventreceive.c (added) * cpukit/rtems/src/systemeventsend.c (added) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/speventsystem01/Makefile.am (added) * testsuites/sptests/speventsystem01/init.c (added) * testsuites/sptests/speventsystem01/speventsystem01.doc (added) * testsuites/sptests/speventsystem01/speventsystem01.scn (added) * testsuites/sptests/speventtransient01/Makefile.am (added) * testsuites/sptests/speventtransient01/init.c (added) * testsuites/sptests/speventtransient01/speventtransient01.doc (added) * testsuites/sptests/speventtransient01/speventtransient01.scn (added) rtems: Add system events System events are similar to normal ... Fri, 26 Oct 2012 19:31:45 GMT Sebastian Huber [9dffa384] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev-ioctl.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) libblock: rtems_bdbuf_set_block_size() API change The set block ... Fri, 26 Oct 2012 19:29:36 GMT Sebastian Huber [0d68d8f2] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block16/Makefile.am (added) * testsuites/libtests/block16/block16.doc (added) * testsuites/libtests/block16/block16.scn (added) * testsuites/libtests/block16/init.c (added) * testsuites/libtests/configure.ac (modified) libtests/block16: New test Thu, 09 Aug 2012 14:48:00 GMT Sebastian Huber [47a3cd8] * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc/shared/startup/early_malloc.c (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/shared/startup/bspgetworkarea.c (deleted) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_sbrk_helpers.c (deleted) * cpukit/libcsupport/src/mallocinfo.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (added) * cpukit/libcsupport/src/rtems_heap_null_extend.c (added) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/wkspace.c (modified) * doc/bsp_howto/init.t (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal21/Makefile.am (deleted) * testsuites/sptests/spfatal21/spfatal21.doc (deleted) * testsuites/sptests/spfatal21/spfatal21.scn (deleted) * testsuites/sptests/spfatal21/testcase.h (deleted) * testsuites/sptests/spfatal_support/init.c (modified) score: Work area initialization API change The work areas (RTEMS ... Fri, 12 Oct 2012 15:02:30 GMT Sebastian Huber [e4278f2] * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/heapextend.c (modified) * testsuites/libtests/malloctest/init.c (modified) score: Append to free list in _Heap_Extend() Thu, 09 Aug 2012 08:17:42 GMT Sebastian Huber [6ccfe72] * cpukit/rtems/src/regionextend.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapnoextend.c (added) * cpukit/score/src/pheapextend.c (modified) * testsuites/libtests/malloctest/init.c (modified) score: Change _Heap_Extend() API The _Heap_Extend() has now the ... Mon, 15 Oct 2012 15:45:04 GMT Ralf Corsépius [503de116] * testsuites/fstests/fsrfsbitmap01/test.c (modified) Make tems_rfs_bitmap_ut_test_range, ... Mon, 15 Oct 2012 02:39:21 GMT Ralf Corsépius [e693b9ed] * testsuites/libtests/mghttpd01/init.c (modified) Remove unused var "sc". Mon, 15 Oct 2012 02:39:04 GMT Ralf Corsépius [b9e9dab] * testsuites/libtests/mghttpd01/test-http-client.c (modified) Remove unused var "service". Move #include "test-http-client.h" after ... Mon, 15 Oct 2012 02:37:40 GMT Ralf Corsépius [2d72c198] * testsuites/libtests/mghttpd01/test-http-client.h (modified) Move extern "C" after std-header inclusions. Mon, 15 Oct 2012 02:36:15 GMT Ralf Corsépius [35320729] * testsuites/fstests/fsrdwr/init.c (modified) Use %zd instead of %d to print size_t's Fri, 24 Aug 2012 13:22:51 GMT Sebastian Huber [178a7bb9] * testsuites/sptests/sp39/system.h (modified) sptests/sp39: Increase clock tick interval Not every BSP supports a ... Thu, 11 Oct 2012 20:52:18 GMT Joel Sherrill [0e27119] * c/src/lib/libbsp/arm/gdbarmsim/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/ssp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/mscan-base.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan-base.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xxevb.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c (modified) * c/src/lib/libbsp/powerpc/shared/include/tictac.h (modified) * c/src/lib/libbsp/powerpc/shared/src/tictac.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/dspi/dspi.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/fec/fec.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/dspi.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/edma.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/esci.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/watchdog.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/copy.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/siu/siu.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/gtm.h (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/i2c/spi-sd-card.h (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/status-checks.h (modified) * testsuites/sptests/sp14/sp14.scn (modified) Use proper 3 line form of license text Thu, 11 Oct 2012 16:27:34 GMT Ralf Corsépius [c1412db] * testsuites/fstests/fsrfsbitmap01/test.c (modified) Use %zu instead of %lu to print size_t's. Thu, 11 Oct 2012 16:25:03 GMT Ralf Corsépius [fd71610] * cpukit/sapi/include/rtems/timespec.h (modified) * cpukit/sapi/inline/rtems/timespec.inl (modified) * testsuites/fstests/fsfpathconf/fsfpathconf.doc (modified) * testsuites/fstests/fsfpathconf/test.c (modified) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) * testsuites/sptests/sp77/init.c (modified) * testsuites/sptests/sp77/sp77.doc (modified) * testsuites/sptests/sptimespec01/init.c (modified) Cleanup Krzysztof's copyright notices. Sun, 07 Oct 2012 15:11:30 GMT Sebastian Huber [39d7d51] * testsuites/fstests/fsimfsgeneric01/init.c (modified) fstests/fsimfsgeneric01: Avoid global state Tue, 02 Oct 2012 13:44:59 GMT Sebastian Huber [c17d0b3] * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) Filesystem: Reject removal of root nodes Reject the removal of file ... Tue, 02 Oct 2012 14:13:00 GMT Sebastian Huber [9b83a66] * cpukit/score/src/threaddispatch.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical18/Makefile.am (added) * testsuites/sptests/spintrcritical18/init.c (added) * testsuites/sptests/spintrcritical18/spintrcritical18.doc (added) * testsuites/sptests/spintrcritical18/spintrcritical18.scn (added) score: Critical fix for thread dispatching The changes in ... Wed, 03 Oct 2012 16:09:32 GMT Joel Sherrill [cb7b57e1] * cpukit/mghttpd/Makefile.am (modified) * cpukit/mghttpd/preinstall.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) mghttpd: Requires POSIX to build server and tests Formerly, mghttpd ... Fri, 28 Sep 2012 19:07:24 GMT Joel Sherrill [29b1bbf] * testsuites/fstests/fsrfsbitmap01/test.c (modified) fsrfsbitmap01/test.c: Remove tabs Fri, 28 Sep 2012 19:04:08 GMT Joel Sherrill [35c58a56] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/fsfpathconf/fsfpathconf.doc (modified) * testsuites/fstests/fsfpathconf/test.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) misc fstests: Remove spaces at EOL Wed, 26 Sep 2012 11:42:11 GMT Krzysztof Miesowicz [445b2bd6] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc (added) * testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.scn (added) * testsuites/fstests/fsrfsbitmap01/test.c (added) * testsuites/fstests/mrfs_fsrfsbitmap01/Makefile.am (added) New fstest to cover RFS bitmaps - fsrfsbitmap01 Sat, 01 Sep 2012 08:50:54 GMT Krzysztof Miesowicz [37b18d21] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsfpathconf/fsfpathconf.doc (added) * testsuites/fstests/fsfpathconf/fsfpathconf.scn (added) * testsuites/fstests/fsfpathconf/test.c (added) * testsuites/fstests/mrfs_fsfpathconf/Makefile.am (added) new fstest hitting fpathconf function Wed, 29 Aug 2012 12:38:54 GMT Krzysztof Mięsowicz [a6eaa548] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/timespec.h (added) * cpukit/sapi/inline/rtems/timespec.inl (added) * cpukit/sapi/preinstall.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sptimespec01/Makefile.am (added) * testsuites/sptests/sptimespec01/init.c (added) * testsuites/sptests/sptimespec01/sptimespec01.doc (added) * testsuites/sptests/sptimespec01/sptimespec01.scn (added) timespec helpers: Add wrappers with new test Wed, 29 Aug 2012 12:35:23 GMT Krzysztof Mięsowicz [3913e3cf] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp77/Makefile.am (added) * testsuites/sptests/sp77/init.c (added) * testsuites/sptests/sp77/sp77.doc (added) * testsuites/sptests/sp77/sp77.scn (added) sp77: new test to cover allocated message size overflowing Author: ... Mon, 06 Aug 2012 17:04:24 GMT Gedare Bloom [57e922c7] * .gitignore (modified) * cpukit/config.h.in (deleted) * testsuites/fstests/config.h.in (deleted) * testsuites/libtests/config.h.in (deleted) * testsuites/mptests/config.h.in (deleted) * testsuites/psxtests/config.h.in (deleted) * testsuites/psxtmtests/config.h.in (deleted) * testsuites/samples/config.h.in (deleted) * testsuites/sptests/config.h.in (deleted) * testsuites/tmtests/config.h.in (deleted) Revert "Add config.h.in." This reverts commit ... Thu, 19 Jul 2012 14:14:53 GMT Ralf Corsépius [1c554014] * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/README (modified) * c/src/lib/libbsp/mips/hurricane/make/custom/hurricane.cfg (modified) * c/src/lib/libbsp/mips/hurricane/startup/ghlinkcmds (modified) * c/src/lib/libbsp/mips/hurricane/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4925/README (modified) * c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4938/README (modified) * c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/linkcmds (modified) * c/src/lib/libbsp/mips/shared/liblnk/lnklib.S (modified) * c/src/lib/libbsp/mips/shared/startup/idttlb.S (modified) * c/src/lib/libbsp/powerpc/beatnik/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/ep1a/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/README (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2cdrv.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/i2c.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/i2cdrv.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/todcfg.c (modified) * c/src/lib/libbsp/powerpc/haleakala/dlentry/dlentry.S (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.mtx603e (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) * c/src/lib/libbsp/sparc/leon3/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/sparc/shared/include/pci.h (modified) * c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S (modified) * c/src/libchip/network/README.3com (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/cs8900.h (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libmisc/fsmount/README (modified) * cpukit/posix/src/ptimer.c (modified) * testsuites/samples/fileio/system.h (modified) Remove CVS-Ids. Thu, 19 Jul 2012 13:59:46 GMT Ralf Corsépius [59bd5115] * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * testsuites/samples/fileio/Makefile.am (modified) Remove CVS-Ids. Thu, 19 Jul 2012 13:47:55 GMT Ralf Corsépius [bb2b825] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Require automake-1.12.2. Thu, 19 Jul 2012 13:44:32 GMT Ralf Corsépius [0f77281] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/rtemsrpms/configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Require autoconf-2.69. Tue, 17 Jul 2012 09:27:50 GMT Sebastian Huber [cd035725] * testsuites/psxtests/psxchroot01/test.c (modified) psxtests/psxchroot01: Typo Tue, 17 Jul 2012 09:24:56 GMT Sebastian Huber [d6460e81] * testsuites/psxtests/psxpipe01/init.c (modified) psxtests/psxpipe01: Use greedy allocation API Tue, 17 Jul 2012 08:45:17 GMT Sebastian Huber [c8615dcf] * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) libtests/termios01: Use greedy allocation API Tue, 17 Jul 2012 08:19:16 GMT Sebastian Huber [317ee8d] * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heapgreedy.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/devfs02/init.c (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxkey01/init.c (modified) * testsuites/psxtests/psxmsgq02/init.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/sptests/spfatal22/testcase.h (modified) * testsuites/sptests/spprivenv01/init.c (modified) score: Change greedy allocation API Tue, 03 Jul 2012 08:42:17 GMT Christian Mauderer [0eb5bfba] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/mghttpd01/Makefile.am (added) * testsuites/libtests/mghttpd01/init.c (added) * testsuites/libtests/mghttpd01/init_fs.tar (added) * testsuites/libtests/mghttpd01/mghttpd01.doc (added) * testsuites/libtests/mghttpd01/mghttpd01.scn (added) * testsuites/libtests/mghttpd01/test-http-client.c (added) * testsuites/libtests/mghttpd01/test-http-client.h (added) libtests/mghttpd01: New test Mon, 02 Jul 2012 14:58:01 GMT Sebastian Huber [71092f7] * cpukit/libblock/src/bdbuf.c (modified) * testsuites/libtests/block13/init.c (modified) libblock: Fix read-ahead trigger and next update The previous ... Mon, 02 Jul 2012 14:06:10 GMT Sebastian Huber [f29d969] * cpukit/libblock/src/bdbuf.c (modified) * testsuites/libtests/block13/block13.scn (modified) * testsuites/libtests/block13/init.c (modified) libblock: Fix read-ahead trigger and next update Mon, 02 Jul 2012 13:08:08 GMT Sebastian Huber [f12249f] * cpukit/libblock/src/bdbuf.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block15/Makefile.am (added) * testsuites/libtests/block15/block15.doc (added) * testsuites/libtests/block15/block15.scn (added) * testsuites/libtests/block15/init.c (added) * testsuites/libtests/configure.ac (modified) libblock: Fix continuous blocks write request Mon, 02 Jul 2012 13:08:24 GMT Sebastian Huber [6a03786d] * testsuites/libtests/block06/init.c (modified) libtests/block06: Increase stack size Tue, 19 Jun 2012 13:53:56 GMT Sebastian Huber [361a400] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsfseeko01/Makefile.am (added) * testsuites/fstests/fsfseeko01/fsfseeko01.doc (added) * testsuites/fstests/fsfseeko01/fsfseeko01.scn (added) * testsuites/fstests/fsfseeko01/init.c (added) fstests/fsfseeko01: New test Wed, 13 Jun 2012 09:29:53 GMT Sebastian Huber [3246b0f8] * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptime.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * testsuites/sptests/spsize/size.c (modified) score: New structure TOD_Control Group the global TOD variables ... Tue, 12 Jun 2012 07:46:09 GMT Sebastian Huber [9f527308] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev-blkstats.c (added) * cpukit/libblock/src/blkdev-ioctl.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (added) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_blkstats.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block14/Makefile.am (added) * testsuites/libtests/block14/block14.doc (added) * testsuites/libtests/block14/block14.scn (added) * testsuites/libtests/block14/init.c (added) * testsuites/libtests/configure.ac (modified) libblock: Add block device statistics Mon, 04 Jun 2012 15:04:49 GMT Sebastian Huber [1f7b5b0] * testsuites/libtests/block13/init.c (modified) libtests/block13: Add const qualifier Mon, 04 Jun 2012 07:41:13 GMT Sebastian Huber [b8ed6d80] * testsuites/libtests/block05/init.c (modified) libtests/block05: Fix warnings Thu, 31 May 2012 08:27:29 GMT Sebastian Huber [39ee704e] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/diskdevs-init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block13/Makefile.am (added) * testsuites/libtests/block13/block13.doc (added) * testsuites/libtests/block13/block13.scn (added) * testsuites/libtests/block13/init.c (added) * testsuites/libtests/configure.ac (modified) libblock: Add read-ahead task Read-ahead requests were previously ... Thu, 31 May 2012 20:34:36 GMT Joel Sherrill [721fe34] * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5235/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5329/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/powerpc/beatnik/flash/flashcfg.c (modified) * c/src/lib/libbsp/powerpc/shared/flash/spansionFlash.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/termios04/termios_testdriver_intr.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) Fix C files which had two semi-colons at EOL Sat, 12 May 2012 16:12:57 GMT Joel Sherrill [5f0cd34] * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/capture/init.c (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/loopback/init.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/nsecs/init.c (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/pppd/init.c (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/unlimited/init.c (modified) samples - Eliminate missing prototype warnings
