# # ChangeLog for scripts in rtems # # Generated by Trac 1.2.1.dev0 # 05/16/24 14:16:40 Fri, 20 May 2005 08:53:30 GMT Ralf Corsepius [ee19895e] * scripts/gccnewlib/mkspec.in (modified) Correct PATCH handling. Fri, 20 May 2005 08:53:14 GMT Ralf Corsepius [d53bbd5a] * scripts/gccnewlib/gccnewlib.add (modified) Remove bogus comment Fri, 20 May 2005 05:40:51 GMT Ralf Corsepius [3963da6] * scripts/ChangeLog (modified) 2005-05-20 Ralf Corsepius * ... Fri, 20 May 2005 05:40:30 GMT Ralf Corsepius [b3fded0f] * scripts/binutils/base-binutils.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gdb/base-gdb.add (modified) install-info --info-dir= Wed, 18 May 2005 15:47:11 GMT Ralf Corsepius [07b3eb9e] * scripts/ChangeLog (modified) 2005-05-18 Ralf Corsepius * ... Wed, 18 May 2005 15:46:33 GMT Ralf Corsepius [d7f3b91d] * scripts/gccnewlib/header.add (modified) Document --with/--without. Wed, 18 May 2005 15:46:21 GMT Ralf Corsepius [9724b05] * scripts/gccnewlib/gccnewlib.add (modified) Reflect changes to mkspec.in. Use --with/--without, rework logic for ... Wed, 18 May 2005 15:46:00 GMT Ralf Corsepius [07cf62a] * scripts/gccnewlib/mkspec.in (modified) Correct patch handling magic. Tue, 10 May 2005 02:30:04 GMT Ralf Corsepius [0ff08b1] * scripts/ChangeLog (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2005-05-10 Ralf Corsepius * ... Thu, 05 May 2005 03:30:00 GMT Ralf Corsepius [e9a5718] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gcc.add (modified) 2005-05-05 Ralf Corsepius * ... Tue, 03 May 2005 13:55:29 GMT Ralf Corsepius [c8dcc881] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:45:14 GMT Ralf Corsepius [54651194] * scripts/ChangeLog (modified) * scripts/rtemsdoc/supplement.add.in (modified) * scripts/rtemsdoc/templ.add.in (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:40:48 GMT Ralf Corsepius [c579940] * scripts/configure.ac (modified) Add patch having been missed in 05/02 patch Tue, 03 May 2005 13:39:20 GMT Ralf Corsepius [2645067] * scripts/ChangeLog (modified) * scripts/rtemsdoc/rtemsdoc.add (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:37:53 GMT Ralf Corsepius [855db417] * scripts/ChangeLog (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:37:35 GMT Ralf Corsepius [01309994] * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) Misc. %infodir/dir handling changes. Tue, 03 May 2005 13:35:40 GMT Ralf Corsepius [894a6b22] * scripts/ChangeLog (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:32:57 GMT Ralf Corsepius [e4b19874] * scripts/ChangeLog (modified) * scripts/common/common.add.in (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:28:23 GMT Ralf Corsepius [4c4ab7d] * scripts/gccnewlib/gccnewlib.add (modified) 2005-05-03 Ralf Corsepius * ... Tue, 03 May 2005 13:27:55 GMT Ralf Corsepius [904a7b11] * scripts/ChangeLog (modified) Fix typo in previous changelog entry Tue, 03 May 2005 13:27:38 GMT Ralf Corsepius [7ccbe41] * scripts/ChangeLog (modified) Fix typo in previous changelog entry Tue, 03 May 2005 13:26:32 GMT Ralf Corsepius [4853c7d] * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-objc.add (modified) Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}. Tue, 03 May 2005 13:25:21 GMT Ralf Corsepius [ab6272e] * scripts/ChangeLog (modified) 2005-05-03 Ralf Corsepius * ... Mon, 02 May 2005 08:09:22 GMT Ralf Corsepius [29eb9a3] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) 2005-05-02 Ralf Corsepius * ... Mon, 02 May 2005 07:43:50 GMT Ralf Corsepius [e0790401] * scripts/ChangeLog (modified) * scripts/autotools/Makefile.am (modified) 2005-05-02 Ralf Corsepius * ... Mon, 02 May 2005 07:28:33 GMT Ralf Corsepius [705a0156] * scripts/autotools/.cvsignore (modified) Reflect changes to *.spec.in generation. Mon, 02 May 2005 07:27:53 GMT Ralf Corsepius [a297f20d] * scripts/ChangeLog (modified) * scripts/autotools/Makefile.am (modified) 2005-05-02 Ralf Corsepius * ... Mon, 02 May 2005 07:27:29 GMT Ralf Corsepius [f6d780f] * scripts/autotools/autoconf.add (added) * scripts/autotools/automake.add (added) * scripts/autotools/header.add (added) New. Mon, 02 May 2005 07:27:04 GMT Ralf Corsepius [68211c1a] * scripts/autotools/autoconf-rtems.spec.in (deleted) * scripts/autotools/automake-rtems.spec.in (deleted) Remove. Fri, 29 Apr 2005 08:24:14 GMT Ralf Corsepius [cae3c928] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/rtemsdoc/supplement.add.in (modified) * scripts/rtemsdoc/templ.add.in (modified) 2005-04-29 Ralf Corsepius * ... Fri, 29 Apr 2005 07:53:13 GMT Ralf Corsepius [d3dd09b] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gnat.add (modified) 2005-04-29 Ralf Corsepius * ... Wed, 27 Apr 2005 11:28:34 GMT Ralf Corsepius [f078d21] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gccnewlib/target-gnat.add (modified) 2005-04-27 Ralf Corsepius * ... Tue, 26 Apr 2005 13:48:59 GMT Ralf Corsepius [9ec745dc] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2005-04-26 Ralf Corsepius * ... Tue, 26 Apr 2005 13:45:48 GMT Ralf Corsepius [1c23f166] * scripts/ChangeLog (modified) 2005-04-26 Ralf Corsepius * ... Tue, 26 Apr 2005 13:45:33 GMT Ralf Corsepius [e6bb55e] * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/gdb/base-gdb.add (modified) Install infos using FC conventions. Tue, 26 Apr 2005 13:36:21 GMT Ralf Corsepius [3e66bcf] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/target-gcj.add (modified) 2005-04-26 Ralf Corsepius * ... Mon, 25 Apr 2005 12:36:37 GMT Ralf Corsepius [a4d8296] * scripts/gccnewlib/gccnewlib.add (modified) Fix another typo in previous patch Mon, 25 Apr 2005 12:33:38 GMT Ralf Corsepius [5537653] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) 2005-04-25 Ralf Corsepius * ... Mon, 25 Apr 2005 12:30:57 GMT Ralf Corsepius [07d3a3e] * scripts/ChangeLog (modified) Fix typo in changelog entry Mon, 25 Apr 2005 12:20:12 GMT Ralf Corsepius [633c36a] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2005-04-25 Ralf Corsepius * ... Sat, 23 Apr 2005 16:32:04 GMT Ralf Corsepius [bd21844] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2005-04-23 Ralf Corsepius * ... Sat, 23 Apr 2005 16:24:11 GMT Ralf Corsepius [b0c0fad] * scripts/ChangeLog (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-objc.add (modified) 2005-04-23 Ralf Corsepius * ... Sat, 23 Apr 2005 05:07:46 GMT Ralf Corsepius [4a6751a2] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) 2005-04-23 Ralf Corsepius * ... Sat, 23 Apr 2005 04:31:52 GMT Ralf Corsepius [b898358c] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/binutils.add (modified) 2005-04-22 Ralf Corsepius * ... Fri, 22 Apr 2005 05:15:44 GMT Ralf Corsepius [1eb65053] * scripts/ChangeLog (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gnat.add (modified) 2005-04-22 Ralf Corsepius * ... Thu, 21 Apr 2005 20:35:22 GMT Ralf Corsepius [6d4ad173] * scripts/gccnewlib/base-gfortran.add (added) * scripts/gccnewlib/target-gfortran.add (added) New. Wed, 20 Apr 2005 08:59:45 GMT Ralf Corsepius [4279a35] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) 2005-04-20 Ralf Corsepius * ... Wed, 20 Apr 2005 07:24:58 GMT Ralf Corsepius [d8fa12c] * scripts/ChangeLog (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) 2005-04-20 Ralf Corsepius * ... Wed, 20 Apr 2005 07:14:16 GMT Ralf Corsepius [b17dd93] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/configure.ac (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.add (modified) 2005-04-20 Ralf Corsepius * ... Thu, 14 Apr 2005 10:42:45 GMT Ralf Corsepius [9308d7be] * scripts/ChangeLog (modified) * scripts/gdb/mkspec.in (modified) 2005-04-14 Ralf Corsepius * ... Thu, 14 Apr 2005 10:41:17 GMT Ralf Corsepius [9674bf43] * scripts/ChangeLog (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/cpukit/target-cpukit.add (modified) 2005-04-14 Ralf Corsepius * ... Wed, 13 Apr 2005 17:10:16 GMT Ralf Corsepius [a97f235a] * scripts/cpukit/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) Cleanup Wed, 13 Apr 2005 17:09:08 GMT Ralf Corsepius [ea099a63] * scripts/rtems/README (added) New. Wed, 13 Apr 2005 17:07:02 GMT Ralf Corsepius [f862fb0] * scripts/rtems/Makefile.am (modified) Cleanup Wed, 13 Apr 2005 17:06:44 GMT Ralf Corsepius [96efa1fd] * scripts/configure.ac (modified) Fix typo Wed, 13 Apr 2005 17:02:59 GMT Ralf Corsepius [0b1af09] * scripts/ChangeLog (modified) * scripts/rtems/Makefile.am (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 17:02:00 GMT Ralf Corsepius [06f9fdb8] * scripts/rtems/.cvsignore (modified) Add mkspec. Wed, 13 Apr 2005 16:49:09 GMT Ralf Corsepius [78747ad7] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:47:50 GMT Ralf Corsepius [b3dc9ac4] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:41:59 GMT Ralf Corsepius [3860abd] * scripts/mkbspspec.in (deleted) Remove Wed, 13 Apr 2005 16:41:45 GMT Ralf Corsepius [32f9fdc] * scripts/rtems/mkspec.in (added) New. Wed, 13 Apr 2005 16:39:53 GMT Ralf Corsepius [fd6e1ec] * scripts/ChangeLog (modified) * scripts/common/clean.add.in (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:14:58 GMT Ralf Corsepius [62d1d45] * scripts/rtems/.cvsignore (modified) Add rtems.spec.in. Wed, 13 Apr 2005 16:14:02 GMT Ralf Corsepius [428e662] * scripts/rtems/rtems.spec.in (deleted) Remove. Wed, 13 Apr 2005 16:13:10 GMT Ralf Corsepius [0941438] * scripts/rtems/header.add (added) * scripts/rtems/rtems.add (added) * scripts/rtems/target-rtems.add (added) New. Wed, 13 Apr 2005 16:11:56 GMT Ralf Corsepius [0da7ecd2] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:11:30 GMT Ralf Corsepius [56b864e] * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) Various changes and hacks Wed, 13 Apr 2005 16:08:37 GMT Ralf Corsepius [39e9ed0] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:08:21 GMT Ralf Corsepius [f85f2f0] * scripts/binutils/binutils.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) Let %install rm -f $RPM_BUILD_ROOT. Wed, 13 Apr 2005 16:07:50 GMT Ralf Corsepius [b46104c] * scripts/common/common.add.in (modified) Remove _defaultbuildroot. Wed, 13 Apr 2005 16:07:23 GMT Ralf Corsepius [efafab16] * scripts/binutils/mkspec.in (modified) * scripts/cpukit/mkspec.in (modified) * scripts/gccnewlib/mkspec.in (modified) * scripts/gdb/mkspec.in (modified) Remove rpm_build_root. Wed, 13 Apr 2005 07:07:18 GMT Ralf Corsepius [3e6e43c6] * scripts/gdb/gdb.add (modified) Fix type in previous patch Wed, 13 Apr 2005 07:06:29 GMT Ralf Corsepius [5158680] * scripts/ChangeLog (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/gdb.add (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:21:17 GMT Ralf Corsepius [689b94dd] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:21:06 GMT Ralf Corsepius [e9166f31] * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:20:16 GMT Ralf Corsepius [59788fa9] * scripts/binutils/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) Move target-*.add before base*.add. Wed, 13 Apr 2005 06:14:37 GMT Ralf Corsepius [71554553] * scripts/gcc3newlib/.cvsignore (deleted) Remove. Tue, 12 Apr 2005 20:51:18 GMT Ralf Corsepius [c70ec42] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:53:01 GMT Ralf Corsepius [e8d34cb7] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:51:25 GMT Ralf Corsepius [7337984] * scripts/gcc3newlib/HISTORY (deleted) * scripts/gcc3newlib/Makefile.am (deleted) * scripts/gcc3newlib/README (deleted) * scripts/gcc3newlib/base-g77.add (deleted) * scripts/gcc3newlib/base-gcc.add (deleted) * scripts/gcc3newlib/base-gcj.add (deleted) * scripts/gcc3newlib/base-gnat.add (deleted) * scripts/gcc3newlib/gccnewlib.add (deleted) * scripts/gcc3newlib/header.add (deleted) * scripts/gcc3newlib/mkspec.in (deleted) * scripts/gcc3newlib/target-c++.add (deleted) * scripts/gcc3newlib/target-g77.add (deleted) * scripts/gcc3newlib/target-gcc.add (deleted) * scripts/gcc3newlib/target-gcj.add (deleted) * scripts/gcc3newlib/target-gnat.add (deleted) * scripts/gcc3newlib/target-objc.add (deleted) Remove. Tue, 12 Apr 2005 16:45:06 GMT Ralf Corsepius [c855b21] * scripts/ChangeLog (modified) * scripts/gccnewlib/mkspec.in (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:18:35 GMT Ralf Corsepius [b5402c6] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:18:14 GMT Ralf Corsepius [21e940b6] * scripts/README.cdn-X (modified) Minor updates. Tue, 12 Apr 2005 16:17:59 GMT Ralf Corsepius [327b340d] * scripts/Makefile.am (modified) * scripts/configure.ac (modified) Use gccnewlib/ instead of gcc3newlib/ Tue, 12 Apr 2005 15:46:33 GMT Ralf Corsepius [bcebcfe6] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 15:17:39 GMT Ralf Corsepius [664d8b71] * scripts/gccnewlib/.cvsignore (added) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-g77.add (added) * scripts/gccnewlib/base-gcc.add (added) * scripts/gccnewlib/base-gcj.add (added) * scripts/gccnewlib/base-gnat.add (added) * scripts/gccnewlib/gccnewlib.add (added) * scripts/gccnewlib/header.add (added) * scripts/gccnewlib/mkspec.in (added) * scripts/gccnewlib/target-c++.add (added) * scripts/gccnewlib/target-g77.add (added) * scripts/gccnewlib/target-gcc.add (added) * scripts/gccnewlib/target-gcj.add (added) * scripts/gccnewlib/target-gnat.add (added) * scripts/gccnewlib/target-objc.add (added) New. Tue, 12 Apr 2005 08:59:05 GMT Ralf Corsepius [ccf76fb] * scripts/ChangeLog (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/gdb/gdb.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:53:25 GMT Ralf Corsepius [9182195] * scripts/ChangeLog (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:46:58 GMT Ralf Corsepius [0c42d6d] * scripts/ChangeLog (modified) * scripts/setup (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:31:58 GMT Ralf Corsepius [e93fa77] * scripts/ChangeLog (modified) * scripts/binutils/target-binutils.add (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) * scripts/rtemsdoc/rtemsdoc.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:25:38 GMT Ralf Corsepius [e4c2a09] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:13:48 GMT Ralf Corsepius [28072168] * scripts/gcc3newlib/mkspec.in (modified) Fix stupid typo in previous patch. Tue, 12 Apr 2005 08:11:39 GMT Ralf Corsepius [76842bf2] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:11:11 GMT Ralf Corsepius [3cba822] * scripts/configure.ac (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) Use newlib_* instead of gcc3newlib_* for values from setup.*. Tue, 12 Apr 2005 07:51:18 GMT Ralf Corsepius [dad59e4] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 07:51:07 GMT Ralf Corsepius [c610055c] * scripts/configure.ac (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) Use gcc_* instead of gcc3_* for setup.* values. Tue, 12 Apr 2005 07:42:38 GMT Ralf Corsepius [c974e32] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 07:42:25 GMT Ralf Corsepius [f50f0cd] * scripts/binutils/binutils.add (modified) * scripts/gdb/gdb.add (modified) Sync %setup with gcc/gcc.add for consistency. Tue, 12 Apr 2005 06:38:14 GMT Ralf Corsepius [cf342037] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 06:37:51 GMT Ralf Corsepius [b64edb5b] * scripts/binutils/binutils.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) Apply patches in tool subdirs.
