@9fd7271
05/13/16 12:59:31 |
Sebastian Huber |
posix: Fix return status of pthread_cancel()
POSIX recommends ESRCH …
5
@1d40d81b
05/03/16 05:38:19 |
Sebastian Huber |
rtems: Remove task variables
Update #2494.
Update #2555.
5
@e4fd35d
05/03/16 10:55:00 |
Sebastian Huber |
confdefs.h: Fix named object size estimate
Account for the …
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@f05eeb2
04/19/16 11:39:00 |
Sebastian Huber |
score: Simplify _Objects_Initialize_information()
Remove unused …
5
@48b04fc3
04/19/16 04:28:03 |
Sebastian Huber |
posix: Avoid Giant lock for mutexes
Delete _POSIX_Mutex_Get(). Use …
5
@90f1265e
04/18/16 04:23:27 |
Sebastian Huber |
score: Fix _CORE_semaphore_Flush()
Use proper CORE_semaphore_Status …
5
@8228548
02/19/16 22:00:48 |
joel |
Add pthread_getconcurrency() and pthread_setconcurrency()
This is the …
5
@6efa349
04/14/16 06:56:53 |
Sebastian Huber |
posix: Run key destructors during thread restart
POSIX key …
5
@9e2acee
03/22/16 07:24:45 |
Sebastian Huber |
psxtests/psxobj01: Fix for RTEMS_DEBUG
5
@c904df5
03/18/16 06:25:23 |
Sebastian Huber |
score: Add _Objects_Get_by_name()
Replace …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@5d478af
02/22/16 08:40:16 |
Sebastian Huber |
psxtests/psxualarm: Add test cases
Update #2344.
5
@452f6ba9
02/22/16 08:15:45 |
Sebastian Huber |
psxtests/psxalarm01: Add adjtime() test case
Update #2606.
5
@dcb1dc4d
01/26/16 16:41:12 |
Sebastian Huber |
psxtests: Disable POSIX only psxcleanup02
5
@438fa8d
01/19/16 08:31:58 |
Sebastian Huber |
psxtests: Fix link-time errors
Fix link-time errors introduced by …
5
@fe100e16
12/22/15 08:13:08 |
Sebastian Huber |
score: Add fatal errors for NULL entry init tasks
This simplifies the …
5
@f9f7321e
12/22/15 06:56:57 |
Sebastian Huber |
Filesystem: Remove superfluous permission checks
The permission is …
5
@f6a8663e
12/26/15 16:58:25 |
Joel Sherrill |
Remove H8300 port
updates #2452.
5
@2b137ed
12/15/15 05:36:52 |
Sebastian Huber |
psxtests/psxcleanup02: New test
5
@69be1a22
10/20/15 19:47:10 |
Joel Sherrill |
CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error …
5
@f97536d
10/16/15 06:21:48 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_UNUSED
5
@3b3d1489
09/01/15 12:16:48 |
Sebastian Huber |
posix: glibc compatibility
5
@d9d0a84
09/01/15 12:07:51 |
Sebastian Huber |
psxtests/psxcancel: Check return status
Update #2402.
5
@20b423c6
05/11/15 13:02:51 |
Sebastian Huber |
psxualarm: Avoid endless signal handling
Increase the ualarm timer …
4.115
@fc0756e
04/14/15 15:01:05 |
Joel Sherrill |
Add test assertion for allocator mutex being unlocked
The Allocator …
4.115
@ab90136b
03/20/15 15:45:55 |
Joel Sherrill |
psxconfig01/init.c: Correct pointer/integer size warning
4.115
@278da87
03/20/15 15:45:28 |
Joel Sherrill |
psxtests/psx15/init.c: Correct printf() warning
4.115
@e0437fe
03/20/15 15:38:44 |
Joel Sherrill |
testsuites/psxtests/psxsignal03/init.c: Fix line wrap
4.115
@d4edbdbc
03/20/15 13:09:26 |
Sebastian Huber |
Replace www.rtems.com with www.rtems.org
4.115
@e334edd
03/14/15 15:52:24 |
Joel Sherrill |
tests misc: Disable deprecated method usage warning when intentional
4.115
@1f67156
03/09/15 12:18:36 |
Sebastian Huber |
libcsupport: Delete superfluous _gettimeofday()
4.115
@40ecd11
03/09/15 14:23:20 |
Sebastian Huber |
sysconf: Add _SC_NPROCESSORS_(CONF|ONLN)
4.115
@56c7192
03/03/15 16:08:51 |
Gedare Bloom |
psxtests/psxclock01: use clock() and CLOCKS_PER_SEC
Closes #2182
4.115
@6357e14a
02/26/15 11:55:43 |
Sebastian Huber |
psxtests/psx05: Adjust test case
Update #2170.
4.115
@83fe4468
02/23/15 14:59:49 |
Gedare Bloom |
psxtests: add string param to printf. closes #2241
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@b57a6a7
02/11/15 19:59:29 |
Joel Sherrill |
psxhdrs: Reorganize into subdirectories per .h file and rename files
4.115
@86076f3
02/11/15 19:31:30 |
Joel Sherrill |
psxhdrs: Remove test of pthread_attr_[gs]et_cputime
These methods are …
4.115
@eedaf9b
02/11/15 20:00:35 |
Joel Sherrill |
psxhdrs: Add tests for <sys/socket.h> API compliance
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@16939b18
02/09/15 18:09:23 |
Sebastian Huber |
Filesystem: Simplify FIFO and pipe configuration
4.115
@cf36b70
12/31/14 09:56:05 |
Sebastian Huber |
IMFS: Replace node union with individual struct
This reduces the …
4.115
@80bfd3a
01/23/15 15:46:48 |
Joel Sherrill |
psx07: Add missing parameter to printf() call
Close 2241.
Conflicts: …
4.115
@ffb1a45
01/23/15 11:49:44 |
Sebastian Huber |
psxtests/psx07: Fix printf() statement
Close #2240.
4.115
@a0b1b5ed
12/15/14 13:19:43 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define was …
4.115
@7bdb765
12/12/14 07:46:30 |
Sebastian Huber |
Add POSIX key value pairs to resource snapshot
4.115
@172e953
12/12/14 12:16:11 |
Sebastian Huber |
posix: Delete key/value if value is set to NULL
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@ffa71f1
11/17/14 06:53:01 |
Sebastian Huber |
libcsupport: Implement getgroups()
4.115
@395e5d4
11/14/14 14:33:57 |
Sebastian Huber |
libcsupport: Use POSIX key for getgrent()
4.115
@002f351
11/14/14 13:30:36 |
Sebastian Huber |
libcsupport: Minimal /etc/passwd and /etc/group
Create a minimal …
4.115
@43633ae
10/14/14 10:12:32 |
Sebastian Huber |
testsuites: Avoid clock driver
4.115
@a38ced2
10/10/14 07:09:19 |
Sebastian Huber |
score: Rework global construction
Ensure that the global construction …
4.115
@b9f95225
10/08/14 08:31:36 |
Sebastian Huber |
posix: Add auto initializaton for rwlock
4.115
@b5f9ad2
09/09/14 14:49:20 |
Sebastian Huber |
psxtests/psxonce01: Use test extension
4.115
@8028089
09/08/14 13:18:07 |
Sebastian Huber |
tests: Rework interrupt critical tests
This avoids test durations of …
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@fef4293
04/07/14 13:59:09 |
Sebastian Huber |
psxtests/psxkey02: Test for proper error case
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@391ad3e
03/17/14 14:03:22 |
Sebastian Huber |
score: Fix thread restart extensions context
Run the thread restart …
4.115
@ecd8c8ad
03/28/14 10:58:20 |
Sebastian Huber |
tests/fatal: Fix test names
4.115
@d98217c
03/28/14 10:52:28 |
Sebastian Huber |
psxtests/psxconfig01: Fix for POSIX keys config
4.115
@5c0c0cf
03/27/14 13:23:21 |
Christian.Mauderer |
privateenv: Use POSIX keys instead of task variables.
4.115
@8c26e798
03/25/14 15:45:08 |
Sebastian Huber |
tests: Produce proper begin/end messages
4.115
@698c2e50
03/25/14 07:06:16 |
Sebastian Huber |
tests/psxtests: Use <rtems/test.h>
4.115
@22729053
03/25/14 07:06:06 |
Sebastian Huber |
tests: Use rtems_status_text()
4.115
@01f23374
03/21/14 11:07:27 |
posix: Prevent pthread_setspecific from returning EAGAIN.
The …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@4484112
03/18/14 15:25:34 |
psxonce01: Add call counter to check if init function has been called.
4.115
@6592cab
03/18/14 15:25:33 |
psxtests: move pthread_once tests into an extra test.
4.115
@51f823c9
03/18/14 07:28:14 |
Sebastian Huber |
posix: Use interal mutex for once implementation
Enable …
4.115
@0dd025cc
03/11/14 13:15:54 |
Sebastian Huber |
psxtests/psxkey07: Do not allocate task IDs
4.115
@92d261c
03/11/14 13:02:42 |
Sebastian Huber |
psxtests/psxkey07: Limit workspace size
This avoids large test …
4.115
@fca27b7
03/11/14 13:02:07 |
Sebastian Huber |
psxtests/psxkey07: Account for RTEMS_TOO_MANY
4.115
@0a64eba9
03/11/14 12:58:49 |
Sebastian Huber |
psxtests/psxkey08: Limit workspace size
4.115
@61081541
03/11/14 12:57:22 |
Sebastian Huber |
psxtests/psxkey08: Do not allocate task IDs
We have a unified work …
4.115
@e6c87f7
03/04/14 21:54:12 |
Joel Sherrill |
POSIX keys now enabled in all configurations.
Formerly POSIX keys …
4.115
@5c332349
03/07/14 15:06:57 |
Jennifer Averett |
Remove trailing whitespace in previous patches
4.115
@c315dbf2
01/14/14 18:45:49 |
Jennifer Averett |
psxtests: Added test for pthread_getattr_np().
4.115
@f38060b
02/17/14 18:17:26 |
Jennifer Averett |
psxtests: Correct bug in check of affinity support in newlib.
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@6e6fd513
01/18/14 23:42:17 |
Chris Johns |
testsuite/psx13: Add linefeed to end of test message.
The lack of a …
4.115
@bc55e4f
01/08/14 00:02:46 |
Joel Sherrill |
psximfs02: Clean up output
4.115
@524e785
01/03/14 19:12:43 |
shailysangwan |
psxtime: Added doc file.
4.115
@12f81c09
01/03/14 14:25:14 |
mjuvekar0 |
pskey09, sp17: documentation cleanup.
4.115
@b23ef87
12/26/13 16:10:52 |
rishisharma7361 |
psx03: Add doc file
4.115
@c51645f
12/24/13 09:01:42 |
mjuvekar0 |
psxtests/psx14: Add doc file
4.115
@1464599
12/20/13 16:37:25 |
mjuvekar0 |
psxtests/psxfatal01: add doc file
4.115
@c1d8ee4
12/17/13 09:59:13 |
Sebastian Huber |
libcsupport: Accept NULL for zero-length entries
4.115
@95a57280
12/16/13 12:12:22 |
Sebastian Huber |
libcsupport: Add and use rtems_libio_iovec_eval()
4.115
@540a635
12/18/13 20:01:20 |
email.anukul |
psxtests: add psxcleanup/psxcleanup.doc
4.115
@73184499
12/09/13 20:22:13 |
Joel Sherrill |
psxtests/configure.ac: Probe for SMP affinity methods
4.115
@0b599421
12/11/13 01:48:28 |
Joel Sherrill |
psxsignal06: Fix bug where mutex not locked and add EPERM error check
4.115
@74c15fe6
12/10/13 23:56:22 |
Joel Sherrill |
psxtmcond01: Fix bug where mutex not locked and add EPERM error check
4.115
@927a0a1
12/02/13 07:33:35 |
Sebastian Huber |
posix: Use cleanup contexts on the stack
Provide support for latest …
4.115
@95d7ac7
12/01/13 00:41:11 |
annelies.odermann |
psx07.doc: New file
4.115
