# # ChangeLog for testsuites/aclocal/env-rtemsbsp.m4 in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 11:48:16 Sun, 13 Nov 2005 06:23:34 GMT Ralf Corsepius [5c193c2] * testsuites/aclocal/env-rtemsbsp.m4 (modified) Remove project_libdir. Remove project_includedir. Add rtems_testsdir. Wed, 09 Nov 2005 09:30:22 GMT Ralf Corsepius [703e81b] * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/automake/compile.am (modified) Assume PROJECT_ROOT to contain RTEMS_BSP. Tue, 08 Nov 2005 10:48:39 GMT Ralf Corsepius [e7642162] * testsuites/aclocal/env-rtemsbsp.m4 (modified) Remove GCCSPECS. Tue, 08 Nov 2005 07:33:38 GMT Ralf Corsepius [40b0086d] * testsuites/aclocal/env-rtemsbsp.m4 (modified) Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. Tue, 08 Nov 2005 06:05:48 GMT Ralf Corsepius [01ad78c] * testsuites/aclocal/env-rtemsbsp.m4 (modified) Don't provide MULTILIB conditional. Thu, 06 Jan 2005 14:56:27 GMT Ralf Corsepius [a4b8a37d] * testsuites/ChangeLog (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) 2004-01-06 Ralf Corsepius * ... Thu, 19 Feb 2004 05:40:02 GMT Ralf Corsepius [17ad82c] * testsuites/ChangeLog (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/configure.ac (modified) 2004-02-18 Ralf Corsepius * ... Mon, 15 Dec 2003 07:27:36 GMT Ralf Corsepius [d7e0507] * testsuites/ChangeLog (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/automake/compile.am (modified) 2003-12-15 Ralf Corsepius * ... Fri, 12 Dec 2003 16:14:32 GMT Ralf Corsepius [55f441e3] * testsuites/ChangeLog (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/lead-dot.m4 (deleted) 2003-12-12 Ralf Corsepius * ... Wed, 26 Nov 2003 06:21:00 GMT Ralf Corsepius [0e8262cf] * testsuites/ChangeLog (modified) * testsuites/aclocal/canonical-target-name.m4 (modified) * testsuites/aclocal/canonicalize-tools.m4 (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/check-cxx.m4 (modified) * testsuites/aclocal/check-itron.m4 (modified) * testsuites/aclocal/check-multiprocessing.m4 (modified) * testsuites/aclocal/check-networking.m4 (modified) * testsuites/aclocal/check-posix.m4 (modified) * testsuites/aclocal/check-tool.m4 (modified) * testsuites/aclocal/config-subdirs.m4 (modified) * testsuites/aclocal/enable-bare.m4 (modified) * testsuites/aclocal/enable-cxx.m4 (modified) * testsuites/aclocal/enable-itron.m4 (modified) * testsuites/aclocal/enable-multiprocessing.m4 (modified) * testsuites/aclocal/enable-networking.m4 (modified) * testsuites/aclocal/enable-posix.m4 (modified) * testsuites/aclocal/enable-rtemsbsp.m4 (modified) * testsuites/aclocal/enable-tests.m4 (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/gcc-isystem.m4 (modified) * testsuites/aclocal/gcc-pipe.m4 (modified) * testsuites/aclocal/gcc-specs.m4 (modified) * testsuites/aclocal/multilib.m4 (modified) * testsuites/aclocal/path-ksh.m4 (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/aclocal/rtems-test-no-pause.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/aclocal/target.m4 (modified) * testsuites/aclocal/tool-paths.m4 (modified) 2003-11-26 Ralf Corsepius * ... Mon, 18 Aug 2003 05:40:53 GMT Ralf Corsepius [3c69a774] * c/src/tests/ChangeLog (modified) * c/src/tests/aclocal/bsp-alias.m4 (added) * c/src/tests/aclocal/canonical-host.m4 (added) * c/src/tests/aclocal/canonical-target-name.m4 (added) * c/src/tests/aclocal/canonicalize-tools.m4 (added) * c/src/tests/aclocal/check-cpu.m4 (added) * c/src/tests/aclocal/check-custom-bsp.m4 (added) * c/src/tests/aclocal/check-cxx.m4 (added) * c/src/tests/aclocal/check-itron.m4 (added) * c/src/tests/aclocal/check-multiprocessing.m4 (added) * c/src/tests/aclocal/check-networking.m4 (added) * c/src/tests/aclocal/check-posix.m4 (added) * c/src/tests/aclocal/check-tool.m4 (added) * c/src/tests/aclocal/config-subdirs.m4 (added) * c/src/tests/aclocal/enable-bare.m4 (added) * c/src/tests/aclocal/enable-cxx.m4 (added) * c/src/tests/aclocal/enable-itron.m4 (added) * c/src/tests/aclocal/enable-multiprocessing.m4 (added) * c/src/tests/aclocal/enable-networking.m4 (added) * c/src/tests/aclocal/enable-posix.m4 (added) * c/src/tests/aclocal/enable-rtemsbsp.m4 (added) * c/src/tests/aclocal/enable-tests.m4 (added) * c/src/tests/aclocal/env-rtemsbsp.m4 (added) * c/src/tests/aclocal/gcc-isystem.m4 (added) * c/src/tests/aclocal/gcc-pipe.m4 (added) * c/src/tests/aclocal/gcc-specs.m4 (added) * c/src/tests/aclocal/multilib.m4 (added) * c/src/tests/aclocal/path-ksh.m4 (added) * c/src/tests/aclocal/prog-cc.m4 (added) * c/src/tests/aclocal/prog-cxx.m4 (added) * c/src/tests/aclocal/project-root.m4 (added) * c/src/tests/aclocal/quoting.m4 (added) * c/src/tests/aclocal/rtems-cpu-subdirs.m4 (added) * c/src/tests/aclocal/rtems-flags.m4 (added) * c/src/tests/aclocal/rtems-test-no-pause.m4 (added) * c/src/tests/aclocal/rtems-top.m4 (added) * c/src/tests/aclocal/target.m4 (added) * c/src/tests/aclocal/tool-paths.m4 (added) * c/src/tests/aclocal/version.m4 (added) * testsuites/ChangeLog (modified) * testsuites/aclocal/canonical-target-name.m4 (added) * testsuites/aclocal/canonicalize-tools.m4 (added) * testsuites/aclocal/check-custom-bsp.m4 (added) * testsuites/aclocal/check-cxx.m4 (added) * testsuites/aclocal/check-itron.m4 (added) * testsuites/aclocal/check-multiprocessing.m4 (added) * testsuites/aclocal/check-networking.m4 (added) * testsuites/aclocal/check-posix.m4 (added) * testsuites/aclocal/check-tool.m4 (added) * testsuites/aclocal/config-subdirs.m4 (added) * testsuites/aclocal/enable-bare.m4 (added) * testsuites/aclocal/enable-cxx.m4 (added) * testsuites/aclocal/enable-itron.m4 (added) * testsuites/aclocal/enable-multiprocessing.m4 (added) * testsuites/aclocal/enable-networking.m4 (added) * testsuites/aclocal/enable-posix.m4 (added) * testsuites/aclocal/enable-rtemsbsp.m4 (added) * testsuites/aclocal/enable-tests.m4 (added) * testsuites/aclocal/env-rtemsbsp.m4 (added) * testsuites/aclocal/gcc-isystem.m4 (added) * testsuites/aclocal/gcc-pipe.m4 (added) * testsuites/aclocal/gcc-specs.m4 (added) * testsuites/aclocal/multilib.m4 (added) * testsuites/aclocal/path-ksh.m4 (added) * testsuites/aclocal/prog-cc.m4 (added) * testsuites/aclocal/prog-cxx.m4 (added) * testsuites/aclocal/project-root.m4 (added) * testsuites/aclocal/quoting.m4 (added) * testsuites/aclocal/rtems-cpu-subdirs.m4 (added) * testsuites/aclocal/rtems-flags.m4 (added) * testsuites/aclocal/rtems-test-no-pause.m4 (added) * testsuites/aclocal/rtems-top.m4 (added) * testsuites/aclocal/target.m4 (added) * testsuites/aclocal/tool-paths.m4 (added) * testsuites/aclocal/version.m4 (added) 2003-08-17 Ralf Corsepius * ...
