# # ChangeLog for testsuites/itrontests in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 21:07:43 Mon, 15 Nov 1999 21:19:58 GMT Jennifer Averett [0f88857] * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/dormant.c (moved) * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask02/dormant.c (added) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/system.h (modified) + Changed preempt routine into two dummy tasks one that is in dormant ... Fri, 12 Nov 1999 22:00:10 GMT Joel Sherrill [afb11f8] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) + Modified calls to use TSK_SLF for calls to self. + Modified calls ... Fri, 12 Nov 1999 21:27:42 GMT Joel Sherrill [624d7ca4] * c/src/tests/itrontests/itronhello/itronhello.doc (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itronhello/itronhello.doc (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) + Added comments on paths tested. Fri, 12 Nov 1999 21:26:54 GMT Joel Sherrill [e8c902c] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) + Added check for priority over 256. + Modified output to correctly ... Fri, 12 Nov 1999 21:24:56 GMT Joel Sherrill [8ed3125d] * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) Added comments for path's tested. Fri, 12 Nov 1999 14:51:03 GMT Joel Sherrill [f4771656] * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask04/init.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.scn (modified) * c/src/tests/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/itrontask04.scn (modified) * testsuites/itrontests/itrontask04/task3.c (modified) Test name changed to reflect placement after merger. Fri, 12 Nov 1999 14:50:42 GMT Joel Sherrill [ec0b5ce] * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/itrontask02.scn (modified) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/itrontask02.scn (modified) Test name changed to reflect placement after merger. Changed output ... Fri, 12 Nov 1999 14:49:47 GMT Joel Sherrill [3136f5c9] * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/itrontask01.scn (modified) * c/src/tests/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/itrontask01.scn (modified) * testsuites/itrontests/itrontask01/task1.c (modified) Test name changed to reflect placement after merger. Increased ... Fri, 12 Nov 1999 13:45:39 GMT Joel Sherrill [6977b38] * c/src/tests/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/init.c (modified) Enabled after merging message buffer code. Wed, 10 Nov 1999 22:15:42 GMT Joel Sherrill [713b2ea] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/init.c (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/itrontask02.doc (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/itrontask02.doc (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/system.h (modified) General cleanup. Test documentation improved. The message buffer ... Wed, 10 Nov 1999 14:19:55 GMT Joel Sherrill [442d0478] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.in (added) * c/src/tests/itrontests/itronmbf01/Makefile.in (added) * c/src/tests/itrontests/itronsem01/Makefile.in (added) * c/src/tests/itrontests/itrontask01/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask04/Makefile.in (modified) * c/src/tests/itrontests/itrontime01/Makefile.in (added) * c/src/tests/itrontests/itrontime01/init.c (added) * c/src/tests/itrontests/itrontime01/itrontime01.doc (added) * c/src/tests/itrontests/itrontime01/itrontime01.scn (added) * c/src/tests/itrontests/itrontime01/system.h (added) * testsuites/itrontests/Makefile.am (modified) * testsuites/itrontests/itrontime01/init.c (added) * testsuites/itrontests/itrontime01/itrontime01.doc (added) * testsuites/itrontests/itrontime01/itrontime01.scn (added) * testsuites/itrontests/itrontime01/system.h (added) Combination of committing some new files which had been overlooked ... Tue, 09 Nov 1999 23:28:04 GMT Joel Sherrill [bab5ba44] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/configure.in (modified) * testsuites/itrontests/Makefile.am (modified) Added more tasking tests. Tue, 09 Nov 1999 23:27:05 GMT Joel Sherrill [e099180] * c/src/tests/itrontests/itronhello/itronhello.doc (added) * c/src/tests/itrontests/itronhello/itronhello.scn (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.doc (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.scn (added) * c/src/tests/itrontests/itronsem01/itronsem01.doc (added) * c/src/tests/itrontests/itronsem01/itronsem01.scn (added) * c/src/tests/itrontests/itrontask01/Makefile.in (added) * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (added) * c/src/tests/itrontests/itrontask01/itrontask01.scn (added) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask01/task1.c (added) * c/src/tests/itrontests/itrontask02/Makefile.in (added) * c/src/tests/itrontests/itrontask02/init.c (added) * c/src/tests/itrontests/itrontask02/itrontask02.doc (added) * c/src/tests/itrontests/itrontask02/itrontask02.scn (added) * c/src/tests/itrontests/itrontask02/preempt.c (added) * c/src/tests/itrontests/itrontask02/system.h (added) * c/src/tests/itrontests/itrontask03/Makefile.in (added) * c/src/tests/itrontests/itrontask03/init.c (added) * c/src/tests/itrontests/itrontask03/itrontask03.doc (added) * c/src/tests/itrontests/itrontask03/itrontask03.scn (added) * c/src/tests/itrontests/itrontask03/preempt.c (added) * c/src/tests/itrontests/itrontask03/spinit.c (added) * c/src/tests/itrontests/itrontask03/system.h (added) * c/src/tests/itrontests/itrontask03/task1.c (added) * c/src/tests/itrontests/itrontask03/task2.c (added) * c/src/tests/itrontests/itrontask03/task3.c (added) * c/src/tests/itrontests/itrontask04/Makefile.in (added) * c/src/tests/itrontests/itrontask04/init.c (added) * c/src/tests/itrontests/itrontask04/itrontask04.doc (added) * c/src/tests/itrontests/itrontask04/itrontask04.scn (added) * c/src/tests/itrontests/itrontask04/system.h (added) * c/src/tests/itrontests/itrontask04/task1.c (added) * c/src/tests/itrontests/itrontask04/task2.c (added) * c/src/tests/itrontests/itrontask04/task3.c (added) * testsuites/itrontests/itronhello/itronhello.doc (added) * testsuites/itrontests/itronhello/itronhello.scn (added) * testsuites/itrontests/itronmbf01/itronmbf01.doc (added) * testsuites/itrontests/itronmbf01/itronmbf01.scn (added) * testsuites/itrontests/itronsem01/itronsem01.doc (added) * testsuites/itrontests/itronsem01/itronsem01.scn (added) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (added) * testsuites/itrontests/itrontask01/itrontask01.scn (added) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (added) * testsuites/itrontests/itrontask02/init.c (added) * testsuites/itrontests/itrontask02/itrontask02.doc (added) * testsuites/itrontests/itrontask02/itrontask02.scn (added) * testsuites/itrontests/itrontask02/system.h (added) * testsuites/itrontests/itrontask03/init.c (added) * testsuites/itrontests/itrontask03/itrontask03.doc (added) * testsuites/itrontests/itrontask03/itrontask03.scn (added) * testsuites/itrontests/itrontask03/preempt.c (added) * testsuites/itrontests/itrontask03/system.h (added) * testsuites/itrontests/itrontask03/task1.c (added) * testsuites/itrontests/itrontask03/task2.c (added) * testsuites/itrontests/itrontask03/task3.c (added) * testsuites/itrontests/itrontask04/init.c (added) * testsuites/itrontests/itrontask04/itrontask04.doc (added) * testsuites/itrontests/itrontask04/itrontask04.scn (added) * testsuites/itrontests/itrontask04/system.h (added) * testsuites/itrontests/itrontask04/task1.c (added) * testsuites/itrontests/itrontask04/task2.c (added) * testsuites/itrontests/itrontask04/task3.c (added) Merged tests from Task group. Tue, 09 Nov 1999 22:07:23 GMT Joel Sherrill [352c9b2] * c/src/exec/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/Makefile.am (added) * c/src/exec/itron/configure.in (added) * c/src/exec/itron/include/Makefile.am (added) * c/src/exec/itron/include/itron.h (added) * c/src/exec/itron/include/itronsys/Makefile.am (added) * c/src/exec/itron/include/itronsys/README (added) * c/src/exec/itron/include/itronsys/eventflags.h (added) * c/src/exec/itron/include/itronsys/fmempool.h (added) * c/src/exec/itron/include/itronsys/intr.h (added) * c/src/exec/itron/include/itronsys/mbox.h (added) * c/src/exec/itron/include/itronsys/msgbuffer.h (added) * c/src/exec/itron/include/itronsys/network.h (added) * c/src/exec/itron/include/itronsys/port.h (added) * c/src/exec/itron/include/itronsys/semaphore.h (added) * c/src/exec/itron/include/itronsys/status.h (added) * c/src/exec/itron/include/itronsys/sysmgmt.h (added) * c/src/exec/itron/include/itronsys/task.h (added) * c/src/exec/itron/include/itronsys/time.h (added) * c/src/exec/itron/include/itronsys/types.h (added) * c/src/exec/itron/include/itronsys/vmempool.h (added) * c/src/exec/itron/include/rtems/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/README (added) * c/src/exec/itron/include/rtems/itron/config.h (added) * c/src/exec/itron/include/rtems/itron/eventflags.h (added) * c/src/exec/itron/include/rtems/itron/fmempool.h (added) * c/src/exec/itron/include/rtems/itron/intr.h (added) * c/src/exec/itron/include/rtems/itron/itronapi.h (added) * c/src/exec/itron/include/rtems/itron/mbox.h (added) * c/src/exec/itron/include/rtems/itron/msgbuffer.h (added) * c/src/exec/itron/include/rtems/itron/network.h (added) * c/src/exec/itron/include/rtems/itron/object.h (added) * c/src/exec/itron/include/rtems/itron/port.h (added) * c/src/exec/itron/include/rtems/itron/semaphore.h (added) * c/src/exec/itron/include/rtems/itron/sysmgmt.h (added) * c/src/exec/itron/include/rtems/itron/task.h (added) * c/src/exec/itron/include/rtems/itron/time.h (added) * c/src/exec/itron/include/rtems/itron/vmempool.h (added) * c/src/exec/itron/inline/Makefile.am (added) * c/src/exec/itron/inline/rtems/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/eventflags.inl (added) * c/src/exec/itron/inline/rtems/itron/fmempool.inl (added) * c/src/exec/itron/inline/rtems/itron/intr.inl (added) * c/src/exec/itron/inline/rtems/itron/mbox.inl (added) * c/src/exec/itron/inline/rtems/itron/msgbuffer.inl (added) * c/src/exec/itron/inline/rtems/itron/network.inl (added) * c/src/exec/itron/inline/rtems/itron/port.inl (added) * c/src/exec/itron/inline/rtems/itron/semaphore.inl (added) * c/src/exec/itron/inline/rtems/itron/sysmgmt.inl (added) * c/src/exec/itron/inline/rtems/itron/task.inl (added) * c/src/exec/itron/inline/rtems/itron/time.inl (added) * c/src/exec/itron/inline/rtems/itron/vmempool.inl (added) * c/src/exec/itron/src/Makefile.in (added) * c/src/exec/itron/src/can_wup.c (added) * c/src/exec/itron/src/chg_pri.c (added) * c/src/exec/itron/src/cre_tsk.c (added) * c/src/exec/itron/src/del_tsk.c (added) * c/src/exec/itron/src/dis_dsp.c (added) * c/src/exec/itron/src/ena_dsp.c (added) * c/src/exec/itron/src/eventflags.c (added) * c/src/exec/itron/src/exd_tsk.c (added) * c/src/exec/itron/src/ext_tsk.c (added) * c/src/exec/itron/src/fmempool.c (added) * c/src/exec/itron/src/frsm_tsk.c (added) * c/src/exec/itron/src/get_tid.c (added) * c/src/exec/itron/src/itronintr.c (added) * c/src/exec/itron/src/itronsem.c (added) * c/src/exec/itron/src/itrontime.c (added) * c/src/exec/itron/src/mbox.c (added) * c/src/exec/itron/src/msgbuffer.c (added) * c/src/exec/itron/src/network.c (added) * c/src/exec/itron/src/port.c (added) * c/src/exec/itron/src/ref_tsk.c (added) * c/src/exec/itron/src/rel_wai.c (added) * c/src/exec/itron/src/rot_rdq.c (added) * c/src/exec/itron/src/rsm_tsk.c (added) * c/src/exec/itron/src/slp_tsk.c (added) * c/src/exec/itron/src/sta_tsk.c (added) * c/src/exec/itron/src/sus_tsk.c (added) * c/src/exec/itron/src/sysmgmt.c (added) * c/src/exec/itron/src/task.c (added) * c/src/exec/itron/src/ter_tsk.c (added) * c/src/exec/itron/src/tslp_tsk.c (added) * c/src/exec/itron/src/vmempool.c (added) * c/src/exec/itron/src/wup_tsk.c (added) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/itronapi.c (added) * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/exec/wrapup/itron/Makefile.in (added) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/Makefile.am (added) * c/src/tests/itrontests/README (added) * c/src/tests/itrontests/configure.in (added) * c/src/tests/itrontests/itronhello/init.c (added) * c/src/tests/itrontests/itronhello/system.h (added) * c/src/tests/itrontests/itronmbf01/init.c (added) * c/src/tests/itrontests/itronmbf01/system.h (added) * c/src/tests/itrontests/itronsem01/init.c (added) * c/src/tests/itrontests/itronsem01/system.h (added) * c/src/tests/itrontests/itrontask01/init.c (added) * c/src/tests/itrontests/itrontask01/system.h (added) * c/src/tests/samples/configure.in (modified) * c/src/tests/tmitrontests/Makefile.am (added) * c/src/tests/tmitrontests/README (added) * c/src/tests/tmitrontests/configure.in (added) * c/src/tests/tmitrontests/include/Makefile.am (added) * c/src/tests/tmitrontests/include/timesys.h (added) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (added) * c/src/tests/tmitrontests/tmitronsem01/init.c (added) * c/src/tests/tmitrontests/tmitronsem01/system.h (added) * c/src/tests/tmitrontests/tmitronsem01/tmitronsem01.doc (added) * cpukit/Makefile.am (modified) * cpukit/itron/Makefile.am (added) * cpukit/itron/include/Makefile.am (added) * cpukit/itron/include/itron.h (added) * cpukit/itron/include/itronsys/README (added) * cpukit/itron/include/itronsys/eventflags.h (added) * cpukit/itron/include/itronsys/fmempool.h (added) * cpukit/itron/include/itronsys/intr.h (added) * cpukit/itron/include/itronsys/mbox.h (added) * cpukit/itron/include/itronsys/msgbuffer.h (added) * cpukit/itron/include/itronsys/network.h (added) * cpukit/itron/include/itronsys/port.h (added) * cpukit/itron/include/itronsys/semaphore.h (added) * cpukit/itron/include/itronsys/status.h (added) * cpukit/itron/include/itronsys/sysmgmt.h (added) * cpukit/itron/include/itronsys/task.h (added) * cpukit/itron/include/itronsys/time.h (added) * cpukit/itron/include/itronsys/types.h (added) * cpukit/itron/include/itronsys/vmempool.h (added) * cpukit/itron/include/rtems/itron/README (added) * cpukit/itron/include/rtems/itron/config.h (added) * cpukit/itron/include/rtems/itron/eventflags.h (added) * cpukit/itron/include/rtems/itron/fmempool.h (added) * cpukit/itron/include/rtems/itron/intr.h (added) * cpukit/itron/include/rtems/itron/itronapi.h (added) * cpukit/itron/include/rtems/itron/mbox.h (added) * cpukit/itron/include/rtems/itron/msgbuffer.h (added) * cpukit/itron/include/rtems/itron/network.h (added) * cpukit/itron/include/rtems/itron/object.h (added) * cpukit/itron/include/rtems/itron/port.h (added) * cpukit/itron/include/rtems/itron/semaphore.h (added) * cpukit/itron/include/rtems/itron/sysmgmt.h (added) * cpukit/itron/include/rtems/itron/task.h (added) * cpukit/itron/include/rtems/itron/time.h (added) * cpukit/itron/include/rtems/itron/vmempool.h (added) * cpukit/itron/inline/Makefile.am (added) * cpukit/itron/inline/rtems/itron/eventflags.inl (added) * cpukit/itron/inline/rtems/itron/fmempool.inl (added) * cpukit/itron/inline/rtems/itron/intr.inl (added) * cpukit/itron/inline/rtems/itron/mbox.inl (added) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (added) * cpukit/itron/inline/rtems/itron/network.inl (added) * cpukit/itron/inline/rtems/itron/port.inl (added) * cpukit/itron/inline/rtems/itron/semaphore.inl (added) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (added) * cpukit/itron/inline/rtems/itron/task.inl (added) * cpukit/itron/inline/rtems/itron/time.inl (added) * cpukit/itron/inline/rtems/itron/vmempool.inl (added) * cpukit/itron/src/can_wup.c (added) * cpukit/itron/src/chg_pri.c (added) * cpukit/itron/src/cre_tsk.c (added) * cpukit/itron/src/del_tsk.c (added) * cpukit/itron/src/dis_dsp.c (added) * cpukit/itron/src/ena_dsp.c (added) * cpukit/itron/src/eventflags.c (added) * cpukit/itron/src/exd_tsk.c (added) * cpukit/itron/src/ext_tsk.c (added) * cpukit/itron/src/fmempool.c (added) * cpukit/itron/src/frsm_tsk.c (added) * cpukit/itron/src/get_tid.c (added) * cpukit/itron/src/itronintr.c (added) * cpukit/itron/src/itronsem.c (added) * cpukit/itron/src/itrontime.c (added) * cpukit/itron/src/mbox.c (added) * cpukit/itron/src/msgbuffer.c (added) * cpukit/itron/src/network.c (added) * cpukit/itron/src/port.c (added) * cpukit/itron/src/ref_tsk.c (added) * cpukit/itron/src/rel_wai.c (added) * cpukit/itron/src/rot_rdq.c (added) * cpukit/itron/src/rsm_tsk.c (added) * cpukit/itron/src/slp_tsk.c (added) * cpukit/itron/src/sta_tsk.c (added) * cpukit/itron/src/sus_tsk.c (added) * cpukit/itron/src/sysmgmt.c (added) * cpukit/itron/src/task.c (added) * cpukit/itron/src/ter_tsk.c (added) * cpukit/itron/src/tslp_tsk.c (added) * cpukit/itron/src/vmempool.c (added) * cpukit/itron/src/wup_tsk.c (added) * cpukit/posix/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/itronapi.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/itrontests/Makefile.am (added) * testsuites/itrontests/README (added) * testsuites/itrontests/itronhello/init.c (added) * testsuites/itrontests/itronhello/system.h (added) * testsuites/itrontests/itronmbf01/init.c (added) * testsuites/itrontests/itronmbf01/system.h (added) * testsuites/itrontests/itronsem01/init.c (added) * testsuites/itrontests/itronsem01/system.h (added) * testsuites/itrontests/itrontask01/init.c (added) * testsuites/itrontests/itrontask01/system.h (added) * testsuites/tmitrontests/Makefile.am (added) * testsuites/tmitrontests/README (added) * testsuites/tmitrontests/include/Makefile.am (added) * testsuites/tmitrontests/include/timesys.h (added) * testsuites/tmitrontests/tmitronsem01/init.c (added) * testsuites/tmitrontests/tmitronsem01/system.h (added) * testsuites/tmitrontests/tmitronsem01/tmitronsem01.doc (added) This patch adds the basic framework for the ITRON 3.0 API ...
