# # ChangeLog for testsuites in rtems # # Generated by Trac 1.2.1.dev0 # 05/30/24 15:14:44 Wed, 02 Apr 1997 16:26:39 GMT Joel Sherrill [51f5d64c] * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp25/system.h (modified) corrected printf format to avoid warning Wed, 02 Apr 1997 16:26:28 GMT Joel Sherrill [892a536d] * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) initialized variables or removed unused variables to remove warnings Wed, 29 Jan 1997 00:31:56 GMT Joel Sherrill [2a3d1fd] * c/src/tests/support/include/tmacros.h (modified) * testsuites/support/include/tmacros.h (modified) Made stopping for the pause an option which can be configured in the ... Wed, 08 Jan 1997 16:22:22 GMT Joel Sherrill [d135fc52] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) _CPU_Trap_Table_area is now conditional based on whether or not the ... Wed, 18 Sep 1996 22:23:15 GMT Joel Sherrill [1f4f392a] * c/src/tests/psxtests/psx04/task1.c (added) * c/src/tests/psxtests/psx04/task2.c (added) * c/src/tests/psxtests/psx04/task3.c (added) * testsuites/psxtests/psx04/task1.c (added) * testsuites/psxtests/psx04/task2.c (added) * testsuites/psxtests/psx04/task3.c (added) new files Wed, 18 Sep 1996 21:07:37 GMT Joel Sherrill [7abd27b] * c/src/tests/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task1.c (modified) added cast Wed, 18 Sep 1996 21:07:14 GMT Joel Sherrill [c3e3d07] * c/src/tests/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/blow.c (modified) address arithmetic changed to be more portable Wed, 18 Sep 1996 21:06:49 GMT Joel Sherrill [4a5e651] * c/src/tests/libtests/malloctest/init.c (added) * c/src/tests/libtests/malloctest/system.h (added) * c/src/tests/libtests/malloctest/task1.c (added) * testsuites/libtests/malloctest/init.c (added) * testsuites/libtests/malloctest/system.h (added) * testsuites/libtests/malloctest/task1.c (added) new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick ... Tue, 17 Sep 1996 21:38:59 GMT Joel Sherrill [cc51de91] * c/src/tests/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/system.h (modified) extended Task_id and Task_name arrays to avoid indexing past end of ... Thu, 12 Sep 1996 20:41:27 GMT Mark Johannes [09093ee] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Fixed test to match change to pthread_cond_timedwait which now takes ... Fri, 06 Sep 1996 15:17:39 GMT Joel Sherrill [2ffcc2ed] * c/src/tests/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/init.c (modified) modified test to take into account change in default value of ... Thu, 05 Sep 1996 20:31:32 GMT Joel Sherrill [7e230f10] * c/src/tests/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task2.c (modified) added printf of status when not successful Thu, 05 Sep 1996 20:03:19 GMT Joel Sherrill [f254b93f] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) nanosleep no longer consider a negative value of tv_sec to be an ... Fri, 23 Aug 1996 15:58:24 GMT Mark Johannes [e4cc4176] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Changed all EFAULTS to EINVALs Fri, 23 Aug 1996 15:56:50 GMT Mark Johannes [3adf786] * c/src/tests/psxtests/psx12/psx12.scn (modified) * testsuites/psxtests/psx12/psx12.scn (modified) filled in screen Fri, 23 Aug 1996 15:56:22 GMT Mark Johannes [237088c] * c/src/tests/psxtests/psx10/psx10.scn (added) * c/src/tests/psxtests/psx11/psx11.scn (modified) * testsuites/psxtests/psx10/psx10.scn (added) * testsuites/psxtests/psx11/psx11.scn (modified) Filled in screen Fri, 23 Aug 1996 15:55:02 GMT Mark Johannes [78f5dae] * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx02/psx02.scn (modified) * c/src/tests/psxtests/psx03/psx03.scn (modified) * c/src/tests/psxtests/psx04/psx04.scn (modified) * c/src/tests/psxtests/psx05/psx05.scn (modified) * c/src/tests/psxtests/psx06/psx06.scn (modified) * c/src/tests/psxtests/psx07/psx07.scn (modified) * c/src/tests/psxtests/psx08/psx08.scn (modified) * c/src/tests/psxtests/psx09/psx09.scn (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx02/psx02.scn (modified) * testsuites/psxtests/psx03/psx03.scn (modified) * testsuites/psxtests/psx04/psx04.scn (modified) * testsuites/psxtests/psx05/psx05.scn (modified) * testsuites/psxtests/psx06/psx06.scn (modified) * testsuites/psxtests/psx07/psx07.scn (modified) * testsuites/psxtests/psx08/psx08.scn (modified) * testsuites/psxtests/psx09/psx09.scn (modified) Filled in the screen Fri, 23 Aug 1996 15:50:53 GMT Mark Johannes [e2ceeca7] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) Added build_time statement to provide a tm for the test Fri, 23 Aug 1996 15:17:16 GMT Mark Johannes [257adba] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Changed test 5 to test 10 at bottom Thu, 22 Aug 1996 20:18:44 GMT Mark Johannes [df70c6b] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Commented out the EINVAL for mutex not acquired befor cond_wait call Wed, 21 Aug 1996 15:49:21 GMT Mark Johannes [6702bffc] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) updated to support ENOTSUP Tue, 20 Aug 1996 21:41:08 GMT Mark Johannes [256a462] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) Added Einval case for mutex not initialized Thu, 15 Aug 1996 19:27:08 GMT Mark Johannes [7fb19bb] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) init: added tests for pthread_kill and kill errors. Thu, 15 Aug 1996 18:59:34 GMT Joel Sherrill [851b18d] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) changed error code Thu, 15 Aug 1996 18:59:00 GMT Joel Sherrill [fdf6917] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) changed error for too many threads to EAGAIN Wed, 14 Aug 1996 20:25:57 GMT Joel Sherrill [fb7d080] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) pthread_mutex_init returns EAGAIN not ENOMEM when there are too many ... Wed, 14 Aug 1996 19:41:47 GMT Joel Sherrill [ac81b6ca] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added test cases for NULL being passed to pthread attribute get routines Wed, 14 Aug 1996 19:30:49 GMT Joel Sherrill [ff53a6d4] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added test case for pthread_attr_getscope being passed a NULL ... Wed, 14 Aug 1996 17:19:03 GMT Mark Johannes [87c8fd09] * c/src/tests/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/system.h (modified) system.h: added task3 and changed condition variable config to 1 Wed, 14 Aug 1996 17:18:02 GMT Mark Johannes [b0c483ed] * c/src/tests/psxtests/psx10/task3.c (added) * testsuites/psxtests/psx10/task3.c (added) task3: added to test error case in Wait_support for lock on mutex Wed, 14 Aug 1996 17:16:14 GMT Mark Johannes [520949bf] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) init: added error case for wait timedwait, and wait support Wed, 14 Aug 1996 15:27:14 GMT Joel Sherrill [645fc954] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope Tue, 13 Aug 1996 19:06:45 GMT Mark Johannes [c8a4ed6] * c/src/tests/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task2.c (modified) task_2: added comments and print statement for task exit Tue, 13 Aug 1996 19:06:12 GMT Mark Johannes [1d428a3c] * c/src/tests/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task.c (modified) task_1: added comments and print statement for task exit Tue, 13 Aug 1996 19:05:27 GMT Mark Johannes [c9c94387] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init.c: added timewait case, added broadcast case Tue, 13 Aug 1996 15:36:28 GMT Joel Sherrill [9b67f170] * c/src/tests/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/init.c (modified) corrected problem in which sigtimedwait() was being invoked with the ... Tue, 13 Aug 1996 15:35:36 GMT Joel Sherrill [fc960ab] * c/src/tests/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx03/task.c (modified) chenaged format of output Tue, 13 Aug 1996 14:47:52 GMT Joel Sherrill [0d59c7a] * c/src/tests/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/system.h (modified) added include of errno.h so the test can check for EINTR. Tue, 13 Aug 1996 14:47:31 GMT Joel Sherrill [85f5b4ab] * c/src/tests/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/init.c (modified) nanosleep now returns -1 and EINTR when a signal interrupts EINTR. Mon, 12 Aug 1996 21:52:37 GMT Mark Johannes [e9624663] * c/src/tests/psxtests/psx10/task.c (added) * testsuites/psxtests/psx10/task.c (added) task_1: added to handle cases of waiting tasks on condition variables Mon, 12 Aug 1996 21:51:44 GMT Mark Johannes [a7f4c5a] * c/src/tests/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/system.h (modified) system.h: added protoypes for task and task2, added mutex id, and ... Mon, 12 Aug 1996 21:49:54 GMT Mark Johannes [aad3fe6] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init.c: added cases for signal, wait and broadcast Mon, 12 Aug 1996 21:49:14 GMT Mark Johannes [08515de] * c/src/tests/psxtests/psx10/task2.c (added) * testsuites/psxtests/psx10/task2.c (added) Task2: new task for broadcast case Mon, 12 Aug 1996 21:15:15 GMT Joel Sherrill [5da2ae8] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test cases for clock_getres Mon, 12 Aug 1996 20:00:02 GMT Joel Sherrill [221bd65] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added test case for stack too large Mon, 12 Aug 1996 19:54:12 GMT Joel Sherrill [c4f5e752] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test cases for clock_gettime (invalid id), clock_settime ... Mon, 12 Aug 1996 19:20:18 GMT Joel Sherrill [d60d9505] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test case for non-NULL parameter to time() Mon, 12 Aug 1996 18:04:38 GMT Joel Sherrill [d06e9ca] * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) added numerous error test cases. Mon, 12 Aug 1996 15:15:51 GMT Mark Johannes [0cd15947] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init: added pthread_cond_init with an attr non-NULL, initialized the ... Mon, 12 Aug 1996 14:49:02 GMT Mark Johannes [5263668] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init: added prliminary phtread_cond_init and destroy cases. Mon, 12 Aug 1996 14:48:13 GMT Mark Johannes [da4e38d] * c/src/tests/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/system.h (modified) system.h: added condition variable #define for 10 condition variables Fri, 09 Aug 1996 21:16:01 GMT Joel Sherrill [da2e539] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) added test cases for errors in pthread_mutexattr_getpshared Fri, 09 Aug 1996 19:55:04 GMT Joel Sherrill [13adea0] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) added test cases for EINVAL cases in pthread_mutexattr_destroy Fri, 09 Aug 1996 19:50:26 GMT Joel Sherrill [c03aeaf] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) added test case for pthread_mutexattr_init being passed a null pointer. Fri, 09 Aug 1996 19:20:54 GMT Joel Sherrill [76117f2b] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) changed style of output to match other tests Fri, 09 Aug 1996 19:10:50 GMT Mark Johannes [1406a4b] * c/src/tests/psxtests/psx10/system.h (added) * testsuites/psxtests/psx10/system.h (added) system.h: initial cvs Fri, 09 Aug 1996 18:48:33 GMT Joel Sherrill [c7dd091f] * c/src/tests/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/system.h (modified) lowered maximum number of threads to 2 to make test case easier. ... Fri, 09 Aug 1996 18:47:58 GMT Joel Sherrill [d0b5249] * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/task.c (modified) added test case for sched_yield. changed format of some output. Fri, 09 Aug 1996 18:47:38 GMT Joel Sherrill [f643e230] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test cases for errors in sched_get_priority_min and ... Fri, 09 Aug 1996 18:28:21 GMT Mark Johannes [695dd0b] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init: added condattr - destroy, init, set and get cases Fri, 09 Aug 1996 17:44:04 GMT Joel Sherrill [66dfd0b] * c/src/tests/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/init.c (modified) added test cases for invalid key ids Fri, 09 Aug 1996 16:02:06 GMT Joel Sherrill [760ee96d] * c/src/tests/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/system.h (modified) reduced maximum keys to 2 to more easily generate error Fri, 09 Aug 1996 16:01:50 GMT Joel Sherrill [5b08e20] * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) changed printf's which could be puts's to puts Thu, 08 Aug 1996 23:02:13 GMT Joel Sherrill [54e34e7] * c/src/tests/psxtests/psx12/init.c (added) * c/src/tests/psxtests/psx12/psx12.scn (added) * c/src/tests/psxtests/psx12/system.h (added) * c/src/tests/psxtests/psx12/task.c (added) * testsuites/psxtests/psx12/init.c (added) * testsuites/psxtests/psx12/psx12.scn (added) * testsuites/psxtests/psx12/system.h (added) * testsuites/psxtests/psx12/task.c (added) new test to test scheduling policy and paremeter paths in pthread_create. Thu, 08 Aug 1996 22:26:55 GMT Mark Johannes [13642cbc] * c/src/tests/psxtests/psx10/init.c (added) * testsuites/psxtests/psx10/init.c (added) Init: Original file - tests for condition variables. Thu, 08 Aug 1996 21:58:26 GMT Joel Sherrill [79f189e] * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task2.c (added) * c/src/tests/psxtests/psx05/task3.c (added) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task2.c (added) * testsuites/psxtests/psx05/task3.c (added) split test into multiple tasks. Thu, 08 Aug 1996 21:46:40 GMT Joel Sherrill [76de65b3] * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (added) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (added) added cases to increase coverage of pthread_create. cases added ... Thu, 08 Aug 1996 20:47:49 GMT Joel Sherrill [2b613588] * c/src/tests/psxtests/psx11/init.c (added) * c/src/tests/psxtests/psx11/psx11.scn (added) * c/src/tests/psxtests/psx11/system.h (added) * c/src/tests/psxtests/psx11/task.c (added) * testsuites/psxtests/psx11/init.c (added) * testsuites/psxtests/psx11/psx11.scn (added) * testsuites/psxtests/psx11/system.h (added) * testsuites/psxtests/psx11/task.c (added) added test to complete coverage of pthread_setschedparam and increase ... Thu, 08 Aug 1996 19:21:47 GMT Mark Johannes [8ca831af] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) Init: spacing Thu, 08 Aug 1996 19:20:13 GMT Mark Johannes [e3515731] * c/src/tests/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task.c (modified) Task_1: changed comment and task name to task1. Thu, 08 Aug 1996 19:19:09 GMT Mark Johannes [9f1a034e] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) Init.c: added priority ceiling task cases. Thu, 08 Aug 1996 18:50:39 GMT Mark Johannes [77597dd] * c/src/tests/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/system.h (modified) Added task2 and task3 prototypes and ids Thu, 08 Aug 1996 18:44:09 GMT Mark Johannes [481d8f8] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Signal_info_handler: added multiple signal cases to finish out the test Thu, 08 Aug 1996 18:27:44 GMT Joel Sherrill [4357da1] * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) changed phrase "RTEMS is support" to "RTEMS is supposed" Thu, 08 Aug 1996 16:53:32 GMT Joel Sherrill [8b1c1ae] * c/src/tests/psxtests/include/pmacros.h (modified) * c/src/tests/psxtests/support/include/pmacros.h (modified) * testsuites/psxtests/include/pmacros.h (modified) print_current_time: added leading underscore to variables allocated ... Thu, 08 Aug 1996 16:28:24 GMT Joel Sherrill [644c0fa6] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) added complete test cases for pthread_once. Wed, 07 Aug 1996 22:05:15 GMT Joel Sherrill [ecc912f4] * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/task.c (modified) added more error cases to complete testing of pthread_equal when ... Wed, 07 Aug 1996 22:00:57 GMT Joel Sherrill [42418a9] * c/src/tests/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/init.c (modified) added test cases for ESRCH from pthread_join and pthread_detach Wed, 07 Aug 1996 21:38:18 GMT Joel Sherrill [84b03316] * c/src/tests/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/init.c (modified) removed if 0 for basic sporadic server case accidentally left in. Wed, 07 Aug 1996 21:27:25 GMT Joel Sherrill [7e811af1] * c/src/tests/psxtests/psx09/init.c (added) * c/src/tests/psxtests/psx09/psx09.scn (added) * c/src/tests/psxtests/psx09/system.h (added) * testsuites/psxtests/psx09/init.c (added) * testsuites/psxtests/psx09/psx09.scn (added) * testsuites/psxtests/psx09/system.h (added) basic sporadic server test. sporadic server with priority ceiling ... Wed, 07 Aug 1996 15:52:30 GMT Joel Sherrill [c123a084] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added complete test cases for pthread_attr_getschedparam, ... Fri, 02 Aug 1996 18:25:16 GMT Joel Sherrill [20de272] * c/src/tests/psxtests/psx08/init.c (added) * c/src/tests/psxtests/psx08/psx08.scn (added) * c/src/tests/psxtests/psx08/system.h (added) * c/src/tests/psxtests/psx08/task.c (added) * c/src/tests/psxtests/psx08/task2.c (added) * testsuites/psxtests/psx08/init.c (added) * testsuites/psxtests/psx08/psx08.scn (added) * testsuites/psxtests/psx08/system.h (added) * testsuites/psxtests/psx08/task2.c (added) join/detach basic tests pass Fri, 02 Aug 1996 16:46:56 GMT Joel Sherrill [375f37d] * c/src/tests/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/system.h (modified) removed unused prototypes Thu, 01 Aug 1996 21:02:54 GMT Joel Sherrill [870f2976] * c/src/tests/psxtests/psx07/init.c (added) * c/src/tests/psxtests/psx07/psx07.scn (added) * c/src/tests/psxtests/psx07/system.h (added) * testsuites/psxtests/psx07/init.c (added) * testsuites/psxtests/psx07/psx07.scn (added) * testsuites/psxtests/psx07/system.h (added) test successfully exercises all of pthread_attr_* set and get routines Wed, 31 Jul 1996 17:17:48 GMT Joel Sherrill [c65a0cee] * c/src/tests/psxtests/psx06/init.c (added) * c/src/tests/psxtests/psx06/psx06.scn (added) * c/src/tests/psxtests/psx06/system.h (added) * c/src/tests/psxtests/psx06/task.c (added) * c/src/tests/psxtests/psx06/task2.c (added) * testsuites/psxtests/psx06/init.c (added) * testsuites/psxtests/psx06/psx06.scn (added) * testsuites/psxtests/psx06/system.h (added) * testsuites/psxtests/psx06/task.c (added) * testsuites/psxtests/psx06/task2.c (added) added key test Thu, 04 Jul 1996 17:38:55 GMT Joel Sherrill [ce78b894] * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/task.c (modified) added test case for timeout using pthread_mutex_timedlock Thu, 04 Jul 1996 17:01:48 GMT Joel Sherrill [c6d15c2] * c/src/tests/psxtests/psx05/init.c (added) * c/src/tests/psxtests/psx05/psx05.scn (added) * c/src/tests/psxtests/psx05/system.h (added) * c/src/tests/psxtests/psx05/task.c (added) * testsuites/psxtests/psx05/init.c (added) * testsuites/psxtests/psx05/psx05.scn (added) * testsuites/psxtests/psx05/system.h (added) * testsuites/psxtests/psx05/task.c (added) first test cases for mutex manager pass Sat, 15 Jun 1996 19:56:19 GMT Joel Sherrill [f88310da] * c/src/tests/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/init.c (modified) initial modifications to test sigtimedwait. Thu, 13 Jun 1996 22:16:08 GMT Mark Johannes [36197e53] * c/src/tests/psxtests/psx03/init.c (added) * c/src/tests/psxtests/psx03/psx03.scn (added) * c/src/tests/psxtests/psx03/system.h (added) * c/src/tests/psxtests/psx03/task.c (added) * testsuites/psxtests/psx03/init.c (added) * testsuites/psxtests/psx03/psx03.scn (added) * testsuites/psxtests/psx03/system.h (added) * testsuites/psxtests/psx03/task.c (added) first successful run. Has test cases for a simple sigtimedwait() ... Thu, 13 Jun 1996 16:45:51 GMT Joel Sherrill [022923e] * c/src/tests/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/size.c (modified) Added _Thread_Do_post_task_switch_extension variable. Thu, 13 Jun 1996 16:45:11 GMT Joel Sherrill [728b5a7] * c/src/tests/psxtests/include/pmacros.h (modified) * c/src/tests/psxtests/support/include/pmacros.h (modified) * testsuites/psxtests/include/pmacros.h (modified) Added a macro for "empty_line" which will go between test cases. Thu, 13 Jun 1996 16:44:46 GMT Joel Sherrill [ce0f7d95] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Added more test cases for kill() and alarm(). kill() now can unblock ... Wed, 12 Jun 1996 22:52:13 GMT Joel Sherrill [1094754f] * c/src/tests/psxtests/psx04/init.c (added) * c/src/tests/psxtests/psx04/psx04.scn (added) * c/src/tests/psxtests/psx04/system.h (added) * testsuites/psxtests/psx04/init.c (added) * testsuites/psxtests/psx04/psx04.scn (added) * testsuites/psxtests/psx04/system.h (added) new files Tue, 11 Jun 1996 20:46:13 GMT Joel Sherrill [699fe08a] * c/src/tests/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/init.c (modified) Added test case which blocks a signal, sees what signals are pending, ... Tue, 11 Jun 1996 16:04:25 GMT Joel Sherrill [fb39f19] * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/task.c (modified) modified to test pthread_kill() to self and pthread_kill() to a ... Mon, 10 Jun 1996 20:51:31 GMT Joel Sherrill [1ba858d] * c/src/tests/psxtests/psx02/init.c (added) * c/src/tests/psxtests/psx02/psx02.scn (added) * c/src/tests/psxtests/psx02/system.h (added) * c/src/tests/psxtests/psx02/task.c (added) * testsuites/psxtests/psx02/init.c (added) * testsuites/psxtests/psx02/psx02.scn (added) * testsuites/psxtests/psx02/system.h (added) * testsuites/psxtests/psx02/task.c (added) new files. This test does a basic checkout of signals with a ... Mon, 10 Jun 1996 20:49:21 GMT Joel Sherrill [1e608b0f] * c/src/tests/psxtests/include/pmacros.h (added) * c/src/tests/psxtests/support/include/pmacros.h (added) * testsuites/psxtests/include/pmacros.h (added) new file Mon, 10 Jun 1996 20:49:08 GMT Joel Sherrill [893103c] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) moved the time macros to pmacros.h. Thu, 06 Jun 1996 19:16:20 GMT Joel Sherrill [0a359a7] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added include of and fixed warnings Wed, 05 Jun 1996 21:12:06 GMT Joel Sherrill [7aa4671] * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/thread.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/spsize/size.c (modified) added cpu_time_budget field to Thread_Control and removed the global ...
