# # ChangeLog for testsuites/rtems-test-check.py in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 15:19:22 Fri, 27 Apr 2018 04:18:41 GMT Sebastian Huber [97a48209] * testsuites/aclocal/rtems-test-check.m4 (modified) * testsuites/rtems-test-check.py (moved) * tools/build/rtems-test-check (deleted) tests: Move rtems-test-check.py Remove shell script variant.
