# # ChangeLog for spec in rtems # # Generated by Trac 1.2.1.dev0 # 05/22/24 03:10:21 Mon, 14 Mar 2022 14:04:51 GMT Sebastian Huber [9abcaae] * bsps/include/dev/irq/arm-gicv3.h (added) * bsps/shared/dev/irq/arm-gicv3.c (modified) * spec/build/bsps/aarch64/grp.yml (modified) * spec/build/bsps/arm/grp.yml (modified) bsps: Add Separate the Interrupt Manager ... Wed, 06 Oct 2021 06:13:00 GMT Sebastian Huber [c1a6e62] * spec/build/testsuites/unit/unit-no-clock-0.yml (modified) * testsuites/unit/tc-score-rbtree.c (added) unit: Test red-black trees Thu, 17 Sep 2020 11:11:47 GMT Sebastian Huber [7ca6eeee] * spec/build/testsuites/unit/unit-no-clock-0.yml (modified) * testsuites/unit/tc-misaligned-builtin-memcpy.c (added) unit: Add test for misaligned builtin memcpy() Thu, 17 Sep 2020 11:10:41 GMT Sebastian Huber [95e3ade] * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/grp.yml (modified) * spec/build/testsuites/optunit.yml (added) * spec/build/testsuites/unit/grp.yml (added) * spec/build/testsuites/unit/unit-no-clock-0.yml (added) * testsuites/unit/ts-unit-no-clock-0.c (added) unit: Add a unit test suite Wed, 06 Apr 2022 07:36:38 GMT Sebastian Huber [39439d4] * spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml (modified) bsp/stm32h7: Disable some tests for a variant Making this BSP a ... Tue, 05 Apr 2022 12:16:07 GMT Karel Gardas [282fba3] * spec/build/bsps/arm/stm32h7/optlinkcmds.yml (modified) bsps/stm32h7: link to flash on STM32H7B3I-DK The patch is needed ... Fri, 01 Apr 2022 16:14:15 GMT Karel Gardas [bf64ff2] * spec/build/bsps/arm/stm32h7/optvariant.yml (modified) bsp/stm32h7: use appropriate STM32H7B3xxQ define for STM32H7B3I-DK ... Fri, 01 Apr 2022 16:14:14 GMT Karel Gardas [2414d9b1] * spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram2sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram3sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram4sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsramaxisz.yml (modified) bsp/stm32h7: configure S(D)RAM values for STM32H7B3I-DK BSP variant ... Fri, 01 Apr 2022 16:14:13 GMT Karel Gardas [c2e4128f] * spec/build/bsps/arm/stm32h7/opthse.yml (modified) bsp/stm32h7: HSE clock value configuration for STM32H7B3I-DK BSP variant Fri, 01 Apr 2022 16:14:12 GMT Karel Gardas [c48bedd] * bsps/arm/stm32h7/start/stm32h7-config-fls.c (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/optmemflashlatency.yml (added) bsp/stm32h7: add flash latency configuration Fri, 01 Apr 2022 16:14:11 GMT Karel Gardas [0acc1360] * bsps/arm/stm32h7/console/console-usart1-cfg.c (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml (added) * spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml (added) * spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml (added) bsp/stm32h7: add configuration for USART1 GPIO pins, registers and ... Fri, 01 Apr 2022 16:14:10 GMT Karel Gardas [51db61a] * spec/build/bsps/arm/stm32h7/optenuart5.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart7.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart8.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart9.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart10.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart3.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart6.yml (modified) bsp/stm32h7: disable UART 5, 7, 8, 9 and USART 3, 6, 10 for ... Fri, 01 Apr 2022 16:14:09 GMT Karel Gardas [044bc3c] * bsps/arm/stm32h7/start/bspstarthooks.c (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/optpwrsupply.yml (added) bsp/stm32h7: add power supply configuration Fri, 01 Apr 2022 16:14:08 GMT Karel Gardas [1050b629] * spec/build/bsps/arm/stm32h7/bspstm32h7b3i-dk.yml (added) bsp/stm32h7: add spec file for the STM32H7B3I-DK BSP variant Tue, 29 Mar 2022 13:23:29 GMT Sebastian Huber [9f9f140] * cpukit/include/rtems/rtems/tasks.h (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-task-smp.c (added) * testsuites/validation/tc-task.c (modified) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) rtems: Clarify scheduler of created task Tue, 29 Mar 2022 14:31:25 GMT Sebastian Huber [c2d7376] * spec/build/testsuites/validation/libvalidation.yml (modified) * testsuites/validation/tc-barrier-ident.c (modified) * testsuites/validation/tc-message-ident.c (modified) * testsuites/validation/tc-part-ident.c (modified) * testsuites/validation/tc-ratemon-ident.c (modified) * testsuites/validation/tc-sem-ident.c (modified) * testsuites/validation/tc-task-ident.c (modified) * testsuites/validation/tc-timer-ident.c (modified) * testsuites/validation/tc-userext-ident.c (modified) * testsuites/validation/tr-object-ident-local.c (modified) * testsuites/validation/tr-object-ident-local.h (modified) * testsuites/validation/tr-object-ident.c (modified) * testsuites/validation/tr-object-ident.h (modified) * testsuites/validation/tx-default-task-config.c (added) * testsuites/validation/tx-support.h (modified) validation: Use individual names for ident tests Make the task ... Thu, 10 Mar 2022 13:11:12 GMT Sebastian Huber [3661518] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml (added) * spec/build/testsuites/validation/grp.yml (modified) * testsuites/validation/tr-fatal-start-on-not-online-processor.c (added) * testsuites/validation/tr-fatal-start-on-not-online-processor.h (added) * testsuites/validation/ts-fatal-start-on-not-online-processor.c (added) smp: Add fatal error Add SMP-specifc ... Thu, 09 Dec 2021 15:25:29 GMT Sebastian Huber [14de245d] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-support-is-name-valid.c (added) * testsuites/validation/tc-support.c (added) validation: Test support functions The test source code is ... Thu, 09 Dec 2021 15:25:12 GMT Sebastian Huber [ab2c04a] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-tls-0.yml (added) * spec/build/testsuites/validation/validation-tls-1.yml (added) * testsuites/validation/tc-score-thread-tls-max-zero.c (added) * testsuites/validation/tc-score-thread-tls.c (added) * testsuites/validation/tc-score-thread.c (added) * testsuites/validation/ts-validation-tls-0.c (added) * testsuites/validation/ts-validation-tls-1.c (added) validation: Test thread implementation The test source code is ... Thu, 09 Dec 2021 15:24:46 GMT Sebastian Huber [4a8f4b7] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-smp-one-cpu-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-score-smp-per-cpu-jobs.c (added) * testsuites/validation/tc-score-smp-thread.c (added) * testsuites/validation/tc-score-thread-smp-one-cpu.c (added) * testsuites/validation/ts-validation-smp-one-cpu-0.c (added) validation: Test SMP-specific aspects The test source code is ... Thu, 09 Dec 2021 15:22:28 GMT Sebastian Huber [ff50664] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-sched-smp-edf-set-affinity.c (added) * testsuites/validation/tc-sched-smp-edf.c (added) * testsuites/validation/tc-sched-smp.c (added) * testsuites/validation/tc-sched-yield.c (added) validation: Test scheduler operations The test source code is ... Thu, 09 Dec 2021 15:22:11 GMT Sebastian Huber [9f283e7] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-c.c (added) * testsuites/validation/tc-flsl.c (added) validation: Test C libary functions The test source code is ... Thu, 09 Dec 2021 15:21:26 GMT Sebastian Huber [c24747a6] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-sys-lock.c (added) validation: Test mutex operations The test source code ... Thu, 09 Dec 2021 15:21:08 GMT Sebastian Huber [5fb7ce8] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-futex-wait.c (added) * testsuites/validation/tc-futex-wake.c (added) validation: Test futex support The test source code is generated ... Thu, 09 Dec 2021 15:20:45 GMT Sebastian Huber [fa660c4d] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-status-is-equal.c (added) * testsuites/validation/tc-status-is-successful.c (added) * testsuites/validation/tc-status-text.c (added) * testsuites/validation/tc-status.c (added) validation: Test status code directives The test source code is ... Thu, 09 Dec 2021 15:19:41 GMT Sebastian Huber [7eb4fc8d] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-timecounter-0.yml (added) * spec/build/testsuites/validation/validation-timecounter-1.yml (added) * spec/build/testsuites/validation/validation-timecounter-smp-0.yml (added) * testsuites/validation/tc-timecounter-get-smp.c (added) * testsuites/validation/tc-timecounter-get.c (added) * testsuites/validation/tc-timecounter-install.c (added) * testsuites/validation/ts-validation-timecounter-0.c (added) * testsuites/validation/ts-validation-timecounter-1.c (added) * testsuites/validation/ts-validation-timecounter-smp-0.c (added) validation: Test timecounter The test source code is generated from ... Thu, 09 Dec 2021 15:19:24 GMT Sebastian Huber [bc0cd69] * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-object.c (modified) * testsuites/validation/tc-type.c (added) validation: Test object services The test source code is generated ... Thu, 09 Dec 2021 15:17:23 GMT Sebastian Huber [c88db0f] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/userext.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-userext-create.c (added) * testsuites/validation/tc-userext-delete.c (added) * testsuites/validation/tc-userext-ident.c (added) * testsuites/validation/ts-userext.c (added) validation: Test User Extensions Manager The test source code is ... Thu, 09 Dec 2021 15:17:07 GMT Frank Kühndel [565a7e66] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-timer-cancel.c (added) * testsuites/validation/tc-timer-create.c (added) * testsuites/validation/tc-timer-delete.c (added) * testsuites/validation/tc-timer-fire-after.c (added) * testsuites/validation/tc-timer-fire-when.c (added) * testsuites/validation/tc-timer-ident.c (added) * testsuites/validation/tc-timer-initiate-server.c (added) * testsuites/validation/tc-timer-reset.c (added) * testsuites/validation/tc-timer-server-fire-after.c (added) * testsuites/validation/tc-timer-server-fire-when.c (added) * testsuites/validation/tc-timer.c (added) validation: Test Timer Manager The test source code is generated ... Tue, 07 Sep 2021 11:56:42 GMT Sebastian Huber [6b293904] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-1.yml (added) * testsuites/validation/tc-task-construct-errors.c (deleted) * testsuites/validation/tc-task-construct.c (added) * testsuites/validation/tc-task-create-errors.c (modified) * testsuites/validation/tc-task-delete.c (added) * testsuites/validation/tc-task-exit.c (added) * testsuites/validation/tc-task-get-affinity.c (added) * testsuites/validation/tc-task-get-priority.c (added) * testsuites/validation/tc-task-get-scheduler.c (added) * testsuites/validation/tc-task-ident.c (added) * testsuites/validation/tc-task-is-suspended.c (added) * testsuites/validation/tc-task-mode.c (added) * testsuites/validation/tc-task-performance.c (added) * testsuites/validation/tc-task-restart.c (added) * testsuites/validation/tc-task-resume.c (added) * testsuites/validation/tc-task-set-affinity.c (added) * testsuites/validation/tc-task-set-priority.c (added) * testsuites/validation/tc-task-set-scheduler.c (added) * testsuites/validation/tc-task-start.c (added) * testsuites/validation/tc-task-storage-size.c (added) * testsuites/validation/tc-task-suspend.c (added) * testsuites/validation/tc-task-wake-after.c (added) * testsuites/validation/tc-task-wake-when.c (added) * testsuites/validation/tc-task.c (added) * testsuites/validation/ts-validation-one-cpu-1.c (added) validation: Test Task Manager The test source code is generated ... Tue, 07 Sep 2021 11:56:42 GMT Sebastian Huber [32e472a7] * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tc-signals.c (added) * testsuites/validation/tr-signal-constant.c (added) * testsuites/validation/tr-signal-constant.h (added) validation: Test Signal Manager The test source code is generated ... Thu, 09 Dec 2021 15:16:34 GMT Sebastian Huber [43adf2e] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-sem-create.c (added) * testsuites/validation/tc-sem-delete.c (added) * testsuites/validation/tc-sem-flush.c (added) * testsuites/validation/tc-sem-ident.c (added) * testsuites/validation/tc-sem-mrsp-obtain.c (added) * testsuites/validation/tc-sem-obtain.c (added) * testsuites/validation/tc-sem-performance.c (added) * testsuites/validation/tc-sem-release.c (added) * testsuites/validation/tc-sem-set-priority.c (added) * testsuites/validation/tc-sem-smp.c (added) * testsuites/validation/tc-sem-timeout.c (added) * testsuites/validation/tc-sem-uni.c (added) validation: Test Semaphore Manager The test source code is ... Thu, 09 Dec 2021 15:15:46 GMT Sebastian Huber [1c87bb5] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-scheduler-add-processor.c (added) * testsuites/validation/tc-scheduler-get-maximum-priority.c (added) * testsuites/validation/tc-scheduler-get-processor-set.c (added) * testsuites/validation/tc-scheduler-ident-by-processor-set.c (added) * testsuites/validation/tc-scheduler-ident-by-processor.c (added) * testsuites/validation/tc-scheduler-ident.c (added) * testsuites/validation/tc-scheduler-non-smp.c (added) * testsuites/validation/tc-scheduler-remove-processor.c (added) * testsuites/validation/tc-scheduler-smp-only.c (added) * testsuites/validation/tc-scheduler.c (added) validation: Test Scheduler Manager The test source code is ... Thu, 09 Dec 2021 15:14:37 GMT Frank Kühndel [98091b6d] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * testsuites/validation/tc-ratemon-cancel.c (added) * testsuites/validation/tc-ratemon-create.c (added) * testsuites/validation/tc-ratemon-delete.c (added) * testsuites/validation/tc-ratemon-get-status.c (added) * testsuites/validation/tc-ratemon-ident.c (added) * testsuites/validation/tc-ratemon-period.c (added) * testsuites/validation/tc-ratemon-timeout.c (added) validation: Test Rate Monotonic Manager The test source code is ... Thu, 09 Dec 2021 15:14:24 GMT Sebastian Huber [5c85024] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-part-create.c (added) * testsuites/validation/tc-part-delete.c (added) * testsuites/validation/tc-part-get.c (added) * testsuites/validation/tc-part-ident.c (added) * testsuites/validation/tc-part-performance.c (modified) * testsuites/validation/tc-part-return.c (added) * testsuites/validation/tc-part.c (added) validation: Test Partition Manager The test source code is ... Thu, 09 Dec 2021 15:14:08 GMT Sebastian Huber [372ff26] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-options.c (added) validation: Test options The test source code is generated from ... Thu, 09 Dec 2021 15:13:58 GMT Sebastian Huber [b63084a] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-modes.c (added) validation: Test task modes The test source code is generated from ... Thu, 09 Dec 2021 15:12:55 GMT Frank Kühndel [04fb7b6] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-message-broadcast.c (added) * testsuites/validation/tc-message-construct-errors.c (deleted) * testsuites/validation/tc-message-construct.c (added) * testsuites/validation/tc-message-delete.c (added) * testsuites/validation/tc-message-flush-pending.c (added) * testsuites/validation/tc-message-ident.c (added) * testsuites/validation/tc-message-macros.c (added) * testsuites/validation/tc-message-performance.c (added) * testsuites/validation/tc-message-receive.c (added) * testsuites/validation/tc-message-urgent-send.c (added) validation: Test Message Manager The test source code is generated ... Thu, 09 Dec 2021 15:12:23 GMT Sebastian Huber [134b4cb7] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-io-kernel.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-io-getchark.c (added) * testsuites/validation/tc-io-put-char.c (added) * testsuites/validation/tc-io-putc.c (added) * testsuites/validation/tr-io-kernel.c (added) * testsuites/validation/tr-io-kernel.h (added) * testsuites/validation/ts-validation-io-kernel.c (added) validation: Test IO Manager The test source code is generated from ... Thu, 02 Sep 2021 13:29:10 GMT Sebastian Huber [aebf6b6] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-intr.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-bsp-interrupt-spurious.c (added) * testsuites/validation/tc-intr-clear.c (modified) * testsuites/validation/tc-intr-entry-install.c (modified) * testsuites/validation/tc-intr-entry-remove.c (modified) * testsuites/validation/tc-intr-get-affinity.c (modified) * testsuites/validation/tc-intr-get-attributes.c (modified) * testsuites/validation/tc-intr-handler-iterate.c (modified) * testsuites/validation/tc-intr-is-pending.c (modified) * testsuites/validation/tc-intr-non-smp.c (added) * testsuites/validation/tc-intr-raise-on.c (modified) * testsuites/validation/tc-intr-raise.c (modified) * testsuites/validation/tc-intr-set-affinity.c (modified) * testsuites/validation/tc-intr-smp-only.c (added) * testsuites/validation/tc-intr-vector-disable.c (modified) * testsuites/validation/tc-intr-vector-enable.c (modified) * testsuites/validation/tc-intr-vector-is-enabled.c (modified) * testsuites/validation/tc-intr.c (added) * testsuites/validation/ts-validation-intr.c (added) validation: Test Interrupt Manager The test source code is ... Thu, 09 Dec 2021 15:11:43 GMT Sebastian Huber [8d3fe04] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-event-performance.c (added) * testsuites/validation/tc-event-send-receive.c (added) * testsuites/validation/tc-events.c (added) * testsuites/validation/tr-event-constant.c (added) * testsuites/validation/tr-event-constant.h (added) * testsuites/validation/tr-event-send-receive.c (added) * testsuites/validation/tr-event-send-receive.h (added) validation: Test Event Manager The test source code is generated ... Thu, 09 Dec 2021 15:11:08 GMT Sebastian Huber [32ca0c47] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-cpuuse.c (added) validation: Test rtems_cpu_usage_reset() The test source code is ... Thu, 09 Dec 2021 15:10:46 GMT Frank Kühndel [034d0b2] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-clock-get-tod.c (added) * testsuites/validation/tc-clock-get-uptime.c (added) * testsuites/validation/tc-clock-nanosleep.c (added) * testsuites/validation/tc-clock-set.c (added) * testsuites/validation/tc-clock.c (added) validation: Test Clock Manager The test source code is generated ... Thu, 09 Dec 2021 15:10:25 GMT Sebastian Huber [b322a3ba] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-cache.yml (added) * testsuites/validation/tc-cache.c (added) * testsuites/validation/ts-validation-cache.c (added) validation: Test Cache Manager The test source code is generated ... Thu, 09 Dec 2021 15:09:47 GMT Frank Kühndel [99544e3] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-basedefs-pendant.c (added) * testsuites/validation/tc-basedefs-pendant.h (added) * testsuites/validation/tc-basedefs.c (added) validation: Test The test source code is ... Thu, 15 Jul 2021 08:02:40 GMT Sebastian Huber [1410d5b8] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-ident.c (added) * testsuites/validation/tc-barrier-performance.c (added) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) validation: Test Barrier Manager The test source code is generated ... Thu, 09 Dec 2021 15:09:03 GMT Sebastian Huber [0b26e099] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-attr.c (added) validation: Test attributes The test source code is generated from ... Thu, 09 Dec 2021 15:08:42 GMT Sebastian Huber [ca4d9ea] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-acfg-0.yml (added) * spec/build/testsuites/validation/validation-acfg-1.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-acfg-appl-does-not-need-clock-driver.c (added) * testsuites/validation/tc-acfg-appl-needs-clock-driver.c (added) * testsuites/validation/tc-acfg-default.c (added) * testsuites/validation/tc-acfg-disabled-bsp-settings.c (added) * testsuites/validation/tc-acfg-one-cpu.c (added) * testsuites/validation/tc-acfg-scheduler-edf-smp.c (added) * testsuites/validation/tc-acfg.c (added) * testsuites/validation/ts-validation-acfg-0.c (added) * testsuites/validation/ts-validation-acfg-1.c (added) validation: Test application configuration The test source code is ... Thu, 09 Dec 2021 15:05:48 GMT Sebastian Huber [d9a07fd8] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-object-ident-local.c (added) * testsuites/validation/tr-object-ident-local.h (added) * testsuites/validation/tr-object-ident.c (added) * testsuites/validation/tr-object-ident.h (added) validation: Test object identification The test source code is ... Thu, 09 Dec 2021 15:05:27 GMT Sebastian Huber [a4b77184] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-mtx-seize-try.c (added) * testsuites/validation/tr-mtx-seize-try.h (added) * testsuites/validation/tr-mtx-seize-wait.c (added) * testsuites/validation/tr-mtx-seize-wait.h (added) * testsuites/validation/tr-mtx-surrender.c (added) * testsuites/validation/tr-mtx-surrender.h (added) validation: Test mutex operations The test source code is generated ... Thu, 09 Dec 2021 15:05:09 GMT Sebastian Huber [a6b4a3b0] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-sem-seize-try.c (added) * testsuites/validation/tr-sem-seize-try.h (added) * testsuites/validation/tr-sem-seize-wait.c (added) * testsuites/validation/tr-sem-seize-wait.h (added) * testsuites/validation/tr-sem-surrender.c (added) * testsuites/validation/tr-sem-surrender.h (added) validation: Test semaphore operations The test source code is ... Thu, 09 Dec 2021 15:02:20 GMT Sebastian Huber [7db4c14b] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-score-tq-smp.c (added) * testsuites/validation/tr-tq-enqueue-ceiling.c (added) * testsuites/validation/tr-tq-enqueue-ceiling.h (added) * testsuites/validation/tr-tq-enqueue-deadlock.c (added) * testsuites/validation/tr-tq-enqueue-deadlock.h (added) * testsuites/validation/tr-tq-enqueue-fifo.c (added) * testsuites/validation/tr-tq-enqueue-fifo.h (added) * testsuites/validation/tr-tq-enqueue-mrsp.c (added) * testsuites/validation/tr-tq-enqueue-mrsp.h (added) * testsuites/validation/tr-tq-enqueue-priority-inherit.c (added) * testsuites/validation/tr-tq-enqueue-priority-inherit.h (added) * testsuites/validation/tr-tq-enqueue-priority.c (added) * testsuites/validation/tr-tq-enqueue-priority.h (added) * testsuites/validation/tr-tq-flush-fifo.c (added) * testsuites/validation/tr-tq-flush-fifo.h (added) * testsuites/validation/tr-tq-flush-priority-inherit.c (added) * testsuites/validation/tr-tq-flush-priority-inherit.h (added) * testsuites/validation/tr-tq-flush-priority.c (added) * testsuites/validation/tr-tq-flush-priority.h (added) * testsuites/validation/tr-tq-surrender-mrsp.c (added) * testsuites/validation/tr-tq-surrender-mrsp.h (added) * testsuites/validation/tr-tq-surrender-priority-inherit.c (added) * testsuites/validation/tr-tq-surrender-priority-inherit.h (added) * testsuites/validation/tr-tq-surrender.c (added) * testsuites/validation/tr-tq-surrender.h (added) * testsuites/validation/tr-tq-timeout-mrsp.c (added) * testsuites/validation/tr-tq-timeout-mrsp.h (added) * testsuites/validation/tr-tq-timeout-priority-inherit.c (added) * testsuites/validation/tr-tq-timeout-priority-inherit.h (added) * testsuites/validation/tr-tq-timeout.c (added) * testsuites/validation/tr-tq-timeout.h (added) validation: Test thread queues The test source code is generated ... Fri, 10 Dec 2021 08:41:22 GMT Sebastian Huber [c39133b8] * spec/build/testsuites/validation/fatal-boot-processor-not-assigned-to-scheduler.yml (added) * spec/build/testsuites/validation/fatal-init-task-construct-failed.yml (added) * spec/build/testsuites/validation/fatal-mandatory-processor-not-present.yml (added) * spec/build/testsuites/validation/fatal-scheduler-requires-exactly-one-processor.yml (added) * spec/build/testsuites/validation/fatal-smp.yml (added) * spec/build/testsuites/validation/fatal-start-of-mandatory-processor-failed.yml (added) * spec/build/testsuites/validation/fatal-too-large-tls-size.yml (added) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/terminate.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-2.yml (added) * testsuites/validation/tc-score-fatal.c (added) * testsuites/validation/tc-start-of-optional-processor-failed.c (added) * testsuites/validation/tc-terminate.c (added) * testsuites/validation/tc-userext.c (added) * testsuites/validation/tc-userext.h (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.h (added) * testsuites/validation/tr-fatal-init-task-construct-failed.c (added) * testsuites/validation/tr-fatal-init-task-construct-failed.h (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.h (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.h (added) * testsuites/validation/tr-fatal-smp.c (added) * testsuites/validation/tr-fatal-smp.h (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.h (added) * testsuites/validation/tr-fatal-too-large-tls-size.c (added) * testsuites/validation/tr-fatal-too-large-tls-size.h (added) * testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/ts-fatal-init-task-construct-failed.c (added) * testsuites/validation/ts-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/ts-fatal-smp.c (added) * testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/ts-fatal-sysinit.h (added) * testsuites/validation/ts-fatal-too-large-tls-size.c (added) * testsuites/validation/ts-terminate.c (added) * testsuites/validation/ts-validation-smp-only-2.c (added) validation: Add system termination test suites The test source code ... Thu, 09 Dec 2021 14:58:14 GMT Sebastian Huber [212b0ca] * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (modified) * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/tst-xfail-val.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) * spec/build/bsps/tst-xfail-intr.yml (added) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/performance-no-clock-0.yml (moved) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (added) * spec/build/testsuites/validation/validation-one-cpu-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-1.yml (added) * testsuites/validation/ts-acfg.h (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-idle.h (added) * testsuites/validation/ts-performance-no-clock-0.c (moved) * testsuites/validation/ts-validation-1.c (modified) * testsuites/validation/ts-validation-no-clock-0.c (added) * testsuites/validation/ts-validation-non-smp.c (added) * testsuites/validation/ts-validation-one-cpu-0.c (added) * testsuites/validation/ts-validation-smp-only-0.c (added) * testsuites/validation/ts-validation-smp-only-1.c (added) validation: Add test suites The test source code is generated from ... Thu, 09 Dec 2021 14:49:53 GMT Sebastian Huber [40cc4f5] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/libvalidation.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (added) * testsuites/validation/tc-intr-entry-install.c (modified) * testsuites/validation/tc-intr-entry-remove.c (modified) * testsuites/validation/tc-intr-handler-iterate.c (modified) * testsuites/validation/ts-config.h (added) * testsuites/validation/tx-interrupt.c (modified) * testsuites/validation/tx-io-relax.c (added) * testsuites/validation/tx-memory-alloc.c (added) * testsuites/validation/tx-preemption-intervention.c (added) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) * testsuites/validation/tx-thread-queue.c (added) * testsuites/validation/tx-thread-queue.h (added) * testsuites/validation/tx-timecounter.c (added) * testsuites/validation/tx-timer-server.c (added) * testsuites/validation/tx-wrap-thread-queue.c (added) validation: Improve support library Update #3716. Thu, 08 Apr 2021 06:18:20 GMT Sebastian Huber [cc1c944] * cpukit/include/rtems/test-scheduler.h (added) * cpukit/libtest/t-test-scheduler.c (added) * spec/build/cpukit/librtemstest.yml (modified) libtest: Add scheduler test support Add support to record scheduler ... Thu, 15 Jul 2021 14:51:17 GMT Sebastian Huber [d0de6fd] * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iorelax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add _IO_Relax() This function may be used to burn a couple ... Wed, 23 Mar 2022 16:17:56 GMT Sebastian Huber [5b1b2aa] * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) build: Exclude rcxx01 test for sh BSPs There seems to be a code ... Wed, 16 Feb 2022 19:32:30 GMT Alex White [14381c4] * bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c (added) * bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h (added) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml (added) microblaze: Add JFFS2 AXI QSPI driver This driver has been tested ... Wed, 26 Jan 2022 09:59:02 GMT Sebastian Huber [1a23ee6] * spec/build/bsps/arm/fvp/linkcmds.yml (modified) bsp/fvp: Use only vector table of start section Tue, 08 Mar 2022 08:22:43 GMT Sebastian Huber [b08ba92] * spec/build/testsuites/smptests/grp.yml (modified) * spec/build/testsuites/smptests/smpstart01.yml (added) * testsuites/smptests/smpstart01/init.c (added) * testsuites/smptests/smpstart01/smpstart01.doc (added) smptests/smpstart01: New test program Update #4627. Fri, 25 Feb 2022 14:02:05 GMT Sebastian Huber [3cf618b3] * spec/build/bsps/riscv/linkcmdsbase.yml (modified) bsps/riscv: Support .riscv.attributes Wed, 23 Feb 2022 16:11:34 GMT Kinsey Moore [fa944c5] * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml (added) spec/microblaze: Use configurable RAM size When committed, the ... Wed, 26 Jan 2022 16:57:49 GMT Kinsey Moore [3317d1e] * cpukit/libdebugger/rtems-debugger-microblaze.c (added) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/objdbgmicroblaze.yml (added) * spec/build/cpukit/optlibdebugger.yml (modified) cpukit/libdebugger: Add MicroBlaze support Add MicroBlaze support ... Mon, 07 Feb 2022 15:10:45 GMT Sebastian Huber [8f1e8f8f] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timex.h (modified) * cpukit/posix/src/adjtime.c (deleted) * cpukit/score/src/kern_ntptime.c (modified) * cpukit/score/src/kern_tc.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (added) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/sptests/spntp01/init.c (added) kern_ntptime.c: Port to RTEMS Remove previous adjtime() ... Wed, 26 Jan 2022 16:56:54 GMT Kinsey Moore [ace9955] * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.S (added) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.c (added) * spec/build/cpukit/cpumicroblaze.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) cpukit/microblaze: Add exception extensions Add the functions ... Wed, 26 Jan 2022 16:33:31 GMT Kinsey Moore [530a8c2] * bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S (added) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add debug vector and handler This patch adds a ... Wed, 26 Jan 2022 16:18:46 GMT Kinsey Moore [127980c] * bsps/microblaze/microblaze_fpga/start/_exception_handler.S (modified) * bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S (deleted) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add exception framework This patch updates the ... Thu, 23 Dec 2021 23:33:39 GMT Alex White [37543e19] * bsps/microblaze/microblaze_fpga/dts/system.dts (modified) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (modified) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * bsps/microblaze/microblaze_fpga/include/bsp/microblaze-dtb.h (moved) * bsps/microblaze/microblaze_fpga/irq/irq.c (modified) * bsps/microblaze/microblaze_fpga/start/bspstart.c (modified) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S (added) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdtbheaderpath.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml (added) microblaze: Add support for libbsd networking This includes fixes ... Mon, 20 Dec 2021 16:55:41 GMT Jennifer Averett [50a6580] * bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c (added) * bsps/microblaze/microblaze_fpga/dts/system.dts (added) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (added) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) microblaze: Add support for libbsd. Fri, 28 Jan 2022 07:42:03 GMT Sebastian Huber [20ca3b09] * spec/build/bsps/sparc/grp.yml (modified) sparc: Mark dl06 as expected fail Wed, 26 Jan 2022 22:00:04 GMT Kinsey Moore [b539af8] * cpukit/libmisc/stackchk/check.c (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/stackchk02.yml (added) * testsuites/libtests/stackchk02/init.c (added) * testsuites/libtests/stackchk02/stackchk02.doc (added) * testsuites/libtests/stackchk02/stackchk02.scn (added) cpukit: Prevent error with disabled stack checker When the stack ... Wed, 26 Jan 2022 10:01:44 GMT Sebastian Huber [2145e0c7] * cpukit/include/rtems/gxx_wrappers.h (deleted) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/gxx01.yml (deleted) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal24.yml (deleted) * spec/build/testsuites/sptests/spfatal25.yml (deleted) * testsuites/libtests/gxx01/gxx01.doc (deleted) * testsuites/libtests/gxx01/gxx01.scn (deleted) * testsuites/libtests/gxx01/init.c (deleted) * testsuites/sptests/spfatal24/init.c (deleted) * testsuites/sptests/spfatal24/spfatal24.doc (deleted) * testsuites/sptests/spfatal24/spfatal24.scn (deleted) * testsuites/sptests/spfatal25/init.c (deleted) * testsuites/sptests/spfatal25/spfatal25.doc (deleted) * testsuites/sptests/spfatal25/spfatal25.scn (deleted) Remove obsolete rtems_gxx_*() implementation GCC versions prior to ... Sat, 15 Jan 2022 18:45:46 GMT Sebastian Huber [4e530464] * bsps/shared/dev/btimer/btimer-stub.c (deleted) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) bsps: Default to CPU counter benchmark timer Most BSPs which used ... Fri, 14 Jan 2022 15:06:44 GMT Sebastian Huber [944c210] * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/tst-xfail-dl06.yml (added) bsp/imx7: dl06 fails expectedly Thu, 06 Jan 2022 20:28:34 GMT Gedare Bloom [6c36cb7a] * bsps/aarch64/shared/start/start.S (modified) * bsps/aarch64/xilinx-versal/start/bspstarthooks.c (modified) * bsps/shared/dev/irq/arm-gicv3.c (modified) * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/optisns.yml (deleted) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) aarch64: always boot into EL1NS Always start the executive in ... Tue, 11 Jan 2022 15:15:51 GMT Sebastian Huber [b982b8d4] * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) build: Fix build item format Sat, 11 Dec 2021 10:43:44 GMT Sebastian Huber [18e47db5] * bsps/m68k/mrm332/start/linkcmds (modified) * spec/build/bsps/m68k/mrm332/tstmrm332.yml (modified) bsp/mrm332: Fix TLS support in linker command file Fri, 17 Dec 2021 16:25:52 GMT Joel Sherrill [e92bc254] * bsps/powerpc/haleakala/README (deleted) * bsps/powerpc/haleakala/config/haleakala.cfg (deleted) * bsps/powerpc/haleakala/include/bsp.h (deleted) * bsps/powerpc/haleakala/include/bsp/irq.h (deleted) * bsps/powerpc/haleakala/include/mmu_405.h (deleted) * bsps/powerpc/haleakala/include/tm27.h (deleted) * bsps/powerpc/haleakala/irq/irq.c (deleted) * bsps/powerpc/haleakala/irq/irq_init.c (deleted) * bsps/powerpc/haleakala/start/bspstart.c (deleted) * bsps/powerpc/haleakala/start/linkcmds (deleted) * bsps/powerpc/haleakala/start/mmu_405.c (deleted) * bsps/powerpc/haleakala/start/mmu_405asm.S (deleted) * bsps/powerpc/haleakala/start/start.S (deleted) * spec/build/bsps/optconsolebaud.yml (modified) * spec/build/bsps/powerpc/haleakala/abi.yml (deleted) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (deleted) * spec/build/bsps/powerpc/haleakala/optsprg.yml (deleted) * spec/build/bsps/powerpc/haleakala/optvecbase.yml (deleted) * spec/build/bsps/powerpc/haleakala/start.yml (deleted) Remove powerpc/haleakala board Closes #4302. Sat, 11 Dec 2021 10:44:44 GMT Sebastian Huber [2d75d5d] * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) bsps/arm: Add missing Cache Manager source file Thu, 09 Dec 2021 01:06:29 GMT Kinsey Moore [0f5fa026] * spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) spec: Update location of cadence I2C When the cadence I2C code was ... Thu, 09 Dec 2021 12:31:10 GMT Sebastian Huber [4c20360d] * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) build: Move test header to right library item Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Wed, 08 Apr 2020 15:14:41 GMT Sebastian Huber [d7205f0] * bsps/shared/start/mallocinitmulti.c (added) * bsps/shared/start/mallocinitone.c (added) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mallocinitmulti.h (added) * cpukit/include/rtems/mallocinitone.h (added) * cpukit/libcsupport/src/malloc_initialize.c (deleted) * cpukit/libcsupport/src/mallocheap.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/libtests/malloc04/init.c (modified) libc: Optimize malloc() initialization The BSPs provide memory for ... Wed, 08 Apr 2020 14:54:34 GMT Sebastian Huber [3d0620b] * bsps/shared/start/wkspaceinitmulti.c (added) * bsps/shared/start/wkspaceinitone.c (added) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (added) * cpukit/include/rtems/score/wkspaceinitone.h (added) * cpukit/score/src/wkspace.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) score: Optimize Workspace Handler initialization The BSPs provide ... Mon, 29 Nov 2021 07:35:43 GMT Sebastian Huber [2de3a6e] * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/a72/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/grp.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/csb336/bspcsb336.yml (modified) * spec/build/bsps/arm/csb337/grp.yml (modified) * spec/build/bsps/arm/csb337/obj.yml (modified) * spec/build/bsps/arm/edb7312/bspedb7312.yml (modified) * spec/build/bsps/arm/fvp/grp.yml (modified) * spec/build/bsps/arm/fvp/obj.yml (modified) * spec/build/bsps/arm/gumstix/bspgumstix.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/grp.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/lpc176x/grp.yml (modified) * spec/build/bsps/arm/lpc176x/obj.yml (modified) * spec/build/bsps/arm/lpc24xx/grp.yml (modified) * spec/build/bsps/arm/lpc24xx/obj.yml (modified) * spec/build/bsps/arm/lpc32xx/grp.yml (modified) * spec/build/bsps/arm/lpc32xx/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/rtl22xx/grp.yml (modified) * spec/build/bsps/arm/rtl22xx/obj.yml (modified) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (modified) * spec/build/bsps/arm/stm32f4/grp.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/tms570/grp.yml (modified) * spec/build/bsps/arm/tms570/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (modified) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (modified) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (modified) * spec/build/bsps/lm32/lm32_evr/grp.yml (modified) * spec/build/bsps/lm32/lm32_evr/obj.yml (modified) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (modified) * spec/build/bsps/m68k/av5282/bspav5282.yml (modified) * spec/build/bsps/m68k/csb360/bspcsb360.yml (modified) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (modified) * spec/build/bsps/m68k/gen68360/grp.yml (modified) * spec/build/bsps/m68k/gen68360/obj.yml (modified) * spec/build/bsps/m68k/genmcf548x/grp.yml (modified) * spec/build/bsps/m68k/genmcf548x/obj.yml (modified) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (modified) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (modified) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (modified) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (modified) * spec/build/bsps/m68k/mvme162/grp.yml (modified) * spec/build/bsps/m68k/mvme162/obj.yml (modified) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (modified) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/mips/csb350/bspcsb350.yml (modified) * spec/build/bsps/mips/hurricane/bsphurricane.yml (modified) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (modified) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (modified) * spec/build/bsps/objmem.yml (added) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/gen5200/grp.yml (modified) * spec/build/bsps/powerpc/gen5200/obj.yml (modified) * spec/build/bsps/powerpc/gen83xx/grp.yml (modified) * spec/build/bsps/powerpc/gen83xx/obj.yml (modified) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) * spec/build/bsps/powerpc/objmem.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (modified) * spec/build/bsps/powerpc/ss555/bspss555.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (modified) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (modified) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (modified) * spec/build/bsps/riscv/griscv/grp.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/riscv/riscv/grp.yml (modified) * spec/build/bsps/riscv/riscv/obj.yml (modified) * spec/build/bsps/sh/gensh1/bspgensh1.yml (modified) * spec/build/bsps/sh/gensh2/bspgensh2.yml (modified) * spec/build/bsps/sh/gensh4/bspgensh4.yml (modified) * spec/build/bsps/sh/shsim/grp.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/leon2/grp.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon3/grp.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (added) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/grp.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) build: Use common objects item for get memory Thu, 09 Apr 2020 07:31:28 GMT Sebastian Huber [0bd28da] * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceallocate.c (added) * cpukit/score/src/wkspacefree.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Split wkspace.c Splitting the file avoids unnecessary ... Thu, 25 Nov 2021 01:43:10 GMT Joel Sherrill [dd70c81] * bsps/arm/altera-cyclone-v/start/bsp_specs (deleted) * bsps/arm/atsam/start/bsp_specs (deleted) * bsps/arm/beagle/start/bsp_specs (deleted) * bsps/arm/csb336/start/bsp_specs (deleted) * bsps/arm/csb337/start/bsp_specs (deleted) * bsps/arm/edb7312/start/bsp_specs (deleted) * bsps/arm/gumstix/start/bsp_specs (deleted) * bsps/arm/imx/start/bsp_specs (deleted) * bsps/arm/lm3s69xx/start/bsp_specs (deleted) * bsps/arm/lpc176x/start/bsp_specs (deleted) * bsps/arm/lpc24xx/start/bsp_specs (deleted) * bsps/arm/lpc32xx/start/bsp_specs (deleted) * bsps/arm/raspberrypi/start/bsp_specs (deleted) * bsps/arm/realview-pbx-a9/start/bsp_specs (deleted) * bsps/arm/rtl22xx/start/bsp_specs (deleted) * bsps/arm/smdk2410/start/bsp_specs (deleted) * bsps/arm/stm32f4/start/bsp_specs (deleted) * bsps/arm/stm32h7/start/bsp_specs (deleted) * bsps/arm/tms570/start/bsp_specs (deleted) * bsps/arm/xen/start/bsp_specs (deleted) * bsps/arm/xilinx-zynq/start/bsp_specs (deleted) * bsps/arm/xilinx-zynqmp/start/bsp_specs (deleted) * bsps/bfin/TLL6527M/start/bsp_specs (deleted) * bsps/bfin/bf537Stamp/start/bsp_specs (deleted) * bsps/bfin/eZKit533/start/bsp_specs (deleted) * bsps/i386/pc386/start/bsp_specs (deleted) * bsps/lm32/lm32_evr/start/bsp_specs (deleted) * bsps/lm32/milkymist/start/bsp_specs (deleted) * bsps/m68k/av5282/start/bsp_specs (deleted) * bsps/m68k/csb360/start/bsp_specs (deleted) * bsps/m68k/gen68340/start/bsp_specs (deleted) * bsps/m68k/gen68360/start/bsp_specs (deleted) * bsps/m68k/genmcf548x/start/bsp_specs (deleted) * bsps/m68k/mcf5206elite/start/bsp_specs (deleted) * bsps/m68k/mcf52235/start/bsp_specs (deleted) * bsps/m68k/mcf5225x/start/bsp_specs (deleted) * bsps/m68k/mcf5235/start/bsp_specs (deleted) * bsps/m68k/mcf5329/start/bsp_specs (deleted) * bsps/m68k/mrm332/start/bsp_specs (deleted) * bsps/m68k/mvme147/start/bsp_specs (deleted) * bsps/m68k/mvme147s/start/bsp_specs (deleted) * bsps/m68k/mvme162/start/bsp_specs (deleted) * bsps/m68k/mvme167/start/bsp_specs (deleted) * bsps/m68k/uC5282/start/bsp_specs (deleted) * bsps/mips/csb350/start/bsp_specs (deleted) * bsps/mips/hurricane/start/bsp_specs (deleted) * bsps/mips/jmr3904/start/bsp_specs (deleted) * bsps/mips/malta/start/bsp_specs (deleted) * bsps/mips/rbtx4925/start/bsp_specs (deleted) * bsps/mips/rbtx4938/start/bsp_specs (deleted) * bsps/moxie/moxiesim/start/bsp_specs (deleted) * bsps/nios2/nios2_iss/start/bsp_specs (deleted) * bsps/no_cpu/no_bsp/start/bsp_specs (deleted) * bsps/or1k/generic_or1k/start/bsp_specs (deleted) * bsps/powerpc/beatnik/start/bsp_specs (deleted) * bsps/powerpc/gen5200/start/bsp_specs (deleted) * bsps/powerpc/gen83xx/start/bsp_specs (deleted) * bsps/powerpc/haleakala/start/bsp_specs (deleted) * bsps/powerpc/motorola_powerpc/start/bsp_specs (deleted) * bsps/powerpc/mpc55xxevb/start/bsp_specs (deleted) * bsps/powerpc/mpc8260ads/start/bsp_specs (deleted) * bsps/powerpc/mvme3100/start/bsp_specs (deleted) * bsps/powerpc/mvme5500/start/bsp_specs (deleted) * bsps/powerpc/psim/start/bsp_specs (deleted) * bsps/powerpc/qemuppc/start/bsp_specs (deleted) * bsps/powerpc/qoriq/start/bsp_specs (deleted) * bsps/powerpc/ss555/start/bsp_specs (deleted) * bsps/powerpc/t32mppc/start/bsp_specs (deleted) * bsps/powerpc/tqm8xx/start/bsp_specs (deleted) * bsps/powerpc/virtex/start/bsp_specs (deleted) * bsps/powerpc/virtex4/start/bsp_specs (deleted) * bsps/powerpc/virtex5/start/bsp_specs (deleted) * bsps/riscv/griscv/start/bsp_specs (deleted) * bsps/riscv/riscv/start/bsp_specs (deleted) * bsps/sh/gensh1/start/bsp_specs (deleted) * bsps/sh/gensh2/start/bsp_specs (deleted) * bsps/sh/gensh4/start/bsp_specs (deleted) * bsps/sh/shsim/start/bsp_specs (deleted) * bsps/sparc/erc32/start/bsp_specs (deleted) * bsps/sparc/leon2/start/bsp_specs (deleted) * bsps/sparc/leon3/start/bsp_specs (deleted) * bsps/sparc64/niagara/start/bsp_specs (deleted) * bsps/sparc64/usiii/start/bsp_specs (deleted) * bsps/v850/gdbv850sim/start/bsp_specs (deleted) * bsps/x86_64/amd64/start/bsp_specs (deleted) * spec/build/bsps/arm/stm32h7/obj.yml (modified) bsp_specs: Delete last remnants of these. Updates #3937. Mon, 29 Nov 2021 07:49:27 GMT Sebastian Huber [61d0df45] * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) build: Remove trailing white space Thu, 11 Nov 2021 08:00:03 GMT Sebastian Huber [2e56aab] * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_queue_Extract() Move _Thread_queue_Extract() ... Thu, 11 Nov 2021 07:35:22 GMT Sebastian Huber [50aef135] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadrestart.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objmpci.yml (modified) score: Add _Thread_MP_Extract_proxy() Remove ... Fri, 15 Oct 2021 09:21:31 GMT Sebastian Huber [3d6ebde1] * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulerdefaultmakecleansticky.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * spec/build/cpukit/objsmp.yml (modified) score: Add SMP scheduler make/clean sticky This patch fixes the ... Fri, 22 Oct 2021 05:31:46 GMT Sebastian Huber [577262a7] * cpukit/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtreeappend.c (added) * cpukit/score/src/rbtreeprepend.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add red-black tree append/prepend These functions are a ... Thu, 18 Nov 2021 06:59:04 GMT Sebastian Huber [18484f02] * cpukit/rtems/src/schedulergetprocessor.c (added) * cpukit/rtems/src/schedulergetprocessormax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Add external functions These external functions ... Mon, 15 Nov 2021 07:46:21 GMT Sebastian Huber [f06dd3e] * spec/build/cpukit/optvermaj.yml (modified) build: Optional __RTEMS_MAJOR__ via command line Update #4548. Mon, 15 Nov 2021 07:36:58 GMT Sebastian Huber [9551f340] * spec/build/cpukit/optvermaj.yml (modified) Revert "optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so ... Wed, 27 Oct 2021 10:59:09 GMT Sebastian Huber [240a1f7] * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadcpubudget.h (added) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaulttick.c (deleted) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadexhausttimeslice.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadresettimeslice.c (added) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/watchdogtick.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Introduce CPU budget operations This patch set replaces the ... Fri, 12 Nov 2021 14:59:19 GMT Joel Sherrill [d1bbfbe] * spec/build/cpukit/optvermaj.yml (modified) optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so RTEMS 7 ... Mon, 25 Oct 2021 17:19:13 GMT Kinsey Moore [a857a22] * bsps/aarch64/include/bsp/aarch64-mmu.h (modified) * cpukit/libdebugger/rtems-debugger-aarch64.c (added) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/objdbgaarch64.yml (added) * spec/build/cpukit/optlibdebugger.yml (modified) cpukit/aarch64: Add libdebugger support This adds support for ... Mon, 25 Oct 2021 14:47:47 GMT Kinsey Moore [2055e42] * bsps/aarch64/include/bsp/aarch64-mmu.h (modified) * bsps/aarch64/shared/mmu/vmsav8-64-nommu.c (added) * bsps/aarch64/shared/mmu/vmsav8-64.c (added) * bsps/aarch64/xilinx-versal/start/bspstartmmu.c (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c (modified) * cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h (added) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/a72/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/cpukit/cpuaarch64.yml (modified) aarch64: Break out MMU definitions This moves the AArch64 MMU ...
