# # ChangeLog for testsuites/ada/sptests/sp22/Makefile.am in rtems # # Generated by Trac 1.2.1.dev0 # 05/07/24 11:53:58 Thu, 12 Oct 2017 08:00:10 GMT Sebastian Huber [ee537ea] * c/src/ada-tests/Makefile.am (deleted) * c/src/ada-tests/mptests/mp01/Makefile.am (deleted) * c/src/ada-tests/mptests/mp03/Makefile.am (deleted) * c/src/ada-tests/mptests/mp04/Makefile.am (deleted) * c/src/ada-tests/mptests/mp05/Makefile.am (deleted) * c/src/ada-tests/mptests/mp06/Makefile.am (deleted) * c/src/ada-tests/mptests/mp07/Makefile.am (deleted) * c/src/ada-tests/mptests/mp08/Makefile.am (deleted) * c/src/ada-tests/mptests/mp09/Makefile.am (deleted) * c/src/ada-tests/mptests/mp10/Makefile.am (deleted) * c/src/ada-tests/mptests/mp11/Makefile.am (deleted) * c/src/ada-tests/mptests/mp12/Makefile.am (deleted) * c/src/ada-tests/mptests/mp13/Makefile.am (deleted) * c/src/ada-tests/mptests/mp14/Makefile.am (deleted) * c/src/configure.ac (modified) * testsuites/ada/Makefile.am (added) * testsuites/ada/aclocal/prog-gnat.m4 (moved) * testsuites/ada/ada.am (moved) * testsuites/ada/ada_mvscn (moved) * testsuites/ada/configure.ac (moved) * testsuites/ada/mptests/Makefile.am (moved) * testsuites/ada/mptests/mp01/Makefile.am (added) * testsuites/ada/mptests/mp01/config_base.h (moved) * testsuites/ada/mptests/mp01/mp01.adb (moved) * testsuites/ada/mptests/mp01/mptest.adb (moved) * testsuites/ada/mptests/mp01/mptest.ads (moved) * testsuites/ada/mptests/mp01/node1/Makefile.am (moved) * testsuites/ada/mptests/mp01/node1/ada_mp01-node1.scn (moved) * testsuites/ada/mptests/mp01/node1/config.h (moved) * testsuites/ada/mptests/mp01/node1/mp01_node1.adb (moved) * testsuites/ada/mptests/mp01/node2/Makefile.am (moved) * testsuites/ada/mptests/mp01/node2/ada_mp01-node2.scn (moved) * testsuites/ada/mptests/mp01/node2/config.h (moved) * testsuites/ada/mptests/mp01/node2/mp01_node2.adb (moved) * testsuites/ada/mptests/mp03/Makefile.am (added) * testsuites/ada/mptests/mp03/config_base.h (moved) * testsuites/ada/mptests/mp03/mptest.adb (moved) * testsuites/ada/mptests/mp03/mptest.ads (moved) * testsuites/ada/mptests/mp03/node1/Makefile.am (moved) * testsuites/ada/mptests/mp03/node1/ada_mp03-node1.scn (moved) * testsuites/ada/mptests/mp03/node1/config.h (moved) * testsuites/ada/mptests/mp03/node1/mp03_node1.adb (moved) * testsuites/ada/mptests/mp03/node2/Makefile.am (moved) * testsuites/ada/mptests/mp03/node2/ada_mp03-node2.scn (moved) * testsuites/ada/mptests/mp03/node2/config.h (moved) * testsuites/ada/mptests/mp03/node2/mp03_node2.adb (moved) * testsuites/ada/mptests/mp04/Makefile.am (added) * testsuites/ada/mptests/mp04/config_base.h (moved) * testsuites/ada/mptests/mp04/mptest.adb (moved) * testsuites/ada/mptests/mp04/mptest.ads (moved) * testsuites/ada/mptests/mp04/node1/Makefile.am (moved) * testsuites/ada/mptests/mp04/node1/ada_mp04-node1.scn (moved) * testsuites/ada/mptests/mp04/node1/config.h (moved) * testsuites/ada/mptests/mp04/node1/mp04_node1.adb (moved) * testsuites/ada/mptests/mp04/node2/Makefile.am (moved) * testsuites/ada/mptests/mp04/node2/ada_mp04-node2.scn (moved) * testsuites/ada/mptests/mp04/node2/config.h (moved) * testsuites/ada/mptests/mp04/node2/mp04_node2.adb (moved) * testsuites/ada/mptests/mp05/Makefile.am (added) * testsuites/ada/mptests/mp05/config_base.h (moved) * testsuites/ada/mptests/mp05/mptest.adb (moved) * testsuites/ada/mptests/mp05/mptest.ads (moved) * testsuites/ada/mptests/mp05/node1/Makefile.am (moved) * testsuites/ada/mptests/mp05/node1/ada_mp05-node1.scn (moved) * testsuites/ada/mptests/mp05/node1/config.h (moved) * testsuites/ada/mptests/mp05/node1/mp05_node1.adb (moved) * testsuites/ada/mptests/mp05/node2/Makefile.am (moved) * testsuites/ada/mptests/mp05/node2/ada_mp05-node2.scn (moved) * testsuites/ada/mptests/mp05/node2/config.h (moved) * testsuites/ada/mptests/mp05/node2/mp05_node2.adb (moved) * testsuites/ada/mptests/mp06/Makefile.am (added) * testsuites/ada/mptests/mp06/config_base.h (moved) * testsuites/ada/mptests/mp06/mptest.adb (moved) * testsuites/ada/mptests/mp06/mptest.ads (moved) * testsuites/ada/mptests/mp06/node1/Makefile.am (moved) * testsuites/ada/mptests/mp06/node1/ada_mp06-node1.scn (moved) * testsuites/ada/mptests/mp06/node1/config.h (moved) * testsuites/ada/mptests/mp06/node1/mp06_node1.adb (moved) * testsuites/ada/mptests/mp06/node2/Makefile.am (moved) * testsuites/ada/mptests/mp06/node2/ada_mp06-node2.scn (moved) * testsuites/ada/mptests/mp06/node2/config.h (moved) * testsuites/ada/mptests/mp06/node2/mp06_node2.adb (moved) * testsuites/ada/mptests/mp07/Makefile.am (added) * testsuites/ada/mptests/mp07/config_base.h (moved) * testsuites/ada/mptests/mp07/mptest.adb (moved) * testsuites/ada/mptests/mp07/mptest.ads (moved) * testsuites/ada/mptests/mp07/node1/Makefile.am (moved) * testsuites/ada/mptests/mp07/node1/ada_mp07-node1.scn (moved) * testsuites/ada/mptests/mp07/node1/config.h (moved) * testsuites/ada/mptests/mp07/node1/mp07_node1.adb (moved) * testsuites/ada/mptests/mp07/node2/Makefile.am (moved) * testsuites/ada/mptests/mp07/node2/ada_mp07-node2.scn (moved) * testsuites/ada/mptests/mp07/node2/config.h (moved) * testsuites/ada/mptests/mp07/node2/mp07_node2.adb (moved) * testsuites/ada/mptests/mp08/Makefile.am (added) * testsuites/ada/mptests/mp08/config_base.h (moved) * testsuites/ada/mptests/mp08/mptest.adb (moved) * testsuites/ada/mptests/mp08/mptest.ads (moved) * testsuites/ada/mptests/mp08/node1/Makefile.am (moved) * testsuites/ada/mptests/mp08/node1/ada_mp08-node1.scn (moved) * testsuites/ada/mptests/mp08/node1/config.h (moved) * testsuites/ada/mptests/mp08/node1/mp08_node1.adb (moved) * testsuites/ada/mptests/mp08/node2/Makefile.am (moved) * testsuites/ada/mptests/mp08/node2/ada_mp08-node2.scn (moved) * testsuites/ada/mptests/mp08/node2/config.h (moved) * testsuites/ada/mptests/mp08/node2/mp08_node2.adb (moved) * testsuites/ada/mptests/mp09/Makefile.am (added) * testsuites/ada/mptests/mp09/config_base.h (moved) * testsuites/ada/mptests/mp09/mptest.adb (moved) * testsuites/ada/mptests/mp09/mptest.ads (moved) * testsuites/ada/mptests/mp09/node1/Makefile.am (moved) * testsuites/ada/mptests/mp09/node1/ada_mp09-node1.scn (moved) * testsuites/ada/mptests/mp09/node1/config.h (moved) * testsuites/ada/mptests/mp09/node1/mp09_node1.adb (moved) * testsuites/ada/mptests/mp09/node2/Makefile.am (moved) * testsuites/ada/mptests/mp09/node2/ada_mp09-node2.scn (moved) * testsuites/ada/mptests/mp09/node2/config.h (moved) * testsuites/ada/mptests/mp09/node2/mp09_node2.adb (moved) * testsuites/ada/mptests/mp10/Makefile.am (added) * testsuites/ada/mptests/mp10/config_base.h (moved) * testsuites/ada/mptests/mp10/mptest.adb (moved) * testsuites/ada/mptests/mp10/mptest.ads (moved) * testsuites/ada/mptests/mp10/node1/Makefile.am (moved) * testsuites/ada/mptests/mp10/node1/ada_mp10-node1.scn (moved) * testsuites/ada/mptests/mp10/node1/config.h (moved) * testsuites/ada/mptests/mp10/node1/mp10_node1.adb (moved) * testsuites/ada/mptests/mp10/node2/Makefile.am (moved) * testsuites/ada/mptests/mp10/node2/ada_mp10-node2.scn (moved) * testsuites/ada/mptests/mp10/node2/config.h (moved) * testsuites/ada/mptests/mp10/node2/mp10_node2.adb (moved) * testsuites/ada/mptests/mp11/Makefile.am (added) * testsuites/ada/mptests/mp11/config_base.h (moved) * testsuites/ada/mptests/mp11/mptest.adb (moved) * testsuites/ada/mptests/mp11/mptest.ads (moved) * testsuites/ada/mptests/mp11/node1/Makefile.am (moved) * testsuites/ada/mptests/mp11/node1/ada_mp11-node1.scn (moved) * testsuites/ada/mptests/mp11/node1/config.h (moved) * testsuites/ada/mptests/mp11/node1/mp11_node1.adb (moved) * testsuites/ada/mptests/mp11/node2/Makefile.am (moved) * testsuites/ada/mptests/mp11/node2/ada_mp11-node2.scn (moved) * testsuites/ada/mptests/mp11/node2/config.h (moved) * testsuites/ada/mptests/mp11/node2/mp11_node2.adb (moved) * testsuites/ada/mptests/mp12/Makefile.am (added) * testsuites/ada/mptests/mp12/config_base.h (moved) * testsuites/ada/mptests/mp12/mptest.adb (moved) * testsuites/ada/mptests/mp12/mptest.ads (moved) * testsuites/ada/mptests/mp12/node1/Makefile.am (moved) * testsuites/ada/mptests/mp12/node1/ada_mp12-node1.scn (moved) * testsuites/ada/mptests/mp12/node1/config.h (moved) * testsuites/ada/mptests/mp12/node1/mp12_node1.adb (moved) * testsuites/ada/mptests/mp12/node2/Makefile.am (moved) * testsuites/ada/mptests/mp12/node2/ada_mp12-node2.scn (moved) * testsuites/ada/mptests/mp12/node2/config.h (moved) * testsuites/ada/mptests/mp12/node2/mp12_node2.adb (moved) * testsuites/ada/mptests/mp13/Makefile.am (added) * testsuites/ada/mptests/mp13/config_base.h (moved) * testsuites/ada/mptests/mp13/mptest.adb (moved) * testsuites/ada/mptests/mp13/mptest.ads (moved) * testsuites/ada/mptests/mp13/node1/Makefile.am (moved) * testsuites/ada/mptests/mp13/node1/ada_mp13-node1.scn (moved) * testsuites/ada/mptests/mp13/node1/config.h (moved) * testsuites/ada/mptests/mp13/node1/mp13_node1.adb (moved) * testsuites/ada/mptests/mp13/node2/Makefile.am (moved) * testsuites/ada/mptests/mp13/node2/ada_mp13-node2.scn (moved) * testsuites/ada/mptests/mp13/node2/config.h (moved) * testsuites/ada/mptests/mp13/node2/mp13_node2.adb (moved) * testsuites/ada/mptests/mp14/Makefile.am (added) * testsuites/ada/mptests/mp14/config_base.h (moved) * testsuites/ada/mptests/mp14/mptest.adb (moved) * testsuites/ada/mptests/mp14/mptest.ads (moved) * testsuites/ada/mptests/mp14/node1/Makefile.am (moved) * testsuites/ada/mptests/mp14/node1/ada_mp14-node1.scn (moved) * testsuites/ada/mptests/mp14/node1/config.h (moved) * testsuites/ada/mptests/mp14/node1/mp14_node1.adb (moved) * testsuites/ada/mptests/mp14/node2/Makefile.am (moved) * testsuites/ada/mptests/mp14/node2/ada_mp14-node2.scn (moved) * testsuites/ada/mptests/mp14/node2/config.h (moved) * testsuites/ada/mptests/mp14/node2/mp14_node2.adb (moved) * testsuites/ada/samples/Makefile.am (moved) * testsuites/ada/samples/base_mp/Makefile.am (moved) * testsuites/ada/samples/base_mp/config.h (moved) * testsuites/ada/samples/base_mp/mptest.adb (moved) * testsuites/ada/samples/base_mp/mptest.ads (moved) * testsuites/ada/samples/base_mp/node1/Makefile.am (moved) * testsuites/ada/samples/base_mp/node1/ada_base_mp-node1.scn (moved) * testsuites/ada/samples/base_mp/node2/Makefile.am (moved) * testsuites/ada/samples/base_mp/node2/ada_base_mp-node2.scn (moved) * testsuites/ada/samples/base_sp/Makefile.am (moved) * testsuites/ada/samples/base_sp/ada_base_sp.scn (moved) * testsuites/ada/samples/base_sp/base_sp.adb (moved) * testsuites/ada/samples/base_sp/config.h (moved) * testsuites/ada/samples/base_sp/sptest.adb (moved) * testsuites/ada/samples/base_sp/sptest.ads (moved) * testsuites/ada/samples/hello/Makefile.am (moved) * testsuites/ada/samples/hello/ada_hello.scn (moved) * testsuites/ada/samples/hello/config.h (moved) * testsuites/ada/samples/hello/hello.adb (moved) * testsuites/ada/samples/hello/sptest.adb (moved) * testsuites/ada/samples/hello/sptest.ads (moved) * testsuites/ada/samples/nsecs/Makefile.am (moved) * testsuites/ada/samples/nsecs/ada_nsecs.scn (moved) * testsuites/ada/samples/nsecs/config.h (moved) * testsuites/ada/samples/nsecs/nsecs.adb (moved) * testsuites/ada/samples/nsecs/sptest.adb (moved) * testsuites/ada/samples/nsecs/sptest.ads (moved) * testsuites/ada/samples/ticker/Makefile.am (moved) * testsuites/ada/samples/ticker/ada_ticker.scn (moved) * testsuites/ada/samples/ticker/config.h (moved) * testsuites/ada/samples/ticker/sptest.adb (moved) * testsuites/ada/samples/ticker/sptest.ads (moved) * testsuites/ada/samples/ticker/ticker.adb (moved) * testsuites/ada/sptests/Makefile.am (moved) * testsuites/ada/sptests/sp01/Makefile.am (moved) * testsuites/ada/sptests/sp01/ada_sp01.scn (moved) * testsuites/ada/sptests/sp01/config.h (moved) * testsuites/ada/sptests/sp01/sp01.adb (moved) * testsuites/ada/sptests/sp01/sptest.adb (moved) * testsuites/ada/sptests/sp01/sptest.ads (moved) * testsuites/ada/sptests/sp02/Makefile.am (moved) * testsuites/ada/sptests/sp02/ada_sp02.scn (moved) * testsuites/ada/sptests/sp02/config.h (moved) * testsuites/ada/sptests/sp02/sp02.adb (moved) * testsuites/ada/sptests/sp02/sptest.adb (moved) * testsuites/ada/sptests/sp02/sptest.ads (moved) * testsuites/ada/sptests/sp03/Makefile.am (moved) * testsuites/ada/sptests/sp03/ada_sp03.scn (moved) * testsuites/ada/sptests/sp03/config.h (moved) * testsuites/ada/sptests/sp03/sp03.adb (moved) * testsuites/ada/sptests/sp03/sptest.adb (moved) * testsuites/ada/sptests/sp03/sptest.ads (moved) * testsuites/ada/sptests/sp04/Makefile.am (moved) * testsuites/ada/sptests/sp04/README (moved) * testsuites/ada/sptests/sp04/ada_sp04.scn (moved) * testsuites/ada/sptests/sp04/config.h (moved) * testsuites/ada/sptests/sp04/sp04.adb (moved) * testsuites/ada/sptests/sp04/sptest.adb (moved) * testsuites/ada/sptests/sp04/sptest.ads (moved) * testsuites/ada/sptests/sp05/Makefile.am (moved) * testsuites/ada/sptests/sp05/ada_sp05.scn (moved) * testsuites/ada/sptests/sp05/config.h (moved) * testsuites/ada/sptests/sp05/sp05.adb (moved) * testsuites/ada/sptests/sp05/sptest.adb (moved) * testsuites/ada/sptests/sp05/sptest.ads (moved) * testsuites/ada/sptests/sp06/Makefile.am (moved) * testsuites/ada/sptests/sp06/ada_sp06.scn (moved) * testsuites/ada/sptests/sp06/config.h (moved) * testsuites/ada/sptests/sp06/sp06.adb (moved) * testsuites/ada/sptests/sp06/sptest.adb (moved) * testsuites/ada/sptests/sp06/sptest.ads (moved) * testsuites/ada/sptests/sp07/Makefile.am (moved) * testsuites/ada/sptests/sp07/ada_sp07.scn (moved) * testsuites/ada/sptests/sp07/config.h (moved) * testsuites/ada/sptests/sp07/sp07.adb (moved) * testsuites/ada/sptests/sp07/sptest.adb (moved) * testsuites/ada/sptests/sp07/sptest.ads (moved) * testsuites/ada/sptests/sp08/Makefile.am (moved) * testsuites/ada/sptests/sp08/ada_sp08.scn (moved) * testsuites/ada/sptests/sp08/config.h (moved) * testsuites/ada/sptests/sp08/sp08.adb (moved) * testsuites/ada/sptests/sp08/sptest.adb (moved) * testsuites/ada/sptests/sp08/sptest.ads (moved) * testsuites/ada/sptests/sp09/Makefile.am (moved) * testsuites/ada/sptests/sp09/ada_sp09.scn (moved) * testsuites/ada/sptests/sp09/config.h (moved) * testsuites/ada/sptests/sp09/sp09.adb (moved) * testsuites/ada/sptests/sp09/sptest.adb (moved) * testsuites/ada/sptests/sp09/sptest.ads (moved) * testsuites/ada/sptests/sp11/Makefile.am (moved) * testsuites/ada/sptests/sp11/ada_sp11.scn (moved) * testsuites/ada/sptests/sp11/config.h (moved) * testsuites/ada/sptests/sp11/sp11.adb (moved) * testsuites/ada/sptests/sp11/sptest.adb (moved) * testsuites/ada/sptests/sp11/sptest.ads (moved) * testsuites/ada/sptests/sp12/Makefile.am (moved) * testsuites/ada/sptests/sp12/ada_sp12.scn (moved) * testsuites/ada/sptests/sp12/config.h (moved) * testsuites/ada/sptests/sp12/sp12.adb (moved) * testsuites/ada/sptests/sp12/sptest.adb (moved) * testsuites/ada/sptests/sp12/sptest.ads (moved) * testsuites/ada/sptests/sp13/Makefile.am (moved) * testsuites/ada/sptests/sp13/ada_sp13.scn (moved) * testsuites/ada/sptests/sp13/config.h (moved) * testsuites/ada/sptests/sp13/sp13.adb (moved) * testsuites/ada/sptests/sp13/sptest.adb (moved) * testsuites/ada/sptests/sp13/sptest.ads (moved) * testsuites/ada/sptests/sp14/Makefile.am (moved) * testsuites/ada/sptests/sp14/ada_sp14.scn (moved) * testsuites/ada/sptests/sp14/config.h (moved) * testsuites/ada/sptests/sp14/sp14.adb (moved) * testsuites/ada/sptests/sp14/sptest.adb (moved) * testsuites/ada/sptests/sp14/sptest.ads (moved) * testsuites/ada/sptests/sp15/Makefile.am (moved) * testsuites/ada/sptests/sp15/ada_sp15.scn (moved) * testsuites/ada/sptests/sp15/config.h (moved) * testsuites/ada/sptests/sp15/sp15.adb (moved) * testsuites/ada/sptests/sp15/sptest.adb (moved) * testsuites/ada/sptests/sp15/sptest.ads (moved) * testsuites/ada/sptests/sp16/Makefile.am (moved) * testsuites/ada/sptests/sp16/ada_sp16.scn (moved) * testsuites/ada/sptests/sp16/config.h (moved) * testsuites/ada/sptests/sp16/sp16.adb (moved) * testsuites/ada/sptests/sp16/sptest.adb (moved) * testsuites/ada/sptests/sp16/sptest.ads (moved) * testsuites/ada/sptests/sp17/Makefile.am (moved) * testsuites/ada/sptests/sp17/ada_sp17.scn (moved) * testsuites/ada/sptests/sp17/config.h (moved) * testsuites/ada/sptests/sp17/sp17.adb (moved) * testsuites/ada/sptests/sp17/sptest.adb (moved) * testsuites/ada/sptests/sp17/sptest.ads (moved) * testsuites/ada/sptests/sp19/Makefile.am (moved) * testsuites/ada/sptests/sp19/README (moved) * testsuites/ada/sptests/sp19/ada_sp19.scn (moved) * testsuites/ada/sptests/sp19/config.h (moved) * testsuites/ada/sptests/sp19/sp19.adb (moved) * testsuites/ada/sptests/sp19/sptest.adp (moved) * testsuites/ada/sptests/sp19/sptest.ads (moved) * testsuites/ada/sptests/sp20/Makefile.am (moved) * testsuites/ada/sptests/sp20/ada_sp20.scn (moved) * testsuites/ada/sptests/sp20/config.h (moved) * testsuites/ada/sptests/sp20/sp20.adb (moved) * testsuites/ada/sptests/sp20/sptest.adb (moved) * testsuites/ada/sptests/sp20/sptest.ads (moved) * testsuites/ada/sptests/sp22/Makefile.am (moved) * testsuites/ada/sptests/sp22/ada_sp22.scn (moved) * testsuites/ada/sptests/sp22/config.h (moved) * testsuites/ada/sptests/sp22/sp22.adb (moved) * testsuites/ada/sptests/sp22/sptest.adb (moved) * testsuites/ada/sptests/sp22/sptest.ads (moved) * testsuites/ada/sptests/sp23/Makefile.am (moved) * testsuites/ada/sptests/sp23/ada_sp23.scn (moved) * testsuites/ada/sptests/sp23/config.h (moved) * testsuites/ada/sptests/sp23/sp23.adb (moved) * testsuites/ada/sptests/sp23/sptest.adb (moved) * testsuites/ada/sptests/sp23/sptest.ads (moved) * testsuites/ada/sptests/sp24/Makefile.am (moved) * testsuites/ada/sptests/sp24/ada_sp24.scn (moved) * testsuites/ada/sptests/sp24/config.h (moved) * testsuites/ada/sptests/sp24/sp24.adb (moved) * testsuites/ada/sptests/sp24/sptest.adb (moved) * testsuites/ada/sptests/sp24/sptest.ads (moved) * testsuites/ada/sptests/sp25/Makefile.am (moved) * testsuites/ada/sptests/sp25/ada_sp25.scn (moved) * testsuites/ada/sptests/sp25/config.h (moved) * testsuites/ada/sptests/sp25/sp25.adb (moved) * testsuites/ada/sptests/sp25/sptest.adb (moved) * testsuites/ada/sptests/sp25/sptest.ads (moved) * testsuites/ada/sptests/spatcb01/Makefile.am (moved) * testsuites/ada/sptests/spatcb01/ada_spatcb01.scn (moved) * testsuites/ada/sptests/spatcb01/config.h (moved) * testsuites/ada/sptests/spatcb01/spatcb01.adb (moved) * testsuites/ada/sptests/spname01/Makefile.am (moved) * testsuites/ada/sptests/spname01/ada_spname01.scn (moved) * testsuites/ada/sptests/spname01/config.h (moved) * testsuites/ada/sptests/spname01/spname01.adb (moved) * testsuites/ada/sptests/spname01/sptest.adb (moved) * testsuites/ada/sptests/spname01/sptest.ads (moved) * testsuites/ada/support/Makefile.am (moved) * testsuites/ada/support/address_io.adb (moved) * testsuites/ada/support/address_io.ads (moved) * testsuites/ada/support/float_io.ads (moved) * testsuites/ada/support/fp.inc (moved) * testsuites/ada/support/init.c (moved) * testsuites/ada/support/integer.inc (moved) * testsuites/ada/support/rtems_calling_overhead.ads (moved) * testsuites/ada/support/status_io.ads (moved) * testsuites/ada/support/test_support.adb (moved) * testsuites/ada/support/test_support.ads (moved) * testsuites/ada/support/time_test_support.adb (moved) * testsuites/ada/support/time_test_support.ads (moved) * testsuites/ada/support/timer_driver.adb (moved) * testsuites/ada/support/timer_driver.ads (moved) * testsuites/ada/support/unsigned32_io.ads (moved) * testsuites/ada/tmtests/Makefile.am (moved) * testsuites/ada/tmtests/tm01/Makefile.am (moved) * testsuites/ada/tmtests/tm01/config.h (moved) * testsuites/ada/tmtests/tm01/tm01.adb (moved) * testsuites/ada/tmtests/tm01/tmtest.adb (moved) * testsuites/ada/tmtests/tm01/tmtest.ads (moved) * testsuites/ada/tmtests/tm02/Makefile.am (moved) * testsuites/ada/tmtests/tm02/config.h (moved) * testsuites/ada/tmtests/tm02/tm02.adb (moved) * testsuites/ada/tmtests/tm02/tmtest.adb (moved) * testsuites/ada/tmtests/tm02/tmtest.ads (moved) * testsuites/ada/tmtests/tm03/Makefile.am (moved) * testsuites/ada/tmtests/tm03/config.h (moved) * testsuites/ada/tmtests/tm03/tm03.adb (moved) * testsuites/ada/tmtests/tm03/tmtest.adb (moved) * testsuites/ada/tmtests/tm03/tmtest.ads (moved) * testsuites/ada/tmtests/tm04/Makefile.am (moved) * testsuites/ada/tmtests/tm04/config.h (moved) * testsuites/ada/tmtests/tm04/tm04.adb (moved) * testsuites/ada/tmtests/tm04/tmtest.adb (moved) * testsuites/ada/tmtests/tm04/tmtest.ads (moved) * testsuites/ada/tmtests/tm05/Makefile.am (moved) * testsuites/ada/tmtests/tm05/config.h (moved) * testsuites/ada/tmtests/tm05/tm05.adb (moved) * testsuites/ada/tmtests/tm05/tmtest.adb (moved) * testsuites/ada/tmtests/tm05/tmtest.ads (moved) * testsuites/ada/tmtests/tm06/Makefile.am (moved) * testsuites/ada/tmtests/tm06/config.h (moved) * testsuites/ada/tmtests/tm06/tm06.adb (moved) * testsuites/ada/tmtests/tm06/tmtest.adb (moved) * testsuites/ada/tmtests/tm06/tmtest.ads (moved) * testsuites/ada/tmtests/tm07/Makefile.am (moved) * testsuites/ada/tmtests/tm07/config.h (moved) * testsuites/ada/tmtests/tm07/tm07.adb (moved) * testsuites/ada/tmtests/tm07/tmtest.adb (moved) * testsuites/ada/tmtests/tm07/tmtest.ads (moved) * testsuites/ada/tmtests/tm08/Makefile.am (moved) * testsuites/ada/tmtests/tm08/config.h (moved) * testsuites/ada/tmtests/tm08/tm08.adb (moved) * testsuites/ada/tmtests/tm08/tmtest.adb (moved) * testsuites/ada/tmtests/tm08/tmtest.ads (moved) * testsuites/ada/tmtests/tm09/Makefile.am (moved) * testsuites/ada/tmtests/tm09/config.h (moved) * testsuites/ada/tmtests/tm09/tm09.adb (moved) * testsuites/ada/tmtests/tm09/tmtest.adb (moved) * testsuites/ada/tmtests/tm09/tmtest.ads (moved) * testsuites/ada/tmtests/tm10/Makefile.am (moved) * testsuites/ada/tmtests/tm10/config.h (moved) * testsuites/ada/tmtests/tm10/tm10.adb (moved) * testsuites/ada/tmtests/tm10/tmtest.adb (moved) * testsuites/ada/tmtests/tm10/tmtest.ads (moved) * testsuites/ada/tmtests/tm11/Makefile.am (moved) * testsuites/ada/tmtests/tm11/config.h (moved) * testsuites/ada/tmtests/tm11/tm11.adb (moved) * testsuites/ada/tmtests/tm11/tmtest.adb (moved) * testsuites/ada/tmtests/tm11/tmtest.ads (moved) * testsuites/ada/tmtests/tm12/Makefile.am (moved) * testsuites/ada/tmtests/tm12/config.h (moved) * testsuites/ada/tmtests/tm12/tm12.adb (moved) * testsuites/ada/tmtests/tm12/tmtest.adb (moved) * testsuites/ada/tmtests/tm12/tmtest.ads (moved) * testsuites/ada/tmtests/tm13/Makefile.am (moved) * testsuites/ada/tmtests/tm13/config.h (moved) * testsuites/ada/tmtests/tm13/tm13.adb (moved) * testsuites/ada/tmtests/tm13/tmtest.adb (moved) * testsuites/ada/tmtests/tm13/tmtest.ads (moved) * testsuites/ada/tmtests/tm14/Makefile.am (moved) * testsuites/ada/tmtests/tm14/config.h (moved) * testsuites/ada/tmtests/tm14/tm14.adb (moved) * testsuites/ada/tmtests/tm14/tmtest.adb (moved) * testsuites/ada/tmtests/tm14/tmtest.ads (moved) * testsuites/ada/tmtests/tm15/Makefile.am (moved) * testsuites/ada/tmtests/tm15/config.h (moved) * testsuites/ada/tmtests/tm15/tm15.adb (moved) * testsuites/ada/tmtests/tm15/tmtest.adb (moved) * testsuites/ada/tmtests/tm15/tmtest.ads (moved) * testsuites/ada/tmtests/tm16/Makefile.am (moved) * testsuites/ada/tmtests/tm16/config.h (moved) * testsuites/ada/tmtests/tm16/tm16.adb (moved) * testsuites/ada/tmtests/tm16/tmtest.adb (moved) * testsuites/ada/tmtests/tm16/tmtest.ads (moved) * testsuites/ada/tmtests/tm17/Makefile.am (moved) * testsuites/ada/tmtests/tm17/config.h (moved) * testsuites/ada/tmtests/tm17/tm17.adb (moved) * testsuites/ada/tmtests/tm17/tmtest.adb (moved) * testsuites/ada/tmtests/tm17/tmtest.ads (moved) * testsuites/ada/tmtests/tm18/Makefile.am (moved) * testsuites/ada/tmtests/tm18/config.h (moved) * testsuites/ada/tmtests/tm18/tm18.adb (moved) * testsuites/ada/tmtests/tm18/tmtest.adb (moved) * testsuites/ada/tmtests/tm18/tmtest.ads (moved) * testsuites/ada/tmtests/tm19/Makefile.am (moved) * testsuites/ada/tmtests/tm19/config.h (moved) * testsuites/ada/tmtests/tm19/tm19.adb (moved) * testsuites/ada/tmtests/tm19/tmtest.adb (moved) * testsuites/ada/tmtests/tm19/tmtest.ads (moved) * testsuites/ada/tmtests/tm20/Makefile.am (moved) * testsuites/ada/tmtests/tm20/config.h (moved) * testsuites/ada/tmtests/tm20/tm20.adb (moved) * testsuites/ada/tmtests/tm20/tmtest.adb (moved) * testsuites/ada/tmtests/tm20/tmtest.ads (moved) * testsuites/ada/tmtests/tm21/Makefile.am (moved) * testsuites/ada/tmtests/tm21/config.h (moved) * testsuites/ada/tmtests/tm21/tm21.adb (moved) * testsuites/ada/tmtests/tm21/tmtest.adb (moved) * testsuites/ada/tmtests/tm21/tmtest.ads (moved) * testsuites/ada/tmtests/tm22/Makefile.am (moved) * testsuites/ada/tmtests/tm22/config.h (moved) * testsuites/ada/tmtests/tm22/tm22.adb (moved) * testsuites/ada/tmtests/tm22/tmtest.adb (moved) * testsuites/ada/tmtests/tm22/tmtest.ads (moved) * testsuites/ada/tmtests/tm23/Makefile.am (moved) * testsuites/ada/tmtests/tm23/config.h (moved) * testsuites/ada/tmtests/tm23/tm23.adb (moved) * testsuites/ada/tmtests/tm23/tmtest.adb (moved) * testsuites/ada/tmtests/tm23/tmtest.ads (moved) * testsuites/ada/tmtests/tm24/Makefile.am (moved) * testsuites/ada/tmtests/tm24/config.h (moved) * testsuites/ada/tmtests/tm24/tm24.adb (moved) * testsuites/ada/tmtests/tm24/tmtest.adb (moved) * testsuites/ada/tmtests/tm24/tmtest.ads (moved) * testsuites/ada/tmtests/tm25/Makefile.am (moved) * testsuites/ada/tmtests/tm25/config.h (moved) * testsuites/ada/tmtests/tm25/tm25.adb (moved) * testsuites/ada/tmtests/tm25/tmtest.adb (moved) * testsuites/ada/tmtests/tm25/tmtest.ads (moved) * testsuites/ada/tmtests/tm28/Makefile.am (moved) * testsuites/ada/tmtests/tm28/config.h (moved) * testsuites/ada/tmtests/tm28/tm28.adb (moved) * testsuites/ada/tmtests/tm28/tmtest.adb (moved) * testsuites/ada/tmtests/tm28/tmtest.ads (moved) * testsuites/ada/tmtests/tm29/Makefile.am (moved) * testsuites/ada/tmtests/tm29/config.h (moved) * testsuites/ada/tmtests/tm29/tm29.adb (moved) * testsuites/ada/tmtests/tm29/tmtest.adb (moved) * testsuites/ada/tmtests/tm29/tmtest.ads (moved) * testsuites/ada/tmtests/tmck/Makefile.am (moved) * testsuites/ada/tmtests/tmck/config.h (moved) * testsuites/ada/tmtests/tmck/tmck.adb (moved) * testsuites/ada/tmtests/tmck/tmtest.adb (moved) * testsuites/ada/tmtests/tmck/tmtest.ads (moved) * testsuites/ada/tmtests/tmoverhd/Makefile.am (moved) * testsuites/ada/tmtests/tmoverhd/README (moved) * testsuites/ada/tmtests/tmoverhd/config.h (moved) * testsuites/ada/tmtests/tmoverhd/dummy_rtems.adb (moved) * testsuites/ada/tmtests/tmoverhd/dummy_rtems.ads (moved) * testsuites/ada/tmtests/tmoverhd/tmoverhd.adb (moved) * testsuites/ada/tmtests/tmoverhd/tmtest.adb (moved) * testsuites/ada/tmtests/tmoverhd/tmtest.ads (moved) * testsuites/configure.ac (modified) ada-tests: Move to testsuites/ada This solves a build dependency ...
