@8028089
09/08/14 13:18:07 |
Sebastian Huber |
tests: Rework interrupt critical tests
This avoids test durations of …
4.115
@07b4594
09/05/14 07:27:41 |
Sebastian Huber |
sptests/spcontext01: Fix warning
4.115
@a864016f
09/03/14 15:21:21 |
Joel Sherrill |
spcpuset01: Use %zd for size_t to eliminate warning
4.115
@9aa6ddf
09/03/14 15:07:28 |
Joel Sherrill |
spfreechain01/init.c: Use %zd for size_t to eliminate warning
4.115
@e1462e1
09/02/14 17:30:25 |
Joel Sherrill |
sp19: Eliminate warnings
4.115
@be4992b1
09/02/14 23:00:44 |
Joel Sherrill |
raspberrypi: Use shared bspreset.c
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@96ec8ee8
08/22/14 15:09:36 |
Sebastian Huber |
rtems: Add more clock tick functions
Add rtems_clock_tick_later(), …
4.115
@23b14f87
08/22/14 20:20:16 |
Hesham Almatary |
sptests/spcache01: Make inline assembly conditional to account for …
4.115
@bba3507
08/19/14 15:43:36 |
Sebastian Huber |
score: PR2179: Fix initially locked PI mutex
4.115
@0b9fe3ec
08/07/14 17:41:25 |
Sebastian Huber |
sptests/sprbtree01: Add random ops test case
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@d472d21
08/05/14 12:07:07 |
Sebastian Huber |
sptests/sprbtree01: Check tree layout
4.115
@888edf6
08/05/14 11:52:45 |
Sebastian Huber |
sptests/sprbtree01: Reduce stack usage
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@9ba76ed8
07/07/14 22:42:28 |
Joel Sherrill |
sp59: Fix typos
4.115
@8852594
07/01/14 10:02:24 |
Sebastian Huber |
sptests/spcontext01: Avoid NULL pointer access
4.115
@f6fc6359
06/03/14 10:00:53 |
Sebastian Huber |
sptests/spsem03: New test
4.115
@3e201139
05/23/14 08:00:33 |
Sebastian Huber |
score: Add Resource Handler
A resource is something that has at most …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@4edf348c
05/22/14 07:31:13 |
Sebastian Huber |
score: PR2179: Fix initially locked PCP mutexes
Elevate the priority …
4.115
@eae0863
04/27/14 08:11:09 |
Chris Johns |
rtems: Fix sp2038 test.
Avoid using newlib's gmtime_r call which …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@3324383c
05/05/14 14:47:30 |
Joel Sherrill |
testsuites: Remove BSP_SMALL_MEMORY
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@27270b0d
04/09/14 08:09:39 |
Sebastian Huber |
rtems: Add task get/set scheduler
4.115
@1b67535d
04/09/14 08:09:57 |
Sebastian Huber |
rtems: Add scheduler get processors
4.115
@b427a92
04/09/14 08:09:24 |
Sebastian Huber |
rtems: Add scheduler identification
4.115
@0712d17
04/08/14 09:14:27 |
Sebastian Huber |
score: Task get/set affinity
Make rtems_task_get_affinity() and …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@589bbcb
04/14/14 21:05:52 |
Joel Sherrill |
sp74.doc: Correct minor typos
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@2d5424d2
04/09/14 07:40:43 |
Sebastian Huber |
sptests/sp37: Account for internal struct align
4.115
@eeb45b5
04/07/14 14:07:25 |
Sebastian Huber |
sptests/sp68: Fix configuration
4.115
@781631e
04/07/14 12:50:34 |
Sebastian Huber |
sptests/spwatchdog: Fix for short enums
4.115
@e785fbaa
04/04/14 11:58:26 |
Sebastian Huber |
score: Delete _Thread_Ticks_per_timeslice
Use the Configuration instead.
4.115
@47445846
04/04/14 11:43:15 |
Sebastian Huber |
score: Delete _Thread_Maximum_extensions
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@91e7b0c
03/27/14 08:04:47 |
Sebastian Huber |
score: PR2172: _Thread_queue_Extract()
Add …
4.115
@ab816bc
03/31/14 07:23:48 |
Sebastian Huber |
sptests/sptask_err04: Fix broken test
4.115
@03e89287
03/27/14 13:46:31 |
Sebastian Huber |
score: Delete CORE_mutex_Control::lock
The holder field is enough to …
4.115
@f0b4fd9
03/28/14 08:29:51 |
Sebastian Huber |
score: Do not reset resource count during restart
This fixes an …
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@ecd8c8ad
03/28/14 10:58:20 |
Sebastian Huber |
tests/fatal: Fix test names
4.115
@5a13ef9
03/28/14 10:34:16 |
Sebastian Huber |
sptests/sp44: Fix end of test output
4.115
@df367fad
03/28/14 18:05:57 |
bjornlarsson |
sptests: New tests split from sp09 screen 1 and screen 2.
Split sp09 …
4.115
@719c7e5
03/27/14 14:47:24 |
bjornlarsson |
sptask_err03: New test split from sp09 screen 3.
4.115
@4327a7b
03/26/14 18:22:43 |
bjornlarsson |
spevent_err03: New test split from sp09 screen 4.
4.115
@d6f65e40
03/26/14 14:56:43 |
bjornlarsson |
sptests: split sp09 screen 5,6 into spsem_err01, spsem_err02, and …
4.115
@a3707d89
03/25/14 18:48:30 |
bjornlarsson |
sptests: Split sp09 screens 7,8 into spmsg1_err01 and spmsgq_err02.
4.115
@abc833bd
03/25/14 17:51:14 |
bjornlarsson |
spport_err01: New test split from sp09
This test verifies …
4.115
@34244b7a
03/25/14 14:58:04 |
bjornlarsson |
spsignal_err01: New test split from sp09.
This test moves …
4.115
@0cf41e5
03/25/14 14:43:09 |
bjornlarsson |
spintr_err01: New test split from sp09.
This test contains the …
4.115
@9c88bc6e
03/25/14 14:13:03 |
bjornlarsson |
spratemon_err01: New test split from sp09.
4.115
@5c0c0cf
03/27/14 13:23:21 |
Christian.Mauderer |
privateenv: Use POSIX keys instead of task variables.
4.115
@7d5c27e
03/27/14 13:23:20 |
privateenv: Remove sharing of user environment between threads.
4.115
@8c26e798
03/25/14 15:45:08 |
Sebastian Huber |
tests: Produce proper begin/end messages
4.115
@9b44339c
03/24/14 06:53:45 |
Sebastian Huber |
score: Delete _Watchdog_Report()
Delete _Watchdog_Report_chain(). …
4.115
@65612cc
03/25/14 08:46:45 |
Sebastian Huber |
sptests/spprintk: Use <rtems/test.h>
4.115
@6c0301d
03/25/14 07:06:21 |
Sebastian Huber |
tests/sptests: Use <rtems/test.h>
4.115
@22729053
03/25/14 07:06:06 |
Sebastian Huber |
tests: Use rtems_status_text()
4.115
@5ef9f23
03/21/14 13:29:55 |
libcsupport: Use POSIX keys for GXX key functions
With this patch C++ …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@29c9eb6
03/10/14 09:03:55 |
Sebastian Huber |
sapi: Add per-CPU profiling application level data
4.115
@4dad4b8
03/10/14 13:39:49 |
Sebastian Huber |
sapi: Add profiling application level support
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@b1196e3
03/10/14 07:13:06 |
Sebastian Huber |
printk: Add support for long long
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@13ab94b
02/06/14 18:51:01 |
Jennifer Averett |
spcpuset01: Add check for sys/cpuset.h.
If <sys/cpuset.h> is not …
4.115
@e1d7bf0
02/26/14 10:08:31 |
Sebastian Huber |
rtems: Add cache size functions
Add rtems_cache_get_data_cache_size() …
4.115
@e7549ff4
02/26/14 10:00:17 |
Sebastian Huber |
rtems: Use size_t for cache line size
A cache line cannot have a …
4.115
@31494ab2
02/26/14 11:59:47 |
Sebastian Huber |
sptests/spcache01: Detect write-through cache
4.115
@3378be95
02/17/14 07:16:54 |
Sebastian Huber |
sptests/spcache01: New test
4.115
@95d0c98
02/24/14 09:13:32 |
Sebastian Huber |
score: Fix thread TLS area initialization
Do not use _TLS_Size here …
4.115
@07dc970
02/24/14 08:53:16 |
Sebastian Huber |
sptests/spcpucounter01: Adjust test
Adjust test to work with clock …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
