# # ChangeLog for scripts in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 10:57:28 Fri, 05 Nov 1999 19:40:48 GMT Joel Sherrill [6c85bdd] * scripts/gnatnewlib/Makefile.in (deleted) Removed. Fri, 05 Nov 1999 19:40:42 GMT Joel Sherrill [e639b998] * scripts/gccnewlib/gccnewlib_c_only.spec.in (added) Added this file as a way to build RPMs for CPUs that would only ... Thu, 04 Nov 1999 18:05:09 GMT Joel Sherrill [f817b02] * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/mcp750/clock/c_clock.c (added) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/c_clock.c (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.c (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/align_h.S (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/align_h.S (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/ictrl.c (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/align_h.S (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/console/console.c (modified) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/samples/minimum/init.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * scripts/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gnatnewlib/gnatnewlib.spec.in (modified) * scripts/mkgccnewlibspec.in (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/minimum/init.c (modified) The files in libcpu should not be directly dependent on any BSP. In ... Thu, 04 Nov 1999 13:18:23 GMT Joel Sherrill [d5704c6] * scripts/Makefile.am (modified) * scripts/configure.in (modified) * scripts/gnatnewlib/Makefile.am (added) * scripts/gnatnewlib/Makefile.in (added) * scripts/gnatnewlib/gnatnewlib.spec.in (added) * scripts/mkgnatnewlibspec.in (added) Added first stab at mkgnatnewlib. Tue, 02 Nov 1999 16:07:13 GMT Joel Sherrill [f5a1fe9] * scripts/gdb/gdb.spec.in (modified) Fixed typo. Tue, 02 Nov 1999 16:07:06 GMT Joel Sherrill [ee9d8d52] * scripts/buildall.in (modified) Clean up /opt/rtems in case junk is installed in the wrong place. ... Wed, 27 Oct 1999 19:07:56 GMT Joel Sherrill [4b42e20] * scripts/gccnewlib/gccnewlib.spec.in (modified) Latest version from Ralf Corsepius which ... Tue, 26 Oct 1999 12:31:48 GMT Joel Sherrill [5f78061b] * scripts/Makefile.in (deleted) * scripts/binutils/Makefile.in (deleted) * scripts/gccnewlib/Makefile.in (deleted) * scripts/gdb/Makefile.in (deleted) Removing automatically generated files. Tue, 26 Oct 1999 12:31:00 GMT Joel Sherrill [1da921e1] * scripts/configure (deleted) Removed generated file. Tue, 26 Oct 1999 12:29:36 GMT Joel Sherrill [511a12c6] * scripts/setup.def (modified) New versions for gcc and patch. Tue, 26 Oct 1999 02:35:51 GMT Joel Sherrill [85cb0e5] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/configure (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) Regenerated Mon, 25 Oct 1999 19:35:56 GMT Joel Sherrill [213c518] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) Patch generated from scripts-19991025-0.tar.gz from Ralf Corsepius ... Mon, 25 Oct 1999 19:33:54 GMT Joel Sherrill [c302d7a3] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/configure (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) Regnenerated following update from Ralf. Mon, 25 Oct 1999 14:15:09 GMT Joel Sherrill [72d3f610] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) Merged scripts-19991022-0 changes from Ralf. Mon, 25 Oct 1999 12:29:38 GMT Joel Sherrill [666e377] * scripts/configure (modified) Changed version number. Thu, 21 Oct 1999 19:25:19 GMT Joel Sherrill [ac5a9bf] * scripts/binutils/binutils.spec.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) Now builds RPM without complete source. Each target is only 15K. Thu, 21 Oct 1999 17:22:02 GMT Joel Sherrill [7063e223] * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup (modified) Made the RTEMS version get substituted properly even though it is ... Thu, 21 Oct 1999 17:21:05 GMT Joel Sherrill [f4a5803e] * scripts/gccnewlib/gccnewlib.spec.in (modified) Now can specify rpm_build_root via setup. Changed package name so ... Thu, 21 Oct 1999 16:15:54 GMT Joel Sherrill [39537657] * scripts/Makefile.in (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/rtems/Makefile.am (modified) Added sh-rtemself and m68k-rtemself. Thu, 21 Oct 1999 15:59:54 GMT Joel Sherrill [43e7d103] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup (modified) Changes from Ralf with script-19991021-0. He fixed the %files issue ... Thu, 21 Oct 1999 05:07:17 GMT Joel Sherrill [98e6eb8] * scripts/buildall.in (modified) * scripts/rtems/Makefile.am (modified) Shipping this all to Ralf. Wed, 20 Oct 1999 20:23:18 GMT Joel Sherrill [2f23359] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/buildall.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gdb/Makefile.in (modified) Moved stuff to rtems subdirectory and made sure the system still ... Wed, 20 Oct 1999 20:23:16 GMT Joel Sherrill [6e608c43] * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) Moved stuff to rtems subdirectory and made sure the system still ... Wed, 20 Oct 1999 20:22:13 GMT Joel Sherrill [e171450] * scripts/rtems/Makefile.am (added) New file. Wed, 20 Oct 1999 19:59:01 GMT Joel Sherrill [431c35d] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/TODO (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall (deleted) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) Miscellaneous improvements and cleanups committed so I can merge ... Wed, 20 Oct 1999 19:54:55 GMT Joel Sherrill [c429ec80] * scripts/rtems/rtems.spec.in (added) Moved rtems specific files into here. Wed, 20 Oct 1999 19:54:36 GMT Joel Sherrill [0f242f5f] * scripts/mkbspspec.in (moved) * scripts/rtems.spec.in (deleted) Moving things to an rtems subdirectory like the other tools. Wed, 20 Oct 1999 19:51:57 GMT Joel Sherrill [d35e532b] * scripts/buildall.in (added) New file. Wed, 20 Oct 1999 16:57:50 GMT Joel Sherrill [e46cd61] * scripts/setup (modified) * scripts/setup.def (modified) Added RPM release numbers. Wed, 20 Oct 1999 16:23:32 GMT Joel Sherrill [e4b4a771] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/buildall (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/mkbinutilspec (deleted) * scripts/mkgccnewlibspec (deleted) * scripts/mkgdbspec (deleted) * scripts/mkgdbspec.in (modified) * scripts/setup.cache (deleted) Generated files removed. Wed, 20 Oct 1999 16:15:20 GMT Joel Sherrill [c5fc4a0b] * scripts/mktoolspec (deleted) Obsoleted. Wed, 20 Oct 1999 16:14:54 GMT Joel Sherrill [bde73461] * scripts/binutils.spec.in (deleted) * scripts/gccnewlib.spec.in (deleted) * scripts/gdb.spec.in (deleted) * scripts/toolchain.spec.in (deleted) Obsoleted as they were distributed to subdirectories. Wed, 20 Oct 1999 15:55:45 GMT Joel Sherrill [8ace612e] * scripts/mkgdbspec.in (modified) Made this more binutils like. :) Wed, 20 Oct 1999 15:50:27 GMT Joel Sherrill [1f339c2] * scripts/gdb/gdb.spec.in (added) New file. Wed, 20 Oct 1999 15:50:13 GMT Joel Sherrill [c4d1d41] * scripts/gdb/Makefile.am (added) * scripts/gdb/Makefile.in (added) New files. Wed, 20 Oct 1999 15:49:13 GMT Joel Sherrill [1805015] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb.spec.in (modified) * scripts/mkbinutilspec (modified) * scripts/mkgccnewlibspec (modified) * scripts/mkgdbspec (modified) * scripts/mkgdbspec.in (added) Adding the infrastructure for gdb. Wed, 20 Oct 1999 15:31:15 GMT Joel Sherrill [36b6704e] * scripts/configure.in (modified) Corrected typo. Wed, 20 Oct 1999 15:29:35 GMT Joel Sherrill [5f7b118] * scripts/buildall (modified) Restored joel's changes after merging old version from Ralf. Wed, 20 Oct 1999 15:29:12 GMT Joel Sherrill [10629f7] * scripts/Makefile.am (added) * scripts/Makefile.in (added) * scripts/TODO (modified) * scripts/aclocal.m4 (added) * scripts/binutils/Makefile.am (added) * scripts/binutils/Makefile.in (added) * scripts/binutils/binutils.spec.in (added) * scripts/buildall (modified) * scripts/configure (added) * scripts/configure.in (added) * scripts/gccnewlib.spec.in (modified) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/Makefile.in (added) * scripts/gccnewlib/gccnewlib.spec.in (added) * scripts/gdb.spec.in (modified) * scripts/install-sh (added) * scripts/missing (added) * scripts/mkbinutilspec (modified) * scripts/mkbinutilspec.in (added) * scripts/mkgccnewlibspec (modified) * scripts/mkgccnewlibspec.in (added) * scripts/mkgdbspec (modified) * scripts/mkinstalldirs (added) * scripts/mkspec (modified) * scripts/rtems.spec.in (modified) * scripts/setup (added) * scripts/setup.cache (added) * scripts/setup.def (added) New version from Ralf. Wed, 20 Oct 1999 15:21:11 GMT Joel Sherrill [1410dc36] * scripts/binutils.spec.in (modified) * scripts/buildall (modified) * scripts/gccnewlib.spec.in (modified) * scripts/gdb.spec.in (modified) Committing changes before Ralf's changed. Tue, 19 Oct 1999 22:27:13 GMT Joel Sherrill [7815d96] * scripts/binutils.spec.in (modified) * scripts/buildall (added) * scripts/gccnewlib.spec.in (modified) * scripts/gdb.spec.in (modified) * scripts/mkbinutilspec (modified) * scripts/mkgdbspec (modified) * scripts/mkspec (modified) Left to build overnight. Tue, 19 Oct 1999 22:10:08 GMT Joel Sherrill [c937033e] * scripts/gdb.spec.in (modified) * scripts/mkgdbspec (modified) Made it easier to change version numbers. Tue, 19 Oct 1999 22:07:21 GMT Joel Sherrill [38118d3] * scripts/binutils.spec.in (modified) * scripts/mkbinutilspec (modified) Now easier to modify version numbers in scripts. Tue, 19 Oct 1999 22:02:39 GMT Joel Sherrill [ab25407c] * scripts/gccnewlib.spec.in (modified) * scripts/mkgccnewlibspec (modified) Easier to insert tool version number. Mon, 18 Oct 1999 21:40:05 GMT Joel Sherrill [c5b8d6d] * scripts/gccnewlib.spec.in (modified) * scripts/mkbinutilspec (modified) * scripts/mkgdbspec (modified) Making sparc-rtems rpms available. Mon, 18 Oct 1999 19:10:03 GMT Joel Sherrill [8c5e54b] * scripts/README (modified) * scripts/TODO (added) * scripts/binutils.spec.in (added) * scripts/gccnewlib.spec.in (added) * scripts/gdb.spec.in (added) * scripts/mkbinutils_subpackage_version (added) * scripts/mkbinutilspec (added) * scripts/mkgccnewlibspec (added) * scripts/mkgdbspec (added) * scripts/mkspec (modified) * scripts/mktoolspec (modified) * scripts/toolchain.spec.in (modified) Working on being able to cut RPMs. It now appears that the process ... Fri, 15 Oct 1999 14:11:02 GMT Joel Sherrill [18408af] * scripts/README (added) * scripts/mkbspspec (added) * scripts/mkrpms (added) * scripts/mkspec (added) * scripts/mktoolspec (added) * scripts/rtems.spec.in (added) * scripts/toolchain.spec.in (added) Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to ...
