Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/testsuites/sptests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @f8700f77   04/07/97 21:33:28 Joel Sherrill corrected printf specifications and added casts as necessary to … 4.104.114.84.95
(edit) @de4f281   04/07/97 21:31:59 Joel Sherrill added ifdef to avoid warning for unused variable. 4.104.114.84.95
(edit) @1c666fc   04/07/97 21:31:39 Joel Sherrill corrected integer only definitions of "FP CHECK" routines to eliminate … 4.104.114.84.95
(edit) @51f5d64c   04/02/97 16:26:39 Joel Sherrill corrected printf format to avoid warning 4.104.114.84.95
(edit) @d135fc52   01/08/97 16:22:22 Joel Sherrill _CPU_Trap_Table_area is now conditional based on whether or not the … 4.104.114.84.95
(edit) @7abd27b   09/18/96 21:07:37 Joel Sherrill added cast 4.104.114.84.95
(edit) @cc51de91   09/17/96 21:38:59 Joel Sherrill extended Task_id and Task_name arrays to avoid indexing past end of array. 4.104.114.84.95
(edit) @022923e   06/13/96 16:45:51 Joel Sherrill Added _Thread_Do_post_task_switch_extension variable. 4.104.114.84.95
(edit) @7aa4671   06/05/96 21:12:06 Joel Sherrill added cpu_time_budget field to Thread_Control and removed the global … 4.104.114.84.95
(edit) @fa4fdd7d   06/03/96 20:15:16 Joel Sherrill updated screen 4.104.114.84.95
(edit) @5e7b6272   05/31/96 23:27:45 Joel Sherrill renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the … 4.104.114.84.95
(edit) @be1c11ed   05/29/96 22:48:26 Joel Sherrill tests now specify whether using posix initialization threads table or … 4.104.114.84.95
(edit) @6d12f59   05/24/96 19:34:05 Joel Sherrill updates from Tony Bennett to correct calling sequences. 4.104.114.84.95
(edit) @8389628   04/22/96 16:53:46 Joel Sherrill updates from Tony Bennett 4.104.114.84.95
(edit) @5a36154a   04/22/96 16:53:05 Joel Sherrill addition of optional user provided stack allocator means that we can … 4.104.114.84.95
(edit) @ba39113   02/22/96 20:14:36 Joel Sherrill The name of the test support routine pause was changed to … 4.104.114.84.95
(edit) @0e0d88b   02/21/96 14:47:58 Joel Sherrill Dispersal of internal thread handler resulted in removal of some … 4.104.114.84.95
(edit) @8bde6ea9   02/13/96 22:16:36 Joel Sherrill removed post switch extension 4.104.114.84.95
(edit) @8c8a924   02/09/96 14:31:39 Joel Sherrill As part of implementing the new isr synchronization algorithm using a … 4.104.114.84.95
(edit) @c3dcd6e   01/19/96 22:22:12 Joel Sherrill Added RTEMS API control structure to per task memory usage macro. 4.104.114.84.95
(edit) @709b93d   01/19/96 22:21:46 Joel Sherrill Increased stack size. 4.104.114.84.95
(edit) @97dde60   01/17/96 20:14:18 Joel Sherrill increased stack space 4.104.114.84.95
(edit) @c64e4ed4   01/15/96 21:50:28 Joel Sherrill updates from Tony Bennett for PA and UNIX ports 4.104.114.84.95
(edit) @c4808ca   10/31/95 21:28:16 Joel Sherrill typos fixed 4.104.114.84.95
(edit) @9700578   10/30/95 21:54:45 Joel Sherrill SPARC port passes all tests 4.104.114.84.95
(edit) @eb5a7e07   10/06/95 20:48:38 Joel Sherrill fixed missing CVS IDs 4.104.114.84.95
(edit) @37f4c2d   09/27/95 20:53:58 Joel Sherrill Modified UNIX simulator port so all references to native unix stuff is … 4.104.114.84.95
(edit) @5e9b32b   09/26/95 19:27:15 Joel Sherrill posix support initially added 4.104.114.84.95
(edit) @18c5378   09/22/95 15:35:48 Joel Sherrill moving files around and adding the exec/wrapup directory 4.104.114.84.95
(edit) @c896e8d   09/19/95 21:44:52 Joel Sherrill Heap changes required some changes in this screen. 4.104.114.84.95
(edit) @3652ad35   09/19/95 14:53:29 Joel Sherrill Minor bug fixes to get all targets compilable and running. The single … 4.104.114.84.95
(edit) @4b61ebfb   09/11/95 20:19:06 Joel Sherrill Added… 4.104.114.84.95
(edit) @3a4ae6c   09/11/95 19:35:39 Joel Sherrill The word "RTEMS" almost completely removed from the core. … 4.104.114.84.95
(edit) @7f6a24ab   08/28/95 15:30:29 Joel Sherrill Added unused priority ceiling parameter to rtems_semaphore_create. … 4.104.114.84.95
(edit) @5250ff39   08/23/95 21:06:31 Joel Sherrill Moved _Thread_Information -> _RTEMS_tasks_Information. Added a table … 4.104.114.84.95
(edit) @3235ad9   08/23/95 19:30:23 Joel Sherrill Support for variable length names added to Object Handler. This … 4.104.114.84.95
(edit) @2a0b721   08/18/95 21:44:46 Joel Sherrill Changed to reflect adding object class to id Added "0x" to printf of id 4.104.114.84.95
(edit) @94179e0   08/18/95 21:44:29 Joel Sherrill Changed to reflect adding object class to id 4.104.114.84.95
(edit) @4b374f36   08/17/95 19:36:43 Joel Sherrill maximum number of messages removed and include statement cleanup 4.104.114.84.95
(edit) @1690c6b   07/21/95 20:10:49 Joel Sherrill after testing go32 and cvme961 4.104.114.84.95
(edit) @637df35   07/12/95 19:47:25 Joel Sherrill Ada95, gnat, go32 4.104.114.84.95
(edit) @6b782ab   06/05/95 23:53:37 Joel Sherrill conditional added for the hppa gr27 4.104.114.84.95
(edit) @7c22114b   05/31/95 17:37:05 Joel Sherrill Corrected minor number for "Null" device driver 4.104.114.84.95
(edit) @88d594a   05/24/95 21:39:42 Joel Sherrill Fully tested on all in-house targets 4.104.114.84.95
(add) @ac7d5ef0   05/11/95 17:39:37 Joel Sherrill Initial revision 4.104.114.84.95
