Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/testsuites/tmtests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @c610850e   12/04/07 22:18:39 Joel Sherrill 2007-12-04 Joel Sherrill <joel.sherrill@…> * … 4.104.114.95
(edit) @dc172333   05/11/07 19:44:44 Joel Sherrill 2007-05-11 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @5343588   02/06/07 19:14:37 Joel Sherrill 2007-02-06 Joel Sherrill <joel@…> * tm09/task1.c, … 4.104.114.84.95
(edit) @fcb0cd46   12/02/06 06:06:55 Ralf Corsepius 2006-12-02 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @ba2c04f   10/17/06 07:38:02 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @9c5ea11   07/11/06 05:09:12 Ralf Corsepius Eliminate scndir, docdir. Use rtems_testsdir instead. 4.104.114.84.95
(edit) @1fe16f56   07/11/06 05:05:11 Ralf Corsepius 2006-07-11 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1fd1595   11/22/05 15:30:31 Ralf Corsepius 2005-11-22 Ralf Corsepius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @6f2593f   11/13/05 06:52:39 Ralf Corsepius Fix my email address 4.104.114.84.95
(edit) @a6b588d6   11/13/05 06:46:05 Ralf Corsepius Convert to using *_PROGRAMS. 4.104.114.84.95
(edit) @3290efc   11/13/05 06:45:40 Ralf Corsepius 2005-11-13 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @dc35ca43   11/11/05 15:10:59 Ralf Corsepius Fix typos. 4.104.114.84.95
(edit) @ce4669a   11/11/05 14:40:44 Ralf Corsepius * tm01/Makefile.am: Rework. * tm02/Makefile.am: Rework. * … 4.104.114.84.95
(edit) @3bb5d94   11/11/05 14:33:33 Ralf Corsepius Rework. 4.104.114.84.95
(edit) @4024e578   11/11/05 10:26:50 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @7e38877   11/11/05 09:03:24 Ralf Corsepius Eliminate TEST. 4.104.114.84.95
(edit) @95ec9ee5   11/11/05 08:29:12 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @acdc144   11/11/05 08:25:58 Ralf Corsepius Expand tmtests.am. 4.104.114.84.95
(edit) @92c3342   11/11/05 08:25:09 Ralf Corsepius 2005-11-11 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @cb281880   11/10/05 22:21:20 Ralf Corsepius Eliminate DOCTYPES. 4.104.114.84.95
(edit) @61994ea4   11/10/05 14:29:01 Ralf Corsepius Remove redundnant AM_CPPFLAGS 4.104.114.84.95
(edit) @5475b13   11/09/05 12:45:10 Ralf Corsepius * tm01/Makefile.am: AM_CPPFLAGS += -I..../support/include. * … 4.104.114.84.95
(edit) @d65005e   11/09/05 12:44:35 Ralf Corsepius AM_CPPFLAGS += -I..../support/include. 4.104.114.84.95
(edit) @a965dc14   11/09/05 09:26:41 Ralf Corsepius 2005-11-09 Ralf Corsepius <ralf.corsepius@…> * tmtests.am: … 4.104.114.84.95
(edit) @e9f8b7f   11/08/05 14:20:02 Ralf Corsepius changes 4.104.114.84.95
(edit) @c9e3d13   11/08/05 14:19:40 Ralf Corsepius Add ../include/systime.h 4.104.114.84.95
(edit) @75df8e2a   11/08/05 14:17:00 Ralf Corsepius Remove noinst_HEADERS 4.104.114.84.95
(edit) @1675b79   11/07/05 12:42:49 Ralf Corsepius 2005-11-07 Ralf Corsepius <ralf.corsepius@…> * tmtests.am: … 4.104.114.84.95
(edit) @98e92f6f   11/07/05 09:59:07 Ralf Corsepius Cleanup 4.104.114.84.95
(edit) @39767d0   11/07/05 09:43:59 Ralf Corsepius Remove SRC, PRINT_SRC. 4.104.114.84.95
(edit) @190c7e0   11/07/05 09:43:33 Ralf Corsepius * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, … 4.104.114.84.95
(edit) @d66557f   11/07/05 09:09:26 Ralf Corsepius Switch back to include compile.am instead of amcompile.am 4.104.114.84.95
(edit) @c32fb8f   11/07/05 08:43:52 Ralf Corsepius 2005-11-07 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @784853b   11/07/05 08:37:44 Ralf Corsepius Add $(PGM): ${ARCH}/$(dirstamp). 4.104.114.84.95
(edit) @91de2549   11/07/05 08:37:18 Ralf Corsepius Partial conversion to automake. 4.104.114.84.95
(edit) @4089a6f   11/07/05 08:30:08 Ralf Corsepius 2005-11-07 Ralf Corsepius <ralf.corsepius@…> * tmtests.am: … 4.104.114.84.95
(edit) @3fcabb1   12/30/04 12:24:42 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @3e46c1cf   09/24/04 06:32:10 Ralf Corsepius Fix typo in previous change. 4.104.114.84.95
(edit) @97891e5e   09/24/04 05:54:59 Ralf Corsepius 2004-09-24 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @b40e9cc   04/23/04 04:51:16 Ralf Corsepius 2004-04-23 Ralf Corsepius <ralf_corsepius@…> PR 610/bsps * … 4.104.114.84.95
(edit) @c6fe4b6   04/21/04 20:25:10 Joel Sherrill 2004-04-21 Joel Sherrill <joel@…> PR 611/bsps * … 4.104.114.84.95
(edit) @8f71a36   04/20/04 07:09:31 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @3239698   04/15/04 13:26:21 Ralf Corsepius Remove stray white spaces. 4.104.114.84.95
(edit) @0eef698f   04/01/04 15:16:36 Ralf Corsepius * tm01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. … 4.104.114.84.95
(edit) @e0f75b1   03/30/04 19:17:34 Joel Sherrill 2004-03-30 David Querbach <querbach@…> PR 597/tests * … 4.104.114.84.95
(edit) @0720ff4   03/28/04 07:20:11 Ralf Corsepius 2004-03-28 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @c9160531   03/26/04 05:09:01 Ralf Corsepius 2004-03-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @7c48a2e8   03/25/04 06:05:21 Ralf Corsepius 2004-03-25 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @54a43fe4   02/26/04 16:50:21 Joel Sherrill 2004-02-26 Joel Sherrill <joel@…> PR 583/tests * … 4.104.114.84.95
(edit) @987f0ea   01/14/04 07:50:09 Ralf Corsepius 2004-01-14 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @f1a4e10   12/18/03 09:49:59 Ralf Corsepius 2003-12-18 Ralf Corsepius <corsepiu@…> * tmtests.am: … 4.104.114.84.95
(edit) @b4a45137   12/17/03 04:19:15 Ralf Corsepius 2003-12-17 Ralf Corsepius <corsepiu@…> * tmtests.am: … 4.104.114.84.95
(edit) @810720b6   12/12/03 03:28:02 Ralf Corsepius 2003-12-12 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @eaab53e8   12/01/03 21:35:53 Ralf Corsepius 2003-12-01 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @5f52d1f   11/10/03 21:57:23 Ralf Corsepius 2003-11-10 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c6328bee   10/22/03 10:05:17 Ralf Corsepius 2003-10-22 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @5445ee60   10/02/03 03:44:52 Ralf Corsepius 2003-10-02 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @95a81ab   09/04/03 18:53:55 Joel Sherrill 2003-09-04 Joel Sherrill <joel@…> * include/timesys.h, … 4.104.114.84.95
(edit) @7862f888   08/18/03 05:50:27 Ralf Corsepius 2003-08-18 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @61d9371   08/17/03 12:59:28 Ralf Corsepius Fix broken ChangeLog? entries. 4.104.114.84.95
(edit) @20668c7   08/16/03 16:28:00 Ralf Corsepius 2003-08-16 Ralf Corsepius <corsepiu@…> Makefile.am: … 4.104.114.84.95
(edit) @7dcc3fe   08/11/03 14:20:43 Ralf Corsepius 2003-08-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c98849ef   05/27/03 09:40:33 Ralf Corsepius 2003-05-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @78bea14   05/27/03 07:18:07 Ralf Corsepius 2003-05-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @3c55718   03/11/03 09:06:13 Ralf Corsepius Merger from rtems-4-6-branch. 4.104.114.84.95
(edit) @ccd81b60   02/11/03 11:47:49 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9b5c258   02/11/03 11:11:33 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8730f45   10/21/02 12:19:27 Ralf Corsepius 2002-10-21 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @dfdf09ae   08/11/02 04:53:39 Ralf Corsepius 2002-08-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b454bc9   08/02/02 00:52:37 Joel Sherrill 2002-08-01 Joel Sherrill <joel@…> * Per PR47 add support … 4.104.114.84.95
(edit) @cb9b2bfc   04/16/02 13:53:23 Joel Sherrill 2002-04-14 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @f66be68   03/28/02 00:44:39 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ed07762   11/08/01 13:42:46 Joel Sherrill 2001-11-08 Jiri Gaisler <jiri@…> This fix is response to … 4.104.114.84.95
(edit) @d7aecdc   10/12/01 18:47:00 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @df25c998   10/11/01 19:36:23 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @366867bf   09/24/01 18:28:48 Joel Sherrill 2001-09-22 Ralf Corsepius <corsepiu@…> * tmtests.am: … 4.104.114.84.95
(edit) @5dfa8c1   09/19/01 17:22:19 Joel Sherrill 2001-09-19 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @95083c0   05/10/01 13:38:37 Joel Sherrill 2001-05-10 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @d481f9a   01/26/01 21:56:25 Joel Sherrill 2001-01-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @feead226   11/09/00 16:43:05 Joel Sherrill 2000-11-09 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a314d3b4   11/02/00 15:49:06 Joel Sherrill 2000-11-02 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @dd943f6   10/27/00 13:29:35 Joel Sherrill 2000-10-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d6cd8bb   09/05/00 16:05:24 Joel Sherrill 2000-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e94ad1fe   08/10/00 13:24:00 Joel Sherrill Adding ChangeLogs?. 4.104.114.84.95
(edit) @ca7858bb   07/26/00 19:28:11 Joel Sherrill Port of RTEMS to the Texas Instruments C3x/C4x DSP families including … 4.104.114.84.95
(edit) @b8a30d07   07/13/00 15:05:38 Joel Sherrill Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8fbdf07   01/31/00 15:22:23 Joel Sherrill Patch rtems-rc-20000118-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @89703c3   01/10/00 18:16:22 Joel Sherrill Patch from Jay Kulpinski <jskulpin@…> to make sure … 4.104.114.84.95
(edit) @fc20c53   01/05/00 22:09:36 Joel Sherrill Increased stack space. 4.104.114.84.95
(edit) @db941670   01/03/00 14:14:24 Joel Sherrill Added define to trip items that are private to tm27 in bsp.h. 4.104.114.84.95
(edit) @3ad7602e   12/20/99 15:21:31 Joel Sherrill Modifications to avoid having the size of the Buffer_addresses array … 4.104.114.84.95
(edit) @1d9a2fc   11/29/99 15:45:11 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @23e3f642   11/23/99 14:10:05 Joel Sherrill Missed in previous automake conversion patches from Ralf Corsepius … 4.104.114.84.95
(edit) @6e9ad6c   11/23/99 13:32:07 Joel Sherrill Patch rtems-rc-19991117-12.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @f811c8e   11/18/99 17:05:44 Joel Sherrill Removed IT_COUNT since it was not used. 4.104.114.84.95
(edit) @b7852c2   11/18/99 13:58:02 Joel Sherrill Patch rtems-rc-19991105-3.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @ca7d922   11/16/99 21:32:09 Joel Sherrill Fixed typo. 4.104.114.84.95
