# # ChangeLog for testsuites/rtems-test-check.py in rtems # # Generated by Trac 1.2.1.dev0 # 05/26/24 19:45:24 Wed, 28 Nov 2018 09:32:46 GMT Chris Johns [aa5c462] * testsuites/rtems-test-check.py (modified) testsuite: Parse TCFG path based on OS path separator. Wed, 07 Nov 2018 05:09:07 GMT Chris Johns [06ced25] * testsuites/aclocal/rtems-test-check.m4 (modified) * testsuites/rtems-test-check (added) * testsuites/rtems-test-check.py (modified) testsuite: Add python verison support to rtems-test-check.py Closes ... Fri, 27 Apr 2018 04:18:41 GMT Sebastian Huber [97a48209] * testsuites/aclocal/rtems-test-check.m4 (modified) * testsuites/rtems-test-check.py (moved) * tools/build/rtems-test-check (deleted) tests: Move rtems-test-check.py Remove shell script variant.
