# # ChangeLog for testsuites/samples/paranoia/system.h in rtems # # Generated by Trac 1.2.1.dev0 # 06/05/24 10:58:47 Wed, 29 May 1996 22:48:26 GMT Joel Sherrill [be1c11ed] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) tests now specify whether using posix initialization threads table ... Fri, 19 Jan 1996 22:21:46 GMT Joel Sherrill [709b93d] * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp16/init.c (modified) Increased stack size. Mon, 15 Jan 1996 23:07:00 GMT Joel Sherrill [b817240c] * c/src/tests/samples/paranoia/system.h (modified) * testsuites/samples/paranoia/system.h (modified) Init task was not defined as being floating point. Mon, 11 Sep 1995 19:35:39 GMT Joel Sherrill [3a4ae6c] * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/src/error.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/clock.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/mp.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/rtemsapi.h (added) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (added) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/macros/asr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/status.inl (modified) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/directives.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/directives.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/rtemsapi.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/asm.h (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i960/asm.h (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/no_cpu/asm.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/coremutex.h (added) * c/src/exec/score/headers/coresem.h (added) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/interr.h (added) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/threadq.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (added) * c/src/exec/score/include/rtems/score/coresem.h (added) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (added) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/coremutex.inl (added) * c/src/exec/score/inline/coresem.inl (added) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (added) * c/src/exec/score/inline/rtems/score/coresem.inl (added) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/address.inl (modified) * c/src/exec/score/macros/coremutex.inl (added) * c/src/exec/score/macros/coresem.inl (added) * c/src/exec/score/macros/heap.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (added) * c/src/exec/score/macros/rtems/score/coresem.inl (added) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/stack.inl (modified) * c/src/exec/score/macros/states.inl (modified) * c/src/exec/score/macros/sysstate.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremutex.c (added) * c/src/exec/score/src/coresem.c (added) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/interr.c (added) * c/src/exec/score/src/isr.c (added) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/tod.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/lib/include/console.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/go32/console/console.c (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/unix/posix/console/console.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/support.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/monitor/mon-dname.c (modified) * c/src/lib/libmisc/monitor/mon-extension.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-server.c (modified) * c/src/lib/libmisc/monitor/mon-task.c (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/internal.h (modified) * c/src/lib/start/i960/start.s (modified) * c/src/lib/start/m68k/start.s (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/monitor/mon-dname.c (modified) * c/src/libmisc/monitor/mon-extension.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/monitor/mon-task.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (added) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/sp12.scn (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libmisc/monitor/mon-dname.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (added) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/rtemsapi.c (added) * cpukit/score/cpu/hppa1.1/cpu.c (modified) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) * cpukit/score/cpu/i960/asm.h (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/coremutex.h (added) * cpukit/score/include/rtems/score/coresem.h (added) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (added) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (added) * cpukit/score/inline/rtems/score/coresem.inl (added) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (added) * cpukit/score/macros/rtems/score/coresem.inl (added) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremutex.c (added) * cpukit/score/src/coresem.c (added) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (added) * cpukit/score/src/isr.c (added) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (added) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/sp12.scn (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) The word "RTEMS" almost completely removed from the core. ... Wed, 23 Aug 1995 19:30:23 GMT Joel Sherrill [3235ad9] * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/support.h (added) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (added) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (added) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (added) * c/src/exec/rtems/inline/rtems/rtems/support.inl (added) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/support.inl (added) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (added) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/support.inl (added) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (added) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (added) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libcpu/powerpc/README (added) * c/src/lib/libcpu/powerpc/ppc403/README (added) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (added) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (added) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/README (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/vectors.s (added) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (added) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (added) * cpukit/rtems/inline/rtems/rtems/support.inl (added) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (added) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/system.h (modified) Support for variable length names added to Object Handler. This ... Thu, 17 Aug 1995 19:36:43 GMT Joel Sherrill [4b374f36] * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.scn (modified) * c/src/tests/mptests/mp09/node2/mp09.scn (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/sp09.scn (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.scn (modified) * testsuites/mptests/mp09/node2/mp09.scn (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/system.h (modified) maximum number of messages removed and include statement cleanup Thu, 11 May 1995 17:39:37 GMT Joel Sherrill [ac7d5ef0] * INSTALL (added) * LICENSE (added) * README (added) * SUPPORT (added) * c/ACKNOWLEDGEMENTS (added) * c/PROBLEMS (added) * c/README (added) * c/REQUIRES (added) * c/UPDATE_HELP (added) * c/build-tools/README (added) * c/build-tools/cklength.c (added) * c/build-tools/eolstrip.c (added) * c/build-tools/packhex.c (added) * c/build-tools/scripts/README (added) * c/build-tools/src/cklength.c (added) * c/build-tools/src/eolstrip.c (added) * c/build-tools/src/packhex.c (added) * c/build-tools/src/unhex.c (added) * c/build-tools/unhex.c (added) * c/src/README (added) * c/src/exec/libcsupport/include/clockdrv.h (added) * c/src/exec/libcsupport/include/console.h (added) * c/src/exec/libcsupport/include/iosupp.h (added) * c/src/exec/libcsupport/include/rtems/libcsupport.h (added) * c/src/exec/libcsupport/include/spurious.h (added) * c/src/exec/libcsupport/include/timerdrv.h (added) * c/src/exec/libcsupport/include/vmeintr.h (added) * c/src/exec/libcsupport/src/README (added) * c/src/exec/libcsupport/src/__brk.c (added) * c/src/exec/libcsupport/src/__gettod.c (added) * c/src/exec/libcsupport/src/__times.c (added) * c/src/exec/libcsupport/src/malloc.c (added) * c/src/exec/libcsupport/src/newlibc.c (added) * c/src/exec/libcsupport/src/no_libc.c (added) * c/src/exec/libcsupport/src/unixlibc.c (added) * c/src/exec/rtems/headers/asr.h (added) * c/src/exec/rtems/headers/attr.h (added) * c/src/exec/rtems/headers/clock.h (added) * c/src/exec/rtems/headers/dpmem.h (added) * c/src/exec/rtems/headers/event.h (added) * c/src/exec/rtems/headers/eventmp.h (added) * c/src/exec/rtems/headers/eventset.h (added) * c/src/exec/rtems/headers/intr.h (added) * c/src/exec/rtems/headers/message.h (added) * c/src/exec/rtems/headers/modes.h (added) * c/src/exec/rtems/headers/mp.h (added) * c/src/exec/rtems/headers/msgmp.h (added) * c/src/exec/rtems/headers/options.h (added) * c/src/exec/rtems/headers/part.h (added) * c/src/exec/rtems/headers/partmp.h (added) * c/src/exec/rtems/headers/ratemon.h (added) * c/src/exec/rtems/headers/region.h (added) * c/src/exec/rtems/headers/regionmp.h (added) * c/src/exec/rtems/headers/rtems.h (added) * c/src/exec/rtems/headers/sem.h (added) * c/src/exec/rtems/headers/semmp.h (added) * c/src/exec/rtems/headers/signal.h (added) * c/src/exec/rtems/headers/signalmp.h (added) * c/src/exec/rtems/headers/status.h (added) * c/src/exec/rtems/headers/taskmp.h (added) * c/src/exec/rtems/headers/tasks.h (added) * c/src/exec/rtems/headers/timer.h (added) * c/src/exec/rtems/include/rtems.h (added) * c/src/exec/rtems/include/rtems/rtems/asr.h (added) * c/src/exec/rtems/include/rtems/rtems/attr.h (added) * c/src/exec/rtems/include/rtems/rtems/clock.h (added) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (added) * c/src/exec/rtems/include/rtems/rtems/event.h (added) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (added) * c/src/exec/rtems/include/rtems/rtems/eventset.h (added) * c/src/exec/rtems/include/rtems/rtems/intr.h (added) * c/src/exec/rtems/include/rtems/rtems/message.h (added) * c/src/exec/rtems/include/rtems/rtems/modes.h (added) * c/src/exec/rtems/include/rtems/rtems/mp.h (added) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (added) * c/src/exec/rtems/include/rtems/rtems/options.h (added) * c/src/exec/rtems/include/rtems/rtems/part.h (added) * c/src/exec/rtems/include/rtems/rtems/partmp.h (added) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (added) * c/src/exec/rtems/include/rtems/rtems/region.h (added) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (added) * c/src/exec/rtems/include/rtems/rtems/sem.h (added) * c/src/exec/rtems/include/rtems/rtems/semmp.h (added) * c/src/exec/rtems/include/rtems/rtems/signal.h (added) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (added) * c/src/exec/rtems/include/rtems/rtems/status.h (added) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (added) * c/src/exec/rtems/include/rtems/rtems/tasks.h (added) * c/src/exec/rtems/include/rtems/rtems/timer.h (added) * c/src/exec/rtems/inline/asr.inl (added) * c/src/exec/rtems/inline/attr.inl (added) * c/src/exec/rtems/inline/dpmem.inl (added) * c/src/exec/rtems/inline/event.inl (added) * c/src/exec/rtems/inline/eventset.inl (added) * c/src/exec/rtems/inline/message.inl (added) * c/src/exec/rtems/inline/modes.inl (added) * c/src/exec/rtems/inline/options.inl (added) * c/src/exec/rtems/inline/part.inl (added) * c/src/exec/rtems/inline/ratemon.inl (added) * c/src/exec/rtems/inline/region.inl (added) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (added) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (added) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (added) * c/src/exec/rtems/inline/rtems/rtems/event.inl (added) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (added) * c/src/exec/rtems/inline/rtems/rtems/message.inl (added) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (added) * c/src/exec/rtems/inline/rtems/rtems/options.inl (added) * c/src/exec/rtems/inline/rtems/rtems/part.inl (added) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (added) * c/src/exec/rtems/inline/rtems/rtems/region.inl (added) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (added) * c/src/exec/rtems/inline/rtems/rtems/status.inl (added) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (added) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (added) * c/src/exec/rtems/inline/sem.inl (added) * c/src/exec/rtems/inline/status.inl (added) * c/src/exec/rtems/inline/tasks.inl (added) * c/src/exec/rtems/inline/timer.inl (added) * c/src/exec/rtems/macros/asr.inl (added) * c/src/exec/rtems/macros/attr.inl (added) * c/src/exec/rtems/macros/dpmem.inl (added) * c/src/exec/rtems/macros/event.inl (added) * c/src/exec/rtems/macros/eventset.inl (added) * c/src/exec/rtems/macros/message.inl (added) * c/src/exec/rtems/macros/modes.inl (added) * c/src/exec/rtems/macros/options.inl (added) * c/src/exec/rtems/macros/part.inl (added) * c/src/exec/rtems/macros/ratemon.inl (added) * c/src/exec/rtems/macros/region.inl (added) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (added) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (added) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (added) * c/src/exec/rtems/macros/rtems/rtems/event.inl (added) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (added) * c/src/exec/rtems/macros/rtems/rtems/message.inl (added) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (added) * c/src/exec/rtems/macros/rtems/rtems/options.inl (added) * c/src/exec/rtems/macros/rtems/rtems/part.inl (added) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (added) * c/src/exec/rtems/macros/rtems/rtems/region.inl (added) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (added) * c/src/exec/rtems/macros/rtems/rtems/status.inl (added) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (added) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (added) * c/src/exec/rtems/macros/sem.inl (added) * c/src/exec/rtems/macros/status.inl (added) * c/src/exec/rtems/macros/tasks.inl (added) * c/src/exec/rtems/macros/timer.inl (added) * c/src/exec/rtems/optman/no-dpmem.c (added) * c/src/exec/rtems/optman/no-event.c (added) * c/src/exec/rtems/optman/no-mp.c (added) * c/src/exec/rtems/optman/no-msg.c (added) * c/src/exec/rtems/optman/no-part.c (added) * c/src/exec/rtems/optman/no-region.c (added) * c/src/exec/rtems/optman/no-rtmon.c (added) * c/src/exec/rtems/optman/no-sem.c (added) * c/src/exec/rtems/optman/no-signal.c (added) * c/src/exec/rtems/optman/no-timer.c (added) * c/src/exec/rtems/src/clock.c (added) * c/src/exec/rtems/src/dpmem.c (added) * c/src/exec/rtems/src/event.c (added) * c/src/exec/rtems/src/eventmp.c (added) * c/src/exec/rtems/src/intr.c (added) * c/src/exec/rtems/src/mp.c (added) * c/src/exec/rtems/src/msg.c (added) * c/src/exec/rtems/src/msgmp.c (added) * c/src/exec/rtems/src/part.c (added) * c/src/exec/rtems/src/partmp.c (added) * c/src/exec/rtems/src/ratemon.c (added) * c/src/exec/rtems/src/region.c (added) * c/src/exec/rtems/src/regionmp.c (added) * c/src/exec/rtems/src/rtclock.c (added) * c/src/exec/rtems/src/rtemstimer.c (added) * c/src/exec/rtems/src/sem.c (added) * c/src/exec/rtems/src/semmp.c (added) * c/src/exec/rtems/src/signal.c (added) * c/src/exec/rtems/src/signalmp.c (added) * c/src/exec/rtems/src/taskmp.c (added) * c/src/exec/rtems/src/tasks.c (added) * c/src/exec/rtems/src/timer.c (added) * c/src/exec/sapi/headers/config.h (added) * c/src/exec/sapi/headers/directives.h (added) * c/src/exec/sapi/headers/extension.h (added) * c/src/exec/sapi/headers/fatal.h (added) * c/src/exec/sapi/headers/init.h (added) * c/src/exec/sapi/headers/io.h (added) * c/src/exec/sapi/headers/mptables.h (added) * c/src/exec/sapi/headers/sptables.h (added) * c/src/exec/sapi/include/rtems/config.h (added) * c/src/exec/sapi/include/rtems/directives.h (added) * c/src/exec/sapi/include/rtems/extension.h (added) * c/src/exec/sapi/include/rtems/fatal.h (added) * c/src/exec/sapi/include/rtems/init.h (added) * c/src/exec/sapi/include/rtems/io.h (added) * c/src/exec/sapi/include/rtems/mptables.h (added) * c/src/exec/sapi/include/rtems/sptables.h (added) * c/src/exec/sapi/inline/extension.inl (added) * c/src/exec/sapi/inline/rtems/extension.inl (added) * c/src/exec/sapi/macros/extension.inl (added) * c/src/exec/sapi/macros/rtems/extension.inl (added) * c/src/exec/sapi/optman/no-ext.c (added) * c/src/exec/sapi/optman/no-io.c (added) * c/src/exec/sapi/src/debug.c (added) * c/src/exec/sapi/src/exinit.c (added) * c/src/exec/sapi/src/extension.c (added) * c/src/exec/sapi/src/fatal.c (added) * c/src/exec/sapi/src/io.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.h (added) * c/src/exec/score/cpu/hppa1.1/cpu_asm.h (added) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (added) * c/src/exec/score/cpu/hppa1.1/hppa.h (added) * c/src/exec/score/cpu/hppa1.1/rtems.s (added) * c/src/exec/score/cpu/i386/asm.h (added) * c/src/exec/score/cpu/i386/cpu.c (added) * c/src/exec/score/cpu/i386/cpu.h (added) * c/src/exec/score/cpu/i386/cpu_asm.s (added) * c/src/exec/score/cpu/i386/i386.h (added) * c/src/exec/score/cpu/i386/rtems.s (added) * c/src/exec/score/cpu/i960/asm.h (added) * c/src/exec/score/cpu/i960/cpu.c (added) * c/src/exec/score/cpu/i960/cpu.h (added) * c/src/exec/score/cpu/i960/cpu_asm.s (added) * c/src/exec/score/cpu/i960/i960.h (added) * c/src/exec/score/cpu/i960/rtems.s (added) * c/src/exec/score/cpu/m68k/asm.h (added) * c/src/exec/score/cpu/m68k/cpu.c (added) * c/src/exec/score/cpu/m68k/cpu.h (added) * c/src/exec/score/cpu/m68k/cpu_asm.s (added) * c/src/exec/score/cpu/m68k/m68k.h (added) * c/src/exec/score/cpu/m68k/rtems.s (added) * c/src/exec/score/cpu/no_cpu/asm.h (added) * c/src/exec/score/cpu/no_cpu/cpu.c (added) * c/src/exec/score/cpu/no_cpu/cpu.h (added) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (added) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (added) * c/src/exec/score/cpu/no_cpu/no_cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems.c (added) * c/src/exec/score/cpu/unix/cpu.c (added) * c/src/exec/score/cpu/unix/cpu.h (added) * c/src/exec/score/cpu/unix/unix.h (added) * c/src/exec/score/headers/address.h (added) * c/src/exec/score/headers/bitfield.h (added) * c/src/exec/score/headers/chain.h (added) * c/src/exec/score/headers/context.h (added) * c/src/exec/score/headers/copyrt.h (added) * c/src/exec/score/headers/debug.h (added) * c/src/exec/score/headers/heap.h (added) * c/src/exec/score/headers/isr.h (added) * c/src/exec/score/headers/mpci.h (added) * c/src/exec/score/headers/mppkt.h (added) * c/src/exec/score/headers/object.h (added) * c/src/exec/score/headers/objectmp.h (added) * c/src/exec/score/headers/priority.h (added) * c/src/exec/score/headers/stack.h (added) * c/src/exec/score/headers/states.h (added) * c/src/exec/score/headers/sysstate.h (added) * c/src/exec/score/headers/system.h (added) * c/src/exec/score/headers/thread.h (added) * c/src/exec/score/headers/threadmp.h (added) * c/src/exec/score/headers/threadq.h (added) * c/src/exec/score/headers/tod.h (added) * c/src/exec/score/headers/tqdata.h (added) * c/src/exec/score/headers/userext.h (added) * c/src/exec/score/headers/watchdog.h (added) * c/src/exec/score/headers/wkspace.h (added) * c/src/exec/score/include/rtems/debug.h (added) * c/src/exec/score/include/rtems/score/address.h (added) * c/src/exec/score/include/rtems/score/bitfield.h (added) * c/src/exec/score/include/rtems/score/chain.h (added) * c/src/exec/score/include/rtems/score/context.h (added) * c/src/exec/score/include/rtems/score/copyrt.h (added) * c/src/exec/score/include/rtems/score/heap.h (added) * c/src/exec/score/include/rtems/score/isr.h (added) * c/src/exec/score/include/rtems/score/mpci.h (added) * c/src/exec/score/include/rtems/score/mppkt.h (added) * c/src/exec/score/include/rtems/score/object.h (added) * c/src/exec/score/include/rtems/score/objectmp.h (added) * c/src/exec/score/include/rtems/score/priority.h (added) * c/src/exec/score/include/rtems/score/stack.h (added) * c/src/exec/score/include/rtems/score/states.h (added) * c/src/exec/score/include/rtems/score/sysstate.h (added) * c/src/exec/score/include/rtems/score/thread.h (added) * c/src/exec/score/include/rtems/score/threadmp.h (added) * c/src/exec/score/include/rtems/score/threadq.h (added) * c/src/exec/score/include/rtems/score/tod.h (added) * c/src/exec/score/include/rtems/score/tqdata.h (added) * c/src/exec/score/include/rtems/score/userext.h (added) * c/src/exec/score/include/rtems/score/watchdog.h (added) * c/src/exec/score/include/rtems/score/wkspace.h (added) * c/src/exec/score/include/rtems/system.h (added) * c/src/exec/score/inline/address.inl (added) * c/src/exec/score/inline/chain.inl (added) * c/src/exec/score/inline/heap.inl (added) * c/src/exec/score/inline/isr.inl (added) * c/src/exec/score/inline/mppkt.inl (added) * c/src/exec/score/inline/object.inl (added) * c/src/exec/score/inline/objectmp.inl (added) * c/src/exec/score/inline/priority.inl (added) * c/src/exec/score/inline/rtems/score/address.inl (added) * c/src/exec/score/inline/rtems/score/chain.inl (added) * c/src/exec/score/inline/rtems/score/heap.inl (added) * c/src/exec/score/inline/rtems/score/isr.inl (added) * c/src/exec/score/inline/rtems/score/mppkt.inl (added) * c/src/exec/score/inline/rtems/score/object.inl (added) * c/src/exec/score/inline/rtems/score/objectmp.inl (added) * c/src/exec/score/inline/rtems/score/priority.inl (added) * c/src/exec/score/inline/rtems/score/stack.inl (added) * c/src/exec/score/inline/rtems/score/states.inl (added) * c/src/exec/score/inline/rtems/score/sysstate.inl (added) * c/src/exec/score/inline/rtems/score/thread.inl (added) * c/src/exec/score/inline/rtems/score/threadmp.inl (added) * c/src/exec/score/inline/rtems/score/tod.inl (added) * c/src/exec/score/inline/rtems/score/tqdata.inl (added) * c/src/exec/score/inline/rtems/score/userext.inl (added) * c/src/exec/score/inline/rtems/score/watchdog.inl (added) * c/src/exec/score/inline/rtems/score/wkspace.inl (added) * c/src/exec/score/inline/stack.inl (added) * c/src/exec/score/inline/states.inl (added) * c/src/exec/score/inline/sysstate.inl (added) * c/src/exec/score/inline/thread.inl (added) * c/src/exec/score/inline/threadmp.inl (added) * c/src/exec/score/inline/tod.inl (added) * c/src/exec/score/inline/tqdata.inl (added) * c/src/exec/score/inline/userext.inl (added) * c/src/exec/score/inline/watchdog.inl (added) * c/src/exec/score/inline/wkspace.inl (added) * c/src/exec/score/macros/README (added) * c/src/exec/score/macros/address.inl (added) * c/src/exec/score/macros/chain.inl (added) * c/src/exec/score/macros/heap.inl (added) * c/src/exec/score/macros/isr.inl (added) * c/src/exec/score/macros/mppkt.inl (added) * c/src/exec/score/macros/object.inl (added) * c/src/exec/score/macros/objectmp.inl (added) * c/src/exec/score/macros/priority.inl (added) * c/src/exec/score/macros/rtems/score/README (added) * c/src/exec/score/macros/rtems/score/address.inl (added) * c/src/exec/score/macros/rtems/score/chain.inl (added) * c/src/exec/score/macros/rtems/score/heap.inl (added) * c/src/exec/score/macros/rtems/score/isr.inl (added) * c/src/exec/score/macros/rtems/score/mppkt.inl (added) * c/src/exec/score/macros/rtems/score/object.inl (added) * c/src/exec/score/macros/rtems/score/objectmp.inl (added) * c/src/exec/score/macros/rtems/score/priority.inl (added) * c/src/exec/score/macros/rtems/score/stack.inl (added) * c/src/exec/score/macros/rtems/score/states.inl (added) * c/src/exec/score/macros/rtems/score/sysstate.inl (added) * c/src/exec/score/macros/rtems/score/thread.inl (added) * c/src/exec/score/macros/rtems/score/threadmp.inl (added) * c/src/exec/score/macros/rtems/score/tod.inl (added) * c/src/exec/score/macros/rtems/score/tqdata.inl (added) * c/src/exec/score/macros/rtems/score/userext.inl (added) * c/src/exec/score/macros/rtems/score/watchdog.inl (added) * c/src/exec/score/macros/rtems/score/wkspace.inl (added) * c/src/exec/score/macros/stack.inl (added) * c/src/exec/score/macros/states.inl (added) * c/src/exec/score/macros/sysstate.inl (added) * c/src/exec/score/macros/thread.inl (added) * c/src/exec/score/macros/threadmp.inl (added) * c/src/exec/score/macros/tod.inl (added) * c/src/exec/score/macros/tqdata.inl (added) * c/src/exec/score/macros/userext.inl (added) * c/src/exec/score/macros/watchdog.inl (added) * c/src/exec/score/macros/wkspace.inl (added) * c/src/exec/score/src/chain.c (added) * c/src/exec/score/src/coretod.c (added) * c/src/exec/score/src/heap.c (added) * c/src/exec/score/src/mpci.c (added) * c/src/exec/score/src/object.c (added) * c/src/exec/score/src/objectmp.c (added) * c/src/exec/score/src/thread.c (added) * c/src/exec/score/src/threadmp.c (added) * c/src/exec/score/src/threadq.c (added) * c/src/exec/score/src/tod.c (added) * c/src/exec/score/src/watchdog.c (added) * c/src/exec/score/src/wkspace.c (added) * c/src/exec/score/tools/hppa1.1/genoffsets.c (added) * c/src/lib/include/clockdrv.h (added) * c/src/lib/include/console.h (added) * c/src/lib/include/iosupp.h (added) * c/src/lib/include/rtems/libcsupport.h (added) * c/src/lib/include/spurious.h (added) * c/src/lib/include/timerdrv.h (added) * c/src/lib/include/vmeintr.h (added) * c/src/lib/libbsp/README (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/README (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/tools/print_dump.c (added) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (added) * c/src/lib/libbsp/i386/force386/console/console.c (added) * c/src/lib/libbsp/i386/force386/include/bsp.h (added) * c/src/lib/libbsp/i386/force386/include/coverhd.h (added) * c/src/lib/libbsp/i386/force386/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/lock.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (added) * c/src/lib/libbsp/i386/force386/startup/exit.c (added) * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (added) * c/src/lib/libbsp/i386/force386/startup/linkcmds (added) * c/src/lib/libbsp/i386/force386/startup/setvec.c (added) * c/src/lib/libbsp/i386/force386/timer/timer.c (added) * c/src/lib/libbsp/i386/force386/timer/timerisr.s (added) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (added) * c/src/lib/libbsp/i960/cvme961/console/console.c (added) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (added) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (added) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (added) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (added) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (added) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (added) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (added) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/dmv152/console/console.c (added) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (added) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (added) * c/src/lib/libbsp/m68k/dmv152/spurious/spinit.c (added) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (added) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (added) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (added) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/idp/README (added) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/idp/console/console.c (added) * c/src/lib/libbsp/m68k/idp/console/duart.c (added) * c/src/lib/libbsp/m68k/idp/console/leds.c (added) * c/src/lib/libbsp/m68k/idp/console/mc68ec.c (added) * c/src/lib/libbsp/m68k/idp/include/README (added) * c/src/lib/libbsp/m68k/idp/include/bsp.h (added) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (added) * c/src/lib/libbsp/m68k/idp/include/leds.h (added) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (added) * c/src/lib/libbsp/m68k/idp/timer/timer.c (added) * c/src/lib/libbsp/m68k/idp/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme136/console/console.c (added) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme162/README (added) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme162/console/console.c (added) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme162/tools/sload.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/README (added) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (added) * c/src/lib/libbsp/shmdr/README (added) * c/src/lib/libbsp/shmdr/addlq.c (added) * c/src/lib/libbsp/shmdr/cnvpkt.c (added) * c/src/lib/libbsp/shmdr/dump.c (added) * c/src/lib/libbsp/shmdr/fatal.c (added) * c/src/lib/libbsp/shmdr/getlq.c (added) * c/src/lib/libbsp/shmdr/getpkt.c (added) * c/src/lib/libbsp/shmdr/init.c (added) * c/src/lib/libbsp/shmdr/initlq.c (added) * c/src/lib/libbsp/shmdr/intr.c (added) * c/src/lib/libbsp/shmdr/mpci.h (added) * c/src/lib/libbsp/shmdr/mpisr.c (added) * c/src/lib/libbsp/shmdr/poll.c (added) * c/src/lib/libbsp/shmdr/receive.c (added) * c/src/lib/libbsp/shmdr/retpkt.c (added) * c/src/lib/libbsp/shmdr/send.c (added) * c/src/lib/libbsp/shmdr/setckvec.c (added) * c/src/lib/libbsp/shmdr/shm.h (added) * c/src/lib/libbsp/shmdr/shm_driver.h (added) * c/src/lib/libc/README (added) * c/src/lib/libc/__brk.c (added) * c/src/lib/libc/__gettod.c (added) * c/src/lib/libc/__times.c (added) * c/src/lib/libc/internal.h (added) * c/src/lib/libc/libcsupport.h (added) * c/src/lib/libc/malloc.c (added) * c/src/lib/libc/newlibc.c (added) * c/src/lib/libc/no_libc.c (added) * c/src/lib/libc/support.c (added) * c/src/lib/libc/syscalls.c (added) * c/src/lib/libc/unixlibc.c (added) * c/src/lib/libcpu/README (added) * c/src/lib/libcpu/hppa1.1/clock/clock.c (added) * c/src/lib/libcpu/hppa1.1/runway/runway.h (added) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.c (added) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.h (added) * c/src/lib/libcpu/hppa1.1/timer/timer.c (added) * c/src/lib/libmisc/README (added) * c/src/lib/libmisc/monitor/README (added) * c/src/lib/libmisc/monitor/mon-monitor.c (added) * c/src/lib/libmisc/monitor/mon-symbols.c (added) * c/src/lib/libmisc/monitor/monitor.h (added) * c/src/lib/libmisc/monitor/symbols.h (added) * c/src/lib/libmisc/stackchk/README (added) * c/src/lib/libmisc/stackchk/check.c (added) * c/src/lib/libmisc/stackchk/internal.h (added) * c/src/lib/libmisc/stackchk/stackchk.h (added) * c/src/lib/start/README (added) * c/src/lib/start/i960/start.s (added) * c/src/lib/start/m68k/start.s (added) * c/src/libchip/shmdr/README (added) * c/src/libchip/shmdr/addlq.c (added) * c/src/libchip/shmdr/cnvpkt.c (added) * c/src/libchip/shmdr/dump.c (added) * c/src/libchip/shmdr/fatal.c (added) * c/src/libchip/shmdr/getlq.c (added) * c/src/libchip/shmdr/getpkt.c (added) * c/src/libchip/shmdr/init.c (added) * c/src/libchip/shmdr/initlq.c (added) * c/src/libchip/shmdr/intr.c (added) * c/src/libchip/shmdr/mpci.h (added) * c/src/libchip/shmdr/mpisr.c (added) * c/src/libchip/shmdr/poll.c (added) * c/src/libchip/shmdr/receive.c (added) * c/src/libchip/shmdr/retpkt.c (added) * c/src/libchip/shmdr/send.c (added) * c/src/libchip/shmdr/setckvec.c (added) * c/src/libchip/shmdr/shm_driver.h (added) * c/src/libmisc/README (added) * c/src/libmisc/monitor/README (added) * c/src/libmisc/monitor/mon-monitor.c (added) * c/src/libmisc/monitor/mon-symbols.c (added) * c/src/libmisc/monitor/monitor.h (added) * c/src/libmisc/monitor/symbols.h (added) * c/src/libmisc/stackchk/README (added) * c/src/libmisc/stackchk/check.c (added) * c/src/libmisc/stackchk/internal.h (added) * c/src/libmisc/stackchk/stackchk.h (added) * c/src/optman/rtems/no-dpmem.c (added) * c/src/optman/rtems/no-event.c (added) * c/src/optman/rtems/no-mp.c (added) * c/src/optman/rtems/no-msg.c (added) * c/src/optman/rtems/no-part.c (added) * c/src/optman/rtems/no-region.c (added) * c/src/optman/rtems/no-rtmon.c (added) * c/src/optman/rtems/no-sem.c (added) * c/src/optman/rtems/no-signal.c (added) * c/src/optman/rtems/no-timer.c (added) * c/src/optman/sapi/no-ext.c (added) * c/src/optman/sapi/no-io.c (added) * c/src/tests/README (added) * c/src/tests/libtests/README (added) * c/src/tests/libtests/stackchk/blow.c (added) * c/src/tests/libtests/stackchk/init.c (added) * c/src/tests/libtests/stackchk/stackchk.scn (added) * c/src/tests/libtests/stackchk/task1.c (added) * c/src/tests/mptests/README (added) * c/src/tests/mptests/mp01/init.c (added) * c/src/tests/mptests/mp01/node1/mp01.doc (added) * c/src/tests/mptests/mp01/node1/mp01.scn (added) * c/src/tests/mptests/mp01/node2/mp01.doc (added) * c/src/tests/mptests/mp01/node2/mp01.scn (added) * c/src/tests/mptests/mp01/system.h (added) * c/src/tests/mptests/mp01/task1.c (added) * c/src/tests/mptests/mp02/init.c (added) * c/src/tests/mptests/mp02/node1/mp02.doc (added) * c/src/tests/mptests/mp02/node1/mp02.scn (added) * c/src/tests/mptests/mp02/node2/mp02.doc (added) * c/src/tests/mptests/mp02/node2/mp02.scn (added) * c/src/tests/mptests/mp02/system.h (added) * c/src/tests/mptests/mp02/task1.c (added) * c/src/tests/mptests/mp03/delay.c (added) * c/src/tests/mptests/mp03/init.c (added) * c/src/tests/mptests/mp03/node1/mp03.doc (added) * c/src/tests/mptests/mp03/node1/mp03.scn (added) * c/src/tests/mptests/mp03/node2/mp03.doc (added) * c/src/tests/mptests/mp03/node2/mp03.scn (added) * c/src/tests/mptests/mp03/system.h (added) * c/src/tests/mptests/mp03/task1.c (added) * c/src/tests/mptests/mp04/init.c (added) * c/src/tests/mptests/mp04/node1/mp04.doc (added) * c/src/tests/mptests/mp04/node1/mp04.scn (added) * c/src/tests/mptests/mp04/node2/mp04.doc (added) * c/src/tests/mptests/mp04/node2/mp04.scn (added) * c/src/tests/mptests/mp04/system.h (added) * c/src/tests/mptests/mp04/task1.c (added) * c/src/tests/mptests/mp05/asr.c (added) * c/src/tests/mptests/mp05/init.c (added) * c/src/tests/mptests/mp05/node1/mp05.doc (added) * c/src/tests/mptests/mp05/node1/mp05.scn (added) * c/src/tests/mptests/mp05/node2/mp05.doc (added) * c/src/tests/mptests/mp05/node2/mp05.scn (added) * c/src/tests/mptests/mp05/system.h (added) * c/src/tests/mptests/mp05/task1.c (added) * c/src/tests/mptests/mp06/init.c (added) * c/src/tests/mptests/mp06/node1/mp06.doc (added) * c/src/tests/mptests/mp06/node1/mp06.scn (added) * c/src/tests/mptests/mp06/node2/mp06.doc (added) * c/src/tests/mptests/mp06/node2/mp06.scn (added) * c/src/tests/mptests/mp06/system.h (added) * c/src/tests/mptests/mp06/task1.c (added) * c/src/tests/mptests/mp07/init.c (added) * c/src/tests/mptests/mp07/node1/mp07.doc (added) * c/src/tests/mptests/mp07/node1/mp07.scn (added) * c/src/tests/mptests/mp07/node2/mp07.doc (added) * c/src/tests/mptests/mp07/node2/mp07.scn (added) * c/src/tests/mptests/mp07/system.h (added) * c/src/tests/mptests/mp07/task1.c (added) * c/src/tests/mptests/mp08/init.c (added) * c/src/tests/mptests/mp08/node1/mp08.doc (added) * c/src/tests/mptests/mp08/node1/mp08.scn (added) * c/src/tests/mptests/mp08/node2/mp08.doc (added) * c/src/tests/mptests/mp08/node2/mp08.scn (added) * c/src/tests/mptests/mp08/system.h (added) * c/src/tests/mptests/mp08/task1.c (added) * c/src/tests/mptests/mp09/init.c (added) * c/src/tests/mptests/mp09/node1/mp09.doc (added) * c/src/tests/mptests/mp09/node1/mp09.scn (added) * c/src/tests/mptests/mp09/node2/mp09.doc (added) * c/src/tests/mptests/mp09/node2/mp09.scn (added) * c/src/tests/mptests/mp09/recvmsg.c (added) * c/src/tests/mptests/mp09/sendmsg.c (added) * c/src/tests/mptests/mp09/system.h (added) * c/src/tests/mptests/mp09/task1.c (added) * c/src/tests/mptests/mp10/init.c (added) * c/src/tests/mptests/mp10/node1/mp10.doc (added) * c/src/tests/mptests/mp10/node1/mp10.scn (added) * c/src/tests/mptests/mp10/node2/mp10.doc (added) * c/src/tests/mptests/mp10/node2/mp10.scn (added) * c/src/tests/mptests/mp10/system.h (added) * c/src/tests/mptests/mp10/task1.c (added) * c/src/tests/mptests/mp10/task2.c (added) * c/src/tests/mptests/mp10/task3.c (added) * c/src/tests/mptests/mp11/init.c (added) * c/src/tests/mptests/mp11/node1/mp11.doc (added) * c/src/tests/mptests/mp11/node1/mp11.scn (added) * c/src/tests/mptests/mp11/node2/mp11.doc (added) * c/src/tests/mptests/mp11/node2/mp11.scn (added) * c/src/tests/mptests/mp11/system.h (added) * c/src/tests/mptests/mp12/init.c (added) * c/src/tests/mptests/mp12/node1/mp12.doc (added) * c/src/tests/mptests/mp12/node1/mp12.scn (added) * c/src/tests/mptests/mp12/node2/mp12.doc (added) * c/src/tests/mptests/mp12/node2/mp12.scn (added) * c/src/tests/mptests/mp12/system.h (added) * c/src/tests/mptests/mp13/init.c (added) * c/src/tests/mptests/mp13/node1/mp13.doc (added) * c/src/tests/mptests/mp13/node1/mp13.scn (added) * c/src/tests/mptests/mp13/node2/mp13.doc (added) * c/src/tests/mptests/mp13/node2/mp13.scn (added) * c/src/tests/mptests/mp13/system.h (added) * c/src/tests/mptests/mp13/task1.c (added) * c/src/tests/mptests/mp13/task2.c (added) * c/src/tests/mptests/mp14/delay.c (added) * c/src/tests/mptests/mp14/evtask1.c (added) * c/src/tests/mptests/mp14/evtmtask.c (added) * c/src/tests/mptests/mp14/exit.c (added) * c/src/tests/mptests/mp14/init.c (added) * c/src/tests/mptests/mp14/msgtask1.c (added) * c/src/tests/mptests/mp14/node1/mp14.doc (added) * c/src/tests/mptests/mp14/node1/mp14.scn (added) * c/src/tests/mptests/mp14/node2/mp14.doc (added) * c/src/tests/mptests/mp14/node2/mp14.scn (added) * c/src/tests/mptests/mp14/pttask1.c (added) * c/src/tests/mptests/mp14/smtask1.c (added) * c/src/tests/mptests/mp14/system.h (added) * c/src/tests/samples/README (added) * c/src/tests/samples/base_mp/apptask.c (added) * c/src/tests/samples/base_mp/init.c (added) * c/src/tests/samples/base_mp/node1/base_mp.doc (added) * c/src/tests/samples/base_mp/node1/base_mp.scn (added) * c/src/tests/samples/base_mp/node2/base_mp.doc (added) * c/src/tests/samples/base_mp/node2/base_mp.scn (added) * c/src/tests/samples/base_mp/system.h (added) * c/src/tests/samples/base_sp/apptask.c (added) * c/src/tests/samples/base_sp/base_sp.doc (added) * c/src/tests/samples/base_sp/base_sp.scn (added) * c/src/tests/samples/base_sp/init.c (added) * c/src/tests/samples/base_sp/system.h (added) * c/src/tests/samples/cdtest/cdtest.scn (added) * c/src/tests/samples/cdtest/init.c (added) * c/src/tests/samples/cdtest/main.cc (added) * c/src/tests/samples/cdtest/system.h (added) * c/src/tests/samples/hello/hello.doc (added) * c/src/tests/samples/hello/hello.scn (added) * c/src/tests/samples/hello/init.c (added) * c/src/tests/samples/hello/system.h (added) * c/src/tests/samples/paranoia/init.c (added) * c/src/tests/samples/paranoia/paranoia.c (added) * c/src/tests/samples/paranoia/paranoia.doc (added) * c/src/tests/samples/paranoia/system.h (added) * c/src/tests/samples/ticker/init.c (added) * c/src/tests/samples/ticker/system.h (added) * c/src/tests/samples/ticker/tasks.c (added) * c/src/tests/samples/ticker/ticker.doc (added) * c/src/tests/samples/ticker/ticker.scn (added) * c/src/tests/sptests/README (added) * c/src/tests/sptests/sp01/init.c (added) * c/src/tests/sptests/sp01/sp01.doc (added) * c/src/tests/sptests/sp01/sp01.scn (added) * c/src/tests/sptests/sp01/system.h (added) * c/src/tests/sptests/sp01/task1.c (added) * c/src/tests/sptests/sp02/init.c (added) * c/src/tests/sptests/sp02/preempt.c (added) * c/src/tests/sptests/sp02/sp02.doc (added) * c/src/tests/sptests/sp02/sp02.scn (added) * c/src/tests/sptests/sp02/system.h (added) * c/src/tests/sptests/sp02/task1.c (added) * c/src/tests/sptests/sp02/task2.c (added) * c/src/tests/sptests/sp02/task3.c (added) * c/src/tests/sptests/sp03/init.c (added) * c/src/tests/sptests/sp03/sp03.doc (added) * c/src/tests/sptests/sp03/sp03.scn (added) * c/src/tests/sptests/sp03/system.h (added) * c/src/tests/sptests/sp03/task1.c (added) * c/src/tests/sptests/sp03/task2.c (added) * c/src/tests/sptests/sp04/init.c (added) * c/src/tests/sptests/sp04/sp04.doc (added) * c/src/tests/sptests/sp04/sp04.scn (added) * c/src/tests/sptests/sp04/system.h (added) * c/src/tests/sptests/sp04/task1.c (added) * c/src/tests/sptests/sp04/task2.c (added) * c/src/tests/sptests/sp04/task3.c (added) * c/src/tests/sptests/sp04/tswitch.c (added) * c/src/tests/sptests/sp05/init.c (added) * c/src/tests/sptests/sp05/sp05.doc (added) * c/src/tests/sptests/sp05/sp05.scn (added) * c/src/tests/sptests/sp05/system.h (added) * c/src/tests/sptests/sp05/task1.c (added) * c/src/tests/sptests/sp05/task2.c (added) * c/src/tests/sptests/sp05/task3.c (added) * c/src/tests/sptests/sp06/init.c (added) * c/src/tests/sptests/sp06/sp06.doc (added) * c/src/tests/sptests/sp06/sp06.scn (added) * c/src/tests/sptests/sp06/system.h (added) * c/src/tests/sptests/sp06/task1.c (added) * c/src/tests/sptests/sp06/task2.c (added) * c/src/tests/sptests/sp06/task3.c (added) * c/src/tests/sptests/sp07/init.c (added) * c/src/tests/sptests/sp07/sp07.doc (added) * c/src/tests/sptests/sp07/sp07.scn (added) * c/src/tests/sptests/sp07/system.h (added) * c/src/tests/sptests/sp07/task1.c (added) * c/src/tests/sptests/sp07/task2.c (added) * c/src/tests/sptests/sp07/task3.c (added) * c/src/tests/sptests/sp07/task4.c (added) * c/src/tests/sptests/sp07/taskexit.c (added) * c/src/tests/sptests/sp07/tcreate.c (added) * c/src/tests/sptests/sp07/tdelete.c (added) * c/src/tests/sptests/sp07/trestart.c (added) * c/src/tests/sptests/sp07/tstart.c (added) * c/src/tests/sptests/sp08/init.c (added) * c/src/tests/sptests/sp08/sp08.doc (added) * c/src/tests/sptests/sp08/sp08.scn (added) * c/src/tests/sptests/sp08/system.h (added) * c/src/tests/sptests/sp08/task1.c (added) * c/src/tests/sptests/sp09/delay.c (added) * c/src/tests/sptests/sp09/init.c (added) * c/src/tests/sptests/sp09/isr.c (added) * c/src/tests/sptests/sp09/screen01.c (added) * c/src/tests/sptests/sp09/screen02.c (added) * c/src/tests/sptests/sp09/screen03.c (added) * c/src/tests/sptests/sp09/screen04.c (added) * c/src/tests/sptests/sp09/screen05.c (added) * c/src/tests/sptests/sp09/screen06.c (added) * c/src/tests/sptests/sp09/screen07.c (added) * c/src/tests/sptests/sp09/screen08.c (added) * c/src/tests/sptests/sp09/screen09.c (added) * c/src/tests/sptests/sp09/screen10.c (added) * c/src/tests/sptests/sp09/screen11.c (added) * c/src/tests/sptests/sp09/screen12.c (added) * c/src/tests/sptests/sp09/screen13.c (added) * c/src/tests/sptests/sp09/screen14.c (added) * c/src/tests/sptests/sp09/sp09.doc (added) * c/src/tests/sptests/sp09/sp09.scn (added) * c/src/tests/sptests/sp09/system.h (added) * c/src/tests/sptests/sp09/task1.c (added) * c/src/tests/sptests/sp09/task2.c (added) * c/src/tests/sptests/sp09/task3.c (added) * c/src/tests/sptests/sp09/task4.c (added) * c/src/tests/sptests/sp11/init.c (added) * c/src/tests/sptests/sp11/sp11.doc (added) * c/src/tests/sptests/sp11/sp11.scn (added) * c/src/tests/sptests/sp11/system.h (added) * c/src/tests/sptests/sp11/task1.c (added) * c/src/tests/sptests/sp11/task2.c (added) * c/src/tests/sptests/sp11/timer.c (added) * c/src/tests/sptests/sp12/init.c (added) * c/src/tests/sptests/sp12/pridrv.c (added) * c/src/tests/sptests/sp12/pritask.c (added) * c/src/tests/sptests/sp12/sp12.doc (added) * c/src/tests/sptests/sp12/sp12.scn (added) * c/src/tests/sptests/sp12/system.h (added) * c/src/tests/sptests/sp12/task1.c (added) * c/src/tests/sptests/sp12/task2.c (added) * c/src/tests/sptests/sp12/task3.c (added) * c/src/tests/sptests/sp12/task4.c (added) * c/src/tests/sptests/sp12/task5.c (added) * c/src/tests/sptests/sp13/fillbuff.c (added) * c/src/tests/sptests/sp13/init.c (added) * c/src/tests/sptests/sp13/putbuff.c (added) * c/src/tests/sptests/sp13/sp13.doc (added) * c/src/tests/sptests/sp13/sp13.scn (added) * c/src/tests/sptests/sp13/system.h (added) * c/src/tests/sptests/sp13/task1.c (added) * c/src/tests/sptests/sp13/task2.c (added) * c/src/tests/sptests/sp13/task3.c (added) * c/src/tests/sptests/sp14/asr.c (added) * c/src/tests/sptests/sp14/init.c (added) * c/src/tests/sptests/sp14/sp14.doc (added) * c/src/tests/sptests/sp14/sp14.scn (added) * c/src/tests/sptests/sp14/system.h (added) * c/src/tests/sptests/sp14/task1.c (added) * c/src/tests/sptests/sp14/task2.c (added) * c/src/tests/sptests/sp15/init.c (added) * c/src/tests/sptests/sp15/sp15.doc (added) * c/src/tests/sptests/sp15/sp15.scn (added) * c/src/tests/sptests/sp15/system.h (added) * c/src/tests/sptests/sp15/task1.c (added) * c/src/tests/sptests/sp16/init.c (added) * c/src/tests/sptests/sp16/sp16.doc (added) * c/src/tests/sptests/sp16/sp16.scn (added) * c/src/tests/sptests/sp16/system.h (added) * c/src/tests/sptests/sp16/task1.c (added) * c/src/tests/sptests/sp16/task2.c (added) * c/src/tests/sptests/sp16/task3.c (added) * c/src/tests/sptests/sp16/task4.c (added) * c/src/tests/sptests/sp16/task5.c (added) * c/src/tests/sptests/sp17/asr.c (added) * c/src/tests/sptests/sp17/init.c (added) * c/src/tests/sptests/sp17/sp17.doc (added) * c/src/tests/sptests/sp17/sp17.scn (added) * c/src/tests/sptests/sp17/system.h (added) * c/src/tests/sptests/sp17/task1.c (added) * c/src/tests/sptests/sp17/task2.c (added) * c/src/tests/sptests/sp19/first.c (added) * c/src/tests/sptests/sp19/fptask.c (added) * c/src/tests/sptests/sp19/fptest.h (added) * c/src/tests/sptests/sp19/init.c (added) * c/src/tests/sptests/sp19/inttest.h (added) * c/src/tests/sptests/sp19/sp19.doc (added) * c/src/tests/sptests/sp19/sp19.scn (added) * c/src/tests/sptests/sp19/system.h (added) * c/src/tests/sptests/sp19/task1.c (added) * c/src/tests/sptests/sp20/getall.c (added) * c/src/tests/sptests/sp20/init.c (added) * c/src/tests/sptests/sp20/sp20.doc (added) * c/src/tests/sptests/sp20/sp20.scn (added) * c/src/tests/sptests/sp20/system.h (added) * c/src/tests/sptests/sp20/task1.c (added) * c/src/tests/sptests/sp21/init.c (added) * c/src/tests/sptests/sp21/sp21.doc (added) * c/src/tests/sptests/sp21/sp21.scn (added) * c/src/tests/sptests/sp21/system.h (added) * c/src/tests/sptests/sp21/task1.c (added) * c/src/tests/sptests/sp22/delay.c (added) * c/src/tests/sptests/sp22/init.c (added) * c/src/tests/sptests/sp22/prtime.c (added) * c/src/tests/sptests/sp22/sp22.doc (added) * c/src/tests/sptests/sp22/sp22.scn (added) * c/src/tests/sptests/sp22/system.h (added) * c/src/tests/sptests/sp22/task1.c (added) * c/src/tests/sptests/sp23/init.c (added) * c/src/tests/sptests/sp23/sp23.doc (added) * c/src/tests/sptests/sp23/sp23.scn (added) * c/src/tests/sptests/sp23/system.h (added) * c/src/tests/sptests/sp23/task1.c (added) * c/src/tests/sptests/sp24/init.c (added) * c/src/tests/sptests/sp24/resume.c (added) * c/src/tests/sptests/sp24/sp24.doc (added) * c/src/tests/sptests/sp24/sp24.scn (added) * c/src/tests/sptests/sp24/system.h (added) * c/src/tests/sptests/sp24/task1.c (added) * c/src/tests/sptests/sp25/init.c (added) * c/src/tests/sptests/sp25/sp25.doc (added) * c/src/tests/sptests/sp25/sp25.scn (added) * c/src/tests/sptests/sp25/system.h (added) * c/src/tests/sptests/sp25/task1.c (added) * c/src/tests/sptests/spfatal/fatal.c (added) * c/src/tests/sptests/spfatal/init.c (added) * c/src/tests/sptests/spfatal/puterr.c (added) * c/src/tests/sptests/spfatal/spfatal.doc (added) * c/src/tests/sptests/spfatal/spfatal.scn (added) * c/src/tests/sptests/spfatal/system.h (added) * c/src/tests/sptests/spfatal/task1.c (added) * c/src/tests/sptests/spsize/getint.c (added) * c/src/tests/sptests/spsize/init.c (added) * c/src/tests/sptests/spsize/size.c (added) * c/src/tests/support/include/tmacros.h (added) * c/src/tests/support/stubdr/close.c (added) * c/src/tests/support/stubdr/cntrl.c (added) * c/src/tests/support/stubdr/init.c (added) * c/src/tests/support/stubdr/open.c (added) * c/src/tests/support/stubdr/read.c (added) * c/src/tests/support/stubdr/stubdrv.h (added) * c/src/tests/support/stubdr/write.c (added) * c/src/tests/tmtests/README (added) * c/src/tests/tmtests/include/timesys.h (added) * c/src/tests/tmtests/tm01/system.h (added) * c/src/tests/tmtests/tm01/task1.c (added) * c/src/tests/tmtests/tm01/tm01.doc (added) * c/src/tests/tmtests/tm02/system.h (added) * c/src/tests/tmtests/tm02/task1.c (added) * c/src/tests/tmtests/tm02/tm02.doc (added) * c/src/tests/tmtests/tm03/system.h (added) * c/src/tests/tmtests/tm03/task1.c (added) * c/src/tests/tmtests/tm03/tm03.doc (added) * c/src/tests/tmtests/tm04/system.h (added) * c/src/tests/tmtests/tm04/task1.c (added) * c/src/tests/tmtests/tm04/tm04.doc (added) * c/src/tests/tmtests/tm05/system.h (added) * c/src/tests/tmtests/tm05/task1.c (added) * c/src/tests/tmtests/tm05/tm05.doc (added) * c/src/tests/tmtests/tm06/system.h (added) * c/src/tests/tmtests/tm06/task1.c (added) * c/src/tests/tmtests/tm06/tm06.doc (added) * c/src/tests/tmtests/tm07/system.h (added) * c/src/tests/tmtests/tm07/task1.c (added) * c/src/tests/tmtests/tm07/tm07.doc (added) * c/src/tests/tmtests/tm08/system.h (added) * c/src/tests/tmtests/tm08/task1.c (added) * c/src/tests/tmtests/tm08/tm08.doc (added) * c/src/tests/tmtests/tm09/system.h (added) * c/src/tests/tmtests/tm09/task1.c (added) * c/src/tests/tmtests/tm09/tm09.doc (added) * c/src/tests/tmtests/tm10/system.h (added) * c/src/tests/tmtests/tm10/task1.c (added) * c/src/tests/tmtests/tm10/tm10.doc (added) * c/src/tests/tmtests/tm11/system.h (added) * c/src/tests/tmtests/tm11/task1.c (added) * c/src/tests/tmtests/tm11/tm11.doc (added) * c/src/tests/tmtests/tm12/system.h (added) * c/src/tests/tmtests/tm12/task1.c (added) * c/src/tests/tmtests/tm12/tm12.doc (added) * c/src/tests/tmtests/tm13/system.h (added) * c/src/tests/tmtests/tm13/task1.c (added) * c/src/tests/tmtests/tm13/tm13.doc (added) * c/src/tests/tmtests/tm14/system.h (added) * c/src/tests/tmtests/tm14/task1.c (added) * c/src/tests/tmtests/tm14/tm14.doc (added) * c/src/tests/tmtests/tm15/system.h (added) * c/src/tests/tmtests/tm15/task1.c (added) * c/src/tests/tmtests/tm15/tm15.doc (added) * c/src/tests/tmtests/tm16/system.h (added) * c/src/tests/tmtests/tm16/task1.c (added) * c/src/tests/tmtests/tm16/tm16.doc (added) * c/src/tests/tmtests/tm17/system.h (added) * c/src/tests/tmtests/tm17/task1.c (added) * c/src/tests/tmtests/tm17/tm17.doc (added) * c/src/tests/tmtests/tm18/system.h (added) * c/src/tests/tmtests/tm18/task1.c (added) * c/src/tests/tmtests/tm18/tm18.doc (added) * c/src/tests/tmtests/tm19/system.h (added) * c/src/tests/tmtests/tm19/task1.c (added) * c/src/tests/tmtests/tm19/tm19.doc (added) * c/src/tests/tmtests/tm20/system.h (added) * c/src/tests/tmtests/tm20/task1.c (added) * c/src/tests/tmtests/tm20/tm20.doc (added) * c/src/tests/tmtests/tm21/system.h (added) * c/src/tests/tmtests/tm21/task1.c (added) * c/src/tests/tmtests/tm21/tm21.doc (added) * c/src/tests/tmtests/tm22/system.h (added) * c/src/tests/tmtests/tm22/task1.c (added) * c/src/tests/tmtests/tm22/tm22.doc (added) * c/src/tests/tmtests/tm23/system.h (added) * c/src/tests/tmtests/tm23/task1.c (added) * c/src/tests/tmtests/tm23/tm23.doc (added) * c/src/tests/tmtests/tm24/system.h (added) * c/src/tests/tmtests/tm24/task1.c (added) * c/src/tests/tmtests/tm24/tm24.doc (added) * c/src/tests/tmtests/tm25/system.h (added) * c/src/tests/tmtests/tm25/task1.c (added) * c/src/tests/tmtests/tm25/tm25.doc (added) * c/src/tests/tmtests/tm26/fptest.h (added) * c/src/tests/tmtests/tm26/system.h (added) * c/src/tests/tmtests/tm26/task1.c (added) * c/src/tests/tmtests/tm26/tm26.doc (added) * c/src/tests/tmtests/tm27/system.h (added) * c/src/tests/tmtests/tm27/task1.c (added) * c/src/tests/tmtests/tm27/tm27.doc (added) * c/src/tests/tmtests/tm28/system.h (added) * c/src/tests/tmtests/tm28/task1.c (added) * c/src/tests/tmtests/tm28/tm28.doc (added) * c/src/tests/tmtests/tm29/system.h (added) * c/src/tests/tmtests/tm29/task1.c (added) * c/src/tests/tmtests/tm29/tm29.doc (added) * c/src/tests/tmtests/tmck/system.h (added) * c/src/tests/tmtests/tmck/task1.c (added) * c/src/tests/tmtests/tmck/tmck.doc (added) * c/src/tests/tmtests/tmoverhd/dumrtems.h (added) * c/src/tests/tmtests/tmoverhd/empty.c (added) * c/src/tests/tmtests/tmoverhd/system.h (added) * c/src/tests/tmtests/tmoverhd/testtask.c (added) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (added) * c/src/tests/tools/generic/difftest (added) * c/update-tools/310_to_320_list (added) * c/update-tools/README (added) * cpukit/libcsupport/include/clockdrv.h (added) * cpukit/libcsupport/include/console.h (added) * cpukit/libcsupport/include/iosupp.h (added) * cpukit/libcsupport/include/rtems/libcsupport.h (added) * cpukit/libcsupport/include/spurious.h (added) * cpukit/libcsupport/include/timerdrv.h (added) * cpukit/libcsupport/include/vmeintr.h (added) * cpukit/libcsupport/src/README (added) * cpukit/libcsupport/src/__brk.c (added) * cpukit/libcsupport/src/__gettod.c (added) * cpukit/libcsupport/src/__times.c (added) * cpukit/libcsupport/src/malloc.c (added) * cpukit/libcsupport/src/newlibc.c (added) * cpukit/libcsupport/src/no_libc.c (added) * cpukit/libcsupport/src/unixlibc.c (added) * cpukit/libmisc/README (added) * cpukit/libmisc/monitor/README (added) * cpukit/libmisc/monitor/mon-monitor.c (added) * cpukit/libmisc/monitor/mon-symbols.c (added) * cpukit/libmisc/monitor/monitor.h (added) * cpukit/libmisc/monitor/symbols.h (added) * cpukit/libmisc/stackchk/README (added) * cpukit/libmisc/stackchk/check.c (added) * cpukit/libmisc/stackchk/internal.h (added) * cpukit/libmisc/stackchk/stackchk.h (added) * cpukit/rtems/include/rtems.h (added) * cpukit/rtems/include/rtems/rtems/asr.h (added) * cpukit/rtems/include/rtems/rtems/attr.h (added) * cpukit/rtems/include/rtems/rtems/clock.h (added) * cpukit/rtems/include/rtems/rtems/dpmem.h (added) * cpukit/rtems/include/rtems/rtems/event.h (added) * cpukit/rtems/include/rtems/rtems/eventmp.h (added) * cpukit/rtems/include/rtems/rtems/eventset.h (added) * cpukit/rtems/include/rtems/rtems/intr.h (added) * cpukit/rtems/include/rtems/rtems/message.h (added) * cpukit/rtems/include/rtems/rtems/modes.h (added) * cpukit/rtems/include/rtems/rtems/mp.h (added) * cpukit/rtems/include/rtems/rtems/msgmp.h (added) * cpukit/rtems/include/rtems/rtems/options.h (added) * cpukit/rtems/include/rtems/rtems/part.h (added) * cpukit/rtems/include/rtems/rtems/partmp.h (added) * cpukit/rtems/include/rtems/rtems/ratemon.h (added) * cpukit/rtems/include/rtems/rtems/region.h (added) * cpukit/rtems/include/rtems/rtems/regionmp.h (added) * cpukit/rtems/include/rtems/rtems/sem.h (added) * cpukit/rtems/include/rtems/rtems/semmp.h (added) * cpukit/rtems/include/rtems/rtems/signal.h (added) * cpukit/rtems/include/rtems/rtems/signalmp.h (added) * cpukit/rtems/include/rtems/rtems/status.h (added) * cpukit/rtems/include/rtems/rtems/taskmp.h (added) * cpukit/rtems/include/rtems/rtems/tasks.h (added) * cpukit/rtems/include/rtems/rtems/timer.h (added) * cpukit/rtems/inline/rtems/rtems/asr.inl (added) * cpukit/rtems/inline/rtems/rtems/attr.inl (added) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (added) * cpukit/rtems/inline/rtems/rtems/event.inl (added) * cpukit/rtems/inline/rtems/rtems/eventset.inl (added) * cpukit/rtems/inline/rtems/rtems/message.inl (added) * cpukit/rtems/inline/rtems/rtems/modes.inl (added) * cpukit/rtems/inline/rtems/rtems/options.inl (added) * cpukit/rtems/inline/rtems/rtems/part.inl (added) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (added) * cpukit/rtems/inline/rtems/rtems/region.inl (added) * cpukit/rtems/inline/rtems/rtems/sem.inl (added) * cpukit/rtems/inline/rtems/rtems/status.inl (added) * cpukit/rtems/inline/rtems/rtems/tasks.inl (added) * cpukit/rtems/inline/rtems/rtems/timer.inl (added) * cpukit/rtems/macros/rtems/rtems/asr.inl (added) * cpukit/rtems/macros/rtems/rtems/attr.inl (added) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (added) * cpukit/rtems/macros/rtems/rtems/event.inl (added) * cpukit/rtems/macros/rtems/rtems/eventset.inl (added) * cpukit/rtems/macros/rtems/rtems/message.inl (added) * cpukit/rtems/macros/rtems/rtems/modes.inl (added) * cpukit/rtems/macros/rtems/rtems/options.inl (added) * cpukit/rtems/macros/rtems/rtems/part.inl (added) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (added) * cpukit/rtems/macros/rtems/rtems/region.inl (added) * cpukit/rtems/macros/rtems/rtems/sem.inl (added) * cpukit/rtems/macros/rtems/rtems/status.inl (added) * cpukit/rtems/macros/rtems/rtems/tasks.inl (added) * cpukit/rtems/macros/rtems/rtems/timer.inl (added) * cpukit/rtems/src/dpmem.c (added) * cpukit/rtems/src/event.c (added) * cpukit/rtems/src/eventmp.c (added) * cpukit/rtems/src/intr.c (added) * cpukit/rtems/src/mp.c (added) * cpukit/rtems/src/msg.c (added) * cpukit/rtems/src/msgmp.c (added) * cpukit/rtems/src/part.c (added) * cpukit/rtems/src/partmp.c (added) * cpukit/rtems/src/ratemon.c (added) * cpukit/rtems/src/region.c (added) * cpukit/rtems/src/regionmp.c (added) * cpukit/rtems/src/rtclock.c (added) * cpukit/rtems/src/rtemstimer.c (added) * cpukit/rtems/src/sem.c (added) * cpukit/rtems/src/semmp.c (added) * cpukit/rtems/src/signal.c (added) * cpukit/rtems/src/signalmp.c (added) * cpukit/rtems/src/taskmp.c (added) * cpukit/rtems/src/tasks.c (added) * cpukit/sapi/include/rtems/config.h (added) * cpukit/sapi/include/rtems/extension.h (added) * cpukit/sapi/include/rtems/fatal.h (added) * cpukit/sapi/include/rtems/init.h (added) * cpukit/sapi/include/rtems/io.h (added) * cpukit/sapi/include/rtems/mptables.h (added) * cpukit/sapi/inline/rtems/extension.inl (added) * cpukit/sapi/macros/rtems/extension.inl (added) * cpukit/sapi/src/debug.c (added) * cpukit/sapi/src/exinit.c (added) * cpukit/sapi/src/extension.c (added) * cpukit/sapi/src/fatal.c (added) * cpukit/sapi/src/io.c (added) * cpukit/score/cpu/hppa1.1/cpu.c (added) * cpukit/score/cpu/i386/asm.h (added) * cpukit/score/cpu/i386/cpu.c (added) * cpukit/score/cpu/i386/rtems/asm.h (added) * cpukit/score/cpu/i960/asm.h (added) * cpukit/score/cpu/i960/cpu.c (added) * cpukit/score/cpu/m68k/asm.h (added) * cpukit/score/cpu/m68k/cpu.c (added) * cpukit/score/cpu/m68k/rtems/asm.h (added) * cpukit/score/cpu/no_cpu/asm.h (added) * cpukit/score/cpu/no_cpu/cpu.c (added) * cpukit/score/cpu/no_cpu/cpu_asm.c (added) * cpukit/score/cpu/no_cpu/rtems/asm.h (added) * cpukit/score/cpu/unix/cpu.c (added) * cpukit/score/include/rtems/debug.h (added) * cpukit/score/include/rtems/score/address.h (added) * cpukit/score/include/rtems/score/bitfield.h (added) * cpukit/score/include/rtems/score/chain.h (added) * cpukit/score/include/rtems/score/context.h (added) * cpukit/score/include/rtems/score/copyrt.h (added) * cpukit/score/include/rtems/score/heap.h (added) * cpukit/score/include/rtems/score/isr.h (added) * cpukit/score/include/rtems/score/mpci.h (added) * cpukit/score/include/rtems/score/mppkt.h (added) * cpukit/score/include/rtems/score/object.h (added) * cpukit/score/include/rtems/score/objectmp.h (added) * cpukit/score/include/rtems/score/priority.h (added) * cpukit/score/include/rtems/score/stack.h (added) * cpukit/score/include/rtems/score/states.h (added) * cpukit/score/include/rtems/score/sysstate.h (added) * cpukit/score/include/rtems/score/thread.h (added) * cpukit/score/include/rtems/score/threadmp.h (added) * cpukit/score/include/rtems/score/threadq.h (added) * cpukit/score/include/rtems/score/tod.h (added) * cpukit/score/include/rtems/score/tqdata.h (added) * cpukit/score/include/rtems/score/userext.h (added) * cpukit/score/include/rtems/score/watchdog.h (added) * cpukit/score/include/rtems/score/wkspace.h (added) * cpukit/score/include/rtems/system.h (added) * cpukit/score/inline/rtems/score/address.inl (added) * cpukit/score/inline/rtems/score/chain.inl (added) * cpukit/score/inline/rtems/score/heap.inl (added) * cpukit/score/inline/rtems/score/isr.inl (added) * cpukit/score/inline/rtems/score/mppkt.inl (added) * cpukit/score/inline/rtems/score/object.inl (added) * cpukit/score/inline/rtems/score/objectmp.inl (added) * cpukit/score/inline/rtems/score/priority.inl (added) * cpukit/score/inline/rtems/score/stack.inl (added) * cpukit/score/inline/rtems/score/states.inl (added) * cpukit/score/inline/rtems/score/sysstate.inl (added) * cpukit/score/inline/rtems/score/thread.inl (added) * cpukit/score/inline/rtems/score/threadmp.inl (added) * cpukit/score/inline/rtems/score/tod.inl (added) * cpukit/score/inline/rtems/score/tqdata.inl (added) * cpukit/score/inline/rtems/score/userext.inl (added) * cpukit/score/inline/rtems/score/watchdog.inl (added) * cpukit/score/inline/rtems/score/wkspace.inl (added) * cpukit/score/macros/README (added) * cpukit/score/macros/rtems/score/README (added) * cpukit/score/macros/rtems/score/address.inl (added) * cpukit/score/macros/rtems/score/chain.inl (added) * cpukit/score/macros/rtems/score/heap.inl (added) * cpukit/score/macros/rtems/score/isr.inl (added) * cpukit/score/macros/rtems/score/mppkt.inl (added) * cpukit/score/macros/rtems/score/object.inl (added) * cpukit/score/macros/rtems/score/objectmp.inl (added) * cpukit/score/macros/rtems/score/priority.inl (added) * cpukit/score/macros/rtems/score/stack.inl (added) * cpukit/score/macros/rtems/score/states.inl (added) * cpukit/score/macros/rtems/score/sysstate.inl (added) * cpukit/score/macros/rtems/score/thread.inl (added) * cpukit/score/macros/rtems/score/threadmp.inl (added) * cpukit/score/macros/rtems/score/tod.inl (added) * cpukit/score/macros/rtems/score/tqdata.inl (added) * cpukit/score/macros/rtems/score/userext.inl (added) * cpukit/score/macros/rtems/score/watchdog.inl (added) * cpukit/score/macros/rtems/score/wkspace.inl (added) * cpukit/score/src/chain.c (added) * cpukit/score/src/coretod.c (added) * cpukit/score/src/heap.c (added) * cpukit/score/src/mpci.c (added) * cpukit/score/src/object.c (added) * cpukit/score/src/objectmp.c (added) * cpukit/score/src/thread.c (added) * cpukit/score/src/threadmp.c (added) * cpukit/score/src/threadq.c (added) * cpukit/score/src/watchdog.c (added) * cpukit/score/src/wkspace.c (added) * testsuites/README (added) * testsuites/libtests/README (added) * testsuites/libtests/stackchk/blow.c (added) * testsuites/libtests/stackchk/init.c (added) * testsuites/libtests/stackchk/stackchk.scn (added) * testsuites/libtests/stackchk/task1.c (added) * testsuites/mptests/README (added) * testsuites/mptests/mp01/init.c (added) * testsuites/mptests/mp01/node1/mp01.doc (added) * testsuites/mptests/mp01/node1/mp01.scn (added) * testsuites/mptests/mp01/node2/mp01.doc (added) * testsuites/mptests/mp01/node2/mp01.scn (added) * testsuites/mptests/mp01/system.h (added) * testsuites/mptests/mp01/task1.c (added) * testsuites/mptests/mp02/init.c (added) * testsuites/mptests/mp02/node1/mp02.doc (added) * testsuites/mptests/mp02/node1/mp02.scn (added) * testsuites/mptests/mp02/node2/mp02.doc (added) * testsuites/mptests/mp02/node2/mp02.scn (added) * testsuites/mptests/mp02/system.h (added) * testsuites/mptests/mp02/task1.c (added) * testsuites/mptests/mp03/delay.c (added) * testsuites/mptests/mp03/init.c (added) * testsuites/mptests/mp03/node1/mp03.doc (added) * testsuites/mptests/mp03/node1/mp03.scn (added) * testsuites/mptests/mp03/node2/mp03.doc (added) * testsuites/mptests/mp03/node2/mp03.scn (added) * testsuites/mptests/mp03/system.h (added) * testsuites/mptests/mp03/task1.c (added) * testsuites/mptests/mp04/init.c (added) * testsuites/mptests/mp04/node1/mp04.doc (added) * testsuites/mptests/mp04/node1/mp04.scn (added) * testsuites/mptests/mp04/node2/mp04.doc (added) * testsuites/mptests/mp04/node2/mp04.scn (added) * testsuites/mptests/mp04/system.h (added) * testsuites/mptests/mp04/task1.c (added) * testsuites/mptests/mp05/asr.c (added) * testsuites/mptests/mp05/init.c (added) * testsuites/mptests/mp05/node1/mp05.doc (added) * testsuites/mptests/mp05/node1/mp05.scn (added) * testsuites/mptests/mp05/node2/mp05.doc (added) * testsuites/mptests/mp05/node2/mp05.scn (added) * testsuites/mptests/mp05/system.h (added) * testsuites/mptests/mp05/task1.c (added) * testsuites/mptests/mp06/init.c (added) * testsuites/mptests/mp06/node1/mp06.doc (added) * testsuites/mptests/mp06/node1/mp06.scn (added) * testsuites/mptests/mp06/node2/mp06.doc (added) * testsuites/mptests/mp06/node2/mp06.scn (added) * testsuites/mptests/mp06/system.h (added) * testsuites/mptests/mp06/task1.c (added) * testsuites/mptests/mp07/init.c (added) * testsuites/mptests/mp07/node1/mp07.doc (added) * testsuites/mptests/mp07/node1/mp07.scn (added) * testsuites/mptests/mp07/node2/mp07.doc (added) * testsuites/mptests/mp07/node2/mp07.scn (added) * testsuites/mptests/mp07/system.h (added) * testsuites/mptests/mp07/task1.c (added) * testsuites/mptests/mp08/init.c (added) * testsuites/mptests/mp08/node1/mp08.doc (added) * testsuites/mptests/mp08/node1/mp08.scn (added) * testsuites/mptests/mp08/node2/mp08.doc (added) * testsuites/mptests/mp08/node2/mp08.scn (added) * testsuites/mptests/mp08/system.h (added) * testsuites/mptests/mp08/task1.c (added) * testsuites/mptests/mp09/init.c (added) * testsuites/mptests/mp09/node1/mp09.doc (added) * testsuites/mptests/mp09/node1/mp09.scn (added) * testsuites/mptests/mp09/node2/mp09.doc (added) * testsuites/mptests/mp09/node2/mp09.scn (added) * testsuites/mptests/mp09/recvmsg.c (added) * testsuites/mptests/mp09/sendmsg.c (added) * testsuites/mptests/mp09/system.h (added) * testsuites/mptests/mp09/task1.c (added) * testsuites/mptests/mp10/init.c (added) * testsuites/mptests/mp10/node1/mp10.doc (added) * testsuites/mptests/mp10/node1/mp10.scn (added) * testsuites/mptests/mp10/node2/mp10.doc (added) * testsuites/mptests/mp10/node2/mp10.scn (added) * testsuites/mptests/mp10/system.h (added) * testsuites/mptests/mp10/task1.c (added) * testsuites/mptests/mp10/task2.c (added) * testsuites/mptests/mp10/task3.c (added) * testsuites/mptests/mp11/init.c (added) * testsuites/mptests/mp11/node1/mp11.doc (added) * testsuites/mptests/mp11/node1/mp11.scn (added) * testsuites/mptests/mp11/node2/mp11.doc (added) * testsuites/mptests/mp11/node2/mp11.scn (added) * testsuites/mptests/mp11/system.h (added) * testsuites/mptests/mp12/init.c (added) * testsuites/mptests/mp12/node1/mp12.doc (added) * testsuites/mptests/mp12/node1/mp12.scn (added) * testsuites/mptests/mp12/node2/mp12.doc (added) * testsuites/mptests/mp12/node2/mp12.scn (added) * testsuites/mptests/mp12/system.h (added) * testsuites/mptests/mp13/init.c (added) * testsuites/mptests/mp13/node1/mp13.doc (added) * testsuites/mptests/mp13/node1/mp13.scn (added) * testsuites/mptests/mp13/node2/mp13.doc (added) * testsuites/mptests/mp13/node2/mp13.scn (added) * testsuites/mptests/mp13/system.h (added) * testsuites/mptests/mp13/task1.c (added) * testsuites/mptests/mp13/task2.c (added) * testsuites/mptests/mp14/delay.c (added) * testsuites/mptests/mp14/evtask1.c (added) * testsuites/mptests/mp14/evtmtask.c (added) * testsuites/mptests/mp14/exit.c (added) * testsuites/mptests/mp14/init.c (added) * testsuites/mptests/mp14/msgtask1.c (added) * testsuites/mptests/mp14/node1/mp14.doc (added) * testsuites/mptests/mp14/node1/mp14.scn (added) * testsuites/mptests/mp14/node2/mp14.doc (added) * testsuites/mptests/mp14/node2/mp14.scn (added) * testsuites/mptests/mp14/pttask1.c (added) * testsuites/mptests/mp14/smtask1.c (added) * testsuites/mptests/mp14/system.h (added) * testsuites/samples/README (added) * testsuites/samples/base_mp/apptask.c (added) * testsuites/samples/base_mp/init.c (added) * testsuites/samples/base_mp/node1/base_mp.doc (added) * testsuites/samples/base_mp/node1/base_mp.scn (added) * testsuites/samples/base_mp/node2/base_mp.doc (added) * testsuites/samples/base_mp/node2/base_mp.scn (added) * testsuites/samples/base_mp/system.h (added) * testsuites/samples/base_sp/apptask.c (added) * testsuites/samples/base_sp/base_sp.doc (added) * testsuites/samples/base_sp/base_sp.scn (added) * testsuites/samples/base_sp/init.c (added) * testsuites/samples/base_sp/system.h (added) * testsuites/samples/cdtest/cdtest.scn (added) * testsuites/samples/cdtest/init.c (added) * testsuites/samples/cdtest/main.cc (added) * testsuites/samples/cdtest/system.h (added) * testsuites/samples/hello/hello.doc (added) * testsuites/samples/hello/hello.scn (added) * testsuites/samples/hello/init.c (added) * testsuites/samples/hello/system.h (added) * testsuites/samples/paranoia/init.c (added) * testsuites/samples/paranoia/paranoia.c (added) * testsuites/samples/paranoia/paranoia.doc (added) * testsuites/samples/paranoia/system.h (added) * testsuites/samples/ticker/init.c (added) * testsuites/samples/ticker/system.h (added) * testsuites/samples/ticker/tasks.c (added) * testsuites/samples/ticker/ticker.doc (added) * testsuites/samples/ticker/ticker.scn (added) * testsuites/sptests/README (added) * testsuites/sptests/sp01/init.c (added) * testsuites/sptests/sp01/sp01.doc (added) * testsuites/sptests/sp01/sp01.scn (added) * testsuites/sptests/sp01/system.h (added) * testsuites/sptests/sp01/task1.c (added) * testsuites/sptests/sp02/init.c (added) * testsuites/sptests/sp02/preempt.c (added) * testsuites/sptests/sp02/sp02.doc (added) * testsuites/sptests/sp02/sp02.scn (added) * testsuites/sptests/sp02/system.h (added) * testsuites/sptests/sp02/task1.c (added) * testsuites/sptests/sp02/task2.c (added) * testsuites/sptests/sp02/task3.c (added) * testsuites/sptests/sp03/init.c (added) * testsuites/sptests/sp03/sp03.doc (added) * testsuites/sptests/sp03/sp03.scn (added) * testsuites/sptests/sp03/system.h (added) * testsuites/sptests/sp03/task1.c (added) * testsuites/sptests/sp03/task2.c (added) * testsuites/sptests/sp04/init.c (added) * testsuites/sptests/sp04/sp04.doc (added) * testsuites/sptests/sp04/sp04.scn (added) * testsuites/sptests/sp04/system.h (added) * testsuites/sptests/sp04/task1.c (added) * testsuites/sptests/sp04/task2.c (added) * testsuites/sptests/sp04/task3.c (added) * testsuites/sptests/sp04/tswitch.c (added) * testsuites/sptests/sp05/init.c (added) * testsuites/sptests/sp05/sp05.doc (added) * testsuites/sptests/sp05/sp05.scn (added) * testsuites/sptests/sp05/system.h (added) * testsuites/sptests/sp05/task1.c (added) * testsuites/sptests/sp05/task2.c (added) * testsuites/sptests/sp05/task3.c (added) * testsuites/sptests/sp06/init.c (added) * testsuites/sptests/sp06/sp06.doc (added) * testsuites/sptests/sp06/sp06.scn (added) * testsuites/sptests/sp06/system.h (added) * testsuites/sptests/sp06/task1.c (added) * testsuites/sptests/sp06/task2.c (added) * testsuites/sptests/sp06/task3.c (added) * testsuites/sptests/sp07/init.c (added) * testsuites/sptests/sp07/sp07.doc (added) * testsuites/sptests/sp07/sp07.scn (added) * testsuites/sptests/sp07/system.h (added) * testsuites/sptests/sp07/task1.c (added) * testsuites/sptests/sp07/task2.c (added) * testsuites/sptests/sp07/task3.c (added) * testsuites/sptests/sp07/task4.c (added) * testsuites/sptests/sp07/taskexit.c (added) * testsuites/sptests/sp07/tcreate.c (added) * testsuites/sptests/sp07/tdelete.c (added) * testsuites/sptests/sp07/trestart.c (added) * testsuites/sptests/sp07/tstart.c (added) * testsuites/sptests/sp08/init.c (added) * testsuites/sptests/sp08/sp08.doc (added) * testsuites/sptests/sp08/sp08.scn (added) * testsuites/sptests/sp08/system.h (added) * testsuites/sptests/sp08/task1.c (added) * testsuites/sptests/sp09/delay.c (added) * testsuites/sptests/sp09/init.c (added) * testsuites/sptests/sp09/isr.c (added) * testsuites/sptests/sp09/screen01.c (added) * testsuites/sptests/sp09/screen02.c (added) * testsuites/sptests/sp09/screen03.c (added) * testsuites/sptests/sp09/screen04.c (added) * testsuites/sptests/sp09/screen05.c (added) * testsuites/sptests/sp09/screen06.c (added) * testsuites/sptests/sp09/screen07.c (added) * testsuites/sptests/sp09/screen08.c (added) * testsuites/sptests/sp09/screen09.c (added) * testsuites/sptests/sp09/screen10.c (added) * testsuites/sptests/sp09/screen11.c (added) * testsuites/sptests/sp09/screen12.c (added) * testsuites/sptests/sp09/screen13.c (added) * testsuites/sptests/sp09/screen14.c (added) * testsuites/sptests/sp09/sp09.doc (added) * testsuites/sptests/sp09/sp09.scn (added) * testsuites/sptests/sp09/system.h (added) * testsuites/sptests/sp09/task1.c (added) * testsuites/sptests/sp09/task2.c (added) * testsuites/sptests/sp09/task3.c (added) * testsuites/sptests/sp09/task4.c (added) * testsuites/sptests/sp11/init.c (added) * testsuites/sptests/sp11/sp11.doc (added) * testsuites/sptests/sp11/sp11.scn (added) * testsuites/sptests/sp11/system.h (added) * testsuites/sptests/sp11/task1.c (added) * testsuites/sptests/sp11/task2.c (added) * testsuites/sptests/sp11/timer.c (added) * testsuites/sptests/sp12/init.c (added) * testsuites/sptests/sp12/pridrv.c (added) * testsuites/sptests/sp12/pritask.c (added) * testsuites/sptests/sp12/sp12.doc (added) * testsuites/sptests/sp12/sp12.scn (added) * testsuites/sptests/sp12/system.h (added) * testsuites/sptests/sp12/task1.c (added) * testsuites/sptests/sp12/task2.c (added) * testsuites/sptests/sp12/task3.c (added) * testsuites/sptests/sp12/task4.c (added) * testsuites/sptests/sp12/task5.c (added) * testsuites/sptests/sp13/fillbuff.c (added) * testsuites/sptests/sp13/init.c (added) * testsuites/sptests/sp13/putbuff.c (added) * testsuites/sptests/sp13/sp13.doc (added) * testsuites/sptests/sp13/sp13.scn (added) * testsuites/sptests/sp13/system.h (added) * testsuites/sptests/sp13/task1.c (added) * testsuites/sptests/sp13/task2.c (added) * testsuites/sptests/sp13/task3.c (added) * testsuites/sptests/sp14/asr.c (added) * testsuites/sptests/sp14/init.c (added) * testsuites/sptests/sp14/sp14.doc (added) * testsuites/sptests/sp14/sp14.scn (added) * testsuites/sptests/sp14/system.h (added) * testsuites/sptests/sp14/task1.c (added) * testsuites/sptests/sp14/task2.c (added) * testsuites/sptests/sp15/init.c (added) * testsuites/sptests/sp15/sp15.doc (added) * testsuites/sptests/sp15/sp15.scn (added) * testsuites/sptests/sp15/system.h (added) * testsuites/sptests/sp15/task1.c (added) * testsuites/sptests/sp16/init.c (added) * testsuites/sptests/sp16/sp16.doc (added) * testsuites/sptests/sp16/sp16.scn (added) * testsuites/sptests/sp16/system.h (added) * testsuites/sptests/sp16/task1.c (added) * testsuites/sptests/sp16/task2.c (added) * testsuites/sptests/sp16/task3.c (added) * testsuites/sptests/sp16/task4.c (added) * testsuites/sptests/sp16/task5.c (added) * testsuites/sptests/sp17/asr.c (added) * testsuites/sptests/sp17/init.c (added) * testsuites/sptests/sp17/sp17.doc (added) * testsuites/sptests/sp17/sp17.scn (added) * testsuites/sptests/sp17/system.h (added) * testsuites/sptests/sp17/task1.c (added) * testsuites/sptests/sp17/task2.c (added) * testsuites/sptests/sp19/first.c (added) * testsuites/sptests/sp19/fptask.c (added) * testsuites/sptests/sp19/fptest.h (added) * testsuites/sptests/sp19/init.c (added) * testsuites/sptests/sp19/inttest.h (added) * testsuites/sptests/sp19/sp19.doc (added) * testsuites/sptests/sp19/sp19.scn (added) * testsuites/sptests/sp19/system.h (added) * testsuites/sptests/sp19/task1.c (added) * testsuites/sptests/sp20/getall.c (added) * testsuites/sptests/sp20/init.c (added) * testsuites/sptests/sp20/sp20.doc (added) * testsuites/sptests/sp20/sp20.scn (added) * testsuites/sptests/sp20/system.h (added) * testsuites/sptests/sp20/task1.c (added) * testsuites/sptests/sp21/init.c (added) * testsuites/sptests/sp21/sp21.doc (added) * testsuites/sptests/sp21/sp21.scn (added) * testsuites/sptests/sp21/system.h (added) * testsuites/sptests/sp21/task1.c (added) * testsuites/sptests/sp22/delay.c (added) * testsuites/sptests/sp22/init.c (added) * testsuites/sptests/sp22/prtime.c (added) * testsuites/sptests/sp22/sp22.doc (added) * testsuites/sptests/sp22/sp22.scn (added) * testsuites/sptests/sp22/system.h (added) * testsuites/sptests/sp22/task1.c (added) * testsuites/sptests/sp23/init.c (added) * testsuites/sptests/sp23/sp23.doc (added) * testsuites/sptests/sp23/sp23.scn (added) * testsuites/sptests/sp23/system.h (added) * testsuites/sptests/sp23/task1.c (added) * testsuites/sptests/sp24/init.c (added) * testsuites/sptests/sp24/resume.c (added) * testsuites/sptests/sp24/sp24.doc (added) * testsuites/sptests/sp24/sp24.scn (added) * testsuites/sptests/sp24/system.h (added) * testsuites/sptests/sp24/task1.c (added) * testsuites/sptests/sp25/init.c (added) * testsuites/sptests/sp25/sp25.doc (added) * testsuites/sptests/sp25/sp25.scn (added) * testsuites/sptests/sp25/system.h (added) * testsuites/sptests/sp25/task1.c (added) * testsuites/sptests/spfatal/fatal.c (added) * testsuites/sptests/spfatal/init.c (added) * testsuites/sptests/spfatal/puterr.c (added) * testsuites/sptests/spfatal/spfatal.doc (added) * testsuites/sptests/spfatal/spfatal.scn (added) * testsuites/sptests/spfatal/system.h (added) * testsuites/sptests/spfatal/task1.c (added) * testsuites/sptests/spsize/getint.c (added) * testsuites/sptests/spsize/init.c (added) * testsuites/sptests/spsize/size.c (added) * testsuites/support/include/tmacros.h (added) * testsuites/tmtests/README (added) * testsuites/tmtests/include/timesys.h (added) * testsuites/tmtests/tm01/system.h (added) * testsuites/tmtests/tm01/task1.c (added) * testsuites/tmtests/tm01/tm01.doc (added) * testsuites/tmtests/tm02/system.h (added) * testsuites/tmtests/tm02/task1.c (added) * testsuites/tmtests/tm02/tm02.doc (added) * testsuites/tmtests/tm03/system.h (added) * testsuites/tmtests/tm03/task1.c (added) * testsuites/tmtests/tm03/tm03.doc (added) * testsuites/tmtests/tm04/system.h (added) * testsuites/tmtests/tm04/task1.c (added) * testsuites/tmtests/tm04/tm04.doc (added) * testsuites/tmtests/tm05/system.h (added) * testsuites/tmtests/tm05/task1.c (added) * testsuites/tmtests/tm05/tm05.doc (added) * testsuites/tmtests/tm06/system.h (added) * testsuites/tmtests/tm06/task1.c (added) * testsuites/tmtests/tm06/tm06.doc (added) * testsuites/tmtests/tm07/system.h (added) * testsuites/tmtests/tm07/task1.c (added) * testsuites/tmtests/tm07/tm07.doc (added) * testsuites/tmtests/tm08/system.h (added) * testsuites/tmtests/tm08/task1.c (added) * testsuites/tmtests/tm08/tm08.doc (added) * testsuites/tmtests/tm09/system.h (added) * testsuites/tmtests/tm09/task1.c (added) * testsuites/tmtests/tm09/tm09.doc (added) * testsuites/tmtests/tm10/system.h (added) * testsuites/tmtests/tm10/task1.c (added) * testsuites/tmtests/tm10/tm10.doc (added) * testsuites/tmtests/tm11/system.h (added) * testsuites/tmtests/tm11/task1.c (added) * testsuites/tmtests/tm11/tm11.doc (added) * testsuites/tmtests/tm12/system.h (added) * testsuites/tmtests/tm12/task1.c (added) * testsuites/tmtests/tm12/tm12.doc (added) * testsuites/tmtests/tm13/system.h (added) * testsuites/tmtests/tm13/task1.c (added) * testsuites/tmtests/tm13/tm13.doc (added) * testsuites/tmtests/tm14/system.h (added) * testsuites/tmtests/tm14/task1.c (added) * testsuites/tmtests/tm14/tm14.doc (added) * testsuites/tmtests/tm15/system.h (added) * testsuites/tmtests/tm15/task1.c (added) * testsuites/tmtests/tm15/tm15.doc (added) * testsuites/tmtests/tm16/system.h (added) * testsuites/tmtests/tm16/task1.c (added) * testsuites/tmtests/tm16/tm16.doc (added) * testsuites/tmtests/tm17/system.h (added) * testsuites/tmtests/tm17/task1.c (added) * testsuites/tmtests/tm17/tm17.doc (added) * testsuites/tmtests/tm18/system.h (added) * testsuites/tmtests/tm18/task1.c (added) * testsuites/tmtests/tm18/tm18.doc (added) * testsuites/tmtests/tm19/system.h (added) * testsuites/tmtests/tm19/task1.c (added) * testsuites/tmtests/tm19/tm19.doc (added) * testsuites/tmtests/tm20/system.h (added) * testsuites/tmtests/tm20/task1.c (added) * testsuites/tmtests/tm20/tm20.doc (added) * testsuites/tmtests/tm21/system.h (added) * testsuites/tmtests/tm21/task1.c (added) * testsuites/tmtests/tm21/tm21.doc (added) * testsuites/tmtests/tm22/system.h (added) * testsuites/tmtests/tm22/task1.c (added) * testsuites/tmtests/tm22/tm22.doc (added) * testsuites/tmtests/tm23/system.h (added) * testsuites/tmtests/tm23/task1.c (added) * testsuites/tmtests/tm23/tm23.doc (added) * testsuites/tmtests/tm24/system.h (added) * testsuites/tmtests/tm24/task1.c (added) * testsuites/tmtests/tm24/tm24.doc (added) * testsuites/tmtests/tm25/system.h (added) * testsuites/tmtests/tm25/task1.c (added) * testsuites/tmtests/tm25/tm25.doc (added) * testsuites/tmtests/tm26/fptest.h (added) * testsuites/tmtests/tm26/system.h (added) * testsuites/tmtests/tm26/task1.c (added) * testsuites/tmtests/tm26/tm26.doc (added) * testsuites/tmtests/tm27/system.h (added) * testsuites/tmtests/tm27/task1.c (added) * testsuites/tmtests/tm27/tm27.doc (added) * testsuites/tmtests/tm28/system.h (added) * testsuites/tmtests/tm28/task1.c (added) * testsuites/tmtests/tm28/tm28.doc (added) * testsuites/tmtests/tm29/system.h (added) * testsuites/tmtests/tm29/task1.c (added) * testsuites/tmtests/tm29/tm29.doc (added) * testsuites/tmtests/tmck/system.h (added) * testsuites/tmtests/tmck/task1.c (added) * testsuites/tmtests/tmck/tmck.doc (added) * testsuites/tmtests/tmoverhd/dumrtems.h (added) * testsuites/tmtests/tmoverhd/empty.c (added) * testsuites/tmtests/tmoverhd/system.h (added) * testsuites/tmtests/tmoverhd/testtask.c (added) * testsuites/tmtests/tmoverhd/tmoverhd.doc (added) * tools/build/README (added) * tools/build/cklength.c (added) * tools/build/eolstrip.c (added) * tools/build/packhex.c (added) * tools/build/scripts/README (added) * tools/build/src/cklength.c (added) * tools/build/src/eolstrip.c (added) * tools/build/src/packhex.c (added) * tools/build/src/unhex.c (added) * tools/build/unhex.c (added) * tools/cpu/hppa1.1/genoffsets.c (added) * tools/update/310_to_320_list (added) * tools/update/README (added) Initial revision
