Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/testsuites/libtests
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @979d95e   09/01/14 08:08:12 Sebastian Huber libtests/capture01: Force error if SMP enabled This prevents infinite … 4.115
(edit) @4030ccc   09/01/14 09:01:04 Sebastian Huber tests: Add documentation 4.115
(edit) @60fe374   08/03/14 11:02:58 Sebastian Huber rbtree: Add and use RBTree_Compare_result 4.115
(edit) @648c86c   07/14/14 18:12:31 Jennifer Averett capture01: Add include of assert.h. 4.115
(edit) @82d137ae   04/23/14 20:08:26 Jennifer Averett capture01: New non-interactive test for capture engine. 4.115
(edit) @93726e5   07/09/14 13:44:13 Sebastian Huber termios: Add rtems_termios_set_best_baud() 4.115
(edit) @a0fb29f   07/09/14 09:52:56 Sebastian Huber termios: PR1279: Use first open status 4.115
(edit) @32fc6a3   07/09/14 09:15:53 Sebastian Huber termios: PR1279: Use set attributes status 4.115
(edit) @ef8c00bc   06/27/14 11:10:15 Sebastian Huber termios: PR2153: New low-level device API Add a new low-level device … 4.115
(edit) @3324383c   05/05/14 14:47:30 Joel Sherrill testsuites: Remove BSP_SMALL_MEMORY 4.115
(edit) @1461b648   05/04/14 22:12:52 Chris Johns testsuite: Add a per BSP test check for tests not to build. Provide a … 4.115
(edit) @a44fa5a7   04/21/14 14:08:48 Joel Sherrill utf8proc01: Honor BSP_SMALL_MEMORY 4.115
(edit) @faa4e4c0   04/21/14 14:08:34 Joel Sherrill flashdisk01: Honor BSP_SMALL_MEMORY 4.115
(edit) @263f4bec   04/07/14 12:50:37 Sebastian Huber score: Statically initialize IO manager This simplifies the RTEMS … 4.115
(edit) @3ccfd98b   04/01/14 07:21:05 Sebastian Huber libtests/newlib01: New test 4.115
(edit) @ecd8c8ad   03/28/14 10:58:20 Sebastian Huber tests/fatal: Fix test names 4.115
(edit) @5c0c0cf   03/27/14 13:23:21 Christian.Mauderer privateenv: Use POSIX keys instead of task variables. 4.115
(edit) @8c26e798   03/25/14 15:45:08 Sebastian Huber tests: Produce proper begin/end messages 4.115
(edit) @5ef9f23   03/21/14 13:29:55 Christian.Mauderer libcsupport: Use POSIX keys for GXX key functions With this patch C++ … 4.115
(edit) @9d9df8b   03/21/14 11:07:28 Christian.Mauderer libcsupport: Remove unused gxx-wrapper function. The … 4.115
(edit) @c499856   03/20/14 21:10:47 Chris Johns Change all references of rtems.com to rtems.org. 4.115
(edit) @f8b2eb03   03/17/14 07:10:40 Sebastian Huber tests/libtests: Use <rtems/test.h> 4.115
(edit) @ae88aa7   03/10/14 07:15:37 Sebastian Huber sapi: Use one SMP lock for all chains This partially reverts commit … 4.115
(edit) @a418b2f   03/03/14 07:38:10 Sebastian Huber libnetworking: Typo 4.115
(edit) @92f50c3   02/17/14 08:47:12 Sebastian Huber score: Add SYSTEM_STATE_TERMINATED Merge systems states … 4.115
(edit) @a49bc35   01/28/14 10:49:57 Sebastian Huber score: Add _Heap_Size_with_overhead() 4.115
(edit) @e1b96b8   02/03/14 12:43:21 Sebastian Huber libtests/block11: Use custom device driver 4.115
(edit) @e83be28   01/09/14 23:57:08 Chris Johns testsuite/rtems++: Output format change. Alter the output to avoid … 4.115
(edit) @46123cf2   01/09/14 15:41:44 cynt6007 libtests: Add contents to rbheap and stackchk documentation files 4.115
(edit) @3096f5c9   12/06/13 22:13:27 Daniel Ramirez libtests/termios01: Add tests for cfsetspeed() and cfmakeraw() 4.115
(edit) @8950204   12/19/13 04:58:53 Daniel Ramirez libtests/uid01: Fix Copyright information 4.115
(edit) @7cf81ba4   12/19/13 04:58:53 Daniel Ramirez libtests: added test to confirm patch fixes bug 4.115
(edit) @73a7713   01/08/14 18:48:37 cynt6007 fstests and libtests: Add contents to multiple documentation files 4.115
(edit) @d2d4a8f9   12/25/13 12:06:19 mjuvekar0 utf8proc1/spedgsched01: minor fixes in test document files 4.115
(edit) @b5d2d4a   12/03/13 23:42:26 Nick Withers Update to Mongoose 3.9 at the last point before the MIT -> GPL license … 4.115
(edit) @4ea97d24   11/19/13 15:21:54 Sebastian Huber score/rbtree: Remove "unprotected" from API 4.115
(edit) @435f2c0   11/15/13 13:11:51 Sebastian Huber libtests/malloctest: Fix heap extend test case 4.115
(edit) @a136fb6   11/15/13 17:53:36 Joel Sherrill testsuites: Add missing .scn files 4.115
(edit) @9e1d605   10/16/13 13:18:30 Sebastian Huber libtests/flashdisk01: Include missing header file 4.115
(edit) @d9998172   09/17/13 11:48:30 Sebastian Huber libtests/termios04: Avoid NULL pointer access 4.115
(edit) @390e987e   09/16/13 08:43:30 Sebastian Huber libblock: PR2145: Limit maximum read-ahead blocks This helps to … 4.115
(edit) @1215fd4   08/26/13 13:14:33 Sebastian Huber sapi: SMP support for chains Add ISR lock to chain control for proper … 4.115
(edit) @38ec8af   08/23/13 07:20:23 Sebastian Huber libtests/flashdisk01: Update screen file 4.115
(edit) @ae75429   08/06/13 14:10:26 Sebastian Huber PR766: Delete RTEMS_VIOLATE_KERNEL_VISIBILITY 4.115
(edit) @ede5a2a   07/26/13 12:00:00 Sebastian Huber libtests/malloc04: Fixes for RTEMS_DEBUG 2nd try 4.115
(edit) @88c74ab   07/25/13 13:10:11 Sebastian Huber score: Merge tod implementation into one file Delete … 4.115
(edit) @044f317a   07/24/13 18:59:06 Sebastian Huber libtests/malloc04: Fixes for RTEMS_DEBUG 4.115
(edit) @39046f7   07/24/13 09:09:23 Sebastian Huber score: Merge sysstate API into one file 4.115
(edit) @b7cf09c3   07/23/13 19:48:18 Sebastian Huber libtests/malloctest: Fixes for RTEMS_DEBUG 4.115
(edit) @e6f7f81   07/23/13 14:50:51 Sebastian Huber score: Create heap implementation header Move implementation specific … 4.115
(edit) @7660e8b3   07/23/13 11:32:58 Sebastian Huber Include missing <string.h> 4.115
(edit) @93fb3cb0   07/23/13 08:38:11 Sebastian Huber score: Create rbtree implementation header Move implementation … 4.115
(edit) @d7ce33f1   07/22/13 07:16:58 Sebastian Huber testsuites: Use _Thread_Get_executing() 4.115
(edit) @a9127a2e   07/18/13 13:55:46 Sebastian Huber testsuites: Include missing header files 4.115
(edit) @0dd262d3   07/18/13 07:42:46 Sebastian Huber libtests/gxx01: Avoid random memory read/write 4.115
(edit) @2ee8b15   02/26/13 12:25:46 ralf.kirchner libtests: Add new test: utf8proc01 utf8proc is a library for … 4.115
(edit) @9deed9ed   05/10/13 09:58:39 Sebastian Huber libtests/malloc04: Prevent compiler optimizations 4.115
(edit) @85387db5   05/03/13 15:28:48 Sebastian Huber libtests/malloc04: Adjust for new sbrk() support 4.115
(edit) @dfd1508   04/23/13 12:30:52 Sebastian Huber libtests/exit02: New test 4.115
(edit) @49120e8   04/23/13 12:30:35 Sebastian Huber libtests/exit01: New test 4.115
(edit) @f205c18f   04/17/13 10:19:33 Ralf Corsepius Use uint32_t instead of long. Use unsigned defines (Prevent overflows … 4.115
(edit) @a53045fd   04/08/13 07:47:54 Sebastian Huber libtests/flashdisk01: Disable for small memory BSP 4.115
(edit) @fad2d38   03/08/13 20:55:06 Gedare Bloom RTEMS: Delete ChangeLog? files. This commit deletes all RTEMS … 4.115
(edit) @b63c8f9   01/28/13 09:23:28 Sebastian Huber ftpfs: Fix SIZE command handling It is invalid to issue a SIZE … 4.115
(edit) @33bd2efb   01/27/13 12:46:40 Sebastian Huber testsuites: Fix prototypes 4.115
(edit) @fe62f3a   12/22/12 16:29:15 Sebastian Huber libtests/rbheap01: Add test cases 4.115
(edit) @aaee3a9   12/22/12 15:38:45 Sebastian Huber libtests/malloctest: Add test case 4.115
(edit) @d8efe3d   12/22/12 15:28:26 Sebastian Huber libtests/malloctest: Add test case 4.115
(edit) @c40f36b0   12/16/12 20:34:13 Sebastian Huber libtests/md501: Use test cases of RFC 2202 4.115
(edit) @f95d74a4   12/16/12 16:33:57 Sebastian Huber libtests/md501: New test 4.115
(edit) @b0da5796   12/12/12 08:25:03 Sebastian Huber termios: Implement tcflush() New IO control RTEMS_IO_TCFLUSH. 4.115
(edit) @ad13ebe   12/12/12 08:36:02 Sebastian Huber termios: Fix tcflow() error status 4.115
(edit) @7fab7fc   12/05/12 09:54:17 ralf.kirchner libblock: Add sparse disk 4.115
(edit) @fe0f24e   11/21/12 14:27:43 Sebastian Huber ftpfs: Use SIZE command 4.115
(edit) @3fbcadf   11/16/12 13:17:31 Sebastian Huber libnetworking: Use rtems_clock_get_uptime_seconds This reduces the … 4.115
(edit) @a12f7e9   11/14/12 14:10:46 Sebastian Huber score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER 4.115
(edit) @dc0eed7   11/14/12 10:51:45 Sebastian Huber testsuites: Include <bsp.h> Include <bsp.h> for proper BSP specific … 4.115
(edit) @3cd79b0   11/07/12 12:48:31 Sebastian Huber libtests/devfs03: Initialize nodes 4.115
(edit) @9f0a68c   10/31/12 10:54:39 Sebastian Huber libblock: Block device transfer request API change Add and use … 4.115
(edit) @9dffa384   10/26/12 19:31:45 Sebastian Huber libblock: rtems_bdbuf_set_block_size() API change The set block size … 4.115
(edit) @0d68d8f2   10/26/12 19:29:36 Sebastian Huber libtests/block16: New test 4.115
(edit) @47a3cd8   08/09/12 14:48:00 Sebastian Huber score: Work area initialization API change The work areas (RTEMS work … 4.115
(edit) @e4278f2   10/12/12 15:02:30 Sebastian Huber score: Append to free list in _Heap_Extend() 4.115
(edit) @6ccfe72   08/09/12 08:17:42 Sebastian Huber score: Change _Heap_Extend() API The _Heap_Extend() has now the same … 4.115
(edit) @e693b9ed   10/15/12 02:39:21 Ralf Corsepius Remove unused var "sc". 4.115
(edit) @b9e9dab   10/15/12 02:39:04 Ralf Corsepius Remove unused var "service". Move #include "test-http-client.h" after … 4.115
(edit) @2d72c198   10/15/12 02:37:40 Ralf Corsepius Move extern "C" after std-header inclusions. 4.115
(edit) @cb7b57e1   10/03/12 16:09:32 Joel Sherrill mghttpd: Requires POSIX to build server and tests Formerly, mghttpd … 4.115
(edit) @57e922c7   08/06/12 17:04:24 Gedare Bloom Revert "Add config.h.in." This reverts commit … 4.115
(edit) @bb2b825   07/19/12 13:47:55 Ralf Corsepius Require automake-1.12.2. 4.115
(edit) @0f77281   07/19/12 13:44:32 Ralf Corsepius Require autoconf-2.69. 4.115
(edit) @c8615dcf   07/17/12 08:45:17 Sebastian Huber libtests/termios01: Use greedy allocation API 4.115
(edit) @317ee8d   07/17/12 08:19:16 Sebastian Huber score: Change greedy allocation API 4.115
(edit) @0eb5bfba   07/03/12 08:42:17 christian.mauderer libtests/mghttpd01: New test 4.115
(edit) @71092f7   07/02/12 14:58:01 Sebastian Huber libblock: Fix read-ahead trigger and next update The previous version … 4.115
(edit) @f29d969   07/02/12 14:06:10 Sebastian Huber libblock: Fix read-ahead trigger and next update 4.115
(edit) @f12249f   07/02/12 13:08:08 Sebastian Huber libblock: Fix continuous blocks write request 4.115
(edit) @6a03786d   07/02/12 13:08:24 Sebastian Huber libtests/block06: Increase stack size 4.115
(edit) @9f527308   06/12/12 07:46:09 Sebastian Huber libblock: Add block device statistics 4.115
(edit) @1f7b5b0   06/04/12 15:04:49 Sebastian Huber libtests/block13: Add const qualifier 4.115
