@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@84e6f15
11/10/16 11:02:28 |
Sebastian Huber |
score: Robust thread dispatch
On SMP configurations, it is a fatal …
5
@408609f6
11/10/16 14:17:28 |
Sebastian Huber |
score: Add _ISR_Is_enabled()
In contrast to _ISR_Get_level() the …
5
@d78d529
11/14/16 08:11:07 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_direct()
This function is useful …
5
@1897fa6
11/10/16 15:56:11 |
Sebastian Huber |
sptests/sp37: Better cope with internal padding
5
@05ca53d
10/31/16 12:08:33 |
Sebastian Huber |
rtems: Add scheduler processor add/remove
Update #2797.
5
@1f5bee3
11/07/16 15:54:40 |
Sebastian Huber |
score: Add and use Thread_Control::is_idle
Update #2797.
5
@6de41c5f
10/27/16 06:24:50 |
Sebastian Huber |
Provide kernel space header files
These kernel space header files …
5
@47d2464
10/31/16 15:23:52 |
Sebastian Huber |
score: Conditionally enable thread resource count
Maintain the thread …
5
@9e7fa07
10/31/16 15:23:13 |
Sebastian Huber |
score: Relax _Scheduler_Set() restrictions
No longer unconditionally …
5
@1cafc46
10/31/16 05:19:43 |
Sebastian Huber |
score: Delete Resource Handler
Update #2556.
5
@3a27248
10/21/16 07:23:58 |
Sebastian Huber |
score: First part of new MrsP implementation
Update #2556.
5
@b7694c8c
10/31/16 15:04:11 |
Sebastian Huber |
sptests/sp35: Remove dead code
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@be57318
09/23/16 04:45:07 |
Sebastian Huber |
score: More robust linker sets
Update #2408.
Update #2790.
5
@938ee19c
09/23/16 08:09:57 |
Sebastian Huber |
sptests/spsem03: Fix compile error
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@3709987
08/10/16 06:21:54 |
Sebastian Huber |
score: Add _Chain_Initialize_one()
5
@83b0229
06/28/16 04:59:29 |
Sebastian Huber |
score: Add _RBTree_Initialize_one()
5
@55faa44
08/12/16 09:16:45 |
Sebastian Huber |
score: Improve _RBTree_Insert_inline()
Return if the inserted node is …
5
@21d73655
08/10/16 07:54:13 |
Sebastian Huber |
sptests/splinkersets01: Fix for small-data area
5
@5c09e9d
08/08/16 07:47:06 |
Sebastian Huber |
sptests/splinkersets01: Fix warnings
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@5fe6d07a
08/01/16 11:16:57 |
Christian.Mauderer |
linker set: Allow adding any variable into content
The newly created …
5
@d79df38
07/26/16 08:34:21 |
Sebastian Huber |
score: Add deadlock detection
The mutex objects use the owner field …
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@c1b815ab
07/26/16 07:26:19 |
Sebastian Huber |
sptests/spextensions01: Avoid NULL pointer access
5
@0fd6f255
07/08/16 14:58:48 |
Sebastian Huber |
score: Relax thread begin extension environment
Update #2752.
5
@059529e
07/21/16 08:15:02 |
Sebastian Huber |
score: Add debug support to chains
* double …
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@9f61ad60
06/23/16 11:43:38 |
Sebastian Huber |
testsuites: Increase invalid priority values
Increase the invalid …
5
@50a56dff
06/24/16 09:16:35 |
Sebastian Huber |
score: Move SCHEDULER_EDF_PRIO_MSB
This is an implementation detail …
5
@b364d38
06/24/16 06:26:55 |
Sebastian Huber |
sptests/spintrcritical23: Explicity set scheduler
This test uses …
5
@b679b492
06/23/16 07:09:55 |
Sebastian Huber |
sptests/sp42: Relax priority requirements
5
@9bfad8c
06/08/16 20:22:46 |
Sebastian Huber |
score: Add thread priority to scheduler nodes
The thread priority is …
5
@c82835a
06/21/16 15:12:40 |
Sebastian Huber |
rtems: Rework RTEMS API to SuperCore? priority
Use same structure as …
5
@3d9fd2ce
06/21/16 12:30:13 |
Sebastian Huber |
sptests/sp20: Use printer task
This avoids test failures due to slow …
5
@ede1a41
06/21/16 11:12:31 |
Sebastian Huber |
Make rtems/print.h independent of rtems/bspIo.h
5
@e8020d1
06/21/16 11:28:01 |
Sebastian Huber |
Rename and move RTEMS_PRINTF_ATTRIBUTE()
Rename …
5
@7222a65
06/21/16 07:45:39 |
Sebastian Huber |
sptests/spcpucounter01: Resurrect workaround
Resurrect workaround …
5
@3e2a3c4
06/20/16 11:55:37 |
Sebastian Huber |
sptests/spcpucounter01: Add some statistics
5
@bc47ec1c
06/20/16 04:50:12 |
Sebastian Huber |
score: Refine system initialization order
5
@6a6a225
06/20/16 06:10:51 |
Sebastian Huber |
sptests/spsysinit01: Move begin of test message
5
@3ad5f86
06/03/16 06:15:21 |
Sebastian Huber |
rtems: Fix no protocol mutex release
The Classic binary semaphores …
5
@73f2ddb
05/30/16 08:43:31 |
Sebastian Huber |
rtems: Fix semaphore field name
5
@09c5ca4
05/26/16 20:29:56 |
Sebastian Huber |
score: Simplify CORE mutex
Remove superfluous support for simple …
5
@93306058
05/27/16 12:43:19 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Move the safety check …
5
@0e1d11f3
05/27/16 11:26:53 |
Sebastian Huber |
score: Add _Thread_queue_Context_set_MP_callout()
Add …
5
@dce48791
05/23/16 11:37:59 |
Sebastian Huber |
score: Add Status_Control for all APIs
Unify the status codes of the …
5
@39bcf741
05/25/16 12:23:48 |
Sebastian Huber |
Fix semaphore post overflow status
Close #2720.
5
@631b3c8
05/23/16 09:40:18 |
Sebastian Huber |
score: Move thread queue MP callout to context
Drop the …
5
@addf1aa
05/23/16 05:29:49 |
Chris Johns |
testsuite: Fix printk format warnings.
5
@24d0ee57
05/20/16 08:39:50 |
Chris Johns |
cpukit, testsuite: Add rtems_printf and rtems_printer support.
This …
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@62c528e6
05/20/16 12:59:30 |
Sebastian Huber |
rtems: _Semaphore_Get_interrupt_disable()
Use _Objects_Get_local() …
5
@dab902d5
05/17/16 13:43:31 |
Sebastian Huber |
testsuites: Avoid Giant lock
Replace _Thread_Disable_dispatch() with …
5
@5eac9676
05/17/16 12:54:48 |
Sebastian Huber |
testsuites: Replace _Thread_Get()
Replace _Thread_Get() with …
5
@92f68830
05/17/16 12:48:46 |
Sebastian Huber |
sptests/spintrcritical22: Avoid _Objects_Get()
Use …
5
@9949d8a7
05/12/16 14:32:27 |
Sebastian Huber |
score: Add Thread_Change_life()
Add _Thread_Change_life_locked() as a …
5
@adc819ef
05/17/16 05:36:27 |
Sebastian Huber |
sptests/spthreadlife01: Add self delete test case
5
@9276fde
05/11/16 15:52:13 |
Sebastian Huber |
score: Fix CORE mutex initialization
The priority inheritance and …
5
@876dde7a
05/03/16 07:19:59 |
Sebastian Huber |
score: Make _Objects_Information_table const
The …
5
@1d40d81b
05/03/16 05:38:19 |
Sebastian Huber |
rtems: Remove task variables
Update #2494.
Update #2555.
5
@500a8e9c
04/28/16 04:26:01 |
Sebastian Huber |
score: Delete RTEMS_STRICT_ORDER_MUTEX
Remove support for strict …
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@b466226
04/20/16 04:57:47 |
Sebastian Huber |
score: Add _Thread_queue_Is_empty()
5
@36cd27c
04/19/16 12:12:06 |
Sebastian Huber |
score: Simplify _Objects_Get_next()
Remove unused location parameter.
5
@bdf6cc2
04/20/16 12:00:44 |
Sebastian Huber |
sptests/spsysinit01: Fix warning
5
@709f38a
04/13/16 04:48:58 |
Sebastian Huber |
score: Use chain iterator for user extensions
Add a lock and use a …
5
@8f6c295b
04/11/16 15:03:05 |
Sebastian Huber |
score: Add Chain_Iterator
Add a chain iterator for safe iteration of …
5
@e65c45c
03/22/16 22:13:30 |
joel |
Obsolete rtems_clock_get() directive.
This service was marked as …
5
@6efa349
04/14/16 06:56:53 |
Sebastian Huber |
posix: Run key destructors during thread restart
POSIX key …
5
@84f5c0a
04/04/16 07:42:15 |
Sebastian Huber |
score: Use red-black tree for active global objects
Use a red-black …
5
@84dc9df
04/04/16 04:17:36 |
Sebastian Huber |
score: Use red-black tree for active MP proxies
Update #2555.
5
@97312fcc
04/05/16 12:36:30 |
Sebastian Huber |
score: Delete Thread_Wait_information::id
This field was only by the …
5
@1e1a91ed
03/23/16 09:01:31 |
Sebastian Huber |
score: Remove Thread_queue_Queue::operations field
Remove the …
5
@b66394d
03/22/16 15:17:41 |
joel |
sp13/task1.c: Remove warning for misleading indentation
Fix a block …
5
@90960bd
03/21/16 14:01:57 |
Sebastian Huber |
rtems: Rework rate-monotonic scheduler
Use the default thread lock to …
5
@1f0e652a
03/18/16 14:31:28 |
Sebastian Huber |
sptests/sptls02: Use GNU++11
This avoids a problem with the feature …
5
@474b9be
03/15/16 14:42:57 |
Sebastian Huber |
score: Use allocator lock in _Objects_Get_next()
Use the object …
5
@18ff889
03/14/16 09:11:38 |
Sebastian Huber |
score: Use ISR lock for IO driver registration
Create implementation …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@1db9567
03/01/16 14:00:43 |
Sebastian Huber |
sptests/spsysinit01: Fix for RTEMS_DEBUG
Update #2408.
5
@5774b752
02/22/16 05:55:27 |
Sebastian Huber |
sptests/sp65: Fix test names
5
@3bc12a8f
01/26/16 10:16:56 |
Sebastian Huber |
Delete unused API extensions
5
@4210114
01/26/16 10:13:45 |
Sebastian Huber |
Use linker set for POSIX User Threads init
Update #2408.
5
@1ff8eca
01/26/16 10:10:43 |
Sebastian Huber |
Use linker set for Classic User Tasks init
Update #2408.
5
@8ca372e
01/26/16 09:11:48 |
Sebastian Huber |
Use linker set for MPCI initialization
Update #2408.
5
@ca4602e
01/25/16 21:03:00 |
Sebastian Huber |
Use linker set for libio initialization
Update #2408.
5
@3d36164f
01/25/16 20:18:41 |
Sebastian Huber |
Use linker set for root file system initialization
Update #2408.
5
@2605a489
12/15/15 08:32:55 |
Sebastian Huber |
Optional POSIX Keys initialization
Update #2408.
5
@190169fe
12/10/15 14:30:41 |
Sebastian Huber |
Optional CPU Set Handler initialization
Update #2408.
5
@4eee8781
12/14/15 15:40:28 |
Sebastian Huber |
Optional POSIX Spinlock initialization
Update #2408.
5
@76a8328
12/14/15 15:39:10 |
Sebastian Huber |
Optional POSIX RWLock initialization
Update #2408.
5
@e4e7f14
12/14/15 15:37:34 |
Sebastian Huber |
Optional POSIX Barrier initialization
Update #2408.
5
@6c678557
12/14/15 15:36:21 |
Sebastian Huber |
Optional POSIX Timer initialization
Update #2408.
5
@2189b3e
12/14/15 15:34:50 |
Sebastian Huber |
Optional POSIX Semaphore initialization
Update #2408.
5
