# # ChangeLog for testsuites in rtems # # Generated by Trac 1.2.1.dev0 # 05/29/24 11:16:40 Fri, 14 Jun 2013 12:00:38 GMT Sebastian Huber [39e51758] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp01/tasks.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp02/tasks.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/tasks.c (modified) * testsuites/smptests/smpatomic02/tasks.c (modified) * testsuites/smptests/smpatomic03/tasks.c (modified) * testsuites/smptests/smpatomic04/tasks.c (modified) * testsuites/smptests/smpatomic05/tasks.c (modified) * testsuites/smptests/smpatomic06/tasks.c (modified) * testsuites/smptests/smpatomic07/tasks.c (modified) * testsuites/smptests/smplock01/init.c (modified) smp: Add and use _CPU_SMP_Get_current_processor() Add and use ... Mon, 15 Jul 2013 15:31:13 GMT WeiY [2e7f5798] * cpukit/aclocal/check-atomic.m4 (modified) * cpukit/configure.ac (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/preinstall.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpatomic01/Makefile.am (modified) * testsuites/smptests/smpatomic02/Makefile.am (modified) * testsuites/smptests/smpatomic03/Makefile.am (modified) * testsuites/smptests/smpatomic04/Makefile.am (modified) * testsuites/smptests/smpatomic05/Makefile.am (modified) * testsuites/smptests/smpatomic06/Makefile.am (modified) * testsuites/smptests/smpatomic07/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spatomic01/Makefile.am (modified) * testsuites/sptests/spatomic02/Makefile.am (modified) * testsuites/sptests/spatomic03/Makefile.am (modified) * testsuites/sptests/spatomic04/Makefile.am (modified) * testsuites/sptests/spatomic05/Makefile.am (modified) * testsuites/sptests/spatomic06/Makefile.am (modified) * testsuites/sptests/spatomic07/Makefile.am (modified) stdatomic.h support check when configure Mon, 15 Jul 2013 15:31:12 GMT WeiY [5186b55] * testsuites/smptests/smpatomic01/tasks.c (modified) * testsuites/smptests/smpatomic02/tasks.c (modified) * testsuites/smptests/smpatomic03/tasks.c (modified) * testsuites/smptests/smpatomic04/tasks.c (modified) * testsuites/smptests/smpatomic05/tasks.c (modified) * testsuites/smptests/smpatomic06/tasks.c (modified) * testsuites/smptests/smpatomic07/tasks.c (modified) smpatomic test case update Mon, 15 Jul 2013 15:31:11 GMT WeiY [a3e9c228] * testsuites/sptests/spatomic01/tasks.c (modified) * testsuites/sptests/spatomic02/tasks.c (modified) * testsuites/sptests/spatomic03/tasks.c (modified) * testsuites/sptests/spatomic04/tasks.c (modified) * testsuites/sptests/spatomic05/tasks.c (modified) * testsuites/sptests/spatomic06/tasks.c (modified) * testsuites/sptests/spatomic07/tasks.c (modified) spatomic test case update Fri, 05 Jul 2013 13:18:24 GMT Sebastian Huber [0d018268] * testsuites/psxtests/psxcleanup/psxcleanup.c (modified) psxtests/psxcleanup: Fix cleanup push/pop test The ... Fri, 05 Jul 2013 12:53:57 GMT Sebastian Huber [5e2a66d] * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (deleted) psxtests/psxhdrs: Fix cleanup push/pop test The ... Tue, 25 Jun 2013 09:15:18 GMT Sebastian Huber [b4062c3f] * testsuites/tmtests/tm20/task1.c (modified) tmtests/tm20: Change allocation sizes This avoids problems with ... Tue, 25 Jun 2013 10:22:23 GMT Sebastian Huber [22c7a64] * testsuites/psxtests/psxkey02/init.c (modified) * testsuites/psxtests/psxkey02/psxkey02.scn (modified) psxtests/psxkey02: Simplify This avoids problems with debugging enabled. Tue, 25 Jun 2013 09:13:15 GMT Sebastian Huber [d79973d] * testsuites/sptests/spwkspace/init.c (modified) sptests/spwkspace: Reserve space for duplicates Mon, 24 Jun 2013 11:44:51 GMT Sebastian Huber [8ebc680] * testsuites/sptests/spmountmgr01/init.c (modified) sptests/spmountmgr01: Simplify This avoids problems with debugging ... Tue, 25 Jun 2013 12:03:51 GMT Sebastian Huber [b9acb4e] * testsuites/sptests/sp64/init.c (modified) sptests/sp64: Simplify This avoids problems with debugging enabled. Tue, 25 Jun 2013 12:32:44 GMT Sebastian Huber [83889708] * testsuites/sptests/sp62/init.c (modified) sptests/sp62: Rework to avoid heap internals This avoids problems ... Tue, 25 Jun 2013 12:59:45 GMT Sebastian Huber [7c1fcff3] * testsuites/sptests/sp59/init.c (modified) sptests/sp59: Change allocation size This avoids problems with ... Tue, 25 Jun 2013 10:16:13 GMT Sebastian Huber [9f37fb1] * testsuites/sptests/sp18/init.c (modified) * testsuites/sptests/sp18/sp18.scn (modified) sptests/sp18: Simplify This avoids problems with debugging enabled. Tue, 25 Jun 2013 14:57:38 GMT Sebastian Huber [b64e8dc0] * testsuites/sptests/sp16/sp16.scn (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) sptests/sp16: Change allocation sizes This avoids problems with ... Tue, 25 Jun 2013 09:14:17 GMT Sebastian Huber [3948a0b] * testsuites/sptests/sp09/screen12.c (modified) sptests/sp09: Change allocation sizes This avoids problems with ... Mon, 17 Jun 2013 08:21:48 GMT Sebastian Huber [010e4058] * testsuites/smptests/smpschedule01/init.c (modified) smptests/smpschedule01: Update due to API change Mon, 17 Jun 2013 08:12:26 GMT Sebastian Huber [c4a236a] * testsuites/sptests/sp02/system.h (modified) Revert "sptests/sp02: Fix maximum task count" This reverts commit ... Tue, 11 Jun 2013 08:00:25 GMT Sebastian Huber [8b222be] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedule01/Makefile.am (added) * testsuites/smptests/smpschedule01/init.c (added) * testsuites/smptests/smpschedule01/smpschedule01.doc (added) * testsuites/smptests/smpschedule01/smpschedule01.scn (added) smptests/smpschedule01: New test Fri, 14 Jun 2013 12:26:34 GMT Sebastian Huber [edde99b] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpatomic02/init.c (modified) * testsuites/smptests/smpatomic03/init.c (modified) * testsuites/smptests/smpatomic04/init.c (modified) * testsuites/smptests/smpatomic05/init.c (modified) * testsuites/smptests/smpatomic06/init.c (modified) * testsuites/smptests/smpatomic07/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Rename rtems_smp_get_number_of_processors() Rename in ... Wed, 12 Jun 2013 07:25:39 GMT Sebastian Huber [49cdf40] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/support/include/tmacros.h (modified) score: Add and use _Thread_Dispatch_is_enabled() Delete ... Wed, 12 Jun 2013 09:29:12 GMT Sebastian Huber [ec978d9] * cpukit/score/inline/rtems/score/chain.inl (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spchain/spchain.scn (modified) score: Add _Chain_Insert_ordered_unprotected() Fri, 14 Jun 2013 11:04:43 GMT Sebastian Huber [6f8adb0] * testsuites/sptests/sp02/system.h (modified) sptests/sp02: Fix maximum task count Mon, 10 Jun 2013 09:14:35 GMT Sebastian Huber [c7bc6d4] * cpukit/rtems/include/rtems/rtems/intr.h (modified) * doc/user/intr.t (modified) * testsuites/sptests/sp37/init.c (modified) rtems: Add interrupt locks Interrupt locks are low-level lock to ... Fri, 22 Mar 2013 14:14:11 GMT Ralf Kirchner [581c9982] * testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h (added) * testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h (added) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdsosfsname01: Ensure endian correctness Tue, 26 Feb 2013 14:58:42 GMT Ralf Kirchner [e148397] * testsuites/fstests/fsdosfsname01/create_files.cs (added) * testsuites/fstests/fsdosfsname01/create_image.sh (added) * testsuites/fstests/fsdosfsname01/files.h (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (modified) * testsuites/fstests/fsdosfsname01/image.h (added) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdosfsname01: Add compatibility tests Test handling of file names ... Tue, 26 Feb 2013 14:18:55 GMT Ralf Kirchner [52f3aa0] * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdosfsname01: Add multibyte tests Test handling of file names and ... Tue, 26 Feb 2013 12:25:46 GMT Ralf Kirchner [2ee8b15] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/utf8proc01/Makefile.am (added) * testsuites/libtests/utf8proc01/init.c (added) * testsuites/libtests/utf8proc01/utf8proc01.doc (added) * testsuites/libtests/utf8proc01/utf8proc01.scn (added) libtests: Add new test: utf8proc01 utf8proc is a library for ... Tue, 26 Feb 2013 10:18:32 GMT Ralf Kirchner [ccd212e] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsdosfsname01/Makefile.am (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.scn (added) * testsuites/fstests/fsdosfsname01/init.c (added) fsdosfsname01: New test Test handling of file names and directory ... Wed, 29 May 2013 08:41:18 GMT Sebastian Huber [bbed1866] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smplock01/Makefile.am (added) * testsuites/smptests/smplock01/init.c (added) * testsuites/smptests/smplock01/smplock01.doc (added) * testsuites/smptests/smplock01/smplock01.scn (added) smptests/smplock01: New test Mon, 27 May 2013 15:31:46 GMT Sebastian Huber [e3be6915] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) score: Remove idle field of Per_CPU_Control This field is unused ... Fri, 31 May 2013 11:56:56 GMT Sebastian Huber [ac2bb464] * testsuites/smptests/smp08/init.c (modified) * testsuites/support/src/locked_print.c (modified) smptests: Use priority ceiling for locked print In case the ... Fri, 24 May 2013 08:03:40 GMT Sebastian Huber [10fd9533] * testsuites/smptests/smp09/init.c (modified) smptests/smp09: Add missing newline Tue, 21 May 2013 14:42:12 GMT Sebastian Huber [b734b9e8] * testsuites/smptests/smp01/init.c (modified) smptests/smp01: Do not assume CPU 0 runs Init Fri, 18 Jan 2013 08:42:00 GMT Sebastian Huber [db0cede1] * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp09/init.c (modified) smptests/smp01: Fix semaphore count The locked print needs one ... Wed, 22 May 2013 10:10:33 GMT Ralf Kirchner [e67025e] * cpukit/libfs/src/dosfs/dosfs.h (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) dosfs: Add RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE Tue, 26 Feb 2013 10:04:57 GMT Ralf Kirchner [8db586c8] * testsuites/fstests/support/ramdisk_support.c (modified) fstests: Use "tmacros.h" instead of "pmacros.h" Sun, 19 May 2013 21:30:06 GMT Gedare Bloom [26ecc74] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spsem02/Makefile.am (added) * testsuites/sptests/spsem02/init.c (added) * testsuites/sptests/spsem02/spsem02.doc (added) * testsuites/sptests/spsem02/spsem02.scn (added) sptests: add test to demonstrate bug in strict order mutex Sat, 18 May 2013 18:57:14 GMT Gedare Bloom [9cdbf73] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spsem01/Makefile.am (added) * testsuites/sptests/spsem01/init.c (added) * testsuites/sptests/spsem01/spsem01.doc (added) * testsuites/sptests/spsem01/spsem01.scn (added) sptests: add test for priority inversion with multiple locks Thu, 16 May 2013 09:38:57 GMT Sebastian Huber [12c99a64] * testsuites/fstests/fsstatvfs/test.c (modified) fstests/fsstatvfs: Fix end of test message Thu, 16 May 2013 09:23:46 GMT Andrei Mozzhuhin [56f22600] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (added) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsstatvfs/fsstatvfs.doc (added) * testsuites/fstests/fsstatvfs/test.c (added) * testsuites/fstests/mdosfs_fsstatvfs/Makefile.am (added) dosfs: Add statvfs() support Fri, 10 May 2013 09:58:39 GMT Sebastian Huber [9deed9ed] * testsuites/libtests/malloc04/init.c (modified) libtests/malloc04: Prevent compiler optimizations Tue, 07 May 2013 08:14:55 GMT Sebastian Huber [39993d6] * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm-context-validate.S (added) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-context-validate.S (added) * cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S (added) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (added) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (added) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * doc/porting/miscellaneous.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcontext01/Makefile.am (added) * testsuites/sptests/spcontext01/init.c (added) * testsuites/sptests/spcontext01/spcontext01.doc (added) * testsuites/sptests/spcontext01/spcontext01.scn (added) score: Add CPU context validation Fri, 03 May 2013 14:46:09 GMT Sebastian Huber [936c8d6] * testsuites/psxtests/psxtime/psxtime.scn (modified) * testsuites/psxtests/psxtime/test.c (modified) psxtests/psxtime: Reduce test time Fri, 03 May 2013 15:28:48 GMT Sebastian Huber [85387db5] * testsuites/libtests/malloc04/init.c (modified) * testsuites/libtests/malloc04/malloc04.doc (modified) * testsuites/libtests/malloc04/malloc04.scn (modified) libtests/malloc04: Adjust for new sbrk() support Tue, 23 Apr 2013 16:34:17 GMT WeiY [502693f5] * cpukit/configure.ac (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/preinstall.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spatomic01/Makefile.am (modified) * testsuites/sptests/spatomic02/Makefile.am (modified) * testsuites/sptests/spatomic03/Makefile.am (modified) * testsuites/sptests/spatomic04/Makefile.am (modified) * testsuites/sptests/spatomic05/Makefile.am (modified) * testsuites/sptests/spatomic06/Makefile.am (modified) * testsuites/sptests/spatomic07/Makefile.am (modified) Clear the atomic conditional compilation. Tue, 23 Apr 2013 12:30:52 GMT Sebastian Huber [dfd1508] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/exit02/Makefile.am (added) * testsuites/libtests/exit02/exit02.doc (added) * testsuites/libtests/exit02/exit02.scn (added) * testsuites/libtests/exit02/init.c (added) libtests/exit02: New test Tue, 23 Apr 2013 12:30:35 GMT Sebastian Huber [49120e8] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/exit01/Makefile.am (added) * testsuites/libtests/exit01/exit01.doc (added) * testsuites/libtests/exit01/exit01.scn (added) * testsuites/libtests/exit01/init.c (added) libtests/exit01: New test Wed, 17 Apr 2013 10:19:33 GMT Ralf Corsépius [f205c18f] * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/flashdisk01/test-file-system.c (modified) Use uint32_t instead of long. Use unsigned defines (Prevent overflows ... Thu, 11 Apr 2013 11:58:33 GMT Sebastian Huber [7b369af] * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/support/fstest_support.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/sptests/spatomic02/init.c (modified) * testsuites/sptests/spatomic03/init.c (modified) * testsuites/sptests/spatomic04/init.c (modified) * testsuites/sptests/spatomic05/init.c (modified) * testsuites/sptests/spatomic06/init.c (modified) * testsuites/sptests/spatomic07/init.c (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) testsuites: Fix warnings Mon, 08 Apr 2013 07:47:54 GMT Sebastian Huber [a53045fd] * testsuites/libtests/flashdisk01/init.c (modified) * testsuites/libtests/flashdisk01/test-file-system.c (modified) libtests/flashdisk01: Disable for small memory BSP Mon, 08 Apr 2013 07:46:22 GMT Sebastian Huber [b217a4b] * testsuites/sptests/spstkalloc02/init.c (modified) sptests/spstkalloc02: Disable for small memory BSP Fri, 08 Mar 2013 20:55:06 GMT Gedare Bloom [fad2d38] * ChangeLog (deleted) * c/ChangeLog (deleted) * c/src/ChangeLog (deleted) * c/src/ada-tests/ChangeLog (deleted) * c/src/ada/ChangeLog (deleted) * c/src/lib/libbsp/ChangeLog (deleted) * c/src/lib/libbsp/arm/ChangeLog (deleted) * c/src/lib/libbsp/arm/csb336/ChangeLog (deleted) * c/src/lib/libbsp/arm/csb337/ChangeLog (deleted) * c/src/lib/libbsp/arm/edb7312/ChangeLog (deleted) * c/src/lib/libbsp/arm/gba/ChangeLog (deleted) * c/src/lib/libbsp/arm/gdbarmsim/ChangeLog (deleted) * c/src/lib/libbsp/arm/gp32/ChangeLog (deleted) * c/src/lib/libbsp/arm/gumstix/ChangeLog (deleted) * c/src/lib/libbsp/arm/lm3s69xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/nds/ChangeLog (deleted) * c/src/lib/libbsp/arm/nds/tools/ChangeLog (deleted) * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/smdk2410/ChangeLog (deleted) * c/src/lib/libbsp/avr/ChangeLog (deleted) * c/src/lib/libbsp/avr/avrtest/ChangeLog (deleted) * c/src/lib/libbsp/bfin/ChangeLog (deleted) * c/src/lib/libbsp/bfin/TLL6527M/ChangeLog (deleted) * c/src/lib/libbsp/bfin/bf537Stamp/ChangeLog (deleted) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (deleted) * c/src/lib/libbsp/h8300/ChangeLog (deleted) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (deleted) * c/src/lib/libbsp/i386/ChangeLog (deleted) * c/src/lib/libbsp/i386/pc386/ChangeLog (deleted) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (deleted) * c/src/lib/libbsp/lm32/ChangeLog (deleted) * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (deleted) * c/src/lib/libbsp/lm32/milkymist/ChangeLog (deleted) * c/src/lib/libbsp/lm32/shared/ChangeLog (deleted) * c/src/lib/libbsp/m32c/ChangeLog (deleted) * c/src/lib/libbsp/m32c/m32cbsp/ChangeLog (deleted) * c/src/lib/libbsp/m32r/ChangeLog (deleted) * c/src/lib/libbsp/m32r/m32rsim/ChangeLog (deleted) * c/src/lib/libbsp/m68k/ChangeLog (deleted) * c/src/lib/libbsp/m68k/av5282/ChangeLog (deleted) * c/src/lib/libbsp/m68k/csb360/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (deleted) * c/src/lib/libbsp/m68k/genmcf548x/ChangeLog (deleted) * c/src/lib/libbsp/m68k/idp/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf52235/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5225x/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5329/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (deleted) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (deleted) * c/src/lib/libbsp/m68k/shared/gdbstub/ChangeLog (deleted) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (deleted) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (deleted) * c/src/lib/libbsp/mips/ChangeLog (deleted) * c/src/lib/libbsp/mips/csb350/ChangeLog (deleted) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (deleted) * c/src/lib/libbsp/mips/hurricane/ChangeLog (deleted) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (deleted) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (deleted) * c/src/lib/libbsp/mips/malta/ChangeLog (deleted) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (deleted) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (deleted) * c/src/lib/libbsp/nios2/ChangeLog (deleted) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (deleted) * c/src/lib/libbsp/no_cpu/ChangeLog (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/beatnik/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/psim/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/qemuppc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/qoriq/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/virtex/ChangeLog (deleted) * c/src/lib/libbsp/sh/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh1/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh2/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh4/ChangeLog (deleted) * c/src/lib/libbsp/sh/shsim/ChangeLog (deleted) * c/src/lib/libbsp/shared/ChangeLog (deleted) * c/src/lib/libbsp/sparc/ChangeLog (deleted) * c/src/lib/libbsp/sparc/erc32/ChangeLog (deleted) * c/src/lib/libbsp/sparc/leon2/ChangeLog (deleted) * c/src/lib/libbsp/sparc/leon3/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/niagara/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/usiii/ChangeLog (deleted) * c/src/lib/libcpu/ChangeLog (deleted) * c/src/lib/libcpu/arm/ChangeLog (deleted) * c/src/lib/libcpu/bfin/ChangeLog (deleted) * c/src/lib/libcpu/i386/ChangeLog (deleted) * c/src/lib/libcpu/lm32/ChangeLog (deleted) * c/src/lib/libcpu/m68k/ChangeLog (deleted) * c/src/lib/libcpu/mips/ChangeLog (deleted) * c/src/lib/libcpu/nios2/ChangeLog (deleted) * c/src/lib/libcpu/powerpc/ChangeLog (deleted) * c/src/lib/libcpu/sh/ChangeLog (deleted) * c/src/lib/libcpu/sparc/ChangeLog (deleted) * c/src/lib/libcpu/sparc64/ChangeLog (deleted) * c/src/librtems++/ChangeLog (deleted) * c/src/make/ChangeLog (deleted) * contrib/mingw/ChangeLog (deleted) * contrib/rtemsrpms/ChangeLog (deleted) * cpukit/ChangeLog (deleted) * cpukit/ChangeLog-pre2007 (deleted) * cpukit/score/cpu/arm/ChangeLog (deleted) * cpukit/score/cpu/avr/ChangeLog (deleted) * cpukit/score/cpu/bfin/ChangeLog (deleted) * cpukit/score/cpu/h8300/ChangeLog (deleted) * cpukit/score/cpu/i386/ChangeLog (deleted) * cpukit/score/cpu/lm32/ChangeLog (deleted) * cpukit/score/cpu/m32c/ChangeLog (deleted) * cpukit/score/cpu/m32r/ChangeLog (deleted) * cpukit/score/cpu/m68k/ChangeLog (deleted) * cpukit/score/cpu/mips/ChangeLog (deleted) * cpukit/score/cpu/nios2/ChangeLog (deleted) * cpukit/score/cpu/no_cpu/ChangeLog (deleted) * cpukit/score/cpu/powerpc/ChangeLog (deleted) * cpukit/score/cpu/sh/ChangeLog (deleted) * cpukit/score/cpu/sparc/ChangeLog (deleted) * cpukit/score/cpu/sparc64/ChangeLog (deleted) * cpukit/zlib/ChangeLog (deleted) * doc/ChangeLog (deleted) * doc/new_chapters/ChangeLog (deleted) * doc/relnotes/ChangeLog (deleted) * doc/tools/ChangeLog (deleted) * doc/tools/bmenu/ChangeLog (deleted) * make/ChangeLog (deleted) * testsuites/ChangeLog (deleted) * testsuites/fstests/ChangeLog (deleted) * testsuites/libtests/ChangeLog (deleted) * testsuites/mptests/ChangeLog (deleted) * testsuites/psxtests/ChangeLog (deleted) * testsuites/psxtmtests/ChangeLog (deleted) * testsuites/samples/ChangeLog (deleted) * testsuites/smptests/ChangeLog (deleted) * testsuites/sptests/ChangeLog (deleted) * testsuites/tmtests/ChangeLog (deleted) * testsuites/tools/ChangeLog (deleted) * testsuites/tools/generic/ChangeLog (deleted) * tools/build/ChangeLog (deleted) * tools/cpu/ChangeLog (deleted) * tools/cpu/generic/ChangeLog (deleted) * tools/cpu/nios2/ChangeLog (deleted) * tools/cpu/sh/ChangeLog (deleted) RTEMS: Delete ChangeLog files. This commit deletes all RTEMS ... Wed, 20 Feb 2013 12:30:43 GMT Sebastian Huber [71cf3e9d] * cpukit/libblock/src/bdbuf.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) * testsuites/fstests/support/ramdisk_support.c (modified) libblock: Do resource allocation in one place All resource ... Sun, 17 Feb 2013 11:57:27 GMT Sebastian Huber [4ddeb34] * testsuites/fstests/fsrdwr/init.c (modified) * testsuites/fstests/imfs_fsrdwr/imfs_fsrdwr.scn (modified) * testsuites/fstests/mimfs_fsrdwr/mimfs_fsrdwr.scn (modified) fstests/fsrdwr: Add test case Mon, 18 Feb 2013 14:27:40 GMT Sebastian Huber [3d6d4da] * testsuites/fstests/fsrdwr/init.c (modified) fstests/fsrdwr: Fix warning Fri, 15 Feb 2013 17:00:19 GMT Sebastian Huber [0a3a1b24] * testsuites/fstests/support/fstest_support.c (modified) fstests: Prevent compiler optimizations Thu, 14 Feb 2013 22:27:26 GMT Ralf Corsépius [1c0a6e63] * testsuites/sptests/spatomic01/Makefile.am (modified) * testsuites/sptests/spatomic02/Makefile.am (modified) * testsuites/sptests/spatomic03/Makefile.am (modified) * testsuites/sptests/spatomic04/Makefile.am (modified) * testsuites/sptests/spatomic05/Makefile.am (modified) * testsuites/sptests/spatomic06/Makefile.am (modified) * testsuites/sptests/spatomic07/Makefile.am (modified) Introduce AM_CONDITIONAL ATOMIC. Thu, 14 Feb 2013 22:27:00 GMT Ralf Corsépius [bdf90720] * testsuites/sptests/configure.ac (modified) Introduce AM_CONDITIONAL ATOMIC, cpuopt RTEMS_ATOMIC. Tue, 12 Feb 2013 13:15:43 GMT Sebastian Huber [9a2ead0] * testsuites/sptests/spfatal11/spfatal11.scn (modified) * testsuites/sptests/spfatal11/testcase.h (modified) sptests/spfatal11: Update due to API changes Sun, 27 Jan 2013 13:02:50 GMT Sebastian Huber [68f36d14] * cpukit/libcsupport/src/__assert.c (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spfatal10/testcase.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) score: Add and use rtems_assert_context Fri, 25 Jan 2013 16:01:17 GMT WeiY [7e02305] * testsuites/smptests/smpatomic01/Makefile.am (added) * testsuites/smptests/smpatomic01/init.c (added) * testsuites/smptests/smpatomic01/smpatomic01.doc (added) * testsuites/smptests/smpatomic01/smpatomic01.scn (added) * testsuites/smptests/smpatomic01/system.h (added) * testsuites/smptests/smpatomic01/tasks.c (added) * testsuites/smptests/smpatomic02/Makefile.am (added) * testsuites/smptests/smpatomic02/init.c (added) * testsuites/smptests/smpatomic02/smpatomic02.doc (added) * testsuites/smptests/smpatomic02/smpatomic02.scn (added) * testsuites/smptests/smpatomic02/system.h (added) * testsuites/smptests/smpatomic02/tasks.c (added) * testsuites/smptests/smpatomic03/Makefile.am (added) * testsuites/smptests/smpatomic03/init.c (added) * testsuites/smptests/smpatomic03/smpatomic03.doc (added) * testsuites/smptests/smpatomic03/smpatomic03.scn (added) * testsuites/smptests/smpatomic03/system.h (added) * testsuites/smptests/smpatomic03/tasks.c (added) * testsuites/smptests/smpatomic04/Makefile.am (added) * testsuites/smptests/smpatomic04/init.c (added) * testsuites/smptests/smpatomic04/smpatomic04.doc (added) * testsuites/smptests/smpatomic04/smpatomic04.scn (added) * testsuites/smptests/smpatomic04/system.h (added) * testsuites/smptests/smpatomic04/tasks.c (added) * testsuites/smptests/smpatomic05/Makefile.am (added) * testsuites/smptests/smpatomic05/init.c (added) * testsuites/smptests/smpatomic05/smpatomic05.doc (added) * testsuites/smptests/smpatomic05/smpatomic05.scn (added) * testsuites/smptests/smpatomic05/system.h (added) * testsuites/smptests/smpatomic05/tasks.c (added) * testsuites/smptests/smpatomic06/Makefile.am (added) * testsuites/smptests/smpatomic06/init.c (added) * testsuites/smptests/smpatomic06/smpatomic06.doc (added) * testsuites/smptests/smpatomic06/smpatomic06.scn (added) * testsuites/smptests/smpatomic06/system.h (added) * testsuites/smptests/smpatomic06/tasks.c (added) * testsuites/smptests/smpatomic07/Makefile.am (added) * testsuites/smptests/smpatomic07/init.c (added) * testsuites/smptests/smpatomic07/smpatomic07.doc (added) * testsuites/smptests/smpatomic07/smpatomic07.scn (added) * testsuites/smptests/smpatomic07/system.h (added) * testsuites/smptests/smpatomic07/tasks.c (added) tests: atomic support for RTEMS. SMP tests for atomic operations. Fri, 25 Jan 2013 15:59:49 GMT WeiY [fb9fa15] * testsuites/sptests/spatomic01/Makefile.am (added) * testsuites/sptests/spatomic01/init.c (added) * testsuites/sptests/spatomic01/spatomic01.doc (added) * testsuites/sptests/spatomic01/spatomic01.scn (added) * testsuites/sptests/spatomic01/system.h (added) * testsuites/sptests/spatomic01/tasks.c (added) * testsuites/sptests/spatomic02/Makefile.am (added) * testsuites/sptests/spatomic02/init.c (added) * testsuites/sptests/spatomic02/spatomic02.doc (added) * testsuites/sptests/spatomic02/spatomic02.scn (added) * testsuites/sptests/spatomic02/system.h (added) * testsuites/sptests/spatomic02/tasks.c (added) * testsuites/sptests/spatomic03/Makefile.am (added) * testsuites/sptests/spatomic03/init.c (added) * testsuites/sptests/spatomic03/spatomic03.doc (added) * testsuites/sptests/spatomic03/spatomic03.scn (added) * testsuites/sptests/spatomic03/system.h (added) * testsuites/sptests/spatomic03/tasks.c (added) * testsuites/sptests/spatomic04/Makefile.am (added) * testsuites/sptests/spatomic04/init.c (added) * testsuites/sptests/spatomic04/spatomic04.doc (added) * testsuites/sptests/spatomic04/spatomic04.scn (added) * testsuites/sptests/spatomic04/system.h (added) * testsuites/sptests/spatomic04/tasks.c (added) * testsuites/sptests/spatomic05/Makefile.am (added) * testsuites/sptests/spatomic05/init.c (added) * testsuites/sptests/spatomic05/spatomic05.doc (added) * testsuites/sptests/spatomic05/spatomic05.scn (added) * testsuites/sptests/spatomic05/system.h (added) * testsuites/sptests/spatomic05/tasks.c (added) * testsuites/sptests/spatomic06/Makefile.am (added) * testsuites/sptests/spatomic06/init.c (added) * testsuites/sptests/spatomic06/spatomic06.doc (added) * testsuites/sptests/spatomic06/spatomic06.scn (added) * testsuites/sptests/spatomic06/system.h (added) * testsuites/sptests/spatomic06/tasks.c (added) * testsuites/sptests/spatomic07/Makefile.am (added) * testsuites/sptests/spatomic07/init.c (added) * testsuites/sptests/spatomic07/spatomic07.doc (added) * testsuites/sptests/spatomic07/spatomic07.scn (added) * testsuites/sptests/spatomic07/system.h (added) * testsuites/sptests/spatomic07/tasks.c (added) tests: atomic support for RTEMS. Uniprocessor tests for atomic ops. Fri, 25 Jan 2013 15:53:52 GMT WeiY [9d23df2] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/preinstall.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) score: atomic support for RTEMS automake and autoconf changes Wed, 30 Jan 2013 16:21:26 GMT Sebastian Huber [80e3743] * testsuites/fstests/fsrdwr/init.c (modified) fstests/fsrdwr: Free allocated memory Wed, 30 Jan 2013 16:03:38 GMT Sebastian Huber [2e0177d8] * testsuites/fstests/mdosfs_support/fs_support.c (modified) fstests: Check resources used by FAT file system Wed, 30 Jan 2013 16:01:07 GMT Sebastian Huber [065441d8] * testsuites/fstests/support/fstest_support.c (modified) fstests: Use global environment and clean up This releases all ... Wed, 30 Jan 2013 16:00:22 GMT Sebastian Huber [334222f0] * testsuites/fstests/support/ramdisk_support.c (modified) fstests: Initialize swapout task Wed, 30 Jan 2013 15:59:49 GMT Sebastian Huber [399afaf] * testsuites/fstests/mdosfs_support/fs_support.c (modified) fstests: Perform a quick format Wed, 30 Jan 2013 15:58:21 GMT Sebastian Huber [524cdbbc] * testsuites/fstests/mdosfs_support/fs_support.c (modified) fstests: Use designated initializers Mon, 28 Jan 2013 09:23:28 GMT Sebastian Huber [b63c8f9] * cpukit/libnetworking/lib/ftpfs.c (modified) * testsuites/libtests/ftp01/ftp01.scn (modified) * testsuites/libtests/ftp01/init.c (modified) ftpfs: Fix SIZE command handling It is invalid to issue a SIZE ... Sun, 27 Jan 2013 12:46:40 GMT Sebastian Huber [33bd2efb] * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) testsuites: Fix prototypes Sun, 27 Jan 2013 12:05:13 GMT Sebastian Huber [565d8da] * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) testsuites: Use rtems_fatal_source_description() Tue, 15 Jan 2013 19:46:56 GMT Alex Ivanov [99d1197] * testsuites/fstests/mimfs_fslink/mimfs_fslink.scn (added) * testsuites/fstests/mimfs_fspatheval/mimfs_fspatheval.scn (added) * testsuites/fstests/mimfs_fspermission/mimfs_fspermission-interupted.scn (added) * testsuites/fstests/mimfs_fsrdwr/mimfs_fsrdwr.scn (added) * testsuites/fstests/mimfs_fssymlink/mimfs_fssymlink.scn (added) * testsuites/fstests/mimfs_fstime/mimfs_fstime.scn (added) fstests: Generating .scn (Screen Shots) #4 Tue, 15 Jan 2013 16:03:55 GMT Alex Ivanov [79060eb6] * testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.scn (added) * testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.scn (added) * testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.scn (added) * testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.scn (added) * testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.scn (added) * testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.scn (added) * testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.scn (added) psxtmtests: Generating .scn (Screen Shots) #8 Mon, 14 Jan 2013 16:12:14 GMT Christopher Kerl [408a16e] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmthread02/Makefile.am (added) * testsuites/psxtmtests/psxtmthread02/init.c (added) * testsuites/psxtmtests/psxtmthread02/psxtmthread02.doc (added) Create POSIX Timing Test psxtmthread02 Minor modifications were made ... Mon, 14 Jan 2013 15:53:36 GMT Alex Ivanov [e214280b] * testsuites/psxtests/psxbarrier01/psxtmbarrier01.scn (added) * testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.scn (added) * testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.scn (added) * testsuites/psxtmtests/psxtmkey01/psxtmkey01.scn (added) * testsuites/psxtmtests/psxtmkey02/psxtmkey02.scn (added) * testsuites/psxtmtests/psxtmmq01/psxtmmq01.scn (added) Generating .scn (Screen Shots) #7 Fri, 11 Jan 2013 20:33:37 GMT Christopher Kerl [72f3b05] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcond08/Makefile.am (added) * testsuites/psxtmtests/psxtmcond08/init.c (added) * testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc (added) * testsuites/psxtmtests/psxtmcond09/Makefile.am (added) * testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc (added) * testsuites/psxtmtests/psxtmcond10/Makefile.am (added) * testsuites/psxtmtests/psxtmcond10/psxtmcond10.doc (added) Create POSIX Timing Test psxtmcond09 Modifications were made to ... Fri, 11 Jan 2013 20:15:24 GMT Christopher Kerl [bcefae2e] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcond03/Makefile.am (added) * testsuites/psxtmtests/psxtmcond03/init.c (added) * testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc (added) Create POSIX Timing Test psxtmcond03 Fri, 11 Jan 2013 20:12:54 GMT Jennifer Averett [86d06a6] * testsuites/psxtmtests/psxtmtests_plan.csv (modified) Added more condition variable timing tests. Wed, 09 Jan 2013 19:27:57 GMT Christopher Kerl [7f97cb3] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcond05/Makefile.am (added) * testsuites/psxtmtests/psxtmcond05/init.c (added) * testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc (added) Create POSIX Timing Test psxtmcond05 Wed, 09 Jan 2013 18:52:50 GMT Christopher Kerl [55ea222] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcond02/Makefile.am (added) * testsuites/psxtmtests/psxtmcond02/init.c (added) * testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc (added) Create POSIX Timing Test psxtmcond02 Wed, 09 Jan 2013 15:24:10 GMT Christopher Kerl [cc2857a] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcond01/Makefile.am (added) * testsuites/psxtmtests/psxtmcond01/init.c (added) * testsuites/psxtmtests/psxtmcond01/psxtmcond01.doc (added) GCI: Create POSIX Timing Test psxtmcond01 Mon, 07 Jan 2013 15:01:45 GMT Sebastian Huber [f2f39b62] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/fatalsrcdesc.c (added) * doc/user/fatal.t (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) sapi: Add rtems_fatal_source_description() Wed, 02 Jan 2013 17:56:35 GMT Sebastian Huber [57f125d] * cpukit/rtems/src/eventtimeout.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical10/spintrcritical10.scn (modified) rtems: Critical fix for events Commit ... Sun, 30 Dec 2012 04:55:11 GMT Cynthia Rempel [3169affa] * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) tmoverhd.doc Hi, Adding test documentation... Wed, 02 Jan 2013 17:37:07 GMT Christopher Kerl [3106d7c] * testsuites/fstests/imfs_fserror/imfs_fserror.scn (added) * testsuites/fstests/imfs_fslink/imfs_fslink.scn (added) * testsuites/fstests/imfs_fspatheval/imfs_fspathenval.scn (added) * testsuites/fstests/imfs_fspermission/imfs_fspermission.scn (added) * testsuites/fstests/imfs_fsrdwr/imfs_fsrdwr.scn (added) * testsuites/fstests/imfs_fstime/imfs_fstime.scn (added) IMFS: Generating .scn (Screen Shots) #2 Sun, 23 Dec 2012 13:13:46 GMT Sebastian Huber [355ca1ad] * testsuites/sptests/spintrcritical16/init.c (modified) sptests/spintrcritical16: Fix NULL pointer access Sat, 22 Dec 2012 16:29:15 GMT Sebastian Huber [fe62f3a] * testsuites/libtests/rbheap01/init.c (modified) libtests/rbheap01: Add test cases Sat, 22 Dec 2012 15:48:45 GMT Sebastian Huber [11c10b8b] * testsuites/sptests/speventsystem01/init.c (modified) sptests/speventsystem01: Add test cases Sat, 22 Dec 2012 15:38:45 GMT Sebastian Huber [aaee3a9] * testsuites/libtests/malloctest/init.c (modified) libtests/malloctest: Add test case Sat, 22 Dec 2012 15:28:26 GMT Sebastian Huber [d8efe3d] * testsuites/libtests/malloctest/init.c (modified) libtests/malloctest: Add test case Tue, 18 Dec 2012 13:44:42 GMT Sebastian Huber [72c6861] * cpukit/libblock/src/bdpart-register.c (modified) * testsuites/fstests/fsbdpart01/init.c (modified) libblock: Use rtems_blkdev_create_partition() Use ... Fri, 21 Dec 2012 11:21:11 GMT Sebastian Huber [3b91605] * cpukit/libfs/src/imfs/imfs_creat.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) IMFS: Fix resource leak in IMFS_allocate_node() Fri, 21 Dec 2012 09:59:04 GMT Sebastian Huber [c5d2760] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/src/resource_snapshot.c (added) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxconfig01/psxconfig01.scn (modified) libcsupport: Add rtems_resource_snapshot_take() Add ... Fri, 21 Dec 2012 09:17:34 GMT Sebastian Huber [fe1dc22] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/src/objectactivecount.c (added) * testsuites/sptests/spobjgetnext/init.c (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.doc (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.scn (modified) score: Add _Objects_Active_count() Fri, 21 Dec 2012 08:50:15 GMT Sebastian Huber [cbd07e4] * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/src/chainnodecount.c (added) * doc/user/chains.t (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spchain/spchain.scn (modified) score: Add rtems_chain_node_count_unprotected() Sun, 16 Dec 2012 20:34:13 GMT Sebastian Huber [c40f36b0] * testsuites/libtests/md501/init.c (modified) * testsuites/libtests/md501/md501.doc (modified) libtests/md501: Use test cases of RFC 2202 Sun, 16 Dec 2012 16:33:57 GMT Sebastian Huber [f95d74a4] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/md501/Makefile.am (added) * testsuites/libtests/md501/init.c (added) * testsuites/libtests/md501/md501.doc (added) * testsuites/libtests/md501/md501.scn (added) libtests/md501: New test Thu, 13 Dec 2012 10:08:03 GMT Sebastian Huber [4b8e01f] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) dosfs: Add sync_device option for msdos_format()
