@5b43316
06/29/00 16:28:39 |
Joel Sherrill |
Added initial h8300 support.
4.104.114.84.95
@847ed4bd
06/29/00 16:28:27 |
Joel Sherrill |
gdb 5.0 does not install readline so don't try to grab the info files.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@f50c11b
05/28/00 18:12:21 |
Joel Sherrill |
These files were added or deleted on the 4.5 branch as part of
Ralf's …
4.104.114.84.95
@778239e9
05/28/00 18:03:55 |
Joel Sherrill |
Added on 4.5 branch
4.104.114.84.95
@dcb4a44c
05/21/00 15:20:44 |
Joel Sherrill |
Added on branch.
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@b33ab2b
02/08/00 15:24:16 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to match his Cygwin
for …
4.104.114.84.95
@c5206d0
02/08/00 14:01:31 |
Joel Sherrill |
Updated version numbers.
4.104.114.84.95
@847dbbe
02/01/00 13:41:54 |
Joel Sherrill |
Patches rtems-rc-20000118-5.diff from Ralf Corsepius …
4.104.114.84.95
@543452de
01/31/00 20:48:14 |
Joel Sherrill |
Changed versions of newlib patch.
4.104.114.84.95
@4c46630
01/31/00 15:15:10 |
Joel Sherrill |
Patch rtems-rc-20000118-1.diff from Ralf Corsepius …
4.104.114.84.95
@8030d8a
01/31/00 14:46:38 |
Joel Sherrill |
Updated versions.
4.104.114.84.95
@42ec72d
01/27/00 23:49:44 |
Joel Sherrill |
Removed gnat and made final cleanup.
4.104.114.84.95
@f82fee9
01/27/00 23:48:50 |
Joel Sherrill |
Patch rtems-rc-20000118-0.diff from Ralf Corsepius …
4.104.114.84.95
@5eac93c7
01/25/00 19:47:32 |
Joel Sherrill |
Now binutils, gcc, and gdb build into a "base" package that is shared …
4.104.114.84.95
@9ce64148
01/24/00 23:50:28 |
Joel Sherrill |
Attempting to split binutils and gcc into base/shared and CPU specific …
4.104.114.84.95
@0c602f0
01/23/00 19:20:02 |
Joel Sherrill |
Patch from David Fiddes <D.J@…> which adds basic …
4.104.114.84.95
@318e23b
01/14/00 17:41:57 |
Joel Sherrill |
Updated versions.
4.104.114.84.95
@1cb2f89a
01/14/00 17:41:45 |
Joel Sherrill |
Updated list of targets to build.
4.104.114.84.95
@1591a1aa
11/30/99 14:43:46 |
Joel Sherrill |
Uncommitted remains of a previous patch from Ralf Corsepius …
4.104.114.84.95
@b41a0d1
11/22/99 14:30:41 |
Joel Sherrill |
RTEMS RPM basically working.
4.104.114.84.95
@5503d75
11/18/99 20:41:13 |
Joel Sherrill |
Corrected to include extra arguments for simulators on sparc
and …
4.104.114.84.95
@ea72a6c
11/18/99 20:40:23 |
Joel Sherrill |
Corrected to remove references to non-existent subpackages.
4.104.114.84.95
@1479c22
11/18/99 20:38:27 |
Joel Sherrill |
Added code to set extra configure arguments for sparc and powerpc …
4.104.114.84.95
@97d7eaf8
11/18/99 20:37:29 |
Joel Sherrill |
Added ";;" to correct syntactical error.
4.104.114.84.95
@56e61bb8
11/16/99 14:24:50 |
Joel Sherrill |
Patch rtems-rc-19991105-0.diff from Ralf Corsepius …
4.104.114.84.95
@6c85bdd
11/05/99 19:40:48 |
Joel Sherrill |
Removed.
4.104.114.84.95
@e639b998
11/05/99 19:40:42 |
Joel Sherrill |
Added this file as a way to build RPMs for CPUs that would only …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@d5704c6
11/04/99 13:18:23 |
Joel Sherrill |
Added first stab at mkgnatnewlib.
4.104.114.84.95
@f5a1fe9
11/02/99 16:07:13 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@ee9d8d52
11/02/99 16:07:06 |
Joel Sherrill |
Clean up /opt/rtems in case junk is installed in the wrong place.
This …
4.104.114.84.95
@4b42e20
10/27/99 19:07:56 |
Joel Sherrill |
Latest version from Ralf Corsepius <corsepiu@…> which …
4.104.114.84.95
@5f78061b
10/26/99 12:31:48 |
Joel Sherrill |
Removing automatically generated files.
4.104.114.84.95
@1da921e1
10/26/99 12:31:00 |
Joel Sherrill |
Removed generated file.
4.104.114.84.95
@511a12c6
10/26/99 12:29:36 |
Joel Sherrill |
New versions for gcc and patch.
4.104.114.84.95
@85cb0e5
10/26/99 02:35:51 |
Joel Sherrill |
Regenerated
4.104.114.84.95
@213c518
10/25/99 19:35:56 |
Joel Sherrill |
Patch generated from scripts-19991025-0.tar.gz from
Ralf Corsepius …
4.104.114.84.95
@c302d7a3
10/25/99 19:33:54 |
Joel Sherrill |
Regnenerated following update from Ralf.
4.104.114.84.95
@72d3f610
10/25/99 14:15:09 |
Joel Sherrill |
Merged scripts-19991022-0 changes from Ralf.
4.104.114.84.95
@666e377
10/25/99 12:29:38 |
Joel Sherrill |
Changed version number.
4.104.114.84.95
@ac5a9bf
10/21/99 19:25:19 |
Joel Sherrill |
Now builds RPM without complete source. Each target is only 15K.
4.104.114.84.95
@7063e223
10/21/99 17:22:02 |
Joel Sherrill |
Made the RTEMS version get substituted properly even though it is
not …
4.104.114.84.95
@f4a5803e
10/21/99 17:21:05 |
Joel Sherrill |
Now can specify rpm_build_root via setup.
Changed package name so …
4.104.114.84.95
@39537657
10/21/99 16:15:54 |
Joel Sherrill |
Added sh-rtemself and m68k-rtemself.
4.104.114.84.95
@43e7d103
10/21/99 15:59:54 |
Joel Sherrill |
Changes from Ralf with script-19991021-0. He fixed the %files
issue …
4.104.114.84.95
@98e6eb8
10/21/99 05:07:17 |
Joel Sherrill |
Shipping this all to Ralf.
4.104.114.84.95
@2f23359
10/20/99 20:23:18 |
Joel Sherrill |
Moved stuff to rtems subdirectory and made sure the system still …
4.104.114.84.95
@6e608c43
10/20/99 20:23:16 |
Joel Sherrill |
4.104.114.84.95
@e171450
10/20/99 20:22:13 |
Joel Sherrill |
New file.
4.104.114.84.95
@431c35d
10/20/99 19:59:01 |
Joel Sherrill |
Miscellaneous improvements and cleanups committed so I can merge …
4.104.114.84.95
@c429ec80
10/20/99 19:54:55 |
Joel Sherrill |
Moved rtems specific files into here.
4.104.114.84.95
@0f242f5f
10/20/99 19:54:36 |
Joel Sherrill |
Moving things to an rtems subdirectory like the other tools.
4.104.114.84.95
@d35e532b
10/20/99 19:51:57 |
Joel Sherrill |
New file.
4.104.114.84.95
@e46cd61
10/20/99 16:57:50 |
Joel Sherrill |
Added RPM release numbers.
4.104.114.84.95
@e4b4a771
10/20/99 16:23:32 |
Joel Sherrill |
Generated files removed.
4.104.114.84.95
@c5fc4a0b
10/20/99 16:15:20 |
Joel Sherrill |
Obsoleted.
4.104.114.84.95
@bde73461
10/20/99 16:14:54 |
Joel Sherrill |
Obsoleted as they were distributed to subdirectories.
4.104.114.84.95
@8ace612e
10/20/99 15:55:45 |
Joel Sherrill |
Made this more binutils like. :)
4.104.114.84.95
@1f339c2
10/20/99 15:50:27 |
Joel Sherrill |
New file.
4.104.114.84.95
@c4d1d41
10/20/99 15:50:13 |
Joel Sherrill |
New files.
4.104.114.84.95
@1805015
10/20/99 15:49:13 |
Joel Sherrill |
Adding the infrastructure for gdb.
4.104.114.84.95
@36b6704e
10/20/99 15:31:15 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@5f7b118
10/20/99 15:29:35 |
Joel Sherrill |
Restored joel's changes after merging old version from Ralf.
4.104.114.84.95
@10629f7
10/20/99 15:29:12 |
Joel Sherrill |
New version from Ralf.
4.104.114.84.95
@1410dc36
10/20/99 15:21:11 |
Joel Sherrill |
Committing changes before Ralf's changed.
4.104.114.84.95
@7815d96
10/19/99 22:27:13 |
Joel Sherrill |
Left to build overnight.
4.104.114.84.95
@c937033e
10/19/99 22:10:08 |
Joel Sherrill |
Made it easier to change version numbers.
4.104.114.84.95
@38118d3
10/19/99 22:07:21 |
Joel Sherrill |
Now easier to modify version numbers in scripts.
4.104.114.84.95
@ab25407c
10/19/99 22:02:39 |
Joel Sherrill |
Easier to insert tool version number.
4.104.114.84.95
@c5b8d6d
10/18/99 21:40:05 |
Joel Sherrill |
Making sparc-rtems rpms available.
4.104.114.84.95
@8c5e54b
10/18/99 19:10:03 |
Joel Sherrill |
Working on being able to cut RPMs. It now appears that the process
is …
4.104.114.84.95
@18408af
10/15/99 14:11:02 |
Joel Sherrill |
Ralf Corsepius (corsepiu@…) submitted these scripts to …
4.104.114.84.95
