# # ChangeLog for spec in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 10:49:37 Thu, 09 Dec 2021 15:09:47 GMT Frank Kühndel [99544e3] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-basedefs-pendant.c (added) * testsuites/validation/tc-basedefs-pendant.h (added) * testsuites/validation/tc-basedefs.c (added) validation: Test The test source code is ... Thu, 15 Jul 2021 08:02:40 GMT Sebastian Huber [1410d5b8] * spec/build/testsuites/validation/performance-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-ident.c (added) * testsuites/validation/tc-barrier-performance.c (added) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) validation: Test Barrier Manager The test source code is generated ... Thu, 09 Dec 2021 15:09:03 GMT Sebastian Huber [0b26e099] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tc-attr.c (added) validation: Test attributes The test source code is generated from ... Thu, 09 Dec 2021 15:08:42 GMT Sebastian Huber [ca4d9ea] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-acfg-0.yml (added) * spec/build/testsuites/validation/validation-acfg-1.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-acfg-appl-does-not-need-clock-driver.c (added) * testsuites/validation/tc-acfg-appl-needs-clock-driver.c (added) * testsuites/validation/tc-acfg-default.c (added) * testsuites/validation/tc-acfg-disabled-bsp-settings.c (added) * testsuites/validation/tc-acfg-one-cpu.c (added) * testsuites/validation/tc-acfg-scheduler-edf-smp.c (added) * testsuites/validation/tc-acfg.c (added) * testsuites/validation/ts-validation-acfg-0.c (added) * testsuites/validation/ts-validation-acfg-1.c (added) validation: Test application configuration The test source code is ... Thu, 09 Dec 2021 15:05:48 GMT Sebastian Huber [d9a07fd8] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-object-ident-local.c (added) * testsuites/validation/tr-object-ident-local.h (added) * testsuites/validation/tr-object-ident.c (added) * testsuites/validation/tr-object-ident.h (added) validation: Test object identification The test source code is ... Thu, 09 Dec 2021 15:05:27 GMT Sebastian Huber [a4b77184] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-mtx-seize-try.c (added) * testsuites/validation/tr-mtx-seize-try.h (added) * testsuites/validation/tr-mtx-seize-wait.c (added) * testsuites/validation/tr-mtx-seize-wait.h (added) * testsuites/validation/tr-mtx-surrender.c (added) * testsuites/validation/tr-mtx-surrender.h (added) validation: Test mutex operations The test source code is generated ... Thu, 09 Dec 2021 15:05:09 GMT Sebastian Huber [a6b4a3b0] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * testsuites/validation/tr-sem-seize-try.c (added) * testsuites/validation/tr-sem-seize-try.h (added) * testsuites/validation/tr-sem-seize-wait.c (added) * testsuites/validation/tr-sem-seize-wait.h (added) * testsuites/validation/tr-sem-surrender.c (added) * testsuites/validation/tr-sem-surrender.h (added) validation: Test semaphore operations The test source code is ... Thu, 09 Dec 2021 15:02:20 GMT Sebastian Huber [7db4c14b] * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-0.yml (modified) * testsuites/validation/tc-score-tq-smp.c (added) * testsuites/validation/tr-tq-enqueue-ceiling.c (added) * testsuites/validation/tr-tq-enqueue-ceiling.h (added) * testsuites/validation/tr-tq-enqueue-deadlock.c (added) * testsuites/validation/tr-tq-enqueue-deadlock.h (added) * testsuites/validation/tr-tq-enqueue-fifo.c (added) * testsuites/validation/tr-tq-enqueue-fifo.h (added) * testsuites/validation/tr-tq-enqueue-mrsp.c (added) * testsuites/validation/tr-tq-enqueue-mrsp.h (added) * testsuites/validation/tr-tq-enqueue-priority-inherit.c (added) * testsuites/validation/tr-tq-enqueue-priority-inherit.h (added) * testsuites/validation/tr-tq-enqueue-priority.c (added) * testsuites/validation/tr-tq-enqueue-priority.h (added) * testsuites/validation/tr-tq-flush-fifo.c (added) * testsuites/validation/tr-tq-flush-fifo.h (added) * testsuites/validation/tr-tq-flush-priority-inherit.c (added) * testsuites/validation/tr-tq-flush-priority-inherit.h (added) * testsuites/validation/tr-tq-flush-priority.c (added) * testsuites/validation/tr-tq-flush-priority.h (added) * testsuites/validation/tr-tq-surrender-mrsp.c (added) * testsuites/validation/tr-tq-surrender-mrsp.h (added) * testsuites/validation/tr-tq-surrender-priority-inherit.c (added) * testsuites/validation/tr-tq-surrender-priority-inherit.h (added) * testsuites/validation/tr-tq-surrender.c (added) * testsuites/validation/tr-tq-surrender.h (added) * testsuites/validation/tr-tq-timeout-mrsp.c (added) * testsuites/validation/tr-tq-timeout-mrsp.h (added) * testsuites/validation/tr-tq-timeout-priority-inherit.c (added) * testsuites/validation/tr-tq-timeout-priority-inherit.h (added) * testsuites/validation/tr-tq-timeout.c (added) * testsuites/validation/tr-tq-timeout.h (added) validation: Test thread queues The test source code is generated ... Fri, 10 Dec 2021 08:41:22 GMT Sebastian Huber [c39133b8] * spec/build/testsuites/validation/fatal-boot-processor-not-assigned-to-scheduler.yml (added) * spec/build/testsuites/validation/fatal-init-task-construct-failed.yml (added) * spec/build/testsuites/validation/fatal-mandatory-processor-not-present.yml (added) * spec/build/testsuites/validation/fatal-scheduler-requires-exactly-one-processor.yml (added) * spec/build/testsuites/validation/fatal-smp.yml (added) * spec/build/testsuites/validation/fatal-start-of-mandatory-processor-failed.yml (added) * spec/build/testsuites/validation/fatal-too-large-tls-size.yml (added) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/terminate.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-2.yml (added) * testsuites/validation/tc-score-fatal.c (added) * testsuites/validation/tc-start-of-optional-processor-failed.c (added) * testsuites/validation/tc-terminate.c (added) * testsuites/validation/tc-userext.c (added) * testsuites/validation/tc-userext.h (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.h (added) * testsuites/validation/tr-fatal-init-task-construct-failed.c (added) * testsuites/validation/tr-fatal-init-task-construct-failed.h (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.h (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.h (added) * testsuites/validation/tr-fatal-smp.c (added) * testsuites/validation/tr-fatal-smp.h (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.h (added) * testsuites/validation/tr-fatal-too-large-tls-size.c (added) * testsuites/validation/tr-fatal-too-large-tls-size.h (added) * testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/ts-fatal-init-task-construct-failed.c (added) * testsuites/validation/ts-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/ts-fatal-smp.c (added) * testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/ts-fatal-sysinit.h (added) * testsuites/validation/ts-fatal-too-large-tls-size.c (added) * testsuites/validation/ts-terminate.c (added) * testsuites/validation/ts-validation-smp-only-2.c (added) validation: Add system termination test suites The test source code ... Thu, 09 Dec 2021 14:58:14 GMT Sebastian Huber [212b0ca] * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (modified) * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/tst-xfail-val.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) * spec/build/bsps/tst-xfail-intr.yml (added) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/performance-no-clock-0.yml (moved) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (added) * spec/build/testsuites/validation/validation-one-cpu-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-1.yml (added) * testsuites/validation/ts-acfg.h (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-idle.h (added) * testsuites/validation/ts-performance-no-clock-0.c (moved) * testsuites/validation/ts-validation-1.c (modified) * testsuites/validation/ts-validation-no-clock-0.c (added) * testsuites/validation/ts-validation-non-smp.c (added) * testsuites/validation/ts-validation-one-cpu-0.c (added) * testsuites/validation/ts-validation-smp-only-0.c (added) * testsuites/validation/ts-validation-smp-only-1.c (added) validation: Add test suites The test source code is generated from ... Thu, 09 Dec 2021 14:49:53 GMT Sebastian Huber [40cc4f5] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/libvalidation.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (added) * testsuites/validation/tc-intr-entry-install.c (modified) * testsuites/validation/tc-intr-entry-remove.c (modified) * testsuites/validation/tc-intr-handler-iterate.c (modified) * testsuites/validation/ts-config.h (added) * testsuites/validation/tx-interrupt.c (modified) * testsuites/validation/tx-io-relax.c (added) * testsuites/validation/tx-memory-alloc.c (added) * testsuites/validation/tx-preemption-intervention.c (added) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) * testsuites/validation/tx-thread-queue.c (added) * testsuites/validation/tx-thread-queue.h (added) * testsuites/validation/tx-timecounter.c (added) * testsuites/validation/tx-timer-server.c (added) * testsuites/validation/tx-wrap-thread-queue.c (added) validation: Improve support library Update #3716. Thu, 08 Apr 2021 06:18:20 GMT Sebastian Huber [cc1c944] * cpukit/include/rtems/test-scheduler.h (added) * cpukit/libtest/t-test-scheduler.c (added) * spec/build/cpukit/librtemstest.yml (modified) libtest: Add scheduler test support Add support to record scheduler ... Thu, 15 Jul 2021 14:51:17 GMT Sebastian Huber [d0de6fd] * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iorelax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add _IO_Relax() This function may be used to burn a couple ... Wed, 23 Mar 2022 16:17:56 GMT Sebastian Huber [5b1b2aa] * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) build: Exclude rcxx01 test for sh BSPs There seems to be a code ... Wed, 16 Feb 2022 19:32:30 GMT Alex White [14381c4] * bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c (added) * bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h (added) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml (added) microblaze: Add JFFS2 AXI QSPI driver This driver has been tested ... Wed, 26 Jan 2022 09:59:02 GMT Sebastian Huber [1a23ee6] * spec/build/bsps/arm/fvp/linkcmds.yml (modified) bsp/fvp: Use only vector table of start section Tue, 08 Mar 2022 08:22:43 GMT Sebastian Huber [b08ba92] * spec/build/testsuites/smptests/grp.yml (modified) * spec/build/testsuites/smptests/smpstart01.yml (added) * testsuites/smptests/smpstart01/init.c (added) * testsuites/smptests/smpstart01/smpstart01.doc (added) smptests/smpstart01: New test program Update #4627. Fri, 25 Feb 2022 14:02:05 GMT Sebastian Huber [3cf618b3] * spec/build/bsps/riscv/linkcmdsbase.yml (modified) bsps/riscv: Support .riscv.attributes Wed, 23 Feb 2022 16:11:34 GMT Kinsey Moore [fa944c5] * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml (added) spec/microblaze: Use configurable RAM size When committed, the ... Wed, 26 Jan 2022 16:57:49 GMT Kinsey Moore [3317d1e] * cpukit/libdebugger/rtems-debugger-microblaze.c (added) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/objdbgmicroblaze.yml (added) * spec/build/cpukit/optlibdebugger.yml (modified) cpukit/libdebugger: Add MicroBlaze support Add MicroBlaze support ... Mon, 07 Feb 2022 15:10:45 GMT Sebastian Huber [8f1e8f8f] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/include/sys/timex.h (modified) * cpukit/posix/src/adjtime.c (deleted) * cpukit/score/src/kern_ntptime.c (modified) * cpukit/score/src/kern_tc.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spntp01.yml (added) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/sptests/spntp01/init.c (added) kern_ntptime.c: Port to RTEMS Remove previous adjtime() ... Wed, 26 Jan 2022 16:56:54 GMT Kinsey Moore [ace9955] * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.S (added) * cpukit/score/cpu/microblaze/microblaze-exception-extensions.c (added) * spec/build/cpukit/cpumicroblaze.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) cpukit/microblaze: Add exception extensions Add the functions ... Wed, 26 Jan 2022 16:33:31 GMT Kinsey Moore [530a8c2] * bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S (added) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add debug vector and handler This patch adds a ... Wed, 26 Jan 2022 16:18:46 GMT Kinsey Moore [127980c] * bsps/microblaze/microblaze_fpga/start/_exception_handler.S (modified) * bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S (deleted) * bsps/microblaze/shared/start/start.S (modified) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) cpukit/microblaze: Add exception framework This patch updates the ... Thu, 23 Dec 2021 23:33:39 GMT Alex White [37543e19] * bsps/microblaze/microblaze_fpga/dts/system.dts (modified) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (modified) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * bsps/microblaze/microblaze_fpga/include/bsp/microblaze-dtb.h (moved) * bsps/microblaze/microblaze_fpga/irq/irq.c (modified) * bsps/microblaze/microblaze_fpga/start/bspstart.c (modified) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S (added) * bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S (added) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optdtbheaderpath.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml (added) microblaze: Add support for libbsd networking This includes fixes ... Mon, 20 Dec 2021 16:55:41 GMT Jennifer Averett [50a6580] * bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c (added) * bsps/microblaze/microblaze_fpga/dts/system.dts (added) * bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c (added) * bsps/microblaze/microblaze_fpga/include/bsp.h (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) microblaze: Add support for libbsd. Fri, 28 Jan 2022 07:42:03 GMT Sebastian Huber [20ca3b09] * spec/build/bsps/sparc/grp.yml (modified) sparc: Mark dl06 as expected fail Wed, 26 Jan 2022 22:00:04 GMT Kinsey Moore [b539af8] * cpukit/libmisc/stackchk/check.c (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/stackchk02.yml (added) * testsuites/libtests/stackchk02/init.c (added) * testsuites/libtests/stackchk02/stackchk02.doc (added) * testsuites/libtests/stackchk02/stackchk02.scn (added) cpukit: Prevent error with disabled stack checker When the stack ... Wed, 26 Jan 2022 10:01:44 GMT Sebastian Huber [2145e0c7] * cpukit/include/rtems/gxx_wrappers.h (deleted) * cpukit/include/rtems/score/interr.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/gxx01.yml (deleted) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal24.yml (deleted) * spec/build/testsuites/sptests/spfatal25.yml (deleted) * testsuites/libtests/gxx01/gxx01.doc (deleted) * testsuites/libtests/gxx01/gxx01.scn (deleted) * testsuites/libtests/gxx01/init.c (deleted) * testsuites/sptests/spfatal24/init.c (deleted) * testsuites/sptests/spfatal24/spfatal24.doc (deleted) * testsuites/sptests/spfatal24/spfatal24.scn (deleted) * testsuites/sptests/spfatal25/init.c (deleted) * testsuites/sptests/spfatal25/spfatal25.doc (deleted) * testsuites/sptests/spfatal25/spfatal25.scn (deleted) Remove obsolete rtems_gxx_*() implementation GCC versions prior to ... Sat, 15 Jan 2022 18:45:46 GMT Sebastian Huber [4e530464] * bsps/shared/dev/btimer/btimer-stub.c (deleted) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) bsps: Default to CPU counter benchmark timer Most BSPs which used ... Fri, 14 Jan 2022 15:06:44 GMT Sebastian Huber [944c210] * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/tst-xfail-dl06.yml (added) bsp/imx7: dl06 fails expectedly Thu, 06 Jan 2022 20:28:34 GMT Gedare Bloom [6c36cb7a] * bsps/aarch64/shared/start/start.S (modified) * bsps/aarch64/xilinx-versal/start/bspstarthooks.c (modified) * bsps/shared/dev/irq/arm-gicv3.c (modified) * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/optisns.yml (deleted) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) aarch64: always boot into EL1NS Always start the executive in ... Tue, 11 Jan 2022 15:15:51 GMT Sebastian Huber [b982b8d4] * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) build: Fix build item format Sat, 11 Dec 2021 10:43:44 GMT Sebastian Huber [18e47db5] * bsps/m68k/mrm332/start/linkcmds (modified) * spec/build/bsps/m68k/mrm332/tstmrm332.yml (modified) bsp/mrm332: Fix TLS support in linker command file Fri, 17 Dec 2021 16:25:52 GMT Joel Sherrill [e92bc254] * bsps/powerpc/haleakala/README (deleted) * bsps/powerpc/haleakala/config/haleakala.cfg (deleted) * bsps/powerpc/haleakala/include/bsp.h (deleted) * bsps/powerpc/haleakala/include/bsp/irq.h (deleted) * bsps/powerpc/haleakala/include/mmu_405.h (deleted) * bsps/powerpc/haleakala/include/tm27.h (deleted) * bsps/powerpc/haleakala/irq/irq.c (deleted) * bsps/powerpc/haleakala/irq/irq_init.c (deleted) * bsps/powerpc/haleakala/start/bspstart.c (deleted) * bsps/powerpc/haleakala/start/linkcmds (deleted) * bsps/powerpc/haleakala/start/mmu_405.c (deleted) * bsps/powerpc/haleakala/start/mmu_405asm.S (deleted) * bsps/powerpc/haleakala/start/start.S (deleted) * spec/build/bsps/optconsolebaud.yml (modified) * spec/build/bsps/powerpc/haleakala/abi.yml (deleted) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (deleted) * spec/build/bsps/powerpc/haleakala/optsprg.yml (deleted) * spec/build/bsps/powerpc/haleakala/optvecbase.yml (deleted) * spec/build/bsps/powerpc/haleakala/start.yml (deleted) Remove powerpc/haleakala board Closes #4302. Sat, 11 Dec 2021 10:44:44 GMT Sebastian Huber [2d75d5d] * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) bsps/arm: Add missing Cache Manager source file Thu, 09 Dec 2021 01:06:29 GMT Kinsey Moore [0f5fa026] * spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) spec: Update location of cadence I2C When the cadence I2C code was ... Thu, 09 Dec 2021 12:31:10 GMT Sebastian Huber [4c20360d] * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) build: Move test header to right library item Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Wed, 08 Apr 2020 15:14:41 GMT Sebastian Huber [d7205f0] * bsps/shared/start/mallocinitmulti.c (added) * bsps/shared/start/mallocinitone.c (added) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mallocinitmulti.h (added) * cpukit/include/rtems/mallocinitone.h (added) * cpukit/libcsupport/src/malloc_initialize.c (deleted) * cpukit/libcsupport/src/mallocheap.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/libtests/malloc04/init.c (modified) libc: Optimize malloc() initialization The BSPs provide memory for ... Wed, 08 Apr 2020 14:54:34 GMT Sebastian Huber [3d0620b] * bsps/shared/start/wkspaceinitmulti.c (added) * bsps/shared/start/wkspaceinitone.c (added) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (added) * cpukit/include/rtems/score/wkspaceinitone.h (added) * cpukit/score/src/wkspace.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) score: Optimize Workspace Handler initialization The BSPs provide ... Mon, 29 Nov 2021 07:35:43 GMT Sebastian Huber [2de3a6e] * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/a72/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/grp.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/csb336/bspcsb336.yml (modified) * spec/build/bsps/arm/csb337/grp.yml (modified) * spec/build/bsps/arm/csb337/obj.yml (modified) * spec/build/bsps/arm/edb7312/bspedb7312.yml (modified) * spec/build/bsps/arm/fvp/grp.yml (modified) * spec/build/bsps/arm/fvp/obj.yml (modified) * spec/build/bsps/arm/gumstix/bspgumstix.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/grp.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/lpc176x/grp.yml (modified) * spec/build/bsps/arm/lpc176x/obj.yml (modified) * spec/build/bsps/arm/lpc24xx/grp.yml (modified) * spec/build/bsps/arm/lpc24xx/obj.yml (modified) * spec/build/bsps/arm/lpc32xx/grp.yml (modified) * spec/build/bsps/arm/lpc32xx/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/rtl22xx/grp.yml (modified) * spec/build/bsps/arm/rtl22xx/obj.yml (modified) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (modified) * spec/build/bsps/arm/stm32f4/grp.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/tms570/grp.yml (modified) * spec/build/bsps/arm/tms570/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (modified) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (modified) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (modified) * spec/build/bsps/lm32/lm32_evr/grp.yml (modified) * spec/build/bsps/lm32/lm32_evr/obj.yml (modified) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (modified) * spec/build/bsps/m68k/av5282/bspav5282.yml (modified) * spec/build/bsps/m68k/csb360/bspcsb360.yml (modified) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (modified) * spec/build/bsps/m68k/gen68360/grp.yml (modified) * spec/build/bsps/m68k/gen68360/obj.yml (modified) * spec/build/bsps/m68k/genmcf548x/grp.yml (modified) * spec/build/bsps/m68k/genmcf548x/obj.yml (modified) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (modified) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (modified) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (modified) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (modified) * spec/build/bsps/m68k/mvme162/grp.yml (modified) * spec/build/bsps/m68k/mvme162/obj.yml (modified) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (modified) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/mips/csb350/bspcsb350.yml (modified) * spec/build/bsps/mips/hurricane/bsphurricane.yml (modified) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (modified) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (modified) * spec/build/bsps/objmem.yml (added) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/gen5200/grp.yml (modified) * spec/build/bsps/powerpc/gen5200/obj.yml (modified) * spec/build/bsps/powerpc/gen83xx/grp.yml (modified) * spec/build/bsps/powerpc/gen83xx/obj.yml (modified) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) * spec/build/bsps/powerpc/objmem.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (modified) * spec/build/bsps/powerpc/ss555/bspss555.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (modified) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (modified) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (modified) * spec/build/bsps/riscv/griscv/grp.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/riscv/riscv/grp.yml (modified) * spec/build/bsps/riscv/riscv/obj.yml (modified) * spec/build/bsps/sh/gensh1/bspgensh1.yml (modified) * spec/build/bsps/sh/gensh2/bspgensh2.yml (modified) * spec/build/bsps/sh/gensh4/bspgensh4.yml (modified) * spec/build/bsps/sh/shsim/grp.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/leon2/grp.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon3/grp.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (added) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/grp.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) build: Use common objects item for get memory Thu, 09 Apr 2020 07:31:28 GMT Sebastian Huber [0bd28da] * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceallocate.c (added) * cpukit/score/src/wkspacefree.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Split wkspace.c Splitting the file avoids unnecessary ... Thu, 25 Nov 2021 01:43:10 GMT Joel Sherrill [dd70c81] * bsps/arm/altera-cyclone-v/start/bsp_specs (deleted) * bsps/arm/atsam/start/bsp_specs (deleted) * bsps/arm/beagle/start/bsp_specs (deleted) * bsps/arm/csb336/start/bsp_specs (deleted) * bsps/arm/csb337/start/bsp_specs (deleted) * bsps/arm/edb7312/start/bsp_specs (deleted) * bsps/arm/gumstix/start/bsp_specs (deleted) * bsps/arm/imx/start/bsp_specs (deleted) * bsps/arm/lm3s69xx/start/bsp_specs (deleted) * bsps/arm/lpc176x/start/bsp_specs (deleted) * bsps/arm/lpc24xx/start/bsp_specs (deleted) * bsps/arm/lpc32xx/start/bsp_specs (deleted) * bsps/arm/raspberrypi/start/bsp_specs (deleted) * bsps/arm/realview-pbx-a9/start/bsp_specs (deleted) * bsps/arm/rtl22xx/start/bsp_specs (deleted) * bsps/arm/smdk2410/start/bsp_specs (deleted) * bsps/arm/stm32f4/start/bsp_specs (deleted) * bsps/arm/stm32h7/start/bsp_specs (deleted) * bsps/arm/tms570/start/bsp_specs (deleted) * bsps/arm/xen/start/bsp_specs (deleted) * bsps/arm/xilinx-zynq/start/bsp_specs (deleted) * bsps/arm/xilinx-zynqmp/start/bsp_specs (deleted) * bsps/bfin/TLL6527M/start/bsp_specs (deleted) * bsps/bfin/bf537Stamp/start/bsp_specs (deleted) * bsps/bfin/eZKit533/start/bsp_specs (deleted) * bsps/i386/pc386/start/bsp_specs (deleted) * bsps/lm32/lm32_evr/start/bsp_specs (deleted) * bsps/lm32/milkymist/start/bsp_specs (deleted) * bsps/m68k/av5282/start/bsp_specs (deleted) * bsps/m68k/csb360/start/bsp_specs (deleted) * bsps/m68k/gen68340/start/bsp_specs (deleted) * bsps/m68k/gen68360/start/bsp_specs (deleted) * bsps/m68k/genmcf548x/start/bsp_specs (deleted) * bsps/m68k/mcf5206elite/start/bsp_specs (deleted) * bsps/m68k/mcf52235/start/bsp_specs (deleted) * bsps/m68k/mcf5225x/start/bsp_specs (deleted) * bsps/m68k/mcf5235/start/bsp_specs (deleted) * bsps/m68k/mcf5329/start/bsp_specs (deleted) * bsps/m68k/mrm332/start/bsp_specs (deleted) * bsps/m68k/mvme147/start/bsp_specs (deleted) * bsps/m68k/mvme147s/start/bsp_specs (deleted) * bsps/m68k/mvme162/start/bsp_specs (deleted) * bsps/m68k/mvme167/start/bsp_specs (deleted) * bsps/m68k/uC5282/start/bsp_specs (deleted) * bsps/mips/csb350/start/bsp_specs (deleted) * bsps/mips/hurricane/start/bsp_specs (deleted) * bsps/mips/jmr3904/start/bsp_specs (deleted) * bsps/mips/malta/start/bsp_specs (deleted) * bsps/mips/rbtx4925/start/bsp_specs (deleted) * bsps/mips/rbtx4938/start/bsp_specs (deleted) * bsps/moxie/moxiesim/start/bsp_specs (deleted) * bsps/nios2/nios2_iss/start/bsp_specs (deleted) * bsps/no_cpu/no_bsp/start/bsp_specs (deleted) * bsps/or1k/generic_or1k/start/bsp_specs (deleted) * bsps/powerpc/beatnik/start/bsp_specs (deleted) * bsps/powerpc/gen5200/start/bsp_specs (deleted) * bsps/powerpc/gen83xx/start/bsp_specs (deleted) * bsps/powerpc/haleakala/start/bsp_specs (deleted) * bsps/powerpc/motorola_powerpc/start/bsp_specs (deleted) * bsps/powerpc/mpc55xxevb/start/bsp_specs (deleted) * bsps/powerpc/mpc8260ads/start/bsp_specs (deleted) * bsps/powerpc/mvme3100/start/bsp_specs (deleted) * bsps/powerpc/mvme5500/start/bsp_specs (deleted) * bsps/powerpc/psim/start/bsp_specs (deleted) * bsps/powerpc/qemuppc/start/bsp_specs (deleted) * bsps/powerpc/qoriq/start/bsp_specs (deleted) * bsps/powerpc/ss555/start/bsp_specs (deleted) * bsps/powerpc/t32mppc/start/bsp_specs (deleted) * bsps/powerpc/tqm8xx/start/bsp_specs (deleted) * bsps/powerpc/virtex/start/bsp_specs (deleted) * bsps/powerpc/virtex4/start/bsp_specs (deleted) * bsps/powerpc/virtex5/start/bsp_specs (deleted) * bsps/riscv/griscv/start/bsp_specs (deleted) * bsps/riscv/riscv/start/bsp_specs (deleted) * bsps/sh/gensh1/start/bsp_specs (deleted) * bsps/sh/gensh2/start/bsp_specs (deleted) * bsps/sh/gensh4/start/bsp_specs (deleted) * bsps/sh/shsim/start/bsp_specs (deleted) * bsps/sparc/erc32/start/bsp_specs (deleted) * bsps/sparc/leon2/start/bsp_specs (deleted) * bsps/sparc/leon3/start/bsp_specs (deleted) * bsps/sparc64/niagara/start/bsp_specs (deleted) * bsps/sparc64/usiii/start/bsp_specs (deleted) * bsps/v850/gdbv850sim/start/bsp_specs (deleted) * bsps/x86_64/amd64/start/bsp_specs (deleted) * spec/build/bsps/arm/stm32h7/obj.yml (modified) bsp_specs: Delete last remnants of these. Updates #3937. Mon, 29 Nov 2021 07:49:27 GMT Sebastian Huber [61d0df45] * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) build: Remove trailing white space Thu, 11 Nov 2021 08:00:03 GMT Sebastian Huber [2e56aab] * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_queue_Extract() Move _Thread_queue_Extract() ... Thu, 11 Nov 2021 07:35:22 GMT Sebastian Huber [50aef135] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadrestart.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objmpci.yml (modified) score: Add _Thread_MP_Extract_proxy() Remove ... Fri, 15 Oct 2021 09:21:31 GMT Sebastian Huber [3d6ebde1] * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulerdefaultmakecleansticky.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * spec/build/cpukit/objsmp.yml (modified) score: Add SMP scheduler make/clean sticky This patch fixes the ... Fri, 22 Oct 2021 05:31:46 GMT Sebastian Huber [577262a7] * cpukit/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtreeappend.c (added) * cpukit/score/src/rbtreeprepend.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add red-black tree append/prepend These functions are a ... Thu, 18 Nov 2021 06:59:04 GMT Sebastian Huber [18484f02] * cpukit/rtems/src/schedulergetprocessor.c (added) * cpukit/rtems/src/schedulergetprocessormax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Add external functions These external functions ... Mon, 15 Nov 2021 07:46:21 GMT Sebastian Huber [f06dd3e] * spec/build/cpukit/optvermaj.yml (modified) build: Optional __RTEMS_MAJOR__ via command line Update #4548. Mon, 15 Nov 2021 07:36:58 GMT Sebastian Huber [9551f340] * spec/build/cpukit/optvermaj.yml (modified) Revert "optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so ... Wed, 27 Oct 2021 10:59:09 GMT Sebastian Huber [240a1f7] * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadcpubudget.h (added) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/schedulerdefaulttick.c (deleted) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadexhausttimeslice.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadresettimeslice.c (added) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/watchdogtick.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Introduce CPU budget operations This patch set replaces the ... Fri, 12 Nov 2021 14:59:19 GMT Joel Sherrill [d1bbfbe] * spec/build/cpukit/optvermaj.yml (modified) optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so RTEMS 7 ... Mon, 25 Oct 2021 17:19:13 GMT Kinsey Moore [a857a22] * bsps/aarch64/include/bsp/aarch64-mmu.h (modified) * cpukit/libdebugger/rtems-debugger-aarch64.c (added) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/objdbgaarch64.yml (added) * spec/build/cpukit/optlibdebugger.yml (modified) cpukit/aarch64: Add libdebugger support This adds support for ... Mon, 25 Oct 2021 14:47:47 GMT Kinsey Moore [2055e42] * bsps/aarch64/include/bsp/aarch64-mmu.h (modified) * bsps/aarch64/shared/mmu/vmsav8-64-nommu.c (added) * bsps/aarch64/shared/mmu/vmsav8-64.c (added) * bsps/aarch64/xilinx-versal/start/bspstartmmu.c (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c (modified) * cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h (added) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/a72/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/cpukit/cpuaarch64.yml (modified) aarch64: Break out MMU definitions This moves the AArch64 MMU ... Mon, 05 Apr 2021 20:14:22 GMT Kinsey Moore [c5986a5] * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtests/psxsignal09.yml (added) * testsuites/psxtests/psxsignal09/init.c (added) * testsuites/psxtests/psxsignal09/psxsignal09.doc (added) * testsuites/psxtests/psxsignal09/psxsignal09.scn (added) * testsuites/psxtests/psxsignal09/system.h (added) testsuite: Add machine exception signal map test Add a test to ... Tue, 06 Apr 2021 14:02:20 GMT Kinsey Moore [4812a8b5] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/extensions.h (modified) * cpukit/include/rtems/score/exception.h (added) * cpukit/score/src/exceptionmapping.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objexceptionmapping.yml (added) cpukit: Add signal mapping support This adds a confdef option ... Wed, 22 Sep 2021 21:17:14 GMT Kinsey Moore [3fc641ab] * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal35.yml (added) * testsuites/sptests/spfatal35/init.c (added) * testsuites/sptests/spfatal35/spfatal35.doc (added) * testsuites/sptests/spfatal35/spfatal35.scn (added) testsuite: Add machine exception resume test Add a test to verify ... Tue, 10 Aug 2021 13:09:37 GMT Kinsey Moore [02377c8] * cpukit/score/cpu/aarch64/aarch64-exception-default.S (modified) * cpukit/score/cpu/aarch64/aarch64-exception-default.c (modified) * cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) * spec/build/cpukit/optexceptionextensions.yml (modified) cpukit/aarch64: Add exception extensions support This adds the ... Tue, 10 Aug 2021 13:11:40 GMT Kinsey Moore [db9e885] * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * spec/build/cpukit/cpuopts.yml (modified) * spec/build/cpukit/optexceptionextensions.yml (added) cpukit: Add exception extensions This adds the set of functions ... Tue, 12 Oct 2021 06:26:39 GMT Sebastian Huber [0221da5f] * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadgetcputimeusedafterreset.c (added) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Fix rate monotonic statistics The rate monotonic period ... Thu, 21 Oct 2021 02:08:58 GMT Chris Johns [3f0ad2b] * spec/build/cpukit/cpuopts.yml (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/optlibdebugger.yml (added) * spec/build/testsuites/libtests/debugger01.yml (modified) spec/libdebugger: Only enable for supported architectures Closes #4533 Tue, 19 Oct 2021 20:50:49 GMT Kinsey Moore [087e4ec] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/a72/tsta72.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml (modified) spec/aarch64: Enable previously unbuildable tests The spconfig01 ... Fri, 01 Oct 2021 04:57:01 GMT Alex White [d03776e] * bsps/include/bsp/fatal.h (modified) * bsps/microblaze/include/bsp/linker-symbols.h (moved) * bsps/microblaze/include/common/xil_types.h (added) * bsps/microblaze/include/dev/serial/uartlite.h (added) * bsps/microblaze/include/dev/serial/uartlite_l.h (added) * bsps/microblaze/microblaze_fpga/clock/clock.c (added) * bsps/microblaze/microblaze_fpga/console/console-io.c (added) * bsps/microblaze/microblaze_fpga/console/debug-io.c (moved) * bsps/microblaze/microblaze_fpga/include/bsp.h (moved) * bsps/microblaze/microblaze_fpga/include/bsp/intc.h (added) * bsps/microblaze/microblaze_fpga/include/bsp/irq.h (added) * bsps/microblaze/microblaze_fpga/include/bsp/timer.h (added) * bsps/microblaze/microblaze_fpga/include/tm27.h (moved) * bsps/microblaze/microblaze_fpga/irq/irq.c (added) * bsps/microblaze/microblaze_fpga/start/_exception_handler.S (moved) * bsps/microblaze/microblaze_fpga/start/_hw_exception_handler.S (moved) * bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S (moved) * bsps/microblaze/microblaze_fpga/start/bspreset.c (added) * bsps/microblaze/microblaze_fpga/start/bspstart.c (added) * bsps/microblaze/microblaze_fpga/start/crtinit.S (added) * bsps/microblaze/shared/cache/cache.c (added) * bsps/microblaze/shared/dev/serial/uartlite.c (added) * bsps/microblaze/shared/dev/serial/uartlite_l.c (added) * bsps/microblaze/shared/start/start.S (moved) * c/src/lib/libbsp/microblaze/microblaze_fpga/startup/sim-crtinit.S (deleted) * cpukit/score/cpu/microblaze/__tls_get_addr.c (added) * cpukit/score/cpu/microblaze/cpu.c (modified) * cpukit/score/cpu/microblaze/cpu_asm.S (added) * cpukit/score/cpu/microblaze/include/rtems/asm.h (moved) * cpukit/score/cpu/microblaze/include/rtems/score/cpu.h (added) * cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/microblaze/include/rtems/score/microblaze.h (moved) * cpukit/score/cpu/microblaze/microblaze-context-switch.S (modified) * cpukit/score/cpu/microblaze/microblaze-context-validate.S (added) * cpukit/score/cpu/microblaze/microblaze-context-volatile-clobber.S (added) * cpukit/score/cpu/microblaze/rtems/score/cpu.h (deleted) * spec/build/bsps/microblaze/grp.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/abi.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/bspkcu105.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/bspkcu105_qemu.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optconsoleinterrupts.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optintcbaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opttimerbaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/opttimerfrequency.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/optuartlitebaseaddress.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/start.yml (added) * spec/build/bsps/microblaze/microblaze_fpga/tstkcu105_qemu.yml (added) * spec/build/cpukit/cpumicroblaze.yml (added) * spec/build/cpukit/librtemscpu.yml (modified) microblaze: Rework for RTEMS 6 This reworks the existing MicroBlaze ... Thu, 07 Oct 2021 22:28:26 GMT Joel Sherrill [822ebb4c] * cpukit/include/rtems/confdefs/percpu.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/score/src/stackallocatorforidle.c (added) * cpukit/score/src/threadcreateidle.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spstkalloc03.yml (added) * spec/build/testsuites/sptests/spstkalloc04.yml (added) * testsuites/sptests/spstkalloc03/init.c (added) * testsuites/sptests/spstkalloc03/spstkalloc03.doc (added) * testsuites/sptests/spstkalloc03/spstkalloc03.scn (added) * testsuites/sptests/spstkalloc04/init.c (added) * testsuites/sptests/spstkalloc04/spstkalloc04.doc (added) * testsuites/sptests/spstkalloc04/spstkalloc04.scn (added) Add support for IDLE Thread stack allocator Add a stack allocator ... Mon, 26 Jul 2021 20:43:00 GMT Kinsey Moore [5f652cb2] * bsps/aarch64/include/bsp/aarch64-mmu.h (modified) * bsps/aarch64/shared/start/aarch64-smp.c (added) * bsps/aarch64/shared/start/start.S (modified) * bsps/aarch64/xilinx-versal/start/bspstartmmu.c (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp.h (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c (modified) * cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S (modified) * cpukit/score/cpu/aarch64/cpu_asm.S (modified) * cpukit/score/cpu/aarch64/include/rtems/asm.h (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml (added) * spec/build/cpukit/optsmp.yml (modified) * testsuites/smptests/smpfatal08/init.c (modified) cpukit: Add AArch64 SMP Support This adds SMP support for AArch64 ... Sun, 19 Sep 2021 01:23:53 GMT Kinsey Moore [670a508] * bsps/shared/dev/irq/arm-gicv2-get-attributes.c (added) * bsps/shared/dev/irq/arm-gicv2-zynqmp.c (added) * bsps/shared/dev/irq/arm-gicv2.c (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) bsps/gicv2: Allow BSPs to define IRQ attributes ARM's GICv2 is ... Tue, 21 Sep 2021 05:37:54 GMT Sebastian Huber [0499845] * spec/build/bsps/arm/lpc24xx/bsplpc2362.yml (modified) * spec/build/bsps/arm/lpc24xx/bsplpc23xxtli800.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc2362.yml (deleted) * spec/build/bsps/arm/lpc24xx/tstlpc23xx.yml (moved) arm/lpc24xx: Use common test definition file Fri, 17 Sep 2021 06:30:57 GMT Sebastian Huber [cd198a5] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/score/src/schedulerdefaultaskforhelp.c (deleted) * spec/build/cpukit/objsmp.yml (modified) score: Remove unused default scheduler ops If SMP support is ... Fri, 17 Sep 2021 06:12:35 GMT Sebastian Huber [0036ddf] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulerdefaultpinunpin.c (modified) * cpukit/score/src/schedulerdefaultpinunpindonothing.c (added) * spec/build/cpukit/objsmp.yml (modified) score: Provide two thread pin/unpin defaults The uniprocessor ... Tue, 07 Sep 2021 03:16:13 GMT Alex White [0490be70] * spec/build/testsuites/ada/grp.yml (modified) * spec/build/testsuites/benchmarks/grp.yml (modified) * spec/build/testsuites/fstests/grp.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/mptests/grp.yml (modified) * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtmtests/grp.yml (modified) * spec/build/testsuites/rhealstone/grp.yml (modified) * spec/build/testsuites/samples/grp.yml (modified) * spec/build/testsuites/smptests/grp.yml (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/tmtests/grp.yml (modified) testsuites: Wrap putchar The linker flag to wrap putchar was lost ... Fri, 10 Sep 2021 11:33:53 GMT Sebastian Huber [c274009d] * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) build: Remove invalid attributes Tue, 14 Sep 2021 05:30:36 GMT Sebastian Huber [af722b7] * spec/build/bsps/arm/lpc24xx/abi.yml (modified) * spec/build/bsps/arm/stm32f4/abi.yml (modified) bsps/arm: Fix ABI flags for Cortex-M4 Close #4504. Mon, 23 Aug 2021 17:58:47 GMT Stephen Clark [7792ab8] * bsps/aarch64/xilinx-zynqmp/include/bsp.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h (added) * bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstart.c (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml (added) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml (added) * spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml (added) bsps/zynqmp: Added I2C support for ZynqMP Added I2C drivers for ... Mon, 23 Aug 2021 17:53:42 GMT Stephen Clark [73c182a] * bsps/include/dev/i2c/cadence-i2c-regs.h (moved) * bsps/include/dev/i2c/cadence-i2c.h (moved) * bsps/shared/dev/i2c/cadence-i2c.c (moved) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) bsps/zynq: Moved general i2c files to shared directories Certain ... Fri, 03 Sep 2021 14:33:21 GMT Sebastian Huber [f958d58] * cpukit/Makefile.am (modified) * cpukit/score/src/rbtreemax.c (added) * cpukit/score/src/rbtreemin.c (added) * cpukit/score/src/rbtreenext.c (modified) * cpukit/score/src/rbtreeprev.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Split up rbtreenext.c Split up rbtreenext.c since only ... Fri, 03 Sep 2021 07:46:36 GMT Sebastian Huber [54b4b1f8] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodcheck.c (added) * cpukit/score/src/coretodset.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) score: Add _TOD_Is_valid_new_time_of_day() Move the TOD validation ... Fri, 03 Sep 2021 07:36:55 GMT Sebastian Huber [c8e4de9] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretodtickspersec.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) score: Remove TOD_TICKS_PER_SECOND_method() Use ... Fri, 03 Sep 2021 15:14:19 GMT Sebastian Huber [fbd0a3ce] * cpukit/Makefile.am (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadplaindispatch.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_Dispatch() The _Thread_Dispatch() function was ... Sun, 15 Aug 2021 07:58:15 GMT Eshan dhawan [574cd83] * cpukit/Makefile.am (modified) * cpukit/posix/src/confstr.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtests/psxconfstr.yml (added) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxconfstr/init.c (added) * testsuites/psxtests/psxconfstr/psxconfstr.doc (added) * testsuites/psxtests/psxconfstr/psxconfstr.scn (added) confstr() support for RTEMS Closes #3373 confstr() style update ... Fri, 23 Jul 2021 06:45:07 GMT Sebastian Huber [ebdfa24b] * spec/build/bsps/aarch64/a53/abi.yml (modified) * spec/build/bsps/aarch64/a53/optloadoff.yml (modified) * spec/build/bsps/aarch64/a53/optnocachelen.yml (modified) * spec/build/bsps/aarch64/a53/optramlen.yml (modified) * spec/build/bsps/aarch64/a53/optramori.yml (modified) * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/a72/abi.yml (modified) * spec/build/bsps/aarch64/a72/optloadoff.yml (modified) * spec/build/bsps/aarch64/a72/optnocachelen.yml (modified) * spec/build/bsps/aarch64/a72/optramlen.yml (modified) * spec/build/bsps/aarch64/a72/optramori.yml (modified) * spec/build/bsps/aarch64/a72/tsta72.yml (modified) * spec/build/bsps/aarch64/optgtuseps.yml (modified) * spec/build/bsps/aarch64/optgtusevirt.yml (modified) * spec/build/bsps/aarch64/optisns.yml (modified) * spec/build/bsps/aarch64/optmmupages.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/abi.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optconminor.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optramlen.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/optramori.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optnocachelen.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optramlen.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstzu3eg.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/abi.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/opta9periphclk.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optcachedata.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optcacheinst.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optconcfg.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optconuart1.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optfdten.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/opti2cspeed.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optnoi2c.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optresetvec.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optuartbaud.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/optuartirq.yml (modified) * spec/build/bsps/arm/atsam/abi.yml (modified) * spec/build/bsps/arm/atsam/optchgclksram.yml (modified) * spec/build/bsps/arm/atsam/optchip.yml (modified) * spec/build/bsps/arm/atsam/optconbaud.yml (modified) * spec/build/bsps/arm/atsam/optconidx.yml (modified) * spec/build/bsps/arm/atsam/optconirq.yml (modified) * spec/build/bsps/arm/atsam/optcontype.yml (modified) * spec/build/bsps/arm/atsam/optmck.yml (modified) * spec/build/bsps/arm/atsam/optnocachesz.yml (modified) * spec/build/bsps/arm/atsam/optoscmain.yml (modified) * spec/build/bsps/arm/atsam/optqspiflashsz.yml (modified) * spec/build/bsps/arm/atsam/optsdram.yml (modified) * spec/build/bsps/arm/atsam/opttcmsz.yml (modified) * spec/build/bsps/arm/atsam/optusextal.yml (modified) * spec/build/bsps/arm/atsam/tstatsamv.yml (modified) * spec/build/bsps/arm/beagle/abi.yml (modified) * spec/build/bsps/arm/beagle/optam335x.yml (modified) * spec/build/bsps/arm/beagle/optconbaud.yml (modified) * spec/build/bsps/arm/beagle/optconpoll.yml (modified) * spec/build/bsps/arm/beagle/optdebug.yml (modified) * spec/build/bsps/arm/beagle/optdm3730.yml (modified) * spec/build/bsps/arm/csb336/abi.yml (modified) * spec/build/bsps/arm/csb337/abi.yml (modified) * spec/build/bsps/arm/csb337/optcsb637.yml (modified) * spec/build/bsps/arm/csb337/optenlcd.yml (modified) * spec/build/bsps/arm/csb337/optenumon.yml (modified) * spec/build/bsps/arm/csb337/optenumoncon.yml (modified) * spec/build/bsps/arm/csb337/optenusart0.yml (modified) * spec/build/bsps/arm/csb337/optenusart1.yml (modified) * spec/build/bsps/arm/csb337/optenusart2.yml (modified) * spec/build/bsps/arm/csb337/optenusart3.yml (modified) * spec/build/bsps/arm/edb7312/abi.yml (modified) * spec/build/bsps/arm/edb7312/optskyeye.yml (modified) * spec/build/bsps/arm/fvp/abi.yml (modified) * spec/build/bsps/arm/fvp/optdevbegin.yml (modified) * spec/build/bsps/arm/fvp/optdevsize.yml (modified) * spec/build/bsps/arm/fvp/optdrambegin.yml (modified) * spec/build/bsps/arm/fvp/optdramsize.yml (modified) * spec/build/bsps/arm/fvp/optnullsize.yml (modified) * spec/build/bsps/arm/gumstix/abi.yml (modified) * spec/build/bsps/arm/gumstix/optskyeye.yml (modified) * spec/build/bsps/arm/imx/abi.yml (modified) * spec/build/bsps/arm/imx/optcachedata.yml (modified) * spec/build/bsps/arm/imx/optcacheinst.yml (modified) * spec/build/bsps/arm/imx/optccmahb.yml (modified) * spec/build/bsps/arm/imx/optcmmecspi.yml (modified) * spec/build/bsps/arm/imx/optcmmipg.yml (modified) * spec/build/bsps/arm/imx/optcmmsdhci.yml (modified) * spec/build/bsps/arm/imx/optcmmuart.yml (modified) * spec/build/bsps/arm/imx/optconirq.yml (modified) * spec/build/bsps/arm/imx/optresetvec.yml (modified) * spec/build/bsps/arm/imxrt/abi.yml (modified) * spec/build/bsps/arm/imxrt/optfsledmaemlm.yml (modified) * spec/build/bsps/arm/imxrt/optlinkcmds.yml (modified) * spec/build/bsps/arm/imxrt/optmemdtcmsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramnocachesz.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramorigin.yml (modified) * spec/build/bsps/arm/imxrt/optmemextramsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashivtsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashorigin.yml (modified) * spec/build/bsps/arm/imxrt/optmemflashsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemitcmsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemnullsz.yml (modified) * spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml (modified) * spec/build/bsps/arm/imxrt/optmemocramsz.yml (modified) * spec/build/bsps/arm/lm3s69xx/abi.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart0.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart1.yml (modified) * spec/build/bsps/arm/lm3s69xx/optenuart2.yml (modified) * spec/build/bsps/arm/lm3s69xx/optgpioahb.yml (modified) * spec/build/bsps/arm/lm3s69xx/optgpionum.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml (modified) * spec/build/bsps/arm/lm3s69xx/optlm4f120.yml (modified) * spec/build/bsps/arm/lm3s69xx/optssiblks.yml (modified) * spec/build/bsps/arm/lm3s69xx/optssiclk.yml (modified) * spec/build/bsps/arm/lm3s69xx/optsysclk.yml (modified) * spec/build/bsps/arm/lm3s69xx/optuartbaud.yml (modified) * spec/build/bsps/arm/lm3s69xx/optudma.yml (modified) * spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm3s6965.yml (modified) * spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml (modified) * spec/build/bsps/arm/lpc176x/abi.yml (modified) * spec/build/bsps/arm/lpc176x/optcclk.yml (modified) * spec/build/bsps/arm/lpc176x/optconcfg.yml (modified) * spec/build/bsps/arm/lpc176x/optdmachn.yml (modified) * spec/build/bsps/arm/lpc176x/optlpc1768.yml (modified) * spec/build/bsps/arm/lpc176x/optmintskstksz.yml (modified) * spec/build/bsps/arm/lpc176x/optoscmain.yml (modified) * spec/build/bsps/arm/lpc176x/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc176x/optpclkdiv.yml (modified) * spec/build/bsps/arm/lpc176x/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc176x/optstopusb.yml (modified) * spec/build/bsps/arm/lpc176x/optuart1cfg.yml (modified) * spec/build/bsps/arm/lpc176x/optuartbaud.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbed.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbram.yml (modified) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml (modified) * spec/build/bsps/arm/lpc24xx/abi.yml (modified) * spec/build/bsps/arm/lpc24xx/optcclk.yml (modified) * spec/build/bsps/arm/lpc24xx/optconcfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optdmachn.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcsst39vf3201.yml (modified) * spec/build/bsps/arm/lpc24xx/optemctest.yml (modified) * spec/build/bsps/arm/lpc24xx/optemcw9825g2jb75i.yml (modified) * spec/build/bsps/arm/lpc24xx/optethdownpin.yml (modified) * spec/build/bsps/arm/lpc24xx/optethrmii.yml (modified) * spec/build/bsps/arm/lpc24xx/optheapext.yml (modified) * spec/build/bsps/arm/lpc24xx/optoscmain.yml (modified) * spec/build/bsps/arm/lpc24xx/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc24xx/optotgi2c.yml (modified) * spec/build/bsps/arm/lpc24xx/optpclkdiv.yml (modified) * spec/build/bsps/arm/lpc24xx/optresetvec.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopeth.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc24xx/optstopusb.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart1cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart2cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuart3cfg.yml (modified) * spec/build/bsps/arm/lpc24xx/optuartbaud.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc17xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc17xxplx800romint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc2362.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml (modified) * spec/build/bsps/arm/lpc24xx/tstlpc40xxearomint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstncsromint.yml (modified) * spec/build/bsps/arm/lpc24xx/tstplx800romint.yml (modified) * spec/build/bsps/arm/lpc32xx/abi.yml (modified) * spec/build/bsps/arm/lpc32xx/optdismmu.yml (modified) * spec/build/bsps/arm/lpc32xx/optdisroprot.yml (modified) * spec/build/bsps/arm/lpc32xx/optdisrwdc.yml (modified) * spec/build/bsps/arm/lpc32xx/optdmachn.yml (modified) * spec/build/bsps/arm/lpc32xx/optenwdgrst.yml (modified) * spec/build/bsps/arm/lpc32xx/optethrmii.yml (modified) * spec/build/bsps/arm/lpc32xx/optoscmain.yml (modified) * spec/build/bsps/arm/lpc32xx/optoscrtc.yml (modified) * spec/build/bsps/arm/lpc32xx/optotgi2c.yml (modified) * spec/build/bsps/arm/lpc32xx/optotgvbus.yml (modified) * spec/build/bsps/arm/lpc32xx/optperiphclk.yml (modified) * spec/build/bsps/arm/lpc32xx/optresetvec.yml (modified) * spec/build/bsps/arm/lpc32xx/optscratchsz.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopeth.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopgpdma.yml (modified) * spec/build/bsps/arm/lpc32xx/optstopusb.yml (modified) * spec/build/bsps/arm/lpc32xx/optu3clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu4clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu5clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optu6clk.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart1baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart2baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart3baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart4baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart5baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart6baud.yml (modified) * spec/build/bsps/arm/lpc32xx/optuart7baud.yml (modified) * spec/build/bsps/arm/lpc32xx/tstmzxstage1.yml (modified) * spec/build/bsps/arm/opta9periphclk.yml (modified) * spec/build/bsps/arm/optgiccpuif.yml (modified) * spec/build/bsps/arm/optgicdist.yml (modified) * spec/build/bsps/arm/optgicredist.yml (modified) * spec/build/bsps/arm/optgicspicount.yml (modified) * spec/build/bsps/arm/optgtfreq.yml (modified) * spec/build/bsps/arm/optgtsysbase.yml (modified) * spec/build/bsps/arm/optgtsyscntcr.yml (modified) * spec/build/bsps/arm/optgtusevirt.yml (modified) * spec/build/bsps/arm/optmmusmallpages.yml (modified) * spec/build/bsps/arm/optmmusz.yml (modified) * spec/build/bsps/arm/raspberrypi/abi.yml (modified) * spec/build/bsps/arm/raspberrypi/opti2ciomode.yml (modified) * spec/build/bsps/arm/raspberrypi/optnocachelen.yml (modified) * spec/build/bsps/arm/raspberrypi/optramlen.yml (modified) * spec/build/bsps/arm/raspberrypi/optresetvec.yml (modified) * spec/build/bsps/arm/raspberrypi/optrpi2.yml (modified) * spec/build/bsps/arm/raspberrypi/optspiiomode.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/abi.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/opta9periphclk.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/optresetvec.yml (modified) * spec/build/bsps/arm/rtl22xx/abi.yml (modified) * spec/build/bsps/arm/rtl22xx/optskyeye.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (modified) * spec/build/bsps/arm/smdk2410/abi.yml (modified) * spec/build/bsps/arm/smdk2410/optcpus3c2410.yml (modified) * spec/build/bsps/arm/smdk2410/optskyeye.yml (modified) * spec/build/bsps/arm/stm32f4/abi.yml (modified) * spec/build/bsps/arm/stm32f4/opteni2c1.yml (modified) * spec/build/bsps/arm/stm32f4/opteni2c2.yml (modified) * spec/build/bsps/arm/stm32f4/optenuart4.yml (modified) * spec/build/bsps/arm/stm32f4/optenuart5.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart1.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart2.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart3.yml (modified) * spec/build/bsps/arm/stm32f4/optenusart6.yml (modified) * spec/build/bsps/arm/stm32f4/optf10xxx.yml (modified) * spec/build/bsps/arm/stm32f4/optf4xxxx.yml (modified) * spec/build/bsps/arm/stm32f4/opthclk.yml (modified) * spec/build/bsps/arm/stm32f4/optoschse.yml (modified) * spec/build/bsps/arm/stm32f4/optpclk1.yml (modified) * spec/build/bsps/arm/stm32f4/optpclk2.yml (modified) * spec/build/bsps/arm/stm32f4/optsysclk.yml (modified) * spec/build/bsps/arm/stm32f4/optusartbaud.yml (modified) * spec/build/bsps/arm/stm32f4/tststm32f105rc.yml (modified) * spec/build/bsps/arm/stm32h7/abi.yml (modified) * spec/build/bsps/arm/stm32h7/optenmpualign.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart4.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart5.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart7.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart8.yml (modified) * spec/build/bsps/arm/stm32h7/optenuart9.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart1.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart10.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart2.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart3.yml (modified) * spec/build/bsps/arm/stm32h7/optenusart6.yml (modified) * spec/build/bsps/arm/stm32h7/optethgpiobregs.yml (modified) * spec/build/bsps/arm/stm32h7/optethgpiogregs.yml (modified) * spec/build/bsps/arm/stm32h7/opthse.yml (modified) * spec/build/bsps/arm/stm32h7/optlinkcmds.yml (modified) * spec/build/bsps/arm/stm32h7/optmemdtcmsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemflashsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemitcmsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnandsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnorsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemnullsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemperipheralsz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemquadspisz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram1sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram2sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram3sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsram4sz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsramaxisz.yml (modified) * spec/build/bsps/arm/stm32h7/optmemsrambackupsz.yml (modified) * spec/build/bsps/arm/stm32h7/optprintkinstance.yml (modified) * spec/build/bsps/arm/stm32h7/optusart3gpiopins.yml (modified) * spec/build/bsps/arm/stm32h7/optusart3gpioregs.yml (modified) * spec/build/bsps/arm/stm32h7/optvariant.yml (modified) * spec/build/bsps/arm/tms570/abi.yml (modified) * spec/build/bsps/arm/tms570/optcclk.yml (modified) * spec/build/bsps/arm/tms570/optconirq.yml (modified) * spec/build/bsps/arm/tms570/optlowinit.yml (modified) * spec/build/bsps/arm/tms570/optmintskstksz.yml (modified) * spec/build/bsps/arm/tms570/optoscmain.yml (modified) * spec/build/bsps/arm/tms570/optoscrtc.yml (modified) * spec/build/bsps/arm/tms570/optreginit.yml (modified) * spec/build/bsps/arm/tms570/optscibaud.yml (modified) * spec/build/bsps/arm/tms570/opttms570ls3137.yml (modified) * spec/build/bsps/arm/tms570/tstls3137hdkintram.yml (modified) * spec/build/bsps/arm/xen/abi.yml (modified) * spec/build/bsps/arm/xen/optgentmunmask.yml (modified) * spec/build/bsps/arm/xen/optloadoff.yml (modified) * spec/build/bsps/arm/xen/optnocachelen.yml (modified) * spec/build/bsps/arm/xen/optramlen.yml (modified) * spec/build/bsps/arm/xen/optramori.yml (modified) * spec/build/bsps/arm/xen/optzimghdr.yml (modified) * spec/build/bsps/arm/xilinx-zynq/abi.yml (modified) * spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optcachedata.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optclkuart.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optconirq.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint0len.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint0ori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint1len.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optint1ori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optnocachelen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optramlen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optramori.yml (modified) * spec/build/bsps/arm/xilinx-zynq/optresetvec.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optconirq.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint0len.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint0ori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint1len.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optint1ori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optnocachelen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optramlen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optramori.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/optresetvec.yml (modified) * spec/build/bsps/bfin/TLL6527M/abi.yml (modified) * spec/build/bsps/bfin/TLL6527M/optconbaud.yml (modified) * spec/build/bsps/bfin/TLL6527M/optconirq.yml (modified) * spec/build/bsps/bfin/TLL6527M/optirqtbl.yml (modified) * spec/build/bsps/bfin/TLL6527M/optskyeye.yml (modified) * spec/build/bsps/bfin/TLL6527M/optuartdma.yml (modified) * spec/build/bsps/bfin/bf537Stamp/abi.yml (modified) * spec/build/bsps/bfin/bf537Stamp/optconirq.yml (modified) * spec/build/bsps/bfin/bf537Stamp/optskyeye.yml (modified) * spec/build/bsps/bfin/eZKit533/abi.yml (modified) * spec/build/bsps/bfin/eZKit533/optconirq.yml (modified) * spec/build/bsps/bfin/eZKit533/optskyeye.yml (modified) * spec/build/bsps/i386/pc386/abi.yml (modified) * spec/build/bsps/i386/pc386/optcirrus.yml (modified) * spec/build/bsps/i386/pc386/optclk8253.yml (modified) * spec/build/bsps/i386/pc386/optclktsc.yml (modified) * spec/build/bsps/i386/pc386/optconcom1.yml (modified) * spec/build/bsps/i386/pc386/optencom14.yml (modified) * spec/build/bsps/i386/pc386/optenide.yml (modified) * spec/build/bsps/i386/pc386/optenvga.yml (modified) * spec/build/bsps/i386/pc386/optgdbstub.yml (modified) * spec/build/bsps/i386/pc386/optgdtdesc.yml (modified) * spec/build/bsps/i386/pc386/optidepriifc.yml (modified) * spec/build/bsps/i386/pc386/optidesecifc.yml (modified) * spec/build/bsps/i386/pc386/optrelocaddr.yml (modified) * spec/build/bsps/i386/pc386/optvberm.yml (modified) * spec/build/bsps/i386/pc386/optvga.yml (modified) * spec/build/bsps/i386/pc386/optvideo80x50.yml (modified) * spec/build/bsps/lm32/lm32_evr/abi.yml (modified) * spec/build/bsps/lm32/lm32_evr/optsim.yml (modified) * spec/build/bsps/lm32/milkymist/abi.yml (modified) * spec/build/bsps/lm32/milkymist/optsim.yml (modified) * spec/build/bsps/m68k/av5282/abi.yml (modified) * spec/build/bsps/m68k/csb360/abi.yml (modified) * spec/build/bsps/m68k/gen68340/abi.yml (modified) * spec/build/bsps/m68k/gen68360/abi.yml (modified) * spec/build/bsps/m68k/gen68360/opt68360.yml (modified) * spec/build/bsps/m68k/gen68360/opt68360x040.yml (modified) * spec/build/bsps/m68k/gen68360/optpgh360.yml (modified) * spec/build/bsps/m68k/genmcf548x/abi.yml (modified) * spec/build/bsps/m68k/genmcf548x/optcpuclk.yml (modified) * spec/build/bsps/m68k/genmcf548x/optdbug.yml (modified) * spec/build/bsps/m68k/genmcf548x/optlowinit.yml (modified) * spec/build/bsps/m68k/genmcf548x/optm5484fireengine.yml (modified) * spec/build/bsps/m68k/mcf5206elite/abi.yml (modified) * spec/build/bsps/m68k/mcf5206elite/tstmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/abi.yml (modified) * spec/build/bsps/m68k/mcf52235/tstmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/abi.yml (modified) * spec/build/bsps/m68k/mcf5225x/tstmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/abi.yml (modified) * spec/build/bsps/m68k/mcf5329/abi.yml (modified) * spec/build/bsps/m68k/mrm332/abi.yml (modified) * spec/build/bsps/m68k/mrm332/tstmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/abi.yml (modified) * spec/build/bsps/m68k/mvme147s/abi.yml (modified) * spec/build/bsps/m68k/mvme162/abi.yml (modified) * spec/build/bsps/m68k/mvme162/tstmvme162.yml (modified) * spec/build/bsps/m68k/mvme162/tstmvme162lx.yml (modified) * spec/build/bsps/m68k/mvme167/abi.yml (modified) * spec/build/bsps/m68k/mvme167/optconminor.yml (modified) * spec/build/bsps/m68k/mvme167/optintlvl.yml (modified) * spec/build/bsps/m68k/mvme167/optiomode.yml (modified) * spec/build/bsps/m68k/mvme167/optmvme167.yml (modified) * spec/build/bsps/m68k/mvme167/optprintkminor.yml (modified) * spec/build/bsps/m68k/mvme167/optuseterm.yml (modified) * spec/build/bsps/m68k/uC5282/abi.yml (modified) * spec/build/bsps/mips/csb350/abi.yml (modified) * spec/build/bsps/mips/hurricane/abi.yml (modified) * spec/build/bsps/mips/hurricane/optrm52xx.yml (modified) * spec/build/bsps/mips/hurricane/optusc320.yml (modified) * spec/build/bsps/mips/jmr3904/abi.yml (modified) * spec/build/bsps/mips/jmr3904/tstjmr3904.yml (modified) * spec/build/bsps/mips/malta/abi.yml (modified) * spec/build/bsps/mips/rbtx4925/abi.yml (modified) * spec/build/bsps/mips/rbtx4925/opttx49xx.yml (modified) * spec/build/bsps/mips/rbtx4938/abi.yml (modified) * spec/build/bsps/moxie/moxiesim/abi.yml (modified) * spec/build/bsps/nios2/nios2_iss/abi.yml (modified) * spec/build/bsps/optabi.yml (modified) * spec/build/bsps/optasflags.yml (modified) * spec/build/bsps/optbsp.yml (modified) * spec/build/bsps/optcachedata.yml (modified) * spec/build/bsps/optcacheinst.yml (modified) * spec/build/bsps/optclang.yml (modified) * spec/build/bsps/optclkbootcpu.yml (modified) * spec/build/bsps/optclkfastidle.yml (modified) * spec/build/bsps/optconminor.yml (modified) * spec/build/bsps/optconsolebaud.yml (modified) * spec/build/bsps/optconsoleirq.yml (modified) * spec/build/bsps/optfatalverb.yml (modified) * spec/build/bsps/optfdtcpyro.yml (modified) * spec/build/bsps/optfdtmxsz.yml (modified) * spec/build/bsps/optfdtro.yml (modified) * spec/build/bsps/optfdtuboot.yml (modified) * spec/build/bsps/optgcc.yml (modified) * spec/build/bsps/optincludes.yml (modified) * spec/build/bsps/optldflags.yml (modified) * spec/build/bsps/optldflagsbsp.yml (modified) * spec/build/bsps/optlinkflags.yml (modified) * spec/build/bsps/optmake.yml (modified) * spec/build/bsps/optmakelegacy.yml (modified) * spec/build/bsps/opto0.yml (modified) * spec/build/bsps/opto1.yml (modified) * spec/build/bsps/opto2.yml (modified) * spec/build/bsps/optobjcopy.yml (modified) * spec/build/bsps/optog.yml (modified) * spec/build/bsps/optos.yml (modified) * spec/build/bsps/optprintexcpt.yml (modified) * spec/build/bsps/optreset.yml (modified) * spec/build/bsps/optresetkey.yml (modified) * spec/build/bsps/optstarthyp.yml (modified) * spec/build/bsps/or1k/generic_or1k/abi.yml (modified) * spec/build/bsps/or1k/generic_or1k/optperiphclk.yml (modified) * spec/build/bsps/or1k/generic_or1k/optresetvec.yml (modified) * spec/build/bsps/powerpc/beatnik/abi.yml (modified) * spec/build/bsps/powerpc/beatnik/optsbrk.yml (modified) * spec/build/bsps/powerpc/gen5200/abi.yml (modified) * spec/build/bsps/powerpc/gen5200/optbenchirq.yml (modified) * spec/build/bsps/powerpc/gen5200/optenirqnest.yml (modified) * spec/build/bsps/powerpc/gen5200/optgpiomsk.yml (modified) * spec/build/bsps/powerpc/gen5200/optgpioval.yml (modified) * spec/build/bsps/powerpc/gen5200/opticecub.yml (modified) * spec/build/bsps/powerpc/gen5200/optpm520cr825.yml (modified) * spec/build/bsps/powerpc/gen5200/optpm520ze30.yml (modified) * spec/build/bsps/powerpc/gen5200/optprintkminor.yml (modified) * spec/build/bsps/powerpc/gen5200/optpscgps.yml (modified) * spec/build/bsps/powerpc/gen5200/optsinglechar.yml (modified) * spec/build/bsps/powerpc/gen5200/optuartmsk.yml (modified) * spec/build/bsps/powerpc/gen5200/optuartstermirq.yml (modified) * spec/build/bsps/powerpc/gen5200/optuboot.yml (modified) * spec/build/bsps/powerpc/gen83xx/abi.yml (modified) * spec/build/bsps/powerpc/gen83xx/optbruid.yml (modified) * spec/build/bsps/powerpc/gen83xx/optchiptype.yml (modified) * spec/build/bsps/powerpc/gen83xx/opthsccm01.yml (modified) * spec/build/bsps/powerpc/gen83xx/optirqnest.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8309som.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8313erdb.yml (modified) * spec/build/bsps/powerpc/gen83xx/optmpc8349eamds.yml (modified) * spec/build/bsps/powerpc/gen83xx/optnandcs0.yml (modified) * spec/build/bsps/powerpc/gen83xx/optnet0phy.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuart2.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuartirq.yml (modified) * spec/build/bsps/powerpc/gen83xx/optuboot.yml (modified) * spec/build/bsps/powerpc/gen83xx/optulpi.yml (modified) * spec/build/bsps/powerpc/haleakala/abi.yml (modified) * spec/build/bsps/powerpc/haleakala/optsprg.yml (modified) * spec/build/bsps/powerpc/haleakala/optvecbase.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/abi.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc603e.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc750.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmpc8240.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/optsbrk.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/abi.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optbootflg.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optcachewritethru.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optchipfam.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optconbaud.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optconminor.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optearlystksz.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/opteepromname.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/opteeprompath.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optenstartpro.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optesciirq.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optexcbooke.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllesyncr1.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optgwlcfm.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optphycorempc5554.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc91111.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9111enaddr.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ibige.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218iled.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218irxchn.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218itxchn.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/tstgwlcfm.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/tstmpc5643levb.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/abi.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optconminor.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optdisphandstat.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optprintkminor.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optuartsiomode.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/optuartsterm.yml (modified) * spec/build/bsps/powerpc/mvme3100/abi.yml (modified) * spec/build/bsps/powerpc/mvme3100/optsbrk.yml (modified) * spec/build/bsps/powerpc/mvme5500/abi.yml (modified) * spec/build/bsps/powerpc/mvme5500/optsbrk.yml (modified) * spec/build/bsps/powerpc/psim/abi.yml (modified) * spec/build/bsps/powerpc/psim/optclkfastidle.yml (modified) * spec/build/bsps/powerpc/psim/optsbrk.yml (modified) * spec/build/bsps/powerpc/psim/optsprg.yml (modified) * spec/build/bsps/powerpc/psim/optvecbase.yml (modified) * spec/build/bsps/powerpc/qemuppc/abi.yml (modified) * spec/build/bsps/powerpc/qoriq/abi.yml (modified) * spec/build/bsps/powerpc/qoriq/optbucsr.yml (modified) * spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachealign.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheblktouch.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachedatal1sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheinstl1sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml (modified) * spec/build/bsps/powerpc/qoriq/optchipnum.yml (modified) * spec/build/bsps/powerpc/qoriq/optchipser.yml (modified) * spec/build/bsps/powerpc/qoriq/optclktmctr.yml (modified) * spec/build/bsps/powerpc/qoriq/optclktmr.yml (modified) * spec/build/bsps/powerpc/qoriq/optcpucnt.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec1phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec2phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optetsec3phy.yml (modified) * spec/build/bsps/powerpc/qoriq/optexcbooke.yml (modified) * spec/build/bsps/powerpc/qoriq/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/qoriq/opthid0.yml (modified) * spec/build/bsps/powerpc/qoriq/opthyp.yml (modified) * spec/build/bsps/powerpc/qoriq/opthypguest.yml (modified) * spec/build/bsps/powerpc/qoriq/opticombegin.yml (modified) * spec/build/bsps/powerpc/qoriq/opticomsz.yml (modified) * spec/build/bsps/powerpc/qoriq/optmas7.yml (modified) * spec/build/bsps/powerpc/qoriq/optmsr.yml (modified) * spec/build/bsps/powerpc/qoriq/optspefscr.yml (modified) * spec/build/bsps/powerpc/qoriq/optthrdcnt.yml (modified) * spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml (modified) * spec/build/bsps/powerpc/qoriq/optuart0en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuart1en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrg0en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrg1en.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgmas.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgpri.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartbrgslv.yml (modified) * spec/build/bsps/powerpc/qoriq/optuartirq.yml (modified) * spec/build/bsps/powerpc/ss555/abi.yml (modified) * spec/build/bsps/powerpc/ss555/optconminor.yml (modified) * spec/build/bsps/powerpc/ss555/optprintkminor.yml (modified) * spec/build/bsps/powerpc/ss555/optuartsiomode.yml (modified) * spec/build/bsps/powerpc/ss555/optuartsterm.yml (modified) * spec/build/bsps/powerpc/ss555/optwdgtimeout.yml (modified) * spec/build/bsps/powerpc/t32mppc/abi.yml (modified) * spec/build/bsps/powerpc/t32mppc/optexcbooke.yml (modified) * spec/build/bsps/powerpc/t32mppc/optexcfixdhdlr.yml (modified) * spec/build/bsps/powerpc/tqm8xx/abi.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconchn.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc1.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc2.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc3.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconscc4.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconsmc1.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optconsmc2.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optnetfec.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optnetscc.yml (modified) * spec/build/bsps/powerpc/tqm8xx/optprintkchn.yml (modified) * spec/build/bsps/powerpc/virtex/abi.yml (modified) * spec/build/bsps/powerpc/virtex/optconirq.yml (modified) * spec/build/bsps/powerpc/virtex/optfastramlen.yml (modified) * spec/build/bsps/powerpc/virtex/optfastramorg.yml (modified) * spec/build/bsps/powerpc/virtex/optramlen.yml (modified) * spec/build/bsps/powerpc/virtex/optramorg.yml (modified) * spec/build/bsps/powerpc/virtex/optresetlen.yml (modified) * spec/build/bsps/powerpc/virtex/optresetorg.yml (modified) * spec/build/bsps/powerpc/virtex/optxparam.yml (modified) * spec/build/bsps/powerpc/virtex4/abi.yml (modified) * spec/build/bsps/powerpc/virtex4/optppccachedata.yml (modified) * spec/build/bsps/powerpc/virtex4/optsprg.yml (modified) * spec/build/bsps/powerpc/virtex4/optvecbase.yml (modified) * spec/build/bsps/powerpc/virtex5/abi.yml (modified) * spec/build/bsps/powerpc/virtex5/optppccachedata.yml (modified) * spec/build/bsps/powerpc/virtex5/optsprg.yml (modified) * spec/build/bsps/powerpc/virtex5/optvecbase.yml (modified) * spec/build/bsps/riscv/griscv/abi.yml (modified) * spec/build/bsps/riscv/griscv/optextirqmax.yml (modified) * spec/build/bsps/riscv/optrambegin.yml (modified) * spec/build/bsps/riscv/optramsize.yml (modified) * spec/build/bsps/riscv/riscv/abi.yml (modified) * spec/build/bsps/riscv/riscv/optextirqmax.yml (modified) * spec/build/bsps/riscv/riscv/optfrdme310arty.yml (modified) * spec/build/bsps/riscv/riscv/opthtif.yml (modified) * spec/build/bsps/riscv/riscv/optns16550max.yml (modified) * spec/build/bsps/sh/gensh1/abi.yml (modified) * spec/build/bsps/sh/gensh1/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh1/optlowinit.yml (modified) * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/abi.yml (modified) * spec/build/bsps/sh/gensh2/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh2/optevb.yml (modified) * spec/build/bsps/sh/gensh2/optlowinit.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/gensh4/abi.yml (modified) * spec/build/bsps/sh/gensh4/optcpuclk.yml (modified) * spec/build/bsps/sh/gensh4/optcpydata.yml (modified) * spec/build/bsps/sh/gensh4/optlowinit.yml (modified) * spec/build/bsps/sh/shsim/abi.yml (modified) * spec/build/bsps/sh/shsim/optcpuclk.yml (modified) * spec/build/bsps/sh/shsim/optlowinit.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) * spec/build/bsps/sparc/erc32/abi.yml (modified) * spec/build/bsps/sparc/erc32/optconirq.yml (modified) * spec/build/bsps/sparc/erc32/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc/leon2/abi.yml (modified) * spec/build/bsps/sparc/leon2/optconirq.yml (modified) * spec/build/bsps/sparc/leon2/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc/leon3/abi.yml (modified) * spec/build/bsps/sparc/leon3/abiclang.yml (modified) * spec/build/bsps/sparc/leon3/optconirq.yml (modified) * spec/build/bsps/sparc/leon3/optleon3smp.yml (modified) * spec/build/bsps/sparc/leon3/optpwrdwnhlt.yml (modified) * spec/build/bsps/sparc64/niagara/abi.yml (modified) * spec/build/bsps/sparc64/usiii/abi.yml (modified) * spec/build/bsps/sparc64/usiii/optclkfastidle.yml (modified) * spec/build/bsps/tst.yml (modified) * spec/build/bsps/tstnoiconv.yml (modified) * spec/build/bsps/tstnointrcrit.yml (modified) * spec/build/bsps/tstnojffs2.yml (modified) * spec/build/bsps/tstnolibdl.yml (modified) * spec/build/bsps/tstnorfs.yml (modified) * spec/build/bsps/tstreqtick.yml (modified) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/bsps/v850/gdbv850sim/abi.yml (modified) * spec/build/bsps/x86_64/amd64/abi.yml (modified) * spec/build/cpukit/cfgattrgetaff.yml (modified) * spec/build/cpukit/cfgattrgetgrdsz.yml (modified) * spec/build/cpukit/cfgattrgetstack.yml (modified) * spec/build/cpukit/cfgattrsetaff.yml (modified) * spec/build/cpukit/cfgattrsetgrdsz.yml (modified) * spec/build/cpukit/cfgattrsetstack.yml (modified) * spec/build/cpukit/cfgcfghdr.yml (modified) * spec/build/cpukit/cfgcleanupctx.yml (modified) * spec/build/cpukit/cfggetaff.yml (modified) * spec/build/cpukit/cfggetattr.yml (modified) * spec/build/cpukit/cfginttypes.yml (modified) * spec/build/cpukit/cfgmemory.yml (modified) * spec/build/cpukit/cfgnewlib.yml (modified) * spec/build/cpukit/cfgpmtxceilcnst.yml (modified) * spec/build/cpukit/cfgprionode.yml (modified) * spec/build/cpukit/cfgpshdprmcnst.yml (modified) * spec/build/cpukit/cfgrcmd.yml (modified) * spec/build/cpukit/cfgsetaff.yml (modified) * spec/build/cpukit/cfgstdatomic.yml (modified) * spec/build/cpukit/cfgstdint.yml (modified) * spec/build/cpukit/cfgstdlib.yml (modified) * spec/build/cpukit/cfgstring.yml (modified) * spec/build/cpukit/cfgstrings.yml (modified) * spec/build/cpukit/cfgsysstat.yml (modified) * spec/build/cpukit/cfgsystypes.yml (modified) * spec/build/cpukit/cfgszoff.yml (modified) * spec/build/cpukit/cfgszsize.yml (modified) * spec/build/cpukit/cfgsztime.yml (modified) * spec/build/cpukit/cfgunistd.yml (modified) * spec/build/cpukit/optada.yml (modified) * spec/build/cpukit/optarchbits.yml (modified) * spec/build/cpukit/optarflags.yml (modified) * spec/build/cpukit/optbuildlabel.yml (modified) * spec/build/cpukit/optclang.yml (modified) * spec/build/cpukit/optdebug.yml (modified) * spec/build/cpukit/optdrvmgr.yml (modified) * spec/build/cpukit/optgcc.yml (modified) * spec/build/cpukit/optincludes.yml (modified) * spec/build/cpukit/optinstall.yml (modified) * spec/build/cpukit/optlibdl.yml (modified) * spec/build/cpukit/optmpci.yml (modified) * spec/build/cpukit/optnewlib.yml (modified) * spec/build/cpukit/optparavirt.yml (modified) * spec/build/cpukit/optposix.yml (modified) * spec/build/cpukit/optprofiling.yml (modified) * spec/build/cpukit/optsmp.yml (modified) * spec/build/cpukit/optszblkcnt.yml (modified) * spec/build/cpukit/optszblksize.yml (modified) * spec/build/cpukit/optszmode.yml (modified) * spec/build/cpukit/optszoff.yml (modified) * spec/build/cpukit/optsztime.yml (modified) * spec/build/cpukit/optvermaj.yml (modified) * spec/build/cpukit/optvermin.yml (modified) * spec/build/cpukit/optverrev.yml (modified) * spec/build/cpukit/optversion.yml (modified) * spec/build/cpukit/optwarn.yml (modified) * spec/build/cpukit/optwarncc.yml (modified) * spec/build/cpukit/optwarncxx.yml (modified) * spec/build/testsuites/ada/optgnat.yml (modified) * spec/build/testsuites/libtests/optbin2c.yml (modified) * spec/build/testsuites/libtests/optgzip.yml (modified) * spec/build/testsuites/libtests/optrtemsld.yml (modified) * spec/build/testsuites/libtests/optrtemssyms.yml (modified) * spec/build/testsuites/libtests/optxz.yml (modified) * spec/build/testsuites/optada.yml (modified) * spec/build/testsuites/optall.yml (modified) * spec/build/testsuites/optbenchmarks.yml (modified) * spec/build/testsuites/optfs.yml (modified) * spec/build/testsuites/optlib.yml (modified) * spec/build/testsuites/optmp.yml (modified) * spec/build/testsuites/optpsx.yml (modified) * spec/build/testsuites/optpsxtm.yml (modified) * spec/build/testsuites/optrhs.yml (modified) * spec/build/testsuites/optsamples.yml (modified) * spec/build/testsuites/optsmp.yml (modified) * spec/build/testsuites/optsp.yml (modified) * spec/build/testsuites/opttm.yml (modified) * spec/build/testsuites/optvalidation.yml (modified) * spec/build/testsuites/optverbosity.yml (modified) * wscript (modified) build: Merge default-by-family into by-variant Prefix the BSP ... Fri, 16 Jul 2021 09:31:21 GMT pranav [c71e34b] * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/beagle/grp.yml (modified) * spec/build/bsps/arm/beagle/optfdtcpyro.yml (deleted) * spec/build/bsps/arm/beagle/optfdtmxsz.yml (deleted) * spec/build/bsps/arm/beagle/optfdtro.yml (deleted) * spec/build/bsps/arm/beagle/optfdtuboot.yml (deleted) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imx/optfdtcpyro.yml (deleted) * spec/build/bsps/arm/imx/optfdtmxsz.yml (deleted) * spec/build/bsps/arm/imx/optfdtro.yml (deleted) * spec/build/bsps/arm/imx/optfdtuboot.yml (deleted) * spec/build/bsps/arm/raspberrypi/grp.yml (modified) * spec/build/bsps/optfdtcpyro.yml (moved) * spec/build/bsps/optfdtmxsz.yml (moved) * spec/build/bsps/optfdtro.yml (moved) * spec/build/bsps/optfdtuboot.yml (moved) * spec/build/bsps/powerpc/qoriq/grp.yml (modified) * spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml (deleted) * spec/build/bsps/powerpc/qoriq/optfdtro.yml (deleted) * spec/build/bsps/riscv/riscv/grp.yml (modified) * spec/build/bsps/riscv/riscv/optfdtcpyro.yml (deleted) * spec/build/bsps/riscv/riscv/optfdtmxsz.yml (deleted) * spec/build/bsps/riscv/riscv/optfdtro.yml (deleted) * spec/build/bsps/riscv/riscv/optfdtuboot.yml (deleted) bsps: Move optfdt* files to shared parent directory Thu, 29 Jul 2021 06:05:26 GMT Sebastian Huber [59168e2a] * cpukit/Makefile.am (modified) * cpukit/score/src/smpbroadcastaction.c (added) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/smpothercastaction.c (added) * cpukit/score/src/smpsynchronize.c (added) * spec/build/cpukit/objsmp.yml (modified) score: Split SMP multicast action module Split up the SMP multicast ... Wed, 28 Jul 2021 11:11:41 GMT Sebastian Huber [f799b452] * cpukit/Makefile.am (modified) * cpukit/score/src/percpujobs.c (added) * cpukit/score/src/smpmulticastaction.c (modified) * spec/build/cpukit/objsmp.yml (modified) score: Move per-CPU jobs support Add percpujobs.c to contain the ... Mon, 26 Jul 2021 13:53:26 GMT Sebastian Huber [67c033d3] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-handler-iterate.c (added) validation: Test rtems_interrupt_handler_iterate() Update #3269. Tue, 06 Jul 2021 08:33:51 GMT Sebastian Huber [17fb5239] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-set-affinity.c (added) validation: Test rtems_interrupt_set_affinity() Update #3269. Tue, 06 Jul 2021 06:04:26 GMT Sebastian Huber [aab3713] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-get-affinity.c (added) validation: Test rtems_interrupt_get_affinity() Update #3269. Mon, 05 Jul 2021 14:35:51 GMT Sebastian Huber [32c0cd8] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-raise-on.c (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-validation-0.c (modified) validation: Test rtems_interrupt_raise_on() Update #3269. Mon, 05 Jul 2021 13:50:07 GMT Sebastian Huber [163c1fd] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-is-pending.c (added) validation: Test rtems_interrupt_is_pending() Update #3269. Mon, 05 Jul 2021 12:01:10 GMT Sebastian Huber [1bf8139a] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-clear.c (added) validation: Test rtems_interrupt_clear() Update #3269. Mon, 05 Jul 2021 06:37:15 GMT Sebastian Huber [4341058] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-raise.c (added) validation: Test rtems_interrupt_raise() Update #3269. Wed, 30 Jun 2021 12:08:12 GMT Sebastian Huber [7dbab6af] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-entry-remove.c (added) validation: Test rtems_interrupt_entry_remove() Update #3269. Tue, 29 Jun 2021 13:11:05 GMT Sebastian Huber [09960369] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-entry-install.c (added) validation: Test rtems_interrupt_entry_install() Update #3269. Tue, 29 Jun 2021 13:10:46 GMT Sebastian Huber [aa6c962] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-vector-disable.c (added) validation: Test rtems_interrupt_vector_disable() Update #3269. Tue, 29 Jun 2021 13:10:18 GMT Sebastian Huber [7a3e6c7] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-vector-enable.c (added) validation: Test rtems_interrupt_vector_enable() Update #3269. Tue, 29 Jun 2021 13:09:48 GMT Sebastian Huber [d8be2b97] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-vector-is-enabled.c (added) validation: rtems_interrupt_vector_is_enabled() Update #3269. Tue, 29 Jun 2021 13:09:19 GMT Sebastian Huber [e2894df] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-intr-get-attributes.c (added) validation: Test rtems_interrupt_get_attributes() Update #3269. Tue, 29 Jun 2021 13:57:50 GMT Sebastian Huber [1465e78a] * spec/build/testsuites/validation/libvalidation.yml (modified) * testsuites/validation/tx-interrupt.c (added) * testsuites/validation/tx-support.h (modified) validation: HasInterruptVectorEntriesInstalled() Update #3269. Tue, 29 Jun 2021 13:37:06 GMT Sebastian Huber [f89cf8e8] * spec/build/testsuites/validation/libvalidation.yml (modified) * testsuites/validation/tx-call-within-isr.c (added) * testsuites/validation/tx-support.h (modified) validation: Add CallWithinISR() Update #3269.
