@9949d8a7
05/12/16 14:32:27 |
Sebastian Huber |
score: Add Thread_Change_life()
Add _Thread_Change_life_locked() as a …
5
@41ce30a
05/18/16 12:34:26 |
Sebastian Huber |
SMP: Add Mellor-Crummey and Scott (MCS) lock
Added only for …
5
@1379d84
05/12/16 08:57:15 |
Sebastian Huber |
smptests/smpcapture02: Adjust for clock changes
Fix overall clock …
5
@bd12dda
05/11/16 09:54:49 |
Sebastian Huber |
score: Use thread state lock for current state
In addition protect …
5
@981eed2
04/29/16 10:09:32 |
Sebastian Huber |
score: Add dummy Strong APA scheduler
Start with a copy of the …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@b3a4c48e
02/17/16 13:27:09 |
Sebastian Huber |
score: Add _SMP_Online_processors
5
@eead8f7
03/02/16 14:28:29 |
Sebastian Huber |
smptests/smpmrsp01: Fix test context
5
@10f28914
02/17/16 10:33:27 |
Sebastian Huber |
smptests/smpwakeafter01: Add scheduler config
Update #2554.
5
@3d1becf
01/11/16 06:57:12 |
Sebastian Huber |
smptests/README: Delete obsolete information
5
@54406d9
10/15/15 09:56:15 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define accidentally …
5
@258ad71
09/25/15 12:34:24 |
Sebastian Huber |
SMP: Fix and optimize thread dispatching
According to the C11 and …
5
@8d296cd5
09/26/15 11:03:16 |
Sebastian Huber |
score: Use uintptr_t for atomic pointer operations
Do not obfuscate …
5
@dafa5d88
09/03/15 08:27:16 |
Sebastian Huber |
score: Implement priority boosting
5
@3995e6d
09/02/15 09:58:54 |
Sebastian Huber |
score: Implement SMP-specific priority queue
5
@43d7005
06/02/15 12:32:58 |
Sebastian Huber |
smptests/smpscheduler02: Reduce required CPU count
4.115
@2c14e67
06/02/15 12:22:03 |
Sebastian Huber |
smptests/smpmrsp01: Reduce required CPU count
4.115
@f48b73de
06/02/15 12:10:05 |
Sebastian Huber |
smptests/smpscheduler03: Use proper lock
4.115
@33e30f39
05/12/15 08:15:21 |
Sebastian Huber |
smptests/smpscheduler03: Restructure
Restructure to avoid large …
4.115
@900d337f
05/05/15 11:05:54 |
Sebastian Huber |
score: Rework _Thread_Change_priority()
Move the writes to …
4.115
@b1b5ddf0
05/15/15 11:17:16 |
Sebastian Huber |
smptests/smpcache01: Restructure
Restructure to avoid large maximum …
4.115
@be0366b
05/10/15 19:30:26 |
Sebastian Huber |
score: Fix scheduler helping protocol
Account for priority changes of …
4.115
@36413201
04/22/15 07:22:27 |
cederman |
smptests/smpcache01: Enable interrupts before waiting for other CPUs
4.115
@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
@e7e86ba
03/25/15 08:50:59 |
Sebastian Huber |
smpmigration01: Delete timing dependent assert
The cycles per runner …
4.115
@4f10ed6
03/24/15 12:42:08 |
Sebastian Huber |
smptests/smpfatal08: Workaround for QorIQ BSPs
4.115
@8c7eb00
03/17/15 09:32:20 |
Sebastian Huber |
testsupport: Add worker setup handler
Add …
4.115
@33b72fd
03/06/15 15:13:40 |
alexander.krutwig |
testsupport: Add cascade option to parallel test
4.115
@7f577d3
03/05/15 08:06:44 |
alexander.krutwig |
tests: Refactor parallel test execution
4.115
@c5436ff4
03/04/15 10:56:25 |
Sebastian Huber |
smptests/smpcapture01: Avoid livelock condition
4.115
@0324410
02/26/15 09:26:49 |
Sebastian Huber |
smptests: Do not use Giant directly
This ensures that thread …
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@8d8573ac
02/04/15 09:04:05 |
cederman |
smpcapture02: Add test of functionality to add custom entries to …
4.115
@77c5ddd4
01/14/15 06:34:44 |
Sebastian Huber |
smptests/smpmrsp01: Fix task delete race condition
Do not supsend …
4.115
@e7d175af
01/08/15 09:43:56 |
Sebastian Huber |
smptests/smpwakeafter01: Fix task count
4.115
@ad0743db
12/22/14 14:10:32 |
Sebastian Huber |
smptests/smpmrsp01: Update run indicator only once
On the Freescale …
4.115
@864d3475
12/17/14 14:11:00 |
Sebastian Huber |
smp: Fix timeout for MrsP semaphores
The previous timeout handling …
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@0ff1c29
11/27/14 07:45:10 |
Sebastian Huber |
smptests/smpmrsp01: Use busy waits
Use busy waits instead of sleeps …
4.115
@5bd822a7
11/26/14 10:51:34 |
Sebastian Huber |
smp: Fix scheduler helping protocol
Ensure that scheduler nodes in …
4.115
@39af57c3
11/24/14 20:49:28 |
Jennifer Averett |
smp09: Resolve missing prototype warning.
4.115
@6291e962
11/24/14 20:48:58 |
Jennifer Averett |
smp07: Resolve missing prototype warning.
4.115
@2c474a0
11/24/14 20:48:31 |
Jennifer Averett |
smp05: Resolve missing prototype warning.
4.115
@441dc1c
10/22/14 18:47:25 |
Jennifer Averett |
smp02: Resolve unused method warnings.
4.115
@4375b3b6
10/22/14 18:45:38 |
Jennifer Averett |
smp03: Remove set but not used warning.
Added status validation.
4.115
@689cba2
10/22/14 18:44:02 |
Jennifer Averett |
smpschedsem01: Remove unused variable warning.
4.115
@15e371f
10/22/14 13:42:59 |
Jennifer Averett |
smpschedaffinity02: Remove unused prototype.
4.115
@44da98f
10/24/14 19:37:24 |
Jennifer Averett |
smpcapture01: New test.
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
New test case for …
4.115
@db44590c
11/11/14 16:21:02 |
Jennifer Averett |
smpschedaffinity05: Change semaphore attributes.
Change semaphore …
4.115
@1960dcb9
11/12/14 14:42:13 |
Jennifer Averett |
smpschedaffinity04: Change semaphore attributes.
Change semaphore …
4.115
@bc95f816
11/12/14 14:42:48 |
Jennifer Averett |
smpschedaffinity02: Change semaphore attributes.
Change semaphore …
4.115
@d412e2f
10/24/14 07:18:38 |
Sebastian Huber |
smptests/smpfatal03: Wait for end of test msg
4.115
@092b8c5
10/24/14 05:21:51 |
Sebastian Huber |
tests/smptests: Normal use of test extension
4.115
@17889b2
10/23/14 15:15:47 |
Sebastian Huber |
tests/smptests: Use barriers in smpfatal0{12}
Call the test extension …
4.115
@8f0a2c9
09/17/14 08:28:13 |
Sebastian Huber |
smptests/smpload01: Report profiling only once
Rely on test extension …
4.115
@6e1206a
09/11/14 15:55:34 |
cederman |
smptests/smpcache01: Remove invalidation of data cache lines from test …
4.115
@5689d72
09/01/14 14:12:42 |
Sebastian Huber |
smptests/smplock01: Update screen file
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@c147a139
09/01/14 06:45:23 |
Sebastian Huber |
smptests/smpfatal08: Fix link error
4.115
@9a9ab85
07/03/14 14:42:24 |
cederman |
smptests/smpcache01: Test the SMP cache manager
Invokes SMP cache …
4.115
@247118bf
07/10/14 16:55:04 |
Jennifer Averett |
smpschedsem01: new test.
This test verifies priority is inherited …
4.115
@7eb3fd47
07/10/14 16:45:58 |
Jennifer Averett |
smpschedaffinity05: Add test for worst case migration for affintiy …
4.115
@61d26f93
07/10/14 16:36:40 |
Jennifer Averett |
smpschedaffinity04: New test.
This test walks a secondary high …
4.115
@28d66749
07/10/14 16:18:02 |
Jennifer Averett |
smpschedaffinity03: New test.
This task walks the affinity of self …
4.115
@09293069
07/10/14 15:19:06 |
Jennifer Averett |
smpschedaffinity02: New test.
This test checks setting the affinity …
4.115
@d88b0e7f
05/22/14 14:00:14 |
Jennifer Averett |
smpschedaffinity01: New test.
This test verifies that affinity is …
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@9f228bea
06/24/14 08:00:06 |
Sebastian Huber |
smptests/smpmrsp01: Add and update test cases
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@0b4ec4d
06/30/14 10:30:12 |
Sebastian Huber |
smptests/smpfatal08: Support RTEMS_PARAVIRT
4.115
@b42e148
06/24/14 07:53:11 |
Sebastian Huber |
smptests/smpmigration02: PR2183: Add test case
4.115
@a92989a
06/18/14 13:16:02 |
Sebastian Huber |
score: Fix thread deletion on SMP
Close the thread object in …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@bd56356b
06/18/14 08:54:04 |
Sebastian Huber |
smptests/smpwakeafter01: New test
4.115
@11947299
06/13/14 14:06:20 |
Sebastian Huber |
smptests: Avoid use of uninitialized data
4.115
@4962d24d
06/11/14 14:34:51 |
Sebastian Huber |
smptests/smpscheduler03: Test all SMP schedulers
4.115
@2a2a1695
06/10/14 09:42:19 |
Sebastian Huber |
smptest/smpfatal03: Update due to API changes
4.115
@5abe5a8
06/02/14 14:15:15 |
Christian.Mauderer |
smptests/smpthreadlife01: Fix for debug enabled
4.115
@1ee0d5f
06/02/14 14:15:14 |
smptests/smpmrsp01: Fix scheduler ids
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@23b9d095
05/07/14 16:32:15 |
Sebastian Huber |
smptests/smp07: Fix test output
4.115
@8fa3422
05/07/14 16:30:36 |
Sebastian Huber |
smptests/smp05: Fix test name and output
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@b3613c3a
04/16/14 10:34:07 |
Sebastian Huber |
smptests/smpload01: Reduce timeout value
Use events instead of …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@c3cd7e7
04/09/14 13:26:17 |
Sebastian Huber |
smptests/smpschedule01: Rename in smpscheduler01
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
