@6e1206a
09/11/14 15:55:34 |
cederman |
smptests/smpcache01: Remove invalidation of data cache lines from test …
4.115
@5689d72
09/01/14 14:12:42 |
Sebastian Huber |
smptests/smplock01: Update screen file
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@c147a139
09/01/14 06:45:23 |
Sebastian Huber |
smptests/smpfatal08: Fix link error
4.115
@9a9ab85
07/03/14 14:42:24 |
cederman |
smptests/smpcache01: Test the SMP cache manager
Invokes SMP cache …
4.115
@247118bf
07/10/14 16:55:04 |
Jennifer Averett |
smpschedsem01: new test.
This test verifies priority is inherited …
4.115
@7eb3fd47
07/10/14 16:45:58 |
Jennifer Averett |
smpschedaffinity05: Add test for worst case migration for affintiy …
4.115
@61d26f93
07/10/14 16:36:40 |
Jennifer Averett |
smpschedaffinity04: New test.
This test walks a secondary high …
4.115
@28d66749
07/10/14 16:18:02 |
Jennifer Averett |
smpschedaffinity03: New test.
This task walks the affinity of self …
4.115
@09293069
07/10/14 15:19:06 |
Jennifer Averett |
smpschedaffinity02: New test.
This test checks setting the affinity …
4.115
@d88b0e7f
05/22/14 14:00:14 |
Jennifer Averett |
smpschedaffinity01: New test.
This test verifies that affinity is …
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@9f228bea
06/24/14 08:00:06 |
Sebastian Huber |
smptests/smpmrsp01: Add and update test cases
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@0b4ec4d
06/30/14 10:30:12 |
Sebastian Huber |
smptests/smpfatal08: Support RTEMS_PARAVIRT
4.115
@b42e148
06/24/14 07:53:11 |
Sebastian Huber |
smptests/smpmigration02: PR2183: Add test case
4.115
@a92989a
06/18/14 13:16:02 |
Sebastian Huber |
score: Fix thread deletion on SMP
Close the thread object in …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@bd56356b
06/18/14 08:54:04 |
Sebastian Huber |
smptests/smpwakeafter01: New test
4.115
@11947299
06/13/14 14:06:20 |
Sebastian Huber |
smptests: Avoid use of uninitialized data
4.115
@4962d24d
06/11/14 14:34:51 |
Sebastian Huber |
smptests/smpscheduler03: Test all SMP schedulers
4.115
@2a2a1695
06/10/14 09:42:19 |
Sebastian Huber |
smptest/smpfatal03: Update due to API changes
4.115
@5abe5a8
06/02/14 14:15:15 |
Christian.Mauderer |
smptests/smpthreadlife01: Fix for debug enabled
4.115
@1ee0d5f
06/02/14 14:15:14 |
smptests/smpmrsp01: Fix scheduler ids
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@23b9d095
05/07/14 16:32:15 |
Sebastian Huber |
smptests/smp07: Fix test output
4.115
@8fa3422
05/07/14 16:30:36 |
Sebastian Huber |
smptests/smp05: Fix test name and output
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@b3613c3a
04/16/14 10:34:07 |
Sebastian Huber |
smptests/smpload01: Reduce timeout value
Use events instead of …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@c3cd7e7
04/09/14 13:26:17 |
Sebastian Huber |
smptests/smpschedule01: Rename in smpscheduler01
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@af53e6cf
03/18/14 17:44:32 |
Jennifer Averett |
smpaffinity01: Use Priority Affinity SMP scheduler.
4.115
@d4e1ead
03/18/14 17:43:55 |
Jennifer Averett |
smppsxaffinity01: Use Priority Affinity SMP scheduler.
4.115
@cb283959
03/18/14 17:43:35 |
Jennifer Averett |
smppsxaffinity02: Use Priority Affinity SMP scheduler.
4.115
@57db5f1
04/01/14 06:40:23 |
Sebastian Huber |
smptests/smpthreadlife01: Avoid bad profiling stat
4.115
@b9b014e
03/31/14 13:49:35 |
Sebastian Huber |
smptests/smpthreadlife01: Typo
4.115
@a881ff2
03/31/14 13:45:01 |
Sebastian Huber |
smptests/smpthreadlife01: Add test cases
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@5c731a83
03/17/14 09:12:14 |
Sebastian Huber |
score: Use thread action for thread restart
The thread restart is now …
4.115
@2c83ac3
03/28/14 10:47:42 |
Sebastian Huber |
smptests/smpfatal03: Fix end of test output
4.115
@9486566
03/21/14 08:53:15 |
Sebastian Huber |
smptests/smpload01: Improve test
Add a task producing memory traffic. …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@65c0166
03/17/14 12:20:37 |
Sebastian Huber |
smptests/smpload01: Use test extension
4.115
@ad48ebb
03/17/14 07:10:19 |
Sebastian Huber |
tests/smptests: Use <rtems/test.h>
4.115
@4575ae0
03/10/14 12:39:31 |
Sebastian Huber |
smptests/smpload01: New test
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@909f61b
03/10/14 12:27:42 |
Sebastian Huber |
smptests/smppsxaffinity02: Fix end of test message
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@2ef0328
02/26/14 15:57:16 |
Jennifer Averett |
smptests: Add smppsxaffinity02.
This method exercises the ability to …
4.115
@f3e6b18
02/26/14 15:41:04 |
Jennifer Averett |
smptests: Add smppsxaffinity01.
This test exercises the ability to …
4.115
@a3e055f
02/10/14 18:31:59 |
Jennifer Averett |
smptests: Add smpaffinity01
This test exercises the new Classic API …
4.115
@e5bcb24b
02/19/14 09:58:47 |
Sebastian Huber |
smptests: Delete config.h.in
4.115
@8b50a55
03/03/14 08:09:24 |
Sebastian Huber |
score: Add _Atomic_Fence()
4.115
@ba25cc2
02/19/14 10:21:34 |
Sebastian Huber |
score: Add and use _Giant_Drop()
New test smptests/smpfatal03.
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@2729c1c2
02/17/14 18:19:06 |
Jennifer Averett |
smptests: Add check for affinity support in newlib.
4.115
@ad7292f
02/14/14 11:57:53 |
Sebastian Huber |
score: Add SMP barrier
4.115
@7d066fc
02/13/14 14:39:18 |
Sebastian Huber |
smptests/smplock01: Use atomic operations
4.115
@8a9568d2
02/14/14 10:18:13 |
Sebastian Huber |
Require presence of <stdatomic.h> for SMP support
4.115
@945853b7
02/13/14 14:38:52 |
Sebastian Huber |
score: Add Atomic_Uint
4.115
@7eb6444d
11/11/13 09:25:28 |
Sebastian Huber |
smptests/smp06: Delete test
This test referred to the first version …
4.115
@33e18a4
09/28/13 06:54:38 |
wei.a.yang |
rename smpatomic08 to smpatomic01
4.115
@27a034ef
09/28/13 06:54:37 |
wei.a.yang |
delete smpatomic0-7 test cases
4.115
@fee154be
09/28/13 06:54:36 |
wei.a.yang |
add simple atomic test cases into smpatomic08
4.115
@4a8c334
09/03/13 09:06:46 |
Sebastian Huber |
smptests/smpatomic08: Add initialization test case
4.115
@29f7d317
09/02/13 13:08:05 |
Sebastian Huber |
score: Use unsigned long for atomic integers
Use unsigned long …
4.115
@47b6fad
09/01/13 13:14:07 |
Sebastian Huber |
smptests/smpatomic08: Avoid copy and paste
4.115
@7136d7f
09/01/13 13:01:42 |
Sebastian Huber |
smptests/smpatomic08: Simplify or/and test case
Renamed and use …
4.115
@d39ccd69
09/01/13 12:34:31 |
Sebastian Huber |
smptests/smpatomic08: Fix compare and exchange
4.115
@4238aff
09/01/13 10:28:35 |
wei.a.yang |
add atomic sub, and, or, compare_exchange test cases into smpatomic08
4.115
@e127c4c
08/29/13 08:03:38 |
Sebastian Huber |
smptests/smpatomic08: Fix race conditions
4.115
@79d03e3
08/28/13 12:52:43 |
Sebastian Huber |
smptests/smpatomic08: New test
4.115
@2bbcb64
08/27/13 12:26:33 |
Sebastian Huber |
smptests: Move ATOMIC conditional to top-level
4.115
@518d82b
08/20/13 09:01:55 |
Sebastian Huber |
smp: Disable restart of threads other than self
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@aea4a91
08/08/13 09:49:15 |
Sebastian Huber |
smp: Optimize Simple SMP scheduler
Add Thread_Control::is_in_the_air …
4.115
@6931037
08/04/13 18:56:00 |
wei.a.yang |
correct memory model in smpatomic test case
4.115
@806f84c8
08/08/13 14:34:19 |
Sebastian Huber |
smptests/smpswitchextension01: Fix start sequence
Start the toggler …
4.115
@d19cce29
08/05/13 12:54:11 |
Sebastian Huber |
score: Per-CPU thread dispatch disable level
Use a per-CPU thread …
4.115
@c8670f5
08/08/13 08:57:58 |
Sebastian Huber |
smptests/smpmigration01: Fix start sequence
Start the runner after …
4.115
@015bd1b
08/06/13 08:47:38 |
Sebastian Huber |
smptests/smp07: Use suspend instead of delete
4.115
@20bb89d
08/02/13 09:22:16 |
Sebastian Huber |
smptests/smpswitchextension01: New test
4.115
@b9000fd5
08/02/13 09:37:28 |
Sebastian Huber |
smptests/smpmigration01: New test
4.115
@876dcd02
07/29/13 11:48:18 |
Sebastian Huber |
smptests/smppsxsignal01: New test
4.115
@d4f13d1
07/29/13 08:46:28 |
Sebastian Huber |
smptests/smpsignal01: New test
4.115
