# # ChangeLog for spec/build/testsuites/validation/grp.yml in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 19:03:42 Fri, 10 Dec 2021 08:41:22 GMT Sebastian Huber [c39133b8] * spec/build/testsuites/validation/fatal-boot-processor-not-assigned-to-scheduler.yml (added) * spec/build/testsuites/validation/fatal-init-task-construct-failed.yml (added) * spec/build/testsuites/validation/fatal-mandatory-processor-not-present.yml (added) * spec/build/testsuites/validation/fatal-scheduler-requires-exactly-one-processor.yml (added) * spec/build/testsuites/validation/fatal-smp.yml (added) * spec/build/testsuites/validation/fatal-start-of-mandatory-processor-failed.yml (added) * spec/build/testsuites/validation/fatal-too-large-tls-size.yml (added) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/terminate.yml (added) * spec/build/testsuites/validation/validation-no-clock-0.yml (modified) * spec/build/testsuites/validation/validation-one-cpu-0.yml (modified) * spec/build/testsuites/validation/validation-smp-only-2.yml (added) * testsuites/validation/tc-score-fatal.c (added) * testsuites/validation/tc-start-of-optional-processor-failed.c (added) * testsuites/validation/tc-terminate.c (added) * testsuites/validation/tc-userext.c (added) * testsuites/validation/tc-userext.h (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/tr-fatal-boot-processor-not-assigned-to-scheduler.h (added) * testsuites/validation/tr-fatal-init-task-construct-failed.c (added) * testsuites/validation/tr-fatal-init-task-construct-failed.h (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/tr-fatal-mandatory-processor-not-present.h (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/tr-fatal-scheduler-requires-exactly-one-processor.h (added) * testsuites/validation/tr-fatal-smp.c (added) * testsuites/validation/tr-fatal-smp.h (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/tr-fatal-start-of-mandatory-processor-failed.h (added) * testsuites/validation/tr-fatal-too-large-tls-size.c (added) * testsuites/validation/tr-fatal-too-large-tls-size.h (added) * testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c (added) * testsuites/validation/ts-fatal-init-task-construct-failed.c (added) * testsuites/validation/ts-fatal-mandatory-processor-not-present.c (added) * testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c (added) * testsuites/validation/ts-fatal-smp.c (added) * testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c (added) * testsuites/validation/ts-fatal-sysinit.h (added) * testsuites/validation/ts-fatal-too-large-tls-size.c (added) * testsuites/validation/ts-terminate.c (added) * testsuites/validation/ts-validation-smp-only-2.c (added) validation: Add system termination test suites The test source code ... Thu, 09 Dec 2021 14:58:14 GMT Sebastian Huber [212b0ca] * spec/build/bsps/arm/rtl22xx/tstrtl22xx.yml (modified) * spec/build/bsps/arm/rtl22xx/tstrtl22xxt.yml (modified) * spec/build/bsps/i386/pc386/grp.yml (modified) * spec/build/bsps/i386/pc386/tst-xfail-val.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/sh/gensh1/tstgensh1.yml (modified) * spec/build/bsps/sh/gensh2/tstgensh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh1.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh2e.yml (modified) * spec/build/bsps/sh/shsim/tstsimsh4.yml (modified) * spec/build/bsps/tst-xfail-intr.yml (added) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/performance-no-clock-0.yml (moved) * spec/build/testsuites/validation/validation-1.yml (modified) * spec/build/testsuites/validation/validation-non-smp.yml (added) * spec/build/testsuites/validation/validation-one-cpu-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-0.yml (added) * spec/build/testsuites/validation/validation-smp-only-1.yml (added) * testsuites/validation/ts-acfg.h (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-idle.h (added) * testsuites/validation/ts-performance-no-clock-0.c (moved) * testsuites/validation/ts-validation-1.c (modified) * testsuites/validation/ts-validation-no-clock-0.c (added) * testsuites/validation/ts-validation-non-smp.c (added) * testsuites/validation/ts-validation-one-cpu-0.c (added) * testsuites/validation/ts-validation-smp-only-0.c (added) * testsuites/validation/ts-validation-smp-only-1.c (added) validation: Add test suites The test source code is generated from ... Thu, 09 Dec 2021 14:49:53 GMT Sebastian Huber [40cc4f5] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/libvalidation.yml (modified) * spec/build/testsuites/validation/validation-no-clock-0.yml (added) * testsuites/validation/tc-intr-entry-install.c (modified) * testsuites/validation/tc-intr-entry-remove.c (modified) * testsuites/validation/tc-intr-handler-iterate.c (modified) * testsuites/validation/ts-config.h (added) * testsuites/validation/tx-interrupt.c (modified) * testsuites/validation/tx-io-relax.c (added) * testsuites/validation/tx-memory-alloc.c (added) * testsuites/validation/tx-preemption-intervention.c (added) * testsuites/validation/tx-support.c (modified) * testsuites/validation/tx-support.h (modified) * testsuites/validation/tx-thread-queue.c (added) * testsuites/validation/tx-thread-queue.h (added) * testsuites/validation/tx-timecounter.c (added) * testsuites/validation/tx-timer-server.c (added) * testsuites/validation/tx-wrap-thread-queue.c (added) validation: Improve support library Update #3716. Mon, 12 Apr 2021 04:58:44 GMT Sebastian Huber [bc29c7c] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/libvalidation.yml (added) * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tx-support.c (moved) * testsuites/validation/tx-support.h (moved) validation: Add support library Add a library for support functions ... Mon, 15 Feb 2021 08:14:41 GMT Sebastian Huber [f38c0de4] * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-1.yml (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-validation-0.c (modified) * testsuites/validation/ts-validation-1.c (added) validation: Add Validation1 test suite Update #4244. Wed, 11 Nov 2020 14:40:39 GMT Sebastian Huber [35c52a51] * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/performance-0.yml (added) * testsuites/validation/ts-default.h (added) * testsuites/validation/ts-performance-0.c (added) * testsuites/validation/ts-validation-0.c (modified) validation/ts-performance-0: Add test suite Share a default test ... Fri, 11 Sep 2020 08:33:19 GMT Sebastian Huber [139ffa2] * Doxyfile (modified) * cpukit/doxygen/top-level-groups.h (modified) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/grp.yml (modified) * spec/build/testsuites/optvalidation.yml (added) * spec/build/testsuites/validation/grp.yml (added) * spec/build/testsuites/validation/validation-0.yml (added) * testsuites/validation/ts-validation-0.c (added) validation: Add general purpose test suite Add a general purpose ...
