# # ChangeLog for testsuites/testdata in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 22:43:47 Mon, 03 Oct 2016 16:03:36 GMT Joel Sherrill [8cf2f8b] * testsuites/testdata/dltests-broken-on-this-bsp.tcfg (modified) testsuites/testdata/dltests-broken-on-this-bsp.tcfg: Add new dl tests ... Tue, 31 Mar 2015 22:45:06 GMT Joel Sherrill [7824d15] * testsuites/testdata/disable-intrcritical-tests.tcfg (added) disable-intrcritical-tests.tcfg: New file This file contains the ... Thu, 19 Mar 2015 17:29:17 GMT Joel Sherrill [f061f2f] * testsuites/testdata/disable-jffs2-tests.tcfg (added) * testsuites/testdata/disable-mrfs-tests.tcfg (added) testsuites/testdata: Add sets to disable all jffs2 and mrfs tests Thu, 05 Mar 2015 16:11:12 GMT Joel Sherrill [ee113c2] * testsuites/testdata/dltests-broken-on-this-bsp.tcfg (added) dltests-broken-on-this-bsp.tcfg: New file used for dl* tests work around Mon, 19 May 2014 13:07:22 GMT Chris Johns [431bb85d] * testsuites/automake/test-subdirs.am (modified) * testsuites/testdata/require-tick-isr.tcfg (added) * tools/build/rtems-test-check (modified) rtems-test-check: Ignore tests which require real ISR based clock ...
