@2d48456
08/21/15 03:24:17 |
Sebastian Huber |
rbheap: Drop direction from _RBTree_Iterate()
5
@08135c85
07/23/15 07:00:31 |
Sebastian Huber |
i2c: Fix return status of i2c dev read/write
5
@5f31bbe
06/25/15 12:22:31 |
Sebastian Huber |
libmisc: Simplify <rtems/stackchk.h>
Drop the <rtems/score/percpu.h> …
4.115
@cdf30f05
06/19/15 12:57:44 |
Sebastian Huber |
rtems: Add rtems_interrupt_local_disable|enable()
Add …
4.115
@9d0913d1
05/27/15 10:48:22 |
Sebastian Huber |
libtests/i2c01: Avoid stack overflow
4.115
@7790fec1
03/31/15 06:04:35 |
Chris Johns |
testsuites: dl02 needs an FPU init task.
4.115
@59efbdd4
03/22/15 19:59:52 |
Joel Sherrill |
malloctest/init.c: Fix use uninitialized warning
4.115
@3ac68119
03/06/15 17:41:49 |
Gedare Bloom |
cpukit: deprecate notepads
Deprecate Classic API Notepads. Mark …
4.115
@19799fb
03/09/15 12:52:49 |
Sebastian Huber |
libtests/stringto01: Fix for GCC 5.0
4.115
@19a1f6b
03/06/15 14:34:03 |
Joel Sherrill |
Temporarily disable libdl for h8300
The h8300 gets a linking error …
4.115
@a726ca64
03/05/15 23:33:38 |
Joel Sherrill |
Temporarily disable libdl for lm32
There is a GCC ICE when building …
4.115
@1d061ee
03/04/15 21:13:24 |
Joel Sherrill |
Temporarily disable libdl for v850
There is an issue linking dl0* …
4.115
@9bef63e
03/04/15 21:10:42 |
Joel Sherrill |
Temporarily disable libdl for bfin
4.115
@461a930
03/04/15 20:53:36 |
Joel Sherrill |
capture01: Update screen file
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@cf36b70
12/31/14 09:56:05 |
Sebastian Huber |
IMFS: Replace node union with individual struct
This reduces the …
4.115
@f87ede5
01/15/15 13:13:19 |
Sebastian Huber |
libnetworking: Fix close of active sockets
Send a special event to …
4.115
@8a7048a
01/19/15 12:53:51 |
Marcos Diaz |
Fixed dl01 and dl02 makefiles
4.115
@b3ed66a
12/22/14 06:15:49 |
Sebastian Huber |
libtests/crypt01: Increase stack size
4.115
@a0b1b5ed
12/15/14 13:19:43 |
Sebastian Huber |
Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
This define was …
4.115
@f42d429
12/15/14 02:26:31 |
Nick Withers |
Enable WebSocket? support in the Mongoose HTTP server
4.115
@9d9c426
03/07/14 03:23:30 |
Nick Withers |
Teach rtems_tarfs_load() about symlinks
4.115
@f3730d56
12/08/14 08:47:58 |
Sebastian Huber |
libtests/complex: Avoid multiple definitions
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@e870941
12/04/14 08:38:27 |
Sebastian Huber |
libmisc: More useful default configuration
The dummy.c was a de-facto …
4.115
@f54e503
12/02/14 09:35:13 |
Sebastian Huber |
libtests: Omit libdl tests if no RTEMS tools
4.115
@e7e92da
06/04/14 14:02:11 |
Daniel Hellstrom |
DEVFS04: make test work on LEON3-FT GR712RC
The LEON3 BSP have …
4.115
@80d99aa
12/01/14 07:20:55 |
Sebastian Huber |
libtests/complex,math: Prevent optimizations
For constant arguments …
4.115
@01557b0
11/27/14 10:44:48 |
Sebastian Huber |
libcsupport: Delete malloc statistics
Use the heap handler statistics …
4.115
@11b3ba1
10/03/14 13:47:14 |
Jennifer Averett |
capture01: Use capture engine print methods.
4.115
@6570876
11/23/14 16:40:14 |
Joel Sherrill |
termio05: Remove unreferenced files
The functionality was …
4.115
@163519a0
11/19/14 19:57:37 |
Joel Sherrill |
libtests/malloctest/init.c: Fix warning
posix_memalign() is …
4.115
@a634feb
11/20/14 08:15:19 |
Sebastian Huber |
dl01,dl02: Avoid non-runnable $(EXEEXT) files
4.115
@e02d5dd9
11/17/14 12:35:58 |
Sebastian Huber |
Ensure security of default user environment
4.115
@fa028bb
11/17/14 10:55:27 |
Sebastian Huber |
shell: Do chroot() after successful login
4.115
@065d72ce
11/17/14 09:19:00 |
Sebastian Huber |
shell: Get supplementary group IDs in login check
4.115
@ffa71f1
11/17/14 06:53:01 |
Sebastian Huber |
libcsupport: Implement getgroups()
4.115
@acf9a8d
11/14/14 13:31:54 |
Sebastian Huber |
shell: Use crypt_r() in rtems_shell_login_check()
Use '*" to disable …
4.115
@6935428
11/14/14 10:30:50 |
Sebastian Huber |
libcsupport: Avoid TOCTOU and format errors
4.115
@4466321
11/13/14 14:13:24 |
Sebastian Huber |
Add crypt_r(), etc.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), …
4.115
@1bcd0378
11/13/14 12:18:24 |
Sebastian Huber |
Add SHA256 and SHA512 support
4.115
@0510cfd8
11/11/14 11:41:58 |
Sebastian Huber |
Add NXP PCA9548A 8-channel switch I2C driver
4.115
@67ac69fc
11/07/14 12:50:01 |
Sebastian Huber |
Add NXP PCA9535 16-bit GPIO I2C driver
4.115
@cce46780
11/07/14 12:49:29 |
Sebastian Huber |
Add generic EEPROM I2C device driver
4.115
@41c5f1b7
11/07/14 12:47:39 |
Sebastian Huber |
Add I2C driver framework
This I2C driver framework has some major …
4.115
@3eade710
11/20/14 07:52:50 |
Sebastian Huber |
libtests/top: End test after some time if no input
4.115
@f98abbe
11/06/14 02:08:48 |
Chris Johns |
libdl: Disable building libdl for the NIOS2. No relocation support.
4.115
@540b7b41
11/04/14 05:31:50 |
Chris Johns |
libtests: Add libdl test dl02.
Loads 2 interdependent ELF object files.
4.115
@d52c9e4d
11/04/14 05:30:08 |
Chris Johns |
libtests: Update dl01 documentation.
4.115
@c58f90b
11/03/14 00:54:55 |
Joel Sherrill |
dl01/dl-load.c: Add missing const
4.115
@ae5fe7e6
10/27/14 01:09:41 |
Chris Johns |
cpukit: Add libdl with the Runtime Loader (RTL) code.
This is a merge …
4.115
@410bcdfe
09/29/14 19:31:18 |
Jennifer Averett |
top: Add new test.
4.115
@254b7db0
09/08/14 14:47:13 |
Jennifer Averett |
capture01: Remove capture task tracking.
This involved adding a new …
4.115
@7fd5e89
10/07/14 14:28:04 |
Sebastian Huber |
termios: Partially hide rtems_termios_tty
Move interrupt lock to …
4.115
@a830cb8
10/07/14 14:27:51 |
Sebastian Huber |
termios: Separate flow control from normal handler
4.115
@5cb5342
09/01/14 11:28:30 |
Sebastian Huber |
libtests/capture01: Fix test name
4.115
@979d95e
09/01/14 08:08:12 |
Sebastian Huber |
libtests/capture01: Force error if SMP enabled
This prevents infinite …
4.115
@4030ccc
09/01/14 09:01:04 |
Sebastian Huber |
tests: Add documentation
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@648c86c
07/14/14 18:12:31 |
Jennifer Averett |
capture01: Add include of assert.h.
4.115
@82d137ae
04/23/14 20:08:26 |
Jennifer Averett |
capture01: New non-interactive test for capture engine.
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
@ef8c00bc
06/27/14 11:10:15 |
Sebastian Huber |
termios: PR2153: New low-level device API
Add a new low-level device …
4.115
@3324383c
05/05/14 14:47:30 |
Joel Sherrill |
testsuites: Remove BSP_SMALL_MEMORY
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@a44fa5a7
04/21/14 14:08:48 |
Joel Sherrill |
utf8proc01: Honor BSP_SMALL_MEMORY
4.115
@faa4e4c0
04/21/14 14:08:34 |
Joel Sherrill |
flashdisk01: Honor BSP_SMALL_MEMORY
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@3ccfd98b
04/01/14 07:21:05 |
Sebastian Huber |
libtests/newlib01: New test
4.115
@ecd8c8ad
03/28/14 10:58:20 |
Sebastian Huber |
tests/fatal: Fix test names
4.115
@5c0c0cf
03/27/14 13:23:21 |
Christian.Mauderer |
privateenv: Use POSIX keys instead of task variables.
4.115
@8c26e798
03/25/14 15:45:08 |
Sebastian Huber |
tests: Produce proper begin/end messages
4.115
@5ef9f23
03/21/14 13:29:55 |
libcsupport: Use POSIX keys for GXX key functions
With this patch C++ …
4.115
@9d9df8b
03/21/14 11:07:28 |
libcsupport: Remove unused gxx-wrapper function.
The …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@f8b2eb03
03/17/14 07:10:40 |
Sebastian Huber |
tests/libtests: Use <rtems/test.h>
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@a418b2f
03/03/14 07:38:10 |
Sebastian Huber |
libnetworking: Typo
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@a49bc35
01/28/14 10:49:57 |
Sebastian Huber |
score: Add _Heap_Size_with_overhead()
4.115
@e1b96b8
02/03/14 12:43:21 |
Sebastian Huber |
libtests/block11: Use custom device driver
4.115
@e83be28
01/09/14 23:57:08 |
Chris Johns |
testsuite/rtems++: Output format change.
Alter the output to avoid …
4.115
@46123cf2
01/09/14 15:41:44 |
cynt6007 |
libtests: Add contents to rbheap and stackchk documentation files
4.115
@3096f5c9
12/06/13 22:13:27 |
Daniel Ramirez |
libtests/termios01: Add tests for cfsetspeed() and cfmakeraw()
4.115
@8950204
12/19/13 04:58:53 |
Daniel Ramirez |
libtests/uid01: Fix Copyright information
4.115
@7cf81ba4
12/19/13 04:58:53 |
Daniel Ramirez |
libtests: added test to confirm patch fixes bug
4.115
@73a7713
01/08/14 18:48:37 |
cynt6007 |
fstests and libtests: Add contents to multiple documentation files
4.115
@d2d4a8f9
12/25/13 12:06:19 |
mjuvekar0 |
utf8proc1/spedgsched01: minor fixes in test document files
4.115
@b5d2d4a
12/03/13 23:42:26 |
Nick Withers |
Update to Mongoose 3.9 at the last point before the MIT -> GPL license …
4.115
@4ea97d24
11/19/13 15:21:54 |
Sebastian Huber |
score/rbtree: Remove "unprotected" from API
4.115
@435f2c0
11/15/13 13:11:51 |
Sebastian Huber |
libtests/malloctest: Fix heap extend test case
4.115
@a136fb6
11/15/13 17:53:36 |
Joel Sherrill |
testsuites: Add missing .scn files
4.115
@9e1d605
10/16/13 13:18:30 |
Sebastian Huber |
libtests/flashdisk01: Include missing header file
4.115
@d9998172
09/17/13 11:48:30 |
Sebastian Huber |
libtests/termios04: Avoid NULL pointer access
4.115
@390e987e
09/16/13 08:43:30 |
Sebastian Huber |
libblock: PR2145: Limit maximum read-ahead blocks
This helps to …
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@38ec8af
08/23/13 07:20:23 |
Sebastian Huber |
libtests/flashdisk01: Update screen file
4.115
