@86ef0df
05/09/12 12:33:51 |
Sebastian Huber |
dosfs: Remove fat_file_datasync()
The fat_file_datasync() read every …
4.115
@d61b0a5
05/07/12 14:15:57 |
Sebastian Huber |
Filesystem: PR1871: Fix O_APPEND
4.115
@30d4124
05/07/12 14:30:37 |
Sebastian Huber |
Filesystem: PR1398: Fix lseek() mechanic
According to POSIX the …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@6a5e19cc
05/04/12 06:54:40 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@113944fa
02/28/12 14:37:31 |
Sebastian Huber |
fstests/fsbdpart01: New test
4.115
@c5392ef9
03/01/12 10:51:34 |
Sebastian Huber |
IMFS: Add make generic node support
Generic nodes are an alternative …
4.115
@3ba4f828
03/02/12 09:18:10 |
Sebastian Huber |
Filesystem: Read-only file system checks
o Make sure EROFS is …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@23c6f93a
02/09/12 09:55:25 |
Sebastian Huber |
Increase stack size for symbolic link loop test
4.115
@28860ec0
02/08/12 14:57:04 |
Sebastian Huber |
Fixed warnings and minor bugs
o Due to the usual integer propagation …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@14d4397
12/11/11 07:38:02 |
Ralf Corsepius |
2011-12-11 Ralf Corsépius <ralf.corsepius@…>
4.115
@d7bd47b
12/08/11 21:38:08 |
Joel Sherrill |
2011-12-08 Joel Sherrill <joel.sherrill@…>
PR 1589/build …
4.115
@27620f44
10/26/11 13:35:16 |
Ralf Corsepius |
2011-10-26 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@4ec8180
10/18/11 18:19:36 |
Jennifer.Averett |
2011-10-18 Jennifer Averett <Jennifer.Averett@…
4.115
@951df57
09/30/11 12:57:07 |
Ralf Corsepius |
2011-09-30 Ralf Corsépius <ralf.corsepius@…>
4.115
@32448524
09/30/11 03:07:21 |
Ralf Corsepius |
4.115
@e5b2ed7
09/07/11 07:43:15 |
Ralf Corsepius |
2011-09-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@d957805
09/07/11 07:42:12 |
Ralf Corsepius |
4.115
@88e2a36
09/07/11 07:39:18 |
Ralf Corsepius |
4.115
@db6fbdf
09/07/11 07:32:05 |
Ralf Corsepius |
4.115
@6fed43e
08/02/11 14:24:59 |
Joel Sherrill |
2011-08-02 Xiang Cui <medivhc@…>
* configure.ac, …
4.115
@a7c39d3
08/01/11 21:54:19 |
Joel Sherrill |
2011-08-01 Xiang Cui <medivhc@…>
* imfs_fslink/Makefile.am, …
4.115
@858e013f
08/01/11 20:54:15 |
Joel Sherrill |
* Makefile.am, …
4.115
@7336d4af
08/01/11 14:29:54 |
Joel Sherrill |
* Makefile.am, …
4.115
@7b5eab8
06/20/11 05:02:43 |
Ralf Corsepius |
2011-06-20 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@a2f875f
04/20/11 21:30:15 |
Joel Sherrill |
2011-04-20 Joel Sherrill <joel.sherrill@…>
Add initial …
4.115
