@7fb19bb
08/15/96 19:27:08 |
Mark.Johannes |
init: added tests for pthread_kill and kill errors.
4.104.114.84.95
@851b18d
08/15/96 18:59:34 |
Joel Sherrill |
changed error code
4.104.114.84.95
@fdf6917
08/15/96 18:59:00 |
Joel Sherrill |
changed error for too many threads to EAGAIN
4.104.114.84.95
@fb7d080
08/14/96 20:25:57 |
Joel Sherrill |
pthread_mutex_init returns EAGAIN not ENOMEM when there are too many …
4.104.114.84.95
@ac81b6ca
08/14/96 19:41:47 |
Joel Sherrill |
added test cases for NULL being passed to pthread attribute get routines
4.104.114.84.95
@ff53a6d4
08/14/96 19:30:49 |
Joel Sherrill |
added test case for pthread_attr_getscope being passed a NULL …
4.104.114.84.95
@87c8fd09
08/14/96 17:19:03 |
Mark.Johannes |
system.h: added task3 and changed condition variable config to 1
4.104.114.84.95
@b0c483ed
08/14/96 17:18:02 |
Mark.Johannes |
task3: added to test error case in Wait_support for lock on mutex
4.104.114.84.95
@520949bf
08/14/96 17:16:14 |
Mark.Johannes |
init: added error case for wait timedwait, and wait support
4.104.114.84.95
@645fc954
08/14/96 15:27:14 |
Joel Sherrill |
pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope
4.104.114.84.95
@c8a4ed6
08/13/96 19:06:45 |
Mark.Johannes |
task_2: added comments and print statement for task exit
4.104.114.84.95
@1d428a3c
08/13/96 19:06:12 |
Mark.Johannes |
task_1: added comments and print statement for task exit
4.104.114.84.95
@c9c94387
08/13/96 19:05:27 |
Mark.Johannes |
Init.c: added timewait case, added broadcast case
4.104.114.84.95
@9b67f170
08/13/96 15:36:28 |
Joel Sherrill |
corrected problem in which sigtimedwait() was being invoked with
the …
4.104.114.84.95
@fc960ab
08/13/96 15:35:36 |
Joel Sherrill |
chenaged format of output
4.104.114.84.95
@0d59c7a
08/13/96 14:47:52 |
Joel Sherrill |
added include of errno.h so the test can check for EINTR.
4.104.114.84.95
@85f5b4ab
08/13/96 14:47:31 |
Joel Sherrill |
nanosleep now returns -1 and EINTR when a signal interrupts EINTR.
4.104.114.84.95
@e9624663
08/12/96 21:52:37 |
Mark.Johannes |
task_1: added to handle cases of waiting tasks on condition variables
4.104.114.84.95
@a7f4c5a
08/12/96 21:51:44 |
Mark.Johannes |
system.h: added protoypes for task and task2, added mutex id, and task ids
4.104.114.84.95
@aad3fe6
08/12/96 21:49:54 |
Mark.Johannes |
Init.c: added cases for signal, wait and broadcast
4.104.114.84.95
@08515de
08/12/96 21:49:14 |
Mark.Johannes |
Task2: new task for broadcast case
4.104.114.84.95
@5da2ae8
08/12/96 21:15:15 |
Joel Sherrill |
added test cases for clock_getres
4.104.114.84.95
@221bd65
08/12/96 20:00:02 |
Joel Sherrill |
added test case for stack too large
4.104.114.84.95
@c4f5e752
08/12/96 19:54:12 |
Joel Sherrill |
added test cases for clock_gettime (invalid id), clock_settime …
4.104.114.84.95
@d60d9505
08/12/96 19:20:18 |
Joel Sherrill |
added test case for non-NULL parameter to time()
4.104.114.84.95
@d06e9ca
08/12/96 18:04:38 |
Joel Sherrill |
added numerous error test cases.
4.104.114.84.95
@0cd15947
08/12/96 15:15:51 |
Mark.Johannes |
Init: added pthread_cond_init with an attr non-NULL, initialized the …
4.104.114.84.95
@5263668
08/12/96 14:49:02 |
Mark.Johannes |
Init: added prliminary phtread_cond_init and destroy cases.
4.104.114.84.95
@da4e38d
08/12/96 14:48:13 |
Mark.Johannes |
system.h: added condition variable #define for 10 condition variables
4.104.114.84.95
@da2e539
08/09/96 21:16:01 |
Joel Sherrill |
added test cases for errors in pthread_mutexattr_getpshared
4.104.114.84.95
@13adea0
08/09/96 19:55:04 |
Joel Sherrill |
added test cases for EINVAL cases in pthread_mutexattr_destroy
4.104.114.84.95
@c03aeaf
08/09/96 19:50:26 |
Joel Sherrill |
added test case for pthread_mutexattr_init being passed a null pointer.
4.104.114.84.95
@76117f2b
08/09/96 19:20:54 |
Joel Sherrill |
changed style of output to match other tests
4.104.114.84.95
@1406a4b
08/09/96 19:10:50 |
Mark.Johannes |
system.h: initial cvs
4.104.114.84.95
@c7dd091f
08/09/96 18:48:33 |
Joel Sherrill |
lowered maximum number of threads to 2 to make test case easier.
4.104.114.84.95
@d0b5249
08/09/96 18:47:58 |
Joel Sherrill |
added test case for sched_yield.
changed format of some output.
4.104.114.84.95
@f643e230
08/09/96 18:47:38 |
Joel Sherrill |
added test cases for errors in sched_get_priority_min and …
4.104.114.84.95
@695dd0b
08/09/96 18:28:21 |
Mark.Johannes |
Init: added condattr - destroy, init, set and get cases
4.104.114.84.95
@66dfd0b
08/09/96 17:44:04 |
Joel Sherrill |
added test cases for invalid key ids
4.104.114.84.95
@760ee96d
08/09/96 16:02:06 |
Joel Sherrill |
reduced maximum keys to 2 to more easily generate error
4.104.114.84.95
@5b08e20
08/09/96 16:01:50 |
Joel Sherrill |
changed printf's which could be puts's to puts
4.104.114.84.95
@54e34e7
08/08/96 23:02:13 |
Joel Sherrill |
new test to test scheduling policy and paremeter paths in pthread_create.
4.104.114.84.95
@13642cbc
08/08/96 22:26:55 |
Mark.Johannes |
Init: Original file - tests for condition variables.
4.104.114.84.95
@79f189e
08/08/96 21:58:26 |
Joel Sherrill |
split test into multiple tasks.
4.104.114.84.95
@76de65b3
08/08/96 21:46:40 |
Joel Sherrill |
added cases to increase coverage of pthread_create. cases added …
4.104.114.84.95
@2b613588
08/08/96 20:47:49 |
Joel Sherrill |
added test to complete coverage of pthread_setschedparam and increase …
4.104.114.84.95
@8ca831af
08/08/96 19:21:47 |
Mark.Johannes |
Init: spacing
4.104.114.84.95
@e3515731
08/08/96 19:20:13 |
Mark.Johannes |
Task_1: changed comment and task name to task1.
4.104.114.84.95
@9f1a034e
08/08/96 19:19:09 |
Mark.Johannes |
Init.c: added priority ceiling task cases.
4.104.114.84.95
@77597dd
08/08/96 18:50:39 |
Mark.Johannes |
Added task2 and task3 prototypes and ids
4.104.114.84.95
@481d8f8
08/08/96 18:44:09 |
Mark.Johannes |
Signal_info_handler: added multiple signal cases to finish out the test
4.104.114.84.95
@4357da1
08/08/96 18:27:44 |
Joel Sherrill |
changed phrase "RTEMS is support" to "RTEMS is supposed"
4.104.114.84.95
@8b1c1ae
08/08/96 16:53:32 |
Joel Sherrill |
print_current_time: added leading underscore to variables allocated …
4.104.114.84.95
@644c0fa6
08/08/96 16:28:24 |
Joel Sherrill |
added complete test cases for pthread_once.
4.104.114.84.95
@ecc912f4
08/07/96 22:05:15 |
Joel Sherrill |
added more error cases to complete testing of pthread_equal when …
4.104.114.84.95
@42418a9
08/07/96 22:00:57 |
Joel Sherrill |
added test cases for ESRCH from pthread_join and pthread_detach
4.104.114.84.95
@84b03316
08/07/96 21:38:18 |
Joel Sherrill |
removed if 0 for basic sporadic server case accidentally left in.
4.104.114.84.95
@7e811af1
08/07/96 21:27:25 |
Joel Sherrill |
basic sporadic server test.
sporadic server with priority ceiling …
4.104.114.84.95
@c123a084
08/07/96 15:52:30 |
Joel Sherrill |
added complete test cases for pthread_attr_getschedparam, …
4.104.114.84.95
@20de272
08/02/96 18:25:16 |
Joel Sherrill |
join/detach basic tests pass
4.104.114.84.95
@375f37d
08/02/96 16:46:56 |
Joel Sherrill |
removed unused prototypes
4.104.114.84.95
@870f2976
08/01/96 21:02:54 |
Joel Sherrill |
test successfully exercises all of pthread_attr_* set and get routines
4.104.114.84.95
@c65a0cee
07/31/96 17:17:48 |
Joel Sherrill |
added key test
4.104.114.84.95
@ce78b894
07/04/96 17:38:55 |
Joel Sherrill |
added test case for timeout using pthread_mutex_timedlock
4.104.114.84.95
@c6d15c2
07/04/96 17:01:48 |
Joel Sherrill |
first test cases for mutex manager pass
4.104.114.84.95
@f88310da
06/15/96 19:56:19 |
Joel Sherrill |
initial modifications to test sigtimedwait.
4.104.114.84.95
@36197e53
06/13/96 22:16:08 |
Mark.Johannes |
first successful run. Has test cases for a simple sigtimedwait() …
4.104.114.84.95
@728b5a7
06/13/96 16:45:11 |
Joel Sherrill |
Added a macro for "empty_line" which will go between test cases.
4.104.114.84.95
@ce0f7d95
06/13/96 16:44:46 |
Joel Sherrill |
Added more test cases for kill() and alarm(). kill() now can unblock …
4.104.114.84.95
@1094754f
06/12/96 22:52:13 |
Joel Sherrill |
new files
4.104.114.84.95
@699fe08a
06/11/96 20:46:13 |
Joel Sherrill |
Added test case which blocks a signal, sees what signals are pending, …
4.104.114.84.95
@fb39f19
06/11/96 16:04:25 |
Joel Sherrill |
modified to test pthread_kill() to self and pthread_kill() to a …
4.104.114.84.95
@1ba858d
06/10/96 20:51:31 |
Joel Sherrill |
new files.
This test does a basic checkout of signals with a …
4.104.114.84.95
@1e608b0f
06/10/96 20:49:21 |
Joel Sherrill |
new file
4.104.114.84.95
@893103c
06/10/96 20:49:08 |
Joel Sherrill |
moved the time macros to pmacros.h.
4.104.114.84.95
@0a359a7
06/06/96 19:16:20 |
Joel Sherrill |
added include of <sched.h> and fixed warnings
4.104.114.84.95
@95645a4
06/04/96 19:06:30 |
Joel Sherrill |
added test case for sched_get_priority_min, sched_get_priority_max, …
4.104.114.84.95
@15974b65
06/04/96 14:32:21 |
Joel Sherrill |
added basic test cases for pthread_self and pthread_equal
4.104.114.84.95
@e984c645
06/03/96 18:59:59 |
Joel Sherrill |
added test code for return of remaining time from sleep().
4.104.114.84.95
@e88b589
06/03/96 18:28:30 |
Joel Sherrill |
added test case for nanosleep filling in the time remaining structure.
4.104.114.84.95
@19962562
06/03/96 16:30:44 |
Joel Sherrill |
added test code for nanosleep and return code from sleep.
4.104.114.84.95
@9594cdb
05/30/96 20:49:16 |
Joel Sherrill |
added code to test clock and time related functionality.
4.104.114.84.95
@be1c11ed
05/29/96 22:48:26 |
Joel Sherrill |
tests now specify whether using posix initialization threads table
or …
4.104.114.84.95
@2197a2e1
05/29/96 20:56:57 |
Joel Sherrill |
simple version of test which shows pthread_create, pthread_exit, and …
4.104.114.84.95
@0252200
05/29/96 16:06:47 |
Joel Sherrill |
Gutted test of rtems api calls and added comments to indicate what the …
4.104.114.84.95
@3320e52
05/24/96 22:58:15 |
Joel Sherrill |
new file
4.104.114.84.95
@94bac464
05/24/96 19:35:25 |
Joel Sherrill |
new file
4.104.114.84.95
@86fc81e
05/24/96 19:33:36 |
Joel Sherrill |
new files
4.104.114.84.95
@abd604a
05/24/96 14:25:49 |
Mark.Johannes |
new file
4.104.114.84.95
@6481405e
05/24/96 14:16:24 |
Joel Sherrill |
added use of sporadic server scheduling parameters
4.104.114.84.95
@8442b4c7
05/24/96 14:05:02 |
Joel Sherrill |
new files
4.104.114.84.95
@13fcfde
05/23/96 22:34:18 |
Joel Sherrill |
clean up on DELAYTIMER_MAX
4.104.114.84.95
@8a318cd
05/23/96 22:23:44 |
Joel Sherrill |
new files
4.104.114.84.95
@3a9fc7d
05/23/96 21:51:54 |
Joel Sherrill |
unused variable
4.104.114.84.95
@73c5da6a
05/23/96 21:51:53 |
Joel Sherrill |
new files
4.104.114.84.95
@7303eea
05/23/96 21:23:12 |
Joel Sherrill |
new files
4.104.114.84.95
@1b297b4a
05/23/96 21:10:12 |
Joel Sherrill |
new files
4.104.114.84.95
@d1d7e807
05/23/96 20:43:04 |
Joel Sherrill |
new files
4.104.114.84.95
@a1c86cbe
05/23/96 20:37:09 |
Joel Sherrill |
new files
4.104.114.84.95
@3d135eea
05/23/96 19:56:49 |
Joel Sherrill |
cleanup
4.104.114.84.95
