@dd23125
03/22/15 14:43:23 |
Joel Sherrill |
testsuites/sptests/sp54/init.c: Add cast to avoid warning
4.115
@5da717a
03/20/15 22:56:56 |
Joel Sherrill |
sptls03/init.c: Make type and constants uint32_t to avoid overflow warnings
4.115
@dc8ab440
03/21/15 19:45:10 |
Joel Sherrill |
sptls01/init.c: Use larger data types for values
4.115
@73a2caf
03/20/15 15:50:13 |
Joel Sherrill |
sptests/spwatchdog/init.c: Avoid integer overflow
4.115
@2fe0f16d
03/20/15 15:49:06 |
Joel Sherrill |
sptests/spedfsched02: Reduce stack space usage to fix on smaller targets
4.115
@c6ef870
03/20/15 15:48:32 |
Joel Sherrill |
sptests/spatomic01/init.c: Avoid integer overflow
4.115
@70757114
03/20/15 15:47:59 |
Joel Sherrill |
sptests/sp34/changepri.c: Correct printf() warning
4.115
@6c1aff66
03/20/15 15:47:41 |
Joel Sherrill |
sptests/sp33/init.c: Correct printf() warning
4.115
@6849e53
03/21/15 19:43:47 |
Joel Sherrill |
sptests/sp20: Reduce memory requirements
This was checked on …
4.115
@2be0342
03/20/15 15:47:14 |
Joel Sherrill |
sptests/sp13/system.h: Fine tune message buffer configuration to avoid …
4.115
@52a34a7
03/20/15 15:46:18 |
Joel Sherrill |
sptests/sp12/pritask.c: Correct printf() warning
4.115
@a6524b9
03/22/15 13:31:59 |
Sebastian Huber |
score: Simplify debug code and use _Assert()
4.115
@40a24661
03/21/15 19:14:45 |
Sebastian Huber |
sptests/spintrcritical23: Fix warnings
4.115
@d4edbdbc
03/20/15 13:09:26 |
Sebastian Huber |
Replace www.rtems.com with www.rtems.org
4.115
@6a941e3
03/17/15 15:24:44 |
Sebastian Huber |
score: Fix _Thread_Change_priority()
Atomically update the current …
4.115
@72d3f1a6
03/15/15 15:31:01 |
Joel Sherrill |
spcbssched03/tasks_periodic.c: Fixed now used before set warning
4.115
@3c69c467
03/14/15 16:08:01 |
Joel Sherrill |
sptests misc: Update to not use deprecated methods
4.115
@e334edd
03/14/15 15:52:24 |
Joel Sherrill |
tests misc: Disable deprecated method usage warning when intentional
4.115
@979bda9
03/14/15 15:48:00 |
Joel Sherrill |
tm07: Split some code into new spnotepad02.
Use of deprecated …
4.115
@3ac68119
03/06/15 17:41:49 |
Gedare Bloom |
cpukit: deprecate notepads
Deprecate Classic API Notepads. Mark …
4.115
@7d6e94b
03/04/15 07:02:19 |
Sebastian Huber |
score: Implement fine-grained locking for events
Use the ISR lock of …
4.115
@b8a5abf
02/26/15 09:33:36 |
Sebastian Huber |
score: Update _Thread_Heir only if necessary
Previously, the …
4.115
@d0061287
03/05/15 09:11:23 |
Sebastian Huber |
tests: Fix warnings
4.115
@e50297e
03/04/15 09:15:02 |
Sebastian Huber |
score: ISR lock C/C++ compatiblity issue
Empty structures are …
4.115
@bd1c9248
02/26/15 09:19:38 |
Sebastian Huber |
sptests/sp76: Check that the right task executes
4.115
@a3316f47
02/19/15 10:12:01 |
Sebastian Huber |
sptests: Add missing test extension
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@16939b18
02/09/15 18:09:23 |
Sebastian Huber |
Filesystem: Simplify FIFO and pipe configuration
4.115
@efd2965a
02/02/15 14:25:26 |
Sebastian Huber |
Filesystem: Statically initialize rtems_libio_iops
4.115
@7f28f237
12/23/14 10:05:21 |
Sebastian Huber |
powerpc: Delete _CPU_IRQ_info
4.115
@a0b1b5ed
12/15/14 13:19:43 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define was …
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@0104056
12/03/14 10:14:42 |
Sebastian Huber |
sptests: Add get_one_tick_busy_value()
Extract this function from …
4.115
@9e8d8b5c
11/11/14 13:17:55 |
Daniel Hellstrom |
spcpuset01: fix test comments
4.115
@038faca1
11/25/14 15:47:20 |
Sebastian Huber |
rtems: Add rtems_cache_coherent_allocate()
Add …
4.115
@7e5c9b89
11/25/14 13:58:13 |
Sebastian Huber |
rtems: Move rtems_cache_aligned_malloc()
Make sure also the size is …
4.115
@7981a88
11/25/14 07:39:46 |
Sebastian Huber |
sptest/spcache01: New test cases
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@43633ae
10/14/14 10:12:32 |
Sebastian Huber |
testsuites: Avoid clock driver
4.115
@a38ced2
10/10/14 07:09:19 |
Sebastian Huber |
score: Rework global construction
Ensure that the global construction …
4.115
@6f1e1b3
09/19/14 12:18:00 |
Sebastian Huber |
sptests/spintrcritical22: New test
4.115
@7f8a978
09/16/14 13:43:15 |
Sebastian Huber |
sptests/sp07: Minimize thread dispatch latency
Do not use sprintf() …
4.115
@f9eca790
09/12/14 14:04:40 |
Sebastian Huber |
sptests/spintrcritical_support: Optimize busy loop
4.115
@73b5d8bf
09/12/14 14:04:01 |
Sebastian Huber |
sptests/spintrcritical10: Avoid undefined memory
4.115
@e09f8b08
09/10/14 12:46:03 |
Sebastian Huber |
sptests/spfatal07: Fix end of test message
4.115
@4984ee4
09/09/14 15:13:51 |
Sebastian Huber |
sptests/sp39: Convert to sptests/spintrcritical21
Use interrupt …
4.115
@8028089
09/08/14 13:18:07 |
Sebastian Huber |
tests: Rework interrupt critical tests
This avoids test durations of …
4.115
@07b4594
09/05/14 07:27:41 |
Sebastian Huber |
sptests/spcontext01: Fix warning
4.115
@a864016f
09/03/14 15:21:21 |
Joel Sherrill |
spcpuset01: Use %zd for size_t to eliminate warning
4.115
@9aa6ddf
09/03/14 15:07:28 |
Joel Sherrill |
spfreechain01/init.c: Use %zd for size_t to eliminate warning
4.115
@e1462e1
09/02/14 17:30:25 |
Joel Sherrill |
sp19: Eliminate warnings
4.115
@be4992b1
09/02/14 23:00:44 |
Joel Sherrill |
raspberrypi: Use shared bspreset.c
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@96ec8ee8
08/22/14 15:09:36 |
Sebastian Huber |
rtems: Add more clock tick functions
Add rtems_clock_tick_later(), …
4.115
@23b14f87
08/22/14 20:20:16 |
Hesham Almatary |
sptests/spcache01: Make inline assembly conditional to account for …
4.115
@bba3507
08/19/14 15:43:36 |
Sebastian Huber |
score: PR2179: Fix initially locked PI mutex
4.115
@0b9fe3ec
08/07/14 17:41:25 |
Sebastian Huber |
sptests/sprbtree01: Add random ops test case
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@d472d21
08/05/14 12:07:07 |
Sebastian Huber |
sptests/sprbtree01: Check tree layout
4.115
@888edf6
08/05/14 11:52:45 |
Sebastian Huber |
sptests/sprbtree01: Reduce stack usage
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@9ba76ed8
07/07/14 22:42:28 |
Joel Sherrill |
sp59: Fix typos
4.115
@8852594
07/01/14 10:02:24 |
Sebastian Huber |
sptests/spcontext01: Avoid NULL pointer access
4.115
@f6fc6359
06/03/14 10:00:53 |
Sebastian Huber |
sptests/spsem03: New test
4.115
@3e201139
05/23/14 08:00:33 |
Sebastian Huber |
score: Add Resource Handler
A resource is something that has at most …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@4edf348c
05/22/14 07:31:13 |
Sebastian Huber |
score: PR2179: Fix initially locked PCP mutexes
Elevate the priority …
4.115
@eae0863
04/27/14 08:11:09 |
Chris Johns |
rtems: Fix sp2038 test.
Avoid using newlib's gmtime_r call which …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@3324383c
05/05/14 14:47:30 |
Joel Sherrill |
testsuites: Remove BSP_SMALL_MEMORY
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@27270b0d
04/09/14 08:09:39 |
Sebastian Huber |
rtems: Add task get/set scheduler
4.115
@1b67535d
04/09/14 08:09:57 |
Sebastian Huber |
rtems: Add scheduler get processors
4.115
@b427a92
04/09/14 08:09:24 |
Sebastian Huber |
rtems: Add scheduler identification
4.115
@0712d17
04/08/14 09:14:27 |
Sebastian Huber |
score: Task get/set affinity
Make rtems_task_get_affinity() and …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@589bbcb
04/14/14 21:05:52 |
Joel Sherrill |
sp74.doc: Correct minor typos
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@2d5424d2
04/09/14 07:40:43 |
Sebastian Huber |
sptests/sp37: Account for internal struct align
4.115
@eeb45b5
04/07/14 14:07:25 |
Sebastian Huber |
sptests/sp68: Fix configuration
4.115
@781631e
04/07/14 12:50:34 |
Sebastian Huber |
sptests/spwatchdog: Fix for short enums
4.115
@e785fbaa
04/04/14 11:58:26 |
Sebastian Huber |
score: Delete _Thread_Ticks_per_timeslice
Use the Configuration instead.
4.115
@47445846
04/04/14 11:43:15 |
Sebastian Huber |
score: Delete _Thread_Maximum_extensions
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
