@3c55718
03/11/03 09:06:13 |
Ralf Corsepius |
Merger from rtems-4-6-branch.
4.104.114.84.95
@ccd81b60
02/11/03 11:47:49 |
Ralf Corsepius |
2003-02-11 Ralf Corsepius <corsepiu@…>
* configure.ac: …
4.104.114.84.95
@9b5c258
02/11/03 11:11:33 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@8730f45
10/21/02 12:19:27 |
Ralf Corsepius |
2002-10-21 Ralf Corsepius <corsepiu@…>
* .cvsignore: …
4.104.114.84.95
@304cdca
08/21/02 10:04:45 |
Ralf Corsepius |
2002-08-21 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@cd9396e
08/02/02 00:51:52 |
Joel Sherrill |
2002-08-01 Joel Sherrill <joel@…>
* Per PR47 add support …
4.104.114.84.95
@cb626ac8
03/28/02 00:44:31 |
Joel Sherrill |
2002-03-27 Ralf Corsepius <corsepiu@…>
* configure.ac: …
4.104.114.84.95
@f96cb0b
11/07/01 23:08:40 |
Joel Sherrill |
2001-11-07 Joel Sherrill <joel@…>
Tracked as PR72 but …
4.104.114.84.95
@2444583
11/07/01 23:08:39 |
Joel Sherrill |
4.104.114.84.95
@d7aecdc
10/12/01 18:47:00 |
Joel Sherrill |
2001-10-11 Ralf Corsepius <corsepiu@…>
* .cvsignore: …
4.104.114.84.95
@df25c998
10/11/01 19:36:23 |
Joel Sherrill |
* .cvsignore: …
4.104.114.84.95
@413043b7
08/16/01 19:42:02 |
Joel Sherrill |
2001-08-16 Joel Sherrill <joel@…>
* include/tmacros.h: …
4.104.114.84.95
@95083c0
05/10/01 13:38:37 |
Joel Sherrill |
2001-05-10 Ralf Corsepius <corsepiu@…>
* configure.in: …
4.104.114.84.95
@37222c7e
01/26/01 21:57:44 |
Joel Sherrill |
2001-01-26 Ralf Corsepius <corsepiu@…>
* configure.in: …
4.104.114.84.95
@feead226
11/09/00 16:43:05 |
Joel Sherrill |
2000-11-09 Ralf Corsepius <corsepiu@…>
* Makefile.am: …
4.104.114.84.95
@be59f36
11/02/00 22:48:52 |
Joel Sherrill |
2000-11-02 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@a314d3b4
11/02/00 15:49:06 |
Joel Sherrill |
* Makefile.am: …
4.104.114.84.95
@ae1cce4e
10/27/00 13:32:58 |
Joel Sherrill |
2000-10-26 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@cc2ce655
09/05/00 16:12:05 |
Joel Sherrill |
2000-09-04 Ralf Corsepius <corsepiu@…>
4.104.114.84.95
@e94ad1fe
08/10/00 13:24:00 |
Joel Sherrill |
Adding ChangeLogs?.
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@85d62357
01/13/00 19:26:38 |
Joel Sherrill |
Changed error checking macros for POSIX.
4.104.114.84.95
@f388d36
01/05/00 18:17:01 |
Joel Sherrill |
Now print strings -- not error numbers.
4.104.114.84.95
@b8cda5a6
11/22/99 19:02:35 |
Joel Sherrill |
Added ifndef around build_time so pmacros.h and tmacros.h could be …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@96c2db6
11/16/99 22:51:47 |
Joel Sherrill |
Added code so if dispatching level is specified to be -1, then no …
4.104.114.84.95
@4b960e5
11/16/99 16:21:00 |
Joel Sherrill |
Added code to the macros which checked directive status to also
check …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@908436c1
08/10/99 15:38:09 |
Joel Sherrill |
New configuration files added by patch from
Ralf Corsepius …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@2a3d1fd
01/29/97 00:31:56 |
Joel Sherrill |
Made stopping for the pause an option which can be configured in the …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@ba39113
02/22/96 20:14:36 |
Joel Sherrill |
The name of the test support routine pause was changed to …
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@11290355
09/29/95 17:19:16 |
Joel Sherrill |
all targets compile .. tony's patches in place
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@4b374f36
08/17/95 19:36:43 |
Joel Sherrill |
maximum number of messages removed and include statement cleanup
4.104.114.84.95
@8d47a15
08/11/95 14:33:56 |
Joel Sherrill |
cleanup
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
