# # ChangeLog for testsuites/samples/unlimited/unlimited.scn in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/22 21:07:51 Wed, 17 Mar 1999 16:01:03 GMT Joel Sherrill [f4a8ee1] * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/src/object.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (added) * c/src/tests/samples/unlimited/init.c (added) * c/src/tests/samples/unlimited/system.h (added) * c/src/tests/samples/unlimited/test1.c (added) * c/src/tests/samples/unlimited/test2.c (added) * c/src/tests/samples/unlimited/test3.c (added) * c/src/tests/samples/unlimited/unlimited.doc (added) * c/src/tests/samples/unlimited/unlimited.scn (added) * cpukit/rtems/src/msg.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/src/object.c (modified) * make/compilers/gcc-target-default.cfg (modified) * testsuites/samples/unlimited/init.c (added) * testsuites/samples/unlimited/system.h (added) * testsuites/samples/unlimited/test1.c (added) * testsuites/samples/unlimited/test2.c (added) * testsuites/samples/unlimited/test3.c (added) * testsuites/samples/unlimited/unlimited.doc (added) * testsuites/samples/unlimited/unlimited.scn (added) Unlimited objects patch from Chris Johns . Email ...
