# # ChangeLog for testsuites/automake in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 13:23:21 Sat, 31 Jul 2010 03:09:52 GMT Ralf Corsepius [4d8cd22] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2010-07-31 Ralf Corsépius * ... Fri, 23 Oct 2009 05:37:46 GMT Ralf Corsepius [8f53ef7] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2009-10-23 Ralf Corsepius * ... Tue, 22 Nov 2005 14:13:42 GMT Ralf Corsepius [fdd2816] * testsuites/automake/compile.am (modified) Remove .obj Tue, 22 Nov 2005 13:24:25 GMT Ralf Corsepius [ee844b4] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2005-11-22 Ralf Corsepius * ... Sun, 13 Nov 2005 09:11:32 GMT Ralf Corsepius [bc82457e] * cpukit/automake/local.am (modified) * testsuites/automake/host.am (modified) * testsuites/automake/local.am (modified) Remove depend. Sun, 13 Nov 2005 08:58:29 GMT Ralf Corsepius [82026e3] * testsuites/automake/subdirs.am (modified) Remove preinstall, preinstall-recursive. Sun, 13 Nov 2005 08:58:10 GMT Ralf Corsepius [e29c44e] * testsuites/automake/local.am (modified) Remove preinstall-am. Sun, 13 Nov 2005 06:49:57 GMT Ralf Corsepius [e3f801eb] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2005-11-13 Ralf Corsepius * ... Wed, 09 Nov 2005 09:30:22 GMT Ralf Corsepius [703e81b] * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/automake/compile.am (modified) Assume PROJECT_ROOT to contain RTEMS_BSP. Wed, 09 Nov 2005 03:45:22 GMT Ralf Corsepius [e3f1345] * testsuites/automake/compile.am (modified) Eliminate PROJECT_LIB. Remove START_FILE, OBJS from LINK_FILES. Tue, 08 Nov 2005 12:12:26 GMT Ralf Corsepius [29db40a] * testsuites/automake/compile.am (modified) Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. Tue, 08 Nov 2005 11:49:22 GMT Ralf Corsepius [6fb40f7] * testsuites/automake/compile.am (modified) Cleanup. Tue, 08 Nov 2005 07:35:01 GMT Ralf Corsepius [6f8e7a6] * testsuites/automake/compile.am (modified) Remove RTEMS_BSP_SPECS, GCC_SPECS. Don't manually set up GCCSPEC ... Tue, 08 Nov 2005 06:37:51 GMT Ralf Corsepius [2f77a65] * testsuites/automake/compile.am (modified) Remove CCAS support. Mon, 07 Nov 2005 10:10:47 GMT Ralf Corsepius [fa0ec2e0] * testsuites/automake/local.am (modified) Remove depend-am. Mon, 07 Nov 2005 10:10:35 GMT Ralf Corsepius [c61b7b69] * testsuites/automake/compile.am (modified) Remove depend. Mon, 07 Nov 2005 10:01:16 GMT Ralf Corsepius [1b77ea4a] * testsuites/automake/subdirs.am (modified) Remove depend-recursive. Mon, 07 Nov 2005 09:11:31 GMT Ralf Corsepius [d2ff8254] * testsuites/automake/compile.am (modified) Take contents of amcompile.am. Mon, 07 Nov 2005 09:11:09 GMT Ralf Corsepius [650b975] * testsuites/automake/amcompile.am (deleted) Remove Mon, 07 Nov 2005 07:23:38 GMT Ralf Corsepius [42e191e8] * testsuites/automake/amcompile.am (added) New. Thu, 06 Jan 2005 13:41:12 GMT Ralf Corsepius [f002ec35] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2004-01-06 Ralf Corsepius * ... Thu, 06 Jan 2005 11:37:25 GMT Ralf Corsepius [0961040] * testsuites/automake/compile.am (modified) Remove duplicate CCAS. Thu, 06 Jan 2005 11:31:43 GMT Ralf Corsepius [73f5388] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2004-01-06 Ralf Corsepius * ... Thu, 06 Jan 2005 11:23:24 GMT Ralf Corsepius [b3f1873] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2004-01-06 Ralf Corsepius * ... Tue, 20 Apr 2004 07:09:31 GMT Ralf Corsepius [8f71a36] * testsuites/automake/compile.am (modified) * testsuites/automake/host.am (modified) * testsuites/automake/leaf.am (modified) * testsuites/automake/subdirs.am (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/samples/unlimited/test2.c (modified) * testsuites/samples/unlimited/test3.c (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmitrontests/include/timesys.h (modified) * testsuites/tmitrontests/tmitronsem01/init.c (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * tools/build/binpatch.c (modified) * tools/build/packhex.c (modified) * tools/build/unhex.c (modified) * tools/cpu/sh/sci.c (modified) * tools/cpu/sh/shgen.c (modified) Remove stray white spaces. Wed, 17 Dec 2003 04:12:27 GMT Ralf Corsepius [4470b40a] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2003-12-17 Ralf Corsepius * ... Mon, 15 Dec 2003 07:27:36 GMT Ralf Corsepius [d7e0507] * testsuites/ChangeLog (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/automake/compile.am (modified) 2003-12-15 Ralf Corsepius * ... Fri, 12 Dec 2003 16:12:03 GMT Ralf Corsepius [3d02fadb] * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (modified) 2003-12-12 Ralf Corsepius * ... Mon, 01 Dec 2003 21:38:43 GMT Ralf Corsepius [c17ed71] * testsuites/ChangeLog (modified) * testsuites/aclocal/lead-dot.m4 (added) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/automake/compile.am (modified) 2003-12-01 Ralf Corsepius * ... Sun, 17 Aug 2003 12:44:57 GMT Ralf Corsepius [94e18016] * c/src/tests/ChangeLog (modified) * c/src/tests/automake/host.am (modified) * c/src/tests/automake/local.am (modified) * testsuites/ChangeLog (modified) * testsuites/automake/host.am (modified) * testsuites/automake/local.am (modified) 2003-08-17 Ralf Corsepius * ... Sat, 16 Aug 2003 16:24:45 GMT Ralf Corsepius [4cd2df9] * c/src/tests/ChangeLog (modified) * c/src/tests/automake/compile.am (added) * c/src/tests/automake/host.am (added) * c/src/tests/automake/leaf.am (added) * c/src/tests/automake/local.am (added) * c/src/tests/automake/subdirs.am (added) * testsuites/ChangeLog (modified) * testsuites/automake/compile.am (added) * testsuites/automake/host.am (added) * testsuites/automake/leaf.am (added) * testsuites/automake/local.am (added) * testsuites/automake/subdirs.am (added) 2003-08-16 Ralf Corsepius * ...
