# # ChangeLog for testsuites/psxtests in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 22:38:52 Fri, 09 Aug 1996 18:47:38 GMT Joel Sherrill [f643e230] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test cases for errors in sched_get_priority_min and ... Fri, 09 Aug 1996 18:28:21 GMT Mark Johannes [695dd0b] * c/src/tests/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/init.c (modified) Init: added condattr - destroy, init, set and get cases Fri, 09 Aug 1996 17:44:04 GMT Joel Sherrill [66dfd0b] * c/src/tests/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/init.c (modified) added test cases for invalid key ids Fri, 09 Aug 1996 16:02:06 GMT Joel Sherrill [760ee96d] * c/src/tests/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/system.h (modified) reduced maximum keys to 2 to more easily generate error Fri, 09 Aug 1996 16:01:50 GMT Joel Sherrill [5b08e20] * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) changed printf's which could be puts's to puts Thu, 08 Aug 1996 23:02:13 GMT Joel Sherrill [54e34e7] * c/src/tests/psxtests/psx12/init.c (added) * c/src/tests/psxtests/psx12/psx12.scn (added) * c/src/tests/psxtests/psx12/system.h (added) * c/src/tests/psxtests/psx12/task.c (added) * testsuites/psxtests/psx12/init.c (added) * testsuites/psxtests/psx12/psx12.scn (added) * testsuites/psxtests/psx12/system.h (added) * testsuites/psxtests/psx12/task.c (added) new test to test scheduling policy and paremeter paths in pthread_create. Thu, 08 Aug 1996 22:26:55 GMT Mark Johannes [13642cbc] * c/src/tests/psxtests/psx10/init.c (added) * testsuites/psxtests/psx10/init.c (added) Init: Original file - tests for condition variables. Thu, 08 Aug 1996 21:58:26 GMT Joel Sherrill [79f189e] * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task2.c (added) * c/src/tests/psxtests/psx05/task3.c (added) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task2.c (added) * testsuites/psxtests/psx05/task3.c (added) split test into multiple tasks. Thu, 08 Aug 1996 21:46:40 GMT Joel Sherrill [76de65b3] * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (added) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (added) added cases to increase coverage of pthread_create. cases added ... Thu, 08 Aug 1996 20:47:49 GMT Joel Sherrill [2b613588] * c/src/tests/psxtests/psx11/init.c (added) * c/src/tests/psxtests/psx11/psx11.scn (added) * c/src/tests/psxtests/psx11/system.h (added) * c/src/tests/psxtests/psx11/task.c (added) * testsuites/psxtests/psx11/init.c (added) * testsuites/psxtests/psx11/psx11.scn (added) * testsuites/psxtests/psx11/system.h (added) * testsuites/psxtests/psx11/task.c (added) added test to complete coverage of pthread_setschedparam and increase ... Thu, 08 Aug 1996 19:21:47 GMT Mark Johannes [8ca831af] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) Init: spacing Thu, 08 Aug 1996 19:20:13 GMT Mark Johannes [e3515731] * c/src/tests/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task.c (modified) Task_1: changed comment and task name to task1. Thu, 08 Aug 1996 19:19:09 GMT Mark Johannes [9f1a034e] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) Init.c: added priority ceiling task cases. Thu, 08 Aug 1996 18:50:39 GMT Mark Johannes [77597dd] * c/src/tests/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/system.h (modified) Added task2 and task3 prototypes and ids Thu, 08 Aug 1996 18:44:09 GMT Mark Johannes [481d8f8] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Signal_info_handler: added multiple signal cases to finish out the test Thu, 08 Aug 1996 18:27:44 GMT Joel Sherrill [4357da1] * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) changed phrase "RTEMS is support" to "RTEMS is supposed" Thu, 08 Aug 1996 16:53:32 GMT Joel Sherrill [8b1c1ae] * c/src/tests/psxtests/include/pmacros.h (modified) * c/src/tests/psxtests/support/include/pmacros.h (modified) * testsuites/psxtests/include/pmacros.h (modified) print_current_time: added leading underscore to variables allocated ... Thu, 08 Aug 1996 16:28:24 GMT Joel Sherrill [644c0fa6] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) added complete test cases for pthread_once. Wed, 07 Aug 1996 22:05:15 GMT Joel Sherrill [ecc912f4] * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/task.c (modified) added more error cases to complete testing of pthread_equal when ... Wed, 07 Aug 1996 22:00:57 GMT Joel Sherrill [42418a9] * c/src/tests/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/init.c (modified) added test cases for ESRCH from pthread_join and pthread_detach Wed, 07 Aug 1996 21:38:18 GMT Joel Sherrill [84b03316] * c/src/tests/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/init.c (modified) removed if 0 for basic sporadic server case accidentally left in. Wed, 07 Aug 1996 21:27:25 GMT Joel Sherrill [7e811af1] * c/src/tests/psxtests/psx09/init.c (added) * c/src/tests/psxtests/psx09/psx09.scn (added) * c/src/tests/psxtests/psx09/system.h (added) * testsuites/psxtests/psx09/init.c (added) * testsuites/psxtests/psx09/psx09.scn (added) * testsuites/psxtests/psx09/system.h (added) basic sporadic server test. sporadic server with priority ceiling ... Wed, 07 Aug 1996 15:52:30 GMT Joel Sherrill [c123a084] * c/src/tests/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/init.c (modified) added complete test cases for pthread_attr_getschedparam, ... Fri, 02 Aug 1996 18:25:16 GMT Joel Sherrill [20de272] * c/src/tests/psxtests/psx08/init.c (added) * c/src/tests/psxtests/psx08/psx08.scn (added) * c/src/tests/psxtests/psx08/system.h (added) * c/src/tests/psxtests/psx08/task.c (added) * c/src/tests/psxtests/psx08/task2.c (added) * testsuites/psxtests/psx08/init.c (added) * testsuites/psxtests/psx08/psx08.scn (added) * testsuites/psxtests/psx08/system.h (added) * testsuites/psxtests/psx08/task2.c (added) join/detach basic tests pass Fri, 02 Aug 1996 16:46:56 GMT Joel Sherrill [375f37d] * c/src/tests/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/system.h (modified) removed unused prototypes Thu, 01 Aug 1996 21:02:54 GMT Joel Sherrill [870f2976] * c/src/tests/psxtests/psx07/init.c (added) * c/src/tests/psxtests/psx07/psx07.scn (added) * c/src/tests/psxtests/psx07/system.h (added) * testsuites/psxtests/psx07/init.c (added) * testsuites/psxtests/psx07/psx07.scn (added) * testsuites/psxtests/psx07/system.h (added) test successfully exercises all of pthread_attr_* set and get routines Wed, 31 Jul 1996 17:17:48 GMT Joel Sherrill [c65a0cee] * c/src/tests/psxtests/psx06/init.c (added) * c/src/tests/psxtests/psx06/psx06.scn (added) * c/src/tests/psxtests/psx06/system.h (added) * c/src/tests/psxtests/psx06/task.c (added) * c/src/tests/psxtests/psx06/task2.c (added) * testsuites/psxtests/psx06/init.c (added) * testsuites/psxtests/psx06/psx06.scn (added) * testsuites/psxtests/psx06/system.h (added) * testsuites/psxtests/psx06/task.c (added) * testsuites/psxtests/psx06/task2.c (added) added key test Thu, 04 Jul 1996 17:38:55 GMT Joel Sherrill [ce78b894] * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/task.c (modified) added test case for timeout using pthread_mutex_timedlock Thu, 04 Jul 1996 17:01:48 GMT Joel Sherrill [c6d15c2] * c/src/tests/psxtests/psx05/init.c (added) * c/src/tests/psxtests/psx05/psx05.scn (added) * c/src/tests/psxtests/psx05/system.h (added) * c/src/tests/psxtests/psx05/task.c (added) * testsuites/psxtests/psx05/init.c (added) * testsuites/psxtests/psx05/psx05.scn (added) * testsuites/psxtests/psx05/system.h (added) * testsuites/psxtests/psx05/task.c (added) first test cases for mutex manager pass Sat, 15 Jun 1996 19:56:19 GMT Joel Sherrill [f88310da] * c/src/tests/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/init.c (modified) initial modifications to test sigtimedwait. Thu, 13 Jun 1996 22:16:08 GMT Mark Johannes [36197e53] * c/src/tests/psxtests/psx03/init.c (added) * c/src/tests/psxtests/psx03/psx03.scn (added) * c/src/tests/psxtests/psx03/system.h (added) * c/src/tests/psxtests/psx03/task.c (added) * testsuites/psxtests/psx03/init.c (added) * testsuites/psxtests/psx03/psx03.scn (added) * testsuites/psxtests/psx03/system.h (added) * testsuites/psxtests/psx03/task.c (added) first successful run. Has test cases for a simple sigtimedwait() ... Thu, 13 Jun 1996 16:45:11 GMT Joel Sherrill [728b5a7] * c/src/tests/psxtests/include/pmacros.h (modified) * c/src/tests/psxtests/support/include/pmacros.h (modified) * testsuites/psxtests/include/pmacros.h (modified) Added a macro for "empty_line" which will go between test cases. Thu, 13 Jun 1996 16:44:46 GMT Joel Sherrill [ce0f7d95] * c/src/tests/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/init.c (modified) Added more test cases for kill() and alarm(). kill() now can unblock ... Wed, 12 Jun 1996 22:52:13 GMT Joel Sherrill [1094754f] * c/src/tests/psxtests/psx04/init.c (added) * c/src/tests/psxtests/psx04/psx04.scn (added) * c/src/tests/psxtests/psx04/system.h (added) * testsuites/psxtests/psx04/init.c (added) * testsuites/psxtests/psx04/psx04.scn (added) * testsuites/psxtests/psx04/system.h (added) new files Tue, 11 Jun 1996 20:46:13 GMT Joel Sherrill [699fe08a] * c/src/tests/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/init.c (modified) Added test case which blocks a signal, sees what signals are pending, ... Tue, 11 Jun 1996 16:04:25 GMT Joel Sherrill [fb39f19] * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/task.c (modified) modified to test pthread_kill() to self and pthread_kill() to a ... Mon, 10 Jun 1996 20:51:31 GMT Joel Sherrill [1ba858d] * c/src/tests/psxtests/psx02/init.c (added) * c/src/tests/psxtests/psx02/psx02.scn (added) * c/src/tests/psxtests/psx02/system.h (added) * c/src/tests/psxtests/psx02/task.c (added) * testsuites/psxtests/psx02/init.c (added) * testsuites/psxtests/psx02/psx02.scn (added) * testsuites/psxtests/psx02/system.h (added) * testsuites/psxtests/psx02/task.c (added) new files. This test does a basic checkout of signals with a ... Mon, 10 Jun 1996 20:49:21 GMT Joel Sherrill [1e608b0f] * c/src/tests/psxtests/include/pmacros.h (added) * c/src/tests/psxtests/support/include/pmacros.h (added) * testsuites/psxtests/include/pmacros.h (added) new file Mon, 10 Jun 1996 20:49:08 GMT Joel Sherrill [893103c] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) moved the time macros to pmacros.h. Thu, 06 Jun 1996 19:16:20 GMT Joel Sherrill [0a359a7] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added include of and fixed warnings Tue, 04 Jun 1996 19:06:30 GMT Joel Sherrill [95645a4] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test case for sched_get_priority_min, sched_get_priority_max, ... Tue, 04 Jun 1996 14:32:21 GMT Joel Sherrill [15974b65] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) added basic test cases for pthread_self and pthread_equal Mon, 03 Jun 1996 18:59:59 GMT Joel Sherrill [e984c645] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test code for return of remaining time from sleep(). Mon, 03 Jun 1996 18:28:30 GMT Joel Sherrill [e88b589] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test case for nanosleep filling in the time remaining structure. Mon, 03 Jun 1996 16:30:44 GMT Joel Sherrill [19962562] * c/src/tests/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) added test code for nanosleep and return code from sleep. Thu, 30 May 1996 20:49:16 GMT Joel Sherrill [9594cdb] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) added code to test clock and time related functionality. Wed, 29 May 1996 22:48:26 GMT Joel Sherrill [be1c11ed] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/system.h (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) tests now specify whether using posix initialization threads table ... Wed, 29 May 1996 20:56:57 GMT Joel Sherrill [2197a2e1] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) simple version of test which shows pthread_create, pthread_exit, and ... Wed, 29 May 1996 16:06:47 GMT Joel Sherrill [0252200] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) Gutted test of rtems api calls and added comments to indicate what ... Fri, 24 May 1996 22:58:15 GMT Joel Sherrill [3320e52] * c/src/tests/psxtests/psxhdrs/proc01.c (added) * c/src/tests/psxtests/psxhdrs/proc02.c (added) * c/src/tests/psxtests/psxhdrs/proc03.c (added) * c/src/tests/psxtests/psxhdrs/proc04.c (added) * c/src/tests/psxtests/psxhdrs/proc05.c (added) * c/src/tests/psxtests/psxhdrs/proc06.c (added) * c/src/tests/psxtests/psxhdrs/proc07.c (added) * c/src/tests/psxtests/psxhdrs/proc08.c (added) * c/src/tests/psxtests/psxhdrs/proc09.c (added) * c/src/tests/psxtests/psxhdrs/proc10.c (added) * c/src/tests/psxtests/psxhdrs/proc11.c (added) * c/src/tests/psxtests/psxhdrs/proc12.c (added) * c/src/tests/psxtests/psxhdrs/proc13.c (added) * c/src/tests/psxtests/psxhdrs/proc14.c (added) * testsuites/psxtests/psxhdrs/proc01.c (added) * testsuites/psxtests/psxhdrs/proc02.c (added) * testsuites/psxtests/psxhdrs/proc03.c (added) * testsuites/psxtests/psxhdrs/proc04.c (added) * testsuites/psxtests/psxhdrs/proc05.c (added) * testsuites/psxtests/psxhdrs/proc06.c (added) * testsuites/psxtests/psxhdrs/proc07.c (added) * testsuites/psxtests/psxhdrs/proc08.c (added) * testsuites/psxtests/psxhdrs/proc09.c (added) * testsuites/psxtests/psxhdrs/proc10.c (added) * testsuites/psxtests/psxhdrs/proc11.c (added) * testsuites/psxtests/psxhdrs/proc12.c (added) * testsuites/psxtests/psxhdrs/proc13.c (added) * testsuites/psxtests/psxhdrs/proc14.c (added) new file Fri, 24 May 1996 19:35:25 GMT Joel Sherrill [94bac464] * c/src/tests/psxtests/psx01/task.c (added) * testsuites/psxtests/psx01/task.c (added) new file Fri, 24 May 1996 19:33:36 GMT Joel Sherrill [86fc81e] * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/psx01.scn (added) * c/src/tests/psxtests/psx01/system.h (added) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/psx01.scn (added) * testsuites/psxtests/psx01/system.h (added) new files Fri, 24 May 1996 14:25:49 GMT Mark Johannes [abd604a] * c/src/tests/psxtests/psx01/init.c (added) * testsuites/psxtests/psx01/init.c (added) new file Fri, 24 May 1996 14:16:24 GMT Joel Sherrill [6481405e] * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) added use of sporadic server scheduling parameters Fri, 24 May 1996 14:05:02 GMT Joel Sherrill [8442b4c7] * c/src/tests/psxtests/psxhdrs/clock04.c (added) * c/src/tests/psxtests/psxhdrs/clock05.c (added) * c/src/tests/psxtests/psxhdrs/clock06.c (added) * testsuites/psxtests/psxhdrs/clock04.c (added) * testsuites/psxtests/psxhdrs/clock05.c (added) * testsuites/psxtests/psxhdrs/clock06.c (added) new files Thu, 23 May 1996 22:34:18 GMT Joel Sherrill [13fcfde] * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) clean up on DELAYTIMER_MAX Thu, 23 May 1996 22:23:44 GMT Joel Sherrill [8a318cd] * c/src/tests/psxtests/psxhdrs/timer01.c (added) * c/src/tests/psxtests/psxhdrs/timer02.c (added) * c/src/tests/psxtests/psxhdrs/timer03.c (added) * c/src/tests/psxtests/psxhdrs/timer04.c (added) * c/src/tests/psxtests/psxhdrs/timer05.c (added) * c/src/tests/psxtests/psxhdrs/timer06.c (added) * testsuites/psxtests/psxhdrs/timer01.c (added) * testsuites/psxtests/psxhdrs/timer02.c (added) * testsuites/psxtests/psxhdrs/timer03.c (added) * testsuites/psxtests/psxhdrs/timer04.c (added) * testsuites/psxtests/psxhdrs/timer05.c (added) * testsuites/psxtests/psxhdrs/timer06.c (added) new files Thu, 23 May 1996 21:51:54 GMT Joel Sherrill [3a9fc7d] * c/src/tests/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) unused variable Thu, 23 May 1996 21:51:53 GMT Joel Sherrill [73c5da6a] * c/src/tests/psxtests/psxhdrs/clock02.c (added) * c/src/tests/psxtests/psxhdrs/clock03.c (added) * c/src/tests/psxtests/psxhdrs/time08.c (added) * c/src/tests/psxtests/psxhdrs/time09.c (added) * c/src/tests/psxtests/psxhdrs/time10.c (added) * c/src/tests/psxtests/psxhdrs/time11.c (added) * c/src/tests/psxtests/psxhdrs/time12.c (added) * c/src/tests/psxtests/psxhdrs/time13.c (added) * testsuites/psxtests/psxhdrs/clock02.c (added) * testsuites/psxtests/psxhdrs/clock03.c (added) * testsuites/psxtests/psxhdrs/time08.c (added) * testsuites/psxtests/psxhdrs/time09.c (added) * testsuites/psxtests/psxhdrs/time10.c (added) * testsuites/psxtests/psxhdrs/time11.c (added) * testsuites/psxtests/psxhdrs/time12.c (added) * testsuites/psxtests/psxhdrs/time13.c (added) new files Thu, 23 May 1996 21:23:12 GMT Joel Sherrill [7303eea] * c/src/tests/psxtests/psxhdrs/time01.c (added) * c/src/tests/psxtests/psxhdrs/time02.c (added) * c/src/tests/psxtests/psxhdrs/time03.c (added) * c/src/tests/psxtests/psxhdrs/time04.c (added) * c/src/tests/psxtests/psxhdrs/time05.c (added) * c/src/tests/psxtests/psxhdrs/time06.c (added) * c/src/tests/psxtests/psxhdrs/time07.c (added) * testsuites/psxtests/psxhdrs/time01.c (added) * testsuites/psxtests/psxhdrs/time02.c (added) * testsuites/psxtests/psxhdrs/time03.c (added) * testsuites/psxtests/psxhdrs/time04.c (added) * testsuites/psxtests/psxhdrs/time05.c (added) * testsuites/psxtests/psxhdrs/time06.c (added) * testsuites/psxtests/psxhdrs/time07.c (added) new files Thu, 23 May 1996 21:10:12 GMT Joel Sherrill [1b297b4a] * c/src/tests/psxtests/psxhdrs/signal20.c (added) * c/src/tests/psxtests/psxhdrs/signal21.c (added) * c/src/tests/psxtests/psxhdrs/signal22.c (added) * testsuites/psxtests/psxhdrs/signal20.c (added) * testsuites/psxtests/psxhdrs/signal21.c (added) * testsuites/psxtests/psxhdrs/signal22.c (added) new files Thu, 23 May 1996 20:43:04 GMT Joel Sherrill [d1d7e807] * c/src/tests/psxtests/psxhdrs/signal15.c (added) * c/src/tests/psxtests/psxhdrs/signal16.c (added) * c/src/tests/psxtests/psxhdrs/signal17.c (added) * c/src/tests/psxtests/psxhdrs/signal18.c (added) * c/src/tests/psxtests/psxhdrs/signal19.c (added) * testsuites/psxtests/psxhdrs/signal15.c (added) * testsuites/psxtests/psxhdrs/signal16.c (added) * testsuites/psxtests/psxhdrs/signal17.c (added) * testsuites/psxtests/psxhdrs/signal18.c (added) * testsuites/psxtests/psxhdrs/signal19.c (added) new files Thu, 23 May 1996 20:37:09 GMT Joel Sherrill [a1c86cbe] * c/src/tests/psxtests/psxhdrs/signal11.c (added) * c/src/tests/psxtests/psxhdrs/signal12.c (added) * c/src/tests/psxtests/psxhdrs/signal13.c (added) * c/src/tests/psxtests/psxhdrs/signal14.c (added) * testsuites/psxtests/psxhdrs/signal11.c (added) * testsuites/psxtests/psxhdrs/signal12.c (added) * testsuites/psxtests/psxhdrs/signal13.c (added) * testsuites/psxtests/psxhdrs/signal14.c (added) new files Thu, 23 May 1996 19:56:49 GMT Joel Sherrill [3d135eea] * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) cleanup Thu, 23 May 1996 19:54:08 GMT Joel Sherrill [d3fed0a3] * c/src/tests/psxtests/psxhdrs/sched01.c (added) * c/src/tests/psxtests/psxhdrs/sched02.c (added) * c/src/tests/psxtests/psxhdrs/sched03.c (added) * c/src/tests/psxtests/psxhdrs/sched04.c (added) * c/src/tests/psxtests/psxhdrs/sched05.c (added) * c/src/tests/psxtests/psxhdrs/sched06.c (added) * c/src/tests/psxtests/psxhdrs/sched07.c (added) * c/src/tests/psxtests/psxhdrs/sched08.c (added) * testsuites/psxtests/psxhdrs/sched01.c (added) * testsuites/psxtests/psxhdrs/sched02.c (added) * testsuites/psxtests/psxhdrs/sched03.c (added) * testsuites/psxtests/psxhdrs/sched04.c (added) * testsuites/psxtests/psxhdrs/sched05.c (added) * testsuites/psxtests/psxhdrs/sched06.c (added) * testsuites/psxtests/psxhdrs/sched07.c (added) * testsuites/psxtests/psxhdrs/sched08.c (added) new files Thu, 23 May 1996 19:31:54 GMT Joel Sherrill [02bfc56] * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) cleanup status vs. result Thu, 23 May 1996 19:23:54 GMT Joel Sherrill [318ac69] * c/src/tests/psxtests/psxhdrs/pthread32.c (added) * c/src/tests/psxtests/psxhdrs/pthread33.c (added) * c/src/tests/psxtests/psxhdrs/pthread34.c (added) * c/src/tests/psxtests/psxhdrs/pthread35.c (added) * c/src/tests/psxtests/psxhdrs/pthread36.c (added) * testsuites/psxtests/psxhdrs/pthread32.c (added) * testsuites/psxtests/psxhdrs/pthread33.c (added) * testsuites/psxtests/psxhdrs/pthread34.c (added) * testsuites/psxtests/psxhdrs/pthread35.c (added) * testsuites/psxtests/psxhdrs/pthread36.c (added) new files Thu, 23 May 1996 19:09:21 GMT Joel Sherrill [7af3a828] * c/src/tests/psxtests/psxhdrs/pthread28.c (added) * c/src/tests/psxtests/psxhdrs/pthread29.c (added) * c/src/tests/psxtests/psxhdrs/pthread30.c (added) * c/src/tests/psxtests/psxhdrs/pthread31.c (added) * testsuites/psxtests/psxhdrs/pthread28.c (added) * testsuites/psxtests/psxhdrs/pthread29.c (added) * testsuites/psxtests/psxhdrs/pthread30.c (added) * testsuites/psxtests/psxhdrs/pthread31.c (added) new files Thu, 23 May 1996 19:04:18 GMT Joel Sherrill [f2cb4ac] * c/src/tests/psxtests/psxhdrs/key04.c (added) * c/src/tests/psxtests/psxhdrs/pthread27.c (added) * testsuites/psxtests/psxhdrs/key04.c (added) * testsuites/psxtests/psxhdrs/pthread27.c (added) new files Thu, 23 May 1996 18:55:32 GMT Joel Sherrill [57fc51c] * c/src/tests/psxtests/psxhdrs/mutex14.c (added) * c/src/tests/psxtests/psxhdrs/mutex15.c (added) * c/src/tests/psxtests/psxhdrs/mutex16.c (added) * c/src/tests/psxtests/psxhdrs/pthread24.c (added) * c/src/tests/psxtests/psxhdrs/pthread25.c (added) * c/src/tests/psxtests/psxhdrs/pthread26.c (added) * testsuites/psxtests/psxhdrs/mutex14.c (added) * testsuites/psxtests/psxhdrs/mutex15.c (added) * testsuites/psxtests/psxhdrs/mutex16.c (added) * testsuites/psxtests/psxhdrs/pthread24.c (added) * testsuites/psxtests/psxhdrs/pthread25.c (added) * testsuites/psxtests/psxhdrs/pthread26.c (added) new files Thu, 23 May 1996 18:43:59 GMT Joel Sherrill [41e7a1d8] * c/src/tests/psxtests/psxhdrs/cond08.c (added) * c/src/tests/psxtests/psxhdrs/cond09.c (added) * c/src/tests/psxtests/psxhdrs/cond10.c (added) * c/src/tests/psxtests/psxhdrs/mutex10.c (added) * c/src/tests/psxtests/psxhdrs/mutex11.c (added) * c/src/tests/psxtests/psxhdrs/mutex12.c (added) * c/src/tests/psxtests/psxhdrs/mutex13.c (added) * c/src/tests/psxtests/psxhdrs/pthread22.c (added) * c/src/tests/psxtests/psxhdrs/pthread23.c (added) * testsuites/psxtests/psxhdrs/cond08.c (added) * testsuites/psxtests/psxhdrs/cond09.c (added) * testsuites/psxtests/psxhdrs/cond10.c (added) * testsuites/psxtests/psxhdrs/mutex10.c (added) * testsuites/psxtests/psxhdrs/mutex11.c (added) * testsuites/psxtests/psxhdrs/mutex12.c (added) * testsuites/psxtests/psxhdrs/mutex13.c (added) * testsuites/psxtests/psxhdrs/pthread22.c (added) * testsuites/psxtests/psxhdrs/pthread23.c (added) new files Thu, 23 May 1996 18:08:15 GMT Joel Sherrill [9854e336] * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) updated to reflect more constants and feature macros Wed, 22 May 1996 22:39:47 GMT Joel Sherrill [2328475] * c/src/tests/psxtests/psxhdrs/clock01.c (added) * c/src/tests/psxtests/psxhdrs/cond01.c (added) * c/src/tests/psxtests/psxhdrs/cond02.c (added) * c/src/tests/psxtests/psxhdrs/cond03.c (added) * c/src/tests/psxtests/psxhdrs/cond04.c (added) * c/src/tests/psxtests/psxhdrs/cond05.c (added) * c/src/tests/psxtests/psxhdrs/cond06.c (added) * c/src/tests/psxtests/psxhdrs/cond07.c (added) * c/src/tests/psxtests/psxhdrs/key01.c (added) * c/src/tests/psxtests/psxhdrs/key02.c (added) * c/src/tests/psxtests/psxhdrs/key03.c (added) * c/src/tests/psxtests/psxhdrs/mutex01.c (added) * c/src/tests/psxtests/psxhdrs/mutex02.c (added) * c/src/tests/psxtests/psxhdrs/mutex03.c (added) * c/src/tests/psxtests/psxhdrs/mutex04.c (added) * c/src/tests/psxtests/psxhdrs/mutex05.c (added) * c/src/tests/psxtests/psxhdrs/mutex06.c (added) * c/src/tests/psxtests/psxhdrs/mutex07.c (added) * c/src/tests/psxtests/psxhdrs/mutex08.c (added) * c/src/tests/psxtests/psxhdrs/mutex09.c (added) * c/src/tests/psxtests/psxhdrs/pthread01.c (added) * c/src/tests/psxtests/psxhdrs/pthread02.c (added) * c/src/tests/psxtests/psxhdrs/pthread03.c (added) * c/src/tests/psxtests/psxhdrs/pthread04.c (added) * c/src/tests/psxtests/psxhdrs/pthread05.c (added) * c/src/tests/psxtests/psxhdrs/pthread06.c (added) * c/src/tests/psxtests/psxhdrs/pthread07.c (added) * c/src/tests/psxtests/psxhdrs/pthread08.c (added) * c/src/tests/psxtests/psxhdrs/pthread09.c (added) * c/src/tests/psxtests/psxhdrs/pthread10.c (added) * c/src/tests/psxtests/psxhdrs/pthread11.c (added) * c/src/tests/psxtests/psxhdrs/pthread12.c (added) * c/src/tests/psxtests/psxhdrs/pthread13.c (added) * c/src/tests/psxtests/psxhdrs/pthread14.c (added) * c/src/tests/psxtests/psxhdrs/pthread15.c (added) * c/src/tests/psxtests/psxhdrs/pthread16.c (added) * c/src/tests/psxtests/psxhdrs/pthread17.c (added) * c/src/tests/psxtests/psxhdrs/pthread18.c (added) * c/src/tests/psxtests/psxhdrs/pthread19.c (added) * c/src/tests/psxtests/psxhdrs/pthread20.c (added) * c/src/tests/psxtests/psxhdrs/pthread21.c (added) * c/src/tests/psxtests/psxhdrs/signal01.c (added) * c/src/tests/psxtests/psxhdrs/signal02.c (added) * c/src/tests/psxtests/psxhdrs/signal03.c (added) * c/src/tests/psxtests/psxhdrs/signal04.c (added) * c/src/tests/psxtests/psxhdrs/signal05.c (added) * c/src/tests/psxtests/psxhdrs/signal06.c (added) * c/src/tests/psxtests/psxhdrs/signal07.c (added) * c/src/tests/psxtests/psxhdrs/signal08.c (added) * c/src/tests/psxtests/psxhdrs/signal09.c (added) * c/src/tests/psxtests/psxhdrs/signal10.c (added) * testsuites/psxtests/psxhdrs/clock01.c (added) * testsuites/psxtests/psxhdrs/cond01.c (added) * testsuites/psxtests/psxhdrs/cond02.c (added) * testsuites/psxtests/psxhdrs/cond03.c (added) * testsuites/psxtests/psxhdrs/cond04.c (added) * testsuites/psxtests/psxhdrs/cond05.c (added) * testsuites/psxtests/psxhdrs/cond06.c (added) * testsuites/psxtests/psxhdrs/cond07.c (added) * testsuites/psxtests/psxhdrs/key01.c (added) * testsuites/psxtests/psxhdrs/key02.c (added) * testsuites/psxtests/psxhdrs/key03.c (added) * testsuites/psxtests/psxhdrs/mutex01.c (added) * testsuites/psxtests/psxhdrs/mutex02.c (added) * testsuites/psxtests/psxhdrs/mutex03.c (added) * testsuites/psxtests/psxhdrs/mutex04.c (added) * testsuites/psxtests/psxhdrs/mutex05.c (added) * testsuites/psxtests/psxhdrs/mutex06.c (added) * testsuites/psxtests/psxhdrs/mutex07.c (added) * testsuites/psxtests/psxhdrs/mutex08.c (added) * testsuites/psxtests/psxhdrs/mutex09.c (added) * testsuites/psxtests/psxhdrs/pthread01.c (added) * testsuites/psxtests/psxhdrs/pthread02.c (added) * testsuites/psxtests/psxhdrs/pthread03.c (added) * testsuites/psxtests/psxhdrs/pthread04.c (added) * testsuites/psxtests/psxhdrs/pthread05.c (added) * testsuites/psxtests/psxhdrs/pthread06.c (added) * testsuites/psxtests/psxhdrs/pthread07.c (added) * testsuites/psxtests/psxhdrs/pthread08.c (added) * testsuites/psxtests/psxhdrs/pthread09.c (added) * testsuites/psxtests/psxhdrs/pthread10.c (added) * testsuites/psxtests/psxhdrs/pthread11.c (added) * testsuites/psxtests/psxhdrs/pthread12.c (added) * testsuites/psxtests/psxhdrs/pthread13.c (added) * testsuites/psxtests/psxhdrs/pthread14.c (added) * testsuites/psxtests/psxhdrs/pthread15.c (added) * testsuites/psxtests/psxhdrs/pthread16.c (added) * testsuites/psxtests/psxhdrs/pthread17.c (added) * testsuites/psxtests/psxhdrs/pthread18.c (added) * testsuites/psxtests/psxhdrs/pthread19.c (added) * testsuites/psxtests/psxhdrs/pthread20.c (added) * testsuites/psxtests/psxhdrs/pthread21.c (added) * testsuites/psxtests/psxhdrs/signal01.c (added) * testsuites/psxtests/psxhdrs/signal02.c (added) * testsuites/psxtests/psxhdrs/signal03.c (added) * testsuites/psxtests/psxhdrs/signal04.c (added) * testsuites/psxtests/psxhdrs/signal05.c (added) * testsuites/psxtests/psxhdrs/signal06.c (added) * testsuites/psxtests/psxhdrs/signal07.c (added) * testsuites/psxtests/psxhdrs/signal08.c (added) * testsuites/psxtests/psxhdrs/signal09.c (added) * testsuites/psxtests/psxhdrs/signal10.c (added) created posix test suite with test of header files
