@4962d24d
06/11/14 14:34:51 |
Sebastian Huber |
smptests/smpscheduler03: Test all SMP schedulers
4.115
@2a2a1695
06/10/14 09:42:19 |
Sebastian Huber |
smptest/smpfatal03: Update due to API changes
4.115
@5abe5a8
06/02/14 14:15:15 |
Christian.Mauderer |
smptests/smpthreadlife01: Fix for debug enabled
4.115
@1ee0d5f
06/02/14 14:15:14 |
smptests/smpmrsp01: Fix scheduler ids
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@23b9d095
05/07/14 16:32:15 |
Sebastian Huber |
smptests/smp07: Fix test output
4.115
@8fa3422
05/07/14 16:30:36 |
Sebastian Huber |
smptests/smp05: Fix test name and output
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@b3613c3a
04/16/14 10:34:07 |
Sebastian Huber |
smptests/smpload01: Reduce timeout value
Use events instead of …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@c3cd7e7
04/09/14 13:26:17 |
Sebastian Huber |
smptests/smpschedule01: Rename in smpscheduler01
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@af53e6cf
03/18/14 17:44:32 |
Jennifer Averett |
smpaffinity01: Use Priority Affinity SMP scheduler.
4.115
@d4e1ead
03/18/14 17:43:55 |
Jennifer Averett |
smppsxaffinity01: Use Priority Affinity SMP scheduler.
4.115
@cb283959
03/18/14 17:43:35 |
Jennifer Averett |
smppsxaffinity02: Use Priority Affinity SMP scheduler.
4.115
@57db5f1
04/01/14 06:40:23 |
Sebastian Huber |
smptests/smpthreadlife01: Avoid bad profiling stat
4.115
@b9b014e
03/31/14 13:49:35 |
Sebastian Huber |
smptests/smpthreadlife01: Typo
4.115
@a881ff2
03/31/14 13:45:01 |
Sebastian Huber |
smptests/smpthreadlife01: Add test cases
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@5c731a83
03/17/14 09:12:14 |
Sebastian Huber |
score: Use thread action for thread restart
The thread restart is now …
4.115
@2c83ac3
03/28/14 10:47:42 |
Sebastian Huber |
smptests/smpfatal03: Fix end of test output
4.115
@9486566
03/21/14 08:53:15 |
Sebastian Huber |
smptests/smpload01: Improve test
Add a task producing memory traffic. …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@65c0166
03/17/14 12:20:37 |
Sebastian Huber |
smptests/smpload01: Use test extension
4.115
@ad48ebb
03/17/14 07:10:19 |
Sebastian Huber |
tests/smptests: Use <rtems/test.h>
4.115
@4575ae0
03/10/14 12:39:31 |
Sebastian Huber |
smptests/smpload01: New test
4.115
@53ad908
03/07/14 13:36:22 |
Sebastian Huber |
score: Add SMP lock profiling support
4.115
@28779c7
03/07/14 11:53:41 |
Sebastian Huber |
score: Add function to destroy SMP locks
4.115
@d50acdbb
03/10/14 07:25:32 |
Sebastian Huber |
score: Add local context to SMP lock API
Add a local context …
4.115
@909f61b
03/10/14 12:27:42 |
Sebastian Huber |
smptests/smppsxaffinity02: Fix end of test message
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@2ef0328
02/26/14 15:57:16 |
Jennifer Averett |
smptests: Add smppsxaffinity02.
This method exercises the ability to …
4.115
@f3e6b18
02/26/14 15:41:04 |
Jennifer Averett |
smptests: Add smppsxaffinity01.
This test exercises the ability to …
4.115
@a3e055f
02/10/14 18:31:59 |
Jennifer Averett |
smptests: Add smpaffinity01
This test exercises the new Classic API …
4.115
@e5bcb24b
02/19/14 09:58:47 |
Sebastian Huber |
smptests: Delete config.h.in
4.115
@8b50a55
03/03/14 08:09:24 |
Sebastian Huber |
score: Add _Atomic_Fence()
4.115
@ba25cc2
02/19/14 10:21:34 |
Sebastian Huber |
score: Add and use _Giant_Drop()
New test smptests/smpfatal03.
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@2729c1c2
02/17/14 18:19:06 |
Jennifer Averett |
smptests: Add check for affinity support in newlib.
4.115
@ad7292f
02/14/14 11:57:53 |
Sebastian Huber |
score: Add SMP barrier
4.115
@7d066fc
02/13/14 14:39:18 |
Sebastian Huber |
smptests/smplock01: Use atomic operations
4.115
@8a9568d2
02/14/14 10:18:13 |
Sebastian Huber |
Require presence of <stdatomic.h> for SMP support
4.115
@945853b7
02/13/14 14:38:52 |
Sebastian Huber |
score: Add Atomic_Uint
4.115
@7eb6444d
11/11/13 09:25:28 |
Sebastian Huber |
smptests/smp06: Delete test
This test referred to the first version …
4.115
@33e18a4
09/28/13 06:54:38 |
wei.a.yang |
rename smpatomic08 to smpatomic01
4.115
@27a034ef
09/28/13 06:54:37 |
wei.a.yang |
delete smpatomic0-7 test cases
4.115
@fee154be
09/28/13 06:54:36 |
wei.a.yang |
add simple atomic test cases into smpatomic08
4.115
@4a8c334
09/03/13 09:06:46 |
Sebastian Huber |
smptests/smpatomic08: Add initialization test case
4.115
@29f7d317
09/02/13 13:08:05 |
Sebastian Huber |
score: Use unsigned long for atomic integers
Use unsigned long …
4.115
@47b6fad
09/01/13 13:14:07 |
Sebastian Huber |
smptests/smpatomic08: Avoid copy and paste
4.115
@7136d7f
09/01/13 13:01:42 |
Sebastian Huber |
smptests/smpatomic08: Simplify or/and test case
Renamed and use …
4.115
@d39ccd69
09/01/13 12:34:31 |
Sebastian Huber |
smptests/smpatomic08: Fix compare and exchange
4.115
@4238aff
09/01/13 10:28:35 |
wei.a.yang |
add atomic sub, and, or, compare_exchange test cases into smpatomic08
4.115
@e127c4c
08/29/13 08:03:38 |
Sebastian Huber |
smptests/smpatomic08: Fix race conditions
4.115
@79d03e3
08/28/13 12:52:43 |
Sebastian Huber |
smptests/smpatomic08: New test
4.115
@2bbcb64
08/27/13 12:26:33 |
Sebastian Huber |
smptests: Move ATOMIC conditional to top-level
4.115
@518d82b
08/20/13 09:01:55 |
Sebastian Huber |
smp: Disable restart of threads other than self
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@aea4a91
08/08/13 09:49:15 |
Sebastian Huber |
smp: Optimize Simple SMP scheduler
Add Thread_Control::is_in_the_air …
4.115
@6931037
08/04/13 18:56:00 |
wei.a.yang |
correct memory model in smpatomic test case
4.115
@806f84c8
08/08/13 14:34:19 |
Sebastian Huber |
smptests/smpswitchextension01: Fix start sequence
Start the toggler …
4.115
@d19cce29
08/05/13 12:54:11 |
Sebastian Huber |
score: Per-CPU thread dispatch disable level
Use a per-CPU thread …
4.115
@c8670f5
08/08/13 08:57:58 |
Sebastian Huber |
smptests/smpmigration01: Fix start sequence
Start the runner after …
4.115
@015bd1b
08/06/13 08:47:38 |
Sebastian Huber |
smptests/smp07: Use suspend instead of delete
4.115
@20bb89d
08/02/13 09:22:16 |
Sebastian Huber |
smptests/smpswitchextension01: New test
4.115
@b9000fd5
08/02/13 09:37:28 |
Sebastian Huber |
smptests/smpmigration01: New test
4.115
@876dcd02
07/29/13 11:48:18 |
Sebastian Huber |
smptests/smppsxsignal01: New test
4.115
@d4f13d1
07/29/13 08:46:28 |
Sebastian Huber |
smptests/smpsignal01: New test
4.115
@fe52e7c0
07/26/13 12:10:25 |
Sebastian Huber |
smp: Add and use _Per_CPU_Get()
Add and use _Per_CPU_Get_by_index() …
4.115
@d8dd80e
07/19/13 12:02:47 |
Sebastian Huber |
smptests/smp08: Print missing newline
4.115
@05e82bd7
07/18/13 09:53:48 |
Sebastian Huber |
score: Error for non-preemptible tasks on SMP
A common use case for …
4.115
@79d9523
07/18/13 09:39:44 |
Sebastian Huber |
rtems: Error for task variables on SMP
Task variables are not …
4.115
@50ccf98
07/18/13 09:34:29 |
Sebastian Huber |
rtems: Error for task delete on SMP
Task deletion is currently not …
4.115
@f913c79
07/18/13 09:27:39 |
Sebastian Huber |
sapi: Add rtems_configuration_is_smp_enabled()
Add a configuration …
4.115
@57c88056
07/19/13 08:12:13 |
Sebastian Huber |
smptests: Be successful on one processor
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@2e7f5798
07/15/13 15:31:13 |
wei.a.yang |
stdatomic.h support check when configure
4.115
@5186b55
07/15/13 15:31:12 |
wei.a.yang |
smpatomic test case update
4.115
@010e4058
06/17/13 08:21:48 |
Sebastian Huber |
smptests/smpschedule01: Update due to API change
4.115
@8b222be
06/11/13 08:00:25 |
Sebastian Huber |
smptests/smpschedule01: New test
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@bbed1866
05/29/13 08:41:18 |
Sebastian Huber |
smptests/smplock01: New test
4.115
@ac2bb464
05/31/13 11:56:56 |
Sebastian Huber |
smptests: Use priority ceiling for locked print
In case the printf() …
4.115
@10fd9533
05/24/13 08:03:40 |
Sebastian Huber |
smptests/smp09: Add missing newline
4.115
@b734b9e8
05/21/13 14:42:12 |
Sebastian Huber |
smptests/smp01: Do not assume CPU 0 runs Init
4.115
@db0cede1
01/18/13 08:42:00 |
Sebastian Huber |
smptests/smp01: Fix semaphore count
The locked print needs one semaphore.
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@7e02305
01/25/13 16:01:17 |
wei.a.yang |
tests: atomic support for RTEMS. SMP tests for atomic operations.
4.115
@9d23df2
01/25/13 15:53:52 |
wei.a.yang |
score: atomic support for RTEMS automake and autoconf changes
4.115
