# # ChangeLog for spec in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 11:14:57 Tue, 15 Sep 2020 18:04:51 GMT Sebastian Huber [9979042] * spec/build/bsps/i386/pc386/objsmpstart.yml (modified) build: Fix multiple defintion error for i386/pc386 Make the objcopy ... Tue, 15 Sep 2020 13:06:48 GMT Sebastian Huber [8f424e45] * spec/build/bsps/i386/pc386/objsmpstart.yml (modified) build: Fix i386/pc386 link of SMP start file Update #3818. Tue, 15 Sep 2020 11:29:36 GMT Sebastian Huber [d9d31b3] * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/optrelocaddr.yml (added) build: Add RELOCADDR to i386/pc386 options Update #3818. Tue, 15 Sep 2020 11:28:10 GMT Sebastian Huber [3be23809] * spec/build/bsps/i386/pc386/abi.yml (modified) build: Fix i386/pc386 ABI flags Update #3818. Tue, 15 Sep 2020 07:16:13 GMT Sebastian Huber [127c3ea5] * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/objsmp.yml (modified) * spec/build/bsps/i386/pc386/objsmpstart.yml (added) * spec/build/bsps/optobjcopy.yml (added) build: Fix i386/pc386 with SMP enabled Update #3818. Fri, 31 Jul 2020 08:15:59 GMT Sebastian Huber [46477898] * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/irqs01.yml (added) * spec/build/testsuites/smptests/grp.yml (modified) * spec/build/testsuites/smptests/smpirqs01.yml (added) * testsuites/libtests/irqs01/init.c (added) * testsuites/libtests/irqs01/irqs01.doc (added) * testsuites/smptests/smpirqs01/init.c (added) * testsuites/smptests/smpirqs01/smpirqs01.doc (added) irqs01/smpirqs01: New tests Close #4034. Tue, 18 Aug 2020 11:14:48 GMT Sebastian Huber [aa27a85] * spec/build/testsuites/libtests/dl01.yml (modified) * spec/build/testsuites/libtests/dl02.yml (modified) * spec/build/testsuites/libtests/dl04.yml (modified) * spec/build/testsuites/libtests/dl05.yml (modified) * spec/build/testsuites/libtests/dl06.yml (modified) * spec/build/testsuites/libtests/dl07.yml (modified) * spec/build/testsuites/libtests/dl08.yml (modified) * spec/build/testsuites/libtests/dl09.yml (modified) * spec/build/testsuites/libtests/dl10.yml (modified) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/optpax.yml (deleted) * wscript (modified) build: Use Python tarfile instead of pax This patch is for the new ... Fri, 19 Jul 2019 11:09:43 GMT Sebastian Huber [f3f0370f] * .gitignore (modified) * bsps/arm/csb337/start/linkcmds.kit637_v6 (added) * gccdeps.py (added) * long_gcc.py (added) * make/README (added) * make/compilers/gcc-target-default.cfg (added) * make/directory.cfg (added) * make/host.cfg (added) * make/lib.cfg (added) * spec/build/bsps/arm/altera-cyclone-v/abi.yml (added) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (added) * spec/build/bsps/arm/altera-cyclone-v/objsmp.yml (added) * spec/build/bsps/arm/altera-cyclone-v/opta9periphclk.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optcachedata.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optcacheinst.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optconcfg.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optconuart1.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optfdten.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml (added) * spec/build/bsps/arm/altera-cyclone-v/opti2cspeed.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optnoi2c.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optresetvec.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optuartbaud.yml (added) * spec/build/bsps/arm/altera-cyclone-v/optuartirq.yml (added) * spec/build/bsps/arm/atsam/abi.yml (added) * spec/build/bsps/arm/atsam/bspatsam.yml (added) * spec/build/bsps/arm/atsam/linkcmds.yml (added) * spec/build/bsps/arm/atsam/objnet.yml (added) * spec/build/bsps/arm/atsam/optchgclksram.yml (added) * spec/build/bsps/arm/atsam/optchip.yml (added) * spec/build/bsps/arm/atsam/optconbaud.yml (added) * spec/build/bsps/arm/atsam/optconidx.yml (added) * spec/build/bsps/arm/atsam/optconirq.yml (added) * spec/build/bsps/arm/atsam/optcontype.yml (added) * spec/build/bsps/arm/atsam/optmck.yml (added) * spec/build/bsps/arm/atsam/optnocachesz.yml (added) * spec/build/bsps/arm/atsam/optoscmain.yml (added) * spec/build/bsps/arm/atsam/optqspiflashsz.yml (added) * spec/build/bsps/arm/atsam/optsdram.yml (added) * spec/build/bsps/arm/atsam/opttcmsz.yml (added) * spec/build/bsps/arm/atsam/optusextal.yml (added) * spec/build/bsps/arm/atsam/tstatsamv.yml (added) * spec/build/bsps/arm/beagle/abi.yml (added) * spec/build/bsps/arm/beagle/bspboardorig.yml (added) * spec/build/bsps/arm/beagle/bspboardxm.yml (added) * spec/build/bsps/arm/beagle/bspboneblack.yml (added) * spec/build/bsps/arm/beagle/bspbonewhite.yml (added) * spec/build/bsps/arm/beagle/grp.yml (added) * spec/build/bsps/arm/beagle/obj.yml (added) * spec/build/bsps/arm/beagle/optam335x.yml (added) * spec/build/bsps/arm/beagle/optconbaud.yml (added) * spec/build/bsps/arm/beagle/optconpoll.yml (added) * spec/build/bsps/arm/beagle/optdebug.yml (added) * spec/build/bsps/arm/beagle/optdm3730.yml (added) * spec/build/bsps/arm/beagle/optfdtcpyro.yml (added) * spec/build/bsps/arm/beagle/optfdtmxsz.yml (added) * spec/build/bsps/arm/beagle/optfdtro.yml (added) * spec/build/bsps/arm/beagle/optfdtuboot.yml (added) * spec/build/bsps/arm/csb336/abi.yml (added) * spec/build/bsps/arm/csb336/bspcsb336.yml (added) * spec/build/bsps/arm/csb336/objnet.yml (added) * spec/build/bsps/arm/csb336/start.yml (added) * spec/build/bsps/arm/csb337/abi.yml (added) * spec/build/bsps/arm/csb337/bspcsb337.yml (added) * spec/build/bsps/arm/csb337/bspcsb637.yml (added) * spec/build/bsps/arm/csb337/bspkit637v6.yml (added) * spec/build/bsps/arm/csb337/grp.yml (added) * spec/build/bsps/arm/csb337/obj.yml (added) * spec/build/bsps/arm/csb337/objlcd.yml (added) * spec/build/bsps/arm/csb337/objnet.yml (added) * spec/build/bsps/arm/csb337/objumon.yml (added) * spec/build/bsps/arm/csb337/objumoncon.yml (added) * spec/build/bsps/arm/csb337/optcsb637.yml (added) * spec/build/bsps/arm/csb337/optenlcd.yml (added) * spec/build/bsps/arm/csb337/optenumon.yml (added) * spec/build/bsps/arm/csb337/optenumoncon.yml (added) * spec/build/bsps/arm/csb337/optenusart0.yml (added) * spec/build/bsps/arm/csb337/optenusart1.yml (added) * spec/build/bsps/arm/csb337/optenusart2.yml (added) * spec/build/bsps/arm/csb337/optenusart3.yml (added) * spec/build/bsps/arm/csb337/start.yml (added) * spec/build/bsps/arm/edb7312/abi.yml (added) * spec/build/bsps/arm/edb7312/bspedb7312.yml (added) * spec/build/bsps/arm/edb7312/objnet.yml (added) * spec/build/bsps/arm/edb7312/optskyeye.yml (added) * spec/build/bsps/arm/edb7312/start.yml (added) * spec/build/bsps/arm/grp.yml (added) * spec/build/bsps/arm/gumstix/abi.yml (added) * spec/build/bsps/arm/gumstix/bspgumstix.yml (added) * spec/build/bsps/arm/gumstix/objnet.yml (added) * spec/build/bsps/arm/gumstix/optskyeye.yml (added) * spec/build/bsps/arm/gumstix/start.yml (added) * spec/build/bsps/arm/imx/abi.yml (added) * spec/build/bsps/arm/imx/bspimx.yml (added) * spec/build/bsps/arm/imx/objsmp.yml (added) * spec/build/bsps/arm/imx/optcachedata.yml (added) * spec/build/bsps/arm/imx/optcacheinst.yml (added) * spec/build/bsps/arm/imx/optccmahb.yml (added) * spec/build/bsps/arm/imx/optcmmecspi.yml (added) * spec/build/bsps/arm/imx/optcmmipg.yml (added) * spec/build/bsps/arm/imx/optcmmsdhci.yml (added) * spec/build/bsps/arm/imx/optcmmuart.yml (added) * spec/build/bsps/arm/imx/optconirq.yml (added) * spec/build/bsps/arm/imx/optfdtcpyro.yml (added) * spec/build/bsps/arm/imx/optfdtmxsz.yml (added) * spec/build/bsps/arm/imx/optfdtro.yml (added) * spec/build/bsps/arm/imx/optfdtuboot.yml (added) * spec/build/bsps/arm/imx/optresetvec.yml (added) * spec/build/bsps/arm/lm3s69xx/abi.yml (added) * spec/build/bsps/arm/lm3s69xx/bsplm3s3749.yml (added) * spec/build/bsps/arm/lm3s69xx/bsplm3s6965.yml (added) * spec/build/bsps/arm/lm3s69xx/bsplm4f120.yml (added) * spec/build/bsps/arm/lm3s69xx/bspqemu.yml (added) * spec/build/bsps/arm/lm3s69xx/grp.yml (added) * spec/build/bsps/arm/lm3s69xx/obj.yml (added) * spec/build/bsps/arm/lm3s69xx/optenuart0.yml (added) * spec/build/bsps/arm/lm3s69xx/optenuart1.yml (added) * spec/build/bsps/arm/lm3s69xx/optenuart2.yml (added) * spec/build/bsps/arm/lm3s69xx/optgpioahb.yml (added) * spec/build/bsps/arm/lm3s69xx/optgpionum.yml (added) * spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml (added) * spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml (added) * spec/build/bsps/arm/lm3s69xx/optlm4f120.yml (added) * spec/build/bsps/arm/lm3s69xx/optssiblks.yml (added) * spec/build/bsps/arm/lm3s69xx/optssiclk.yml (added) * spec/build/bsps/arm/lm3s69xx/optsysclk.yml (added) * spec/build/bsps/arm/lm3s69xx/optuartbaud.yml (added) * spec/build/bsps/arm/lm3s69xx/optudma.yml (added) * spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml (added) * spec/build/bsps/arm/lm3s69xx/tstlm3s3749.yml (added) * spec/build/bsps/arm/lm3s69xx/tstlm3s6965.yml (added) * spec/build/bsps/arm/lm3s69xx/tstlm4f120.yml (added) * spec/build/bsps/arm/lpc176x/abi.yml (added) * spec/build/bsps/arm/lpc176x/bsplpc1768mbed.yml (added) * spec/build/bsps/arm/lpc176x/bsplpc1768mbedahbram.yml (added) * spec/build/bsps/arm/lpc176x/bsplpc1768mbedahbrameth.yml (added) * spec/build/bsps/arm/lpc176x/grp.yml (added) * spec/build/bsps/arm/lpc176x/obj.yml (added) * spec/build/bsps/arm/lpc176x/optcclk.yml (added) * spec/build/bsps/arm/lpc176x/optconcfg.yml (added) * spec/build/bsps/arm/lpc176x/optdmachn.yml (added) * spec/build/bsps/arm/lpc176x/optlpc1768.yml (added) * spec/build/bsps/arm/lpc176x/optmintskstksz.yml (added) * spec/build/bsps/arm/lpc176x/optoscmain.yml (added) * spec/build/bsps/arm/lpc176x/optoscrtc.yml (added) * spec/build/bsps/arm/lpc176x/optpclkdiv.yml (added) * spec/build/bsps/arm/lpc176x/optstopgpdma.yml (added) * spec/build/bsps/arm/lpc176x/optstopusb.yml (added) * spec/build/bsps/arm/lpc176x/optuart1cfg.yml (added) * spec/build/bsps/arm/lpc176x/optuartbaud.yml (added) * spec/build/bsps/arm/lpc176x/tstlpc1768mbed.yml (added) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbram.yml (added) * spec/build/bsps/arm/lpc176x/tstlpc1768mbedahbrameth.yml (added) * spec/build/bsps/arm/lpc24xx/abi.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc17xxearam.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc17xxearomint.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc17xxplx800ram.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc17xxplx800romint.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc2362.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc23xxtli800.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc24xxea.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc40xxearam.yml (added) * spec/build/bsps/arm/lpc24xx/bsplpc40xxearomint.yml (added) * spec/build/bsps/arm/lpc24xx/bspncsram.yml (added) * spec/build/bsps/arm/lpc24xx/bspncsromext.yml (added) * spec/build/bsps/arm/lpc24xx/bspncsromint.yml (added) * spec/build/bsps/arm/lpc24xx/bspplx800ram.yml (added) * spec/build/bsps/arm/lpc24xx/bspplx800romint.yml (added) * spec/build/bsps/arm/lpc24xx/grp.yml (added) * spec/build/bsps/arm/lpc24xx/obj.yml (added) * spec/build/bsps/arm/lpc24xx/objnet.yml (added) * spec/build/bsps/arm/lpc24xx/optcclk.yml (added) * spec/build/bsps/arm/lpc24xx/optconcfg.yml (added) * spec/build/bsps/arm/lpc24xx/optdmachn.yml (added) * spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml (added) * spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml (added) * spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml (added) * spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml (added) * spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml (added) * spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml (added) * spec/build/bsps/arm/lpc24xx/optemcsst39vf3201.yml (added) * spec/build/bsps/arm/lpc24xx/optemctest.yml (added) * spec/build/bsps/arm/lpc24xx/optemcw9825g2jb75i.yml (added) * spec/build/bsps/arm/lpc24xx/optethdownpin.yml (added) * spec/build/bsps/arm/lpc24xx/optethrmii.yml (added) * spec/build/bsps/arm/lpc24xx/optheapext.yml (added) * spec/build/bsps/arm/lpc24xx/optoscmain.yml (added) * spec/build/bsps/arm/lpc24xx/optoscrtc.yml (added) * spec/build/bsps/arm/lpc24xx/optotgi2c.yml (added) * spec/build/bsps/arm/lpc24xx/optpclkdiv.yml (added) * spec/build/bsps/arm/lpc24xx/optresetvec.yml (added) * spec/build/bsps/arm/lpc24xx/optstopeth.yml (added) * spec/build/bsps/arm/lpc24xx/optstopgpdma.yml (added) * spec/build/bsps/arm/lpc24xx/optstopusb.yml (added) * spec/build/bsps/arm/lpc24xx/optuart1cfg.yml (added) * spec/build/bsps/arm/lpc24xx/optuart2cfg.yml (added) * spec/build/bsps/arm/lpc24xx/optuart3cfg.yml (added) * spec/build/bsps/arm/lpc24xx/optuartbaud.yml (added) * spec/build/bsps/arm/lpc24xx/tstlpc17xxearomint.yml (added) * spec/build/bsps/arm/lpc24xx/tstlpc17xxplx800romint.yml (added) * spec/build/bsps/arm/lpc24xx/tstlpc2362.yml (added) * spec/build/bsps/arm/lpc24xx/tstlpc23xxtli800.yml (added) * spec/build/bsps/arm/lpc24xx/tstlpc40xxearomint.yml (added) * spec/build/bsps/arm/lpc24xx/tstncsromint.yml (added) * spec/build/bsps/arm/lpc24xx/tstplx800romint.yml (added) * spec/build/bsps/arm/lpc32xx/abi.yml (added) * spec/build/bsps/arm/lpc32xx/bsplpc32xxmzx.yml (added) * spec/build/bsps/arm/lpc32xx/bspmzxstage1.yml (added) * spec/build/bsps/arm/lpc32xx/bspmzxstage2.yml (added) * spec/build/bsps/arm/lpc32xx/bspphycore.yml (added) * spec/build/bsps/arm/lpc32xx/grp.yml (added) * spec/build/bsps/arm/lpc32xx/obj.yml (added) * spec/build/bsps/arm/lpc32xx/objnet.yml (added) * spec/build/bsps/arm/lpc32xx/optdismmu.yml (added) * spec/build/bsps/arm/lpc32xx/optdisroprot.yml (added) * spec/build/bsps/arm/lpc32xx/optdisrwdc.yml (added) * spec/build/bsps/arm/lpc32xx/optdmachn.yml (added) * spec/build/bsps/arm/lpc32xx/optenwdgrst.yml (added) * spec/build/bsps/arm/lpc32xx/optethrmii.yml (added) * spec/build/bsps/arm/lpc32xx/optoscmain.yml (added) * spec/build/bsps/arm/lpc32xx/optoscrtc.yml (added) * spec/build/bsps/arm/lpc32xx/optotgi2c.yml (added) * spec/build/bsps/arm/lpc32xx/optotgvbus.yml (added) * spec/build/bsps/arm/lpc32xx/optperiphclk.yml (added) * spec/build/bsps/arm/lpc32xx/optresetvec.yml (added) * spec/build/bsps/arm/lpc32xx/optscratchsz.yml (added) * spec/build/bsps/arm/lpc32xx/optstopeth.yml (added) * spec/build/bsps/arm/lpc32xx/optstopgpdma.yml (added) * spec/build/bsps/arm/lpc32xx/optstopusb.yml (added) * spec/build/bsps/arm/lpc32xx/optu3clk.yml (added) * spec/build/bsps/arm/lpc32xx/optu4clk.yml (added) * spec/build/bsps/arm/lpc32xx/optu5clk.yml (added) * spec/build/bsps/arm/lpc32xx/optu6clk.yml (added) * spec/build/bsps/arm/lpc32xx/optuart1baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart2baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart3baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart4baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart5baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart6baud.yml (added) * spec/build/bsps/arm/lpc32xx/optuart7baud.yml (added) * spec/build/bsps/arm/lpc32xx/tstmzxstage1.yml (added) * spec/build/bsps/arm/opta9periphclk.yml (added) * spec/build/bsps/arm/optmmusmallpages.yml (added) * spec/build/bsps/arm/optmmusz.yml (added) * spec/build/bsps/arm/raspberrypi/abi.yml (added) * spec/build/bsps/arm/raspberrypi/bspraspberrypi.yml (added) * spec/build/bsps/arm/raspberrypi/bspraspberrypi2.yml (added) * spec/build/bsps/arm/raspberrypi/grp.yml (added) * spec/build/bsps/arm/raspberrypi/linkcmds.yml (added) * spec/build/bsps/arm/raspberrypi/obj.yml (added) * spec/build/bsps/arm/raspberrypi/objsmp.yml (added) * spec/build/bsps/arm/raspberrypi/optenhyp.yml (added) * spec/build/bsps/arm/raspberrypi/opti2ciomode.yml (added) * spec/build/bsps/arm/raspberrypi/optnocachelen.yml (added) * spec/build/bsps/arm/raspberrypi/optramlen.yml (added) * spec/build/bsps/arm/raspberrypi/optresetvec.yml (added) * spec/build/bsps/arm/raspberrypi/optrpi2.yml (added) * spec/build/bsps/arm/raspberrypi/optspiiomode.yml (added) * spec/build/bsps/arm/realview-pbx-a9/abi.yml (added) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (added) * spec/build/bsps/arm/realview-pbx-a9/objsmp.yml (added) * spec/build/bsps/arm/realview-pbx-a9/opta9periphclk.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optmmusmallpages.yml (added) * spec/build/bsps/arm/realview-pbx-a9/optresetvec.yml (added) * spec/build/bsps/arm/rtl22xx/abi.yml (added) * spec/build/bsps/arm/rtl22xx/bsprtl22xx.yml (added) * spec/build/bsps/arm/rtl22xx/bsprtl22xxt.yml (added) * spec/build/bsps/arm/rtl22xx/grp.yml (added) * spec/build/bsps/arm/rtl22xx/obj.yml (added) * spec/build/bsps/arm/rtl22xx/objnet.yml (added) * spec/build/bsps/arm/rtl22xx/optskyeye.yml (added) * spec/build/bsps/arm/rtl22xx/start.yml (added) * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (added) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (added) * spec/build/bsps/arm/smdk2410/abi.yml (added) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (added) * spec/build/bsps/arm/smdk2410/optcpus3c2410.yml (added) * spec/build/bsps/arm/smdk2410/optskyeye.yml (added) * spec/build/bsps/arm/smdk2410/start.yml (added) * spec/build/bsps/arm/start.yml (added) * spec/build/bsps/arm/stm32f4/abi.yml (added) * spec/build/bsps/arm/stm32f4/bspstm32f105rc.yml (added) * spec/build/bsps/arm/stm32f4/bspstm32f4.yml (added) * spec/build/bsps/arm/stm32f4/grp.yml (added) * spec/build/bsps/arm/stm32f4/obj.yml (added) * spec/build/bsps/arm/stm32f4/opteni2c1.yml (added) * spec/build/bsps/arm/stm32f4/opteni2c2.yml (added) * spec/build/bsps/arm/stm32f4/optenuart4.yml (added) * spec/build/bsps/arm/stm32f4/optenuart5.yml (added) * spec/build/bsps/arm/stm32f4/optenusart1.yml (added) * spec/build/bsps/arm/stm32f4/optenusart2.yml (added) * spec/build/bsps/arm/stm32f4/optenusart3.yml (added) * spec/build/bsps/arm/stm32f4/optenusart6.yml (added) * spec/build/bsps/arm/stm32f4/optf10xxx.yml (added) * spec/build/bsps/arm/stm32f4/optf4xxxx.yml (added) * spec/build/bsps/arm/stm32f4/opthclk.yml (added) * spec/build/bsps/arm/stm32f4/optoschse.yml (added) * spec/build/bsps/arm/stm32f4/optpclk1.yml (added) * spec/build/bsps/arm/stm32f4/optpclk2.yml (added) * spec/build/bsps/arm/stm32f4/optsysclk.yml (added) * spec/build/bsps/arm/stm32f4/optusartbaud.yml (added) * spec/build/bsps/arm/stm32f4/tststm32f105rc.yml (added) * spec/build/bsps/arm/tms570/abi.yml (added) * spec/build/bsps/arm/tms570/bspls3137hdk.yml (added) * spec/build/bsps/arm/tms570/bspls3137hdkintram.yml (added) * spec/build/bsps/arm/tms570/bspls3137hdksdram.yml (added) * spec/build/bsps/arm/tms570/bspls3137hdkwithloader.yml (added) * spec/build/bsps/arm/tms570/grp.yml (added) * spec/build/bsps/arm/tms570/obj.yml (added) * spec/build/bsps/arm/tms570/objhwinit.yml (added) * spec/build/bsps/arm/tms570/optcclk.yml (added) * spec/build/bsps/arm/tms570/optconirq.yml (added) * spec/build/bsps/arm/tms570/optlowinit.yml (added) * spec/build/bsps/arm/tms570/optmintskstksz.yml (added) * spec/build/bsps/arm/tms570/optoscmain.yml (added) * spec/build/bsps/arm/tms570/optoscrtc.yml (added) * spec/build/bsps/arm/tms570/optreginit.yml (added) * spec/build/bsps/arm/tms570/optscibaud.yml (added) * spec/build/bsps/arm/tms570/opttms570ls3137.yml (added) * spec/build/bsps/arm/tms570/tstls3137hdkintram.yml (added) * spec/build/bsps/arm/xen/abi.yml (added) * spec/build/bsps/arm/xen/bspxen.yml (added) * spec/build/bsps/arm/xen/linkcmds.yml (added) * spec/build/bsps/arm/xen/optgentmrusevirt.yml (added) * spec/build/bsps/arm/xen/optgentmunmask.yml (added) * spec/build/bsps/arm/xen/optloadoff.yml (added) * spec/build/bsps/arm/xen/optnocachelen.yml (added) * spec/build/bsps/arm/xen/optramlen.yml (added) * spec/build/bsps/arm/xen/optramori.yml (added) * spec/build/bsps/arm/xen/optzimghdr.yml (added) * spec/build/bsps/arm/xilinx-zynq/abi.yml (added) * spec/build/bsps/arm/xilinx-zynq/bspqemu.yml (added) * spec/build/bsps/arm/xilinx-zynq/bspzc702.yml (added) * spec/build/bsps/arm/xilinx-zynq/bspzc706.yml (added) * spec/build/bsps/arm/xilinx-zynq/bspzedboard.yml (added) * spec/build/bsps/arm/xilinx-zynq/grp.yml (added) * spec/build/bsps/arm/xilinx-zynq/linkcmds.yml (added) * spec/build/bsps/arm/xilinx-zynq/obj.yml (added) * spec/build/bsps/arm/xilinx-zynq/objsmp.yml (added) * spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml (added) * spec/build/bsps/arm/xilinx-zynq/optcachedata.yml (added) * spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml (added) * spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml (added) * spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml (added) * spec/build/bsps/arm/xilinx-zynq/optclkuart.yml (added) * spec/build/bsps/arm/xilinx-zynq/optconirq.yml (added) * spec/build/bsps/arm/xilinx-zynq/optconminor.yml (added) * spec/build/bsps/arm/xilinx-zynq/optint0len.yml (added) * spec/build/bsps/arm/xilinx-zynq/optint0ori.yml (added) * spec/build/bsps/arm/xilinx-zynq/optint1len.yml (added) * spec/build/bsps/arm/xilinx-zynq/optint1ori.yml (added) * spec/build/bsps/arm/xilinx-zynq/optnocachelen.yml (added) * spec/build/bsps/arm/xilinx-zynq/optramlen.yml (added) * spec/build/bsps/arm/xilinx-zynq/optramori.yml (added) * spec/build/bsps/arm/xilinx-zynq/optresetvec.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/abi.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/linkcmds.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/objsmp.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optconirq.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optconminor.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optgentmrfreq.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optgentmrusevirt.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optint0len.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optint0ori.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optint1len.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optint1ori.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optnocachelen.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optramlen.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optramori.yml (added) * spec/build/bsps/arm/xilinx-zynqmp/optresetvec.yml (added) * spec/build/bsps/bfin/TLL6527M/abi.yml (added) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (added) * spec/build/bsps/bfin/TLL6527M/optconbaud.yml (added) * spec/build/bsps/bfin/TLL6527M/optconirq.yml (added) * spec/build/bsps/bfin/TLL6527M/optirqtbl.yml (added) * spec/build/bsps/bfin/TLL6527M/optskyeye.yml (added) * spec/build/bsps/bfin/TLL6527M/optuartdma.yml (added) * spec/build/bsps/bfin/bf537Stamp/abi.yml (added) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (added) * spec/build/bsps/bfin/bf537Stamp/objnet.yml (added) * spec/build/bsps/bfin/bf537Stamp/optconirq.yml (added) * spec/build/bsps/bfin/bf537Stamp/optskyeye.yml (added) * spec/build/bsps/bfin/bf537Stamp/start.yml (added) * spec/build/bsps/bfin/eZKit533/abi.yml (added) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (added) * spec/build/bsps/bfin/eZKit533/optconirq.yml (added) * spec/build/bsps/bfin/eZKit533/optskyeye.yml (added) * spec/build/bsps/bfin/grp.yml (added) * spec/build/bsps/bfin/obj.yml (added) * spec/build/bsps/bfin/start.yml (added) * spec/build/bsps/bspopts.yml (added) * spec/build/bsps/grpmake.yml (added) * spec/build/bsps/i386/grp.yml (added) * spec/build/bsps/i386/pc386/abi.yml (added) * spec/build/bsps/i386/pc386/bsppc386.yml (added) * spec/build/bsps/i386/pc386/bsppc486.yml (added) * spec/build/bsps/i386/pc386/bsppc586.yml (added) * spec/build/bsps/i386/pc386/bsppc586sse.yml (added) * spec/build/bsps/i386/pc386/bsppc686.yml (added) * spec/build/bsps/i386/pc386/bsppcp4.yml (added) * spec/build/bsps/i386/pc386/grp.yml (added) * spec/build/bsps/i386/pc386/obj.yml (added) * spec/build/bsps/i386/pc386/objide.yml (added) * spec/build/bsps/i386/pc386/objnet.yml (added) * spec/build/bsps/i386/pc386/objsmp.yml (added) * spec/build/bsps/i386/pc386/objvga.yml (added) * spec/build/bsps/i386/pc386/objvgacir.yml (added) * spec/build/bsps/i386/pc386/objvgavbe.yml (added) * spec/build/bsps/i386/pc386/objvgavga.yml (added) * spec/build/bsps/i386/pc386/optcirrus.yml (added) * spec/build/bsps/i386/pc386/optclk8253.yml (added) * spec/build/bsps/i386/pc386/optclktsc.yml (added) * spec/build/bsps/i386/pc386/optconcom1.yml (added) * spec/build/bsps/i386/pc386/optencom14.yml (added) * spec/build/bsps/i386/pc386/optenide.yml (added) * spec/build/bsps/i386/pc386/optenvga.yml (added) * spec/build/bsps/i386/pc386/optgdbstub.yml (added) * spec/build/bsps/i386/pc386/optgdtdesc.yml (added) * spec/build/bsps/i386/pc386/optidepriifc.yml (added) * spec/build/bsps/i386/pc386/optidesecifc.yml (added) * spec/build/bsps/i386/pc386/optvberm.yml (added) * spec/build/bsps/i386/pc386/optvga.yml (added) * spec/build/bsps/i386/pc386/optvideo80x50.yml (added) * spec/build/bsps/i386/pc386/start.yml (added) * spec/build/bsps/linkcmds.yml (added) * spec/build/bsps/lm32/grp.yml (added) * spec/build/bsps/lm32/lm32_evr/abi.yml (added) * spec/build/bsps/lm32/lm32_evr/bspgdbsim.yml (added) * spec/build/bsps/lm32/lm32_evr/bsplm32evr.yml (added) * spec/build/bsps/lm32/lm32_evr/grp.yml (added) * spec/build/bsps/lm32/lm32_evr/obj.yml (added) * spec/build/bsps/lm32/lm32_evr/objnet.yml (added) * spec/build/bsps/lm32/lm32_evr/optsim.yml (added) * spec/build/bsps/lm32/milkymist/abi.yml (added) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (added) * spec/build/bsps/lm32/milkymist/objnet.yml (added) * spec/build/bsps/lm32/milkymist/optsim.yml (added) * spec/build/bsps/lm32/start.yml (added) * spec/build/bsps/m68k/av5282/abi.yml (added) * spec/build/bsps/m68k/av5282/bspav5282.yml (added) * spec/build/bsps/m68k/av5282/objnet.yml (added) * spec/build/bsps/m68k/av5282/start.yml (added) * spec/build/bsps/m68k/csb360/abi.yml (added) * spec/build/bsps/m68k/csb360/bspcsb360.yml (added) * spec/build/bsps/m68k/csb360/start.yml (added) * spec/build/bsps/m68k/gen68340/abi.yml (added) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (added) * spec/build/bsps/m68k/gen68340/start.yml (added) * spec/build/bsps/m68k/gen68360/abi.yml (added) * spec/build/bsps/m68k/gen68360/bspgen68360.yml (added) * spec/build/bsps/m68k/gen68360/bspgen68360040.yml (added) * spec/build/bsps/m68k/gen68360/bsppgh360.yml (added) * spec/build/bsps/m68k/gen68360/grp.yml (added) * spec/build/bsps/m68k/gen68360/obj.yml (added) * spec/build/bsps/m68k/gen68360/objnet.yml (added) * spec/build/bsps/m68k/gen68360/opt68360.yml (added) * spec/build/bsps/m68k/gen68360/opt68360x040.yml (added) * spec/build/bsps/m68k/gen68360/optpgh360.yml (added) * spec/build/bsps/m68k/gen68360/start.yml (added) * spec/build/bsps/m68k/genmcf548x/abi.yml (added) * spec/build/bsps/m68k/genmcf548x/bspcobra5475.yml (added) * spec/build/bsps/m68k/genmcf548x/bspm5484fireengine.yml (added) * spec/build/bsps/m68k/genmcf548x/grp.yml (added) * spec/build/bsps/m68k/genmcf548x/obj.yml (added) * spec/build/bsps/m68k/genmcf548x/objnet.yml (added) * spec/build/bsps/m68k/genmcf548x/optcpuclk.yml (added) * spec/build/bsps/m68k/genmcf548x/optdbug.yml (added) * spec/build/bsps/m68k/genmcf548x/optlowinit.yml (added) * spec/build/bsps/m68k/genmcf548x/optm5484fireengine.yml (added) * spec/build/bsps/m68k/genmcf548x/start.yml (added) * spec/build/bsps/m68k/grp.yml (added) * spec/build/bsps/m68k/mcf5206elite/abi.yml (added) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (added) * spec/build/bsps/m68k/mcf5206elite/start.yml (added) * spec/build/bsps/m68k/mcf5206elite/tstmcf5206elite.yml (added) * spec/build/bsps/m68k/mcf52235/abi.yml (added) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (added) * spec/build/bsps/m68k/mcf52235/start.yml (added) * spec/build/bsps/m68k/mcf52235/tstmcf52235.yml (added) * spec/build/bsps/m68k/mcf5225x/abi.yml (added) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (added) * spec/build/bsps/m68k/mcf5225x/start.yml (added) * spec/build/bsps/m68k/mcf5225x/tstmcf5225x.yml (added) * spec/build/bsps/m68k/mcf5235/abi.yml (added) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (added) * spec/build/bsps/m68k/mcf5235/objnet.yml (added) * spec/build/bsps/m68k/mcf5235/start.yml (added) * spec/build/bsps/m68k/mcf5329/abi.yml (added) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (added) * spec/build/bsps/m68k/mcf5329/objnet.yml (added) * spec/build/bsps/m68k/mcf5329/start.yml (added) * spec/build/bsps/m68k/mrm332/abi.yml (added) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (added) * spec/build/bsps/m68k/mrm332/start.yml (added) * spec/build/bsps/m68k/mrm332/tstmrm332.yml (added) * spec/build/bsps/m68k/mvme147/abi.yml (added) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (added) * spec/build/bsps/m68k/mvme147s/abi.yml (added) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (added) * spec/build/bsps/m68k/mvme147s/objmpci.yml (added) * spec/build/bsps/m68k/mvme162/abi.yml (added) * spec/build/bsps/m68k/mvme162/bspmvme162.yml (added) * spec/build/bsps/m68k/mvme162/bspmvme162lx.yml (added) * spec/build/bsps/m68k/mvme162/grp.yml (added) * spec/build/bsps/m68k/mvme162/obj.yml (added) * spec/build/bsps/m68k/mvme162/objnet.yml (added) * spec/build/bsps/m68k/mvme162/tstmvme162.yml (added) * spec/build/bsps/m68k/mvme162/tstmvme162lx.yml (added) * spec/build/bsps/m68k/mvme167/abi.yml (added) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (added) * spec/build/bsps/m68k/mvme167/objnet.yml (added) * spec/build/bsps/m68k/mvme167/optconminor.yml (added) * spec/build/bsps/m68k/mvme167/optintlvl.yml (added) * spec/build/bsps/m68k/mvme167/optiomode.yml (added) * spec/build/bsps/m68k/mvme167/optmvme167.yml (added) * spec/build/bsps/m68k/mvme167/optprintkminor.yml (added) * spec/build/bsps/m68k/mvme167/optuseterm.yml (added) * spec/build/bsps/m68k/objfpsp.yml (added) * spec/build/bsps/m68k/start.yml (added) * spec/build/bsps/m68k/uC5282/abi.yml (added) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (added) * spec/build/bsps/m68k/uC5282/objnet.yml (added) * spec/build/bsps/m68k/uC5282/start.yml (added) * spec/build/bsps/makebsp.yml (added) * spec/build/bsps/makecustom.yml (added) * spec/build/bsps/makeinc.yml (added) * spec/build/bsps/maketarget.yml (added) * spec/build/bsps/mips/csb350/abi.yml (added) * spec/build/bsps/mips/csb350/bspcsb350.yml (added) * spec/build/bsps/mips/csb350/objnet.yml (added) * spec/build/bsps/mips/csb350/start.yml (added) * spec/build/bsps/mips/grp.yml (added) * spec/build/bsps/mips/hurricane/abi.yml (added) * spec/build/bsps/mips/hurricane/bsphurricane.yml (added) * spec/build/bsps/mips/hurricane/optrm52xx.yml (added) * spec/build/bsps/mips/hurricane/optusc320.yml (added) * spec/build/bsps/mips/hurricane/start.yml (added) * spec/build/bsps/mips/jmr3904/abi.yml (added) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (added) * spec/build/bsps/mips/jmr3904/start.yml (added) * spec/build/bsps/mips/jmr3904/tstjmr3904.yml (added) * spec/build/bsps/mips/malta/abi.yml (added) * spec/build/bsps/mips/malta/bspmalta.yml (added) * spec/build/bsps/mips/malta/start.yml (added) * spec/build/bsps/mips/rbtx4925/abi.yml (added) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (added) * spec/build/bsps/mips/rbtx4925/opttx49xx.yml (added) * spec/build/bsps/mips/rbtx4925/start.yml (added) * spec/build/bsps/mips/rbtx4938/abi.yml (added) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (added) * spec/build/bsps/mips/rbtx4938/start.yml (added) * spec/build/bsps/moxie/moxiesim/abi.yml (added) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (added) * spec/build/bsps/moxie/moxiesim/start.yml (added) * spec/build/bsps/nios2/nios2_iss/abi.yml (added) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (added) * spec/build/bsps/nios2/nios2_iss/start.yml (added) * spec/build/bsps/obj.yml (added) * spec/build/bsps/objgrlib.yml (added) * spec/build/bsps/objgrlibnet.yml (added) * spec/build/bsps/objgrlibnosmp.yml (added) * spec/build/bsps/objirq.yml (added) * spec/build/bsps/objirqdflt.yml (added) * spec/build/bsps/objmpci.yml (added) * spec/build/bsps/objnet.yml (added) * spec/build/bsps/objnetnosmp.yml (added) * spec/build/bsps/optabi.yml (added) * spec/build/bsps/optasflags.yml (added) * spec/build/bsps/optbsp.yml (added) * spec/build/bsps/optcachedata.yml (added) * spec/build/bsps/optcacheinst.yml (added) * spec/build/bsps/optclang.yml (added) * spec/build/bsps/optclkbootcpu.yml (added) * spec/build/bsps/optclkfastidle.yml (added) * spec/build/bsps/optconsolebaud.yml (added) * spec/build/bsps/optconsoleirq.yml (added) * spec/build/bsps/optfatalverb.yml (added) * spec/build/bsps/optgcc.yml (added) * spec/build/bsps/optincludes.yml (added) * spec/build/bsps/optldflags.yml (added) * spec/build/bsps/optldflagsbsp.yml (added) * spec/build/bsps/optmake.yml (added) * spec/build/bsps/optmakelegacy.yml (added) * spec/build/bsps/opto0.yml (added) * spec/build/bsps/opto1.yml (added) * spec/build/bsps/opto2.yml (added) * spec/build/bsps/optog.yml (added) * spec/build/bsps/optos.yml (added) * spec/build/bsps/optprintexcpt.yml (added) * spec/build/bsps/optreset.yml (added) * spec/build/bsps/optresetkey.yml (added) * spec/build/bsps/or1k/generic_or1k/abi.yml (added) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (added) * spec/build/bsps/or1k/generic_or1k/optperiphclk.yml (added) * spec/build/bsps/or1k/generic_or1k/optresetvec.yml (added) * spec/build/bsps/or1k/generic_or1k/start.yml (added) * spec/build/bsps/or1k/grp.yml (added) * spec/build/bsps/pkgconfig.yml (added) * spec/build/bsps/powerpc/beatnik/abi.yml (added) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (added) * spec/build/bsps/powerpc/beatnik/objnet.yml (added) * spec/build/bsps/powerpc/beatnik/optsbrk.yml (added) * spec/build/bsps/powerpc/crti.yml (added) * spec/build/bsps/powerpc/crtn.yml (added) * spec/build/bsps/powerpc/gen5200/abi.yml (added) * spec/build/bsps/powerpc/gen5200/bspicecube.yml (added) * spec/build/bsps/powerpc/gen5200/bsppm520cr825.yml (added) * spec/build/bsps/powerpc/gen5200/bsppm520ze30.yml (added) * spec/build/bsps/powerpc/gen5200/grp.yml (added) * spec/build/bsps/powerpc/gen5200/obj.yml (added) * spec/build/bsps/powerpc/gen5200/objnet.yml (added) * spec/build/bsps/powerpc/gen5200/optbenchirq.yml (added) * spec/build/bsps/powerpc/gen5200/optenirqnest.yml (added) * spec/build/bsps/powerpc/gen5200/optgpiomsk.yml (added) * spec/build/bsps/powerpc/gen5200/optgpioval.yml (added) * spec/build/bsps/powerpc/gen5200/opticecub.yml (added) * spec/build/bsps/powerpc/gen5200/optpm520cr825.yml (added) * spec/build/bsps/powerpc/gen5200/optpm520ze30.yml (added) * spec/build/bsps/powerpc/gen5200/optprintkminor.yml (added) * spec/build/bsps/powerpc/gen5200/optpscgps.yml (added) * spec/build/bsps/powerpc/gen5200/optsinglechar.yml (added) * spec/build/bsps/powerpc/gen5200/optuartmsk.yml (added) * spec/build/bsps/powerpc/gen5200/optuartstermirq.yml (added) * spec/build/bsps/powerpc/gen5200/optuboot.yml (added) * spec/build/bsps/powerpc/gen5200/start.yml (added) * spec/build/bsps/powerpc/gen83xx/abi.yml (added) * spec/build/bsps/powerpc/gen83xx/bspbruid.yml (added) * spec/build/bsps/powerpc/gen83xx/bsphsccm01.yml (added) * spec/build/bsps/powerpc/gen83xx/bspmpc8309som.yml (added) * spec/build/bsps/powerpc/gen83xx/bspmpc8313erdb.yml (added) * spec/build/bsps/powerpc/gen83xx/bspmpc8349eamds.yml (added) * spec/build/bsps/powerpc/gen83xx/grp.yml (added) * spec/build/bsps/powerpc/gen83xx/obj.yml (added) * spec/build/bsps/powerpc/gen83xx/objnet.yml (added) * spec/build/bsps/powerpc/gen83xx/optbruid.yml (added) * spec/build/bsps/powerpc/gen83xx/optchiptype.yml (added) * spec/build/bsps/powerpc/gen83xx/opthsccm01.yml (added) * spec/build/bsps/powerpc/gen83xx/optirqnest.yml (added) * spec/build/bsps/powerpc/gen83xx/optmpc8309som.yml (added) * spec/build/bsps/powerpc/gen83xx/optmpc8313erdb.yml (added) * spec/build/bsps/powerpc/gen83xx/optmpc8349eamds.yml (added) * spec/build/bsps/powerpc/gen83xx/optnandcs0.yml (added) * spec/build/bsps/powerpc/gen83xx/optnet0phy.yml (added) * spec/build/bsps/powerpc/gen83xx/optuart2.yml (added) * spec/build/bsps/powerpc/gen83xx/optuartirq.yml (added) * spec/build/bsps/powerpc/gen83xx/optuboot.yml (added) * spec/build/bsps/powerpc/gen83xx/optulpi.yml (added) * spec/build/bsps/powerpc/gen83xx/start.yml (added) * spec/build/bsps/powerpc/grp.yml (added) * spec/build/bsps/powerpc/haleakala/abi.yml (added) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (added) * spec/build/bsps/powerpc/haleakala/objnet.yml (added) * spec/build/bsps/powerpc/haleakala/optsprg.yml (added) * spec/build/bsps/powerpc/haleakala/optvecbase.yml (added) * spec/build/bsps/powerpc/haleakala/start.yml (added) * spec/build/bsps/powerpc/motld.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/abi.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/boot.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspmcp750.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspmtx603e.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspmvme2100.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspmvme2307.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspqemu.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/bspqemualtivec.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/objqemunet.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optmpc603e.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optmpc750.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optmpc8240.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optppcgeneric.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/optsbrk.yml (added) * spec/build/bsps/powerpc/motorola_powerpc/qemufakerom.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/abi.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspgwlcfm.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5566evb.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5643levb.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5668g.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspmpc5674fevb.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/bspphycorempc5554.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/grp.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/objnet.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optbootflg.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optcachewritethru.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optchipfam.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optconbaud.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optconminor.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optearlystksz.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/opteepromname.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/opteeprompath.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optenstartpro.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optesciirq.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optexcbooke.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optexcfixdhdlr.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllesyncr1.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optgwlcfm.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optphycorempc5554.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc91111.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9111enaddr.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ibige.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218iled.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218irxchn.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsmc9218itxchn.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/start.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/tstgwlcfm.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/tstmpc5643ldpu.yml (added) * spec/build/bsps/powerpc/mpc55xxevb/tstmpc5643levb.yml (added) * spec/build/bsps/powerpc/mpc8260ads/abi.yml (added) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (added) * spec/build/bsps/powerpc/mpc8260ads/objnet.yml (added) * spec/build/bsps/powerpc/mpc8260ads/optconminor.yml (added) * spec/build/bsps/powerpc/mpc8260ads/optdisphandstat.yml (added) * spec/build/bsps/powerpc/mpc8260ads/optprintkminor.yml (added) * spec/build/bsps/powerpc/mpc8260ads/optuartsiomode.yml (added) * spec/build/bsps/powerpc/mpc8260ads/optuartsterm.yml (added) * spec/build/bsps/powerpc/mpc8260ads/start.yml (added) * spec/build/bsps/powerpc/mvme3100/abi.yml (added) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (added) * spec/build/bsps/powerpc/mvme3100/objnet.yml (added) * spec/build/bsps/powerpc/mvme3100/optsbrk.yml (added) * spec/build/bsps/powerpc/mvme3100/start.yml (added) * spec/build/bsps/powerpc/mvme5500/abi.yml (added) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (added) * spec/build/bsps/powerpc/mvme5500/objnet.yml (added) * spec/build/bsps/powerpc/mvme5500/optsbrk.yml (added) * spec/build/bsps/powerpc/mvme5500/start.yml (added) * spec/build/bsps/powerpc/obj.yml (added) * spec/build/bsps/powerpc/objexc.yml (added) * spec/build/bsps/powerpc/objvme.yml (added) * spec/build/bsps/powerpc/psim/abi.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (added) * spec/build/bsps/powerpc/psim/objmpci.yml (added) * spec/build/bsps/powerpc/psim/objnet.yml (added) * spec/build/bsps/powerpc/psim/optclkfastidle.yml (added) * spec/build/bsps/powerpc/psim/optsbrk.yml (added) * spec/build/bsps/powerpc/psim/optsprg.yml (added) * spec/build/bsps/powerpc/psim/optvecbase.yml (added) * spec/build/bsps/powerpc/psim/start.yml (added) * spec/build/bsps/powerpc/qemuppc/abi.yml (added) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (added) * spec/build/bsps/powerpc/qemuppc/start.yml (added) * spec/build/bsps/powerpc/qoriq/abi.yml (added) * spec/build/bsps/powerpc/qoriq/bspcore0.yml (added) * spec/build/bsps/powerpc/qoriq/bspcore1.yml (added) * spec/build/bsps/powerpc/qoriq/bspe500.yml (added) * spec/build/bsps/powerpc/qoriq/bspe650032.yml (added) * spec/build/bsps/powerpc/qoriq/bspe650064.yml (added) * spec/build/bsps/powerpc/qoriq/grp.yml (added) * spec/build/bsps/powerpc/qoriq/obj.yml (added) * spec/build/bsps/powerpc/qoriq/objnet.yml (added) * spec/build/bsps/powerpc/qoriq/objsmp.yml (added) * spec/build/bsps/powerpc/qoriq/optbucsr.yml (added) * spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml (added) * spec/build/bsps/powerpc/qoriq/optcachealign.yml (added) * spec/build/bsps/powerpc/qoriq/optcacheblktouch.yml (added) * spec/build/bsps/powerpc/qoriq/optcachedatal1sz.yml (added) * spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml (added) * spec/build/bsps/powerpc/qoriq/optcacheinstl1sz.yml (added) * spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml (added) * spec/build/bsps/powerpc/qoriq/optchipnum.yml (added) * spec/build/bsps/powerpc/qoriq/optchipser.yml (added) * spec/build/bsps/powerpc/qoriq/optclktmctr.yml (added) * spec/build/bsps/powerpc/qoriq/optclktmr.yml (added) * spec/build/bsps/powerpc/qoriq/optcpucnt.yml (added) * spec/build/bsps/powerpc/qoriq/optetsec1phy.yml (added) * spec/build/bsps/powerpc/qoriq/optetsec2phy.yml (added) * spec/build/bsps/powerpc/qoriq/optetsec3phy.yml (added) * spec/build/bsps/powerpc/qoriq/optexcbooke.yml (added) * spec/build/bsps/powerpc/qoriq/optexcfixdhdlr.yml (added) * spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml (added) * spec/build/bsps/powerpc/qoriq/optfdtro.yml (added) * spec/build/bsps/powerpc/qoriq/opthid0.yml (added) * spec/build/bsps/powerpc/qoriq/opthyp.yml (added) * spec/build/bsps/powerpc/qoriq/opthypguest.yml (added) * spec/build/bsps/powerpc/qoriq/opticombegin.yml (added) * spec/build/bsps/powerpc/qoriq/opticomsz.yml (added) * spec/build/bsps/powerpc/qoriq/optmas7.yml (added) * spec/build/bsps/powerpc/qoriq/optmsr.yml (added) * spec/build/bsps/powerpc/qoriq/optspefscr.yml (added) * spec/build/bsps/powerpc/qoriq/optthrdcnt.yml (added) * spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml (added) * spec/build/bsps/powerpc/qoriq/optuart0en.yml (added) * spec/build/bsps/powerpc/qoriq/optuart1en.yml (added) * spec/build/bsps/powerpc/qoriq/optuartbrg0en.yml (added) * spec/build/bsps/powerpc/qoriq/optuartbrg1en.yml (added) * spec/build/bsps/powerpc/qoriq/optuartbrgmas.yml (added) * spec/build/bsps/powerpc/qoriq/optuartbrgpri.yml (added) * spec/build/bsps/powerpc/qoriq/optuartbrgslv.yml (added) * spec/build/bsps/powerpc/qoriq/optuartirq.yml (added) * spec/build/bsps/powerpc/qoriq/start.yml (added) * spec/build/bsps/powerpc/ss555/abi.yml (added) * spec/build/bsps/powerpc/ss555/bspss555.yml (added) * spec/build/bsps/powerpc/ss555/optconminor.yml (added) * spec/build/bsps/powerpc/ss555/optprintkminor.yml (added) * spec/build/bsps/powerpc/ss555/optuartsiomode.yml (added) * spec/build/bsps/powerpc/ss555/optuartsterm.yml (added) * spec/build/bsps/powerpc/ss555/optwdgtimeout.yml (added) * spec/build/bsps/powerpc/ss555/start.yml (added) * spec/build/bsps/powerpc/start.yml (added) * spec/build/bsps/powerpc/t32mppc/abi.yml (added) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (added) * spec/build/bsps/powerpc/t32mppc/objsmp.yml (added) * spec/build/bsps/powerpc/t32mppc/optexcbooke.yml (added) * spec/build/bsps/powerpc/t32mppc/optexcfixdhdlr.yml (added) * spec/build/bsps/powerpc/t32mppc/start.yml (added) * spec/build/bsps/powerpc/tqm8xx/abi.yml (added) * spec/build/bsps/powerpc/tqm8xx/bsppghplus.yml (added) * spec/build/bsps/powerpc/tqm8xx/bspstk8xx.yml (added) * spec/build/bsps/powerpc/tqm8xx/grp.yml (added) * spec/build/bsps/powerpc/tqm8xx/obj.yml (added) * spec/build/bsps/powerpc/tqm8xx/objnet.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconchn.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconscc1.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconscc2.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconscc3.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconscc4.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconsmc1.yml (added) * spec/build/bsps/powerpc/tqm8xx/optconsmc2.yml (added) * spec/build/bsps/powerpc/tqm8xx/optnetfec.yml (added) * spec/build/bsps/powerpc/tqm8xx/optnetscc.yml (added) * spec/build/bsps/powerpc/tqm8xx/optprintkchn.yml (added) * spec/build/bsps/powerpc/tqm8xx/start.yml (added) * spec/build/bsps/powerpc/vecentry.yml (added) * spec/build/bsps/powerpc/virtex/abi.yml (added) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (added) * spec/build/bsps/powerpc/virtex/linkcmds.yml (added) * spec/build/bsps/powerpc/virtex/objnet.yml (added) * spec/build/bsps/powerpc/virtex/optconirq.yml (added) * spec/build/bsps/powerpc/virtex/optfastramlen.yml (added) * spec/build/bsps/powerpc/virtex/optfastramorg.yml (added) * spec/build/bsps/powerpc/virtex/optramlen.yml (added) * spec/build/bsps/powerpc/virtex/optramorg.yml (added) * spec/build/bsps/powerpc/virtex/optresetlen.yml (added) * spec/build/bsps/powerpc/virtex/optresetorg.yml (added) * spec/build/bsps/powerpc/virtex/optxparam.yml (added) * spec/build/bsps/powerpc/virtex/start.yml (added) * spec/build/bsps/powerpc/virtex4/abi.yml (added) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (added) * spec/build/bsps/powerpc/virtex4/optppccachedata.yml (added) * spec/build/bsps/powerpc/virtex4/optsprg.yml (added) * spec/build/bsps/powerpc/virtex4/optvecbase.yml (added) * spec/build/bsps/powerpc/virtex4/start.yml (added) * spec/build/bsps/powerpc/virtex5/abi.yml (added) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (added) * spec/build/bsps/powerpc/virtex5/optppccachedata.yml (added) * spec/build/bsps/powerpc/virtex5/optsprg.yml (added) * spec/build/bsps/powerpc/virtex5/optvecbase.yml (added) * spec/build/bsps/powerpc/virtex5/start.yml (added) * spec/build/bsps/riscv/griscv/abi.yml (added) * spec/build/bsps/riscv/griscv/bspgriscv.yml (added) * spec/build/bsps/riscv/griscv/bspgrv32i.yml (added) * spec/build/bsps/riscv/griscv/bspgrv32im.yml (added) * spec/build/bsps/riscv/griscv/bspgrv32imac.yml (added) * spec/build/bsps/riscv/griscv/bspgrv32imafdc.yml (added) * spec/build/bsps/riscv/griscv/grp.yml (added) * spec/build/bsps/riscv/griscv/obj.yml (added) * spec/build/bsps/riscv/griscv/objsmp.yml (added) * spec/build/bsps/riscv/griscv/optextirqmax.yml (added) * spec/build/bsps/riscv/grp.yml (added) * spec/build/bsps/riscv/linkcmds.yml (added) * spec/build/bsps/riscv/linkcmdsbase.yml (added) * spec/build/bsps/riscv/optrambegin.yml (added) * spec/build/bsps/riscv/optramsize.yml (added) * spec/build/bsps/riscv/riscv/abi.yml (added) * spec/build/bsps/riscv/riscv/bspfrdme310arty.yml (added) * spec/build/bsps/riscv/riscv/bsprv32i.yml (added) * spec/build/bsps/riscv/riscv/bsprv32iac.yml (added) * spec/build/bsps/riscv/riscv/bsprv32im.yml (added) * spec/build/bsps/riscv/riscv/bsprv32imac.yml (added) * spec/build/bsps/riscv/riscv/bsprv32imafc.yml (added) * spec/build/bsps/riscv/riscv/bsprv32imafd.yml (added) * spec/build/bsps/riscv/riscv/bsprv32imafdc.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imac.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imacmedany.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imafd.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imafdc.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imafdcmedany.yml (added) * spec/build/bsps/riscv/riscv/bsprv64imafdmedany.yml (added) * spec/build/bsps/riscv/riscv/grp.yml (added) * spec/build/bsps/riscv/riscv/obj.yml (added) * spec/build/bsps/riscv/riscv/objsmp.yml (added) * spec/build/bsps/riscv/riscv/optextirqmax.yml (added) * spec/build/bsps/riscv/riscv/optfdtcpyro.yml (added) * spec/build/bsps/riscv/riscv/optfdtmxsz.yml (added) * spec/build/bsps/riscv/riscv/optfdtro.yml (added) * spec/build/bsps/riscv/riscv/optfdtuboot.yml (added) * spec/build/bsps/riscv/riscv/optfrdme310arty.yml (added) * spec/build/bsps/riscv/riscv/opthtif.yml (added) * spec/build/bsps/riscv/riscv/optns16550max.yml (added) * spec/build/bsps/riscv/start.yml (added) * spec/build/bsps/sh/gensh1/abi.yml (added) * spec/build/bsps/sh/gensh1/bspgensh1.yml (added) * spec/build/bsps/sh/gensh1/optcpuclk.yml (added) * spec/build/bsps/sh/gensh1/optlowinit.yml (added) * spec/build/bsps/sh/gensh1/start.yml (added) * spec/build/bsps/sh/gensh1/tstgensh1.yml (added) * spec/build/bsps/sh/gensh2/abi.yml (added) * spec/build/bsps/sh/gensh2/bspgensh2.yml (added) * spec/build/bsps/sh/gensh2/optcpuclk.yml (added) * spec/build/bsps/sh/gensh2/optevb.yml (added) * spec/build/bsps/sh/gensh2/optlowinit.yml (added) * spec/build/bsps/sh/gensh2/start.yml (added) * spec/build/bsps/sh/gensh2/tstgensh2.yml (added) * spec/build/bsps/sh/gensh4/abi.yml (added) * spec/build/bsps/sh/gensh4/bspgensh4.yml (added) * spec/build/bsps/sh/gensh4/optcpuclk.yml (added) * spec/build/bsps/sh/gensh4/optcpydata.yml (added) * spec/build/bsps/sh/gensh4/optlowinit.yml (added) * spec/build/bsps/sh/gensh4/start.yml (added) * spec/build/bsps/sh/shsim/abi.yml (added) * spec/build/bsps/sh/shsim/bspsimsh1.yml (added) * spec/build/bsps/sh/shsim/bspsimsh2.yml (added) * spec/build/bsps/sh/shsim/bspsimsh2e.yml (added) * spec/build/bsps/sh/shsim/bspsimsh4.yml (added) * spec/build/bsps/sh/shsim/grp.yml (added) * spec/build/bsps/sh/shsim/obj.yml (added) * spec/build/bsps/sh/shsim/optcpuclk.yml (added) * spec/build/bsps/sh/shsim/optlowinit.yml (added) * spec/build/bsps/sh/shsim/start.yml (added) * spec/build/bsps/sh/shsim/tstsimsh1.yml (added) * spec/build/bsps/sh/shsim/tstsimsh2.yml (added) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (added) * spec/build/bsps/sh/shsim/tstsimsh4.yml (added) * spec/build/bsps/sparc/erc32/abi.yml (added) * spec/build/bsps/sparc/erc32/bsperc32.yml (added) * spec/build/bsps/sparc/erc32/objnet.yml (added) * spec/build/bsps/sparc/erc32/objsmp.yml (added) * spec/build/bsps/sparc/erc32/optconirq.yml (added) * spec/build/bsps/sparc/erc32/optpwrdwnhlt.yml (added) * spec/build/bsps/sparc/grp.yml (added) * spec/build/bsps/sparc/leon2/abi.yml (added) * spec/build/bsps/sparc/leon2/bspat697f.yml (added) * spec/build/bsps/sparc/leon2/bspleon2.yml (added) * spec/build/bsps/sparc/leon2/grp.yml (added) * spec/build/bsps/sparc/leon2/obj.yml (added) * spec/build/bsps/sparc/leon2/objnet.yml (added) * spec/build/bsps/sparc/leon2/objsmp.yml (added) * spec/build/bsps/sparc/leon2/optconirq.yml (added) * spec/build/bsps/sparc/leon2/optpwrdwnhlt.yml (added) * spec/build/bsps/sparc/leon3/abi.yml (added) * spec/build/bsps/sparc/leon3/abiclang.yml (added) * spec/build/bsps/sparc/leon3/bspgr712rc.yml (added) * spec/build/bsps/sparc/leon3/bspgr740.yml (added) * spec/build/bsps/sparc/leon3/bspleon3.yml (added) * spec/build/bsps/sparc/leon3/bsput699.yml (added) * spec/build/bsps/sparc/leon3/bsput700.yml (added) * spec/build/bsps/sparc/leon3/grp.yml (added) * spec/build/bsps/sparc/leon3/obj.yml (added) * spec/build/bsps/sparc/leon3/objmpci.yml (added) * spec/build/bsps/sparc/leon3/objnet.yml (added) * spec/build/bsps/sparc/leon3/objnetnosmp.yml (added) * spec/build/bsps/sparc/leon3/objsmp.yml (added) * spec/build/bsps/sparc/leon3/optconirq.yml (added) * spec/build/bsps/sparc/leon3/optleon3smp.yml (added) * spec/build/bsps/sparc/leon3/optpwrdwnhlt.yml (added) * spec/build/bsps/sparc/start.yml (added) * spec/build/bsps/sparc64/grp.yml (added) * spec/build/bsps/sparc64/niagara/abi.yml (added) * spec/build/bsps/sparc64/niagara/bspniagara.yml (added) * spec/build/bsps/sparc64/start.yml (added) * spec/build/bsps/sparc64/usiii/abi.yml (added) * spec/build/bsps/sparc64/usiii/bspusiii.yml (added) * spec/build/bsps/sparc64/usiii/optclkfastidle.yml (added) * spec/build/bsps/tst.yml (added) * spec/build/bsps/tstnoiconv.yml (added) * spec/build/bsps/tstnointrcrit.yml (added) * spec/build/bsps/tstnojffs2.yml (added) * spec/build/bsps/tstnolibdl.yml (added) * spec/build/bsps/tstnorfs.yml (added) * spec/build/bsps/tstreqtick.yml (added) * spec/build/bsps/tstsmallmem.yml (added) * spec/build/bsps/v850/gdbv850sim/abi.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850e1sim.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850e2sim.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850e2v3sim.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850esim.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850essim.yml (added) * spec/build/bsps/v850/gdbv850sim/bspv850sim.yml (added) * spec/build/bsps/v850/gdbv850sim/grp.yml (added) * spec/build/bsps/v850/gdbv850sim/obj.yml (added) * spec/build/bsps/v850/gdbv850sim/start.yml (added) * spec/build/bsps/x86_64/amd64/abi.yml (added) * spec/build/bsps/x86_64/amd64/bspamd64.yml (added) * spec/build/bsps/x86_64/amd64/start.yml (added) * spec/build/bsps/x86_64/grp.yml (added) * spec/build/cpukit/cfgattrgetaff.yml (added) * spec/build/cpukit/cfgattrgetgrdsz.yml (added) * spec/build/cpukit/cfgattrgetstack.yml (added) * spec/build/cpukit/cfgattrsetaff.yml (added) * spec/build/cpukit/cfgattrsetgrdsz.yml (added) * spec/build/cpukit/cfgattrsetstack.yml (added) * spec/build/cpukit/cfgcfghdr.yml (added) * spec/build/cpukit/cfgcleanupctx.yml (added) * spec/build/cpukit/cfggetaff.yml (added) * spec/build/cpukit/cfggetattr.yml (added) * spec/build/cpukit/cfghdr.yml (added) * spec/build/cpukit/cfginttypes.yml (added) * spec/build/cpukit/cfgmemory.yml (added) * spec/build/cpukit/cfgnewlib.yml (added) * spec/build/cpukit/cfgpmtxceilcnst.yml (added) * spec/build/cpukit/cfgprionode.yml (added) * spec/build/cpukit/cfgpshdprmcnst.yml (added) * spec/build/cpukit/cfgrcmd.yml (added) * spec/build/cpukit/cfgsetaff.yml (added) * spec/build/cpukit/cfgstdatomic.yml (added) * spec/build/cpukit/cfgstdint.yml (added) * spec/build/cpukit/cfgstdlib.yml (added) * spec/build/cpukit/cfgstring.yml (added) * spec/build/cpukit/cfgstrings.yml (added) * spec/build/cpukit/cfgsysstat.yml (added) * spec/build/cpukit/cfgsystypes.yml (added) * spec/build/cpukit/cfgszoff.yml (added) * spec/build/cpukit/cfgszsize.yml (added) * spec/build/cpukit/cfgsztime.yml (added) * spec/build/cpukit/cfgunistd.yml (added) * spec/build/cpukit/cpuarm.yml (added) * spec/build/cpukit/cpubfin.yml (added) * spec/build/cpukit/cpui386.yml (added) * spec/build/cpukit/cpulm32.yml (added) * spec/build/cpukit/cpum68k.yml (added) * spec/build/cpukit/cpumips.yml (added) * spec/build/cpukit/cpumoxie.yml (added) * spec/build/cpukit/cpunios2.yml (added) * spec/build/cpukit/cpuopts.yml (added) * spec/build/cpukit/cpuor1k.yml (added) * spec/build/cpukit/cpupowerpc.yml (added) * spec/build/cpukit/cpuriscv.yml (added) * spec/build/cpukit/cpush.yml (added) * spec/build/cpukit/cpusparc.yml (added) * spec/build/cpukit/cpusparc64.yml (added) * spec/build/cpukit/cpuv850.yml (added) * spec/build/cpukit/cpux8664.yml (added) * spec/build/cpukit/grp.yml (added) * spec/build/cpukit/libdebugger.yml (added) * spec/build/cpukit/libftpd.yml (added) * spec/build/cpukit/libftpfs.yml (added) * spec/build/cpukit/libjffs2.yml (added) * spec/build/cpukit/libmghttpd.yml (added) * spec/build/cpukit/libnfs.yml (added) * spec/build/cpukit/libpppd.yml (added) * spec/build/cpukit/librtemscpu.yml (added) * spec/build/cpukit/librtemsdfltcfg.yml (added) * spec/build/cpukit/librtemstest.yml (added) * spec/build/cpukit/libtelnetd.yml (added) * spec/build/cpukit/libtftpfs.yml (added) * spec/build/cpukit/libz.yml (added) * spec/build/cpukit/objdbgarm.yml (added) * spec/build/cpukit/objdbgi386.yml (added) * spec/build/cpukit/objdl.yml (added) * spec/build/cpukit/objdlarm.yml (added) * spec/build/cpukit/objdli386.yml (added) * spec/build/cpukit/objdlm68k.yml (added) * spec/build/cpukit/objdlmips.yml (added) * spec/build/cpukit/objdlmoxie.yml (added) * spec/build/cpukit/objdlpowerpc.yml (added) * spec/build/cpukit/objdlsparc.yml (added) * spec/build/cpukit/objdrvmgr.yml (added) * spec/build/cpukit/objgnat.yml (added) * spec/build/cpukit/objmpci.yml (added) * spec/build/cpukit/objnet.yml (added) * spec/build/cpukit/objpci.yml (added) * spec/build/cpukit/objpsxsgnl.yml (added) * spec/build/cpukit/objshell.yml (added) * spec/build/cpukit/objsmp.yml (added) * spec/build/cpukit/objutf8.yml (added) * spec/build/cpukit/optada.yml (added) * spec/build/cpukit/optarchbits.yml (added) * spec/build/cpukit/optarflags.yml (added) * spec/build/cpukit/optclang.yml (added) * spec/build/cpukit/optdebug.yml (added) * spec/build/cpukit/optdrvmgr.yml (added) * spec/build/cpukit/optgcc.yml (added) * spec/build/cpukit/optincludes.yml (added) * spec/build/cpukit/optinstall.yml (added) * spec/build/cpukit/optlibdl.yml (added) * spec/build/cpukit/optmpci.yml (added) * spec/build/cpukit/optnet.yml (added) * spec/build/cpukit/optnewlib.yml (added) * spec/build/cpukit/optparavirt.yml (added) * spec/build/cpukit/optposix.yml (added) * spec/build/cpukit/optsmp.yml (added) * spec/build/cpukit/optszblkcnt.yml (added) * spec/build/cpukit/optszblksize.yml (added) * spec/build/cpukit/optszmode.yml (added) * spec/build/cpukit/optszoff.yml (added) * spec/build/cpukit/optsztime.yml (added) * spec/build/cpukit/optvermaj.yml (added) * spec/build/cpukit/optvermin.yml (added) * spec/build/cpukit/optverrev.yml (added) * spec/build/cpukit/optversion.yml (added) * spec/build/cpukit/optwarn.yml (added) * spec/build/cpukit/optwarncc.yml (added) * spec/build/cpukit/optwarncxx.yml (added) * spec/build/cpukit/vckey.yml (added) * spec/build/grp.yml (added) * spec/build/testsuites/ada/adabasesp.yml (added) * spec/build/testsuites/ada/adahello.yml (added) * spec/build/testsuites/ada/adamp01node1.yml (added) * spec/build/testsuites/ada/adamp01node2.yml (added) * spec/build/testsuites/ada/adamp03node1.yml (added) * spec/build/testsuites/ada/adamp03node2.yml (added) * spec/build/testsuites/ada/adamp04node1.yml (added) * spec/build/testsuites/ada/adamp04node2.yml (added) * spec/build/testsuites/ada/adamp05node1.yml (added) * spec/build/testsuites/ada/adamp05node2.yml (added) * spec/build/testsuites/ada/adamp06node1.yml (added) * spec/build/testsuites/ada/adamp06node2.yml (added) * spec/build/testsuites/ada/adamp07node1.yml (added) * spec/build/testsuites/ada/adamp07node2.yml (added) * spec/build/testsuites/ada/adamp08node1.yml (added) * spec/build/testsuites/ada/adamp08node2.yml (added) * spec/build/testsuites/ada/adamp09node1.yml (added) * spec/build/testsuites/ada/adamp09node2.yml (added) * spec/build/testsuites/ada/adamp10node1.yml (added) * spec/build/testsuites/ada/adamp10node2.yml (added) * spec/build/testsuites/ada/adamp11node1.yml (added) * spec/build/testsuites/ada/adamp11node2.yml (added) * spec/build/testsuites/ada/adamp12node1.yml (added) * spec/build/testsuites/ada/adamp12node2.yml (added) * spec/build/testsuites/ada/adamp13node1.yml (added) * spec/build/testsuites/ada/adamp13node2.yml (added) * spec/build/testsuites/ada/adamp14node1.yml (added) * spec/build/testsuites/ada/adamp14node2.yml (added) * spec/build/testsuites/ada/adansecs.yml (added) * spec/build/testsuites/ada/adasp01.yml (added) * spec/build/testsuites/ada/adasp02.yml (added) * spec/build/testsuites/ada/adasp03.yml (added) * spec/build/testsuites/ada/adasp04.yml (added) * spec/build/testsuites/ada/adasp05.yml (added) * spec/build/testsuites/ada/adasp06.yml (added) * spec/build/testsuites/ada/adasp07.yml (added) * spec/build/testsuites/ada/adasp08.yml (added) * spec/build/testsuites/ada/adasp09.yml (added) * spec/build/testsuites/ada/adasp11.yml (added) * spec/build/testsuites/ada/adasp12.yml (added) * spec/build/testsuites/ada/adasp13.yml (added) * spec/build/testsuites/ada/adasp14.yml (added) * spec/build/testsuites/ada/adasp15.yml (added) * spec/build/testsuites/ada/adasp16.yml (added) * spec/build/testsuites/ada/adasp17.yml (added) * spec/build/testsuites/ada/adasp19.yml (added) * spec/build/testsuites/ada/adasp20.yml (added) * spec/build/testsuites/ada/adasp22.yml (added) * spec/build/testsuites/ada/adasp23.yml (added) * spec/build/testsuites/ada/adasp24.yml (added) * spec/build/testsuites/ada/adasp25.yml (added) * spec/build/testsuites/ada/adaspatcb01.yml (added) * spec/build/testsuites/ada/adaspname01.yml (added) * spec/build/testsuites/ada/adaticker.yml (added) * spec/build/testsuites/ada/adatm01.yml (added) * spec/build/testsuites/ada/adatm02.yml (added) * spec/build/testsuites/ada/adatm03.yml (added) * spec/build/testsuites/ada/adatm04.yml (added) * spec/build/testsuites/ada/adatm05.yml (added) * spec/build/testsuites/ada/adatm06.yml (added) * spec/build/testsuites/ada/adatm07.yml (added) * spec/build/testsuites/ada/adatm08.yml (added) * spec/build/testsuites/ada/adatm09.yml (added) * spec/build/testsuites/ada/adatm10.yml (added) * spec/build/testsuites/ada/adatm11.yml (added) * spec/build/testsuites/ada/adatm12.yml (added) * spec/build/testsuites/ada/adatm13.yml (added) * spec/build/testsuites/ada/adatm14.yml (added) * spec/build/testsuites/ada/adatm15.yml (added) * spec/build/testsuites/ada/adatm16.yml (added) * spec/build/testsuites/ada/adatm17.yml (added) * spec/build/testsuites/ada/adatm18.yml (added) * spec/build/testsuites/ada/adatm19.yml (added) * spec/build/testsuites/ada/adatm20.yml (added) * spec/build/testsuites/ada/adatm21.yml (added) * spec/build/testsuites/ada/adatm22.yml (added) * spec/build/testsuites/ada/adatm23.yml (added) * spec/build/testsuites/ada/adatm24.yml (added) * spec/build/testsuites/ada/adatm25.yml (added) * spec/build/testsuites/ada/adatm28.yml (added) * spec/build/testsuites/ada/adatm29.yml (added) * spec/build/testsuites/ada/adatmck.yml (added) * spec/build/testsuites/ada/grp.yml (added) * spec/build/testsuites/ada/optgnat.yml (added) * spec/build/testsuites/benchmarks/dhrystone.yml (added) * spec/build/testsuites/benchmarks/grp.yml (added) * spec/build/testsuites/benchmarks/linpack.yml (added) * spec/build/testsuites/benchmarks/whetstone.yml (added) * spec/build/testsuites/fstests/fsbdpart01.yml (added) * spec/build/testsuites/fstests/fsclose01.yml (added) * spec/build/testsuites/fstests/fsdosfsformat01.yml (added) * spec/build/testsuites/fstests/fsdosfsname01.yml (added) * spec/build/testsuites/fstests/fsdosfsname02.yml (added) * spec/build/testsuites/fstests/fsdosfssync01.yml (added) * spec/build/testsuites/fstests/fsdosfswrite01.yml (added) * spec/build/testsuites/fstests/fsfseeko01.yml (added) * spec/build/testsuites/fstests/fsimfsconfig01.yml (added) * spec/build/testsuites/fstests/fsimfsconfig02.yml (added) * spec/build/testsuites/fstests/fsimfsconfig03.yml (added) * spec/build/testsuites/fstests/fsimfsgeneric01.yml (added) * spec/build/testsuites/fstests/fsjffs2gc01.yml (added) * spec/build/testsuites/fstests/fsnofs01.yml (added) * spec/build/testsuites/fstests/fsrfsbitmap01.yml (added) * spec/build/testsuites/fstests/fsrofs01.yml (added) * spec/build/testsuites/fstests/grp.yml (added) * spec/build/testsuites/fstests/imfsfserror.yml (added) * spec/build/testsuites/fstests/imfsfslink.yml (added) * spec/build/testsuites/fstests/imfsfspatheval.yml (added) * spec/build/testsuites/fstests/imfsfspermission.yml (added) * spec/build/testsuites/fstests/imfsfsrdwr.yml (added) * spec/build/testsuites/fstests/imfsfsscandir01.yml (added) * spec/build/testsuites/fstests/imfsfssymlink.yml (added) * spec/build/testsuites/fstests/imfsfstime.yml (added) * spec/build/testsuites/fstests/jffs2fserror.yml (added) * spec/build/testsuites/fstests/jffs2fslink.yml (added) * spec/build/testsuites/fstests/jffs2fspatheval.yml (added) * spec/build/testsuites/fstests/jffs2fspermission.yml (added) * spec/build/testsuites/fstests/jffs2fsrdwr.yml (added) * spec/build/testsuites/fstests/jffs2fsscandir01.yml (added) * spec/build/testsuites/fstests/jffs2fssymlink.yml (added) * spec/build/testsuites/fstests/jffs2fstime.yml (added) * spec/build/testsuites/fstests/libdosfs.yml (added) * spec/build/testsuites/fstests/libimfs.yml (added) * spec/build/testsuites/fstests/libjffs2.yml (added) * spec/build/testsuites/fstests/libmimfs.yml (added) * spec/build/testsuites/fstests/librfs.yml (added) * spec/build/testsuites/fstests/mdosfsfserror.yml (added) * spec/build/testsuites/fstests/mdosfsfspatheval.yml (added) * spec/build/testsuites/fstests/mdosfsfsrdwr.yml (added) * spec/build/testsuites/fstests/mdosfsfsscandir01.yml (added) * spec/build/testsuites/fstests/mdosfsfsstatvfs.yml (added) * spec/build/testsuites/fstests/mdosfsfstime.yml (added) * spec/build/testsuites/fstests/mimfsfserror.yml (added) * spec/build/testsuites/fstests/mimfsfslink.yml (added) * spec/build/testsuites/fstests/mimfsfspatheval.yml (added) * spec/build/testsuites/fstests/mimfsfspermission.yml (added) * spec/build/testsuites/fstests/mimfsfsrdwr.yml (added) * spec/build/testsuites/fstests/mimfsfsrename.yml (added) * spec/build/testsuites/fstests/mimfsfsscandir01.yml (added) * spec/build/testsuites/fstests/mimfsfssymlink.yml (added) * spec/build/testsuites/fstests/mimfsfstime.yml (added) * spec/build/testsuites/fstests/mrfsfserror.yml (added) * spec/build/testsuites/fstests/mrfsfsfpathconf.yml (added) * spec/build/testsuites/fstests/mrfsfslink.yml (added) * spec/build/testsuites/fstests/mrfsfspatheval.yml (added) * spec/build/testsuites/fstests/mrfsfspermission.yml (added) * spec/build/testsuites/fstests/mrfsfsrdwr.yml (added) * spec/build/testsuites/fstests/mrfsfsrename.yml (added) * spec/build/testsuites/fstests/mrfsfsscandir01.yml (added) * spec/build/testsuites/fstests/mrfsfssymlink.yml (added) * spec/build/testsuites/fstests/mrfsfstime.yml (added) * spec/build/testsuites/grp.yml (added) * spec/build/testsuites/libtests/block01.yml (added) * spec/build/testsuites/libtests/block02.yml (added) * spec/build/testsuites/libtests/block03.yml (added) * spec/build/testsuites/libtests/block04.yml (added) * spec/build/testsuites/libtests/block05.yml (added) * spec/build/testsuites/libtests/block06.yml (added) * spec/build/testsuites/libtests/block07.yml (added) * spec/build/testsuites/libtests/block08.yml (added) * spec/build/testsuites/libtests/block09.yml (added) * spec/build/testsuites/libtests/block10.yml (added) * spec/build/testsuites/libtests/block11.yml (added) * spec/build/testsuites/libtests/block12.yml (added) * spec/build/testsuites/libtests/block13.yml (added) * spec/build/testsuites/libtests/block14.yml (added) * spec/build/testsuites/libtests/block15.yml (added) * spec/build/testsuites/libtests/block16.yml (added) * spec/build/testsuites/libtests/block17.yml (added) * spec/build/testsuites/libtests/bspcmdline01.yml (added) * spec/build/testsuites/libtests/calloc.yml (added) * spec/build/testsuites/libtests/capture01.yml (added) * spec/build/testsuites/libtests/clockgettime.yml (added) * spec/build/testsuites/libtests/close.yml (added) * spec/build/testsuites/libtests/complex.yml (added) * spec/build/testsuites/libtests/cpuuse.yml (added) * spec/build/testsuites/libtests/crypt01.yml (added) * spec/build/testsuites/libtests/debugger01.yml (added) * spec/build/testsuites/libtests/defaultconfig01.yml (added) * spec/build/testsuites/libtests/devfs01.yml (added) * spec/build/testsuites/libtests/devfs04.yml (added) * spec/build/testsuites/libtests/deviceio01.yml (added) * spec/build/testsuites/libtests/devnullfatal01.yml (added) * spec/build/testsuites/libtests/dl01.yml (added) * spec/build/testsuites/libtests/dl02.yml (added) * spec/build/testsuites/libtests/dl03.yml (added) * spec/build/testsuites/libtests/dl04.yml (added) * spec/build/testsuites/libtests/dl05.yml (added) * spec/build/testsuites/libtests/dl06.yml (added) * spec/build/testsuites/libtests/dl07.yml (added) * spec/build/testsuites/libtests/dl08.yml (added) * spec/build/testsuites/libtests/dl09.yml (added) * spec/build/testsuites/libtests/dl10.yml (added) * spec/build/testsuites/libtests/dumpbuf01.yml (added) * spec/build/testsuites/libtests/dup2.yml (added) * spec/build/testsuites/libtests/exit01.yml (added) * spec/build/testsuites/libtests/exit02.yml (added) * spec/build/testsuites/libtests/fcntl.yml (added) * spec/build/testsuites/libtests/flashdisk01.yml (added) * spec/build/testsuites/libtests/flockfile.yml (added) * spec/build/testsuites/libtests/fork.yml (added) * spec/build/testsuites/libtests/free.yml (added) * spec/build/testsuites/libtests/fstat.yml (added) * spec/build/testsuites/libtests/ftp01.yml (added) * spec/build/testsuites/libtests/ftrylockfile.yml (added) * spec/build/testsuites/libtests/funlockfile.yml (added) * spec/build/testsuites/libtests/getentropy01.yml (added) * spec/build/testsuites/libtests/getlogin.yml (added) * spec/build/testsuites/libtests/getpwnam.yml (added) * spec/build/testsuites/libtests/getpwuid.yml (added) * spec/build/testsuites/libtests/gettimeofday.yml (added) * spec/build/testsuites/libtests/getuid.yml (added) * spec/build/testsuites/libtests/grp.yml (added) * spec/build/testsuites/libtests/gxx01.yml (added) * spec/build/testsuites/libtests/heapwalk.yml (added) * spec/build/testsuites/libtests/htonl.yml (added) * spec/build/testsuites/libtests/i2c01.yml (added) * spec/build/testsuites/libtests/iconv.yml (added) * spec/build/testsuites/libtests/iconvclose.yml (added) * spec/build/testsuites/libtests/iconvopen.yml (added) * spec/build/testsuites/libtests/kill.yml (added) * spec/build/testsuites/libtests/libdl081.yml (added) * spec/build/testsuites/libtests/libdl082.yml (added) * spec/build/testsuites/libtests/libdl101.yml (added) * spec/build/testsuites/libtests/libdl102.yml (added) * spec/build/testsuites/libtests/libfdt01.yml (added) * spec/build/testsuites/libtests/longjmp.yml (added) * spec/build/testsuites/libtests/lseek.yml (added) * spec/build/testsuites/libtests/lstat.yml (added) * spec/build/testsuites/libtests/malloc.yml (added) * spec/build/testsuites/libtests/malloc02.yml (added) * spec/build/testsuites/libtests/malloc03.yml (added) * spec/build/testsuites/libtests/malloc04.yml (added) * spec/build/testsuites/libtests/malloctest.yml (added) * spec/build/testsuites/libtests/math.yml (added) * spec/build/testsuites/libtests/mathf.yml (added) * spec/build/testsuites/libtests/mathl.yml (added) * spec/build/testsuites/libtests/md501.yml (added) * spec/build/testsuites/libtests/mghttpd01.yml (added) * spec/build/testsuites/libtests/monitor.yml (added) * spec/build/testsuites/libtests/monitor02.yml (added) * spec/build/testsuites/libtests/mouse01.yml (added) * spec/build/testsuites/libtests/nanosleep.yml (added) * spec/build/testsuites/libtests/networking01.yml (added) * spec/build/testsuites/libtests/newlib01.yml (added) * spec/build/testsuites/libtests/open.yml (added) * spec/build/testsuites/libtests/optbin2c.yml (added) * spec/build/testsuites/libtests/optgzip.yml (added) * spec/build/testsuites/libtests/optpax.yml (added) * spec/build/testsuites/libtests/optrtemsld.yml (added) * spec/build/testsuites/libtests/optrtemssyms.yml (added) * spec/build/testsuites/libtests/optxz.yml (added) * spec/build/testsuites/libtests/pipe.yml (added) * spec/build/testsuites/libtests/posix.yml (added) * spec/build/testsuites/libtests/posixmemalign.yml (added) * spec/build/testsuites/libtests/putenvtest.yml (added) * spec/build/testsuites/libtests/pwdgrp01.yml (added) * spec/build/testsuites/libtests/pwdgrp02.yml (added) * spec/build/testsuites/libtests/rbheap01.yml (added) * spec/build/testsuites/libtests/read.yml (added) * spec/build/testsuites/libtests/readv.yml (added) * spec/build/testsuites/libtests/realloc.yml (added) * spec/build/testsuites/libtests/record01.yml (added) * spec/build/testsuites/libtests/record02.yml (added) * spec/build/testsuites/libtests/rtmonuse.yml (added) * spec/build/testsuites/libtests/setjmp.yml (added) * spec/build/testsuites/libtests/sha.yml (added) * spec/build/testsuites/libtests/shell01.yml (added) * spec/build/testsuites/libtests/sigaddset.yml (added) * spec/build/testsuites/libtests/sigdelset.yml (added) * spec/build/testsuites/libtests/sigemptyset.yml (added) * spec/build/testsuites/libtests/sigfillset.yml (added) * spec/build/testsuites/libtests/sigismember.yml (added) * spec/build/testsuites/libtests/sigprocmask.yml (added) * spec/build/testsuites/libtests/sparsedisk01.yml (added) * spec/build/testsuites/libtests/spi01.yml (added) * spec/build/testsuites/libtests/stackchk.yml (added) * spec/build/testsuites/libtests/stackchk01.yml (added) * spec/build/testsuites/libtests/stat.yml (added) * spec/build/testsuites/libtests/stringto01.yml (added) * spec/build/testsuites/libtests/syscall01.yml (added) * spec/build/testsuites/libtests/tar01.yml (added) * spec/build/testsuites/libtests/tar02.yml (added) * spec/build/testsuites/libtests/tar03.yml (added) * spec/build/testsuites/libtests/telnetd01.yml (added) * spec/build/testsuites/libtests/termios.yml (added) * spec/build/testsuites/libtests/termios01.yml (added) * spec/build/testsuites/libtests/termios02.yml (added) * spec/build/testsuites/libtests/termios03.yml (added) * spec/build/testsuites/libtests/termios04.yml (added) * spec/build/testsuites/libtests/termios05.yml (added) * spec/build/testsuites/libtests/termios06.yml (added) * spec/build/testsuites/libtests/termios07.yml (added) * spec/build/testsuites/libtests/termios08.yml (added) * spec/build/testsuites/libtests/termios09.yml (added) * spec/build/testsuites/libtests/termios10.yml (added) * spec/build/testsuites/libtests/termios11.yml (added) * spec/build/testsuites/libtests/top.yml (added) * spec/build/testsuites/libtests/ttest01.yml (added) * spec/build/testsuites/libtests/ttest02.yml (added) * spec/build/testsuites/libtests/tztest.yml (added) * spec/build/testsuites/libtests/uid01.yml (added) * spec/build/testsuites/libtests/unlink.yml (added) * spec/build/testsuites/libtests/utf8proc01.yml (added) * spec/build/testsuites/libtests/vfork.yml (added) * spec/build/testsuites/libtests/wait.yml (added) * spec/build/testsuites/libtests/waitpid.yml (added) * spec/build/testsuites/libtests/write.yml (added) * spec/build/testsuites/libtests/writev.yml (added) * spec/build/testsuites/mptests/grp.yml (added) * spec/build/testsuites/mptests/mp01.yml (added) * spec/build/testsuites/mptests/mp01node1.yml (added) * spec/build/testsuites/mptests/mp01node2.yml (added) * spec/build/testsuites/mptests/mp03.yml (added) * spec/build/testsuites/mptests/mp03node1.yml (added) * spec/build/testsuites/mptests/mp03node2.yml (added) * spec/build/testsuites/mptests/mp04.yml (added) * spec/build/testsuites/mptests/mp04node1.yml (added) * spec/build/testsuites/mptests/mp04node2.yml (added) * spec/build/testsuites/mptests/mp05.yml (added) * spec/build/testsuites/mptests/mp05node1.yml (added) * spec/build/testsuites/mptests/mp05node2.yml (added) * spec/build/testsuites/mptests/mp06.yml (added) * spec/build/testsuites/mptests/mp06node1.yml (added) * spec/build/testsuites/mptests/mp06node2.yml (added) * spec/build/testsuites/mptests/mp07.yml (added) * spec/build/testsuites/mptests/mp07node1.yml (added) * spec/build/testsuites/mptests/mp07node2.yml (added) * spec/build/testsuites/mptests/mp08.yml (added) * spec/build/testsuites/mptests/mp08node1.yml (added) * spec/build/testsuites/mptests/mp08node2.yml (added) * spec/build/testsuites/mptests/mp09.yml (added) * spec/build/testsuites/mptests/mp09node1.yml (added) * spec/build/testsuites/mptests/mp09node2.yml (added) * spec/build/testsuites/mptests/mp10.yml (added) * spec/build/testsuites/mptests/mp10node1.yml (added) * spec/build/testsuites/mptests/mp10node2.yml (added) * spec/build/testsuites/mptests/mp11.yml (added) * spec/build/testsuites/mptests/mp11node1.yml (added) * spec/build/testsuites/mptests/mp11node2.yml (added) * spec/build/testsuites/mptests/mp12.yml (added) * spec/build/testsuites/mptests/mp12node1.yml (added) * spec/build/testsuites/mptests/mp12node2.yml (added) * spec/build/testsuites/mptests/mp13.yml (added) * spec/build/testsuites/mptests/mp13node1.yml (added) * spec/build/testsuites/mptests/mp13node2.yml (added) * spec/build/testsuites/mptests/mp14.yml (added) * spec/build/testsuites/mptests/mp14node1.yml (added) * spec/build/testsuites/mptests/mp14node2.yml (added) * spec/build/testsuites/optada.yml (added) * spec/build/testsuites/optall.yml (added) * spec/build/testsuites/optbenchmarks.yml (added) * spec/build/testsuites/optfs.yml (added) * spec/build/testsuites/optlib.yml (added) * spec/build/testsuites/optmp.yml (added) * spec/build/testsuites/optpsx.yml (added) * spec/build/testsuites/optpsxtm.yml (added) * spec/build/testsuites/optrhs.yml (added) * spec/build/testsuites/optsamples.yml (added) * spec/build/testsuites/optsmp.yml (added) * spec/build/testsuites/optsp.yml (added) * spec/build/testsuites/opttm.yml (added) * spec/build/testsuites/psxtests/grp.yml (added) * spec/build/testsuites/psxtests/libpsxhdrs.yml (added) * spec/build/testsuites/psxtests/psx01.yml (added) * spec/build/testsuites/psxtests/psx02.yml (added) * spec/build/testsuites/psxtests/psx03.yml (added) * spec/build/testsuites/psxtests/psx04.yml (added) * spec/build/testsuites/psxtests/psx05.yml (added) * spec/build/testsuites/psxtests/psx06.yml (added) * spec/build/testsuites/psxtests/psx07.yml (added) * spec/build/testsuites/psxtests/psx08.yml (added) * spec/build/testsuites/psxtests/psx09.yml (added) * spec/build/testsuites/psxtests/psx10.yml (added) * spec/build/testsuites/psxtests/psx11.yml (added) * spec/build/testsuites/psxtests/psx12.yml (added) * spec/build/testsuites/psxtests/psx13.yml (added) * spec/build/testsuites/psxtests/psx14.yml (added) * spec/build/testsuites/psxtests/psx15.yml (added) * spec/build/testsuites/psxtests/psx16.yml (added) * spec/build/testsuites/psxtests/psxaio01.yml (added) * spec/build/testsuites/psxtests/psxaio02.yml (added) * spec/build/testsuites/psxtests/psxaio03.yml (added) * spec/build/testsuites/psxtests/psxalarm01.yml (added) * spec/build/testsuites/psxtests/psxautoinit01.yml (added) * spec/build/testsuites/psxtests/psxautoinit02.yml (added) * spec/build/testsuites/psxtests/psxbarrier01.yml (added) * spec/build/testsuites/psxtests/psxcancel.yml (added) * spec/build/testsuites/psxtests/psxcancel01.yml (added) * spec/build/testsuites/psxtests/psxchroot01.yml (added) * spec/build/testsuites/psxtests/psxclassic01.yml (added) * spec/build/testsuites/psxtests/psxcleanup.yml (added) * spec/build/testsuites/psxtests/psxcleanup01.yml (added) * spec/build/testsuites/psxtests/psxcleanup02.yml (added) * spec/build/testsuites/psxtests/psxclock.yml (added) * spec/build/testsuites/psxtests/psxclock01.yml (added) * spec/build/testsuites/psxtests/psxclockrealtime01.yml (added) * spec/build/testsuites/psxtests/psxconcurrency01.yml (added) * spec/build/testsuites/psxtests/psxcond01.yml (added) * spec/build/testsuites/psxtests/psxcond02.yml (added) * spec/build/testsuites/psxtests/psxconfig01.yml (added) * spec/build/testsuites/psxtests/psxdevctl01.yml (added) * spec/build/testsuites/psxtests/psxeintrjoin.yml (added) * spec/build/testsuites/psxtests/psxenosys.yml (added) * spec/build/testsuites/psxtests/psxfatal01.yml (added) * spec/build/testsuites/psxtests/psxfatal02.yml (added) * spec/build/testsuites/psxtests/psxfatalsupport.yml (added) * spec/build/testsuites/psxtests/psxfchx01.yml (added) * spec/build/testsuites/psxtests/psxfenv01.yml (added) * spec/build/testsuites/psxtests/psxfile01.yml (added) * spec/build/testsuites/psxtests/psxfile02.yml (added) * spec/build/testsuites/psxtests/psxfilelock01.yml (added) * spec/build/testsuites/psxtests/psxgetattrnp01.yml (added) * spec/build/testsuites/psxtests/psxgetrusage01.yml (added) * spec/build/testsuites/psxtests/psxglobalcon01.yml (added) * spec/build/testsuites/psxtests/psxglobalcon02.yml (added) * spec/build/testsuites/psxtests/psxhdrs.yml (added) * spec/build/testsuites/psxtests/psxid01.yml (added) * spec/build/testsuites/psxtests/psximfs01.yml (added) * spec/build/testsuites/psxtests/psximfs02.yml (added) * spec/build/testsuites/psxtests/psxintrcritical01.yml (added) * spec/build/testsuites/psxtests/psxinttypes01.yml (added) * spec/build/testsuites/psxtests/psxitimer.yml (added) * spec/build/testsuites/psxtests/psxkey01.yml (added) * spec/build/testsuites/psxtests/psxkey02.yml (added) * spec/build/testsuites/psxtests/psxkey03.yml (added) * spec/build/testsuites/psxtests/psxkey04.yml (added) * spec/build/testsuites/psxtests/psxkey05.yml (added) * spec/build/testsuites/psxtests/psxkey06.yml (added) * spec/build/testsuites/psxtests/psxkey07.yml (added) * spec/build/testsuites/psxtests/psxkey08.yml (added) * spec/build/testsuites/psxtests/psxkey09.yml (added) * spec/build/testsuites/psxtests/psxkey10.yml (added) * spec/build/testsuites/psxtests/psxmmap01.yml (added) * spec/build/testsuites/psxtests/psxmount.yml (added) * spec/build/testsuites/psxtests/psxmsgq01.yml (added) * spec/build/testsuites/psxtests/psxmsgq02.yml (added) * spec/build/testsuites/psxtests/psxmsgq03.yml (added) * spec/build/testsuites/psxtests/psxmsgq04.yml (added) * spec/build/testsuites/psxtests/psxmutexattr01.yml (added) * spec/build/testsuites/psxtests/psxndbm01.yml (added) * spec/build/testsuites/psxtests/psxobj01.yml (added) * spec/build/testsuites/psxtests/psxonce01.yml (added) * spec/build/testsuites/psxtests/psxpasswd01.yml (added) * spec/build/testsuites/psxtests/psxpasswd02.yml (added) * spec/build/testsuites/psxtests/psxpipe01.yml (added) * spec/build/testsuites/psxtests/psxrdwrv.yml (added) * spec/build/testsuites/psxtests/psxreaddir.yml (added) * spec/build/testsuites/psxtests/psxrwlock01.yml (added) * spec/build/testsuites/psxtests/psxsem01.yml (added) * spec/build/testsuites/psxtests/psxshm01.yml (added) * spec/build/testsuites/psxtests/psxshm02.yml (added) * spec/build/testsuites/psxtests/psxsignal01.yml (added) * spec/build/testsuites/psxtests/psxsignal02.yml (added) * spec/build/testsuites/psxtests/psxsignal03.yml (added) * spec/build/testsuites/psxtests/psxsignal04.yml (added) * spec/build/testsuites/psxtests/psxsignal05.yml (added) * spec/build/testsuites/psxtests/psxsignal06.yml (added) * spec/build/testsuites/psxtests/psxsignal07.yml (added) * spec/build/testsuites/psxtests/psxsignal08.yml (added) * spec/build/testsuites/psxtests/psxspin01.yml (added) * spec/build/testsuites/psxtests/psxstack01.yml (added) * spec/build/testsuites/psxtests/psxstack02.yml (added) * spec/build/testsuites/psxtests/psxstat.yml (added) * spec/build/testsuites/psxtests/psxstrsignal01.yml (added) * spec/build/testsuites/psxtests/psxsysconf.yml (added) * spec/build/testsuites/psxtests/psxthreadname01.yml (added) * spec/build/testsuites/psxtests/psxtime.yml (added) * spec/build/testsuites/psxtests/psxtimer01.yml (added) * spec/build/testsuites/psxtests/psxtimer02.yml (added) * spec/build/testsuites/psxtests/psxtimes01.yml (added) * spec/build/testsuites/psxtests/psxualarm.yml (added) * spec/build/testsuites/psxtests/psxusleep.yml (added) * spec/build/testsuites/psxtmtests/grp.yml (added) * spec/build/testsuites/psxtmtests/psxtmbarrier01.yml (added) * spec/build/testsuites/psxtmtests/psxtmbarrier02.yml (added) * spec/build/testsuites/psxtmtests/psxtmbarrier03.yml (added) * spec/build/testsuites/psxtmtests/psxtmbarrier04.yml (added) * spec/build/testsuites/psxtmtests/psxtmbarrierattr01.yml (added) * spec/build/testsuites/psxtmtests/psxtmcleanup01.yml (added) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep01.yml (added) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep02.yml (added) * spec/build/testsuites/psxtmtests/psxtmclocknanosleep03.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond01.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond02.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond03.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond04.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond05.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond06.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond07.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond08.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond09.yml (added) * spec/build/testsuites/psxtmtests/psxtmcond10.yml (added) * spec/build/testsuites/psxtmtests/psxtmkey01.yml (added) * spec/build/testsuites/psxtmtests/psxtmkey02.yml (added) * spec/build/testsuites/psxtmtests/psxtmmq01.yml (added) * spec/build/testsuites/psxtmtests/psxtmmqrcvblock01.yml (added) * spec/build/testsuites/psxtmtests/psxtmmqrcvblock02.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex01.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex02.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex03.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex04.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex05.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex06.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutex07.yml (added) * spec/build/testsuites/psxtmtests/psxtmmutexattr01.yml (added) * spec/build/testsuites/psxtmtests/psxtmnanosleep01.yml (added) * spec/build/testsuites/psxtmtests/psxtmnanosleep02.yml (added) * spec/build/testsuites/psxtmtests/psxtmonce01.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock01.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock02.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock03.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock04.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock05.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock06.yml (added) * spec/build/testsuites/psxtmtests/psxtmrwlock07.yml (added) * spec/build/testsuites/psxtmtests/psxtmsem01.yml (added) * spec/build/testsuites/psxtmtests/psxtmsem02.yml (added) * spec/build/testsuites/psxtmtests/psxtmsem03.yml (added) * spec/build/testsuites/psxtmtests/psxtmsem04.yml (added) * spec/build/testsuites/psxtmtests/psxtmsem05.yml (added) * spec/build/testsuites/psxtmtests/psxtmsleep01.yml (added) * spec/build/testsuites/psxtmtests/psxtmsleep02.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread01.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread02.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread03.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread04.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread05.yml (added) * spec/build/testsuites/psxtmtests/psxtmthread06.yml (added) * spec/build/testsuites/psxtmtests/psxtmthreadattr01.yml (added) * spec/build/testsuites/rhealstone/grp.yml (added) * spec/build/testsuites/rhealstone/rhdeadlockbrk.yml (added) * spec/build/testsuites/rhealstone/rhilatency.yml (added) * spec/build/testsuites/rhealstone/rhmlatency.yml (added) * spec/build/testsuites/rhealstone/rhsemshuffle.yml (added) * spec/build/testsuites/rhealstone/rhtaskpreempt.yml (added) * spec/build/testsuites/rhealstone/rhtaskswitch.yml (added) * spec/build/testsuites/samples/basempnode1.yml (added) * spec/build/testsuites/samples/basempnode2.yml (added) * spec/build/testsuites/samples/basesp.yml (added) * spec/build/testsuites/samples/capture.yml (added) * spec/build/testsuites/samples/cdtest.yml (added) * spec/build/testsuites/samples/fileio.yml (added) * spec/build/testsuites/samples/grp.yml (added) * spec/build/testsuites/samples/hello.yml (added) * spec/build/testsuites/samples/iostream.yml (added) * spec/build/testsuites/samples/loopback.yml (added) * spec/build/testsuites/samples/minimum.yml (added) * spec/build/testsuites/samples/nsecs.yml (added) * spec/build/testsuites/samples/paranoia.yml (added) * spec/build/testsuites/samples/pppd.yml (added) * spec/build/testsuites/samples/ticker.yml (added) * spec/build/testsuites/samples/unlimited.yml (added) * spec/build/testsuites/smptests/grp.yml (added) * spec/build/testsuites/smptests/smp01.yml (added) * spec/build/testsuites/smptests/smp02.yml (added) * spec/build/testsuites/smptests/smp03.yml (added) * spec/build/testsuites/smptests/smp05.yml (added) * spec/build/testsuites/smptests/smp07.yml (added) * spec/build/testsuites/smptests/smp08.yml (added) * spec/build/testsuites/smptests/smp09.yml (added) * spec/build/testsuites/smptests/smpaffinity01.yml (added) * spec/build/testsuites/smptests/smpatomic01.yml (added) * spec/build/testsuites/smptests/smpcache01.yml (added) * spec/build/testsuites/smptests/smpcapture01.yml (added) * spec/build/testsuites/smptests/smpcapture02.yml (added) * spec/build/testsuites/smptests/smpclock01.yml (added) * spec/build/testsuites/smptests/smpfatal01.yml (added) * spec/build/testsuites/smptests/smpfatal02.yml (added) * spec/build/testsuites/smptests/smpfatal03.yml (added) * spec/build/testsuites/smptests/smpfatal04.yml (added) * spec/build/testsuites/smptests/smpfatal05.yml (added) * spec/build/testsuites/smptests/smpfatal06.yml (added) * spec/build/testsuites/smptests/smpfatal08.yml (added) * spec/build/testsuites/smptests/smpfatal09.yml (added) * spec/build/testsuites/smptests/smpipi01.yml (added) * spec/build/testsuites/smptests/smpload01.yml (added) * spec/build/testsuites/smptests/smplock01.yml (added) * spec/build/testsuites/smptests/smpmigration01.yml (added) * spec/build/testsuites/smptests/smpmigration02.yml (added) * spec/build/testsuites/smptests/smpmrsp01.yml (added) * spec/build/testsuites/smptests/smpmulticast01.yml (added) * spec/build/testsuites/smptests/smpmutex01.yml (added) * spec/build/testsuites/smptests/smpmutex02.yml (added) * spec/build/testsuites/smptests/smpopenmp01.yml (added) * spec/build/testsuites/smptests/smppsxaffinity01.yml (added) * spec/build/testsuites/smptests/smppsxaffinity02.yml (added) * spec/build/testsuites/smptests/smppsxmutex01.yml (added) * spec/build/testsuites/smptests/smppsxsignal01.yml (added) * spec/build/testsuites/smptests/smpschedaffinity01.yml (added) * spec/build/testsuites/smptests/smpschedaffinity02.yml (added) * spec/build/testsuites/smptests/smpschedaffinity03.yml (added) * spec/build/testsuites/smptests/smpschedaffinity04.yml (added) * spec/build/testsuites/smptests/smpschedaffinity05.yml (added) * spec/build/testsuites/smptests/smpschededf01.yml (added) * spec/build/testsuites/smptests/smpschededf02.yml (added) * spec/build/testsuites/smptests/smpschededf03.yml (added) * spec/build/testsuites/smptests/smpschededf04.yml (added) * spec/build/testsuites/smptests/smpschedsem01.yml (added) * spec/build/testsuites/smptests/smpscheduler01.yml (added) * spec/build/testsuites/smptests/smpscheduler02.yml (added) * spec/build/testsuites/smptests/smpscheduler03.yml (added) * spec/build/testsuites/smptests/smpscheduler04.yml (added) * spec/build/testsuites/smptests/smpscheduler05.yml (added) * spec/build/testsuites/smptests/smpscheduler06.yml (added) * spec/build/testsuites/smptests/smpscheduler07.yml (added) * spec/build/testsuites/smptests/smpsignal01.yml (added) * spec/build/testsuites/smptests/smpstrongapa01.yml (added) * spec/build/testsuites/smptests/smpswitchextension01.yml (added) * spec/build/testsuites/smptests/smpthreadlife01.yml (added) * spec/build/testsuites/smptests/smpthreadpin01.yml (added) * spec/build/testsuites/smptests/smpunsupported01.yml (added) * spec/build/testsuites/smptests/smpwakeafter01.yml (added) * spec/build/testsuites/sptests/grp.yml (added) * spec/build/testsuites/sptests/sp01.yml (added) * spec/build/testsuites/sptests/sp02.yml (added) * spec/build/testsuites/sptests/sp03.yml (added) * spec/build/testsuites/sptests/sp04.yml (added) * spec/build/testsuites/sptests/sp05.yml (added) * spec/build/testsuites/sptests/sp06.yml (added) * spec/build/testsuites/sptests/sp07.yml (added) * spec/build/testsuites/sptests/sp08.yml (added) * spec/build/testsuites/sptests/sp11.yml (added) * spec/build/testsuites/sptests/sp12.yml (added) * spec/build/testsuites/sptests/sp13.yml (added) * spec/build/testsuites/sptests/sp14.yml (added) * spec/build/testsuites/sptests/sp15.yml (added) * spec/build/testsuites/sptests/sp16.yml (added) * spec/build/testsuites/sptests/sp17.yml (added) * spec/build/testsuites/sptests/sp18.yml (added) * spec/build/testsuites/sptests/sp19.yml (added) * spec/build/testsuites/sptests/sp20.yml (added) * spec/build/testsuites/sptests/sp2038.yml (added) * spec/build/testsuites/sptests/sp21.yml (added) * spec/build/testsuites/sptests/sp22.yml (added) * spec/build/testsuites/sptests/sp23.yml (added) * spec/build/testsuites/sptests/sp24.yml (added) * spec/build/testsuites/sptests/sp25.yml (added) * spec/build/testsuites/sptests/sp26.yml (added) * spec/build/testsuites/sptests/sp27.yml (added) * spec/build/testsuites/sptests/sp27a.yml (added) * spec/build/testsuites/sptests/sp29.yml (added) * spec/build/testsuites/sptests/sp30.yml (added) * spec/build/testsuites/sptests/sp31.yml (added) * spec/build/testsuites/sptests/sp32.yml (added) * spec/build/testsuites/sptests/sp33.yml (added) * spec/build/testsuites/sptests/sp34.yml (added) * spec/build/testsuites/sptests/sp35.yml (added) * spec/build/testsuites/sptests/sp36.yml (added) * spec/build/testsuites/sptests/sp37.yml (added) * spec/build/testsuites/sptests/sp38.yml (added) * spec/build/testsuites/sptests/sp40.yml (added) * spec/build/testsuites/sptests/sp41.yml (added) * spec/build/testsuites/sptests/sp42.yml (added) * spec/build/testsuites/sptests/sp43.yml (added) * spec/build/testsuites/sptests/sp44.yml (added) * spec/build/testsuites/sptests/sp45.yml (added) * spec/build/testsuites/sptests/sp46.yml (added) * spec/build/testsuites/sptests/sp47.yml (added) * spec/build/testsuites/sptests/sp48.yml (added) * spec/build/testsuites/sptests/sp49.yml (added) * spec/build/testsuites/sptests/sp50.yml (added) * spec/build/testsuites/sptests/sp51.yml (added) * spec/build/testsuites/sptests/sp52.yml (added) * spec/build/testsuites/sptests/sp53.yml (added) * spec/build/testsuites/sptests/sp54.yml (added) * spec/build/testsuites/sptests/sp55.yml (added) * spec/build/testsuites/sptests/sp56.yml (added) * spec/build/testsuites/sptests/sp57.yml (added) * spec/build/testsuites/sptests/sp58.yml (added) * spec/build/testsuites/sptests/sp59.yml (added) * spec/build/testsuites/sptests/sp60.yml (added) * spec/build/testsuites/sptests/sp62.yml (added) * spec/build/testsuites/sptests/sp63.yml (added) * spec/build/testsuites/sptests/sp64.yml (added) * spec/build/testsuites/sptests/sp65.yml (added) * spec/build/testsuites/sptests/sp66.yml (added) * spec/build/testsuites/sptests/sp67.yml (added) * spec/build/testsuites/sptests/sp68.yml (added) * spec/build/testsuites/sptests/sp69.yml (added) * spec/build/testsuites/sptests/sp70.yml (added) * spec/build/testsuites/sptests/sp71.yml (added) * spec/build/testsuites/sptests/sp72.yml (added) * spec/build/testsuites/sptests/sp73.yml (added) * spec/build/testsuites/sptests/sp74.yml (added) * spec/build/testsuites/sptests/sp75.yml (added) * spec/build/testsuites/sptests/sp76.yml (added) * spec/build/testsuites/sptests/sp77.yml (added) * spec/build/testsuites/sptests/spassoc01.yml (added) * spec/build/testsuites/sptests/spatomic01.yml (added) * spec/build/testsuites/sptests/spcache01.yml (added) * spec/build/testsuites/sptests/spcbssched01.yml (added) * spec/build/testsuites/sptests/spcbssched02.yml (added) * spec/build/testsuites/sptests/spcbssched03.yml (added) * spec/build/testsuites/sptests/spchain.yml (added) * spec/build/testsuites/sptests/spclockerr01.yml (added) * spec/build/testsuites/sptests/spclockerr02.yml (added) * spec/build/testsuites/sptests/spclocktodhook01.yml (added) * spec/build/testsuites/sptests/spconfig01.yml (added) * spec/build/testsuites/sptests/spconfig02.yml (added) * spec/build/testsuites/sptests/spconsole01.yml (added) * spec/build/testsuites/sptests/spcontext01.yml (added) * spec/build/testsuites/sptests/spcoverage.yml (added) * spec/build/testsuites/sptests/spcpucounter01.yml (added) * spec/build/testsuites/sptests/spcpuset01.yml (added) * spec/build/testsuites/sptests/spcxx01.yml (added) * spec/build/testsuites/sptests/spedfsched01.yml (added) * spec/build/testsuites/sptests/spedfsched02.yml (added) * spec/build/testsuites/sptests/spedfsched03.yml (added) * spec/build/testsuites/sptests/spedfsched04.yml (added) * spec/build/testsuites/sptests/sperror01.yml (added) * spec/build/testsuites/sptests/sperror02.yml (added) * spec/build/testsuites/sptests/sperror03.yml (added) * spec/build/testsuites/sptests/speventerr03.yml (added) * spec/build/testsuites/sptests/speventsystem01.yml (added) * spec/build/testsuites/sptests/speventtransient01.yml (added) * spec/build/testsuites/sptests/spextensions01.yml (added) * spec/build/testsuites/sptests/spfatal01.yml (added) * spec/build/testsuites/sptests/spfatal02.yml (added) * spec/build/testsuites/sptests/spfatal03.yml (added) * spec/build/testsuites/sptests/spfatal04.yml (added) * spec/build/testsuites/sptests/spfatal05.yml (added) * spec/build/testsuites/sptests/spfatal06.yml (added) * spec/build/testsuites/sptests/spfatal07.yml (added) * spec/build/testsuites/sptests/spfatal09.yml (added) * spec/build/testsuites/sptests/spfatal10.yml (added) * spec/build/testsuites/sptests/spfatal11.yml (added) * spec/build/testsuites/sptests/spfatal12.yml (added) * spec/build/testsuites/sptests/spfatal13.yml (added) * spec/build/testsuites/sptests/spfatal14.yml (added) * spec/build/testsuites/sptests/spfatal15.yml (added) * spec/build/testsuites/sptests/spfatal16.yml (added) * spec/build/testsuites/sptests/spfatal17.yml (added) * spec/build/testsuites/sptests/spfatal18.yml (added) * spec/build/testsuites/sptests/spfatal19.yml (added) * spec/build/testsuites/sptests/spfatal20.yml (added) * spec/build/testsuites/sptests/spfatal24.yml (added) * spec/build/testsuites/sptests/spfatal25.yml (added) * spec/build/testsuites/sptests/spfatal26.yml (added) * spec/build/testsuites/sptests/spfatal28.yml (added) * spec/build/testsuites/sptests/spfatal29.yml (added) * spec/build/testsuites/sptests/spfatal30.yml (added) * spec/build/testsuites/sptests/spfatal31.yml (added) * spec/build/testsuites/sptests/spfatal32.yml (added) * spec/build/testsuites/sptests/spfatalsupport.yml (added) * spec/build/testsuites/sptests/spfifo01.yml (added) * spec/build/testsuites/sptests/spfifo02.yml (added) * spec/build/testsuites/sptests/spfifo03.yml (added) * spec/build/testsuites/sptests/spfifo04.yml (added) * spec/build/testsuites/sptests/spfifo05.yml (added) * spec/build/testsuites/sptests/spfreechain01.yml (added) * spec/build/testsuites/sptests/spglobalcon01.yml (added) * spec/build/testsuites/sptests/spglobalcon02.yml (added) * spec/build/testsuites/sptests/spheapprot.yml (added) * spec/build/testsuites/sptests/spinternalerror01.yml (added) * spec/build/testsuites/sptests/spinternalerror02.yml (added) * spec/build/testsuites/sptests/spintrcritical01.yml (added) * spec/build/testsuites/sptests/spintrcritical02.yml (added) * spec/build/testsuites/sptests/spintrcritical03.yml (added) * spec/build/testsuites/sptests/spintrcritical04.yml (added) * spec/build/testsuites/sptests/spintrcritical05.yml (added) * spec/build/testsuites/sptests/spintrcritical08.yml (added) * spec/build/testsuites/sptests/spintrcritical09.yml (added) * spec/build/testsuites/sptests/spintrcritical10.yml (added) * spec/build/testsuites/sptests/spintrcritical11.yml (added) * spec/build/testsuites/sptests/spintrcritical12.yml (added) * spec/build/testsuites/sptests/spintrcritical13.yml (added) * spec/build/testsuites/sptests/spintrcritical14.yml (added) * spec/build/testsuites/sptests/spintrcritical15.yml (added) * spec/build/testsuites/sptests/spintrcritical16.yml (added) * spec/build/testsuites/sptests/spintrcritical18.yml (added) * spec/build/testsuites/sptests/spintrcritical20.yml (added) * spec/build/testsuites/sptests/spintrcritical21.yml (added) * spec/build/testsuites/sptests/spintrcritical22.yml (added) * spec/build/testsuites/sptests/spintrcritical23.yml (added) * spec/build/testsuites/sptests/spintrcritical24.yml (added) * spec/build/testsuites/sptests/spintrerr01.yml (added) * spec/build/testsuites/sptests/splinkersets01.yml (added) * spec/build/testsuites/sptests/spmisc01.yml (added) * spec/build/testsuites/sptests/spmkdir.yml (added) * spec/build/testsuites/sptests/spmountmgr01.yml (added) * spec/build/testsuites/sptests/spmrsp01.yml (added) * spec/build/testsuites/sptests/spmsgqerr01.yml (added) * spec/build/testsuites/sptests/spmsgqerr02.yml (added) * spec/build/testsuites/sptests/spmutex01.yml (added) * spec/build/testsuites/sptests/spnsext01.yml (added) * spec/build/testsuites/sptests/spobjgetnext.yml (added) * spec/build/testsuites/sptests/sppagesize.yml (added) * spec/build/testsuites/sptests/sppartitionerr01.yml (added) * spec/build/testsuites/sptests/sppercpudata01.yml (added) * spec/build/testsuites/sptests/spporterr01.yml (added) * spec/build/testsuites/sptests/spprintk.yml (added) * spec/build/testsuites/sptests/spprivenv01.yml (added) * spec/build/testsuites/sptests/spprofiling01.yml (added) * spec/build/testsuites/sptests/spqreslib.yml (added) * spec/build/testsuites/sptests/spratemonerr01.yml (added) * spec/build/testsuites/sptests/sprbtree01.yml (added) * spec/build/testsuites/sptests/spregionerr01.yml (added) * spec/build/testsuites/sptests/sprmsched01.yml (added) * spec/build/testsuites/sptests/sprmsched02.yml (added) * spec/build/testsuites/sptests/spscheduler01.yml (added) * spec/build/testsuites/sptests/spsem01.yml (added) * spec/build/testsuites/sptests/spsem02.yml (added) * spec/build/testsuites/sptests/spsem03.yml (added) * spec/build/testsuites/sptests/spsemerr01.yml (added) * spec/build/testsuites/sptests/spsemerr02.yml (added) * spec/build/testsuites/sptests/spsignalerr01.yml (added) * spec/build/testsuites/sptests/spsimplesched01.yml (added) * spec/build/testsuites/sptests/spsimplesched02.yml (added) * spec/build/testsuites/sptests/spsimplesched03.yml (added) * spec/build/testsuites/sptests/spsize.yml (added) * spec/build/testsuites/sptests/spstdthreads01.yml (added) * spec/build/testsuites/sptests/spstkalloc.yml (added) * spec/build/testsuites/sptests/spstkalloc02.yml (added) * spec/build/testsuites/sptests/spsysinit01.yml (added) * spec/build/testsuites/sptests/spsyslock01.yml (added) * spec/build/testsuites/sptests/sptaskerr01.yml (added) * spec/build/testsuites/sptests/sptaskerr02.yml (added) * spec/build/testsuites/sptests/sptaskerr03.yml (added) * spec/build/testsuites/sptests/sptaskerr04.yml (added) * spec/build/testsuites/sptests/sptasknopreempt01.yml (added) * spec/build/testsuites/sptests/spthread01.yml (added) * spec/build/testsuites/sptests/spthreadlife01.yml (added) * spec/build/testsuites/sptests/spthreadq01.yml (added) * spec/build/testsuites/sptests/sptimecounter01.yml (added) * spec/build/testsuites/sptests/sptimecounter02.yml (added) * spec/build/testsuites/sptests/sptimecounter03.yml (added) * spec/build/testsuites/sptests/sptimecounter04.yml (added) * spec/build/testsuites/sptests/sptimererr01.yml (added) * spec/build/testsuites/sptests/sptimererr02.yml (added) * spec/build/testsuites/sptests/sptimerserver01.yml (added) * spec/build/testsuites/sptests/sptimespec01.yml (added) * spec/build/testsuites/sptests/sptls01.yml (added) * spec/build/testsuites/sptests/sptls02.yml (added) * spec/build/testsuites/sptests/sptls03.yml (added) * spec/build/testsuites/sptests/sptls04.yml (added) * spec/build/testsuites/sptests/spversion01.yml (added) * spec/build/testsuites/sptests/spwatchdog.yml (added) * spec/build/testsuites/sptests/spwkspace.yml (added) * spec/build/testsuites/tmtests/grp.yml (added) * spec/build/testsuites/tmtests/tm01.yml (added) * spec/build/testsuites/tmtests/tm02.yml (added) * spec/build/testsuites/tmtests/tm03.yml (added) * spec/build/testsuites/tmtests/tm04.yml (added) * spec/build/testsuites/tmtests/tm05.yml (added) * spec/build/testsuites/tmtests/tm06.yml (added) * spec/build/testsuites/tmtests/tm07.yml (added) * spec/build/testsuites/tmtests/tm08.yml (added) * spec/build/testsuites/tmtests/tm09.yml (added) * spec/build/testsuites/tmtests/tm10.yml (added) * spec/build/testsuites/tmtests/tm11.yml (added) * spec/build/testsuites/tmtests/tm12.yml (added) * spec/build/testsuites/tmtests/tm13.yml (added) * spec/build/testsuites/tmtests/tm14.yml (added) * spec/build/testsuites/tmtests/tm15.yml (added) * spec/build/testsuites/tmtests/tm16.yml (added) * spec/build/testsuites/tmtests/tm17.yml (added) * spec/build/testsuites/tmtests/tm18.yml (added) * spec/build/testsuites/tmtests/tm19.yml (added) * spec/build/testsuites/tmtests/tm20.yml (added) * spec/build/testsuites/tmtests/tm21.yml (added) * spec/build/testsuites/tmtests/tm22.yml (added) * spec/build/testsuites/tmtests/tm23.yml (added) * spec/build/testsuites/tmtests/tm24.yml (added) * spec/build/testsuites/tmtests/tm25.yml (added) * spec/build/testsuites/tmtests/tm26.yml (added) * spec/build/testsuites/tmtests/tm27.yml (added) * spec/build/testsuites/tmtests/tm28.yml (added) * spec/build/testsuites/tmtests/tm29.yml (added) * spec/build/testsuites/tmtests/tm30.yml (added) * spec/build/testsuites/tmtests/tm31.yml (added) * spec/build/testsuites/tmtests/tm32.yml (added) * spec/build/testsuites/tmtests/tm33.yml (added) * spec/build/testsuites/tmtests/tm34.yml (added) * spec/build/testsuites/tmtests/tm35.yml (added) * spec/build/testsuites/tmtests/tm36.yml (added) * spec/build/testsuites/tmtests/tmck.yml (added) * spec/build/testsuites/tmtests/tmcontext01.yml (added) * spec/build/testsuites/tmtests/tmfine01.yml (added) * spec/build/testsuites/tmtests/tmonetoone.yml (added) * spec/build/testsuites/tmtests/tmtimer01.yml (added) * testsuites/build/.doorstop.skip (added) * testsuites/build/bad-integer.ini (added) * testsuites/build/bin/fake-rtems5-ar (added) * testsuites/build/bin/fake-rtems5-gcc (added) * testsuites/build/bin/fake-rtems5-ld (added) * testsuites/build/fake-good.ini (added) * testsuites/build/fake-inherit-good.ini (added) * testsuites/build/fake-inherit-loop.ini (added) * testsuites/build/fake-inherit-none.ini (added) * testsuites/build/fake-none.ini (added) * testsuites/build/good-integer.ini (added) * testsuites/build/not-power-of-two.ini (added) * testsuites/build/spec/bsp.yml (added) * testsuites/build/spec/config-file.yml (added) * testsuites/build/spec/config-header.yml (added) * testsuites/build/spec/gcc.yml (added) * testsuites/build/spec/integer-option.yml (added) * testsuites/build/spec/string-option.yml (added) * testsuites/build/spec/top-level-group.yml (added) * testsuites/build/spec2/config-file.yml (added) * testsuites/build/spec2/gcc.yml (added) * testsuites/build/spec2/top-level-group.yml (added) * testsuites/build/test.py (added) * testsuites/build/too-big.ini (added) * testsuites/build/too-small.ini (added) * waf (added) * wscript (added) * yaml/LICENSE (added) * yaml/PKG-INFO (added) * yaml/lib/yaml/__init__.py (added) * yaml/lib/yaml/composer.py (added) * yaml/lib/yaml/constructor.py (added) * yaml/lib/yaml/cyaml.py (added) * yaml/lib/yaml/dumper.py (added) * yaml/lib/yaml/emitter.py (added) * yaml/lib/yaml/error.py (added) * yaml/lib/yaml/events.py (added) * yaml/lib/yaml/loader.py (added) * yaml/lib/yaml/nodes.py (added) * yaml/lib/yaml/parser.py (added) * yaml/lib/yaml/reader.py (added) * yaml/lib/yaml/representer.py (added) * yaml/lib/yaml/resolver.py (added) * yaml/lib/yaml/scanner.py (added) * yaml/lib/yaml/serializer.py (added) * yaml/lib/yaml/tokens.py (added) * yaml/lib3/yaml/__init__.py (added) * yaml/lib3/yaml/composer.py (added) * yaml/lib3/yaml/constructor.py (added) * yaml/lib3/yaml/cyaml.py (added) * yaml/lib3/yaml/dumper.py (added) * yaml/lib3/yaml/emitter.py (added) * yaml/lib3/yaml/error.py (added) * yaml/lib3/yaml/events.py (added) * yaml/lib3/yaml/loader.py (added) * yaml/lib3/yaml/nodes.py (added) * yaml/lib3/yaml/parser.py (added) * yaml/lib3/yaml/reader.py (added) * yaml/lib3/yaml/representer.py (added) * yaml/lib3/yaml/resolver.py (added) * yaml/lib3/yaml/scanner.py (added) * yaml/lib3/yaml/serializer.py (added) * yaml/lib3/yaml/tokens.py (added) build: Alternative build system based on waf Update #3818.
