source: rtems/testsuites/mptests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @7dcc3fe   08/11/03 14:20:43 Ralf Corsepius 2003-08-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @c98849ef   05/27/03 09:40:33 Ralf Corsepius 2003-05-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @78bea14   05/27/03 07:18:07 Ralf Corsepius 2003-05-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @3c55718   03/11/03 09:06:13 Ralf Corsepius Merger from rtems-4-6-branch. 4.104.114.84.95
(edit) @ccd81b60   02/11/03 11:47:49 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9b5c258   02/11/03 11:11:33 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8730f45   10/21/02 12:19:27 Ralf Corsepius 2002-10-21 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @d822540   08/11/02 04:49:45 Ralf Corsepius 2002-08-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @116845e8   08/02/02 00:53:03 Joel Sherrill 2002-08-01 Joel Sherrill <joel@…> * Per PR47 add support … 4.104.114.84.95
(edit) @cb9b2bfc   04/16/02 13:53:23 Joel Sherrill 2002-04-14 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ed794ad   03/28/02 00:44:13 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @0897d38   11/07/01 23:04:50 Joel Sherrill 2001-11-07 Joel Sherrill <joel@…> Tracked as PR72 but … 4.104.114.84.95
(edit) @d7aecdc   10/12/01 18:47:00 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @df25c998   10/11/01 19:36:23 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @65126558   09/24/01 18:27:53 Joel Sherrill 2001-09-22 Ralf Corsepius <corsepiu@…> * mptests.am: … 4.104.114.84.95
(edit) @e242657   09/19/01 17:20:55 Joel Sherrill 2001-09-19 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @95083c0   05/10/01 13:38:37 Joel Sherrill 2001-05-10 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @feead226   11/09/00 16:43:05 Joel Sherrill 2000-11-09 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a314d3b4   11/02/00 15:49:06 Joel Sherrill 2000-11-02 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @b33e20e   10/27/00 13:32:26 Joel Sherrill 2000-10-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @5b6ea7a   09/05/00 16:05:46 Joel Sherrill 2000-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e94ad1fe   08/10/00 13:24:00 Joel Sherrill Adding ChangeLogs?. 4.104.114.84.95
(edit) @b8a30d07   07/13/00 15:05:38 Joel Sherrill Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8fbdf07   01/31/00 15:22:23 Joel Sherrill Patch rtems-rc-20000118-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @369ef189   12/21/99 15:00:49 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @116e54ad   11/30/99 14:03:29 Joel Sherrill Uncommitted remains of a previous patch from Ralf Corsepius … 4.104.114.84.95
(edit) @1d9a2fc   11/29/99 15:45:11 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @c4ea5efc   11/24/99 14:19:26 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @908436c1   08/10/99 15:38:09 Joel Sherrill New configuration files added by patch from Ralf Corsepius … 4.104.114.84.95
(edit) @9a993ed5   04/27/98 13:51:23 Joel Sherrill Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory … 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @be1c11ed   05/29/96 22:48:26 Joel Sherrill tests now specify whether using posix initialization threads table or … 4.104.114.84.95
(edit) @8b2ecf85   05/23/96 15:37:38 Joel Sherrill updates from Tony Bennett 4.104.114.84.95
(edit) @5c491aef   12/20/95 15:39:19 Joel Sherrill changes remerged after lost in disk crash -- recovered from snapshot, … 4.104.114.84.95
(edit) @8bdcfc4   12/19/95 20:26:32 Joel Sherrill changes remerged after disk crash -- history lost 4.104.114.84.95
(edit) @2122a0b   09/19/95 21:44:33 Joel Sherrill Modifications from Tony Bennett accepted to tune this test a little. 4.104.114.84.95
(edit) @38ffa0c   09/19/95 18:32:18 Joel Sherrill Incorporated the submission from John S. Gwynne … 4.104.114.84.95
(edit) @3652ad35   09/19/95 14:53:29 Joel Sherrill Minor bug fixes to get all targets compilable and running. The single … 4.104.114.84.95
(edit) @3a4ae6c   09/11/95 19:35:39 Joel Sherrill The word "RTEMS" almost completely removed from the core. … 4.104.114.84.95
(edit) @7f6a24ab   08/28/95 15:30:29 Joel Sherrill Added unused priority ceiling parameter to rtems_semaphore_create. … 4.104.114.84.95
(edit) @3235ad9   08/23/95 19:30:23 Joel Sherrill Support for variable length names added to Object Handler. This … 4.104.114.84.95
(edit) @4b374f36   08/17/95 19:36:43 Joel Sherrill maximum number of messages removed and include statement cleanup 4.104.114.84.95
(edit) @891e9c3   08/11/95 14:35:01 Joel Sherrill added alignment attribute for array used as partition memory. 4.104.114.84.95
(edit) @637df35   07/12/95 19:47:25 Joel Sherrill Ada95, gnat, go32 4.104.114.84.95
(edit) @497428a2   05/30/95 19:42:36 Joel Sherrill cpu/*types.h added and successfully compiled. IDLE task priority … 4.104.114.84.95
(edit) @88d594a   05/24/95 21:39:42 Joel Sherrill Fully tested on all in-house targets 4.104.114.84.95
(add) @ac7d5ef0   05/11/95 17:39:37 Joel Sherrill Initial revision 4.104.114.84.95
