# # ChangeLog for testsuites in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 16:51:07 Sat, 21 Mar 2015 19:45:10 GMT Joel Sherrill [dc8ab440] * testsuites/sptests/sptls01/init.c (modified) sptls01/init.c: Use larger data types for values Fri, 20 Mar 2015 15:50:13 GMT Joel Sherrill [73a2caf] * testsuites/sptests/spwatchdog/init.c (modified) sptests/spwatchdog/init.c: Avoid integer overflow Fri, 20 Mar 2015 15:49:06 GMT Joel Sherrill [2fe0f16d] * testsuites/sptests/spedfsched02/init.c (modified) * testsuites/sptests/spedfsched02/system.h (modified) sptests/spedfsched02: Reduce stack space usage to fix on smaller targets Fri, 20 Mar 2015 15:48:32 GMT Joel Sherrill [c6ef870] * testsuites/sptests/spatomic01/init.c (modified) sptests/spatomic01/init.c: Avoid integer overflow Fri, 20 Mar 2015 15:47:59 GMT Joel Sherrill [70757114] * testsuites/sptests/sp34/changepri.c (modified) sptests/sp34/changepri.c: Correct printf() warning Fri, 20 Mar 2015 15:47:41 GMT Joel Sherrill [6c1aff66] * testsuites/sptests/sp33/init.c (modified) sptests/sp33/init.c: Correct printf() warning Sat, 21 Mar 2015 19:43:47 GMT Joel Sherrill [6849e53] * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/system.h (modified) sptests/sp20: Reduce memory requirements This was checked on ... Fri, 20 Mar 2015 15:47:14 GMT Joel Sherrill [2be0342] * testsuites/sptests/sp13/system.h (modified) sptests/sp13/system.h: Fine tune message buffer configuration to ... Fri, 20 Mar 2015 15:46:18 GMT Joel Sherrill [52a34a7] * testsuites/sptests/sp12/pritask.c (modified) sptests/sp12/pritask.c: Correct printf() warning Fri, 20 Mar 2015 15:45:55 GMT Joel Sherrill [ab90136b] * testsuites/psxtests/psxconfig01/init.c (modified) psxconfig01/init.c: Correct pointer/integer size warning Fri, 20 Mar 2015 15:45:28 GMT Joel Sherrill [278da87] * testsuites/psxtests/psx15/init.c (modified) psxtests/psx15/init.c: Correct printf() warning Sun, 22 Mar 2015 19:59:52 GMT Joel Sherrill [59efbdd4] * testsuites/libtests/malloctest/init.c (modified) malloctest/init.c: Fix use uninitialized warning Fri, 20 Mar 2015 15:38:44 GMT Joel Sherrill [e0437fe] * testsuites/psxtests/psxsignal03/init.c (modified) testsuites/psxtests/psxsignal03/init.c: Fix line wrap Thu, 19 Mar 2015 17:29:17 GMT Joel Sherrill [f061f2f] * testsuites/testdata/disable-jffs2-tests.tcfg (added) * testsuites/testdata/disable-mrfs-tests.tcfg (added) testsuites/testdata: Add sets to disable all jffs2 and mrfs tests Sun, 22 Mar 2015 13:31:59 GMT Sebastian Huber [a6524b9] * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Simplify debug code and use _Assert() Sat, 21 Mar 2015 19:14:45 GMT Sebastian Huber [40a24661] * testsuites/sptests/spintrcritical23/init.c (modified) sptests/spintrcritical23: Fix warnings Fri, 20 Mar 2015 13:09:26 GMT Sebastian Huber [d4edbdbc] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (modified) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (modified) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn-shell.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap-shell.h (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rap.h (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-chain-iterator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-find-file.h (modified) * cpukit/libdl/rtl-fwd.h (modified) * cpukit/libdl/rtl-indirect-ptr.h (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-cache.h (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj-comp.h (modified) * cpukit/libdl/rtl-obj-fwd.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-shell.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-trace.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unresolved.h (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * testsuites/psxtests/psxclock01/init.c (modified) * testsuites/sptests/spclock_err01/delay.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spclock_err01/system.h (modified) * testsuites/sptests/spevent_err03/init.c (modified) * testsuites/sptests/spevent_err03/system.h (modified) * testsuites/sptests/spintr_err01/init.c (modified) * testsuites/sptests/spintr_err01/isr.c (modified) * testsuites/sptests/spintr_err01/system.h (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) * testsuites/sptests/spmsgq_err01/system.h (modified) * testsuites/sptests/spmsgq_err02/init.c (modified) * testsuites/sptests/spmsgq_err02/system.h (modified) * testsuites/sptests/spmsgq_err02/task3.c (modified) * testsuites/sptests/spport_err01/init.c (modified) * testsuites/sptests/spport_err01/system.h (modified) * testsuites/sptests/spratemon_err01/init.c (modified) * testsuites/sptests/spratemon_err01/screen10.c (modified) * testsuites/sptests/spratemon_err01/system.h (modified) * testsuites/sptests/spratemon_err01/task4.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/init.c (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/spsem_err02/task2.c (modified) * testsuites/sptests/spsignal_err01/init.c (modified) * testsuites/sptests/spsignal_err01/isr.c (modified) * testsuites/sptests/spsignal_err01/system.h (modified) * testsuites/sptests/sptask_err01/init.c (modified) * testsuites/sptests/sptask_err01/system.h (modified) * testsuites/sptests/sptask_err01/task2.c (modified) * testsuites/sptests/sptask_err02/init.c (modified) * testsuites/sptests/sptask_err02/system.h (modified) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptask_err03/system.h (modified) * testsuites/sptests/sptask_err04/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) Replace www.rtems.com with www.rtems.org Tue, 17 Mar 2015 15:24:44 GMT Sebastian Huber [6a941e3] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical23/Makefile.am (added) * testsuites/sptests/spintrcritical23/init.c (added) * testsuites/sptests/spintrcritical23/spintrcritical23.doc (added) * testsuites/sptests/spintrcritical23/spintrcritical23.scn (added) score: Fix _Thread_Change_priority() Atomically update the current ... Sun, 15 Mar 2015 15:31:01 GMT Joel Sherrill [72d3f1a6] * testsuites/sptests/spcbssched03/tasks_periodic.c (modified) spcbssched03/tasks_periodic.c: Fixed now used before set warning Sat, 14 Mar 2015 16:08:01 GMT Joel Sherrill [3c69c467] * testsuites/sptests/spcbssched02/task_periodic.c (modified) * testsuites/sptests/spcbssched03/tasks_aperiodic.c (modified) * testsuites/sptests/spcbssched03/tasks_periodic.c (modified) * testsuites/sptests/spedfsched03/tasks_aperiodic.c (modified) * testsuites/sptests/spedfsched03/tasks_periodic.c (modified) * testsuites/sptests/spqreslib/task_periodic.c (modified) sptests misc: Update to not use deprecated methods Sat, 14 Mar 2015 15:52:24 GMT Joel Sherrill [e334edd] * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spclockget/init.c (modified) * testsuites/sptests/spnotepad01/init.c (modified) * testsuites/sptests/sptask_err04/task1.c (modified) * testsuites/tmtests/tm08/task1.c (modified) tests misc: Disable deprecated method usage warning when intentional ... Sat, 14 Mar 2015 15:48:00 GMT Joel Sherrill [979bda9] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.scn (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/spnotepad02/Makefile.am (added) * testsuites/sptests/spnotepad02/init.c (added) * testsuites/sptests/spnotepad02/spnotepad02.doc (added) * testsuites/sptests/spnotepad02/spnotepad02.scn (added) tm07: Split some code into new spnotepad02. Use of deprecated ... Sat, 14 Mar 2015 15:34:33 GMT Joel Sherrill [0e6f915c] * testsuites/samples/minimum/init.c (modified) testsuites/samples/minimum/init.c: Notepads no longer need to be ... Tue, 17 Mar 2015 09:32:20 GMT Sebastian Huber [8c7eb00] * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testparallel.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) testsupport: Add worker setup handler Add ... Mon, 16 Mar 2015 12:52:19 GMT Sebastian Huber [dc5e5f44] * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tmtests/tmfine01/Makefile.am (added) * testsuites/tmtests/tmfine01/init.c (added) * testsuites/tmtests/tmfine01/tmfine01.doc (added) * testsuites/tmtests/tmfine01/tmfine01.scn (added) tmtests/tmfine01: New test Fri, 06 Mar 2015 17:41:49 GMT Gedare Bloom [3ac68119] * c/src/librtems++/include/rtems++/rtemsTask.h (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/spnotepad01/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) cpukit: deprecate notepads Deprecate Classic API Notepads. Mark ... Mon, 09 Mar 2015 12:18:36 GMT Sebastian Huber [1f67156] * cpukit/libcsupport/src/__gettod.c (modified) * testsuites/psxtests/psxtime/test.c (modified) libcsupport: Delete superfluous _gettimeofday() Mon, 09 Mar 2015 14:23:20 GMT Sebastian Huber [40ecd11] * cpukit/posix/src/sysconf.c (modified) * testsuites/psxtests/psxsysconf/init.c (modified) sysconf: Add _SC_NPROCESSORS_(CONF|ONLN) Mon, 09 Mar 2015 12:52:49 GMT Sebastian Huber [19799fb] * testsuites/libtests/stringto01/init.c (modified) * testsuites/libtests/stringto01/stringto_test_template.h (modified) libtests/stringto01: Fix for GCC 5.0 Fri, 06 Mar 2015 14:34:03 GMT Joel Sherrill [19a1f6b] * cpukit/configure.ac (modified) * testsuites/libtests/configure.ac (modified) Temporarily disable libdl for h8300 The h8300 gets a linking error ... Thu, 05 Mar 2015 16:11:12 GMT Joel Sherrill [ee113c2] * testsuites/testdata/dltests-broken-on-this-bsp.tcfg (added) dltests-broken-on-this-bsp.tcfg: New file used for dl* tests work around Thu, 05 Mar 2015 23:33:38 GMT Joel Sherrill [a726ca64] * cpukit/configure.ac (modified) * testsuites/libtests/configure.ac (modified) Temporarily disable libdl for lm32 There is a GCC ICE when building ... Wed, 04 Mar 2015 21:13:24 GMT Joel Sherrill [1d061ee] * cpukit/configure.ac (modified) * testsuites/libtests/configure.ac (modified) Temporarily disable libdl for v850 There is an issue linking dl0* ... Wed, 04 Mar 2015 21:10:42 GMT Joel Sherrill [9bef63e] * cpukit/configure.ac (modified) * testsuites/libtests/configure.ac (modified) Temporarily disable libdl for bfin There is an issue linking dl0* ... Fri, 06 Mar 2015 15:13:40 GMT Alexander Krutwig [33b72fd] * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testparallel.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) testsupport: Add cascade option to parallel test Wed, 04 Mar 2015 07:02:19 GMT Sebastian Huber [7d6e94b] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/eventimpl.h (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventdata.c (deleted) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/tasks.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical21/init.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Implement fine-grained locking for events Use the ISR lock ... Thu, 26 Feb 2015 09:32:08 GMT Sebastian Huber [222dc775] * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Add and use _Thread_Do_dispatch() The _Thread_Dispatch() ... Thu, 26 Feb 2015 09:33:36 GMT Sebastian Huber [b8a5abf] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/tmtests/tm04/task1.c (modified) score: Update _Thread_Heir only if necessary Previously, the ... Thu, 05 Mar 2015 09:11:23 GMT Sebastian Huber [d0061287] * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) tests: Fix warnings Thu, 05 Mar 2015 08:06:44 GMT Alexander Krutwig [7f577d3] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testparallel.c (added) * testsuites/smptests/smpatomic01/init.c (modified) tests: Refactor parallel test execution Wed, 04 Mar 2015 20:53:36 GMT Joel Sherrill [461a930] * testsuites/libtests/capture01/capture01.scn (modified) capture01: Update screen file Tue, 03 Mar 2015 21:15:00 GMT Joel Sherrill [57a914a3] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsscandir01/fsscandir01.doc (added) * testsuites/fstests/fsscandir01/init.c (added) * testsuites/fstests/imfs_fsscandir01/Makefile.am (added) * testsuites/fstests/imfs_fsscandir01/imfs_fsscandir01.scn (added) * testsuites/fstests/jffs2_fsscandir01/Makefile.am (added) * testsuites/fstests/jffs2_fsscandir01/jffs2_fsscandir01.scn (added) * testsuites/fstests/mdosfs_fsscandir01/Makefile.am (added) * testsuites/fstests/mdosfs_fsscandir01/mdosfs_fsscandir01.scn (added) * testsuites/fstests/mimfs_fsscandir01/Makefile.am (added) * testsuites/fstests/mimfs_fsscandir01/mimfs_fsscandir01.scn (added) * testsuites/fstests/mrfs_fsscandir01/Makefile.am (added) * testsuites/fstests/mrfs_fsscandir01/mrfs_fsscandir01.scn (added) Add simple test for scandir() on all file systems tested updates 1394 Tue, 03 Mar 2015 16:08:51 GMT Gedare Bloom [56c7192] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxclock01/Makefile.am (added) * testsuites/psxtests/psxclock01/init.c (added) * testsuites/psxtests/psxclock01/psxclock01.doc (added) * testsuites/psxtests/psxclock01/psxclock01.scn (added) psxtests/psxclock01: use clock() and CLOCKS_PER_SEC Closes #2182 Wed, 04 Mar 2015 09:15:02 GMT Sebastian Huber [e50297e] * cpukit/score/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: ISR lock C/C++ compatiblity issue Empty structures are ... Wed, 04 Mar 2015 10:56:25 GMT Sebastian Huber [c5436ff4] * testsuites/smptests/smpcapture01/init.c (modified) * testsuites/smptests/smpcapture01/smpcapture01.scn (modified) smptests/smpcapture01: Avoid livelock condition Thu, 26 Feb 2015 09:26:49 GMT Sebastian Huber [0324410] * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) smptests: Do not use Giant directly This ensures that thread ... Thu, 26 Feb 2015 11:55:43 GMT Sebastian Huber [6357e14a] * testsuites/psxtests/psx05/init.c (modified) psxtests/psx05: Adjust test case Update #2170. Thu, 26 Feb 2015 09:19:38 GMT Sebastian Huber [bd1c9248] * testsuites/sptests/sp76/init.c (modified) sptests/sp76: Check that the right task executes Mon, 23 Feb 2015 14:59:49 GMT Gedare Bloom [83fe4468] * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx12/init.c (modified) psxtests: add string param to printf. closes #2241 Fri, 20 Feb 2015 08:42:15 GMT Sebastian Huber [a45dfa14] * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.scn (modified) IMFS: Fix copy on write for linfiles Thu, 19 Feb 2015 10:12:01 GMT Sebastian Huber [a3316f47] * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/sptask_err01/system.h (modified) sptests: Add missing test extension Wed, 18 Feb 2015 16:46:37 GMT Sebastian Huber [4e3d9a4d] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/atomic.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/preinstall.am (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpatomic01/smpatomic01.scn (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spatomic01/Makefile.am (added) * testsuites/sptests/spatomic01/init.c (added) * testsuites/sptests/spatomic01/spatomic01.doc (added) * testsuites/sptests/spatomic01/spatomic01.scn (added) score: Make available Make ... Mon, 16 Feb 2015 10:55:03 GMT Sebastian Huber [c34f94f7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/shared/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) score: Add _CPU_SMP_Prepare_start_multitasking() Update #2268. Sun, 15 Feb 2015 09:38:15 GMT Sebastian Huber [a43a3466] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * testsuites/psxtests/psxstat/test.c (modified) IMFS: Implement variable length node names This reduces the average ... Sat, 14 Feb 2015 19:07:19 GMT Sebastian Huber [f785492] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_dir.c (added) * cpukit/libfs/src/imfs/imfs_dir_default.c (moved) * cpukit/libfs/src/imfs/imfs_dir_minimal.c (added) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (deleted) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR Fri, 13 Feb 2015 20:26:17 GMT Sebastian Huber [249766c5] * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) IMFS: Rename CONFIGURE_IMFS_DISABLE_FCHMOD Rename ... Fri, 13 Feb 2015 20:11:55 GMT Sebastian Huber [40a18d7f] * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) IMFS: Add CONFIGURE_IMFS_DISABLE_MKNOD_FILE Fri, 13 Feb 2015 19:53:41 GMT Sebastian Huber [12eee4fd] * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsimfsconfig01/init.c (modified) * testsuites/fstests/fsimfsconfig03/Makefile.am (added) * testsuites/fstests/fsimfsconfig03/fsimfsconfig03.doc (added) * testsuites/fstests/fsimfsconfig03/fsimfsconfig03.scn (added) * testsuites/fstests/fsimfsconfig03/init.c (added) IMFS: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM Resurrect ... Wed, 11 Feb 2015 19:59:29 GMT Joel Sherrill [b57a6a7] * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_destroy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_init.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setdetachstate.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setguardsize.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setinheritsched.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedpolicy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setscope.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstack.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstackaddr.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstacksize.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cancel.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cleanup.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_broadcast.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_destroy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_signal.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_wait.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_destroy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_init.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_setpshared.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_create.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_detach.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_equal.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_exit.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_getcpuclockid.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_getschedparam.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_getspecific.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_join.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_key_create.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_key_delete.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_destroy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_lock.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_setprioceiling.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_trylock.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_unlock.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_destroy.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprioceiling.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_init.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprioceiling.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprotocol.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setpshared.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_once.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_self.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_setcancelstate.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_setcanceltype.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_setschedparam.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_setspecific.c (moved) * testsuites/psxtests/psxhdrs/pthread/pthread_testcancel.c (moved) * testsuites/psxtests/psxhdrs/pthread11.c (deleted) * testsuites/psxtests/psxhdrs/pthread12.c (deleted) * testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_getparam.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_setparam.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c (moved) * testsuites/psxtests/psxhdrs/sched/sched_yield.c (moved) * testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c (moved) * testsuites/psxtests/psxhdrs/signal/raise.c (moved) * testsuites/psxtests/psxhdrs/signal/signal.c (moved) * testsuites/psxtests/psxhdrs/signal/sigpending.c (moved) * testsuites/psxtests/psxhdrs/signal/sigprocmask.c (moved) * testsuites/psxtests/psxhdrs/signal/sigsuspend.c (moved) * testsuites/psxtests/psxhdrs/signal/sigtimedwait.c (moved) * testsuites/psxtests/psxhdrs/signal/sigwait.c (moved) * testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c (moved) * testsuites/psxtests/psxhdrs/signal01.c (deleted) * testsuites/psxtests/psxhdrs/signal02.c (deleted) * testsuites/psxtests/psxhdrs/signal03.c (deleted) * testsuites/psxtests/psxhdrs/signal04.c (deleted) * testsuites/psxtests/psxhdrs/signal05.c (deleted) * testsuites/psxtests/psxhdrs/signal06.c (deleted) * testsuites/psxtests/psxhdrs/signal07.c (deleted) * testsuites/psxtests/psxhdrs/signal08.c (deleted) * testsuites/psxtests/psxhdrs/signal09.c (deleted) * testsuites/psxtests/psxhdrs/signal10.c (deleted) * testsuites/psxtests/psxhdrs/time/asctime.c (moved) * testsuites/psxtests/psxhdrs/time/asctime_r.c (moved) * testsuites/psxtests/psxhdrs/time/clock.c (moved) * testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c (moved) * testsuites/psxtests/psxhdrs/time/clock_getenable_attr.c (moved) * testsuites/psxtests/psxhdrs/time/clock_getres.c (moved) * testsuites/psxtests/psxhdrs/time/clock_gettime.c (moved) * testsuites/psxtests/psxhdrs/time/clock_setenable_attr.c (moved) * testsuites/psxtests/psxhdrs/time/clock_settime.c (moved) * testsuites/psxtests/psxhdrs/time/ctime.c (moved) * testsuites/psxtests/psxhdrs/time/ctime_r.c (moved) * testsuites/psxtests/psxhdrs/time/difftime.c (moved) * testsuites/psxtests/psxhdrs/time/gmtime.c (moved) * testsuites/psxtests/psxhdrs/time/gmtime_r.c (moved) * testsuites/psxtests/psxhdrs/time/localtime.c (moved) * testsuites/psxtests/psxhdrs/time/localtime_r.c (moved) * testsuites/psxtests/psxhdrs/time/mktime.c (moved) * testsuites/psxtests/psxhdrs/time/nanosleep.c (moved) * testsuites/psxtests/psxhdrs/time/strftime.c (moved) * testsuites/psxtests/psxhdrs/time/time.c (moved) * testsuites/psxtests/psxhdrs/time/timer_create.c (moved) * testsuites/psxtests/psxhdrs/time/timer_delete.c (moved) * testsuites/psxtests/psxhdrs/time/timer_getoverrun.c (moved) * testsuites/psxtests/psxhdrs/time/timer_gettime.c (moved) * testsuites/psxtests/psxhdrs/time/timer_settime.c (moved) * testsuites/psxtests/psxhdrs/unistd/alarm.c (moved) * testsuites/psxtests/psxhdrs/unistd/fdatasync.c (moved) * testsuites/psxtests/psxhdrs/unistd/fsync.c (moved) * testsuites/psxtests/psxhdrs/unistd/getegid.c (moved) * testsuites/psxtests/psxhdrs/unistd/geteuid.c (moved) * testsuites/psxtests/psxhdrs/unistd/getgid.c (moved) * testsuites/psxtests/psxhdrs/unistd/getgroups.c (moved) * testsuites/psxtests/psxhdrs/unistd/getlogin.c (moved) * testsuites/psxtests/psxhdrs/unistd/getlogin_r.c (moved) * testsuites/psxtests/psxhdrs/unistd/getpgrp.c (moved) * testsuites/psxtests/psxhdrs/unistd/getpid.c (moved) * testsuites/psxtests/psxhdrs/unistd/getppid.c (moved) * testsuites/psxtests/psxhdrs/unistd/getuid.c (moved) * testsuites/psxtests/psxhdrs/unistd/pause.c (moved) * testsuites/psxtests/psxhdrs/unistd/setgid.c (moved) * testsuites/psxtests/psxhdrs/unistd/setpgid.c (moved) * testsuites/psxtests/psxhdrs/unistd/setsid.c (moved) * testsuites/psxtests/psxhdrs/unistd/setuid.c (moved) * testsuites/psxtests/psxhdrs/unistd/sleep.c (moved) * testsuites/psxtests/psxhdrs/unistd/sync.c (moved) * testsuites/psxtests/psxhdrs/unistd/ualarm.c (moved) * testsuites/psxtests/psxhdrs/unistd/usleep.c (moved) psxhdrs: Reorganize into subdirectories per .h file and rename files ... Wed, 11 Feb 2015 19:31:30 GMT Joel Sherrill [86076f3] * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxhdrs/pthread35.c (deleted) * testsuites/psxtests/psxhdrs/pthread36.c (deleted) psxhdrs: Remove test of pthread_attr_[gs]et_cputime These methods ... Wed, 11 Feb 2015 20:00:35 GMT Joel Sherrill [eedaf9b] * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/socket/accept.c (added) * testsuites/psxtests/psxhdrs/sys/socket/bind.c (added) * testsuites/psxtests/psxhdrs/sys/socket/connect.c (added) * testsuites/psxtests/psxhdrs/sys/socket/getpeername.c (added) * testsuites/psxtests/psxhdrs/sys/socket/getsockname.c (added) * testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c (added) * testsuites/psxtests/psxhdrs/sys/socket/listen.c (added) * testsuites/psxtests/psxhdrs/sys/socket/recv.c (added) * testsuites/psxtests/psxhdrs/sys/socket/recvfrom.c (added) * testsuites/psxtests/psxhdrs/sys/socket/recvmsg.c (added) * testsuites/psxtests/psxhdrs/sys/socket/send.c (added) * testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c (added) * testsuites/psxtests/psxhdrs/sys/socket/sendto.c (added) * testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c (added) * testsuites/psxtests/psxhdrs/sys/socket/shutdown.c (added) * testsuites/psxtests/psxhdrs/sys/socket/socket.c (added) * testsuites/psxtests/psxhdrs/sys/socket/socketpair.c (added) psxhdrs: Add tests for API compliance Sun, 08 Feb 2015 18:43:09 GMT Sebastian Huber [a9df916] * c/src/lib/libbsp/powerpc/beatnik/irq/irq_test_app.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (deleted) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsimfsconfig01/Makefile.am (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.doc (added) * testsuites/fstests/fsimfsconfig01/fsimfsconfig01.scn (added) * testsuites/fstests/fsimfsconfig01/init.c (added) * testsuites/fstests/fsimfsconfig02/Makefile.am (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.doc (added) * testsuites/fstests/fsimfsconfig02/fsimfsconfig02.scn (added) * testsuites/fstests/fsimfsconfig02/init.c (added) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/libtests/tar03/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/sptests/sp47/init.c (modified) * testsuites/sptests/sp48/init.c (modified) IMFS: Add fine grained configuration Remove miniIMFS. Statically ... Fri, 06 Feb 2015 15:32:39 GMT Sebastian Huber [60cf8a5] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) IMFS: Add root directory to FS info Fix memory leak in IMFS_fsunmount(). Thu, 05 Feb 2015 15:14:59 GMT Sebastian Huber [24ec25d] * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) IMFS: Introduce IMFS_mknod_control Drop ... Wed, 04 Feb 2015 09:04:05 GMT Daniel Cederman [8d8573ac] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpcapture02/Makefile.am (added) * testsuites/smptests/smpcapture02/init.c (added) * testsuites/smptests/smpcapture02/smpcapture02.doc (added) * testsuites/smptests/smpcapture02/smpcapture02.scn (added) smpcapture02: Add test of functionality to add custom entries to ... Mon, 09 Feb 2015 18:09:23 GMT Sebastian Huber [16939b18] * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) Filesystem: Simplify FIFO and pipe configuration Fri, 06 Feb 2015 20:12:38 GMT Sebastian Huber [b4e52ce9] * testsuites/fstests/fsrename/test.c (modified) fstests/fsrename: Avoid double initialization Mon, 02 Feb 2015 14:25:26 GMT Sebastian Huber [efd2965a] * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal22/Makefile.am (deleted) * testsuites/sptests/spfatal22/spfatal22.doc (deleted) * testsuites/sptests/spfatal22/spfatal22.scn (deleted) * testsuites/sptests/spfatal22/testcase.h (deleted) Filesystem: Statically initialize rtems_libio_iops Wed, 31 Dec 2014 09:56:05 GMT Sebastian Huber [cf36b70] * cpukit/dev/i2c/i2c-bus.c (modified) * cpukit/dev/i2c/i2c-dev.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (deleted) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.scn (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psximfs02/psximfs02.scn (modified) IMFS: Replace node union with individual struct This reduces the ... Fri, 23 Jan 2015 15:46:48 GMT Joel Sherrill [80bfd3a] * testsuites/psxtests/psx07/init.c (modified) psx07: Add missing parameter to printf() call Close 2241. ... Fri, 23 Jan 2015 11:49:44 GMT Sebastian Huber [ffb1a45] * testsuites/psxtests/psx07/init.c (modified) psxtests/psx07: Fix printf() statement Close #2240. Sun, 21 Dec 2014 19:12:28 GMT Sebastian Huber [c625a641] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/sup_fs_node_type.c (deleted) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_node_type.c (deleted) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (deleted) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (deleted) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (deleted) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) Filesystem: Delete node type operation Use the fstat handler instead. Thu, 15 Jan 2015 13:13:19 GMT Sebastian Huber [f87ede5] * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/samples/loopback/init.c (modified) libnetworking: Fix close of active sockets Send a special event to ... Mon, 19 Jan 2015 12:53:51 GMT Marcos Diaz [8a7048a] * testsuites/libtests/dl01/Makefile.am (modified) * testsuites/libtests/dl02/Makefile.am (modified) Fixed dl01 and dl02 makefiles Wed, 14 Jan 2015 06:34:44 GMT Sebastian Huber [77c5ddd4] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Fix task delete race condition Do not supsend ... Tue, 23 Dec 2014 10:05:21 GMT Sebastian Huber [7f28f237] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * testsuites/sptests/spsize/size.c (modified) powerpc: Delete _CPU_IRQ_info Mon, 22 Dec 2014 06:15:49 GMT Sebastian Huber [b3ed66a] * testsuites/libtests/crypt01/init.c (modified) libtests/crypt01: Increase stack size Thu, 08 Jan 2015 09:43:56 GMT Sebastian Huber [e7d175af] * testsuites/smptests/smpwakeafter01/init.c (modified) smptests/smpwakeafter01: Fix task count Mon, 22 Dec 2014 14:10:32 GMT Sebastian Huber [ad0743db] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Update run indicator only once On the Freescale ... Wed, 17 Dec 2014 14:11:00 GMT Sebastian Huber [864d3475] * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smp: Fix timeout for MrsP semaphores The previous timeout handling ... Mon, 15 Dec 2014 13:19:43 GMT Sebastian Huber [a0b1b5ed] * cpukit/libi2c/libi2c.h (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/fstests/fsfseeko01/init.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) * testsuites/fstests/fsrofs01/init.c (modified) * testsuites/fstests/imfs_support/fs_support.c (modified) * testsuites/fstests/jffs2_support/fs_support.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/block17/init.c (modified) * testsuites/libtests/crypt01/init.c (modified) * testsuites/libtests/devfs03/init.c (modified) * testsuites/libtests/deviceio01/init.c (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/libtests/i2c01/init.c (modified) * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/monitor02/system.h (modified) * testsuites/libtests/newlib01/init.c (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp02/init.c (modified) * testsuites/libtests/sha/init.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) * testsuites/libtests/syscall01/init.c (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/utf8proc01/init.c (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxaio01/system.h (modified) * testsuites/psxtests/psxaio02/system.h (modified) * testsuites/psxtests/psxaio03/system.h (modified) * testsuites/psxtests/psxchroot01/main.c (modified) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile02/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) * testsuites/psxtests/psxpipe01/init.c (modified) * testsuites/psxtests/psxrdwrv/main.c (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/loopback/init.c (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spfifo01/init.c (modified) * testsuites/sptests/spfifo02/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spnsext01/init.c (modified) * testsuites/sptests/spprofiling01/init.c (modified) * testsuites/sptests/spresource01/init.c (modified) * testsuites/sptests/spscheduler01/init.c (modified) * testsuites/sptests/spsem03/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM This define was ... Mon, 15 Dec 2014 02:26:31 GMT Nick Withers [f42d429] * cpukit/mghttpd/Makefile.am (modified) * testsuites/libtests/mghttpd01/init.c (modified) * testsuites/libtests/mghttpd01/test-http-client.c (modified) * testsuites/libtests/mghttpd01/test-http-client.h (modified) Enable WebSocket support in the Mongoose HTTP server Fri, 12 Dec 2014 07:46:30 GMT Sebastian Huber [7bdb765] * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) Add POSIX key value pairs to resource snapshot Fri, 12 Dec 2014 12:16:11 GMT Sebastian Huber [172e953] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * testsuites/psxtests/psxkey02/init.c (modified) posix: Delete key/value if value is set to NULL Fri, 07 Mar 2014 03:23:30 GMT Nick Withers [9d9c426] * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * testsuites/libtests/tar02/init.c (modified) * testsuites/libtests/tar02/tar02.scn (modified) Teach rtems_tarfs_load() about symlinks Mon, 08 Dec 2014 08:47:58 GMT Sebastian Huber [f3730d56] * testsuites/libtests/complex/docomplex.h (modified) libtests/complex: Avoid multiple definitions Thu, 04 Dec 2014 09:03:50 GMT Sebastian Huber [12072880] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Update bug report URL Thu, 04 Dec 2014 08:38:27 GMT Sebastian Huber [e870941] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/shared/bspinit.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/README (deleted) * cpukit/libmisc/dummy/default-configuration.c (added) * cpukit/libmisc/dummy/dummy.c (deleted) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/defaultconfig01/Makefile.am (added) * testsuites/libtests/defaultconfig01/defaultconfig01.doc (added) * testsuites/libtests/defaultconfig01/defaultconfig01.scn (added) * testsuites/libtests/defaultconfig01/init.c (added) libmisc: More useful default configuration The dummy.c was a ... Wed, 03 Dec 2014 10:14:42 GMT Sebastian Huber [0104056] * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) sptests: Add get_one_tick_busy_value() Extract this function from ... Tue, 02 Dec 2014 09:35:13 GMT Sebastian Huber [f54e503] * testsuites/libtests/configure.ac (modified) libtests: Omit libdl tests if no RTEMS tools Wed, 04 Jun 2014 14:02:11 GMT Daniel Hellstrom [e7e92da] * testsuites/libtests/devfs04/init.c (modified) DEVFS04: make test work on LEON3-FT GR712RC The LEON3 BSP have ... Tue, 11 Nov 2014 13:17:55 GMT Daniel Hellstrom [9e8d8b5c] * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/spcpuset01.doc (modified) * testsuites/sptests/spcpuset01/spcpuset01.scn (modified) spcpuset01: fix test comments Mon, 01 Dec 2014 07:20:55 GMT Sebastian Huber [80d99aa] * testsuites/libtests/complex/docomplex.h (modified) * testsuites/libtests/math/domath.h (modified) libtests/complex,math: Prevent optimizations For constant arguments ... Thu, 27 Nov 2014 10:44:48 GMT Sebastian Huber [01557b0] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/calloc.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_get_statistics.c (deleted) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_report_statistics.c (deleted) * cpukit/libcsupport/src/malloc_report_statistics_plugin.c (deleted) * cpukit/libcsupport/src/malloc_statistics_helpers.c (deleted) * cpukit/libcsupport/src/posix_memalign.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/shell/memory.t (modified) * doc/user/conf.t (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/malloc05/Makefile.am (deleted) * testsuites/libtests/malloc05/init.c (deleted) * testsuites/libtests/malloc05/malloc05.doc (deleted) * testsuites/libtests/malloc05/malloc05.scn (deleted) * testsuites/libtests/malloctest/task1.c (modified) libcsupport: Delete malloc statistics Use the heap handler ... Thu, 27 Nov 2014 07:45:10 GMT Sebastian Huber [0ff1c29] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Use busy waits Use busy waits instead of sleeps ... Wed, 26 Nov 2014 10:51:34 GMT Sebastian Huber [5bd822a7] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smp: Fix scheduler helping protocol Ensure that scheduler nodes in ... Tue, 25 Nov 2014 15:47:20 GMT Sebastian Huber [038faca1] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/cachecoherentalloc.c (added) * cpukit/rtems/include/rtems/rtems/cache.h (modified) * testsuites/sptests/spcache01/init.c (modified) * testsuites/sptests/spcache01/spcache01.doc (modified) * testsuites/sptests/spcache01/spcache01.scn (modified) rtems: Add rtems_cache_coherent_allocate() Add ... Mon, 24 Nov 2014 20:49:28 GMT Jennifer Averett [39af57c3] * testsuites/smptests/smp09/init.c (modified) smp09: Resolve missing prototype warning. Mon, 24 Nov 2014 20:48:58 GMT Jennifer Averett [6291e962] * testsuites/smptests/smp07/init.c (modified) smp07: Resolve missing prototype warning. Mon, 24 Nov 2014 20:48:31 GMT Jennifer Averett [2c474a0] * testsuites/smptests/smp05/init.c (modified) smp05: Resolve missing prototype warning.
