@72e0bdb
10/10/16 12:50:19 |
Sebastian Huber |
score: Pass scheduler node to unblock operation
Changed for …
5
@e382a1b
10/10/16 12:33:17 |
Sebastian Huber |
score: Pass scheduler node to block operation
Changed for consistency …
5
@2df4abc
10/10/16 12:01:55 |
Sebastian Huber |
score: Pass scheduler node to yield operation
5
@501043a
09/30/16 12:38:04 |
Sebastian Huber |
score: Pass scheduler node to update priority op
This enables to call …
5
@7eec247
10/31/16 09:50:54 |
Sebastian Huber |
smptests/smplock01: Use test support
Convert output to XML.
5
@ed19002
10/12/16 08:37:07 |
Sebastian Huber |
smpschedaffinity05: Fix configuration
5
@f6142c19
09/09/16 09:00:06 |
Sebastian Huber |
score: Scheduler node awareness for thread queues
Maintain the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@6ae309ec
09/09/16 08:01:06 |
Sebastian Huber |
smptests/smpmutex01: Use test case functions
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@1c18ebf0
08/31/16 08:56:09 |
Chris Johns |
libmisc/capture: Remove the reserved _t in the types.
5
@6da06c5
08/30/16 06:46:25 |
Chris Johns |
libmisc/capture: Fix the capture engine on SMP.
This patches some …
5
@57a00bc6
07/05/16 09:30:14 |
Sebastian Huber |
smptests/smpmutex02: New test
Update #2765.
5
@6f6cf785
07/05/16 07:04:15 |
Sebastian Huber |
score: Postpone SMP shutdown in _Terminate()
This enables fatal …
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@4280dff7
06/30/16 09:01:05 |
Sebastian Huber |
smptests/smpstrongapa01: Simplify
5
@4fe0e97f
06/30/16 07:50:41 |
Sebastian Huber |
smptests/smpstrongapa01: Add test cases
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@ec5d95e1
06/23/16 08:31:04 |
Sebastian Huber |
smptests/smpmrsp01: Fix due to API changes
Commit …
5
@9bfad8c
06/08/16 20:22:46 |
Sebastian Huber |
score: Add thread priority to scheduler nodes
The thread priority is …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@6a631da
06/14/16 09:13:22 |
Sebastian Huber |
posix: sched_get_priority_max()
Enable for all configurations since …
5
@ea02782a
06/14/16 09:12:19 |
Sebastian Huber |
posix: sched_get_priority_min()
5
@05b7eec
06/08/16 13:18:14 |
Sebastian Huber |
score: Add an SMP sequence lock implementation
5
@4c19e59b
06/08/16 08:01:44 |
Sebastian Huber |
smptests/smpatomic01: Fix seqlock write
5
@cc8bb9e3
06/07/16 13:26:52 |
Sebastian Huber |
smptests/smpatomic01: Add seqlock test case
5
@a9cc6a84
06/01/16 07:50:44 |
Sebastian Huber |
smptests/smpatomic01: New test cases
Demonstrate that a …
5
@24d0ee57
05/20/16 08:39:50 |
Chris Johns |
cpukit, testsuite: Add rtems_printf and rtems_printer support.
This …
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@ceb0f659
05/17/16 14:03:46 |
Sebastian Huber |
score: Remove the Giant lock
Update #2555.
5
@4b04cb61
05/18/16 06:03:05 |
Sebastian Huber |
score: Rename _ISR_Disable_without_giant()
Rename …
5
@dab902d5
05/17/16 13:43:31 |
Sebastian Huber |
testsuites: Avoid Giant lock
Replace _Thread_Disable_dispatch() with …
5
@5eac9676
05/17/16 12:54:48 |
Sebastian Huber |
testsuites: Replace _Thread_Get()
Replace _Thread_Get() with …
5
@9949d8a7
05/12/16 14:32:27 |
Sebastian Huber |
score: Add Thread_Change_life()
Add _Thread_Change_life_locked() as a …
5
@41ce30a
05/18/16 12:34:26 |
Sebastian Huber |
SMP: Add Mellor-Crummey and Scott (MCS) lock
Added only for …
5
@1379d84
05/12/16 08:57:15 |
Sebastian Huber |
smptests/smpcapture02: Adjust for clock changes
Fix overall clock …
5
@bd12dda
05/11/16 09:54:49 |
Sebastian Huber |
score: Use thread state lock for current state
In addition protect …
5
@981eed2
04/29/16 10:09:32 |
Sebastian Huber |
score: Add dummy Strong APA scheduler
Start with a copy of the …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@b3a4c48e
02/17/16 13:27:09 |
Sebastian Huber |
score: Add _SMP_Online_processors
5
@eead8f7
03/02/16 14:28:29 |
Sebastian Huber |
smptests/smpmrsp01: Fix test context
5
@10f28914
02/17/16 10:33:27 |
Sebastian Huber |
smptests/smpwakeafter01: Add scheduler config
Update #2554.
5
@3d1becf
01/11/16 06:57:12 |
Sebastian Huber |
smptests/README: Delete obsolete information
5
@54406d9
10/15/15 09:56:15 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define accidentally …
5
@258ad71
09/25/15 12:34:24 |
Sebastian Huber |
SMP: Fix and optimize thread dispatching
According to the C11 and …
5
@8d296cd5
09/26/15 11:03:16 |
Sebastian Huber |
score: Use uintptr_t for atomic pointer operations
Do not obfuscate …
5
@dafa5d88
09/03/15 08:27:16 |
Sebastian Huber |
score: Implement priority boosting
5
@3995e6d
09/02/15 09:58:54 |
Sebastian Huber |
score: Implement SMP-specific priority queue
5
@43d7005
06/02/15 12:32:58 |
Sebastian Huber |
smptests/smpscheduler02: Reduce required CPU count
4.115
@2c14e67
06/02/15 12:22:03 |
Sebastian Huber |
smptests/smpmrsp01: Reduce required CPU count
4.115
@f48b73de
06/02/15 12:10:05 |
Sebastian Huber |
smptests/smpscheduler03: Use proper lock
4.115
@33e30f39
05/12/15 08:15:21 |
Sebastian Huber |
smptests/smpscheduler03: Restructure
Restructure to avoid large …
4.115
@900d337f
05/05/15 11:05:54 |
Sebastian Huber |
score: Rework _Thread_Change_priority()
Move the writes to …
4.115
@b1b5ddf0
05/15/15 11:17:16 |
Sebastian Huber |
smptests/smpcache01: Restructure
Restructure to avoid large maximum …
4.115
@be0366b
05/10/15 19:30:26 |
Sebastian Huber |
score: Fix scheduler helping protocol
Account for priority changes of …
4.115
@36413201
04/22/15 07:22:27 |
cederman |
smptests/smpcache01: Enable interrupts before waiting for other CPUs
4.115
@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
@e7e86ba
03/25/15 08:50:59 |
Sebastian Huber |
smpmigration01: Delete timing dependent assert
The cycles per runner …
4.115
@4f10ed6
03/24/15 12:42:08 |
Sebastian Huber |
smptests/smpfatal08: Workaround for QorIQ BSPs
4.115
@8c7eb00
03/17/15 09:32:20 |
Sebastian Huber |
testsupport: Add worker setup handler
Add …
4.115
@33b72fd
03/06/15 15:13:40 |
alexander.krutwig |
testsupport: Add cascade option to parallel test
4.115
@7f577d3
03/05/15 08:06:44 |
alexander.krutwig |
tests: Refactor parallel test execution
4.115
@c5436ff4
03/04/15 10:56:25 |
Sebastian Huber |
smptests/smpcapture01: Avoid livelock condition
4.115
@0324410
02/26/15 09:26:49 |
Sebastian Huber |
smptests: Do not use Giant directly
This ensures that thread …
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@8d8573ac
02/04/15 09:04:05 |
cederman |
smpcapture02: Add test of functionality to add custom entries to …
4.115
@77c5ddd4
01/14/15 06:34:44 |
Sebastian Huber |
smptests/smpmrsp01: Fix task delete race condition
Do not supsend …
4.115
@e7d175af
01/08/15 09:43:56 |
Sebastian Huber |
smptests/smpwakeafter01: Fix task count
4.115
@ad0743db
12/22/14 14:10:32 |
Sebastian Huber |
smptests/smpmrsp01: Update run indicator only once
On the Freescale …
4.115
@864d3475
12/17/14 14:11:00 |
Sebastian Huber |
smp: Fix timeout for MrsP semaphores
The previous timeout handling …
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@0ff1c29
11/27/14 07:45:10 |
Sebastian Huber |
smptests/smpmrsp01: Use busy waits
Use busy waits instead of sleeps …
4.115
@5bd822a7
11/26/14 10:51:34 |
Sebastian Huber |
smp: Fix scheduler helping protocol
Ensure that scheduler nodes in …
4.115
@39af57c3
11/24/14 20:49:28 |
Jennifer Averett |
smp09: Resolve missing prototype warning.
4.115
@6291e962
11/24/14 20:48:58 |
Jennifer Averett |
smp07: Resolve missing prototype warning.
4.115
@2c474a0
11/24/14 20:48:31 |
Jennifer Averett |
smp05: Resolve missing prototype warning.
4.115
@441dc1c
10/22/14 18:47:25 |
Jennifer Averett |
smp02: Resolve unused method warnings.
4.115
@4375b3b6
10/22/14 18:45:38 |
Jennifer Averett |
smp03: Remove set but not used warning.
Added status validation.
4.115
@689cba2
10/22/14 18:44:02 |
Jennifer Averett |
smpschedsem01: Remove unused variable warning.
4.115
@15e371f
10/22/14 13:42:59 |
Jennifer Averett |
smpschedaffinity02: Remove unused prototype.
4.115
@44da98f
10/24/14 19:37:24 |
Jennifer Averett |
smpcapture01: New test.
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
New test case for …
4.115
@db44590c
11/11/14 16:21:02 |
Jennifer Averett |
smpschedaffinity05: Change semaphore attributes.
Change semaphore …
4.115
@1960dcb9
11/12/14 14:42:13 |
Jennifer Averett |
smpschedaffinity04: Change semaphore attributes.
Change semaphore …
4.115
@bc95f816
11/12/14 14:42:48 |
Jennifer Averett |
smpschedaffinity02: Change semaphore attributes.
Change semaphore …
4.115
@d412e2f
10/24/14 07:18:38 |
Sebastian Huber |
smptests/smpfatal03: Wait for end of test msg
4.115
@092b8c5
10/24/14 05:21:51 |
Sebastian Huber |
tests/smptests: Normal use of test extension
4.115
@17889b2
10/23/14 15:15:47 |
Sebastian Huber |
tests/smptests: Use barriers in smpfatal0{12}
Call the test extension …
4.115
@8f0a2c9
09/17/14 08:28:13 |
Sebastian Huber |
smptests/smpload01: Report profiling only once
Rely on test extension …
4.115
@6e1206a
09/11/14 15:55:34 |
cederman |
smptests/smpcache01: Remove invalidation of data cache lines from test …
4.115
@5689d72
09/01/14 14:12:42 |
Sebastian Huber |
smptests/smplock01: Update screen file
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@c147a139
09/01/14 06:45:23 |
Sebastian Huber |
smptests/smpfatal08: Fix link error
4.115
@9a9ab85
07/03/14 14:42:24 |
cederman |
smptests/smpcache01: Test the SMP cache manager
Invokes SMP cache …
4.115
@247118bf
07/10/14 16:55:04 |
Jennifer Averett |
smpschedsem01: new test.
This test verifies priority is inherited …
4.115
@7eb3fd47
07/10/14 16:45:58 |
Jennifer Averett |
smpschedaffinity05: Add test for worst case migration for affintiy …
4.115
@61d26f93
07/10/14 16:36:40 |
Jennifer Averett |
smpschedaffinity04: New test.
This test walks a secondary high …
4.115
@28d66749
07/10/14 16:18:02 |
Jennifer Averett |
smpschedaffinity03: New test.
This task walks the affinity of self …
4.115
