# # ChangeLog for testsuites in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 16:49:04 Fri, 24 Oct 2014 05:21:51 GMT Sebastian Huber [092b8c5] * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) tests/smptests: Normal use of test extension Thu, 23 Oct 2014 15:15:47 GMT Sebastian Huber [17889b2] * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) tests/smptests: Use barriers in smpfatal0{12} Call the test ... Thu, 23 Oct 2014 07:42:18 GMT Sebastian Huber [3e739ae] * testsuites/support/include/tmacros.h (modified) testsuites: Move include for C++ compatibility Fri, 17 Oct 2014 12:46:13 GMT Sebastian Huber [66c1ef9] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/mdosfs_fstime/Makefile.am (added) Revert "fstests/mdosfs_fstime: Remove test" This reverts commit ... Tue, 14 Oct 2014 10:12:32 GMT Sebastian Huber [43633ae] * testsuites/psxtests/psxglobalcon01/init.cc (modified) * testsuites/psxtests/psxglobalcon02/init.cc (modified) * testsuites/sptests/spglobalcon01/init.cc (modified) testsuites: Avoid clock driver Mon, 13 Oct 2014 16:13:11 GMT Joel Sherrill [945f31b9] * testsuites/samples/nsecs/init.c (modified) nsecs/init.c: Use long to avoid overflow on 16-bit targets Fri, 10 Oct 2014 07:09:19 GMT Sebastian Huber [a38ced2] * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadglobalconstruction.c (added) * cpukit/score/src/threadhandler.c (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxglobalcon01/Makefile.am (added) * testsuites/psxtests/psxglobalcon01/init.cc (added) * testsuites/psxtests/psxglobalcon01/psxglobalcon01.doc (added) * testsuites/psxtests/psxglobalcon01/psxglobalcon01.scn (added) * testsuites/psxtests/psxglobalcon02/Makefile.am (added) * testsuites/psxtests/psxglobalcon02/init.cc (added) * testsuites/psxtests/psxglobalcon02/psxglobalcon02.doc (added) * testsuites/psxtests/psxglobalcon02/psxglobalcon02.scn (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spglobalcon01/Makefile.am (added) * testsuites/sptests/spglobalcon01/init.cc (added) * testsuites/sptests/spglobalcon01/spglobalcon01.doc (added) * testsuites/sptests/spglobalcon01/spglobalcon01.scn (added) * testsuites/sptests/spthreadlife01/init.c (modified) score: Rework global construction Ensure that the global ... Wed, 08 Oct 2014 22:38:12 GMT Joel Sherrill [78a38fa2] * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libcpu/m68k/shared/misc/m68kidle.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/chain.inl (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp06/task1.c (modified) Eliminate use of /*PAGE and clean up formatting Tue, 07 Oct 2014 22:43:35 GMT Joel Sherrill [eb7f306d] * testsuites/samples/base_sp/apptask.c (modified) samples/base_sp: Fix printf() warning Tue, 07 Oct 2014 22:43:18 GMT Joel Sherrill [51a95ff9] * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/samples/unlimited/test3.c (modified) samples/unlimited: Fix printf() warning and clean up Wed, 08 Oct 2014 09:24:36 GMT Sebastian Huber [22cd282] * cpukit/libcsupport/src/__usrenv.c (modified) * testsuites/fstests/fsimfsgeneric01/init.c (modified) IMFS: Avoid NULL pointer access Avoid NULL pointer access in ... Wed, 08 Oct 2014 08:31:36 GMT Sebastian Huber [b9f95225] * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * testsuites/psxtests/psxrwlock01/test.c (modified) posix: Add auto initializaton for rwlock Tue, 07 Oct 2014 14:28:04 GMT Sebastian Huber [7fd5e89] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Partially hide rtems_termios_tty Move interrupt lock to ... Tue, 07 Oct 2014 14:27:51 GMT Sebastian Huber [a830cb8] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Separate flow control from normal handler Tue, 23 Sep 2014 12:20:35 GMT Sebastian Huber [805360b] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/pppd/rtemspppd.h (modified) * testsuites/samples/pppd/netconfig.h (modified) pppd: Fix warnings Fri, 19 Sep 2014 12:18:00 GMT Sebastian Huber [6f1e1b3] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical22/Makefile.am (added) * testsuites/sptests/spintrcritical22/init.c (added) * testsuites/sptests/spintrcritical22/spintrcritical22.doc (added) * testsuites/sptests/spintrcritical22/spintrcritical22.scn (added) sptests/spintrcritical22: New test Wed, 17 Sep 2014 08:28:13 GMT Sebastian Huber [8f0a2c9] * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpload01/smpload01.scn (modified) smptests/smpload01: Report profiling only once Rely on test ... Thu, 04 Sep 2014 13:59:49 GMT Joel Sherrill [8fbe2e6] * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/gba/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (modified) * c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/timer/timer.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf52235/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5329/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mrm332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) * c/src/lib/libbsp/mips/jmr3904/timer/timer.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/or1k/or1ksim/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c (modified) * c/src/lib/libbsp/shared/timerstub.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon3/timer/timer.c (modified) * c/src/lib/libcpu/arm/at91rm9200/timer/timer.c (modified) * c/src/lib/libcpu/arm/lpc22xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c (modified) * c/src/lib/libcpu/arm/pxa255/timer/timer.c (modified) * c/src/lib/libcpu/arm/s3c24xx/timer/timer.c (modified) * c/src/lib/libcpu/bfin/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7750/timer/timer.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/timerdrv.h (deleted) * cpukit/libcsupport/preinstall.am (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/bsp_howto/timer.t (modified) * testsuites/psxtmtests/psxtmbarrier01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier02/init.c (modified) * testsuites/psxtmtests/psxtmbarrier03/init.c (modified) * testsuites/psxtmtests/psxtmbarrier04/init.c (modified) * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond07/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmkey01/init.c (modified) * testsuites/psxtmtests/psxtmkey02/init.c (modified) * testsuites/psxtmtests/psxtmmq01/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmmutex02/init.c (modified) * testsuites/psxtmtests/psxtmmutex03/init.c (modified) * testsuites/psxtmtests/psxtmmutex04/init.c (modified) * testsuites/psxtmtests/psxtmmutex05/init.c (modified) * testsuites/psxtmtests/psxtmmutex06/init.c (modified) * testsuites/psxtmtests/psxtmmutex07/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep01/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock01/init.c (modified) * testsuites/psxtmtests/psxtmrwlock02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock03/init.c (modified) * testsuites/psxtmtests/psxtmrwlock04/init.c (modified) * testsuites/psxtmtests/psxtmrwlock05/init.c (modified) * testsuites/psxtmtests/psxtmrwlock06/init.c (modified) * testsuites/psxtmtests/psxtmrwlock07/init.c (modified) * testsuites/psxtmtests/psxtmsem01/init.c (modified) * testsuites/psxtmtests/psxtmsem02/init.c (modified) * testsuites/psxtmtests/psxtmsem03/init.c (modified) * testsuites/psxtmtests/psxtmsem04/init.c (modified) * testsuites/psxtmtests/psxtmsem05/init.c (modified) * testsuites/psxtmtests/psxtmsleep01/init.c (modified) * testsuites/psxtmtests/psxtmsleep02/init.c (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/psxtmtests/psxtmthread03/init.c (modified) * testsuites/psxtmtests/psxtmthread04/init.c (modified) * testsuites/psxtmtests/psxtmthread05/init.c (modified) * testsuites/psxtmtests/psxtmthread06/init.c (modified) * testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c (modified) * testsuites/rhealstone/rhilatency/ilatency.c (modified) * testsuites/rhealstone/rhmlatency/mlatency.c (modified) * testsuites/rhealstone/rhsemshuffle/semshuffle.c (modified) * testsuites/rhealstone/rhtaskpreempt/taskpreempt.c (modified) * testsuites/rhealstone/rhtaskswitch/taskswitch.c (modified) * testsuites/support/src/tmtests_support.c (modified) Use correct prototype of benchmark_timer_read() This change starts ... Tue, 16 Sep 2014 13:43:15 GMT Sebastian Huber [7f8a978] * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/buffered_io.c (deleted) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.scn (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) sptests/sp07: Minimize thread dispatch latency Do not use sprintf() ... Thu, 11 Sep 2014 15:55:34 GMT Daniel Cederman [6e1206a] * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcache01/smpcache01.doc (modified) * testsuites/smptests/smpcache01/smpcache01.scn (modified) smptests/smpcache01: Remove invalidation of data cache lines from ... Fri, 12 Sep 2014 14:04:40 GMT Sebastian Huber [f9eca790] * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) sptests/spintrcritical_support: Optimize busy loop Fri, 12 Sep 2014 14:04:01 GMT Sebastian Huber [73b5d8bf] * testsuites/sptests/spintrcritical10/init.c (modified) sptests/spintrcritical10: Avoid undefined memory Thu, 11 Sep 2014 05:33:16 GMT Sebastian Huber [f3508c44] * testsuites/tmtests/tmcontext01/init.c (modified) tmtests/tmcontext01: Improve cache dirty function Increment by ... Wed, 10 Sep 2014 12:46:03 GMT Sebastian Huber [e09f8b08] * testsuites/sptests/spfatal07/testcase.h (modified) sptests/spfatal07: Fix end of test message Tue, 09 Sep 2014 15:13:51 GMT Sebastian Huber [4984ee4] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp39/Makefile.am (deleted) * testsuites/sptests/spintrcritical21/Makefile.am (added) * testsuites/sptests/spintrcritical21/init.c (moved) * testsuites/sptests/spintrcritical21/spintrcritical21.doc (moved) * testsuites/sptests/spintrcritical21/spintrcritical21.scn (moved) * testsuites/sptests/spintrcritical21/system.h (moved) sptests/sp39: Convert to sptests/spintrcritical21 Use interrupt ... Tue, 09 Sep 2014 14:49:20 GMT Sebastian Huber [b5f9ad2] * testsuites/psxtests/psxonce01/system.h (modified) psxtests/psxonce01: Use test extension Mon, 08 Sep 2014 13:18:07 GMT Sebastian Huber [8028089] * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical11/init.c (modified) * testsuites/sptests/spintrcritical13/init.c (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.h (modified) tests: Rework interrupt critical tests This avoids test durations ... Mon, 08 Sep 2014 08:19:42 GMT Sebastian Huber [6821a629] * c/src/aclocal/prog-cxx.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) Add -std=gnu++11 to CXXFLAGS if SMP is enabled This is necessary to ... Fri, 05 Sep 2014 11:33:57 GMT Sebastian Huber [8d30713d] * testsuites/tmtests/tmcontext01/init.c (modified) tmtests/tmcontext01: Improve cache dirty function Fri, 05 Sep 2014 07:27:41 GMT Sebastian Huber [07b4594] * testsuites/sptests/spcontext01/init.c (modified) sptests/spcontext01: Fix warning Fri, 05 Sep 2014 06:24:52 GMT Sebastian Huber [b2356837] * testsuites/tmtests/tmcontext01/plot.py (modified) tmtests/tmcontext01: Plot a legend Wed, 03 Sep 2014 15:21:21 GMT Joel Sherrill [a864016f] * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/test.c (modified) spcpuset01: Use %zd for size_t to eliminate warning Wed, 03 Sep 2014 15:16:43 GMT Joel Sherrill [de549c3] * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/psxtmtests/psxtmthread04/init.c (modified) * testsuites/psxtmtests/psxtmthread05/init.c (modified) * testsuites/psxtmtests/psxtmthread06/init.c (modified) Misc psxtmtests: Use uint32_t not long for end_time to match printf() ... Wed, 03 Sep 2014 15:07:28 GMT Joel Sherrill [9aa6ddf] * testsuites/sptests/spfreechain01/init.c (modified) spfreechain01/init.c: Use %zd for size_t to eliminate warning Tue, 02 Sep 2014 17:30:25 GMT Joel Sherrill [e1462e1] * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) sp19: Eliminate warnings Tue, 02 Sep 2014 23:00:44 GMT Joel Sherrill [be4992b1] * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c (deleted) * testsuites/sptests/spintr_err01/init.c (modified) raspberrypi: Use shared bspreset.c Mon, 01 Sep 2014 15:16:53 GMT Sebastian Huber [8ae6f26] * testsuites/samples/iostream/init.cc (modified) * testsuites/samples/iostream/iostream.scn (modified) samples/iostream: Produce proper begin/end message Mon, 01 Sep 2014 14:12:42 GMT Sebastian Huber [5689d72] * testsuites/smptests/smplock01/smplock01.scn (modified) smptests/smplock01: Update screen file Mon, 01 Sep 2014 11:28:30 GMT Sebastian Huber [5cb5342] * testsuites/libtests/capture01/init.c (modified) libtests/capture01: Fix test name Mon, 01 Sep 2014 08:08:12 GMT Sebastian Huber [979d95e] * testsuites/libtests/capture01/init.c (modified) libtests/capture01: Force error if SMP enabled This prevents ... Mon, 01 Sep 2014 09:01:04 GMT Sebastian Huber [4030ccc] * testsuites/libtests/newlib01/newlib01.doc (modified) * testsuites/smptests/smpatomic01/smpatomic01.doc (modified) * testsuites/smptests/smpipi01/smpipi01.doc (modified) * testsuites/smptests/smpmigration01/smpmigration01.doc (modified) * testsuites/smptests/smpmigration02/smpmigration02.doc (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.doc (modified) * testsuites/smptests/smpscheduler01/smpscheduler01.doc (modified) * testsuites/smptests/smpscheduler02/smpscheduler02.doc (modified) * testsuites/smptests/smpthreadlife01/smpthreadlife01.doc (modified) * testsuites/smptests/smpunsupported01/smpunsupported01.doc (modified) * testsuites/sptests/spmrsp01/spmrsp01.doc (modified) * testsuites/sptests/spscheduler01/spscheduler01.doc (modified) tests: Add documentation Mon, 01 Sep 2014 06:45:23 GMT Sebastian Huber [c147a139] * testsuites/smptests/smpfatal08/init.c (modified) smptests/smpfatal08: Fix link error Fri, 22 Aug 2014 15:09:36 GMT Sebastian Huber [96ec8ee8] * cpukit/rtems/include/rtems/rtems/clock.h (modified) * doc/user/clock.t (modified) * testsuites/sptests/sp37/init.c (modified) * testsuites/sptests/sp37/sp37.doc (modified) * testsuites/sptests/sp37/system.h (modified) rtems: Add more clock tick functions Add rtems_clock_tick_later(), ... Fri, 22 Aug 2014 20:20:16 GMT Hesham ALMatary [23b14f87] * testsuites/sptests/spcache01/init.c (modified) sptests/spcache01: Make inline assembly conditional to account for ... Thu, 03 Jul 2014 14:42:24 GMT Daniel Cederman [9a9ab85] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpcache01/Makefile.am (added) * testsuites/smptests/smpcache01/init.c (added) * testsuites/smptests/smpcache01/smpcache01.doc (added) * testsuites/smptests/smpcache01/smpcache01.scn (added) smptests/smpcache01: Test the SMP cache manager Invokes SMP cache ... Tue, 19 Aug 2014 15:43:36 GMT Sebastian Huber [bba3507] * cpukit/score/src/coremutex.c (modified) * testsuites/sptests/sp51/init.c (modified) * testsuites/sptests/sp51/sp51.doc (modified) score: PR2179: Fix initially locked PI mutex Thu, 07 Aug 2014 17:41:25 GMT Sebastian Huber [0b9fe3ec] * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) sptests/sprbtree01: Add random ops test case Wed, 23 Jul 2014 11:03:54 GMT Sebastian Huber [993f5ac] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify insert and extract Simplify _RBTree_Insert() and ... Wed, 23 Jul 2014 11:19:09 GMT Sebastian Huber [4752550f] * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify _RBTree_Rotate() Add and use _RBTree_Direction(). Tue, 05 Aug 2014 12:07:07 GMT Sebastian Huber [d472d21] * testsuites/sptests/sprbtree01/init.c (modified) sptests/sprbtree01: Check tree layout Tue, 05 Aug 2014 11:52:45 GMT Sebastian Huber [888edf6] * testsuites/sptests/sprbtree01/init.c (modified) sptests/sprbtree01: Reduce stack usage Sun, 03 Aug 2014 11:02:58 GMT Sebastian Huber [60fe374] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/sapi/include/rtems/rbheap.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/threadq.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Add and use RBTree_Compare_result Sat, 02 Aug 2014 14:22:31 GMT Sebastian Huber [40dcafa] * cpukit/libblock/src/bdbuf.c (modified) * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/sapi/include/rtems/rbheap.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/resourceiterate.c (modified) * cpukit/score/src/schedulerchangeroot.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqfirst.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) Add and use RTEMS_CONTAINER_OF() Tue, 22 Jul 2014 20:49:09 GMT Sebastian Huber [b767683a] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) rbtree: Rename find header in find control Simplify ... Tue, 22 Jul 2014 17:42:54 GMT Sebastian Huber [6e93c836] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify off-tree handling Only use the parent pointer, ... Tue, 22 Jul 2014 12:50:07 GMT Sebastian Huber [639117f] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) rbtree: Update maximum node in LIFO order The test sptests/sp35 ... Wed, 23 Jul 2014 20:35:35 GMT Joel Sherrill [875fff0a] * cpukit/posix/src/adjtime.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretodadjust.c (added) * testsuites/psxtests/psxtime/psxtime.scn (modified) * testsuites/psxtests/psxtime/test.c (modified) Add _TOD_Adjust to SCORE TOD Handler. This lays the proper ... Mon, 21 Jul 2014 16:29:00 GMT Sebastian Huber [8abbbdde] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtreeextract.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Do not set node off-tree in extract Mon, 21 Jul 2014 16:16:47 GMT Sebastian Huber [d7a94693] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Remove superfluous NULL pointer checks Sat, 12 Jul 2014 19:22:22 GMT Sebastian Huber [64939bc] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Reduce RBTree_Control size Remove compare function and is ... Mon, 07 Jul 2014 22:42:28 GMT Joel Sherrill [9ba76ed8] * testsuites/sptests/sp59/init.c (modified) * testsuites/sptests/sp59/sp59.scn (modified) sp59: Fix typos Thu, 10 Jul 2014 19:20:39 GMT Joel Sherrill [b6343c6] * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm31/Makefile.am (added) * testsuites/tmtests/tm31/tm31.doc (added) * testsuites/tmtests/tm32/Makefile.am (added) * testsuites/tmtests/tm32/tm32.doc (added) * testsuites/tmtests/tm33/Makefile.am (added) * testsuites/tmtests/tm33/tm33.doc (added) * testsuites/tmtests/tm34/Makefile.am (added) * testsuites/tmtests/tm34/tm34.doc (added) * testsuites/tmtests/tm35/Makefile.am (added) * testsuites/tmtests/tm35/tm35.doc (added) * testsuites/tmtests/tm36/Makefile.am (added) * testsuites/tmtests/tm36/tm36.doc (added) * testsuites/tmtests/tmtests_plan.csv (modified) Enhance Semaphore Blocking and Readying Time Test Cases tm02 and ... Mon, 14 Jul 2014 18:12:31 GMT Jennifer Averett [648c86c] * testsuites/libtests/capture01/init.c (modified) capture01: Add include of assert.h. Thu, 10 Jul 2014 16:55:04 GMT Jennifer Averett [247118bf] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedsem01/Makefile.am (added) * testsuites/smptests/smpschedsem01/init.c (added) * testsuites/smptests/smpschedsem01/smpschedsem01.doc (added) * testsuites/smptests/smpschedsem01/smpschedsem01.scn (added) smpschedsem01: new test. This test verifies priority is inherited ... Thu, 10 Jul 2014 16:45:58 GMT Jennifer Averett [7eb3fd47] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity05/Makefile.am (added) * testsuites/smptests/smpschedaffinity05/init.c (added) * testsuites/smptests/smpschedaffinity05/smpschedaffinity05.doc (added) * testsuites/smptests/smpschedaffinity05/smpschedaffinity05.scn (added) smpschedaffinity05: Add test for worst case migration for affintiy ... Thu, 10 Jul 2014 16:36:40 GMT Jennifer Averett [61d26f93] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity04/Makefile.am (added) * testsuites/smptests/smpschedaffinity04/init.c (added) * testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc (added) * testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn (added) smpschedaffinity04: New test. This test walks a secondary high ... Thu, 10 Jul 2014 16:18:02 GMT Jennifer Averett [28d66749] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity03/Makefile.am (added) * testsuites/smptests/smpschedaffinity03/init.c (added) * testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc (added) * testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn (added) smpschedaffinity03: New test. This task walks the affinity of self ... Thu, 10 Jul 2014 15:19:06 GMT Jennifer Averett [09293069] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity02/Makefile.am (added) * testsuites/smptests/smpschedaffinity02/init.c (added) * testsuites/smptests/smpschedaffinity02/smpschedaffinity02.doc (added) * testsuites/smptests/smpschedaffinity02/smpschedaffinity02.scn (added) smpschedaffinity02: New test. This test checks setting the affinity ... Thu, 22 May 2014 14:00:14 GMT Jennifer Averett [d88b0e7f] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity01/Makefile.am (added) * testsuites/smptests/smpschedaffinity01/init.c (added) * testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc (added) * testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn (added) smpschedaffinity01: New test. This test verifies that affinity is ... Wed, 23 Apr 2014 20:08:26 GMT Jennifer Averett [82d137ae] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/capture01/Makefile.am (added) * testsuites/libtests/capture01/capture01.doc (added) * testsuites/libtests/capture01/capture01.scn (added) * testsuites/libtests/capture01/init.c (added) * testsuites/libtests/capture01/system.h (added) * testsuites/libtests/capture01/test1.c (added) * testsuites/libtests/configure.ac (modified) capture01: New non-interactive test for capture engine. Thu, 10 Jul 2014 12:27:42 GMT Sebastian Huber [27783f6] * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) score: Fix scheduler helping implementation Do not extract the idle ... Wed, 09 Jul 2014 13:44:13 GMT Sebastian Huber [93726e5] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (added) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) termios: Add rtems_termios_set_best_baud() Wed, 09 Jul 2014 09:52:56 GMT Sebastian Huber [a0fb29f] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) termios: PR1279: Use first open status Wed, 09 Jul 2014 09:15:53 GMT Sebastian Huber [32fc6a3] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) termios: PR1279: Use set attributes status Fri, 27 Jun 2014 11:10:15 GMT Sebastian Huber [ef8c00bc] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) termios: PR2153: New low-level device API Add a new low-level ... Tue, 24 Jun 2014 08:00:06 GMT Sebastian Huber [9f228bea] * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smptests/smpmrsp01: Add and update test cases Wed, 11 Jun 2014 12:31:03 GMT Sebastian Huber [8568341] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Need for help indicator for scheduler ops Return a thread in ... Tue, 08 Jul 2014 12:25:55 GMT Sebastian Huber [08d9760] * cpukit/score/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfupdate.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityupdate.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Rename *_Node_get() to *_Thread_get_node() This emphasizes ... Tue, 01 Jul 2014 10:02:24 GMT Sebastian Huber [8852594] * testsuites/sptests/spcontext01/init.c (modified) sptests/spcontext01: Avoid NULL pointer access Mon, 30 Jun 2014 10:30:12 GMT Sebastian Huber [0b4ec4d] * testsuites/smptests/smpfatal08/init.c (modified) smptests/smpfatal08: Support RTEMS_PARAVIRT Tue, 24 Jun 2014 07:53:11 GMT Sebastian Huber [b42e148] * testsuites/smptests/smpmigration02/init.c (modified) smptests/smpmigration02: PR2183: Add test case Wed, 18 Jun 2014 13:16:02 GMT Sebastian Huber [a92989a] * cpukit/score/src/threadrestart.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpthreadlife01/smpthreadlife01.doc (modified) score: Fix thread deletion on SMP Close the thread object in ... Wed, 11 Jun 2014 09:03:25 GMT Sebastian Huber [2d36931] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) score: Collect scheduler related fields in TCB Add ... Wed, 18 Jun 2014 08:54:04 GMT Sebastian Huber [bd56356b] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpwakeafter01/Makefile.am (added) * testsuites/smptests/smpwakeafter01/init.c (added) * testsuites/smptests/smpwakeafter01/smpwakeafter01.doc (added) * testsuites/smptests/smpwakeafter01/smpwakeafter01.scn (added) smptests/smpwakeafter01: New test Fri, 13 Jun 2014 14:06:20 GMT Sebastian Huber [11947299] * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) smptests: Avoid use of uninitialized data Wed, 11 Jun 2014 14:34:51 GMT Sebastian Huber [4962d24d] * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler03/smpscheduler03.scn (modified) smptests/smpscheduler03: Test all SMP schedulers Wed, 11 Jun 2014 12:37:03 GMT Sebastian Huber [647859e] * testsuites/samples/pppd/system.h (modified) samples/pppd: Fix extra drivers initializer Tue, 10 Jun 2014 09:42:19 GMT Sebastian Huber [2a2a1695] * testsuites/smptests/smpfatal03/init.c (modified) smptest/smpfatal03: Update due to API changes Tue, 03 Jun 2014 10:00:53 GMT Sebastian Huber [f6fc6359] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spsem03/Makefile.am (added) * testsuites/sptests/spsem03/init.c (added) * testsuites/sptests/spsem03/spsem03.doc (added) * testsuites/sptests/spsem03/spsem03.scn (added) sptests/spsem03: New test Tue, 03 Jun 2014 08:24:55 GMT Sebastian Huber [1d799ad] * testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c (modified) * testsuites/rhealstone/rhilatency/ilatency.c (modified) * testsuites/rhealstone/rhmlatency/mlatency.c (modified) * testsuites/rhealstone/rhsemshuffle/semshuffle.c (modified) * testsuites/rhealstone/rhtaskpreempt/taskpreempt.c (modified) * testsuites/rhealstone/rhtaskswitch/taskswitch.c (modified) rhealstone: Produce proper begin/end messages Mon, 02 Jun 2014 14:15:15 GMT Christian Mauderer [5abe5a8] * testsuites/smptests/smpthreadlife01/init.c (modified) smptests/smpthreadlife01: Fix for debug enabled Mon, 02 Jun 2014 14:15:14 GMT Christian Mauderer [1ee0d5f] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Fix scheduler ids Mon, 26 May 2014 14:02:58 GMT Sebastian Huber [9553e7a6] * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * doc/user/sem.t (modified) * testsuites/smptests/smpmrsp01/init.c (modified) score: Use Resource Handler for MrsP semaphores This enables proper ... Fri, 23 May 2014 08:00:33 GMT Sebastian Huber [3e201139] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/resource.h (added) * cpukit/score/include/rtems/score/resourceimpl.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/resourceiterate.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spresource01/Makefile.am (added) * testsuites/sptests/spresource01/init.c (added) * testsuites/sptests/spresource01/spresource01.doc (added) * testsuites/sptests/spresource01/spresource01.scn (added) score: Add Resource Handler A resource is something that has at ... Wed, 28 May 2014 16:11:51 GMT Sebastian Huber [25f5730f] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * doc/user/smp.t (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: _Scheduler_Set_affinity() Do not change the scheduler with ... Mon, 19 May 2014 13:07:22 GMT Chris Johns [431bb85d] * testsuites/automake/test-subdirs.am (modified) * testsuites/testdata/require-tick-isr.tcfg (added) * tools/build/rtems-test-check (modified) rtems-test-check: Ignore tests which require real ISR based clock ... Wed, 21 May 2014 08:33:43 GMT Sebastian Huber [8fcafdd5] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/attrimpl.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (added) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/mrsp.h (added) * cpukit/score/include/rtems/score/mrspimpl.h (added) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/preinstall.am (modified) * doc/user/Makefile.am (modified) * doc/user/conf.t (modified) * doc/user/sem.t (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpmrsp01/Makefile.am (added) * testsuites/smptests/smpmrsp01/init.c (added) * testsuites/smptests/smpmrsp01/smpmrsp01.doc (added) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spmrsp01/Makefile.am (added) * testsuites/sptests/spmrsp01/init.c (added) * testsuites/sptests/spmrsp01/spmrsp01.doc (added) * testsuites/sptests/spmrsp01/spmrsp01.scn (added) score: Multiprocessor Resource Sharing Protocol Add basic support ... Fri, 23 May 2014 13:32:32 GMT Sebastian Huber [d134adeb] * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal07/Makefile.am (deleted) * testsuites/smptests/smpfatal07/init.c (deleted) * testsuites/smptests/smpfatal07/smpfatal07.doc (deleted) * testsuites/smptests/smpfatal07/smpfatal07.scn (deleted) score: Fix race condition in SMP startup Do not use the ... Thu, 22 May 2014 07:31:13 GMT Sebastian Huber [4edf348c] * cpukit/score/src/coremutex.c (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) score: PR2179: Fix initially locked PCP mutexes Elevate the ... Thu, 22 May 2014 09:56:50 GMT Chris Johns [3cbedb1] * testsuites/samples/pppd/init.c (modified) testsuite: Add a user keypress to start pppd. Allow the test to run ...
