# # ChangeLog for testsuites/samples/base_mp in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 00:40:38 Tue, 05 Sep 2000 16:11:24 GMT Joel Sherrill [6212465d] * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) 2000-09-04 Ralf Corsepius * ... Thu, 13 Jul 2000 15:05:38 GMT Joel Sherrill [b8a30d07] * Makefile.am (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (added) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/h8300/h8sim/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/i960sim/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/libmisc/configure.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/itrontests/itrontests.am (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/libtests/libtests.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mptests.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxtests.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/sample.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sptests.am (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/tmitrontests.am (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tmtests/tmtests.am (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * testsuites/itrontests/itrontests.am (modified) * testsuites/libtests/libtests.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mptests.am (modified) * testsuites/psxtests/psxtests.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/sample.am (modified) * testsuites/sptests/sptests.am (modified) * testsuites/tmitrontests/tmitrontests.am (modified) * testsuites/tmtests/tmtests.am (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Thu, 13 Apr 2000 14:37:14 GMT Joel Sherrill [bf85b19] * c/.cvsignore (added) * c/make/.cvsignore (added) * c/src/.cvsignore (added) * c/src/exec/itron/.cvsignore (added) * c/src/exec/itron/include/.cvsignore (added) * c/src/exec/itron/include/itronsys/.cvsignore (added) * c/src/exec/itron/include/rtems/.cvsignore (added) * c/src/exec/itron/include/rtems/itron/.cvsignore (added) * c/src/exec/itron/inline/.cvsignore (added) * c/src/exec/itron/inline/rtems/.cvsignore (added) * c/src/exec/itron/inline/rtems/itron/.cvsignore (added) * c/src/exec/itron/src/.cvsignore (added) * c/src/exec/libcsupport/.cvsignore (added) * c/src/exec/libnetworking/.cvsignore (added) * c/src/exec/libnetworking/arpa/.cvsignore (added) * c/src/exec/libnetworking/kern/.cvsignore (added) * c/src/exec/libnetworking/lib/.cvsignore (added) * c/src/exec/libnetworking/libc/.cvsignore (added) * c/src/exec/libnetworking/machine/.cvsignore (added) * c/src/exec/libnetworking/net/.cvsignore (added) * c/src/exec/libnetworking/netinet/.cvsignore (added) * c/src/exec/libnetworking/nfs/.cvsignore (added) * c/src/exec/libnetworking/rtems/.cvsignore (added) * c/src/exec/libnetworking/sys/.cvsignore (added) * c/src/exec/libnetworking/vm/.cvsignore (added) * c/src/exec/libnetworking/wrapup/.cvsignore (added) * c/src/exec/librpc/.cvsignore (added) * c/src/exec/librpc/include/.cvsignore (added) * c/src/exec/librpc/include/rpc/.cvsignore (added) * c/src/exec/librpc/src/.cvsignore (added) * c/src/exec/posix/.cvsignore (added) * c/src/exec/posix/include/.cvsignore (added) * c/src/exec/posix/include/rtems/.cvsignore (added) * c/src/exec/posix/include/rtems/posix/.cvsignore (added) * c/src/exec/posix/include/sys/.cvsignore (added) * c/src/exec/posix/inline/.cvsignore (added) * c/src/exec/posix/inline/rtems/.cvsignore (added) * c/src/exec/posix/inline/rtems/posix/.cvsignore (added) * c/src/exec/posix/macros/.cvsignore (added) * c/src/exec/posix/macros/rtems/.cvsignore (added) * c/src/exec/posix/macros/rtems/posix/.cvsignore (added) * c/src/exec/posix/optman/.cvsignore (added) * c/src/exec/posix/src/.cvsignore (added) * c/src/exec/rtems/.cvsignore (added) * c/src/exec/rtems/include/.cvsignore (added) * c/src/exec/rtems/include/rtems/.cvsignore (added) * c/src/exec/rtems/include/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/inline/.cvsignore (added) * c/src/exec/rtems/inline/rtems/.cvsignore (added) * c/src/exec/rtems/inline/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/macros/.cvsignore (added) * c/src/exec/rtems/macros/rtems/.cvsignore (added) * c/src/exec/rtems/macros/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/optman/.cvsignore (added) * c/src/exec/rtems/src/.cvsignore (added) * c/src/exec/sapi/.cvsignore (added) * c/src/exec/sapi/include/.cvsignore (added) * c/src/exec/sapi/include/rtems/.cvsignore (added) * c/src/exec/sapi/inline/.cvsignore (added) * c/src/exec/sapi/inline/rtems/.cvsignore (added) * c/src/exec/sapi/macros/.cvsignore (added) * c/src/exec/sapi/macros/rtems/.cvsignore (added) * c/src/exec/sapi/optman/.cvsignore (added) * c/src/exec/sapi/src/.cvsignore (added) * c/src/exec/score/cpu/a29k/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i386/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i960/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/m68k/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/shared/.cvsignore (added) * c/src/lib/.cvsignore (added) * c/src/lib/libbsp/.cvsignore (added) * c/src/lib/libbsp/powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (added) * c/src/lib/libbsp/sh/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/shared/.cvsignore (added) * c/src/lib/libbsp/shmdr/.cvsignore (added) * c/src/lib/libbsp/sparc/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/clock/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/console/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/gnatsupp/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/start/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/startup/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/timer/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/wrapup/.cvsignore (added) * c/src/lib/libbsp/unix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/clock/.cvsignore (added) * c/src/lib/libbsp/unix/posix/console/.cvsignore (added) * c/src/lib/libbsp/unix/posix/include/.cvsignore (added) * c/src/lib/libbsp/unix/posix/shmsupp/.cvsignore (added) * c/src/lib/libbsp/unix/posix/startup/.cvsignore (added) * c/src/lib/libbsp/unix/posix/timer/.cvsignore (added) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (added) * c/src/lib/libbsp/unix/posix/wrapup/.cvsignore (added) * c/src/lib/libc/.cvsignore (added) * c/src/lib/libcpu/.cvsignore (added) * c/src/lib/libcpu/a29k/.cvsignore (added) * c/src/lib/libcpu/a29k/clock/.cvsignore (added) * c/src/lib/libcpu/a29k/timer/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/clock/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/include/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/milli/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/semaphore/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/timer/.cvsignore (added) * c/src/lib/libcpu/i386/.cvsignore (added) * c/src/lib/libcpu/m68k/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (added) * c/src/lib/libcpu/mips/.cvsignore (added) * c/src/lib/libcpu/mips/clock/.cvsignore (added) * c/src/lib/libcpu/mips/timer/.cvsignore (added) * c/src/lib/libcpu/mips64orion/.cvsignore (added) * c/src/lib/libcpu/mips64orion/clock/.cvsignore (added) * c/src/lib/libcpu/mips64orion/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/shared/.cvsignore (added) * c/src/lib/libcpu/powerpc/wrapup/.cvsignore (added) * c/src/lib/libcpu/sh/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (added) * c/src/lib/libcpu/sparc/.cvsignore (added) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (added) * c/src/lib/libcpu/sparc/syscall/.cvsignore (added) * c/src/libchip/.cvsignore (added) * c/src/libchip/network/.cvsignore (added) * c/src/libchip/rtc/.cvsignore (added) * c/src/libchip/serial/.cvsignore (added) * c/src/libchip/shmdr/.cvsignore (added) * c/src/libmisc/.cvsignore (added) * c/src/libmisc/cpuuse/.cvsignore (added) * c/src/libmisc/dummy/.cvsignore (added) * c/src/libmisc/dumpbuf/.cvsignore (added) * c/src/libmisc/monitor/.cvsignore (added) * c/src/libmisc/rtmonuse/.cvsignore (added) * c/src/libmisc/stackchk/.cvsignore (added) * c/src/libmisc/untar/.cvsignore (added) * c/src/libmisc/wrapup/.cvsignore (added) * c/src/libnetworking/.cvsignore (added) * c/src/libnetworking/arpa/.cvsignore (added) * c/src/libnetworking/include/.cvsignore (added) * c/src/libnetworking/kern/.cvsignore (added) * c/src/libnetworking/lib/.cvsignore (added) * c/src/libnetworking/libc/.cvsignore (added) * c/src/libnetworking/machine/.cvsignore (added) * c/src/libnetworking/net/.cvsignore (added) * c/src/libnetworking/netinet/.cvsignore (added) * c/src/libnetworking/nfs/.cvsignore (added) * c/src/libnetworking/pppd/.cvsignore (added) * c/src/libnetworking/rtems/.cvsignore (added) * c/src/libnetworking/rtems_servers/.cvsignore (added) * c/src/libnetworking/rtems_webserver/.cvsignore (added) * c/src/libnetworking/sys/.cvsignore (added) * c/src/libnetworking/vm/.cvsignore (added) * c/src/libnetworking/wrapup/.cvsignore (added) * c/src/librdbg/.cvsignore (added) * c/src/librdbg/include/.cvsignore (added) * c/src/librdbg/include/rdbg/.cvsignore (added) * c/src/librdbg/include/rdbg/i386/.cvsignore (added) * c/src/librdbg/include/rdbg/powerpc/.cvsignore (added) * c/src/librdbg/src/.cvsignore (added) * c/src/librdbg/src/i386/.cvsignore (added) * c/src/librdbg/src/i386/any/.cvsignore (added) * c/src/librdbg/src/powerpc/.cvsignore (added) * c/src/librdbg/src/powerpc/mcp750/.cvsignore (added) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (added) * c/src/librpc/.cvsignore (added) * c/src/librpc/include/.cvsignore (added) * c/src/librpc/include/rpc/.cvsignore (added) * c/src/librpc/src/.cvsignore (added) * c/src/librtems++/.cvsignore (added) * c/src/librtems++/include/.cvsignore (added) * c/src/librtems++/include/rtems++/.cvsignore (added) * c/src/librtems++/src/.cvsignore (added) * c/src/make/.cvsignore (added) * c/src/make/compilers/.cvsignore (added) * c/src/make/custom/.cvsignore (added) * c/src/tests/.cvsignore (added) * c/src/tests/itrontests/.cvsignore (added) * c/src/tests/itrontests/itronhello/.cvsignore (added) * c/src/tests/itrontests/itronmbf01/.cvsignore (added) * c/src/tests/itrontests/itronmbox01/.cvsignore (added) * c/src/tests/itrontests/itronsem01/.cvsignore (added) * c/src/tests/itrontests/itrontask01/.cvsignore (added) * c/src/tests/itrontests/itrontask02/.cvsignore (added) * c/src/tests/itrontests/itrontask03/.cvsignore (added) * c/src/tests/itrontests/itrontask04/.cvsignore (added) * c/src/tests/itrontests/itrontime01/.cvsignore (added) * c/src/tests/libtests/.cvsignore (added) * c/src/tests/libtests/cpuuse/.cvsignore (added) * c/src/tests/libtests/malloctest/.cvsignore (added) * c/src/tests/libtests/monitor/.cvsignore (added) * c/src/tests/libtests/putenvtest/.cvsignore (added) * c/src/tests/libtests/rtems++/.cvsignore (added) * c/src/tests/libtests/rtmonuse/.cvsignore (added) * c/src/tests/libtests/stackchk/.cvsignore (added) * c/src/tests/libtests/termios/.cvsignore (added) * c/src/tests/mptests/.cvsignore (added) * c/src/tests/mptests/mp01/.cvsignore (added) * c/src/tests/mptests/mp01/node1/.cvsignore (added) * c/src/tests/mptests/mp01/node2/.cvsignore (added) * c/src/tests/mptests/mp02/.cvsignore (added) * c/src/tests/mptests/mp02/node1/.cvsignore (added) * c/src/tests/mptests/mp02/node2/.cvsignore (added) * c/src/tests/mptests/mp03/.cvsignore (added) * c/src/tests/mptests/mp03/node1/.cvsignore (added) * c/src/tests/mptests/mp03/node2/.cvsignore (added) * c/src/tests/mptests/mp04/.cvsignore (added) * c/src/tests/mptests/mp04/node1/.cvsignore (added) * c/src/tests/mptests/mp04/node2/.cvsignore (added) * c/src/tests/mptests/mp05/.cvsignore (added) * c/src/tests/mptests/mp05/node1/.cvsignore (added) * c/src/tests/mptests/mp05/node2/.cvsignore (added) * c/src/tests/mptests/mp06/.cvsignore (added) * c/src/tests/mptests/mp06/node1/.cvsignore (added) * c/src/tests/mptests/mp06/node2/.cvsignore (added) * c/src/tests/mptests/mp07/.cvsignore (added) * c/src/tests/mptests/mp07/node1/.cvsignore (added) * c/src/tests/mptests/mp07/node2/.cvsignore (added) * c/src/tests/mptests/mp08/.cvsignore (added) * c/src/tests/mptests/mp08/node1/.cvsignore (added) * c/src/tests/mptests/mp08/node2/.cvsignore (added) * c/src/tests/mptests/mp09/.cvsignore (added) * c/src/tests/mptests/mp09/node1/.cvsignore (added) * c/src/tests/mptests/mp09/node2/.cvsignore (added) * c/src/tests/mptests/mp10/.cvsignore (added) * c/src/tests/mptests/mp10/node1/.cvsignore (added) * c/src/tests/mptests/mp10/node2/.cvsignore (added) * c/src/tests/mptests/mp11/.cvsignore (added) * c/src/tests/mptests/mp11/node1/.cvsignore (added) * c/src/tests/mptests/mp11/node2/.cvsignore (added) * c/src/tests/mptests/mp12/.cvsignore (added) * c/src/tests/mptests/mp12/node1/.cvsignore (added) * c/src/tests/mptests/mp12/node2/.cvsignore (added) * c/src/tests/mptests/mp13/.cvsignore (added) * c/src/tests/mptests/mp13/node1/.cvsignore (added) * c/src/tests/mptests/mp13/node2/.cvsignore (added) * c/src/tests/mptests/mp14/.cvsignore (added) * c/src/tests/mptests/mp14/node1/.cvsignore (added) * c/src/tests/mptests/mp14/node2/.cvsignore (added) * c/src/tests/psxtests/.cvsignore (added) * c/src/tests/psxtests/include/.cvsignore (added) * c/src/tests/psxtests/psx01/.cvsignore (added) * c/src/tests/psxtests/psx02/.cvsignore (added) * c/src/tests/psxtests/psx03/.cvsignore (added) * c/src/tests/psxtests/psx04/.cvsignore (added) * c/src/tests/psxtests/psx05/.cvsignore (added) * c/src/tests/psxtests/psx06/.cvsignore (added) * c/src/tests/psxtests/psx07/.cvsignore (added) * c/src/tests/psxtests/psx08/.cvsignore (added) * c/src/tests/psxtests/psx09/.cvsignore (added) * c/src/tests/psxtests/psx10/.cvsignore (added) * c/src/tests/psxtests/psx11/.cvsignore (added) * c/src/tests/psxtests/psx12/.cvsignore (added) * c/src/tests/psxtests/psx13/.cvsignore (added) * c/src/tests/psxtests/psxcancel/.cvsignore (added) * c/src/tests/psxtests/psxfile01/.cvsignore (added) * c/src/tests/psxtests/psxhdrs/.cvsignore (added) * c/src/tests/psxtests/psxmount/.cvsignore (added) * c/src/tests/psxtests/psxmsgq01/.cvsignore (added) * c/src/tests/psxtests/psxreaddir/.cvsignore (added) * c/src/tests/psxtests/psxsem01/.cvsignore (added) * c/src/tests/psxtests/psxstat/.cvsignore (added) * c/src/tests/psxtests/psxtime/.cvsignore (added) * c/src/tests/psxtests/psxtimer/.cvsignore (added) * c/src/tests/samples/.cvsignore (added) * c/src/tests/samples/base_mp/.cvsignore (added) * c/src/tests/samples/base_mp/node1/.cvsignore (added) * c/src/tests/samples/base_mp/node2/.cvsignore (added) * c/src/tests/samples/base_sp/.cvsignore (added) * c/src/tests/samples/cdtest/.cvsignore (added) * c/src/tests/samples/hello/.cvsignore (added) * c/src/tests/samples/minimum/.cvsignore (added) * c/src/tests/samples/paranoia/.cvsignore (added) * c/src/tests/samples/ticker/.cvsignore (added) * c/src/tests/samples/unlimited/.cvsignore (added) * c/src/tests/sptests/.cvsignore (added) * c/src/tests/sptests/sp01/.cvsignore (added) * c/src/tests/sptests/sp02/.cvsignore (added) * c/src/tests/sptests/sp03/.cvsignore (added) * c/src/tests/sptests/sp04/.cvsignore (added) * c/src/tests/sptests/sp05/.cvsignore (added) * c/src/tests/sptests/sp06/.cvsignore (added) * c/src/tests/sptests/sp07/.cvsignore (added) * c/src/tests/sptests/sp08/.cvsignore (added) * c/src/tests/sptests/sp09/.cvsignore (added) * c/src/tests/sptests/sp11/.cvsignore (added) * c/src/tests/sptests/sp12/.cvsignore (added) * c/src/tests/sptests/sp13/.cvsignore (added) * c/src/tests/sptests/sp14/.cvsignore (added) * c/src/tests/sptests/sp15/.cvsignore (added) * c/src/tests/sptests/sp16/.cvsignore (added) * c/src/tests/sptests/sp17/.cvsignore (added) * c/src/tests/sptests/sp19/.cvsignore (added) * c/src/tests/sptests/sp20/.cvsignore (added) * c/src/tests/sptests/sp21/.cvsignore (added) * c/src/tests/sptests/sp22/.cvsignore (added) * c/src/tests/sptests/sp23/.cvsignore (added) * c/src/tests/sptests/sp24/.cvsignore (added) * c/src/tests/sptests/sp25/.cvsignore (added) * c/src/tests/sptests/sp26/.cvsignore (added) * c/src/tests/sptests/sp27/.cvsignore (added) * c/src/tests/sptests/sp28/.cvsignore (added) * c/src/tests/sptests/sp29/.cvsignore (added) * c/src/tests/sptests/spfatal/.cvsignore (added) * c/src/tests/sptests/spsize/.cvsignore (added) * c/src/tests/support/.cvsignore (added) * c/src/tests/support/include/.cvsignore (added) * c/src/tests/support/stubdr/.cvsignore (added) * c/src/tests/support/wrapup/.cvsignore (added) * c/src/tests/tmitrontests/.cvsignore (added) * c/src/tests/tmitrontests/include/.cvsignore (added) * c/src/tests/tmitrontests/tmitronsem01/.cvsignore (added) * c/src/tests/tmtests/.cvsignore (added) * c/src/tests/tmtests/include/.cvsignore (added) * c/src/tests/tmtests/tm01/.cvsignore (added) * c/src/tests/tmtests/tm02/.cvsignore (added) * c/src/tests/tmtests/tm03/.cvsignore (added) * c/src/tests/tmtests/tm04/.cvsignore (added) * c/src/tests/tmtests/tm05/.cvsignore (added) * c/src/tests/tmtests/tm06/.cvsignore (added) * c/src/tests/tmtests/tm07/.cvsignore (added) * c/src/tests/tmtests/tm08/.cvsignore (added) * c/src/tests/tmtests/tm09/.cvsignore (added) * c/src/tests/tmtests/tm10/.cvsignore (added) * c/src/tests/tmtests/tm11/.cvsignore (added) * c/src/tests/tmtests/tm12/.cvsignore (added) * c/src/tests/tmtests/tm13/.cvsignore (added) * c/src/tests/tmtests/tm14/.cvsignore (added) * c/src/tests/tmtests/tm15/.cvsignore (added) * c/src/tests/tmtests/tm16/.cvsignore (added) * c/src/tests/tmtests/tm17/.cvsignore (added) * c/src/tests/tmtests/tm18/.cvsignore (added) * c/src/tests/tmtests/tm19/.cvsignore (added) * c/src/tests/tmtests/tm20/.cvsignore (added) * c/src/tests/tmtests/tm21/.cvsignore (added) * c/src/tests/tmtests/tm22/.cvsignore (added) * c/src/tests/tmtests/tm23/.cvsignore (added) * c/src/tests/tmtests/tm24/.cvsignore (added) * c/src/tests/tmtests/tm25/.cvsignore (added) * c/src/tests/tmtests/tm26/.cvsignore (added) * c/src/tests/tmtests/tm27/.cvsignore (added) * c/src/tests/tmtests/tm28/.cvsignore (added) * c/src/tests/tmtests/tm29/.cvsignore (added) * c/src/tests/tmtests/tmck/.cvsignore (added) * c/src/tests/tmtests/tmoverhd/.cvsignore (added) * c/src/tests/tools/.cvsignore (added) * c/src/tests/tools/generic/.cvsignore (added) * c/src/wrapup/.cvsignore (added) * cpukit/httpd/.cvsignore (added) * cpukit/itron/.cvsignore (added) * cpukit/itron/include/.cvsignore (added) * cpukit/itron/include/itronsys/.cvsignore (added) * cpukit/itron/include/rtems/.cvsignore (added) * cpukit/itron/include/rtems/itron/.cvsignore (added) * cpukit/itron/inline/.cvsignore (added) * cpukit/itron/inline/rtems/.cvsignore (added) * cpukit/itron/inline/rtems/itron/.cvsignore (added) * cpukit/itron/src/.cvsignore (added) * cpukit/libcsupport/.cvsignore (added) * cpukit/libmisc/.cvsignore (added) * cpukit/libmisc/cpuuse/.cvsignore (added) * cpukit/libmisc/dummy/.cvsignore (added) * cpukit/libmisc/dumpbuf/.cvsignore (added) * cpukit/libmisc/monitor/.cvsignore (added) * cpukit/libmisc/rtmonuse/.cvsignore (added) * cpukit/libmisc/stackchk/.cvsignore (added) * cpukit/libmisc/untar/.cvsignore (added) * cpukit/libmisc/wrapup/.cvsignore (added) * cpukit/libnetworking/.cvsignore (added) * cpukit/libnetworking/arpa/.cvsignore (added) * cpukit/libnetworking/kern/.cvsignore (added) * cpukit/libnetworking/lib/.cvsignore (added) * cpukit/libnetworking/libc/.cvsignore (added) * cpukit/libnetworking/machine/.cvsignore (added) * cpukit/libnetworking/net/.cvsignore (added) * cpukit/libnetworking/netinet/.cvsignore (added) * cpukit/libnetworking/nfs/.cvsignore (added) * cpukit/libnetworking/rtems/.cvsignore (added) * cpukit/libnetworking/sys/.cvsignore (added) * cpukit/libnetworking/vm/.cvsignore (added) * cpukit/libnetworking/wrapup/.cvsignore (added) * cpukit/librpc/.cvsignore (added) * cpukit/librpc/include/.cvsignore (added) * cpukit/librpc/include/rpc/.cvsignore (added) * cpukit/librpc/src/.cvsignore (added) * cpukit/posix/.cvsignore (added) * cpukit/posix/include/.cvsignore (added) * cpukit/posix/include/rtems/.cvsignore (added) * cpukit/posix/include/rtems/posix/.cvsignore (added) * cpukit/posix/inline/.cvsignore (added) * cpukit/posix/inline/rtems/.cvsignore (added) * cpukit/posix/inline/rtems/posix/.cvsignore (added) * cpukit/posix/macros/.cvsignore (added) * cpukit/posix/macros/rtems/.cvsignore (added) * cpukit/posix/macros/rtems/posix/.cvsignore (added) * cpukit/posix/src/.cvsignore (added) * cpukit/rtems/.cvsignore (added) * cpukit/rtems/include/.cvsignore (added) * cpukit/rtems/include/rtems/.cvsignore (added) * cpukit/rtems/include/rtems/rtems/.cvsignore (added) * cpukit/rtems/inline/.cvsignore (added) * cpukit/rtems/inline/rtems/.cvsignore (added) * cpukit/rtems/inline/rtems/rtems/.cvsignore (added) * cpukit/rtems/macros/.cvsignore (added) * cpukit/rtems/macros/rtems/.cvsignore (added) * cpukit/rtems/macros/rtems/rtems/.cvsignore (added) * cpukit/rtems/src/.cvsignore (added) * cpukit/sapi/.cvsignore (added) * cpukit/sapi/include/.cvsignore (added) * cpukit/sapi/include/rtems/.cvsignore (added) * cpukit/sapi/inline/.cvsignore (added) * cpukit/sapi/inline/rtems/.cvsignore (added) * cpukit/sapi/macros/.cvsignore (added) * cpukit/sapi/macros/rtems/.cvsignore (added) * cpukit/sapi/src/.cvsignore (added) * cpukit/score/cpu/a29k/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/score/.cvsignore (added) * cpukit/score/cpu/hppa1.1/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * cpukit/score/cpu/i386/.cvsignore (added) * cpukit/score/cpu/i386/rtems/.cvsignore (added) * cpukit/score/cpu/i386/rtems/score/.cvsignore (added) * cpukit/score/cpu/i960/.cvsignore (added) * cpukit/score/cpu/i960/rtems/.cvsignore (added) * cpukit/score/cpu/i960/rtems/score/.cvsignore (added) * cpukit/score/cpu/m68k/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips/.cvsignore (added) * cpukit/score/cpu/mips/rtems/.cvsignore (added) * cpukit/score/cpu/mips/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips64orion/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/score/.cvsignore (added) * cpukit/score/cpu/no_cpu/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (added) * doc/.cvsignore (added) * make/.cvsignore (added) * make/Templates/.cvsignore (added) * make/compilers/.cvsignore (added) * make/custom/.cvsignore (added) * scripts-ada/.cvsignore (added) * scripts-ada/binutils/.cvsignore (added) * scripts-ada/gdb/.cvsignore (added) * scripts-ada/gnatnewlib/.cvsignore (added) * scripts/.cvsignore (added) * scripts/binutils/.cvsignore (added) * scripts/gccnewlib/.cvsignore (added) * scripts/gdb/.cvsignore (added) * scripts/rtems/.cvsignore (added) * testsuites/.cvsignore (added) * testsuites/itrontests/.cvsignore (added) * testsuites/itrontests/itronhello/.cvsignore (added) * testsuites/itrontests/itronmbf01/.cvsignore (added) * testsuites/itrontests/itronmbox01/.cvsignore (added) * testsuites/itrontests/itronsem01/.cvsignore (added) * testsuites/itrontests/itrontask01/.cvsignore (added) * testsuites/itrontests/itrontask02/.cvsignore (added) * testsuites/itrontests/itrontask03/.cvsignore (added) * testsuites/itrontests/itrontask04/.cvsignore (added) * testsuites/itrontests/itrontime01/.cvsignore (added) * testsuites/libtests/.cvsignore (added) * testsuites/libtests/cpuuse/.cvsignore (added) * testsuites/libtests/malloctest/.cvsignore (added) * testsuites/libtests/monitor/.cvsignore (added) * testsuites/libtests/putenvtest/.cvsignore (added) * testsuites/libtests/rtems++/.cvsignore (added) * testsuites/libtests/rtmonuse/.cvsignore (added) * testsuites/libtests/stackchk/.cvsignore (added) * testsuites/libtests/termios/.cvsignore (added) * testsuites/mptests/.cvsignore (added) * testsuites/mptests/mp01/.cvsignore (added) * testsuites/mptests/mp01/node1/.cvsignore (added) * testsuites/mptests/mp01/node2/.cvsignore (added) * testsuites/mptests/mp02/.cvsignore (added) * testsuites/mptests/mp02/node1/.cvsignore (added) * testsuites/mptests/mp02/node2/.cvsignore (added) * testsuites/mptests/mp03/.cvsignore (added) * testsuites/mptests/mp03/node1/.cvsignore (added) * testsuites/mptests/mp03/node2/.cvsignore (added) * testsuites/mptests/mp04/.cvsignore (added) * testsuites/mptests/mp04/node1/.cvsignore (added) * testsuites/mptests/mp04/node2/.cvsignore (added) * testsuites/mptests/mp05/.cvsignore (added) * testsuites/mptests/mp05/node1/.cvsignore (added) * testsuites/mptests/mp05/node2/.cvsignore (added) * testsuites/mptests/mp06/.cvsignore (added) * testsuites/mptests/mp06/node1/.cvsignore (added) * testsuites/mptests/mp06/node2/.cvsignore (added) * testsuites/mptests/mp07/.cvsignore (added) * testsuites/mptests/mp07/node1/.cvsignore (added) * testsuites/mptests/mp07/node2/.cvsignore (added) * testsuites/mptests/mp08/.cvsignore (added) * testsuites/mptests/mp08/node1/.cvsignore (added) * testsuites/mptests/mp08/node2/.cvsignore (added) * testsuites/mptests/mp09/.cvsignore (added) * testsuites/mptests/mp09/node1/.cvsignore (added) * testsuites/mptests/mp09/node2/.cvsignore (added) * testsuites/mptests/mp10/.cvsignore (added) * testsuites/mptests/mp10/node1/.cvsignore (added) * testsuites/mptests/mp10/node2/.cvsignore (added) * testsuites/mptests/mp11/.cvsignore (added) * testsuites/mptests/mp11/node1/.cvsignore (added) * testsuites/mptests/mp11/node2/.cvsignore (added) * testsuites/mptests/mp12/.cvsignore (added) * testsuites/mptests/mp12/node1/.cvsignore (added) * testsuites/mptests/mp12/node2/.cvsignore (added) * testsuites/mptests/mp13/.cvsignore (added) * testsuites/mptests/mp13/node1/.cvsignore (added) * testsuites/mptests/mp13/node2/.cvsignore (added) * testsuites/mptests/mp14/.cvsignore (added) * testsuites/mptests/mp14/node1/.cvsignore (added) * testsuites/mptests/mp14/node2/.cvsignore (added) * testsuites/psxtests/.cvsignore (added) * testsuites/psxtests/include/.cvsignore (added) * testsuites/psxtests/psx01/.cvsignore (added) * testsuites/psxtests/psx02/.cvsignore (added) * testsuites/psxtests/psx03/.cvsignore (added) * testsuites/psxtests/psx04/.cvsignore (added) * testsuites/psxtests/psx05/.cvsignore (added) * testsuites/psxtests/psx06/.cvsignore (added) * testsuites/psxtests/psx07/.cvsignore (added) * testsuites/psxtests/psx08/.cvsignore (added) * testsuites/psxtests/psx09/.cvsignore (added) * testsuites/psxtests/psx10/.cvsignore (added) * testsuites/psxtests/psx11/.cvsignore (added) * testsuites/psxtests/psx12/.cvsignore (added) * testsuites/psxtests/psx13/.cvsignore (added) * testsuites/psxtests/psxcancel/.cvsignore (added) * testsuites/psxtests/psxfile01/.cvsignore (added) * testsuites/psxtests/psxhdrs/.cvsignore (added) * testsuites/psxtests/psxmount/.cvsignore (added) * testsuites/psxtests/psxmsgq01/.cvsignore (added) * testsuites/psxtests/psxreaddir/.cvsignore (added) * testsuites/psxtests/psxsem01/.cvsignore (added) * testsuites/psxtests/psxstat/.cvsignore (added) * testsuites/psxtests/psxtime/.cvsignore (added) * testsuites/psxtests/psxtimer/.cvsignore (added) * testsuites/samples/.cvsignore (added) * testsuites/samples/base_mp/.cvsignore (added) * testsuites/samples/base_mp/node1/.cvsignore (added) * testsuites/samples/base_mp/node2/.cvsignore (added) * testsuites/samples/base_sp/.cvsignore (added) * testsuites/samples/cdtest/.cvsignore (added) * testsuites/samples/hello/.cvsignore (added) * testsuites/samples/minimum/.cvsignore (added) * testsuites/samples/paranoia/.cvsignore (added) * testsuites/samples/ticker/.cvsignore (added) * testsuites/samples/unlimited/.cvsignore (added) * testsuites/sptests/.cvsignore (added) * testsuites/sptests/sp01/.cvsignore (added) * testsuites/sptests/sp02/.cvsignore (added) * testsuites/sptests/sp03/.cvsignore (added) * testsuites/sptests/sp04/.cvsignore (added) * testsuites/sptests/sp05/.cvsignore (added) * testsuites/sptests/sp06/.cvsignore (added) * testsuites/sptests/sp07/.cvsignore (added) * testsuites/sptests/sp08/.cvsignore (added) * testsuites/sptests/sp09/.cvsignore (added) * testsuites/sptests/sp11/.cvsignore (added) * testsuites/sptests/sp12/.cvsignore (added) * testsuites/sptests/sp13/.cvsignore (added) * testsuites/sptests/sp14/.cvsignore (added) * testsuites/sptests/sp15/.cvsignore (added) * testsuites/sptests/sp16/.cvsignore (added) * testsuites/sptests/sp17/.cvsignore (added) * testsuites/sptests/sp19/.cvsignore (added) * testsuites/sptests/sp20/.cvsignore (added) * testsuites/sptests/sp21/.cvsignore (added) * testsuites/sptests/sp22/.cvsignore (added) * testsuites/sptests/sp23/.cvsignore (added) * testsuites/sptests/sp24/.cvsignore (added) * testsuites/sptests/sp25/.cvsignore (added) * testsuites/sptests/sp26/.cvsignore (added) * testsuites/sptests/sp27/.cvsignore (added) * testsuites/sptests/sp28/.cvsignore (added) * testsuites/sptests/sp29/.cvsignore (added) * testsuites/sptests/spfatal/.cvsignore (added) * testsuites/sptests/spsize/.cvsignore (added) * testsuites/support/.cvsignore (added) * testsuites/support/include/.cvsignore (added) * testsuites/tmitrontests/.cvsignore (added) * testsuites/tmitrontests/include/.cvsignore (added) * testsuites/tmitrontests/tmitronsem01/.cvsignore (added) * testsuites/tmtests/.cvsignore (added) * testsuites/tmtests/include/.cvsignore (added) * testsuites/tmtests/tm01/.cvsignore (added) * testsuites/tmtests/tm02/.cvsignore (added) * testsuites/tmtests/tm03/.cvsignore (added) * testsuites/tmtests/tm04/.cvsignore (added) * testsuites/tmtests/tm05/.cvsignore (added) * testsuites/tmtests/tm06/.cvsignore (added) * testsuites/tmtests/tm07/.cvsignore (added) * testsuites/tmtests/tm08/.cvsignore (added) * testsuites/tmtests/tm09/.cvsignore (added) * testsuites/tmtests/tm10/.cvsignore (added) * testsuites/tmtests/tm11/.cvsignore (added) * testsuites/tmtests/tm12/.cvsignore (added) * testsuites/tmtests/tm13/.cvsignore (added) * testsuites/tmtests/tm14/.cvsignore (added) * testsuites/tmtests/tm15/.cvsignore (added) * testsuites/tmtests/tm16/.cvsignore (added) * testsuites/tmtests/tm17/.cvsignore (added) * testsuites/tmtests/tm18/.cvsignore (added) * testsuites/tmtests/tm19/.cvsignore (added) * testsuites/tmtests/tm20/.cvsignore (added) * testsuites/tmtests/tm21/.cvsignore (added) * testsuites/tmtests/tm22/.cvsignore (added) * testsuites/tmtests/tm23/.cvsignore (added) * testsuites/tmtests/tm24/.cvsignore (added) * testsuites/tmtests/tm25/.cvsignore (added) * testsuites/tmtests/tm26/.cvsignore (added) * testsuites/tmtests/tm27/.cvsignore (added) * testsuites/tmtests/tm28/.cvsignore (added) * testsuites/tmtests/tm29/.cvsignore (added) * testsuites/tmtests/tmck/.cvsignore (added) * testsuites/tmtests/tmoverhd/.cvsignore (added) * testsuites/tools/.cvsignore (added) * testsuites/tools/generic/.cvsignore (added) * tools/.cvsignore (added) * tools/build/.cvsignore (added) * tools/cpu/.cvsignore (added) * tools/cpu/generic/.cvsignore (added) * tools/cpu/hppa1.1/.cvsignore (added) * tools/cpu/sh/.cvsignore (added) * tools/cpu/unix/.cvsignore (added) * tools/update/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [8fbdf07] * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) Patch rtems-rc-20000118-2.diff from Ralf Corsepius [9ba1f0a] * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) Patch rtems-rc-19991203-9.diff from Ralf Corsepius [de759c5] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/samples/base_mp/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/samples/base_mp/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) Patch rtems-rc-19991117-8.diff from Ralf Corsepius [e31c63e5] * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/Makefile.am (added) * c/src/tests/samples/base_mp/Makefile.in (deleted) * c/src/tests/samples/base_mp/node1/Makefile.am (added) * c/src/tests/samples/base_mp/node1/Makefile.in (deleted) * c/src/tests/samples/base_mp/node2/Makefile.am (added) * c/src/tests/samples/base_mp/node2/Makefile.in (deleted) * c/src/tests/samples/base_sp/Makefile.am (added) * c/src/tests/samples/base_sp/Makefile.in (deleted) * c/src/tests/samples/cdtest/Makefile.am (added) * c/src/tests/samples/cdtest/Makefile.in (deleted) * c/src/tests/samples/hello/Makefile.am (added) * c/src/tests/samples/hello/Makefile.in (deleted) * c/src/tests/samples/minimum/Makefile.am (added) * c/src/tests/samples/minimum/Makefile.in (deleted) * c/src/tests/samples/paranoia/Makefile.am (added) * c/src/tests/samples/paranoia/Makefile.in (deleted) * c/src/tests/samples/ticker/Makefile.am (added) * c/src/tests/samples/ticker/Makefile.in (deleted) * c/src/tests/samples/unlimited/Makefile.am (added) * c/src/tests/samples/unlimited/Makefile.in (deleted) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/Makefile.am (added) * testsuites/samples/base_mp/node1/Makefile.am (added) * testsuites/samples/base_mp/node2/Makefile.am (added) * testsuites/samples/base_sp/Makefile.am (added) * testsuites/samples/cdtest/Makefile.am (added) * testsuites/samples/hello/Makefile.am (added) * testsuites/samples/minimum/Makefile.am (added) * testsuites/samples/paranoia/Makefile.am (added) * testsuites/samples/ticker/Makefile.am (added) * testsuites/samples/unlimited/Makefile.am (added) Patch rtems-rc-19991117-7.diff from Ralf Corsepius [08311cc3] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/clockdrv.h (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/iosupp.h (modified) * c/src/exec/libcsupport/include/motorola/mc68230.h (modified) * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/include/timerdrv.h (modified) * c/src/exec/libcsupport/include/vmeintr.h (modified) * c/src/exec/libcsupport/include/zilog/z8036.h (modified) * c/src/exec/libcsupport/include/zilog/z8530.h (modified) * c/src/exec/libcsupport/include/zilog/z8536.h (modified) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__sbrk.c (modified) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/access.c (modified) * c/src/exec/libcsupport/src/base_fs.c (modified) * c/src/exec/libcsupport/src/cfgetispeed.c (modified) * c/src/exec/libcsupport/src/cfgetospeed.c (modified) * c/src/exec/libcsupport/src/cfsetispeed.c (modified) * c/src/exec/libcsupport/src/cfsetospeed.c (modified) * c/src/exec/libcsupport/src/chdir.c (modified) * c/src/exec/libcsupport/src/chmod.c (modified) * c/src/exec/libcsupport/src/chown.c (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/ctermid.c (modified) * c/src/exec/libcsupport/src/dup.c (modified) * c/src/exec/libcsupport/src/dup2.c (modified) * c/src/exec/libcsupport/src/eval.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fs_null_handlers.c (modified) * c/src/exec/libcsupport/src/fstat.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/getdents.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/libio_sockets.c (modified) * c/src/exec/libcsupport/src/link.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/lstat.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/mkdir.c (modified) * c/src/exec/libcsupport/src/mkfifo.c (modified) * c/src/exec/libcsupport/src/mknod.c (modified) * c/src/exec/libcsupport/src/mount.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/libcsupport/src/open.c (modified) * c/src/exec/libcsupport/src/pathconf.c (modified) * c/src/exec/libcsupport/src/pipe.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/readlink.c (modified) * c/src/exec/libcsupport/src/rewinddir.c (modified) * c/src/exec/libcsupport/src/rmdir.c (modified) * c/src/exec/libcsupport/src/seekdir.c (modified) * c/src/exec/libcsupport/src/stat.c (modified) * c/src/exec/libcsupport/src/symlink.c (modified) * c/src/exec/libcsupport/src/tcdrain.c (modified) * c/src/exec/libcsupport/src/tcflow.c (modified) * c/src/exec/libcsupport/src/tcflush.c (modified) * c/src/exec/libcsupport/src/tcgetattr.c (modified) * c/src/exec/libcsupport/src/tcgetprgrp.c (modified) * c/src/exec/libcsupport/src/tcsendbreak.c (modified) * c/src/exec/libcsupport/src/tcsetattr.c (modified) * c/src/exec/libcsupport/src/tcsetpgrp.c (modified) * c/src/exec/libcsupport/src/telldir.c (modified) * c/src/exec/libcsupport/src/truncate.c (modified) * c/src/exec/libcsupport/src/umask.c (modified) * c/src/exec/libcsupport/src/unixlibc.c (modified) * c/src/exec/libcsupport/src/unlink.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libcsupport/src/utime.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libfs/src/imfs/deviceio.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_chown.c (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_debug.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_eval.c (modified) * c/src/exec/libfs/src/imfs/imfs_fchmod.c (modified) * c/src/exec/libfs/src/imfs/imfs_fcntl.c (modified) * c/src/exec/libfs/src/imfs/imfs_fdatasync.c (modified) * c/src/exec/libfs/src/imfs/imfs_free.c (modified) * c/src/exec/libfs/src/imfs/imfs_fsunmount.c (modified) * c/src/exec/libfs/src/imfs/imfs_getchild.c (modified) * c/src/exec/libfs/src/imfs/imfs_gtkn.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_device.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_link.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_memfile.c (modified) * c/src/exec/libfs/src/imfs/imfs_init.c (modified) * c/src/exec/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/exec/libfs/src/imfs/imfs_link.c (modified) * c/src/exec/libfs/src/imfs/imfs_mknod.c (modified) * c/src/exec/libfs/src/imfs/imfs_mount.c (modified) * c/src/exec/libfs/src/imfs/imfs_ntype.c (modified) * c/src/exec/libfs/src/imfs/imfs_readlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_rmnod.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_symlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_unixstub.c (modified) * c/src/exec/libfs/src/imfs/imfs_unlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libfs/src/imfs/ioman.c (modified) * c/src/exec/libfs/src/imfs/memfile.c (modified) * c/src/exec/libfs/src/imfs/miniimfs_init.c (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/condmp.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/posix/include/rtems/posix/key.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mqueuemp.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/posixapi.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthreadmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/posix/include/rtems/posix/seterr.h (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/intr.inl (modified) * c/src/exec/posix/inline/rtems/posix/key.inl (modified) * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * c/src/exec/posix/inline/rtems/posix/mutex.inl (modified) * c/src/exec/posix/inline/rtems/posix/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * c/src/exec/posix/src/alarm.c (modified) * c/src/exec/posix/src/kill.c (modified) * c/src/exec/posix/src/killinfo.c (modified) * c/src/exec/posix/src/pause.c (modified) * c/src/exec/posix/src/pthreadattrdestroy.c (modified) * c/src/exec/posix/src/pthreadattrgetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrgetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrgetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrgetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrgetscope.c (modified) * c/src/exec/posix/src/pthreadattrgetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrgetstacksize.c (modified) * c/src/exec/posix/src/pthreadattrinit.c (modified) * c/src/exec/posix/src/pthreadattrsetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrsetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrsetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrsetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrsetscope.c (modified) * c/src/exec/posix/src/pthreadattrsetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrsetstacksize.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/pthreaddetach.c (modified) * c/src/exec/posix/src/pthreadequal.c (modified) * c/src/exec/posix/src/pthreadexit.c (modified) * c/src/exec/posix/src/pthreadgetcpuclockid.c (modified) * c/src/exec/posix/src/pthreadgetcputime.c (modified) * c/src/exec/posix/src/pthreadgetschedparam.c (modified) * c/src/exec/posix/src/pthreadjoin.c (modified) * c/src/exec/posix/src/pthreadkill.c (modified) * c/src/exec/posix/src/pthreadonce.c (modified) * c/src/exec/posix/src/pthreadself.c (modified) * c/src/exec/posix/src/pthreadsetcputime.c (modified) * c/src/exec/posix/src/pthreadsetschedparam.c (modified) * c/src/exec/posix/src/pthreadsigmask.c (modified) * c/src/exec/posix/src/sigaction.c (modified) * c/src/exec/posix/src/sigaddset.c (modified) * c/src/exec/posix/src/sigdelset.c (modified) * c/src/exec/posix/src/sigemptyset.c (modified) * c/src/exec/posix/src/sigfillset.c (modified) * c/src/exec/posix/src/sigismember.c (modified) * c/src/exec/posix/src/signal_2.c (modified) * c/src/exec/posix/src/sigpending.c (modified) * c/src/exec/posix/src/sigprocmask.c (modified) * c/src/exec/posix/src/sigqueue.c (modified) * c/src/exec/posix/src/sigsuspend.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/sigwait.c (modified) * c/src/exec/posix/src/sigwaitinfo.c (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/options.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/part.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/attr.c (modified) * c/src/exec/rtems/src/clockget.c (modified) * c/src/exec/rtems/src/clockset.c (modified) * c/src/exec/rtems/src/clocktick.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/dpmemcreate.c (modified) * c/src/exec/rtems/src/dpmemdelete.c (modified) * c/src/exec/rtems/src/dpmemexternal2internal.c (modified) * c/src/exec/rtems/src/dpmemident.c (modified) * c/src/exec/rtems/src/dpmeminternal2external.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/eventreceive.c (modified) * c/src/exec/rtems/src/eventseize.c (modified) * c/src/exec/rtems/src/eventsend.c (modified) * c/src/exec/rtems/src/eventsurrender.c (modified) * c/src/exec/rtems/src/eventtimeout.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/intrbody.c (modified) * c/src/exec/rtems/src/intrcatch.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/msgqallocate.c (modified) * c/src/exec/rtems/src/msgqbroadcast.c (modified) * c/src/exec/rtems/src/msgqcreate.c (modified) * c/src/exec/rtems/src/msgqdelete.c (modified) * c/src/exec/rtems/src/msgqflush.c (modified) * c/src/exec/rtems/src/msgqgetnumberpending.c (modified) * c/src/exec/rtems/src/msgqident.c (modified) * c/src/exec/rtems/src/msgqreceive.c (modified) * c/src/exec/rtems/src/msgqsend.c (modified) * c/src/exec/rtems/src/msgqsubmit.c (modified) * c/src/exec/rtems/src/msgqtranslatereturncode.c (modified) * c/src/exec/rtems/src/msgqurgent.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partcreate.c (modified) * c/src/exec/rtems/src/partdelete.c (modified) * c/src/exec/rtems/src/partgetbuffer.c (modified) * c/src/exec/rtems/src/partident.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/partreturnbuffer.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/ratemoncancel.c (modified) * c/src/exec/rtems/src/ratemoncreate.c (modified) * c/src/exec/rtems/src/ratemondelete.c (modified) * c/src/exec/rtems/src/ratemongetstatus.c (modified) * c/src/exec/rtems/src/ratemonident.c (modified) * c/src/exec/rtems/src/ratemonperiod.c (modified) * c/src/exec/rtems/src/ratemontimeout.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regioncreate.c (modified) * c/src/exec/rtems/src/regiondelete.c (modified) * c/src/exec/rtems/src/regionextend.c (modified) * c/src/exec/rtems/src/regiongetsegment.c (modified) * c/src/exec/rtems/src/regiongetsegmentsize.c (modified) * c/src/exec/rtems/src/regionident.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/regionreturnsegment.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semcreate.c (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/semflush.c (modified) * c/src/exec/rtems/src/semident.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/semobtain.c (modified) * c/src/exec/rtems/src/semrelease.c (modified) * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalcatch.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/signalsend.c (modified) * c/src/exec/rtems/src/taskcreate.c (modified) * c/src/exec/rtems/src/taskdelete.c (modified) * c/src/exec/rtems/src/taskgetnote.c (modified) * c/src/exec/rtems/src/taskident.c (modified) * c/src/exec/rtems/src/taskinitusers.c (modified) * c/src/exec/rtems/src/taskissuspended.c (modified) * c/src/exec/rtems/src/taskmode.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/taskrestart.c (modified) * c/src/exec/rtems/src/taskresume.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/tasksetnote.c (modified) * c/src/exec/rtems/src/tasksetpriority.c (modified) * c/src/exec/rtems/src/taskstart.c (modified) * c/src/exec/rtems/src/tasksuspend.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskwakeafter.c (modified) * c/src/exec/rtems/src/taskwakewhen.c (modified) * c/src/exec/rtems/src/timercancel.c (modified) * c/src/exec/rtems/src/timercreate.c (modified) * c/src/exec/rtems/src/timerdelete.c (modified) * c/src/exec/rtems/src/timerfireafter.c (modified) * c/src/exec/rtems/src/timerfirewhen.c (modified) * c/src/exec/rtems/src/timerident.c (modified) * c/src/exec/rtems/src/timerreset.c (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/fatal.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/mptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/sapi/macros/rtems/extension.inl (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/debug.c (modified) * c/src/exec/sapi/src/entrytable.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/itronapi.c (modified) * c/src/exec/sapi/src/posixapi.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu_asm.S (modified) * c/src/exec/score/cpu/a29k/rtems.c (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29ktypes.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/cpu_asm.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/types.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems.S (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu_asm.S (modified) * c/src/exec/score/cpu/i386/rtems.S (modified) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i386/rtems/score/i386types.h (modified) * c/src/exec/score/cpu/i386/rtems/score/types.h (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (modified) * c/src/exec/score/cpu/i960/rtems.S (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960types.h (modified) * c/src/exec/score/cpu/i960/rtems/score/types.h (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu_asm.S (modified) * c/src/exec/score/cpu/m68k/rtems.S (modified) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68ktypes.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/types.h (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (modified) * c/src/exec/score/cpu/mips/rtems/score/types.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cputypes.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems.S (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/types.h (modified) * c/src/exec/score/cpu/unix/rtems/score/types.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unixtypes.h (modified) * c/src/exec/score/include/rtems/debug.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/copyrt.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/chain.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (modified) * c/src/exec/score/macros/rtems/score/coresem.inl (modified) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/mppkt.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/objectmp.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/threadmp.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremsgbroadcast.c (modified) * c/src/exec/score/src/coremsgclose.c (modified) * c/src/exec/score/src/coremsgflush.c (modified) * c/src/exec/score/src/coremsgflushsupp.c (modified) * c/src/exec/score/src/coremsgseize.c (modified) * c/src/exec/score/src/coremsgsubmit.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coremutexflush.c (modified) * c/src/exec/score/src/coremutexseize.c (modified) * c/src/exec/score/src/coremutexsurrender.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/coresemflush.c (modified) * c/src/exec/score/src/coresemseize.c (modified) * c/src/exec/score/src/coresemsurrender.c (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/coretodset.c (modified) * c/src/exec/score/src/coretodtickle.c (modified) * c/src/exec/score/src/coretodtoseconds.c (modified) * c/src/exec/score/src/coretodvalidate.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/heapallocate.c (modified) * c/src/exec/score/src/heapextend.c (modified) * c/src/exec/score/src/heapfree.c (modified) * c/src/exec/score/src/heapsizeofuserarea.c (modified) * c/src/exec/score/src/heapwalk.c (modified) * c/src/exec/score/src/interr.c (modified) * c/src/exec/score/src/isr.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectallocate.c (modified) * c/src/exec/score/src/objectallocatebyindex.c (modified) * c/src/exec/score/src/objectclearname.c (modified) * c/src/exec/score/src/objectcomparenameraw.c (modified) * c/src/exec/score/src/objectcomparenamestring.c (modified) * c/src/exec/score/src/objectcopynameraw.c (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/score/src/objectextendinformation.c (modified) * c/src/exec/score/src/objectfree.c (modified) * c/src/exec/score/src/objectget.c (modified) * c/src/exec/score/src/objectgetbyindex.c (modified) * c/src/exec/score/src/objectgetnext.c (modified) * c/src/exec/score/src/objectinitializeinformation.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/objectnametoid.c (modified) * c/src/exec/score/src/objectshrinkinformation.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadchangepriority.c (modified) * c/src/exec/score/src/threadclearstate.c (modified) * c/src/exec/score/src/threadclose.c (modified) * c/src/exec/score/src/threadcreateidle.c (modified) * c/src/exec/score/src/threaddelayended.c (modified) * c/src/exec/score/src/threaddispatch.c (modified) * c/src/exec/score/src/threadevaluatemode.c (modified) * c/src/exec/score/src/threadget.c (modified) * c/src/exec/score/src/threadhandler.c (modified) * c/src/exec/score/src/threadidlebody.c (modified) * c/src/exec/score/src/threadinitialize.c (modified) * c/src/exec/score/src/threadloadenv.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/threadqdequeue.c (modified) * c/src/exec/score/src/threadqdequeuefifo.c (modified) * c/src/exec/score/src/threadqdequeuepriority.c (modified) * c/src/exec/score/src/threadqenqueue.c (modified) * c/src/exec/score/src/threadqenqueuefifo.c (modified) * c/src/exec/score/src/threadqenqueuepriority.c (modified) * c/src/exec/score/src/threadqextract.c (modified) * c/src/exec/score/src/threadqextractfifo.c (modified) * c/src/exec/score/src/threadqextractpriority.c (modified) * c/src/exec/score/src/threadqextractwithproxy.c (modified) * c/src/exec/score/src/threadqfirst.c (modified) * c/src/exec/score/src/threadqfirstfifo.c (modified) * c/src/exec/score/src/threadqfirstpriority.c (modified) * c/src/exec/score/src/threadqflush.c (modified) * c/src/exec/score/src/threadqtimeout.c (modified) * c/src/exec/score/src/threadready.c (modified) * c/src/exec/score/src/threadreset.c (modified) * c/src/exec/score/src/threadresettimeslice.c (modified) * c/src/exec/score/src/threadrestart.c (modified) * c/src/exec/score/src/threadresume.c (modified) * c/src/exec/score/src/threadrotatequeue.c (modified) * c/src/exec/score/src/threadsetpriority.c (modified) * c/src/exec/score/src/threadsetstate.c (modified) * c/src/exec/score/src/threadsettransient.c (modified) * c/src/exec/score/src/threadstackallocate.c (modified) * c/src/exec/score/src/threadstackfree.c (modified) * c/src/exec/score/src/threadstart.c (modified) * c/src/exec/score/src/threadstartmultitasking.c (modified) * c/src/exec/score/src/threadsuspend.c (modified) * c/src/exec/score/src/threadtickletimeslice.c (modified) * c/src/exec/score/src/threadyieldprocessor.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/watchdogadjust.c (modified) * c/src/exec/score/src/watchdoginsert.c (modified) * c/src/exec/score/src/watchdogremove.c (modified) * c/src/exec/score/src/watchdogtickle.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/lib/include/clockdrv.h (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/iosupp.h (modified) * c/src/lib/include/motorola/mc68230.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/timerdrv.h (modified) * c/src/lib/include/vmeintr.h (modified) * c/src/lib/include/zilog/z8036.h (modified) * c/src/lib/include/zilog/z8530.h (modified) * c/src/lib/include/zilog/z8536.h (modified) * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/main.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/bare/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/startup/sbrk.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/serial_gdb.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/start/start.S (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (modified) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (modified) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/start340/start340.S (modified) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/cTest.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/helas403/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/clock/ckinit.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/main.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspclean.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/exit.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__sbrk.c (modified) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/access.c (modified) * c/src/lib/libc/base_fs.c (modified) * c/src/lib/libc/cfgetispeed.c (modified) * c/src/lib/libc/cfgetospeed.c (modified) * c/src/lib/libc/cfsetispeed.c (modified) * c/src/lib/libc/cfsetospeed.c (modified) * c/src/lib/libc/chdir.c (modified) * c/src/lib/libc/chmod.c (modified) * c/src/lib/libc/chown.c (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/ctermid.c (modified) * c/src/lib/libc/deviceio.c (modified) * c/src/lib/libc/dup.c (modified) * c/src/lib/libc/dup2.c (modified) * c/src/lib/libc/eval.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fs_null_handlers.c (modified) * c/src/lib/libc/fstat.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/getdents.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_chown.c (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_debug.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_eval.c (modified) * c/src/lib/libc/imfs_fchmod.c (modified) * c/src/lib/libc/imfs_fcntl.c (modified) * c/src/lib/libc/imfs_fdatasync.c (modified) * c/src/lib/libc/imfs_free.c (modified) * c/src/lib/libc/imfs_fsunmount.c (modified) * c/src/lib/libc/imfs_getchild.c (modified) * c/src/lib/libc/imfs_gtkn.c (modified) * c/src/lib/libc/imfs_handlers_device.c (modified) * c/src/lib/libc/imfs_handlers_directory.c (modified) * c/src/lib/libc/imfs_handlers_link.c (modified) * c/src/lib/libc/imfs_handlers_memfile.c (modified) * c/src/lib/libc/imfs_init.c (modified) * c/src/lib/libc/imfs_initsupp.c (modified) * c/src/lib/libc/imfs_link.c (modified) * c/src/lib/libc/imfs_mknod.c (modified) * c/src/lib/libc/imfs_mount.c (modified) * c/src/lib/libc/imfs_ntype.c (modified) * c/src/lib/libc/imfs_readlink.c (modified) * c/src/lib/libc/imfs_rmnod.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_symlink.c (modified) * c/src/lib/libc/imfs_unixstub.c (modified) * c/src/lib/libc/imfs_unlink.c (modified) * c/src/lib/libc/imfs_unmount.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/ioman.c (modified) * c/src/lib/libc/libcsupport.h (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/libio_sockets.c (modified) * c/src/lib/libc/link.c (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/lstat.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/memfile.c (modified) * c/src/lib/libc/miniimfs_init.c (modified) * c/src/lib/libc/mkdir.c (modified) * c/src/lib/libc/mkfifo.c (modified) * c/src/lib/libc/mknod.c (modified) * c/src/lib/libc/mount.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/open.c (modified) * c/src/lib/libc/pathconf.c (modified) * c/src/lib/libc/pipe.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/readlink.c (modified) * c/src/lib/libc/rewinddir.c (modified) * c/src/lib/libc/rmdir.c (modified) * c/src/lib/libc/seekdir.c (modified) * c/src/lib/libc/stat.c (modified) * c/src/lib/libc/symlink.c (modified) * c/src/lib/libc/tcdrain.c (modified) * c/src/lib/libc/tcflow.c (modified) * c/src/lib/libc/tcflush.c (modified) * c/src/lib/libc/tcgetattr.c (modified) * c/src/lib/libc/tcgetprgrp.c (modified) * c/src/lib/libc/tcsendbreak.c (modified) * c/src/lib/libc/tcsetattr.c (modified) * c/src/lib/libc/tcsetpgrp.c (modified) * c/src/lib/libc/telldir.c (modified) * c/src/lib/libc/truncate.c (modified) * c/src/lib/libc/umask.c (modified) * c/src/lib/libc/unixlibc.c (modified) * c/src/lib/libc/unlink.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libc/utime.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7032/include/null.h (modified) * c/src/lib/libcpu/sh/sh7032/null/close.c (modified) * c/src/lib/libcpu/sh/sh7032/null/cntrl.c (modified) * c/src/lib/libcpu/sh/sh7032/null/init.c (modified) * c/src/lib/libcpu/sh/sh7032/null/open.c (modified) * c/src/lib/libcpu/sh/sh7032/null/read.c (modified) * c/src/lib/libcpu/sh/sh7032/null/write.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * c/src/libchip/rtc/icm7170.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libfs/src/imfs/deviceio.c (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_chown.c (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_debug.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_eval.c (modified) * c/src/libfs/src/imfs/imfs_fchmod.c (modified) * c/src/libfs/src/imfs/imfs_fcntl.c (modified) * c/src/libfs/src/imfs/imfs_fdatasync.c (modified) * c/src/libfs/src/imfs/imfs_free.c (modified) * c/src/libfs/src/imfs/imfs_fsunmount.c (modified) * c/src/libfs/src/imfs/imfs_getchild.c (modified) * c/src/libfs/src/imfs/imfs_gtkn.c (modified) * c/src/libfs/src/imfs/imfs_handlers_device.c (modified) * c/src/libfs/src/imfs/imfs_handlers_directory.c (modified) * c/src/libfs/src/imfs/imfs_handlers_link.c (modified) * c/src/libfs/src/imfs/imfs_handlers_memfile.c (modified) * c/src/libfs/src/imfs/imfs_init.c (modified) * c/src/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/libfs/src/imfs/imfs_link.c (modified) * c/src/libfs/src/imfs/imfs_mknod.c (modified) * c/src/libfs/src/imfs/imfs_mount.c (modified) * c/src/libfs/src/imfs/imfs_ntype.c (modified) * c/src/libfs/src/imfs/imfs_readlink.c (modified) * c/src/libfs/src/imfs/imfs_rmnod.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_symlink.c (modified) * c/src/libfs/src/imfs/imfs_unixstub.c (modified) * c/src/libfs/src/imfs/imfs_unlink.c (modified) * c/src/libfs/src/imfs/imfs_unmount.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libfs/src/imfs/ioman.c (modified) * c/src/libfs/src/imfs/memfile.c (modified) * c/src/libfs/src/imfs/miniimfs_init.c (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/init.c (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * c/src/tests/libtests/monitor/init.c (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Init.cc (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtems++/Task1.cc (modified) * c/src/tests/libtests/rtems++/Task2.cc (modified) * c/src/tests/libtests/rtems++/Task3.cc (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/node1/mp01.doc (modified) * c/src/tests/mptests/mp01/node2/mp01.doc (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/node1/mp02.doc (modified) * c/src/tests/mptests/mp02/node2/mp02.doc (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp02/task1.c (modified) * c/src/tests/mptests/mp03/delay.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/node1/mp03.doc (modified) * c/src/tests/mptests/mp03/node2/mp03.doc (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp03/task1.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/node1/mp04.doc (modified) * c/src/tests/mptests/mp04/node2/mp04.doc (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp04/task1.c (modified) * c/src/tests/mptests/mp05/asr.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/node1/mp05.doc (modified) * c/src/tests/mptests/mp05/node2/mp05.doc (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp05/task1.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/node1/mp06.doc (modified) * c/src/tests/mptests/mp06/node2/mp06.doc (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp06/task1.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/node1/mp07.doc (modified) * c/src/tests/mptests/mp07/node2/mp07.doc (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/node1/mp08.doc (modified) * c/src/tests/mptests/mp08/node2/mp08.doc (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp08/task1.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.doc (modified) * c/src/tests/mptests/mp09/node2/mp09.doc (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/node1/mp10.doc (modified) * c/src/tests/mptests/mp10/node2/mp10.doc (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp10/task2.c (modified) * c/src/tests/mptests/mp10/task3.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/node1/mp11.doc (modified) * c/src/tests/mptests/mp11/node2/mp11.doc (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/node1/mp12.doc (modified) * c/src/tests/mptests/mp12/node2/mp12.doc (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/node1/mp13.doc (modified) * c/src/tests/mptests/mp13/node2/mp13.doc (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp13/task2.c (modified) * c/src/tests/mptests/mp14/delay.c (modified) * c/src/tests/mptests/mp14/evtask1.c (modified) * c/src/tests/mptests/mp14/evtmtask.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/node1/mp14.doc (modified) * c/src/tests/mptests/mp14/node2/mp14.doc (modified) * c/src/tests/mptests/mp14/pttask1.c (modified) * c/src/tests/mptests/mp14/smtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx02/task.c (modified) * c/src/tests/psxtests/psx03/init.c (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx03/task.c (modified) * c/src/tests/psxtests/psx04/init.c (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx04/task1.c (modified) * c/src/tests/psxtests/psx04/task2.c (modified) * c/src/tests/psxtests/psx04/task3.c (modified) * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task.c (modified) * c/src/tests/psxtests/psx05/task2.c (modified) * c/src/tests/psxtests/psx05/task3.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (modified) * c/src/tests/psxtests/psx08/init.c (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx08/task1.c (modified) * c/src/tests/psxtests/psx08/task2.c (modified) * c/src/tests/psxtests/psx08/task3.c (modified) * c/src/tests/psxtests/psx09/init.c (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/init.c (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx10/task.c (modified) * c/src/tests/psxtests/psx10/task2.c (modified) * c/src/tests/psxtests/psx10/task3.c (modified) * c/src/tests/psxtests/psx11/init.c (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx11/task.c (modified) * c/src/tests/psxtests/psx12/init.c (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx12/task.c (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psx13/test.c (modified) * c/src/tests/psxtests/psxcancel/init.c (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/clock01.c (modified) * c/src/tests/psxtests/psxhdrs/clock02.c (modified) * c/src/tests/psxtests/psxhdrs/clock03.c (modified) * c/src/tests/psxtests/psxhdrs/clock04.c (modified) * c/src/tests/psxtests/psxhdrs/clock05.c (modified) * c/src/tests/psxtests/psxhdrs/clock06.c (modified) * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/cond08.c (modified) * c/src/tests/psxtests/psxhdrs/cond09.c (modified) * c/src/tests/psxtests/psxhdrs/cond10.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/key04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/mutex10.c (modified) * c/src/tests/psxtests/psxhdrs/mutex11.c (modified) * c/src/tests/psxtests/psxhdrs/mutex12.c (modified) * c/src/tests/psxtests/psxhdrs/mutex13.c (modified) * c/src/tests/psxtests/psxhdrs/mutex14.c (modified) * c/src/tests/psxtests/psxhdrs/mutex15.c (modified) * c/src/tests/psxtests/psxhdrs/mutex16.c (modified) * c/src/tests/psxtests/psxhdrs/proc01.c (modified) * c/src/tests/psxtests/psxhdrs/proc02.c (modified) * c/src/tests/psxtests/psxhdrs/proc03.c (modified) * c/src/tests/psxtests/psxhdrs/proc04.c (modified) * c/src/tests/psxtests/psxhdrs/proc05.c (modified) * c/src/tests/psxtests/psxhdrs/proc06.c (modified) * c/src/tests/psxtests/psxhdrs/proc07.c (modified) * c/src/tests/psxtests/psxhdrs/proc08.c (modified) * c/src/tests/psxtests/psxhdrs/proc09.c (modified) * c/src/tests/psxtests/psxhdrs/proc10.c (modified) * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc12.c (modified) * c/src/tests/psxtests/psxhdrs/proc13.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread24.c (modified) * c/src/tests/psxtests/psxhdrs/pthread25.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * c/src/tests/psxtests/psxhdrs/pthread31.c (modified) * c/src/tests/psxtests/psxhdrs/pthread32.c (modified) * c/src/tests/psxtests/psxhdrs/pthread33.c (modified) * c/src/tests/psxtests/psxhdrs/pthread34.c (modified) * c/src/tests/psxtests/psxhdrs/pthread35.c (modified) * c/src/tests/psxtests/psxhdrs/pthread36.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * c/src/tests/psxtests/psxhdrs/signal01.c (modified) * c/src/tests/psxtests/psxhdrs/signal02.c (modified) * c/src/tests/psxtests/psxhdrs/signal03.c (modified) * c/src/tests/psxtests/psxhdrs/signal04.c (modified) * c/src/tests/psxtests/psxhdrs/signal05.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * c/src/tests/psxtests/psxhdrs/signal09.c (modified) * c/src/tests/psxtests/psxhdrs/signal10.c (modified) * c/src/tests/psxtests/psxhdrs/signal11.c (modified) * c/src/tests/psxtests/psxhdrs/signal12.c (modified) * c/src/tests/psxtests/psxhdrs/signal13.c (modified) * c/src/tests/psxtests/psxhdrs/signal14.c (modified) * c/src/tests/psxtests/psxhdrs/signal15.c (modified) * c/src/tests/psxtests/psxhdrs/signal16.c (modified) * c/src/tests/psxtests/psxhdrs/signal17.c (modified) * c/src/tests/psxtests/psxhdrs/signal18.c (modified) * c/src/tests/psxtests/psxhdrs/signal19.c (modified) * c/src/tests/psxtests/psxhdrs/signal20.c (modified) * c/src/tests/psxtests/psxhdrs/signal21.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * c/src/tests/psxtests/psxhdrs/time01.c (modified) * c/src/tests/psxtests/psxhdrs/time02.c (modified) * c/src/tests/psxtests/psxhdrs/time03.c (modified) * c/src/tests/psxtests/psxhdrs/time04.c (modified) * c/src/tests/psxtests/psxhdrs/time05.c (modified) * c/src/tests/psxtests/psxhdrs/time06.c (modified) * c/src/tests/psxtests/psxhdrs/time07.c (modified) * c/src/tests/psxtests/psxhdrs/time08.c (modified) * c/src/tests/psxtests/psxhdrs/time09.c (modified) * c/src/tests/psxtests/psxhdrs/time10.c (modified) * c/src/tests/psxtests/psxhdrs/time11.c (modified) * c/src/tests/psxtests/psxhdrs/time12.c (modified) * c/src/tests/psxtests/psxhdrs/time13.c (modified) * c/src/tests/psxtests/psxhdrs/timer01.c (modified) * c/src/tests/psxtests/psxhdrs/timer02.c (modified) * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * c/src/tests/psxtests/psxhdrs/timer06.c (modified) * c/src/tests/psxtests/psxmsgq01/init.c (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtime/test.c (modified) * c/src/tests/samples/README (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/node1/base_mp.doc (modified) * c/src/tests/samples/base_mp/node2/base_mp.doc (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/base_sp.doc (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/hello.doc (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/minimum/minimum.doc (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.doc (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/ticker/ticker.doc (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/sp01.doc (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp01/task1.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/sp02.doc (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/sp03.doc (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp03/task1.c (modified) * c/src/tests/sptests/sp03/task2.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/sp04.doc (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/task2.c (modified) * c/src/tests/sptests/sp04/task3.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/sp05.doc (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp05/task1.c (modified) * c/src/tests/sptests/sp05/task2.c (modified) * c/src/tests/sptests/sp05/task3.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/sp06.doc (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp06/task1.c (modified) * c/src/tests/sptests/sp06/task2.c (modified) * c/src/tests/sptests/sp06/task3.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/sp07.doc (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp07/task2.c (modified) * c/src/tests/sptests/sp07/task3.c (modified) * c/src/tests/sptests/sp07/task4.c (modified) * c/src/tests/sptests/sp07/taskexit.c (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp07/tdelete.c (modified) * c/src/tests/sptests/sp07/trestart.c (modified) * c/src/tests/sptests/sp07/tstart.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/sp08.doc (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp08/task1.c (modified) * c/src/tests/sptests/sp09/delay.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/isr.c (modified) * c/src/tests/sptests/sp09/screen01.c (modified) * c/src/tests/sptests/sp09/screen02.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp09/screen04.c (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen06.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen10.c (modified) * c/src/tests/sptests/sp09/screen11.c (modified) * c/src/tests/sptests/sp09/screen12.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/screen14.c (modified) * c/src/tests/sptests/sp09/sp09.doc (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp09/task2.c (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp09/task4.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/sp11.doc (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp11/timer.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/pritask.c (modified) * c/src/tests/sptests/sp12/sp12.doc (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp12/task2.c (modified) * c/src/tests/sptests/sp12/task3.c (modified) * c/src/tests/sptests/sp12/task4.c (modified) * c/src/tests/sptests/sp12/task5.c (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.doc (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/asr.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/sp14.doc (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp14/task2.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/sp15.doc (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp15/task1.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/sp16.doc (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp16/task2.c (modified) * c/src/tests/sptests/sp16/task3.c (modified) * c/src/tests/sptests/sp16/task4.c (modified) * c/src/tests/sptests/sp16/task5.c (modified) * c/src/tests/sptests/sp17/asr.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/sp17.doc (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp17/task1.c (modified) * c/src/tests/sptests/sp17/task2.c (modified) * c/src/tests/sptests/sp19/first.c (modified) * c/src/tests/sptests/sp19/fptask.c (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/sp19.doc (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp19/task1.c (modified) * c/src/tests/sptests/sp20/getall.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/sp20.doc (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp20/task1.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/sp21.doc (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/delay.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/prtime.c (modified) * c/src/tests/sptests/sp22/sp22.doc (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/sp23.doc (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp23/task1.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/resume.c (modified) * c/src/tests/sptests/sp24/sp24.doc (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp24/task1.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/sp25.doc (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/sptests/sp26/init.c (modified) * c/src/tests/sptests/sp26/sp26.doc (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp26/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/puterr.c (modified) * c/src/tests/sptests/spfatal/spfatal.doc (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spfatal/task1.c (modified) * c/src/tests/sptests/spsize/getint.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/support/stubdr/init.c (modified) * c/src/tests/support/stubdr/open.c (modified) * c/src/tests/support/stubdr/read.c (modified) * c/src/tests/support/stubdr/stubdrv.h (modified) * c/src/tests/support/stubdr/write.c (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm01/tm01.doc (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm02/tm02.doc (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm03/tm03.doc (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm04/tm04.doc (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm05/tm05.doc (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm06/tm06.doc (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm07/tm07.doc (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm08/tm08.doc (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm09/tm09.doc (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm10/tm10.doc (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm11/tm11.doc (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm12/tm12.doc (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm13/tm13.doc (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm14/tm14.doc (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm15/tm15.doc (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm16/tm16.doc (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm17/tm17.doc (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm18/tm18.doc (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm19/tm19.doc (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm20/tm20.doc (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm21/tm21.doc (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm22/tm22.doc (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm23/tm23.doc (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm24/tm24.doc (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm25/tm25.doc (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm26/tm26.doc (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm27/tm27.doc (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm28/tm28.doc (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tm29/tm29.doc (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmck/tmck.doc (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/empty.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__sbrk.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fs_null_handlers.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/mkfifo.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/pathconf.c (modified) * cpukit/libcsupport/src/pipe.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcgetprgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/telldir.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unixlibc.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fcntl.c (modified) * cpukit/libfs/src/imfs/imfs_fdatasync.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condmp.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueuemp.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadmp.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/intr.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetcputime.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetcputime.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/eventset.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/options.inl (modified) * cpukit/rtems/macros/rtems/rtems/part.inl (modified) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/macros/rtems/rtems/region.inl (modified) * cpukit/rtems/macros/rtems/rtems/sem.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/timer.inl (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqsubmit.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/include/rtems/sptables.h.in (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/macros/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/itronapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/cpu/a29k/cpu.c (modified) * cpukit/score/cpu/a29k/cpu_asm.S (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/a29k/rtems/score/types.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/i960/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/unix/rtems/score/types.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (modified) * cpukit/score/macros/rtems/score/coresem.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/mppkt.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/objectmp.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexflush.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtoseconds.c (modified) * cpukit/score/src/coretodvalidate.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatebyindex.c (modified) * cpukit/score/src/objectclearname.c (modified) * cpukit/score/src/objectcomparenameraw.c (modified) * cpukit/score/src/objectcomparenamestring.c (modified) * cpukit/score/src/objectcopynameraw.c (modified) * cpukit/score/src/objectcopynamestring.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetbyindex.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadevaluatemode.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadidlebody.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadresettimeslice.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadresume.c (modified) * cpukit/score/src/threadrotatequeue.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadsuspend.c (modified) * cpukit/score/src/threadtickletimeslice.c (modified) * cpukit/score/src/threadyieldprocessor.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01.doc (modified) * testsuites/mptests/mp01/node2/mp01.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02.doc (modified) * testsuites/mptests/mp02/node2/mp02.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03.doc (modified) * testsuites/mptests/mp03/node2/mp03.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04.doc (modified) * testsuites/mptests/mp04/node2/mp04.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05.doc (modified) * testsuites/mptests/mp05/node2/mp05.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06.doc (modified) * testsuites/mptests/mp06/node2/mp06.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07.doc (modified) * testsuites/mptests/mp07/node2/mp07.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08.doc (modified) * testsuites/mptests/mp08/node2/mp08.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.doc (modified) * testsuites/mptests/mp09/node2/mp09.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10.doc (modified) * testsuites/mptests/mp10/node2/mp10.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11.doc (modified) * testsuites/mptests/mp11/node2/mp11.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12.doc (modified) * testsuites/mptests/mp12/node2/mp12.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13.doc (modified) * testsuites/mptests/mp13/node2/mp13.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14.doc (modified) * testsuites/mptests/mp14/node2/mp14.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task1.c (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx08/task3.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp.doc (modified) * testsuites/samples/base_mp/node2/base_mp.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/minimum/minimum.doc (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp08/task1.c (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/sp26/init.c (modified) * testsuites/sptests/sp26/sp26.doc (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp26/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/puterr.c (modified) * testsuites/sptests/spfatal/spfatal.doc (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/task1.c (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) * tools/cpu/unix/gensize.c (modified) Updated copyright notice. Tue, 17 Feb 1998 23:46:28 GMT Joel Sherrill [60b791ad] * c/src/exec/libcsupport/include/clockdrv.h (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/iosupp.h (modified) * c/src/exec/libcsupport/include/motorola/mc68230.h (modified) * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/include/timerdrv.h (modified) * c/src/exec/libcsupport/include/vmeintr.h (modified) * c/src/exec/libcsupport/include/zilog/z8036.h (modified) * c/src/exec/libcsupport/include/zilog/z8530.h (modified) * c/src/exec/libcsupport/include/zilog/z8536.h (modified) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/condmp.h (modified) * c/src/exec/posix/headers/config.h (modified) * c/src/exec/posix/headers/intr.h (modified) * c/src/exec/posix/headers/key.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mqueuemp.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/mutexmp.h (modified) * c/src/exec/posix/headers/posixapi.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/pthreadmp.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/headers/semaphoremp.h (modified) * c/src/exec/posix/headers/seterr.h (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/condmp.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/posix/include/rtems/posix/key.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mqueuemp.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/posixapi.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthreadmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/posix/include/rtems/posix/seterr.h (modified) * c/src/exec/posix/inline/cond.inl (modified) * c/src/exec/posix/inline/intr.inl (modified) * c/src/exec/posix/inline/key.inl (modified) * c/src/exec/posix/inline/mqueue.inl (modified) * c/src/exec/posix/inline/mutex.inl (modified) * c/src/exec/posix/inline/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/intr.inl (modified) * c/src/exec/posix/inline/rtems/posix/key.inl (modified) * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * c/src/exec/posix/inline/rtems/posix/mutex.inl (modified) * c/src/exec/posix/inline/rtems/posix/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * c/src/exec/posix/inline/semaphore.inl (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/clock.h (modified) * c/src/exec/rtems/headers/config.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/mp.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/rtemsapi.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/dpmem.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/eventset.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/options.inl (modified) * c/src/exec/rtems/inline/part.inl (modified) * c/src/exec/rtems/inline/ratemon.inl (modified) * c/src/exec/rtems/inline/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/inline/sem.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/support.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/inline/timer.inl (modified) * c/src/exec/rtems/macros/asr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/dpmem.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/eventset.inl (modified) * c/src/exec/rtems/macros/message.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/options.inl (modified) * c/src/exec/rtems/macros/part.inl (modified) * c/src/exec/rtems/macros/ratemon.inl (modified) * c/src/exec/rtems/macros/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/options.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/part.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/macros/sem.inl (modified) * c/src/exec/rtems/macros/status.inl (modified) * c/src/exec/rtems/macros/support.inl (modified) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/macros/timer.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/attr.c (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/intrbody.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/fatal.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/headers/mptables.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/fatal.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/mptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/inline/extension.inl (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/sapi/macros/extension.inl (modified) * c/src/exec/sapi/macros/rtems/extension.inl (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/debug.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/posixapi.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/cpu/a29k/a29k.h (modified) * c/src/exec/score/cpu/a29k/a29ktypes.h (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.s (modified) * c/src/exec/score/cpu/a29k/rtems.c (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i386/i386types.h (modified) * c/src/exec/score/cpu/i386/rtems.s (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu_asm.s (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/i960/i960types.h (modified) * c/src/exec/score/cpu/i960/rtems.s (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/m68k/m68ktypes.h (modified) * c/src/exec/score/cpu/m68k/rtems.s (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/no_cpu.h (modified) * c/src/exec/score/cpu/no_cpu/no_cputypes.h (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) * c/src/exec/score/cpu/powerpc/ppctypes.h (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.s (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems.s (modified) * c/src/exec/score/cpu/sparc/sparc.h (modified) * c/src/exec/score/cpu/sparc/sparctypes.h (modified) * c/src/exec/score/cpu/unix/unix.h (modified) * c/src/exec/score/cpu/unix/unixtypes.h (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/apiext.h (modified) * c/src/exec/score/headers/bitfield.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/copyrt.h (modified) * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/headers/coremutex.h (modified) * c/src/exec/score/headers/coresem.h (modified) * c/src/exec/score/headers/debug.h (modified) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/interr.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/threadq.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/debug.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/copyrt.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/chain.inl (modified) * c/src/exec/score/inline/coremsg.inl (modified) * c/src/exec/score/inline/coremutex.inl (modified) * c/src/exec/score/inline/coresem.inl (modified) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/objectmp.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/threadmp.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/tqdata.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/address.inl (modified) * c/src/exec/score/macros/chain.inl (modified) * c/src/exec/score/macros/coremsg.inl (modified) * c/src/exec/score/macros/coremutex.inl (modified) * c/src/exec/score/macros/coresem.inl (modified) * c/src/exec/score/macros/heap.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/mppkt.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/objectmp.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/chain.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (modified) * c/src/exec/score/macros/rtems/score/coresem.inl (modified) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/mppkt.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/objectmp.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/threadmp.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/stack.inl (modified) * c/src/exec/score/macros/states.inl (modified) * c/src/exec/score/macros/sysstate.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/macros/threadmp.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/interr.c (modified) * c/src/exec/score/src/isr.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/tod.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/exec/score/tools/hppa1.1/genoffsets.c (modified) * c/src/exec/score/tools/unix/gensize.c (modified) * c/src/lib/include/clockdrv.h (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/iosupp.h (modified) * c/src/lib/include/motorola/mc68230.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/timerdrv.h (modified) * c/src/lib/include/vmeintr.h (modified) * c/src/lib/include/zilog/z8036.h (modified) * c/src/lib/include/zilog/z8530.h (modified) * c/src/lib/include/zilog/z8536.h (modified) * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/main.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/force386/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/lock.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/exit.c (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/force386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/force386/startup/setvec.c (modified) * c/src/lib/libbsp/i386/force386/timer/timer.c (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/include/coverhd.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/exit.c (modified) * c/src/lib/libbsp/i386/go32/startup/setvec.c (modified) * c/src/lib/libbsp/i386/go32/timer/timer.c (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/startup/sbrk.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.s (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (modified) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (modified) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/cTest.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspclean.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/exit.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/internal.h (modified) * c/src/lib/libc/libcsupport.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/support.c (modified) * c/src/lib/libc/syscalls.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * c/src/lib/libmisc/cpuuse/cpuuse.c (modified) * c/src/lib/libmisc/cpuuse/cpuuse.h (modified) * c/src/lib/libmisc/cpuuse/internal.h (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/internal.h (modified) * c/src/lib/libmisc/stackchk/stackchk.h (modified) * c/src/lib/start/i960/start.s (modified) * c/src/lib/start/m68k/start.s (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/cpuuse/internal.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/init.c (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * c/src/tests/libtests/monitor/init.c (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/rtems++/Init.cc (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtems++/Task1.cc (modified) * c/src/tests/libtests/rtems++/Task2.cc (modified) * c/src/tests/libtests/rtems++/Task3.cc (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/node1/mp01.doc (modified) * c/src/tests/mptests/mp01/node2/mp01.doc (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/node1/mp02.doc (modified) * c/src/tests/mptests/mp02/node2/mp02.doc (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp02/task1.c (modified) * c/src/tests/mptests/mp03/delay.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/node1/mp03.doc (modified) * c/src/tests/mptests/mp03/node2/mp03.doc (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp03/task1.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/node1/mp04.doc (modified) * c/src/tests/mptests/mp04/node2/mp04.doc (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp04/task1.c (modified) * c/src/tests/mptests/mp05/asr.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/node1/mp05.doc (modified) * c/src/tests/mptests/mp05/node2/mp05.doc (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp05/task1.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/node1/mp06.doc (modified) * c/src/tests/mptests/mp06/node2/mp06.doc (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp06/task1.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/node1/mp07.doc (modified) * c/src/tests/mptests/mp07/node2/mp07.doc (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/node1/mp08.doc (modified) * c/src/tests/mptests/mp08/node2/mp08.doc (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp08/task1.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.doc (modified) * c/src/tests/mptests/mp09/node2/mp09.doc (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/node1/mp10.doc (modified) * c/src/tests/mptests/mp10/node2/mp10.doc (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp10/task2.c (modified) * c/src/tests/mptests/mp10/task3.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/node1/mp11.doc (modified) * c/src/tests/mptests/mp11/node2/mp11.doc (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/node1/mp12.doc (modified) * c/src/tests/mptests/mp12/node2/mp12.doc (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/node1/mp13.doc (modified) * c/src/tests/mptests/mp13/node2/mp13.doc (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp13/task2.c (modified) * c/src/tests/mptests/mp14/delay.c (modified) * c/src/tests/mptests/mp14/evtask1.c (modified) * c/src/tests/mptests/mp14/evtmtask.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/node1/mp14.doc (modified) * c/src/tests/mptests/mp14/node2/mp14.doc (modified) * c/src/tests/mptests/mp14/pttask1.c (modified) * c/src/tests/mptests/mp14/smtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx02/task.c (modified) * c/src/tests/psxtests/psx03/init.c (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx03/task.c (modified) * c/src/tests/psxtests/psx04/init.c (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx04/task1.c (modified) * c/src/tests/psxtests/psx04/task2.c (modified) * c/src/tests/psxtests/psx04/task3.c (modified) * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task.c (modified) * c/src/tests/psxtests/psx05/task2.c (modified) * c/src/tests/psxtests/psx05/task3.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (modified) * c/src/tests/psxtests/psx08/init.c (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx08/task.c (modified) * c/src/tests/psxtests/psx08/task2.c (modified) * c/src/tests/psxtests/psx09/init.c (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/init.c (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx10/task.c (modified) * c/src/tests/psxtests/psx10/task2.c (modified) * c/src/tests/psxtests/psx10/task3.c (modified) * c/src/tests/psxtests/psx11/init.c (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx11/task.c (modified) * c/src/tests/psxtests/psx12/init.c (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx12/task.c (modified) * c/src/tests/psxtests/psxhdrs/clock01.c (modified) * c/src/tests/psxtests/psxhdrs/clock02.c (modified) * c/src/tests/psxtests/psxhdrs/clock03.c (modified) * c/src/tests/psxtests/psxhdrs/clock04.c (modified) * c/src/tests/psxtests/psxhdrs/clock05.c (modified) * c/src/tests/psxtests/psxhdrs/clock06.c (modified) * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/cond08.c (modified) * c/src/tests/psxtests/psxhdrs/cond09.c (modified) * c/src/tests/psxtests/psxhdrs/cond10.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/key04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/mutex10.c (modified) * c/src/tests/psxtests/psxhdrs/mutex11.c (modified) * c/src/tests/psxtests/psxhdrs/mutex12.c (modified) * c/src/tests/psxtests/psxhdrs/mutex13.c (modified) * c/src/tests/psxtests/psxhdrs/mutex14.c (modified) * c/src/tests/psxtests/psxhdrs/mutex15.c (modified) * c/src/tests/psxtests/psxhdrs/mutex16.c (modified) * c/src/tests/psxtests/psxhdrs/proc01.c (modified) * c/src/tests/psxtests/psxhdrs/proc02.c (modified) * c/src/tests/psxtests/psxhdrs/proc03.c (modified) * c/src/tests/psxtests/psxhdrs/proc04.c (modified) * c/src/tests/psxtests/psxhdrs/proc05.c (modified) * c/src/tests/psxtests/psxhdrs/proc06.c (modified) * c/src/tests/psxtests/psxhdrs/proc07.c (modified) * c/src/tests/psxtests/psxhdrs/proc08.c (modified) * c/src/tests/psxtests/psxhdrs/proc09.c (modified) * c/src/tests/psxtests/psxhdrs/proc10.c (modified) * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc12.c (modified) * c/src/tests/psxtests/psxhdrs/proc13.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread24.c (modified) * c/src/tests/psxtests/psxhdrs/pthread25.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * c/src/tests/psxtests/psxhdrs/pthread31.c (modified) * c/src/tests/psxtests/psxhdrs/pthread32.c (modified) * c/src/tests/psxtests/psxhdrs/pthread33.c (modified) * c/src/tests/psxtests/psxhdrs/pthread34.c (modified) * c/src/tests/psxtests/psxhdrs/pthread35.c (modified) * c/src/tests/psxtests/psxhdrs/pthread36.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * c/src/tests/psxtests/psxhdrs/signal01.c (modified) * c/src/tests/psxtests/psxhdrs/signal02.c (modified) * c/src/tests/psxtests/psxhdrs/signal03.c (modified) * c/src/tests/psxtests/psxhdrs/signal04.c (modified) * c/src/tests/psxtests/psxhdrs/signal05.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * c/src/tests/psxtests/psxhdrs/signal09.c (modified) * c/src/tests/psxtests/psxhdrs/signal10.c (modified) * c/src/tests/psxtests/psxhdrs/signal11.c (modified) * c/src/tests/psxtests/psxhdrs/signal12.c (modified) * c/src/tests/psxtests/psxhdrs/signal13.c (modified) * c/src/tests/psxtests/psxhdrs/signal14.c (modified) * c/src/tests/psxtests/psxhdrs/signal15.c (modified) * c/src/tests/psxtests/psxhdrs/signal16.c (modified) * c/src/tests/psxtests/psxhdrs/signal17.c (modified) * c/src/tests/psxtests/psxhdrs/signal18.c (modified) * c/src/tests/psxtests/psxhdrs/signal19.c (modified) * c/src/tests/psxtests/psxhdrs/signal20.c (modified) * c/src/tests/psxtests/psxhdrs/signal21.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * c/src/tests/psxtests/psxhdrs/time01.c (modified) * c/src/tests/psxtests/psxhdrs/time02.c (modified) * c/src/tests/psxtests/psxhdrs/time03.c (modified) * c/src/tests/psxtests/psxhdrs/time04.c (modified) * c/src/tests/psxtests/psxhdrs/time05.c (modified) * c/src/tests/psxtests/psxhdrs/time06.c (modified) * c/src/tests/psxtests/psxhdrs/time07.c (modified) * c/src/tests/psxtests/psxhdrs/time08.c (modified) * c/src/tests/psxtests/psxhdrs/time09.c (modified) * c/src/tests/psxtests/psxhdrs/time10.c (modified) * c/src/tests/psxtests/psxhdrs/time11.c (modified) * c/src/tests/psxtests/psxhdrs/time12.c (modified) * c/src/tests/psxtests/psxhdrs/time13.c (modified) * c/src/tests/psxtests/psxhdrs/timer01.c (modified) * c/src/tests/psxtests/psxhdrs/timer02.c (modified) * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * c/src/tests/psxtests/psxhdrs/timer06.c (modified) * c/src/tests/samples/README (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/node1/base_mp.doc (modified) * c/src/tests/samples/base_mp/node2/base_mp.doc (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/base_sp.doc (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/hello.doc (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.doc (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/ticker/ticker.doc (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/sp01.doc (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp01/task1.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/sp02.doc (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/sp03.doc (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp03/task1.c (modified) * c/src/tests/sptests/sp03/task2.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/sp04.doc (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/task2.c (modified) * c/src/tests/sptests/sp04/task3.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/sp05.doc (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp05/task1.c (modified) * c/src/tests/sptests/sp05/task2.c (modified) * c/src/tests/sptests/sp05/task3.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/sp06.doc (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp06/task1.c (modified) * c/src/tests/sptests/sp06/task2.c (modified) * c/src/tests/sptests/sp06/task3.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/sp07.doc (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp07/task2.c (modified) * c/src/tests/sptests/sp07/task3.c (modified) * c/src/tests/sptests/sp07/task4.c (modified) * c/src/tests/sptests/sp07/taskexit.c (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp07/tdelete.c (modified) * c/src/tests/sptests/sp07/trestart.c (modified) * c/src/tests/sptests/sp07/tstart.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/sp08.doc (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp08/task1.c (modified) * c/src/tests/sptests/sp09/delay.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/isr.c (modified) * c/src/tests/sptests/sp09/screen01.c (modified) * c/src/tests/sptests/sp09/screen02.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp09/screen04.c (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen06.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen10.c (modified) * c/src/tests/sptests/sp09/screen11.c (modified) * c/src/tests/sptests/sp09/screen12.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/screen14.c (modified) * c/src/tests/sptests/sp09/sp09.doc (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp09/task2.c (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp09/task4.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/sp11.doc (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp11/timer.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/pritask.c (modified) * c/src/tests/sptests/sp12/sp12.doc (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp12/task2.c (modified) * c/src/tests/sptests/sp12/task3.c (modified) * c/src/tests/sptests/sp12/task4.c (modified) * c/src/tests/sptests/sp12/task5.c (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.doc (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/asr.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/sp14.doc (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp14/task2.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/sp15.doc (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp15/task1.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/sp16.doc (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp16/task2.c (modified) * c/src/tests/sptests/sp16/task3.c (modified) * c/src/tests/sptests/sp16/task4.c (modified) * c/src/tests/sptests/sp16/task5.c (modified) * c/src/tests/sptests/sp17/asr.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/sp17.doc (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp17/task1.c (modified) * c/src/tests/sptests/sp17/task2.c (modified) * c/src/tests/sptests/sp19/first.c (modified) * c/src/tests/sptests/sp19/fptask.c (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/sp19.doc (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp19/task1.c (modified) * c/src/tests/sptests/sp20/getall.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/sp20.doc (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp20/task1.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/sp21.doc (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/delay.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/prtime.c (modified) * c/src/tests/sptests/sp22/sp22.doc (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/sp23.doc (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp23/task1.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/resume.c (modified) * c/src/tests/sptests/sp24/sp24.doc (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp24/task1.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/sp25.doc (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/puterr.c (modified) * c/src/tests/sptests/spfatal/spfatal.doc (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spfatal/task1.c (modified) * c/src/tests/sptests/spsize/getint.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/support/stubdr/init.c (modified) * c/src/tests/support/stubdr/open.c (modified) * c/src/tests/support/stubdr/read.c (modified) * c/src/tests/support/stubdr/stubdrv.h (modified) * c/src/tests/support/stubdr/write.c (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm01/tm01.doc (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm02/tm02.doc (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm03/tm03.doc (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm04/tm04.doc (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm05/tm05.doc (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm06/tm06.doc (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm07/tm07.doc (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm08/tm08.doc (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm09/tm09.doc (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm10/tm10.doc (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm11/tm11.doc (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm12/tm12.doc (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm13/tm13.doc (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm14/tm14.doc (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm15/tm15.doc (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm16/tm16.doc (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm17/tm17.doc (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm18/tm18.doc (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm19/tm19.doc (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm20/tm20.doc (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm21/tm21.doc (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm22/tm22.doc (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm23/tm23.doc (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm24/tm24.doc (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm25/tm25.doc (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm26/tm26.doc (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm27/tm27.doc (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm28/tm28.doc (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tm29/tm29.doc (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmck/tmck.doc (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/empty.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condmp.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueuemp.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadmp.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/intr.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/eventset.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/options.inl (modified) * cpukit/rtems/macros/rtems/rtems/part.inl (modified) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/macros/rtems/rtems/region.inl (modified) * cpukit/rtems/macros/rtems/rtems/sem.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/timer.inl (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/macros/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/cpu/a29k/cpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (modified) * cpukit/score/macros/rtems/score/coresem.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/mppkt.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/objectmp.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01.doc (modified) * testsuites/mptests/mp01/node2/mp01.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02.doc (modified) * testsuites/mptests/mp02/node2/mp02.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03.doc (modified) * testsuites/mptests/mp03/node2/mp03.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04.doc (modified) * testsuites/mptests/mp04/node2/mp04.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05.doc (modified) * testsuites/mptests/mp05/node2/mp05.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06.doc (modified) * testsuites/mptests/mp06/node2/mp06.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07.doc (modified) * testsuites/mptests/mp07/node2/mp07.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08.doc (modified) * testsuites/mptests/mp08/node2/mp08.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.doc (modified) * testsuites/mptests/mp09/node2/mp09.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10.doc (modified) * testsuites/mptests/mp10/node2/mp10.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11.doc (modified) * testsuites/mptests/mp11/node2/mp11.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12.doc (modified) * testsuites/mptests/mp12/node2/mp12.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13.doc (modified) * testsuites/mptests/mp13/node2/mp13.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14.doc (modified) * testsuites/mptests/mp14/node2/mp14.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp.doc (modified) * testsuites/samples/base_mp/node2/base_mp.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp08/task1.c (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/puterr.c (modified) * testsuites/sptests/spfatal/spfatal.doc (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/task1.c (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) * tools/cpu/unix/gensize.c (modified) updated copyright to 1998 Wed, 08 Oct 1997 15:45:54 GMT Joel Sherrill [98e4ebf5] * c/src/exec/libcsupport/include/clockdrv.h (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/iosupp.h (modified) * c/src/exec/libcsupport/include/motorola/mc68230.h (modified) * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/exec/libcsupport/include/spurious.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/include/timerdrv.h (modified) * c/src/exec/libcsupport/include/vmeintr.h (modified) * c/src/exec/libcsupport/include/zilog/z8036.h (modified) * c/src/exec/libcsupport/include/zilog/z8530.h (modified) * c/src/exec/libcsupport/include/zilog/z8536.h (modified) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/condmp.h (modified) * c/src/exec/posix/headers/config.h (modified) * c/src/exec/posix/headers/intr.h (modified) * c/src/exec/posix/headers/key.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mqueuemp.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/mutexmp.h (modified) * c/src/exec/posix/headers/posixapi.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/pthreadmp.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/headers/semaphoremp.h (modified) * c/src/exec/posix/headers/seterr.h (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/condmp.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/posix/include/rtems/posix/key.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mqueuemp.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/posixapi.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthreadmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/posix/include/rtems/posix/seterr.h (modified) * c/src/exec/posix/inline/cond.inl (modified) * c/src/exec/posix/inline/intr.inl (modified) * c/src/exec/posix/inline/key.inl (modified) * c/src/exec/posix/inline/mqueue.inl (modified) * c/src/exec/posix/inline/mutex.inl (modified) * c/src/exec/posix/inline/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/intr.inl (modified) * c/src/exec/posix/inline/rtems/posix/key.inl (modified) * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * c/src/exec/posix/inline/rtems/posix/mutex.inl (modified) * c/src/exec/posix/inline/rtems/posix/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * c/src/exec/posix/inline/semaphore.inl (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/clock.h (modified) * c/src/exec/rtems/headers/config.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/mp.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/rtemsapi.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/dpmem.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/eventset.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/options.inl (modified) * c/src/exec/rtems/inline/part.inl (modified) * c/src/exec/rtems/inline/ratemon.inl (modified) * c/src/exec/rtems/inline/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/inline/sem.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/support.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/inline/timer.inl (modified) * c/src/exec/rtems/macros/asr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/dpmem.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/eventset.inl (modified) * c/src/exec/rtems/macros/message.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/options.inl (modified) * c/src/exec/rtems/macros/part.inl (modified) * c/src/exec/rtems/macros/ratemon.inl (modified) * c/src/exec/rtems/macros/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/options.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/part.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/macros/sem.inl (modified) * c/src/exec/rtems/macros/status.inl (modified) * c/src/exec/rtems/macros/support.inl (modified) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/macros/timer.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/attr.c (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/intrbody.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/directives.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/fatal.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/headers/mptables.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/directives.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/fatal.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/mptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/inline/extension.inl (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/sapi/macros/extension.inl (modified) * c/src/exec/sapi/macros/rtems/extension.inl (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/debug.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/posixapi.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/cpu/a29k/a29k.h (modified) * c/src/exec/score/cpu/a29k/a29ktypes.h (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.s (modified) * c/src/exec/score/cpu/a29k/rtems.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i386/i386types.h (modified) * c/src/exec/score/cpu/i386/rtems.s (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu_asm.s (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/i960/i960types.h (modified) * c/src/exec/score/cpu/i960/rtems.s (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/m68k/m68ktypes.h (modified) * c/src/exec/score/cpu/m68k/rtems.s (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/no_cpu.h (modified) * c/src/exec/score/cpu/no_cpu/no_cputypes.h (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) * c/src/exec/score/cpu/powerpc/ppctypes.h (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.s (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems.s (modified) * c/src/exec/score/cpu/sparc/sparc.h (modified) * c/src/exec/score/cpu/sparc/sparctypes.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/cpu/unix/unix.h (modified) * c/src/exec/score/cpu/unix/unixtypes.h (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/apiext.h (modified) * c/src/exec/score/headers/bitfield.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/copyrt.h (modified) * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/headers/coremutex.h (modified) * c/src/exec/score/headers/coresem.h (modified) * c/src/exec/score/headers/debug.h (modified) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/interr.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/threadq.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/debug.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/copyrt.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/chain.inl (modified) * c/src/exec/score/inline/coremsg.inl (modified) * c/src/exec/score/inline/coremutex.inl (modified) * c/src/exec/score/inline/coresem.inl (modified) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/objectmp.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/threadmp.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/tqdata.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/address.inl (modified) * c/src/exec/score/macros/chain.inl (modified) * c/src/exec/score/macros/coremsg.inl (modified) * c/src/exec/score/macros/coremutex.inl (modified) * c/src/exec/score/macros/coresem.inl (modified) * c/src/exec/score/macros/heap.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/mppkt.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/objectmp.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/chain.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (modified) * c/src/exec/score/macros/rtems/score/coresem.inl (modified) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/mppkt.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/objectmp.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/threadmp.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/stack.inl (modified) * c/src/exec/score/macros/states.inl (modified) * c/src/exec/score/macros/sysstate.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/macros/threadmp.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/interr.c (modified) * c/src/exec/score/src/isr.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/tod.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/exec/score/tools/hppa1.1/genoffsets.c (modified) * c/src/exec/score/tools/unix/gensize.c (modified) * c/src/lib/include/clockdrv.h (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/iosupp.h (modified) * c/src/lib/include/motorola/mc68230.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/include/spurious.h (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/timerdrv.h (modified) * c/src/lib/include/vmeintr.h (modified) * c/src/lib/include/zilog/z8036.h (modified) * c/src/lib/include/zilog/z8530.h (modified) * c/src/lib/include/zilog/z8536.h (modified) * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/main.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/print_dump.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/tty.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/force386/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/lock.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/exit.c (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/force386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/force386/startup/setvec.c (modified) * c/src/lib/libbsp/i386/force386/timer/timer.c (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/include/coverhd.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/exit.c (modified) * c/src/lib/libbsp/i386/go32/startup/setvec.c (modified) * c/src/lib/libbsp/i386/go32/timer/timer.c (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (modified) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (modified) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/cTest.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/console/console.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspclean.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/exit.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/internal.h (modified) * c/src/lib/libc/libcsupport.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/support.c (modified) * c/src/lib/libc/syscalls.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.c (modified) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.h (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * c/src/lib/libmisc/cpuuse/cpuuse.c (modified) * c/src/lib/libmisc/cpuuse/cpuuse.h (modified) * c/src/lib/libmisc/cpuuse/internal.h (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/internal.h (modified) * c/src/lib/libmisc/stackchk/stackchk.h (modified) * c/src/lib/start/i960/start.s (modified) * c/src/lib/start/m68k/start.s (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/cpuuse/internal.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/init.c (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * c/src/tests/libtests/monitor/init.c (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/rtems++/Init.cc (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtems++/Task1.cc (modified) * c/src/tests/libtests/rtems++/Task2.cc (modified) * c/src/tests/libtests/rtems++/Task3.cc (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/node1/mp01.doc (modified) * c/src/tests/mptests/mp01/node2/mp01.doc (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/node1/mp02.doc (modified) * c/src/tests/mptests/mp02/node2/mp02.doc (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp02/task1.c (modified) * c/src/tests/mptests/mp03/delay.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/node1/mp03.doc (modified) * c/src/tests/mptests/mp03/node2/mp03.doc (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp03/task1.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/node1/mp04.doc (modified) * c/src/tests/mptests/mp04/node2/mp04.doc (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp04/task1.c (modified) * c/src/tests/mptests/mp05/asr.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/node1/mp05.doc (modified) * c/src/tests/mptests/mp05/node2/mp05.doc (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp05/task1.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/node1/mp06.doc (modified) * c/src/tests/mptests/mp06/node2/mp06.doc (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp06/task1.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/node1/mp07.doc (modified) * c/src/tests/mptests/mp07/node2/mp07.doc (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/node1/mp08.doc (modified) * c/src/tests/mptests/mp08/node2/mp08.doc (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp08/task1.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.doc (modified) * c/src/tests/mptests/mp09/node2/mp09.doc (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/node1/mp10.doc (modified) * c/src/tests/mptests/mp10/node2/mp10.doc (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp10/task2.c (modified) * c/src/tests/mptests/mp10/task3.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/node1/mp11.doc (modified) * c/src/tests/mptests/mp11/node2/mp11.doc (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/node1/mp12.doc (modified) * c/src/tests/mptests/mp12/node2/mp12.doc (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/node1/mp13.doc (modified) * c/src/tests/mptests/mp13/node2/mp13.doc (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp13/task2.c (modified) * c/src/tests/mptests/mp14/delay.c (modified) * c/src/tests/mptests/mp14/evtask1.c (modified) * c/src/tests/mptests/mp14/evtmtask.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/node1/mp14.doc (modified) * c/src/tests/mptests/mp14/node2/mp14.doc (modified) * c/src/tests/mptests/mp14/pttask1.c (modified) * c/src/tests/mptests/mp14/smtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx02/task.c (modified) * c/src/tests/psxtests/psx03/init.c (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx03/task.c (modified) * c/src/tests/psxtests/psx04/init.c (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx04/task1.c (modified) * c/src/tests/psxtests/psx04/task2.c (modified) * c/src/tests/psxtests/psx04/task3.c (modified) * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task.c (modified) * c/src/tests/psxtests/psx05/task2.c (modified) * c/src/tests/psxtests/psx05/task3.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (modified) * c/src/tests/psxtests/psx08/init.c (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx08/task.c (modified) * c/src/tests/psxtests/psx08/task2.c (modified) * c/src/tests/psxtests/psx09/init.c (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/init.c (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx10/task.c (modified) * c/src/tests/psxtests/psx10/task2.c (modified) * c/src/tests/psxtests/psx10/task3.c (modified) * c/src/tests/psxtests/psx11/init.c (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx11/task.c (modified) * c/src/tests/psxtests/psx12/init.c (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx12/task.c (modified) * c/src/tests/psxtests/psxhdrs/clock01.c (modified) * c/src/tests/psxtests/psxhdrs/clock02.c (modified) * c/src/tests/psxtests/psxhdrs/clock03.c (modified) * c/src/tests/psxtests/psxhdrs/clock04.c (modified) * c/src/tests/psxtests/psxhdrs/clock05.c (modified) * c/src/tests/psxtests/psxhdrs/clock06.c (modified) * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/cond08.c (modified) * c/src/tests/psxtests/psxhdrs/cond09.c (modified) * c/src/tests/psxtests/psxhdrs/cond10.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/key04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/mutex10.c (modified) * c/src/tests/psxtests/psxhdrs/mutex11.c (modified) * c/src/tests/psxtests/psxhdrs/mutex12.c (modified) * c/src/tests/psxtests/psxhdrs/mutex13.c (modified) * c/src/tests/psxtests/psxhdrs/mutex14.c (modified) * c/src/tests/psxtests/psxhdrs/mutex15.c (modified) * c/src/tests/psxtests/psxhdrs/mutex16.c (modified) * c/src/tests/psxtests/psxhdrs/proc01.c (modified) * c/src/tests/psxtests/psxhdrs/proc02.c (modified) * c/src/tests/psxtests/psxhdrs/proc03.c (modified) * c/src/tests/psxtests/psxhdrs/proc04.c (modified) * c/src/tests/psxtests/psxhdrs/proc05.c (modified) * c/src/tests/psxtests/psxhdrs/proc06.c (modified) * c/src/tests/psxtests/psxhdrs/proc07.c (modified) * c/src/tests/psxtests/psxhdrs/proc08.c (modified) * c/src/tests/psxtests/psxhdrs/proc09.c (modified) * c/src/tests/psxtests/psxhdrs/proc10.c (modified) * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc12.c (modified) * c/src/tests/psxtests/psxhdrs/proc13.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread24.c (modified) * c/src/tests/psxtests/psxhdrs/pthread25.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * c/src/tests/psxtests/psxhdrs/pthread31.c (modified) * c/src/tests/psxtests/psxhdrs/pthread32.c (modified) * c/src/tests/psxtests/psxhdrs/pthread33.c (modified) * c/src/tests/psxtests/psxhdrs/pthread34.c (modified) * c/src/tests/psxtests/psxhdrs/pthread35.c (modified) * c/src/tests/psxtests/psxhdrs/pthread36.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * c/src/tests/psxtests/psxhdrs/signal01.c (modified) * c/src/tests/psxtests/psxhdrs/signal02.c (modified) * c/src/tests/psxtests/psxhdrs/signal03.c (modified) * c/src/tests/psxtests/psxhdrs/signal04.c (modified) * c/src/tests/psxtests/psxhdrs/signal05.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * c/src/tests/psxtests/psxhdrs/signal09.c (modified) * c/src/tests/psxtests/psxhdrs/signal10.c (modified) * c/src/tests/psxtests/psxhdrs/signal11.c (modified) * c/src/tests/psxtests/psxhdrs/signal12.c (modified) * c/src/tests/psxtests/psxhdrs/signal13.c (modified) * c/src/tests/psxtests/psxhdrs/signal14.c (modified) * c/src/tests/psxtests/psxhdrs/signal15.c (modified) * c/src/tests/psxtests/psxhdrs/signal16.c (modified) * c/src/tests/psxtests/psxhdrs/signal17.c (modified) * c/src/tests/psxtests/psxhdrs/signal18.c (modified) * c/src/tests/psxtests/psxhdrs/signal19.c (modified) * c/src/tests/psxtests/psxhdrs/signal20.c (modified) * c/src/tests/psxtests/psxhdrs/signal21.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * c/src/tests/psxtests/psxhdrs/time01.c (modified) * c/src/tests/psxtests/psxhdrs/time02.c (modified) * c/src/tests/psxtests/psxhdrs/time03.c (modified) * c/src/tests/psxtests/psxhdrs/time04.c (modified) * c/src/tests/psxtests/psxhdrs/time05.c (modified) * c/src/tests/psxtests/psxhdrs/time06.c (modified) * c/src/tests/psxtests/psxhdrs/time07.c (modified) * c/src/tests/psxtests/psxhdrs/time08.c (modified) * c/src/tests/psxtests/psxhdrs/time09.c (modified) * c/src/tests/psxtests/psxhdrs/time10.c (modified) * c/src/tests/psxtests/psxhdrs/time11.c (modified) * c/src/tests/psxtests/psxhdrs/time12.c (modified) * c/src/tests/psxtests/psxhdrs/time13.c (modified) * c/src/tests/psxtests/psxhdrs/timer01.c (modified) * c/src/tests/psxtests/psxhdrs/timer02.c (modified) * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * c/src/tests/psxtests/psxhdrs/timer06.c (modified) * c/src/tests/samples/README (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/node1/base_mp.doc (modified) * c/src/tests/samples/base_mp/node2/base_mp.doc (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/base_sp.doc (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/main.cc (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/hello.doc (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.doc (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/ticker/ticker.doc (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/sp01.doc (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp01/task1.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/sp02.doc (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/sp03.doc (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp03/task1.c (modified) * c/src/tests/sptests/sp03/task2.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/sp04.doc (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/task2.c (modified) * c/src/tests/sptests/sp04/task3.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/sp05.doc (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp05/task1.c (modified) * c/src/tests/sptests/sp05/task2.c (modified) * c/src/tests/sptests/sp05/task3.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/sp06.doc (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp06/task1.c (modified) * c/src/tests/sptests/sp06/task2.c (modified) * c/src/tests/sptests/sp06/task3.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/sp07.doc (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp07/task2.c (modified) * c/src/tests/sptests/sp07/task3.c (modified) * c/src/tests/sptests/sp07/task4.c (modified) * c/src/tests/sptests/sp07/taskexit.c (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp07/tdelete.c (modified) * c/src/tests/sptests/sp07/trestart.c (modified) * c/src/tests/sptests/sp07/tstart.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/sp08.doc (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp08/task1.c (modified) * c/src/tests/sptests/sp09/delay.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/isr.c (modified) * c/src/tests/sptests/sp09/screen01.c (modified) * c/src/tests/sptests/sp09/screen02.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp09/screen04.c (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen06.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen10.c (modified) * c/src/tests/sptests/sp09/screen11.c (modified) * c/src/tests/sptests/sp09/screen12.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/screen14.c (modified) * c/src/tests/sptests/sp09/sp09.doc (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp09/task2.c (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp09/task4.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/sp11.doc (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp11/timer.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/pritask.c (modified) * c/src/tests/sptests/sp12/sp12.doc (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp12/task2.c (modified) * c/src/tests/sptests/sp12/task3.c (modified) * c/src/tests/sptests/sp12/task4.c (modified) * c/src/tests/sptests/sp12/task5.c (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.doc (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/asr.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/sp14.doc (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp14/task2.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/sp15.doc (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp15/task1.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/sp16.doc (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp16/task2.c (modified) * c/src/tests/sptests/sp16/task3.c (modified) * c/src/tests/sptests/sp16/task4.c (modified) * c/src/tests/sptests/sp16/task5.c (modified) * c/src/tests/sptests/sp17/asr.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/sp17.doc (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp17/task1.c (modified) * c/src/tests/sptests/sp17/task2.c (modified) * c/src/tests/sptests/sp19/first.c (modified) * c/src/tests/sptests/sp19/fptask.c (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/sp19.doc (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp19/task1.c (modified) * c/src/tests/sptests/sp20/getall.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/sp20.doc (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp20/task1.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/sp21.doc (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/delay.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/prtime.c (modified) * c/src/tests/sptests/sp22/sp22.doc (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/sp23.doc (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp23/task1.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/resume.c (modified) * c/src/tests/sptests/sp24/sp24.doc (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp24/task1.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/sp25.doc (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/puterr.c (modified) * c/src/tests/sptests/spfatal/spfatal.doc (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spfatal/task1.c (modified) * c/src/tests/sptests/spsize/getint.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/support/stubdr/init.c (modified) * c/src/tests/support/stubdr/open.c (modified) * c/src/tests/support/stubdr/read.c (modified) * c/src/tests/support/stubdr/stubdrv.h (modified) * c/src/tests/support/stubdr/write.c (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm01/tm01.doc (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm02/tm02.doc (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm03/tm03.doc (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm04/tm04.doc (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm05/tm05.doc (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm06/tm06.doc (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm07/tm07.doc (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm08/tm08.doc (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm09/tm09.doc (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm10/tm10.doc (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm11/tm11.doc (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm12/tm12.doc (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm13/tm13.doc (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm14/tm14.doc (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm15/tm15.doc (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm16/tm16.doc (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm17/tm17.doc (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm18/tm18.doc (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm19/tm19.doc (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm20/tm20.doc (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm21/tm21.doc (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm22/tm22.doc (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm23/tm23.doc (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm24/tm24.doc (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm25/tm25.doc (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm26/tm26.doc (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm27/tm27.doc (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm28/tm28.doc (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tm29/tm29.doc (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmck/tmck.doc (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/empty.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/spurious.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condmp.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueuemp.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadmp.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/intr.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/eventset.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/options.inl (modified) * cpukit/rtems/macros/rtems/rtems/part.inl (modified) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/macros/rtems/rtems/region.inl (modified) * cpukit/rtems/macros/rtems/rtems/sem.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/timer.inl (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/macros/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/cpu/a29k/cpu.c (modified) * cpukit/score/cpu/hppa1.1/cpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (modified) * cpukit/score/macros/rtems/score/coresem.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/mppkt.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/objectmp.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01.doc (modified) * testsuites/mptests/mp01/node2/mp01.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02.doc (modified) * testsuites/mptests/mp02/node2/mp02.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03.doc (modified) * testsuites/mptests/mp03/node2/mp03.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04.doc (modified) * testsuites/mptests/mp04/node2/mp04.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05.doc (modified) * testsuites/mptests/mp05/node2/mp05.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06.doc (modified) * testsuites/mptests/mp06/node2/mp06.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07.doc (modified) * testsuites/mptests/mp07/node2/mp07.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08.doc (modified) * testsuites/mptests/mp08/node2/mp08.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.doc (modified) * testsuites/mptests/mp09/node2/mp09.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10.doc (modified) * testsuites/mptests/mp10/node2/mp10.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11.doc (modified) * testsuites/mptests/mp11/node2/mp11.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12.doc (modified) * testsuites/mptests/mp12/node2/mp12.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13.doc (modified) * testsuites/mptests/mp13/node2/mp13.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14.doc (modified) * testsuites/mptests/mp14/node2/mp14.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp.doc (modified) * testsuites/samples/base_mp/node2/base_mp.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp08/task1.c (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/puterr.c (modified) * testsuites/sptests/spfatal/spfatal.doc (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/task1.c (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) * tools/cpu/unix/gensize.c (modified) Fixed typo in the pointer to the license terms. Tue, 22 Apr 1997 17:20:27 GMT Joel Sherrill [03f2154e] * c/src/exec/libcsupport/include/clockdrv.h (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/iosupp.h (modified) * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/exec/libcsupport/include/spurious.h (modified) * c/src/exec/libcsupport/include/timerdrv.h (modified) * c/src/exec/libcsupport/include/vmeintr.h (modified) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/condmp.h (modified) * c/src/exec/posix/headers/config.h (modified) * c/src/exec/posix/headers/intr.h (modified) * c/src/exec/posix/headers/key.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mqueuemp.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/mutexmp.h (modified) * c/src/exec/posix/headers/posixapi.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/pthreadmp.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/headers/semaphoremp.h (modified) * c/src/exec/posix/headers/seterr.h (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/condmp.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/posix/include/rtems/posix/key.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mqueuemp.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/posixapi.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthreadmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/posix/include/rtems/posix/seterr.h (modified) * c/src/exec/posix/inline/cond.inl (modified) * c/src/exec/posix/inline/intr.inl (modified) * c/src/exec/posix/inline/key.inl (modified) * c/src/exec/posix/inline/mqueue.inl (modified) * c/src/exec/posix/inline/mutex.inl (modified) * c/src/exec/posix/inline/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/intr.inl (modified) * c/src/exec/posix/inline/rtems/posix/key.inl (modified) * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * c/src/exec/posix/inline/rtems/posix/mutex.inl (modified) * c/src/exec/posix/inline/rtems/posix/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * c/src/exec/posix/inline/semaphore.inl (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/clock.h (modified) * c/src/exec/rtems/headers/config.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/mp.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/rtemsapi.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/dpmem.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/eventset.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/options.inl (modified) * c/src/exec/rtems/inline/part.inl (modified) * c/src/exec/rtems/inline/ratemon.inl (modified) * c/src/exec/rtems/inline/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/inline/sem.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/support.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/inline/timer.inl (modified) * c/src/exec/rtems/macros/asr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/dpmem.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/eventset.inl (modified) * c/src/exec/rtems/macros/message.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/options.inl (modified) * c/src/exec/rtems/macros/part.inl (modified) * c/src/exec/rtems/macros/ratemon.inl (modified) * c/src/exec/rtems/macros/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/options.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/part.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/macros/sem.inl (modified) * c/src/exec/rtems/macros/status.inl (modified) * c/src/exec/rtems/macros/support.inl (modified) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/macros/timer.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/directives.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/fatal.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/headers/mptables.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/directives.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/fatal.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/mptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/inline/extension.inl (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/sapi/macros/extension.inl (modified) * c/src/exec/sapi/macros/rtems/extension.inl (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/debug.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/posixapi.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/cpu/a29k/a29k.h (modified) * c/src/exec/score/cpu/a29k/a29ktypes.h (modified) * c/src/exec/score/cpu/a29k/asm.h (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.h (modified) * c/src/exec/score/cpu/a29k/cpu_asm.s (modified) * c/src/exec/score/cpu/a29k/rtems.c (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/asm.h (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i386/i386types.h (modified) * c/src/exec/score/cpu/i386/rtems.s (modified) * c/src/exec/score/cpu/i960/asm.h (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu_asm.s (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/i960/i960types.h (modified) * c/src/exec/score/cpu/i960/rtems.s (modified) * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/m68k/m68ktypes.h (modified) * c/src/exec/score/cpu/m68k/rtems.s (modified) * c/src/exec/score/cpu/mips/asm.h (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/asm.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/asm.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/no_cpu.h (modified) * c/src/exec/score/cpu/no_cpu/no_cputypes.h (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) * c/src/exec/score/cpu/powerpc/ppctypes.h (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.s (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems.s (modified) * c/src/exec/score/cpu/sparc/sparc.h (modified) * c/src/exec/score/cpu/sparc/sparctypes.h (modified) * c/src/exec/score/cpu/unix/unix.h (modified) * c/src/exec/score/cpu/unix/unixtypes.h (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/apiext.h (modified) * c/src/exec/score/headers/bitfield.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/copyrt.h (modified) * c/src/exec/score/headers/coremsg.h (modified) * c/src/exec/score/headers/coremutex.h (modified) * c/src/exec/score/headers/coresem.h (modified) * c/src/exec/score/headers/debug.h (modified) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/interr.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/threadq.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/debug.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/copyrt.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/chain.inl (modified) * c/src/exec/score/inline/coremsg.inl (modified) * c/src/exec/score/inline/coremutex.inl (modified) * c/src/exec/score/inline/coresem.inl (modified) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/objectmp.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/threadmp.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/tqdata.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/address.inl (modified) * c/src/exec/score/macros/chain.inl (modified) * c/src/exec/score/macros/coremsg.inl (modified) * c/src/exec/score/macros/coremutex.inl (modified) * c/src/exec/score/macros/coresem.inl (modified) * c/src/exec/score/macros/heap.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/mppkt.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/objectmp.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/chain.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (modified) * c/src/exec/score/macros/rtems/score/coresem.inl (modified) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/mppkt.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/objectmp.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/threadmp.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/stack.inl (modified) * c/src/exec/score/macros/states.inl (modified) * c/src/exec/score/macros/sysstate.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/macros/threadmp.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/interr.c (modified) * c/src/exec/score/src/isr.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/tod.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/exec/score/tools/hppa1.1/genoffsets.c (modified) * c/src/exec/score/tools/unix/gensize.c (modified) * c/src/lib/include/clockdrv.h (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/iosupp.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/include/spurious.h (modified) * c/src/lib/include/timerdrv.h (modified) * c/src/lib/include/vmeintr.h (modified) * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/main.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/force386/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/lock.c (modified) * c/src/lib/libbsp/i386/force386/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/exit.c (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/force386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/force386/startup/setvec.c (modified) * c/src/lib/libbsp/i386/force386/timer/timer.c (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/include/coverhd.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/exit.c (modified) * c/src/lib/libbsp/i386/go32/startup/setvec.c (modified) * c/src/lib/libbsp/i386/go32/timer/timer.c (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (modified) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (modified) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.s (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.s (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspclean.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/exit.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/internal.h (modified) * c/src/lib/libc/libcsupport.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/support.c (modified) * c/src/lib/libc/syscalls.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * c/src/lib/libmisc/cpuuse/cpuuse.c (modified) * c/src/lib/libmisc/cpuuse/cpuuse.h (modified) * c/src/lib/libmisc/cpuuse/internal.h (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/internal.h (modified) * c/src/lib/libmisc/stackchk/stackchk.h (modified) * c/src/lib/start/i960/start.s (modified) * c/src/lib/start/m68k/start.s (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/cpuuse/internal.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/init.c (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/node1/mp01.doc (modified) * c/src/tests/mptests/mp01/node2/mp01.doc (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/node1/mp02.doc (modified) * c/src/tests/mptests/mp02/node2/mp02.doc (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp02/task1.c (modified) * c/src/tests/mptests/mp03/delay.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/node1/mp03.doc (modified) * c/src/tests/mptests/mp03/node2/mp03.doc (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp03/task1.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/node1/mp04.doc (modified) * c/src/tests/mptests/mp04/node2/mp04.doc (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp04/task1.c (modified) * c/src/tests/mptests/mp05/asr.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/node1/mp05.doc (modified) * c/src/tests/mptests/mp05/node2/mp05.doc (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp05/task1.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/node1/mp06.doc (modified) * c/src/tests/mptests/mp06/node2/mp06.doc (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp06/task1.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/node1/mp07.doc (modified) * c/src/tests/mptests/mp07/node2/mp07.doc (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/node1/mp08.doc (modified) * c/src/tests/mptests/mp08/node2/mp08.doc (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp08/task1.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.doc (modified) * c/src/tests/mptests/mp09/node2/mp09.doc (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/node1/mp10.doc (modified) * c/src/tests/mptests/mp10/node2/mp10.doc (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp10/task2.c (modified) * c/src/tests/mptests/mp10/task3.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/node1/mp11.doc (modified) * c/src/tests/mptests/mp11/node2/mp11.doc (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/node1/mp12.doc (modified) * c/src/tests/mptests/mp12/node2/mp12.doc (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/node1/mp13.doc (modified) * c/src/tests/mptests/mp13/node2/mp13.doc (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp13/task2.c (modified) * c/src/tests/mptests/mp14/delay.c (modified) * c/src/tests/mptests/mp14/evtask1.c (modified) * c/src/tests/mptests/mp14/evtmtask.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/node1/mp14.doc (modified) * c/src/tests/mptests/mp14/node2/mp14.doc (modified) * c/src/tests/mptests/mp14/pttask1.c (modified) * c/src/tests/mptests/mp14/smtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx02/task.c (modified) * c/src/tests/psxtests/psx03/init.c (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx03/task.c (modified) * c/src/tests/psxtests/psx04/init.c (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx04/task1.c (modified) * c/src/tests/psxtests/psx04/task2.c (modified) * c/src/tests/psxtests/psx04/task3.c (modified) * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task.c (modified) * c/src/tests/psxtests/psx05/task2.c (modified) * c/src/tests/psxtests/psx05/task3.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (modified) * c/src/tests/psxtests/psx08/init.c (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx08/task.c (modified) * c/src/tests/psxtests/psx08/task2.c (modified) * c/src/tests/psxtests/psx09/init.c (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/init.c (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx10/task.c (modified) * c/src/tests/psxtests/psx10/task2.c (modified) * c/src/tests/psxtests/psx10/task3.c (modified) * c/src/tests/psxtests/psx11/init.c (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx11/task.c (modified) * c/src/tests/psxtests/psx12/init.c (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx12/task.c (modified) * c/src/tests/psxtests/psxhdrs/clock01.c (modified) * c/src/tests/psxtests/psxhdrs/clock02.c (modified) * c/src/tests/psxtests/psxhdrs/clock03.c (modified) * c/src/tests/psxtests/psxhdrs/clock04.c (modified) * c/src/tests/psxtests/psxhdrs/clock05.c (modified) * c/src/tests/psxtests/psxhdrs/clock06.c (modified) * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/cond08.c (modified) * c/src/tests/psxtests/psxhdrs/cond09.c (modified) * c/src/tests/psxtests/psxhdrs/cond10.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/key04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/mutex10.c (modified) * c/src/tests/psxtests/psxhdrs/mutex11.c (modified) * c/src/tests/psxtests/psxhdrs/mutex12.c (modified) * c/src/tests/psxtests/psxhdrs/mutex13.c (modified) * c/src/tests/psxtests/psxhdrs/mutex14.c (modified) * c/src/tests/psxtests/psxhdrs/mutex15.c (modified) * c/src/tests/psxtests/psxhdrs/mutex16.c (modified) * c/src/tests/psxtests/psxhdrs/proc01.c (modified) * c/src/tests/psxtests/psxhdrs/proc02.c (modified) * c/src/tests/psxtests/psxhdrs/proc03.c (modified) * c/src/tests/psxtests/psxhdrs/proc04.c (modified) * c/src/tests/psxtests/psxhdrs/proc05.c (modified) * c/src/tests/psxtests/psxhdrs/proc06.c (modified) * c/src/tests/psxtests/psxhdrs/proc07.c (modified) * c/src/tests/psxtests/psxhdrs/proc08.c (modified) * c/src/tests/psxtests/psxhdrs/proc09.c (modified) * c/src/tests/psxtests/psxhdrs/proc10.c (modified) * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc12.c (modified) * c/src/tests/psxtests/psxhdrs/proc13.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread24.c (modified) * c/src/tests/psxtests/psxhdrs/pthread25.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * c/src/tests/psxtests/psxhdrs/pthread31.c (modified) * c/src/tests/psxtests/psxhdrs/pthread32.c (modified) * c/src/tests/psxtests/psxhdrs/pthread33.c (modified) * c/src/tests/psxtests/psxhdrs/pthread34.c (modified) * c/src/tests/psxtests/psxhdrs/pthread35.c (modified) * c/src/tests/psxtests/psxhdrs/pthread36.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * c/src/tests/psxtests/psxhdrs/signal01.c (modified) * c/src/tests/psxtests/psxhdrs/signal02.c (modified) * c/src/tests/psxtests/psxhdrs/signal03.c (modified) * c/src/tests/psxtests/psxhdrs/signal04.c (modified) * c/src/tests/psxtests/psxhdrs/signal05.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * c/src/tests/psxtests/psxhdrs/signal09.c (modified) * c/src/tests/psxtests/psxhdrs/signal10.c (modified) * c/src/tests/psxtests/psxhdrs/signal11.c (modified) * c/src/tests/psxtests/psxhdrs/signal12.c (modified) * c/src/tests/psxtests/psxhdrs/signal13.c (modified) * c/src/tests/psxtests/psxhdrs/signal14.c (modified) * c/src/tests/psxtests/psxhdrs/signal15.c (modified) * c/src/tests/psxtests/psxhdrs/signal16.c (modified) * c/src/tests/psxtests/psxhdrs/signal17.c (modified) * c/src/tests/psxtests/psxhdrs/signal18.c (modified) * c/src/tests/psxtests/psxhdrs/signal19.c (modified) * c/src/tests/psxtests/psxhdrs/signal20.c (modified) * c/src/tests/psxtests/psxhdrs/signal21.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * c/src/tests/psxtests/psxhdrs/time01.c (modified) * c/src/tests/psxtests/psxhdrs/time02.c (modified) * c/src/tests/psxtests/psxhdrs/time03.c (modified) * c/src/tests/psxtests/psxhdrs/time04.c (modified) * c/src/tests/psxtests/psxhdrs/time05.c (modified) * c/src/tests/psxtests/psxhdrs/time06.c (modified) * c/src/tests/psxtests/psxhdrs/time07.c (modified) * c/src/tests/psxtests/psxhdrs/time08.c (modified) * c/src/tests/psxtests/psxhdrs/time09.c (modified) * c/src/tests/psxtests/psxhdrs/time10.c (modified) * c/src/tests/psxtests/psxhdrs/time11.c (modified) * c/src/tests/psxtests/psxhdrs/time12.c (modified) * c/src/tests/psxtests/psxhdrs/time13.c (modified) * c/src/tests/psxtests/psxhdrs/timer01.c (modified) * c/src/tests/psxtests/psxhdrs/timer02.c (modified) * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * c/src/tests/psxtests/psxhdrs/timer06.c (modified) * c/src/tests/samples/README (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/node1/base_mp.doc (modified) * c/src/tests/samples/base_mp/node2/base_mp.doc (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/base_sp.doc (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/hello.doc (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.doc (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/ticker/ticker.doc (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/sp01.doc (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp01/task1.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/sp02.doc (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/sp03.doc (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp03/task1.c (modified) * c/src/tests/sptests/sp03/task2.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/sp04.doc (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/task2.c (modified) * c/src/tests/sptests/sp04/task3.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/sp05.doc (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp05/task1.c (modified) * c/src/tests/sptests/sp05/task2.c (modified) * c/src/tests/sptests/sp05/task3.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/sp06.doc (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp06/task1.c (modified) * c/src/tests/sptests/sp06/task2.c (modified) * c/src/tests/sptests/sp06/task3.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/sp07.doc (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp07/task2.c (modified) * c/src/tests/sptests/sp07/task3.c (modified) * c/src/tests/sptests/sp07/task4.c (modified) * c/src/tests/sptests/sp07/taskexit.c (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp07/tdelete.c (modified) * c/src/tests/sptests/sp07/trestart.c (modified) * c/src/tests/sptests/sp07/tstart.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/sp08.doc (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp08/task1.c (modified) * c/src/tests/sptests/sp09/delay.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/isr.c (modified) * c/src/tests/sptests/sp09/screen01.c (modified) * c/src/tests/sptests/sp09/screen02.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp09/screen04.c (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen06.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen10.c (modified) * c/src/tests/sptests/sp09/screen11.c (modified) * c/src/tests/sptests/sp09/screen12.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/screen14.c (modified) * c/src/tests/sptests/sp09/sp09.doc (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp09/task2.c (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp09/task4.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/sp11.doc (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp11/timer.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/pritask.c (modified) * c/src/tests/sptests/sp12/sp12.doc (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp12/task2.c (modified) * c/src/tests/sptests/sp12/task3.c (modified) * c/src/tests/sptests/sp12/task4.c (modified) * c/src/tests/sptests/sp12/task5.c (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.doc (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/asr.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/sp14.doc (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp14/task2.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/sp15.doc (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp15/task1.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/sp16.doc (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp16/task2.c (modified) * c/src/tests/sptests/sp16/task3.c (modified) * c/src/tests/sptests/sp16/task4.c (modified) * c/src/tests/sptests/sp16/task5.c (modified) * c/src/tests/sptests/sp17/asr.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/sp17.doc (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp17/task1.c (modified) * c/src/tests/sptests/sp17/task2.c (modified) * c/src/tests/sptests/sp19/first.c (modified) * c/src/tests/sptests/sp19/fptask.c (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/sp19.doc (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp19/task1.c (modified) * c/src/tests/sptests/sp20/getall.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/sp20.doc (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp20/task1.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/sp21.doc (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/delay.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/prtime.c (modified) * c/src/tests/sptests/sp22/sp22.doc (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/sp23.doc (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp23/task1.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/resume.c (modified) * c/src/tests/sptests/sp24/sp24.doc (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp24/task1.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/sp25.doc (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/puterr.c (modified) * c/src/tests/sptests/spfatal/spfatal.doc (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spfatal/task1.c (modified) * c/src/tests/sptests/spsize/getint.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/support/stubdr/init.c (modified) * c/src/tests/support/stubdr/open.c (modified) * c/src/tests/support/stubdr/read.c (modified) * c/src/tests/support/stubdr/stubdrv.h (modified) * c/src/tests/support/stubdr/write.c (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm01/tm01.doc (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm02/tm02.doc (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm03/tm03.doc (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm04/tm04.doc (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm05/tm05.doc (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm06/tm06.doc (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm07/tm07.doc (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm08/tm08.doc (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm09/tm09.doc (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm10/tm10.doc (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm11/tm11.doc (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm12/tm12.doc (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm13/tm13.doc (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm14/tm14.doc (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm15/tm15.doc (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm16/tm16.doc (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm17/tm17.doc (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm18/tm18.doc (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm19/tm19.doc (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm20/tm20.doc (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm21/tm21.doc (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm22/tm22.doc (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm23/tm23.doc (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm24/tm24.doc (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm25/tm25.doc (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm26/tm26.doc (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm27/tm27.doc (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm28/tm28.doc (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tm29/tm29.doc (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmck/tmck.doc (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/empty.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/spurious.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condmp.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueuemp.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadmp.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/intr.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/eventset.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/options.inl (modified) * cpukit/rtems/macros/rtems/rtems/part.inl (modified) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/macros/rtems/rtems/region.inl (modified) * cpukit/rtems/macros/rtems/rtems/sem.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/timer.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/macros/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/cpu/a29k/asm.h (modified) * cpukit/score/cpu/a29k/cpu.c (modified) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) * cpukit/score/cpu/i960/asm.h (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) * cpukit/score/cpu/mips/asm.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/asm.h (modified) * cpukit/score/cpu/mips64orion/asm.h (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (modified) * cpukit/score/macros/rtems/score/coresem.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/mppkt.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/objectmp.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01.doc (modified) * testsuites/mptests/mp01/node2/mp01.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02.doc (modified) * testsuites/mptests/mp02/node2/mp02.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03.doc (modified) * testsuites/mptests/mp03/node2/mp03.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04.doc (modified) * testsuites/mptests/mp04/node2/mp04.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05.doc (modified) * testsuites/mptests/mp05/node2/mp05.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06.doc (modified) * testsuites/mptests/mp06/node2/mp06.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07.doc (modified) * testsuites/mptests/mp07/node2/mp07.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08.doc (modified) * testsuites/mptests/mp08/node2/mp08.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.doc (modified) * testsuites/mptests/mp09/node2/mp09.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10.doc (modified) * testsuites/mptests/mp10/node2/mp10.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11.doc (modified) * testsuites/mptests/mp11/node2/mp11.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12.doc (modified) * testsuites/mptests/mp12/node2/mp12.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13.doc (modified) * testsuites/mptests/mp13/node2/mp13.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14.doc (modified) * testsuites/mptests/mp14/node2/mp14.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp.doc (modified) * testsuites/samples/base_mp/node2/base_mp.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp08/task1.c (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/puterr.c (modified) * testsuites/sptests/spfatal/spfatal.doc (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/task1.c (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) * tools/cpu/unix/gensize.c (modified) headers updated to reflect new style copyright notice as part of ... Wed, 29 May 1996 22:48:26 GMT Joel Sherrill [be1c11ed] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) tests now specify whether using posix initialization threads table ... Tue, 19 Sep 1995 14:53:29 GMT Joel Sherrill [3652ad35] * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/hppa.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/headers/coremsg.h (added) * c/src/exec/score/include/rtems/score/coremsg.h (added) * c/src/exec/score/inline/coremsg.inl (added) * c/src/exec/score/inline/rtems/score/coremsg.inl (added) * c/src/exec/score/macros/coremsg.inl (added) * c/src/exec/score/macros/rtems/score/coremsg.inl (added) * c/src/exec/score/src/coremsg.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/console/console.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-queue.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-queue.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/cpu/hppa1.1/cpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/include/rtems/score/coremsg.h (added) * cpukit/score/inline/rtems/score/coremsg.inl (added) * cpukit/score/macros/rtems/score/coremsg.inl (added) * cpukit/score/src/coremsg.c (added) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) Minor bug fixes to get all targets compilable and running. The ... Mon, 11 Sep 1995 19:35:39 GMT Joel Sherrill [3a4ae6c] * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/src/error.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/rtems/headers/asr.h (modified) * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/headers/clock.h (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/eventset.h (modified) * c/src/exec/rtems/headers/intr.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/modes.h (modified) * c/src/exec/rtems/headers/mp.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/options.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/rtemsapi.h (added) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/status.h (modified) * c/src/exec/rtems/headers/support.h (modified) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (added) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/asr.inl (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/event.inl (modified) * c/src/exec/rtems/inline/message.inl (modified) * c/src/exec/rtems/inline/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/status.inl (modified) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/macros/asr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/event.inl (modified) * c/src/exec/rtems/macros/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/status.inl (modified) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/clock.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/directives.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/headers/io.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/directives.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/rtemsapi.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (modified) * c/src/exec/score/cpu/hppa1.1/rtems.s (modified) * c/src/exec/score/cpu/i386/asm.h (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/exec/score/cpu/i960/asm.h (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/i960/i960.h (modified) * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * c/src/exec/score/cpu/no_cpu/asm.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/headers/address.h (modified) * c/src/exec/score/headers/chain.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/coremutex.h (added) * c/src/exec/score/headers/coresem.h (added) * c/src/exec/score/headers/heap.h (modified) * c/src/exec/score/headers/interr.h (added) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/mpci.h (modified) * c/src/exec/score/headers/mppkt.h (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/headers/stack.h (modified) * c/src/exec/score/headers/states.h (modified) * c/src/exec/score/headers/sysstate.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/headers/threadmp.h (modified) * c/src/exec/score/headers/threadq.h (modified) * c/src/exec/score/headers/tod.h (modified) * c/src/exec/score/headers/tqdata.h (modified) * c/src/exec/score/headers/userext.h (modified) * c/src/exec/score/headers/watchdog.h (modified) * c/src/exec/score/headers/wkspace.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (added) * c/src/exec/score/include/rtems/score/coresem.h (added) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (added) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/address.inl (modified) * c/src/exec/score/inline/coremutex.inl (added) * c/src/exec/score/inline/coresem.inl (added) * c/src/exec/score/inline/heap.inl (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/mppkt.inl (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (added) * c/src/exec/score/inline/rtems/score/coresem.inl (added) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/inline/stack.inl (modified) * c/src/exec/score/inline/states.inl (modified) * c/src/exec/score/inline/sysstate.inl (modified) * c/src/exec/score/inline/thread.inl (modified) * c/src/exec/score/inline/tod.inl (modified) * c/src/exec/score/inline/userext.inl (modified) * c/src/exec/score/inline/watchdog.inl (modified) * c/src/exec/score/inline/wkspace.inl (modified) * c/src/exec/score/macros/address.inl (modified) * c/src/exec/score/macros/coremutex.inl (added) * c/src/exec/score/macros/coresem.inl (added) * c/src/exec/score/macros/heap.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (added) * c/src/exec/score/macros/rtems/score/coresem.inl (added) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/stack.inl (modified) * c/src/exec/score/macros/states.inl (modified) * c/src/exec/score/macros/sysstate.inl (modified) * c/src/exec/score/macros/thread.inl (modified) * c/src/exec/score/macros/userext.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/exec/score/macros/wkspace.inl (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremutex.c (added) * c/src/exec/score/src/coresem.c (added) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/interr.c (added) * c/src/exec/score/src/isr.c (added) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/tod.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/lib/include/console.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/console/console.c (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/go32/console/console.c (modified) * c/src/lib/libbsp/i386/go32/include/bsp.h (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/unix/posix/console/console.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/support.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/monitor/mon-dname.c (modified) * c/src/lib/libmisc/monitor/mon-extension.c (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/mon-server.c (modified) * c/src/lib/libmisc/monitor/mon-task.c (modified) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/lib/libmisc/stackchk/internal.h (modified) * c/src/lib/start/i960/start.s (modified) * c/src/lib/start/m68k/start.s (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/monitor/mon-dname.c (modified) * c/src/libmisc/monitor/mon-extension.c (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/monitor/mon-task.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (added) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/sp12.scn (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libmisc/monitor/mon-dname.c (modified) * cpukit/libmisc/monitor/mon-extension.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (added) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/rtemsapi.c (added) * cpukit/score/cpu/hppa1.1/cpu.c (modified) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) * cpukit/score/cpu/i960/asm.h (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/coremutex.h (added) * cpukit/score/include/rtems/score/coresem.h (added) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (added) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (added) * cpukit/score/inline/rtems/score/coresem.inl (added) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (added) * cpukit/score/macros/rtems/score/coresem.inl (added) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremutex.c (added) * cpukit/score/src/coresem.c (added) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/interr.c (added) * cpukit/score/src/isr.c (added) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (added) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/sp12.scn (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) The word "RTEMS" almost completely removed from the core. ... Wed, 23 Aug 1995 19:30:23 GMT Joel Sherrill [3235ad9] * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/rtems/headers/dpmem.h (modified) * c/src/exec/rtems/headers/eventmp.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/msgmp.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/partmp.h (modified) * c/src/exec/rtems/headers/ratemon.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/regionmp.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/semmp.h (modified) * c/src/exec/rtems/headers/signalmp.h (modified) * c/src/exec/rtems/headers/support.h (added) * c/src/exec/rtems/headers/taskmp.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/timer.h (modified) * c/src/exec/rtems/headers/types.h (added) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (added) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (added) * c/src/exec/rtems/inline/rtems/rtems/support.inl (added) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/support.inl (added) * c/src/exec/rtems/inline/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (added) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/support.inl (added) * c/src/exec/rtems/macros/tasks.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/extension.h (modified) * c/src/exec/sapi/headers/init.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/objectmp.h (modified) * c/src/exec/score/headers/system.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/object.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/macros/object.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (added) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (added) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libcpu/powerpc/README (added) * c/src/lib/libcpu/powerpc/ppc403/README (added) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (added) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (added) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/README (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/vectors.s (added) * c/src/lib/libmisc/stackchk/check.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (added) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (added) * cpukit/rtems/inline/rtems/rtems/support.inl (added) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (added) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/thread.c (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/system.h (modified) Support for variable length names added to Object Handler. This ... Thu, 17 Aug 1995 19:36:43 GMT Joel Sherrill [4b374f36] * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.scn (modified) * c/src/tests/mptests/mp09/node2/mp09.scn (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/sp09.scn (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.scn (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.scn (modified) * testsuites/mptests/mp09/node2/mp09.scn (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.scn (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/system.h (modified) maximum number of messages removed and include statement cleanup Thu, 11 May 1995 17:39:37 GMT Joel Sherrill [ac7d5ef0] * INSTALL (added) * LICENSE (added) * README (added) * SUPPORT (added) * c/ACKNOWLEDGEMENTS (added) * c/PROBLEMS (added) * c/README (added) * c/REQUIRES (added) * c/UPDATE_HELP (added) * c/build-tools/README (added) * c/build-tools/cklength.c (added) * c/build-tools/eolstrip.c (added) * c/build-tools/packhex.c (added) * c/build-tools/scripts/README (added) * c/build-tools/src/cklength.c (added) * c/build-tools/src/eolstrip.c (added) * c/build-tools/src/packhex.c (added) * c/build-tools/src/unhex.c (added) * c/build-tools/unhex.c (added) * c/src/README (added) * c/src/exec/libcsupport/include/clockdrv.h (added) * c/src/exec/libcsupport/include/console.h (added) * c/src/exec/libcsupport/include/iosupp.h (added) * c/src/exec/libcsupport/include/rtems/libcsupport.h (added) * c/src/exec/libcsupport/include/spurious.h (added) * c/src/exec/libcsupport/include/timerdrv.h (added) * c/src/exec/libcsupport/include/vmeintr.h (added) * c/src/exec/libcsupport/src/README (added) * c/src/exec/libcsupport/src/__brk.c (added) * c/src/exec/libcsupport/src/__gettod.c (added) * c/src/exec/libcsupport/src/__times.c (added) * c/src/exec/libcsupport/src/malloc.c (added) * c/src/exec/libcsupport/src/newlibc.c (added) * c/src/exec/libcsupport/src/no_libc.c (added) * c/src/exec/libcsupport/src/unixlibc.c (added) * c/src/exec/rtems/headers/asr.h (added) * c/src/exec/rtems/headers/attr.h (added) * c/src/exec/rtems/headers/clock.h (added) * c/src/exec/rtems/headers/dpmem.h (added) * c/src/exec/rtems/headers/event.h (added) * c/src/exec/rtems/headers/eventmp.h (added) * c/src/exec/rtems/headers/eventset.h (added) * c/src/exec/rtems/headers/intr.h (added) * c/src/exec/rtems/headers/message.h (added) * c/src/exec/rtems/headers/modes.h (added) * c/src/exec/rtems/headers/mp.h (added) * c/src/exec/rtems/headers/msgmp.h (added) * c/src/exec/rtems/headers/options.h (added) * c/src/exec/rtems/headers/part.h (added) * c/src/exec/rtems/headers/partmp.h (added) * c/src/exec/rtems/headers/ratemon.h (added) * c/src/exec/rtems/headers/region.h (added) * c/src/exec/rtems/headers/regionmp.h (added) * c/src/exec/rtems/headers/rtems.h (added) * c/src/exec/rtems/headers/sem.h (added) * c/src/exec/rtems/headers/semmp.h (added) * c/src/exec/rtems/headers/signal.h (added) * c/src/exec/rtems/headers/signalmp.h (added) * c/src/exec/rtems/headers/status.h (added) * c/src/exec/rtems/headers/taskmp.h (added) * c/src/exec/rtems/headers/tasks.h (added) * c/src/exec/rtems/headers/timer.h (added) * c/src/exec/rtems/include/rtems.h (added) * c/src/exec/rtems/include/rtems/rtems/asr.h (added) * c/src/exec/rtems/include/rtems/rtems/attr.h (added) * c/src/exec/rtems/include/rtems/rtems/clock.h (added) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (added) * c/src/exec/rtems/include/rtems/rtems/event.h (added) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (added) * c/src/exec/rtems/include/rtems/rtems/eventset.h (added) * c/src/exec/rtems/include/rtems/rtems/intr.h (added) * c/src/exec/rtems/include/rtems/rtems/message.h (added) * c/src/exec/rtems/include/rtems/rtems/modes.h (added) * c/src/exec/rtems/include/rtems/rtems/mp.h (added) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (added) * c/src/exec/rtems/include/rtems/rtems/options.h (added) * c/src/exec/rtems/include/rtems/rtems/part.h (added) * c/src/exec/rtems/include/rtems/rtems/partmp.h (added) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (added) * c/src/exec/rtems/include/rtems/rtems/region.h (added) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (added) * c/src/exec/rtems/include/rtems/rtems/sem.h (added) * c/src/exec/rtems/include/rtems/rtems/semmp.h (added) * c/src/exec/rtems/include/rtems/rtems/signal.h (added) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (added) * c/src/exec/rtems/include/rtems/rtems/status.h (added) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (added) * c/src/exec/rtems/include/rtems/rtems/tasks.h (added) * c/src/exec/rtems/include/rtems/rtems/timer.h (added) * c/src/exec/rtems/inline/asr.inl (added) * c/src/exec/rtems/inline/attr.inl (added) * c/src/exec/rtems/inline/dpmem.inl (added) * c/src/exec/rtems/inline/event.inl (added) * c/src/exec/rtems/inline/eventset.inl (added) * c/src/exec/rtems/inline/message.inl (added) * c/src/exec/rtems/inline/modes.inl (added) * c/src/exec/rtems/inline/options.inl (added) * c/src/exec/rtems/inline/part.inl (added) * c/src/exec/rtems/inline/ratemon.inl (added) * c/src/exec/rtems/inline/region.inl (added) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (added) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (added) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (added) * c/src/exec/rtems/inline/rtems/rtems/event.inl (added) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (added) * c/src/exec/rtems/inline/rtems/rtems/message.inl (added) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (added) * c/src/exec/rtems/inline/rtems/rtems/options.inl (added) * c/src/exec/rtems/inline/rtems/rtems/part.inl (added) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (added) * c/src/exec/rtems/inline/rtems/rtems/region.inl (added) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (added) * c/src/exec/rtems/inline/rtems/rtems/status.inl (added) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (added) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (added) * c/src/exec/rtems/inline/sem.inl (added) * c/src/exec/rtems/inline/status.inl (added) * c/src/exec/rtems/inline/tasks.inl (added) * c/src/exec/rtems/inline/timer.inl (added) * c/src/exec/rtems/macros/asr.inl (added) * c/src/exec/rtems/macros/attr.inl (added) * c/src/exec/rtems/macros/dpmem.inl (added) * c/src/exec/rtems/macros/event.inl (added) * c/src/exec/rtems/macros/eventset.inl (added) * c/src/exec/rtems/macros/message.inl (added) * c/src/exec/rtems/macros/modes.inl (added) * c/src/exec/rtems/macros/options.inl (added) * c/src/exec/rtems/macros/part.inl (added) * c/src/exec/rtems/macros/ratemon.inl (added) * c/src/exec/rtems/macros/region.inl (added) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (added) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (added) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (added) * c/src/exec/rtems/macros/rtems/rtems/event.inl (added) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (added) * c/src/exec/rtems/macros/rtems/rtems/message.inl (added) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (added) * c/src/exec/rtems/macros/rtems/rtems/options.inl (added) * c/src/exec/rtems/macros/rtems/rtems/part.inl (added) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (added) * c/src/exec/rtems/macros/rtems/rtems/region.inl (added) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (added) * c/src/exec/rtems/macros/rtems/rtems/status.inl (added) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (added) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (added) * c/src/exec/rtems/macros/sem.inl (added) * c/src/exec/rtems/macros/status.inl (added) * c/src/exec/rtems/macros/tasks.inl (added) * c/src/exec/rtems/macros/timer.inl (added) * c/src/exec/rtems/optman/no-dpmem.c (added) * c/src/exec/rtems/optman/no-event.c (added) * c/src/exec/rtems/optman/no-mp.c (added) * c/src/exec/rtems/optman/no-msg.c (added) * c/src/exec/rtems/optman/no-part.c (added) * c/src/exec/rtems/optman/no-region.c (added) * c/src/exec/rtems/optman/no-rtmon.c (added) * c/src/exec/rtems/optman/no-sem.c (added) * c/src/exec/rtems/optman/no-signal.c (added) * c/src/exec/rtems/optman/no-timer.c (added) * c/src/exec/rtems/src/clock.c (added) * c/src/exec/rtems/src/dpmem.c (added) * c/src/exec/rtems/src/event.c (added) * c/src/exec/rtems/src/eventmp.c (added) * c/src/exec/rtems/src/intr.c (added) * c/src/exec/rtems/src/mp.c (added) * c/src/exec/rtems/src/msg.c (added) * c/src/exec/rtems/src/msgmp.c (added) * c/src/exec/rtems/src/part.c (added) * c/src/exec/rtems/src/partmp.c (added) * c/src/exec/rtems/src/ratemon.c (added) * c/src/exec/rtems/src/region.c (added) * c/src/exec/rtems/src/regionmp.c (added) * c/src/exec/rtems/src/rtclock.c (added) * c/src/exec/rtems/src/rtemstimer.c (added) * c/src/exec/rtems/src/sem.c (added) * c/src/exec/rtems/src/semmp.c (added) * c/src/exec/rtems/src/signal.c (added) * c/src/exec/rtems/src/signalmp.c (added) * c/src/exec/rtems/src/taskmp.c (added) * c/src/exec/rtems/src/tasks.c (added) * c/src/exec/rtems/src/timer.c (added) * c/src/exec/sapi/headers/config.h (added) * c/src/exec/sapi/headers/directives.h (added) * c/src/exec/sapi/headers/extension.h (added) * c/src/exec/sapi/headers/fatal.h (added) * c/src/exec/sapi/headers/init.h (added) * c/src/exec/sapi/headers/io.h (added) * c/src/exec/sapi/headers/mptables.h (added) * c/src/exec/sapi/headers/sptables.h (added) * c/src/exec/sapi/include/rtems/config.h (added) * c/src/exec/sapi/include/rtems/directives.h (added) * c/src/exec/sapi/include/rtems/extension.h (added) * c/src/exec/sapi/include/rtems/fatal.h (added) * c/src/exec/sapi/include/rtems/init.h (added) * c/src/exec/sapi/include/rtems/io.h (added) * c/src/exec/sapi/include/rtems/mptables.h (added) * c/src/exec/sapi/include/rtems/sptables.h (added) * c/src/exec/sapi/inline/extension.inl (added) * c/src/exec/sapi/inline/rtems/extension.inl (added) * c/src/exec/sapi/macros/extension.inl (added) * c/src/exec/sapi/macros/rtems/extension.inl (added) * c/src/exec/sapi/optman/no-ext.c (added) * c/src/exec/sapi/optman/no-io.c (added) * c/src/exec/sapi/src/debug.c (added) * c/src/exec/sapi/src/exinit.c (added) * c/src/exec/sapi/src/extension.c (added) * c/src/exec/sapi/src/fatal.c (added) * c/src/exec/sapi/src/io.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.c (added) * c/src/exec/score/cpu/hppa1.1/cpu.h (added) * c/src/exec/score/cpu/hppa1.1/cpu_asm.h (added) * c/src/exec/score/cpu/hppa1.1/cpu_asm.s (added) * c/src/exec/score/cpu/hppa1.1/hppa.h (added) * c/src/exec/score/cpu/hppa1.1/rtems.s (added) * c/src/exec/score/cpu/i386/asm.h (added) * c/src/exec/score/cpu/i386/cpu.c (added) * c/src/exec/score/cpu/i386/cpu.h (added) * c/src/exec/score/cpu/i386/cpu_asm.s (added) * c/src/exec/score/cpu/i386/i386.h (added) * c/src/exec/score/cpu/i386/rtems.s (added) * c/src/exec/score/cpu/i960/asm.h (added) * c/src/exec/score/cpu/i960/cpu.c (added) * c/src/exec/score/cpu/i960/cpu.h (added) * c/src/exec/score/cpu/i960/cpu_asm.s (added) * c/src/exec/score/cpu/i960/i960.h (added) * c/src/exec/score/cpu/i960/rtems.s (added) * c/src/exec/score/cpu/m68k/asm.h (added) * c/src/exec/score/cpu/m68k/cpu.c (added) * c/src/exec/score/cpu/m68k/cpu.h (added) * c/src/exec/score/cpu/m68k/cpu_asm.s (added) * c/src/exec/score/cpu/m68k/m68k.h (added) * c/src/exec/score/cpu/m68k/rtems.s (added) * c/src/exec/score/cpu/no_cpu/asm.h (added) * c/src/exec/score/cpu/no_cpu/cpu.c (added) * c/src/exec/score/cpu/no_cpu/cpu.h (added) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (added) * c/src/exec/score/cpu/no_cpu/cpu_asm.h (added) * c/src/exec/score/cpu/no_cpu/no_cpu.h (added) * c/src/exec/score/cpu/no_cpu/rtems.c (added) * c/src/exec/score/cpu/unix/cpu.c (added) * c/src/exec/score/cpu/unix/cpu.h (added) * c/src/exec/score/cpu/unix/unix.h (added) * c/src/exec/score/headers/address.h (added) * c/src/exec/score/headers/bitfield.h (added) * c/src/exec/score/headers/chain.h (added) * c/src/exec/score/headers/context.h (added) * c/src/exec/score/headers/copyrt.h (added) * c/src/exec/score/headers/debug.h (added) * c/src/exec/score/headers/heap.h (added) * c/src/exec/score/headers/isr.h (added) * c/src/exec/score/headers/mpci.h (added) * c/src/exec/score/headers/mppkt.h (added) * c/src/exec/score/headers/object.h (added) * c/src/exec/score/headers/objectmp.h (added) * c/src/exec/score/headers/priority.h (added) * c/src/exec/score/headers/stack.h (added) * c/src/exec/score/headers/states.h (added) * c/src/exec/score/headers/sysstate.h (added) * c/src/exec/score/headers/system.h (added) * c/src/exec/score/headers/thread.h (added) * c/src/exec/score/headers/threadmp.h (added) * c/src/exec/score/headers/threadq.h (added) * c/src/exec/score/headers/tod.h (added) * c/src/exec/score/headers/tqdata.h (added) * c/src/exec/score/headers/userext.h (added) * c/src/exec/score/headers/watchdog.h (added) * c/src/exec/score/headers/wkspace.h (added) * c/src/exec/score/include/rtems/debug.h (added) * c/src/exec/score/include/rtems/score/address.h (added) * c/src/exec/score/include/rtems/score/bitfield.h (added) * c/src/exec/score/include/rtems/score/chain.h (added) * c/src/exec/score/include/rtems/score/context.h (added) * c/src/exec/score/include/rtems/score/copyrt.h (added) * c/src/exec/score/include/rtems/score/heap.h (added) * c/src/exec/score/include/rtems/score/isr.h (added) * c/src/exec/score/include/rtems/score/mpci.h (added) * c/src/exec/score/include/rtems/score/mppkt.h (added) * c/src/exec/score/include/rtems/score/object.h (added) * c/src/exec/score/include/rtems/score/objectmp.h (added) * c/src/exec/score/include/rtems/score/priority.h (added) * c/src/exec/score/include/rtems/score/stack.h (added) * c/src/exec/score/include/rtems/score/states.h (added) * c/src/exec/score/include/rtems/score/sysstate.h (added) * c/src/exec/score/include/rtems/score/thread.h (added) * c/src/exec/score/include/rtems/score/threadmp.h (added) * c/src/exec/score/include/rtems/score/threadq.h (added) * c/src/exec/score/include/rtems/score/tod.h (added) * c/src/exec/score/include/rtems/score/tqdata.h (added) * c/src/exec/score/include/rtems/score/userext.h (added) * c/src/exec/score/include/rtems/score/watchdog.h (added) * c/src/exec/score/include/rtems/score/wkspace.h (added) * c/src/exec/score/include/rtems/system.h (added) * c/src/exec/score/inline/address.inl (added) * c/src/exec/score/inline/chain.inl (added) * c/src/exec/score/inline/heap.inl (added) * c/src/exec/score/inline/isr.inl (added) * c/src/exec/score/inline/mppkt.inl (added) * c/src/exec/score/inline/object.inl (added) * c/src/exec/score/inline/objectmp.inl (added) * c/src/exec/score/inline/priority.inl (added) * c/src/exec/score/inline/rtems/score/address.inl (added) * c/src/exec/score/inline/rtems/score/chain.inl (added) * c/src/exec/score/inline/rtems/score/heap.inl (added) * c/src/exec/score/inline/rtems/score/isr.inl (added) * c/src/exec/score/inline/rtems/score/mppkt.inl (added) * c/src/exec/score/inline/rtems/score/object.inl (added) * c/src/exec/score/inline/rtems/score/objectmp.inl (added) * c/src/exec/score/inline/rtems/score/priority.inl (added) * c/src/exec/score/inline/rtems/score/stack.inl (added) * c/src/exec/score/inline/rtems/score/states.inl (added) * c/src/exec/score/inline/rtems/score/sysstate.inl (added) * c/src/exec/score/inline/rtems/score/thread.inl (added) * c/src/exec/score/inline/rtems/score/threadmp.inl (added) * c/src/exec/score/inline/rtems/score/tod.inl (added) * c/src/exec/score/inline/rtems/score/tqdata.inl (added) * c/src/exec/score/inline/rtems/score/userext.inl (added) * c/src/exec/score/inline/rtems/score/watchdog.inl (added) * c/src/exec/score/inline/rtems/score/wkspace.inl (added) * c/src/exec/score/inline/stack.inl (added) * c/src/exec/score/inline/states.inl (added) * c/src/exec/score/inline/sysstate.inl (added) * c/src/exec/score/inline/thread.inl (added) * c/src/exec/score/inline/threadmp.inl (added) * c/src/exec/score/inline/tod.inl (added) * c/src/exec/score/inline/tqdata.inl (added) * c/src/exec/score/inline/userext.inl (added) * c/src/exec/score/inline/watchdog.inl (added) * c/src/exec/score/inline/wkspace.inl (added) * c/src/exec/score/macros/README (added) * c/src/exec/score/macros/address.inl (added) * c/src/exec/score/macros/chain.inl (added) * c/src/exec/score/macros/heap.inl (added) * c/src/exec/score/macros/isr.inl (added) * c/src/exec/score/macros/mppkt.inl (added) * c/src/exec/score/macros/object.inl (added) * c/src/exec/score/macros/objectmp.inl (added) * c/src/exec/score/macros/priority.inl (added) * c/src/exec/score/macros/rtems/score/README (added) * c/src/exec/score/macros/rtems/score/address.inl (added) * c/src/exec/score/macros/rtems/score/chain.inl (added) * c/src/exec/score/macros/rtems/score/heap.inl (added) * c/src/exec/score/macros/rtems/score/isr.inl (added) * c/src/exec/score/macros/rtems/score/mppkt.inl (added) * c/src/exec/score/macros/rtems/score/object.inl (added) * c/src/exec/score/macros/rtems/score/objectmp.inl (added) * c/src/exec/score/macros/rtems/score/priority.inl (added) * c/src/exec/score/macros/rtems/score/stack.inl (added) * c/src/exec/score/macros/rtems/score/states.inl (added) * c/src/exec/score/macros/rtems/score/sysstate.inl (added) * c/src/exec/score/macros/rtems/score/thread.inl (added) * c/src/exec/score/macros/rtems/score/threadmp.inl (added) * c/src/exec/score/macros/rtems/score/tod.inl (added) * c/src/exec/score/macros/rtems/score/tqdata.inl (added) * c/src/exec/score/macros/rtems/score/userext.inl (added) * c/src/exec/score/macros/rtems/score/watchdog.inl (added) * c/src/exec/score/macros/rtems/score/wkspace.inl (added) * c/src/exec/score/macros/stack.inl (added) * c/src/exec/score/macros/states.inl (added) * c/src/exec/score/macros/sysstate.inl (added) * c/src/exec/score/macros/thread.inl (added) * c/src/exec/score/macros/threadmp.inl (added) * c/src/exec/score/macros/tod.inl (added) * c/src/exec/score/macros/tqdata.inl (added) * c/src/exec/score/macros/userext.inl (added) * c/src/exec/score/macros/watchdog.inl (added) * c/src/exec/score/macros/wkspace.inl (added) * c/src/exec/score/src/chain.c (added) * c/src/exec/score/src/coretod.c (added) * c/src/exec/score/src/heap.c (added) * c/src/exec/score/src/mpci.c (added) * c/src/exec/score/src/object.c (added) * c/src/exec/score/src/objectmp.c (added) * c/src/exec/score/src/thread.c (added) * c/src/exec/score/src/threadmp.c (added) * c/src/exec/score/src/threadq.c (added) * c/src/exec/score/src/tod.c (added) * c/src/exec/score/src/watchdog.c (added) * c/src/exec/score/src/wkspace.c (added) * c/src/exec/score/tools/hppa1.1/genoffsets.c (added) * c/src/lib/include/clockdrv.h (added) * c/src/lib/include/console.h (added) * c/src/lib/include/iosupp.h (added) * c/src/lib/include/rtems/libcsupport.h (added) * c/src/lib/include/spurious.h (added) * c/src/lib/include/timerdrv.h (added) * c/src/lib/include/vmeintr.h (added) * c/src/lib/libbsp/README (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/README (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (added) * c/src/lib/libbsp/hppa1.1/simhppa/tools/print_dump.c (added) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (added) * c/src/lib/libbsp/i386/force386/console/console.c (added) * c/src/lib/libbsp/i386/force386/include/bsp.h (added) * c/src/lib/libbsp/i386/force386/include/coverhd.h (added) * c/src/lib/libbsp/i386/force386/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/lock.c (added) * c/src/lib/libbsp/i386/force386/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (added) * c/src/lib/libbsp/i386/force386/startup/exit.c (added) * c/src/lib/libbsp/i386/force386/startup/ldsegs.s (added) * c/src/lib/libbsp/i386/force386/startup/linkcmds (added) * c/src/lib/libbsp/i386/force386/startup/setvec.c (added) * c/src/lib/libbsp/i386/force386/timer/timer.c (added) * c/src/lib/libbsp/i386/force386/timer/timerisr.s (added) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (added) * c/src/lib/libbsp/i960/cvme961/console/console.c (added) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (added) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (added) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (added) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (added) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (added) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (added) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (added) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (added) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/dmv152/console/console.c (added) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (added) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (added) * c/src/lib/libbsp/m68k/dmv152/spurious/spinit.c (added) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (added) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (added) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (added) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/idp/README (added) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/idp/console/console.c (added) * c/src/lib/libbsp/m68k/idp/console/duart.c (added) * c/src/lib/libbsp/m68k/idp/console/leds.c (added) * c/src/lib/libbsp/m68k/idp/console/mc68ec.c (added) * c/src/lib/libbsp/m68k/idp/include/README (added) * c/src/lib/libbsp/m68k/idp/include/bsp.h (added) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (added) * c/src/lib/libbsp/m68k/idp/include/leds.h (added) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (added) * c/src/lib/libbsp/m68k/idp/timer/timer.c (added) * c/src/lib/libbsp/m68k/idp/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme136/console/console.c (added) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (added) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme162/README (added) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme162/console/console.c (added) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme162/tools/sload.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/README (added) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (added) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (added) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (added) * c/src/lib/libbsp/shmdr/README (added) * c/src/lib/libbsp/shmdr/addlq.c (added) * c/src/lib/libbsp/shmdr/cnvpkt.c (added) * c/src/lib/libbsp/shmdr/dump.c (added) * c/src/lib/libbsp/shmdr/fatal.c (added) * c/src/lib/libbsp/shmdr/getlq.c (added) * c/src/lib/libbsp/shmdr/getpkt.c (added) * c/src/lib/libbsp/shmdr/init.c (added) * c/src/lib/libbsp/shmdr/initlq.c (added) * c/src/lib/libbsp/shmdr/intr.c (added) * c/src/lib/libbsp/shmdr/mpci.h (added) * c/src/lib/libbsp/shmdr/mpisr.c (added) * c/src/lib/libbsp/shmdr/poll.c (added) * c/src/lib/libbsp/shmdr/receive.c (added) * c/src/lib/libbsp/shmdr/retpkt.c (added) * c/src/lib/libbsp/shmdr/send.c (added) * c/src/lib/libbsp/shmdr/setckvec.c (added) * c/src/lib/libbsp/shmdr/shm.h (added) * c/src/lib/libbsp/shmdr/shm_driver.h (added) * c/src/lib/libc/README (added) * c/src/lib/libc/__brk.c (added) * c/src/lib/libc/__gettod.c (added) * c/src/lib/libc/__times.c (added) * c/src/lib/libc/internal.h (added) * c/src/lib/libc/libcsupport.h (added) * c/src/lib/libc/malloc.c (added) * c/src/lib/libc/newlibc.c (added) * c/src/lib/libc/no_libc.c (added) * c/src/lib/libc/support.c (added) * c/src/lib/libc/syscalls.c (added) * c/src/lib/libc/unixlibc.c (added) * c/src/lib/libcpu/README (added) * c/src/lib/libcpu/hppa1.1/clock/clock.c (added) * c/src/lib/libcpu/hppa1.1/runway/runway.h (added) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.c (added) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.h (added) * c/src/lib/libcpu/hppa1.1/timer/timer.c (added) * c/src/lib/libmisc/README (added) * c/src/lib/libmisc/monitor/README (added) * c/src/lib/libmisc/monitor/mon-monitor.c (added) * c/src/lib/libmisc/monitor/mon-symbols.c (added) * c/src/lib/libmisc/monitor/monitor.h (added) * c/src/lib/libmisc/monitor/symbols.h (added) * c/src/lib/libmisc/stackchk/README (added) * c/src/lib/libmisc/stackchk/check.c (added) * c/src/lib/libmisc/stackchk/internal.h (added) * c/src/lib/libmisc/stackchk/stackchk.h (added) * c/src/lib/start/README (added) * c/src/lib/start/i960/start.s (added) * c/src/lib/start/m68k/start.s (added) * c/src/libchip/shmdr/README (added) * c/src/libchip/shmdr/addlq.c (added) * c/src/libchip/shmdr/cnvpkt.c (added) * c/src/libchip/shmdr/dump.c (added) * c/src/libchip/shmdr/fatal.c (added) * c/src/libchip/shmdr/getlq.c (added) * c/src/libchip/shmdr/getpkt.c (added) * c/src/libchip/shmdr/init.c (added) * c/src/libchip/shmdr/initlq.c (added) * c/src/libchip/shmdr/intr.c (added) * c/src/libchip/shmdr/mpci.h (added) * c/src/libchip/shmdr/mpisr.c (added) * c/src/libchip/shmdr/poll.c (added) * c/src/libchip/shmdr/receive.c (added) * c/src/libchip/shmdr/retpkt.c (added) * c/src/libchip/shmdr/send.c (added) * c/src/libchip/shmdr/setckvec.c (added) * c/src/libchip/shmdr/shm_driver.h (added) * c/src/libmisc/README (added) * c/src/libmisc/monitor/README (added) * c/src/libmisc/monitor/mon-monitor.c (added) * c/src/libmisc/monitor/mon-symbols.c (added) * c/src/libmisc/monitor/monitor.h (added) * c/src/libmisc/monitor/symbols.h (added) * c/src/libmisc/stackchk/README (added) * c/src/libmisc/stackchk/check.c (added) * c/src/libmisc/stackchk/internal.h (added) * c/src/libmisc/stackchk/stackchk.h (added) * c/src/optman/rtems/no-dpmem.c (added) * c/src/optman/rtems/no-event.c (added) * c/src/optman/rtems/no-mp.c (added) * c/src/optman/rtems/no-msg.c (added) * c/src/optman/rtems/no-part.c (added) * c/src/optman/rtems/no-region.c (added) * c/src/optman/rtems/no-rtmon.c (added) * c/src/optman/rtems/no-sem.c (added) * c/src/optman/rtems/no-signal.c (added) * c/src/optman/rtems/no-timer.c (added) * c/src/optman/sapi/no-ext.c (added) * c/src/optman/sapi/no-io.c (added) * c/src/tests/README (added) * c/src/tests/libtests/README (added) * c/src/tests/libtests/stackchk/blow.c (added) * c/src/tests/libtests/stackchk/init.c (added) * c/src/tests/libtests/stackchk/stackchk.scn (added) * c/src/tests/libtests/stackchk/task1.c (added) * c/src/tests/mptests/README (added) * c/src/tests/mptests/mp01/init.c (added) * c/src/tests/mptests/mp01/node1/mp01.doc (added) * c/src/tests/mptests/mp01/node1/mp01.scn (added) * c/src/tests/mptests/mp01/node2/mp01.doc (added) * c/src/tests/mptests/mp01/node2/mp01.scn (added) * c/src/tests/mptests/mp01/system.h (added) * c/src/tests/mptests/mp01/task1.c (added) * c/src/tests/mptests/mp02/init.c (added) * c/src/tests/mptests/mp02/node1/mp02.doc (added) * c/src/tests/mptests/mp02/node1/mp02.scn (added) * c/src/tests/mptests/mp02/node2/mp02.doc (added) * c/src/tests/mptests/mp02/node2/mp02.scn (added) * c/src/tests/mptests/mp02/system.h (added) * c/src/tests/mptests/mp02/task1.c (added) * c/src/tests/mptests/mp03/delay.c (added) * c/src/tests/mptests/mp03/init.c (added) * c/src/tests/mptests/mp03/node1/mp03.doc (added) * c/src/tests/mptests/mp03/node1/mp03.scn (added) * c/src/tests/mptests/mp03/node2/mp03.doc (added) * c/src/tests/mptests/mp03/node2/mp03.scn (added) * c/src/tests/mptests/mp03/system.h (added) * c/src/tests/mptests/mp03/task1.c (added) * c/src/tests/mptests/mp04/init.c (added) * c/src/tests/mptests/mp04/node1/mp04.doc (added) * c/src/tests/mptests/mp04/node1/mp04.scn (added) * c/src/tests/mptests/mp04/node2/mp04.doc (added) * c/src/tests/mptests/mp04/node2/mp04.scn (added) * c/src/tests/mptests/mp04/system.h (added) * c/src/tests/mptests/mp04/task1.c (added) * c/src/tests/mptests/mp05/asr.c (added) * c/src/tests/mptests/mp05/init.c (added) * c/src/tests/mptests/mp05/node1/mp05.doc (added) * c/src/tests/mptests/mp05/node1/mp05.scn (added) * c/src/tests/mptests/mp05/node2/mp05.doc (added) * c/src/tests/mptests/mp05/node2/mp05.scn (added) * c/src/tests/mptests/mp05/system.h (added) * c/src/tests/mptests/mp05/task1.c (added) * c/src/tests/mptests/mp06/init.c (added) * c/src/tests/mptests/mp06/node1/mp06.doc (added) * c/src/tests/mptests/mp06/node1/mp06.scn (added) * c/src/tests/mptests/mp06/node2/mp06.doc (added) * c/src/tests/mptests/mp06/node2/mp06.scn (added) * c/src/tests/mptests/mp06/system.h (added) * c/src/tests/mptests/mp06/task1.c (added) * c/src/tests/mptests/mp07/init.c (added) * c/src/tests/mptests/mp07/node1/mp07.doc (added) * c/src/tests/mptests/mp07/node1/mp07.scn (added) * c/src/tests/mptests/mp07/node2/mp07.doc (added) * c/src/tests/mptests/mp07/node2/mp07.scn (added) * c/src/tests/mptests/mp07/system.h (added) * c/src/tests/mptests/mp07/task1.c (added) * c/src/tests/mptests/mp08/init.c (added) * c/src/tests/mptests/mp08/node1/mp08.doc (added) * c/src/tests/mptests/mp08/node1/mp08.scn (added) * c/src/tests/mptests/mp08/node2/mp08.doc (added) * c/src/tests/mptests/mp08/node2/mp08.scn (added) * c/src/tests/mptests/mp08/system.h (added) * c/src/tests/mptests/mp08/task1.c (added) * c/src/tests/mptests/mp09/init.c (added) * c/src/tests/mptests/mp09/node1/mp09.doc (added) * c/src/tests/mptests/mp09/node1/mp09.scn (added) * c/src/tests/mptests/mp09/node2/mp09.doc (added) * c/src/tests/mptests/mp09/node2/mp09.scn (added) * c/src/tests/mptests/mp09/recvmsg.c (added) * c/src/tests/mptests/mp09/sendmsg.c (added) * c/src/tests/mptests/mp09/system.h (added) * c/src/tests/mptests/mp09/task1.c (added) * c/src/tests/mptests/mp10/init.c (added) * c/src/tests/mptests/mp10/node1/mp10.doc (added) * c/src/tests/mptests/mp10/node1/mp10.scn (added) * c/src/tests/mptests/mp10/node2/mp10.doc (added) * c/src/tests/mptests/mp10/node2/mp10.scn (added) * c/src/tests/mptests/mp10/system.h (added) * c/src/tests/mptests/mp10/task1.c (added) * c/src/tests/mptests/mp10/task2.c (added) * c/src/tests/mptests/mp10/task3.c (added) * c/src/tests/mptests/mp11/init.c (added) * c/src/tests/mptests/mp11/node1/mp11.doc (added) * c/src/tests/mptests/mp11/node1/mp11.scn (added) * c/src/tests/mptests/mp11/node2/mp11.doc (added) * c/src/tests/mptests/mp11/node2/mp11.scn (added) * c/src/tests/mptests/mp11/system.h (added) * c/src/tests/mptests/mp12/init.c (added) * c/src/tests/mptests/mp12/node1/mp12.doc (added) * c/src/tests/mptests/mp12/node1/mp12.scn (added) * c/src/tests/mptests/mp12/node2/mp12.doc (added) * c/src/tests/mptests/mp12/node2/mp12.scn (added) * c/src/tests/mptests/mp12/system.h (added) * c/src/tests/mptests/mp13/init.c (added) * c/src/tests/mptests/mp13/node1/mp13.doc (added) * c/src/tests/mptests/mp13/node1/mp13.scn (added) * c/src/tests/mptests/mp13/node2/mp13.doc (added) * c/src/tests/mptests/mp13/node2/mp13.scn (added) * c/src/tests/mptests/mp13/system.h (added) * c/src/tests/mptests/mp13/task1.c (added) * c/src/tests/mptests/mp13/task2.c (added) * c/src/tests/mptests/mp14/delay.c (added) * c/src/tests/mptests/mp14/evtask1.c (added) * c/src/tests/mptests/mp14/evtmtask.c (added) * c/src/tests/mptests/mp14/exit.c (added) * c/src/tests/mptests/mp14/init.c (added) * c/src/tests/mptests/mp14/msgtask1.c (added) * c/src/tests/mptests/mp14/node1/mp14.doc (added) * c/src/tests/mptests/mp14/node1/mp14.scn (added) * c/src/tests/mptests/mp14/node2/mp14.doc (added) * c/src/tests/mptests/mp14/node2/mp14.scn (added) * c/src/tests/mptests/mp14/pttask1.c (added) * c/src/tests/mptests/mp14/smtask1.c (added) * c/src/tests/mptests/mp14/system.h (added) * c/src/tests/samples/README (added) * c/src/tests/samples/base_mp/apptask.c (added) * c/src/tests/samples/base_mp/init.c (added) * c/src/tests/samples/base_mp/node1/base_mp.doc (added) * c/src/tests/samples/base_mp/node1/base_mp.scn (added) * c/src/tests/samples/base_mp/node2/base_mp.doc (added) * c/src/tests/samples/base_mp/node2/base_mp.scn (added) * c/src/tests/samples/base_mp/system.h (added) * c/src/tests/samples/base_sp/apptask.c (added) * c/src/tests/samples/base_sp/base_sp.doc (added) * c/src/tests/samples/base_sp/base_sp.scn (added) * c/src/tests/samples/base_sp/init.c (added) * c/src/tests/samples/base_sp/system.h (added) * c/src/tests/samples/cdtest/cdtest.scn (added) * c/src/tests/samples/cdtest/init.c (added) * c/src/tests/samples/cdtest/main.cc (added) * c/src/tests/samples/cdtest/system.h (added) * c/src/tests/samples/hello/hello.doc (added) * c/src/tests/samples/hello/hello.scn (added) * c/src/tests/samples/hello/init.c (added) * c/src/tests/samples/hello/system.h (added) * c/src/tests/samples/paranoia/init.c (added) * c/src/tests/samples/paranoia/paranoia.c (added) * c/src/tests/samples/paranoia/paranoia.doc (added) * c/src/tests/samples/paranoia/system.h (added) * c/src/tests/samples/ticker/init.c (added) * c/src/tests/samples/ticker/system.h (added) * c/src/tests/samples/ticker/tasks.c (added) * c/src/tests/samples/ticker/ticker.doc (added) * c/src/tests/samples/ticker/ticker.scn (added) * c/src/tests/sptests/README (added) * c/src/tests/sptests/sp01/init.c (added) * c/src/tests/sptests/sp01/sp01.doc (added) * c/src/tests/sptests/sp01/sp01.scn (added) * c/src/tests/sptests/sp01/system.h (added) * c/src/tests/sptests/sp01/task1.c (added) * c/src/tests/sptests/sp02/init.c (added) * c/src/tests/sptests/sp02/preempt.c (added) * c/src/tests/sptests/sp02/sp02.doc (added) * c/src/tests/sptests/sp02/sp02.scn (added) * c/src/tests/sptests/sp02/system.h (added) * c/src/tests/sptests/sp02/task1.c (added) * c/src/tests/sptests/sp02/task2.c (added) * c/src/tests/sptests/sp02/task3.c (added) * c/src/tests/sptests/sp03/init.c (added) * c/src/tests/sptests/sp03/sp03.doc (added) * c/src/tests/sptests/sp03/sp03.scn (added) * c/src/tests/sptests/sp03/system.h (added) * c/src/tests/sptests/sp03/task1.c (added) * c/src/tests/sptests/sp03/task2.c (added) * c/src/tests/sptests/sp04/init.c (added) * c/src/tests/sptests/sp04/sp04.doc (added) * c/src/tests/sptests/sp04/sp04.scn (added) * c/src/tests/sptests/sp04/system.h (added) * c/src/tests/sptests/sp04/task1.c (added) * c/src/tests/sptests/sp04/task2.c (added) * c/src/tests/sptests/sp04/task3.c (added) * c/src/tests/sptests/sp04/tswitch.c (added) * c/src/tests/sptests/sp05/init.c (added) * c/src/tests/sptests/sp05/sp05.doc (added) * c/src/tests/sptests/sp05/sp05.scn (added) * c/src/tests/sptests/sp05/system.h (added) * c/src/tests/sptests/sp05/task1.c (added) * c/src/tests/sptests/sp05/task2.c (added) * c/src/tests/sptests/sp05/task3.c (added) * c/src/tests/sptests/sp06/init.c (added) * c/src/tests/sptests/sp06/sp06.doc (added) * c/src/tests/sptests/sp06/sp06.scn (added) * c/src/tests/sptests/sp06/system.h (added) * c/src/tests/sptests/sp06/task1.c (added) * c/src/tests/sptests/sp06/task2.c (added) * c/src/tests/sptests/sp06/task3.c (added) * c/src/tests/sptests/sp07/init.c (added) * c/src/tests/sptests/sp07/sp07.doc (added) * c/src/tests/sptests/sp07/sp07.scn (added) * c/src/tests/sptests/sp07/system.h (added) * c/src/tests/sptests/sp07/task1.c (added) * c/src/tests/sptests/sp07/task2.c (added) * c/src/tests/sptests/sp07/task3.c (added) * c/src/tests/sptests/sp07/task4.c (added) * c/src/tests/sptests/sp07/taskexit.c (added) * c/src/tests/sptests/sp07/tcreate.c (added) * c/src/tests/sptests/sp07/tdelete.c (added) * c/src/tests/sptests/sp07/trestart.c (added) * c/src/tests/sptests/sp07/tstart.c (added) * c/src/tests/sptests/sp08/init.c (added) * c/src/tests/sptests/sp08/sp08.doc (added) * c/src/tests/sptests/sp08/sp08.scn (added) * c/src/tests/sptests/sp08/system.h (added) * c/src/tests/sptests/sp08/task1.c (added) * c/src/tests/sptests/sp09/delay.c (added) * c/src/tests/sptests/sp09/init.c (added) * c/src/tests/sptests/sp09/isr.c (added) * c/src/tests/sptests/sp09/screen01.c (added) * c/src/tests/sptests/sp09/screen02.c (added) * c/src/tests/sptests/sp09/screen03.c (added) * c/src/tests/sptests/sp09/screen04.c (added) * c/src/tests/sptests/sp09/screen05.c (added) * c/src/tests/sptests/sp09/screen06.c (added) * c/src/tests/sptests/sp09/screen07.c (added) * c/src/tests/sptests/sp09/screen08.c (added) * c/src/tests/sptests/sp09/screen09.c (added) * c/src/tests/sptests/sp09/screen10.c (added) * c/src/tests/sptests/sp09/screen11.c (added) * c/src/tests/sptests/sp09/screen12.c (added) * c/src/tests/sptests/sp09/screen13.c (added) * c/src/tests/sptests/sp09/screen14.c (added) * c/src/tests/sptests/sp09/sp09.doc (added) * c/src/tests/sptests/sp09/sp09.scn (added) * c/src/tests/sptests/sp09/system.h (added) * c/src/tests/sptests/sp09/task1.c (added) * c/src/tests/sptests/sp09/task2.c (added) * c/src/tests/sptests/sp09/task3.c (added) * c/src/tests/sptests/sp09/task4.c (added) * c/src/tests/sptests/sp11/init.c (added) * c/src/tests/sptests/sp11/sp11.doc (added) * c/src/tests/sptests/sp11/sp11.scn (added) * c/src/tests/sptests/sp11/system.h (added) * c/src/tests/sptests/sp11/task1.c (added) * c/src/tests/sptests/sp11/task2.c (added) * c/src/tests/sptests/sp11/timer.c (added) * c/src/tests/sptests/sp12/init.c (added) * c/src/tests/sptests/sp12/pridrv.c (added) * c/src/tests/sptests/sp12/pritask.c (added) * c/src/tests/sptests/sp12/sp12.doc (added) * c/src/tests/sptests/sp12/sp12.scn (added) * c/src/tests/sptests/sp12/system.h (added) * c/src/tests/sptests/sp12/task1.c (added) * c/src/tests/sptests/sp12/task2.c (added) * c/src/tests/sptests/sp12/task3.c (added) * c/src/tests/sptests/sp12/task4.c (added) * c/src/tests/sptests/sp12/task5.c (added) * c/src/tests/sptests/sp13/fillbuff.c (added) * c/src/tests/sptests/sp13/init.c (added) * c/src/tests/sptests/sp13/putbuff.c (added) * c/src/tests/sptests/sp13/sp13.doc (added) * c/src/tests/sptests/sp13/sp13.scn (added) * c/src/tests/sptests/sp13/system.h (added) * c/src/tests/sptests/sp13/task1.c (added) * c/src/tests/sptests/sp13/task2.c (added) * c/src/tests/sptests/sp13/task3.c (added) * c/src/tests/sptests/sp14/asr.c (added) * c/src/tests/sptests/sp14/init.c (added) * c/src/tests/sptests/sp14/sp14.doc (added) * c/src/tests/sptests/sp14/sp14.scn (added) * c/src/tests/sptests/sp14/system.h (added) * c/src/tests/sptests/sp14/task1.c (added) * c/src/tests/sptests/sp14/task2.c (added) * c/src/tests/sptests/sp15/init.c (added) * c/src/tests/sptests/sp15/sp15.doc (added) * c/src/tests/sptests/sp15/sp15.scn (added) * c/src/tests/sptests/sp15/system.h (added) * c/src/tests/sptests/sp15/task1.c (added) * c/src/tests/sptests/sp16/init.c (added) * c/src/tests/sptests/sp16/sp16.doc (added) * c/src/tests/sptests/sp16/sp16.scn (added) * c/src/tests/sptests/sp16/system.h (added) * c/src/tests/sptests/sp16/task1.c (added) * c/src/tests/sptests/sp16/task2.c (added) * c/src/tests/sptests/sp16/task3.c (added) * c/src/tests/sptests/sp16/task4.c (added) * c/src/tests/sptests/sp16/task5.c (added) * c/src/tests/sptests/sp17/asr.c (added) * c/src/tests/sptests/sp17/init.c (added) * c/src/tests/sptests/sp17/sp17.doc (added) * c/src/tests/sptests/sp17/sp17.scn (added) * c/src/tests/sptests/sp17/system.h (added) * c/src/tests/sptests/sp17/task1.c (added) * c/src/tests/sptests/sp17/task2.c (added) * c/src/tests/sptests/sp19/first.c (added) * c/src/tests/sptests/sp19/fptask.c (added) * c/src/tests/sptests/sp19/fptest.h (added) * c/src/tests/sptests/sp19/init.c (added) * c/src/tests/sptests/sp19/inttest.h (added) * c/src/tests/sptests/sp19/sp19.doc (added) * c/src/tests/sptests/sp19/sp19.scn (added) * c/src/tests/sptests/sp19/system.h (added) * c/src/tests/sptests/sp19/task1.c (added) * c/src/tests/sptests/sp20/getall.c (added) * c/src/tests/sptests/sp20/init.c (added) * c/src/tests/sptests/sp20/sp20.doc (added) * c/src/tests/sptests/sp20/sp20.scn (added) * c/src/tests/sptests/sp20/system.h (added) * c/src/tests/sptests/sp20/task1.c (added) * c/src/tests/sptests/sp21/init.c (added) * c/src/tests/sptests/sp21/sp21.doc (added) * c/src/tests/sptests/sp21/sp21.scn (added) * c/src/tests/sptests/sp21/system.h (added) * c/src/tests/sptests/sp21/task1.c (added) * c/src/tests/sptests/sp22/delay.c (added) * c/src/tests/sptests/sp22/init.c (added) * c/src/tests/sptests/sp22/prtime.c (added) * c/src/tests/sptests/sp22/sp22.doc (added) * c/src/tests/sptests/sp22/sp22.scn (added) * c/src/tests/sptests/sp22/system.h (added) * c/src/tests/sptests/sp22/task1.c (added) * c/src/tests/sptests/sp23/init.c (added) * c/src/tests/sptests/sp23/sp23.doc (added) * c/src/tests/sptests/sp23/sp23.scn (added) * c/src/tests/sptests/sp23/system.h (added) * c/src/tests/sptests/sp23/task1.c (added) * c/src/tests/sptests/sp24/init.c (added) * c/src/tests/sptests/sp24/resume.c (added) * c/src/tests/sptests/sp24/sp24.doc (added) * c/src/tests/sptests/sp24/sp24.scn (added) * c/src/tests/sptests/sp24/system.h (added) * c/src/tests/sptests/sp24/task1.c (added) * c/src/tests/sptests/sp25/init.c (added) * c/src/tests/sptests/sp25/sp25.doc (added) * c/src/tests/sptests/sp25/sp25.scn (added) * c/src/tests/sptests/sp25/system.h (added) * c/src/tests/sptests/sp25/task1.c (added) * c/src/tests/sptests/spfatal/fatal.c (added) * c/src/tests/sptests/spfatal/init.c (added) * c/src/tests/sptests/spfatal/puterr.c (added) * c/src/tests/sptests/spfatal/spfatal.doc (added) * c/src/tests/sptests/spfatal/spfatal.scn (added) * c/src/tests/sptests/spfatal/system.h (added) * c/src/tests/sptests/spfatal/task1.c (added) * c/src/tests/sptests/spsize/getint.c (added) * c/src/tests/sptests/spsize/init.c (added) * c/src/tests/sptests/spsize/size.c (added) * c/src/tests/support/include/tmacros.h (added) * c/src/tests/support/stubdr/close.c (added) * c/src/tests/support/stubdr/cntrl.c (added) * c/src/tests/support/stubdr/init.c (added) * c/src/tests/support/stubdr/open.c (added) * c/src/tests/support/stubdr/read.c (added) * c/src/tests/support/stubdr/stubdrv.h (added) * c/src/tests/support/stubdr/write.c (added) * c/src/tests/tmtests/README (added) * c/src/tests/tmtests/include/timesys.h (added) * c/src/tests/tmtests/tm01/system.h (added) * c/src/tests/tmtests/tm01/task1.c (added) * c/src/tests/tmtests/tm01/tm01.doc (added) * c/src/tests/tmtests/tm02/system.h (added) * c/src/tests/tmtests/tm02/task1.c (added) * c/src/tests/tmtests/tm02/tm02.doc (added) * c/src/tests/tmtests/tm03/system.h (added) * c/src/tests/tmtests/tm03/task1.c (added) * c/src/tests/tmtests/tm03/tm03.doc (added) * c/src/tests/tmtests/tm04/system.h (added) * c/src/tests/tmtests/tm04/task1.c (added) * c/src/tests/tmtests/tm04/tm04.doc (added) * c/src/tests/tmtests/tm05/system.h (added) * c/src/tests/tmtests/tm05/task1.c (added) * c/src/tests/tmtests/tm05/tm05.doc (added) * c/src/tests/tmtests/tm06/system.h (added) * c/src/tests/tmtests/tm06/task1.c (added) * c/src/tests/tmtests/tm06/tm06.doc (added) * c/src/tests/tmtests/tm07/system.h (added) * c/src/tests/tmtests/tm07/task1.c (added) * c/src/tests/tmtests/tm07/tm07.doc (added) * c/src/tests/tmtests/tm08/system.h (added) * c/src/tests/tmtests/tm08/task1.c (added) * c/src/tests/tmtests/tm08/tm08.doc (added) * c/src/tests/tmtests/tm09/system.h (added) * c/src/tests/tmtests/tm09/task1.c (added) * c/src/tests/tmtests/tm09/tm09.doc (added) * c/src/tests/tmtests/tm10/system.h (added) * c/src/tests/tmtests/tm10/task1.c (added) * c/src/tests/tmtests/tm10/tm10.doc (added) * c/src/tests/tmtests/tm11/system.h (added) * c/src/tests/tmtests/tm11/task1.c (added) * c/src/tests/tmtests/tm11/tm11.doc (added) * c/src/tests/tmtests/tm12/system.h (added) * c/src/tests/tmtests/tm12/task1.c (added) * c/src/tests/tmtests/tm12/tm12.doc (added) * c/src/tests/tmtests/tm13/system.h (added) * c/src/tests/tmtests/tm13/task1.c (added) * c/src/tests/tmtests/tm13/tm13.doc (added) * c/src/tests/tmtests/tm14/system.h (added) * c/src/tests/tmtests/tm14/task1.c (added) * c/src/tests/tmtests/tm14/tm14.doc (added) * c/src/tests/tmtests/tm15/system.h (added) * c/src/tests/tmtests/tm15/task1.c (added) * c/src/tests/tmtests/tm15/tm15.doc (added) * c/src/tests/tmtests/tm16/system.h (added) * c/src/tests/tmtests/tm16/task1.c (added) * c/src/tests/tmtests/tm16/tm16.doc (added) * c/src/tests/tmtests/tm17/system.h (added) * c/src/tests/tmtests/tm17/task1.c (added) * c/src/tests/tmtests/tm17/tm17.doc (added) * c/src/tests/tmtests/tm18/system.h (added) * c/src/tests/tmtests/tm18/task1.c (added) * c/src/tests/tmtests/tm18/tm18.doc (added) * c/src/tests/tmtests/tm19/system.h (added) * c/src/tests/tmtests/tm19/task1.c (added) * c/src/tests/tmtests/tm19/tm19.doc (added) * c/src/tests/tmtests/tm20/system.h (added) * c/src/tests/tmtests/tm20/task1.c (added) * c/src/tests/tmtests/tm20/tm20.doc (added) * c/src/tests/tmtests/tm21/system.h (added) * c/src/tests/tmtests/tm21/task1.c (added) * c/src/tests/tmtests/tm21/tm21.doc (added) * c/src/tests/tmtests/tm22/system.h (added) * c/src/tests/tmtests/tm22/task1.c (added) * c/src/tests/tmtests/tm22/tm22.doc (added) * c/src/tests/tmtests/tm23/system.h (added) * c/src/tests/tmtests/tm23/task1.c (added) * c/src/tests/tmtests/tm23/tm23.doc (added) * c/src/tests/tmtests/tm24/system.h (added) * c/src/tests/tmtests/tm24/task1.c (added) * c/src/tests/tmtests/tm24/tm24.doc (added) * c/src/tests/tmtests/tm25/system.h (added) * c/src/tests/tmtests/tm25/task1.c (added) * c/src/tests/tmtests/tm25/tm25.doc (added) * c/src/tests/tmtests/tm26/fptest.h (added) * c/src/tests/tmtests/tm26/system.h (added) * c/src/tests/tmtests/tm26/task1.c (added) * c/src/tests/tmtests/tm26/tm26.doc (added) * c/src/tests/tmtests/tm27/system.h (added) * c/src/tests/tmtests/tm27/task1.c (added) * c/src/tests/tmtests/tm27/tm27.doc (added) * c/src/tests/tmtests/tm28/system.h (added) * c/src/tests/tmtests/tm28/task1.c (added) * c/src/tests/tmtests/tm28/tm28.doc (added) * c/src/tests/tmtests/tm29/system.h (added) * c/src/tests/tmtests/tm29/task1.c (added) * c/src/tests/tmtests/tm29/tm29.doc (added) * c/src/tests/tmtests/tmck/system.h (added) * c/src/tests/tmtests/tmck/task1.c (added) * c/src/tests/tmtests/tmck/tmck.doc (added) * c/src/tests/tmtests/tmoverhd/dumrtems.h (added) * c/src/tests/tmtests/tmoverhd/empty.c (added) * c/src/tests/tmtests/tmoverhd/system.h (added) * c/src/tests/tmtests/tmoverhd/testtask.c (added) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (added) * c/src/tests/tools/generic/difftest (added) * c/update-tools/310_to_320_list (added) * c/update-tools/README (added) * cpukit/libcsupport/include/clockdrv.h (added) * cpukit/libcsupport/include/console.h (added) * cpukit/libcsupport/include/iosupp.h (added) * cpukit/libcsupport/include/rtems/libcsupport.h (added) * cpukit/libcsupport/include/spurious.h (added) * cpukit/libcsupport/include/timerdrv.h (added) * cpukit/libcsupport/include/vmeintr.h (added) * cpukit/libcsupport/src/README (added) * cpukit/libcsupport/src/__brk.c (added) * cpukit/libcsupport/src/__gettod.c (added) * cpukit/libcsupport/src/__times.c (added) * cpukit/libcsupport/src/malloc.c (added) * cpukit/libcsupport/src/newlibc.c (added) * cpukit/libcsupport/src/no_libc.c (added) * cpukit/libcsupport/src/unixlibc.c (added) * cpukit/libmisc/README (added) * cpukit/libmisc/monitor/README (added) * cpukit/libmisc/monitor/mon-monitor.c (added) * cpukit/libmisc/monitor/mon-symbols.c (added) * cpukit/libmisc/monitor/monitor.h (added) * cpukit/libmisc/monitor/symbols.h (added) * cpukit/libmisc/stackchk/README (added) * cpukit/libmisc/stackchk/check.c (added) * cpukit/libmisc/stackchk/internal.h (added) * cpukit/libmisc/stackchk/stackchk.h (added) * cpukit/rtems/include/rtems.h (added) * cpukit/rtems/include/rtems/rtems/asr.h (added) * cpukit/rtems/include/rtems/rtems/attr.h (added) * cpukit/rtems/include/rtems/rtems/clock.h (added) * cpukit/rtems/include/rtems/rtems/dpmem.h (added) * cpukit/rtems/include/rtems/rtems/event.h (added) * cpukit/rtems/include/rtems/rtems/eventmp.h (added) * cpukit/rtems/include/rtems/rtems/eventset.h (added) * cpukit/rtems/include/rtems/rtems/intr.h (added) * cpukit/rtems/include/rtems/rtems/message.h (added) * cpukit/rtems/include/rtems/rtems/modes.h (added) * cpukit/rtems/include/rtems/rtems/mp.h (added) * cpukit/rtems/include/rtems/rtems/msgmp.h (added) * cpukit/rtems/include/rtems/rtems/options.h (added) * cpukit/rtems/include/rtems/rtems/part.h (added) * cpukit/rtems/include/rtems/rtems/partmp.h (added) * cpukit/rtems/include/rtems/rtems/ratemon.h (added) * cpukit/rtems/include/rtems/rtems/region.h (added) * cpukit/rtems/include/rtems/rtems/regionmp.h (added) * cpukit/rtems/include/rtems/rtems/sem.h (added) * cpukit/rtems/include/rtems/rtems/semmp.h (added) * cpukit/rtems/include/rtems/rtems/signal.h (added) * cpukit/rtems/include/rtems/rtems/signalmp.h (added) * cpukit/rtems/include/rtems/rtems/status.h (added) * cpukit/rtems/include/rtems/rtems/taskmp.h (added) * cpukit/rtems/include/rtems/rtems/tasks.h (added) * cpukit/rtems/include/rtems/rtems/timer.h (added) * cpukit/rtems/inline/rtems/rtems/asr.inl (added) * cpukit/rtems/inline/rtems/rtems/attr.inl (added) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (added) * cpukit/rtems/inline/rtems/rtems/event.inl (added) * cpukit/rtems/inline/rtems/rtems/eventset.inl (added) * cpukit/rtems/inline/rtems/rtems/message.inl (added) * cpukit/rtems/inline/rtems/rtems/modes.inl (added) * cpukit/rtems/inline/rtems/rtems/options.inl (added) * cpukit/rtems/inline/rtems/rtems/part.inl (added) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (added) * cpukit/rtems/inline/rtems/rtems/region.inl (added) * cpukit/rtems/inline/rtems/rtems/sem.inl (added) * cpukit/rtems/inline/rtems/rtems/status.inl (added) * cpukit/rtems/inline/rtems/rtems/tasks.inl (added) * cpukit/rtems/inline/rtems/rtems/timer.inl (added) * cpukit/rtems/macros/rtems/rtems/asr.inl (added) * cpukit/rtems/macros/rtems/rtems/attr.inl (added) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (added) * cpukit/rtems/macros/rtems/rtems/event.inl (added) * cpukit/rtems/macros/rtems/rtems/eventset.inl (added) * cpukit/rtems/macros/rtems/rtems/message.inl (added) * cpukit/rtems/macros/rtems/rtems/modes.inl (added) * cpukit/rtems/macros/rtems/rtems/options.inl (added) * cpukit/rtems/macros/rtems/rtems/part.inl (added) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (added) * cpukit/rtems/macros/rtems/rtems/region.inl (added) * cpukit/rtems/macros/rtems/rtems/sem.inl (added) * cpukit/rtems/macros/rtems/rtems/status.inl (added) * cpukit/rtems/macros/rtems/rtems/tasks.inl (added) * cpukit/rtems/macros/rtems/rtems/timer.inl (added) * cpukit/rtems/src/dpmem.c (added) * cpukit/rtems/src/event.c (added) * cpukit/rtems/src/eventmp.c (added) * cpukit/rtems/src/intr.c (added) * cpukit/rtems/src/mp.c (added) * cpukit/rtems/src/msg.c (added) * cpukit/rtems/src/msgmp.c (added) * cpukit/rtems/src/part.c (added) * cpukit/rtems/src/partmp.c (added) * cpukit/rtems/src/ratemon.c (added) * cpukit/rtems/src/region.c (added) * cpukit/rtems/src/regionmp.c (added) * cpukit/rtems/src/rtclock.c (added) * cpukit/rtems/src/rtemstimer.c (added) * cpukit/rtems/src/sem.c (added) * cpukit/rtems/src/semmp.c (added) * cpukit/rtems/src/signal.c (added) * cpukit/rtems/src/signalmp.c (added) * cpukit/rtems/src/taskmp.c (added) * cpukit/rtems/src/tasks.c (added) * cpukit/sapi/include/rtems/config.h (added) * cpukit/sapi/include/rtems/extension.h (added) * cpukit/sapi/include/rtems/fatal.h (added) * cpukit/sapi/include/rtems/init.h (added) * cpukit/sapi/include/rtems/io.h (added) * cpukit/sapi/include/rtems/mptables.h (added) * cpukit/sapi/inline/rtems/extension.inl (added) * cpukit/sapi/macros/rtems/extension.inl (added) * cpukit/sapi/src/debug.c (added) * cpukit/sapi/src/exinit.c (added) * cpukit/sapi/src/extension.c (added) * cpukit/sapi/src/fatal.c (added) * cpukit/sapi/src/io.c (added) * cpukit/score/cpu/hppa1.1/cpu.c (added) * cpukit/score/cpu/i386/asm.h (added) * cpukit/score/cpu/i386/cpu.c (added) * cpukit/score/cpu/i386/rtems/asm.h (added) * cpukit/score/cpu/i960/asm.h (added) * cpukit/score/cpu/i960/cpu.c (added) * cpukit/score/cpu/m68k/asm.h (added) * cpukit/score/cpu/m68k/cpu.c (added) * cpukit/score/cpu/m68k/rtems/asm.h (added) * cpukit/score/cpu/no_cpu/asm.h (added) * cpukit/score/cpu/no_cpu/cpu.c (added) * cpukit/score/cpu/no_cpu/cpu_asm.c (added) * cpukit/score/cpu/no_cpu/rtems/asm.h (added) * cpukit/score/cpu/unix/cpu.c (added) * cpukit/score/include/rtems/debug.h (added) * cpukit/score/include/rtems/score/address.h (added) * cpukit/score/include/rtems/score/bitfield.h (added) * cpukit/score/include/rtems/score/chain.h (added) * cpukit/score/include/rtems/score/context.h (added) * cpukit/score/include/rtems/score/copyrt.h (added) * cpukit/score/include/rtems/score/heap.h (added) * cpukit/score/include/rtems/score/isr.h (added) * cpukit/score/include/rtems/score/mpci.h (added) * cpukit/score/include/rtems/score/mppkt.h (added) * cpukit/score/include/rtems/score/object.h (added) * cpukit/score/include/rtems/score/objectmp.h (added) * cpukit/score/include/rtems/score/priority.h (added) * cpukit/score/include/rtems/score/stack.h (added) * cpukit/score/include/rtems/score/states.h (added) * cpukit/score/include/rtems/score/sysstate.h (added) * cpukit/score/include/rtems/score/thread.h (added) * cpukit/score/include/rtems/score/threadmp.h (added) * cpukit/score/include/rtems/score/threadq.h (added) * cpukit/score/include/rtems/score/tod.h (added) * cpukit/score/include/rtems/score/tqdata.h (added) * cpukit/score/include/rtems/score/userext.h (added) * cpukit/score/include/rtems/score/watchdog.h (added) * cpukit/score/include/rtems/score/wkspace.h (added) * cpukit/score/include/rtems/system.h (added) * cpukit/score/inline/rtems/score/address.inl (added) * cpukit/score/inline/rtems/score/chain.inl (added) * cpukit/score/inline/rtems/score/heap.inl (added) * cpukit/score/inline/rtems/score/isr.inl (added) * cpukit/score/inline/rtems/score/mppkt.inl (added) * cpukit/score/inline/rtems/score/object.inl (added) * cpukit/score/inline/rtems/score/objectmp.inl (added) * cpukit/score/inline/rtems/score/priority.inl (added) * cpukit/score/inline/rtems/score/stack.inl (added) * cpukit/score/inline/rtems/score/states.inl (added) * cpukit/score/inline/rtems/score/sysstate.inl (added) * cpukit/score/inline/rtems/score/thread.inl (added) * cpukit/score/inline/rtems/score/threadmp.inl (added) * cpukit/score/inline/rtems/score/tod.inl (added) * cpukit/score/inline/rtems/score/tqdata.inl (added) * cpukit/score/inline/rtems/score/userext.inl (added) * cpukit/score/inline/rtems/score/watchdog.inl (added) * cpukit/score/inline/rtems/score/wkspace.inl (added) * cpukit/score/macros/README (added) * cpukit/score/macros/rtems/score/README (added) * cpukit/score/macros/rtems/score/address.inl (added) * cpukit/score/macros/rtems/score/chain.inl (added) * cpukit/score/macros/rtems/score/heap.inl (added) * cpukit/score/macros/rtems/score/isr.inl (added) * cpukit/score/macros/rtems/score/mppkt.inl (added) * cpukit/score/macros/rtems/score/object.inl (added) * cpukit/score/macros/rtems/score/objectmp.inl (added) * cpukit/score/macros/rtems/score/priority.inl (added) * cpukit/score/macros/rtems/score/stack.inl (added) * cpukit/score/macros/rtems/score/states.inl (added) * cpukit/score/macros/rtems/score/sysstate.inl (added) * cpukit/score/macros/rtems/score/thread.inl (added) * cpukit/score/macros/rtems/score/threadmp.inl (added) * cpukit/score/macros/rtems/score/tod.inl (added) * cpukit/score/macros/rtems/score/tqdata.inl (added) * cpukit/score/macros/rtems/score/userext.inl (added) * cpukit/score/macros/rtems/score/watchdog.inl (added) * cpukit/score/macros/rtems/score/wkspace.inl (added) * cpukit/score/src/chain.c (added) * cpukit/score/src/coretod.c (added) * cpukit/score/src/heap.c (added) * cpukit/score/src/mpci.c (added) * cpukit/score/src/object.c (added) * cpukit/score/src/objectmp.c (added) * cpukit/score/src/thread.c (added) * cpukit/score/src/threadmp.c (added) * cpukit/score/src/threadq.c (added) * cpukit/score/src/watchdog.c (added) * cpukit/score/src/wkspace.c (added) * testsuites/README (added) * testsuites/libtests/README (added) * testsuites/libtests/stackchk/blow.c (added) * testsuites/libtests/stackchk/init.c (added) * testsuites/libtests/stackchk/stackchk.scn (added) * testsuites/libtests/stackchk/task1.c (added) * testsuites/mptests/README (added) * testsuites/mptests/mp01/init.c (added) * testsuites/mptests/mp01/node1/mp01.doc (added) * testsuites/mptests/mp01/node1/mp01.scn (added) * testsuites/mptests/mp01/node2/mp01.doc (added) * testsuites/mptests/mp01/node2/mp01.scn (added) * testsuites/mptests/mp01/system.h (added) * testsuites/mptests/mp01/task1.c (added) * testsuites/mptests/mp02/init.c (added) * testsuites/mptests/mp02/node1/mp02.doc (added) * testsuites/mptests/mp02/node1/mp02.scn (added) * testsuites/mptests/mp02/node2/mp02.doc (added) * testsuites/mptests/mp02/node2/mp02.scn (added) * testsuites/mptests/mp02/system.h (added) * testsuites/mptests/mp02/task1.c (added) * testsuites/mptests/mp03/delay.c (added) * testsuites/mptests/mp03/init.c (added) * testsuites/mptests/mp03/node1/mp03.doc (added) * testsuites/mptests/mp03/node1/mp03.scn (added) * testsuites/mptests/mp03/node2/mp03.doc (added) * testsuites/mptests/mp03/node2/mp03.scn (added) * testsuites/mptests/mp03/system.h (added) * testsuites/mptests/mp03/task1.c (added) * testsuites/mptests/mp04/init.c (added) * testsuites/mptests/mp04/node1/mp04.doc (added) * testsuites/mptests/mp04/node1/mp04.scn (added) * testsuites/mptests/mp04/node2/mp04.doc (added) * testsuites/mptests/mp04/node2/mp04.scn (added) * testsuites/mptests/mp04/system.h (added) * testsuites/mptests/mp04/task1.c (added) * testsuites/mptests/mp05/asr.c (added) * testsuites/mptests/mp05/init.c (added) * testsuites/mptests/mp05/node1/mp05.doc (added) * testsuites/mptests/mp05/node1/mp05.scn (added) * testsuites/mptests/mp05/node2/mp05.doc (added) * testsuites/mptests/mp05/node2/mp05.scn (added) * testsuites/mptests/mp05/system.h (added) * testsuites/mptests/mp05/task1.c (added) * testsuites/mptests/mp06/init.c (added) * testsuites/mptests/mp06/node1/mp06.doc (added) * testsuites/mptests/mp06/node1/mp06.scn (added) * testsuites/mptests/mp06/node2/mp06.doc (added) * testsuites/mptests/mp06/node2/mp06.scn (added) * testsuites/mptests/mp06/system.h (added) * testsuites/mptests/mp06/task1.c (added) * testsuites/mptests/mp07/init.c (added) * testsuites/mptests/mp07/node1/mp07.doc (added) * testsuites/mptests/mp07/node1/mp07.scn (added) * testsuites/mptests/mp07/node2/mp07.doc (added) * testsuites/mptests/mp07/node2/mp07.scn (added) * testsuites/mptests/mp07/system.h (added) * testsuites/mptests/mp07/task1.c (added) * testsuites/mptests/mp08/init.c (added) * testsuites/mptests/mp08/node1/mp08.doc (added) * testsuites/mptests/mp08/node1/mp08.scn (added) * testsuites/mptests/mp08/node2/mp08.doc (added) * testsuites/mptests/mp08/node2/mp08.scn (added) * testsuites/mptests/mp08/system.h (added) * testsuites/mptests/mp08/task1.c (added) * testsuites/mptests/mp09/init.c (added) * testsuites/mptests/mp09/node1/mp09.doc (added) * testsuites/mptests/mp09/node1/mp09.scn (added) * testsuites/mptests/mp09/node2/mp09.doc (added) * testsuites/mptests/mp09/node2/mp09.scn (added) * testsuites/mptests/mp09/recvmsg.c (added) * testsuites/mptests/mp09/sendmsg.c (added) * testsuites/mptests/mp09/system.h (added) * testsuites/mptests/mp09/task1.c (added) * testsuites/mptests/mp10/init.c (added) * testsuites/mptests/mp10/node1/mp10.doc (added) * testsuites/mptests/mp10/node1/mp10.scn (added) * testsuites/mptests/mp10/node2/mp10.doc (added) * testsuites/mptests/mp10/node2/mp10.scn (added) * testsuites/mptests/mp10/system.h (added) * testsuites/mptests/mp10/task1.c (added) * testsuites/mptests/mp10/task2.c (added) * testsuites/mptests/mp10/task3.c (added) * testsuites/mptests/mp11/init.c (added) * testsuites/mptests/mp11/node1/mp11.doc (added) * testsuites/mptests/mp11/node1/mp11.scn (added) * testsuites/mptests/mp11/node2/mp11.doc (added) * testsuites/mptests/mp11/node2/mp11.scn (added) * testsuites/mptests/mp11/system.h (added) * testsuites/mptests/mp12/init.c (added) * testsuites/mptests/mp12/node1/mp12.doc (added) * testsuites/mptests/mp12/node1/mp12.scn (added) * testsuites/mptests/mp12/node2/mp12.doc (added) * testsuites/mptests/mp12/node2/mp12.scn (added) * testsuites/mptests/mp12/system.h (added) * testsuites/mptests/mp13/init.c (added) * testsuites/mptests/mp13/node1/mp13.doc (added) * testsuites/mptests/mp13/node1/mp13.scn (added) * testsuites/mptests/mp13/node2/mp13.doc (added) * testsuites/mptests/mp13/node2/mp13.scn (added) * testsuites/mptests/mp13/system.h (added) * testsuites/mptests/mp13/task1.c (added) * testsuites/mptests/mp13/task2.c (added) * testsuites/mptests/mp14/delay.c (added) * testsuites/mptests/mp14/evtask1.c (added) * testsuites/mptests/mp14/evtmtask.c (added) * testsuites/mptests/mp14/exit.c (added) * testsuites/mptests/mp14/init.c (added) * testsuites/mptests/mp14/msgtask1.c (added) * testsuites/mptests/mp14/node1/mp14.doc (added) * testsuites/mptests/mp14/node1/mp14.scn (added) * testsuites/mptests/mp14/node2/mp14.doc (added) * testsuites/mptests/mp14/node2/mp14.scn (added) * testsuites/mptests/mp14/pttask1.c (added) * testsuites/mptests/mp14/smtask1.c (added) * testsuites/mptests/mp14/system.h (added) * testsuites/samples/README (added) * testsuites/samples/base_mp/apptask.c (added) * testsuites/samples/base_mp/init.c (added) * testsuites/samples/base_mp/node1/base_mp.doc (added) * testsuites/samples/base_mp/node1/base_mp.scn (added) * testsuites/samples/base_mp/node2/base_mp.doc (added) * testsuites/samples/base_mp/node2/base_mp.scn (added) * testsuites/samples/base_mp/system.h (added) * testsuites/samples/base_sp/apptask.c (added) * testsuites/samples/base_sp/base_sp.doc (added) * testsuites/samples/base_sp/base_sp.scn (added) * testsuites/samples/base_sp/init.c (added) * testsuites/samples/base_sp/system.h (added) * testsuites/samples/cdtest/cdtest.scn (added) * testsuites/samples/cdtest/init.c (added) * testsuites/samples/cdtest/main.cc (added) * testsuites/samples/cdtest/system.h (added) * testsuites/samples/hello/hello.doc (added) * testsuites/samples/hello/hello.scn (added) * testsuites/samples/hello/init.c (added) * testsuites/samples/hello/system.h (added) * testsuites/samples/paranoia/init.c (added) * testsuites/samples/paranoia/paranoia.c (added) * testsuites/samples/paranoia/paranoia.doc (added) * testsuites/samples/paranoia/system.h (added) * testsuites/samples/ticker/init.c (added) * testsuites/samples/ticker/system.h (added) * testsuites/samples/ticker/tasks.c (added) * testsuites/samples/ticker/ticker.doc (added) * testsuites/samples/ticker/ticker.scn (added) * testsuites/sptests/README (added) * testsuites/sptests/sp01/init.c (added) * testsuites/sptests/sp01/sp01.doc (added) * testsuites/sptests/sp01/sp01.scn (added) * testsuites/sptests/sp01/system.h (added) * testsuites/sptests/sp01/task1.c (added) * testsuites/sptests/sp02/init.c (added) * testsuites/sptests/sp02/preempt.c (added) * testsuites/sptests/sp02/sp02.doc (added) * testsuites/sptests/sp02/sp02.scn (added) * testsuites/sptests/sp02/system.h (added) * testsuites/sptests/sp02/task1.c (added) * testsuites/sptests/sp02/task2.c (added) * testsuites/sptests/sp02/task3.c (added) * testsuites/sptests/sp03/init.c (added) * testsuites/sptests/sp03/sp03.doc (added) * testsuites/sptests/sp03/sp03.scn (added) * testsuites/sptests/sp03/system.h (added) * testsuites/sptests/sp03/task1.c (added) * testsuites/sptests/sp03/task2.c (added) * testsuites/sptests/sp04/init.c (added) * testsuites/sptests/sp04/sp04.doc (added) * testsuites/sptests/sp04/sp04.scn (added) * testsuites/sptests/sp04/system.h (added) * testsuites/sptests/sp04/task1.c (added) * testsuites/sptests/sp04/task2.c (added) * testsuites/sptests/sp04/task3.c (added) * testsuites/sptests/sp04/tswitch.c (added) * testsuites/sptests/sp05/init.c (added) * testsuites/sptests/sp05/sp05.doc (added) * testsuites/sptests/sp05/sp05.scn (added) * testsuites/sptests/sp05/system.h (added) * testsuites/sptests/sp05/task1.c (added) * testsuites/sptests/sp05/task2.c (added) * testsuites/sptests/sp05/task3.c (added) * testsuites/sptests/sp06/init.c (added) * testsuites/sptests/sp06/sp06.doc (added) * testsuites/sptests/sp06/sp06.scn (added) * testsuites/sptests/sp06/system.h (added) * testsuites/sptests/sp06/task1.c (added) * testsuites/sptests/sp06/task2.c (added) * testsuites/sptests/sp06/task3.c (added) * testsuites/sptests/sp07/init.c (added) * testsuites/sptests/sp07/sp07.doc (added) * testsuites/sptests/sp07/sp07.scn (added) * testsuites/sptests/sp07/system.h (added) * testsuites/sptests/sp07/task1.c (added) * testsuites/sptests/sp07/task2.c (added) * testsuites/sptests/sp07/task3.c (added) * testsuites/sptests/sp07/task4.c (added) * testsuites/sptests/sp07/taskexit.c (added) * testsuites/sptests/sp07/tcreate.c (added) * testsuites/sptests/sp07/tdelete.c (added) * testsuites/sptests/sp07/trestart.c (added) * testsuites/sptests/sp07/tstart.c (added) * testsuites/sptests/sp08/init.c (added) * testsuites/sptests/sp08/sp08.doc (added) * testsuites/sptests/sp08/sp08.scn (added) * testsuites/sptests/sp08/system.h (added) * testsuites/sptests/sp08/task1.c (added) * testsuites/sptests/sp09/delay.c (added) * testsuites/sptests/sp09/init.c (added) * testsuites/sptests/sp09/isr.c (added) * testsuites/sptests/sp09/screen01.c (added) * testsuites/sptests/sp09/screen02.c (added) * testsuites/sptests/sp09/screen03.c (added) * testsuites/sptests/sp09/screen04.c (added) * testsuites/sptests/sp09/screen05.c (added) * testsuites/sptests/sp09/screen06.c (added) * testsuites/sptests/sp09/screen07.c (added) * testsuites/sptests/sp09/screen08.c (added) * testsuites/sptests/sp09/screen09.c (added) * testsuites/sptests/sp09/screen10.c (added) * testsuites/sptests/sp09/screen11.c (added) * testsuites/sptests/sp09/screen12.c (added) * testsuites/sptests/sp09/screen13.c (added) * testsuites/sptests/sp09/screen14.c (added) * testsuites/sptests/sp09/sp09.doc (added) * testsuites/sptests/sp09/sp09.scn (added) * testsuites/sptests/sp09/system.h (added) * testsuites/sptests/sp09/task1.c (added) * testsuites/sptests/sp09/task2.c (added) * testsuites/sptests/sp09/task3.c (added) * testsuites/sptests/sp09/task4.c (added) * testsuites/sptests/sp11/init.c (added) * testsuites/sptests/sp11/sp11.doc (added) * testsuites/sptests/sp11/sp11.scn (added) * testsuites/sptests/sp11/system.h (added) * testsuites/sptests/sp11/task1.c (added) * testsuites/sptests/sp11/task2.c (added) * testsuites/sptests/sp11/timer.c (added) * testsuites/sptests/sp12/init.c (added) * testsuites/sptests/sp12/pridrv.c (added) * testsuites/sptests/sp12/pritask.c (added) * testsuites/sptests/sp12/sp12.doc (added) * testsuites/sptests/sp12/sp12.scn (added) * testsuites/sptests/sp12/system.h (added) * testsuites/sptests/sp12/task1.c (added) * testsuites/sptests/sp12/task2.c (added) * testsuites/sptests/sp12/task3.c (added) * testsuites/sptests/sp12/task4.c (added) * testsuites/sptests/sp12/task5.c (added) * testsuites/sptests/sp13/fillbuff.c (added) * testsuites/sptests/sp13/init.c (added) * testsuites/sptests/sp13/putbuff.c (added) * testsuites/sptests/sp13/sp13.doc (added) * testsuites/sptests/sp13/sp13.scn (added) * testsuites/sptests/sp13/system.h (added) * testsuites/sptests/sp13/task1.c (added) * testsuites/sptests/sp13/task2.c (added) * testsuites/sptests/sp13/task3.c (added) * testsuites/sptests/sp14/asr.c (added) * testsuites/sptests/sp14/init.c (added) * testsuites/sptests/sp14/sp14.doc (added) * testsuites/sptests/sp14/sp14.scn (added) * testsuites/sptests/sp14/system.h (added) * testsuites/sptests/sp14/task1.c (added) * testsuites/sptests/sp14/task2.c (added) * testsuites/sptests/sp15/init.c (added) * testsuites/sptests/sp15/sp15.doc (added) * testsuites/sptests/sp15/sp15.scn (added) * testsuites/sptests/sp15/system.h (added) * testsuites/sptests/sp15/task1.c (added) * testsuites/sptests/sp16/init.c (added) * testsuites/sptests/sp16/sp16.doc (added) * testsuites/sptests/sp16/sp16.scn (added) * testsuites/sptests/sp16/system.h (added) * testsuites/sptests/sp16/task1.c (added) * testsuites/sptests/sp16/task2.c (added) * testsuites/sptests/sp16/task3.c (added) * testsuites/sptests/sp16/task4.c (added) * testsuites/sptests/sp16/task5.c (added) * testsuites/sptests/sp17/asr.c (added) * testsuites/sptests/sp17/init.c (added) * testsuites/sptests/sp17/sp17.doc (added) * testsuites/sptests/sp17/sp17.scn (added) * testsuites/sptests/sp17/system.h (added) * testsuites/sptests/sp17/task1.c (added) * testsuites/sptests/sp17/task2.c (added) * testsuites/sptests/sp19/first.c (added) * testsuites/sptests/sp19/fptask.c (added) * testsuites/sptests/sp19/fptest.h (added) * testsuites/sptests/sp19/init.c (added) * testsuites/sptests/sp19/inttest.h (added) * testsuites/sptests/sp19/sp19.doc (added) * testsuites/sptests/sp19/sp19.scn (added) * testsuites/sptests/sp19/system.h (added) * testsuites/sptests/sp19/task1.c (added) * testsuites/sptests/sp20/getall.c (added) * testsuites/sptests/sp20/init.c (added) * testsuites/sptests/sp20/sp20.doc (added) * testsuites/sptests/sp20/sp20.scn (added) * testsuites/sptests/sp20/system.h (added) * testsuites/sptests/sp20/task1.c (added) * testsuites/sptests/sp21/init.c (added) * testsuites/sptests/sp21/sp21.doc (added) * testsuites/sptests/sp21/sp21.scn (added) * testsuites/sptests/sp21/system.h (added) * testsuites/sptests/sp21/task1.c (added) * testsuites/sptests/sp22/delay.c (added) * testsuites/sptests/sp22/init.c (added) * testsuites/sptests/sp22/prtime.c (added) * testsuites/sptests/sp22/sp22.doc (added) * testsuites/sptests/sp22/sp22.scn (added) * testsuites/sptests/sp22/system.h (added) * testsuites/sptests/sp22/task1.c (added) * testsuites/sptests/sp23/init.c (added) * testsuites/sptests/sp23/sp23.doc (added) * testsuites/sptests/sp23/sp23.scn (added) * testsuites/sptests/sp23/system.h (added) * testsuites/sptests/sp23/task1.c (added) * testsuites/sptests/sp24/init.c (added) * testsuites/sptests/sp24/resume.c (added) * testsuites/sptests/sp24/sp24.doc (added) * testsuites/sptests/sp24/sp24.scn (added) * testsuites/sptests/sp24/system.h (added) * testsuites/sptests/sp24/task1.c (added) * testsuites/sptests/sp25/init.c (added) * testsuites/sptests/sp25/sp25.doc (added) * testsuites/sptests/sp25/sp25.scn (added) * testsuites/sptests/sp25/system.h (added) * testsuites/sptests/sp25/task1.c (added) * testsuites/sptests/spfatal/fatal.c (added) * testsuites/sptests/spfatal/init.c (added) * testsuites/sptests/spfatal/puterr.c (added) * testsuites/sptests/spfatal/spfatal.doc (added) * testsuites/sptests/spfatal/spfatal.scn (added) * testsuites/sptests/spfatal/system.h (added) * testsuites/sptests/spfatal/task1.c (added) * testsuites/sptests/spsize/getint.c (added) * testsuites/sptests/spsize/init.c (added) * testsuites/sptests/spsize/size.c (added) * testsuites/support/include/tmacros.h (added) * testsuites/tmtests/README (added) * testsuites/tmtests/include/timesys.h (added) * testsuites/tmtests/tm01/system.h (added) * testsuites/tmtests/tm01/task1.c (added) * testsuites/tmtests/tm01/tm01.doc (added) * testsuites/tmtests/tm02/system.h (added) * testsuites/tmtests/tm02/task1.c (added) * testsuites/tmtests/tm02/tm02.doc (added) * testsuites/tmtests/tm03/system.h (added) * testsuites/tmtests/tm03/task1.c (added) * testsuites/tmtests/tm03/tm03.doc (added) * testsuites/tmtests/tm04/system.h (added) * testsuites/tmtests/tm04/task1.c (added) * testsuites/tmtests/tm04/tm04.doc (added) * testsuites/tmtests/tm05/system.h (added) * testsuites/tmtests/tm05/task1.c (added) * testsuites/tmtests/tm05/tm05.doc (added) * testsuites/tmtests/tm06/system.h (added) * testsuites/tmtests/tm06/task1.c (added) * testsuites/tmtests/tm06/tm06.doc (added) * testsuites/tmtests/tm07/system.h (added) * testsuites/tmtests/tm07/task1.c (added) * testsuites/tmtests/tm07/tm07.doc (added) * testsuites/tmtests/tm08/system.h (added) * testsuites/tmtests/tm08/task1.c (added) * testsuites/tmtests/tm08/tm08.doc (added) * testsuites/tmtests/tm09/system.h (added) * testsuites/tmtests/tm09/task1.c (added) * testsuites/tmtests/tm09/tm09.doc (added) * testsuites/tmtests/tm10/system.h (added) * testsuites/tmtests/tm10/task1.c (added) * testsuites/tmtests/tm10/tm10.doc (added) * testsuites/tmtests/tm11/system.h (added) * testsuites/tmtests/tm11/task1.c (added) * testsuites/tmtests/tm11/tm11.doc (added) * testsuites/tmtests/tm12/system.h (added) * testsuites/tmtests/tm12/task1.c (added) * testsuites/tmtests/tm12/tm12.doc (added) * testsuites/tmtests/tm13/system.h (added) * testsuites/tmtests/tm13/task1.c (added) * testsuites/tmtests/tm13/tm13.doc (added) * testsuites/tmtests/tm14/system.h (added) * testsuites/tmtests/tm14/task1.c (added) * testsuites/tmtests/tm14/tm14.doc (added) * testsuites/tmtests/tm15/system.h (added) * testsuites/tmtests/tm15/task1.c (added) * testsuites/tmtests/tm15/tm15.doc (added) * testsuites/tmtests/tm16/system.h (added) * testsuites/tmtests/tm16/task1.c (added) * testsuites/tmtests/tm16/tm16.doc (added) * testsuites/tmtests/tm17/system.h (added) * testsuites/tmtests/tm17/task1.c (added) * testsuites/tmtests/tm17/tm17.doc (added) * testsuites/tmtests/tm18/system.h (added) * testsuites/tmtests/tm18/task1.c (added) * testsuites/tmtests/tm18/tm18.doc (added) * testsuites/tmtests/tm19/system.h (added) * testsuites/tmtests/tm19/task1.c (added) * testsuites/tmtests/tm19/tm19.doc (added) * testsuites/tmtests/tm20/system.h (added) * testsuites/tmtests/tm20/task1.c (added) * testsuites/tmtests/tm20/tm20.doc (added) * testsuites/tmtests/tm21/system.h (added) * testsuites/tmtests/tm21/task1.c (added) * testsuites/tmtests/tm21/tm21.doc (added) * testsuites/tmtests/tm22/system.h (added) * testsuites/tmtests/tm22/task1.c (added) * testsuites/tmtests/tm22/tm22.doc (added) * testsuites/tmtests/tm23/system.h (added) * testsuites/tmtests/tm23/task1.c (added) * testsuites/tmtests/tm23/tm23.doc (added) * testsuites/tmtests/tm24/system.h (added) * testsuites/tmtests/tm24/task1.c (added) * testsuites/tmtests/tm24/tm24.doc (added) * testsuites/tmtests/tm25/system.h (added) * testsuites/tmtests/tm25/task1.c (added) * testsuites/tmtests/tm25/tm25.doc (added) * testsuites/tmtests/tm26/fptest.h (added) * testsuites/tmtests/tm26/system.h (added) * testsuites/tmtests/tm26/task1.c (added) * testsuites/tmtests/tm26/tm26.doc (added) * testsuites/tmtests/tm27/system.h (added) * testsuites/tmtests/tm27/task1.c (added) * testsuites/tmtests/tm27/tm27.doc (added) * testsuites/tmtests/tm28/system.h (added) * testsuites/tmtests/tm28/task1.c (added) * testsuites/tmtests/tm28/tm28.doc (added) * testsuites/tmtests/tm29/system.h (added) * testsuites/tmtests/tm29/task1.c (added) * testsuites/tmtests/tm29/tm29.doc (added) * testsuites/tmtests/tmck/system.h (added) * testsuites/tmtests/tmck/task1.c (added) * testsuites/tmtests/tmck/tmck.doc (added) * testsuites/tmtests/tmoverhd/dumrtems.h (added) * testsuites/tmtests/tmoverhd/empty.c (added) * testsuites/tmtests/tmoverhd/system.h (added) * testsuites/tmtests/tmoverhd/testtask.c (added) * testsuites/tmtests/tmoverhd/tmoverhd.doc (added) * tools/build/README (added) * tools/build/cklength.c (added) * tools/build/eolstrip.c (added) * tools/build/packhex.c (added) * tools/build/scripts/README (added) * tools/build/src/cklength.c (added) * tools/build/src/eolstrip.c (added) * tools/build/src/packhex.c (added) * tools/build/src/unhex.c (added) * tools/build/unhex.c (added) * tools/cpu/hppa1.1/genoffsets.c (added) * tools/update/310_to_320_list (added) * tools/update/README (added) Initial revision
