# # ChangeLog for scripts in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 18:58:03 Wed, 13 Apr 2005 16:13:10 GMT Ralf Corsepius [0941438] * scripts/rtems/header.add (added) * scripts/rtems/rtems.add (added) * scripts/rtems/target-rtems.add (added) New. Wed, 13 Apr 2005 16:11:56 GMT Ralf Corsepius [0da7ecd2] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:11:30 GMT Ralf Corsepius [56b864e] * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) Various changes and hacks Wed, 13 Apr 2005 16:08:37 GMT Ralf Corsepius [39e9ed0] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 16:08:21 GMT Ralf Corsepius [f85f2f0] * scripts/binutils/binutils.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) Let %install rm -f $RPM_BUILD_ROOT. Wed, 13 Apr 2005 16:07:50 GMT Ralf Corsepius [b46104c] * scripts/common/common.add.in (modified) Remove _defaultbuildroot. Wed, 13 Apr 2005 16:07:23 GMT Ralf Corsepius [efafab16] * scripts/binutils/mkspec.in (modified) * scripts/cpukit/mkspec.in (modified) * scripts/gccnewlib/mkspec.in (modified) * scripts/gdb/mkspec.in (modified) Remove rpm_build_root. Wed, 13 Apr 2005 07:07:18 GMT Ralf Corsepius [3e6e43c6] * scripts/gdb/gdb.add (modified) Fix type in previous patch Wed, 13 Apr 2005 07:06:29 GMT Ralf Corsepius [5158680] * scripts/ChangeLog (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/gdb.add (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:21:17 GMT Ralf Corsepius [689b94dd] * scripts/ChangeLog (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:21:06 GMT Ralf Corsepius [e9166f31] * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) 2005-04-13 Ralf Corsepius * ... Wed, 13 Apr 2005 06:20:16 GMT Ralf Corsepius [59788fa9] * scripts/binutils/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) Move target-*.add before base*.add. Wed, 13 Apr 2005 06:14:37 GMT Ralf Corsepius [71554553] * scripts/gcc3newlib/.cvsignore (deleted) Remove. Tue, 12 Apr 2005 20:51:18 GMT Ralf Corsepius [c70ec42] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:53:01 GMT Ralf Corsepius [e8d34cb7] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:51:25 GMT Ralf Corsepius [7337984] * scripts/gcc3newlib/HISTORY (deleted) * scripts/gcc3newlib/Makefile.am (deleted) * scripts/gcc3newlib/README (deleted) * scripts/gcc3newlib/base-g77.add (deleted) * scripts/gcc3newlib/base-gcc.add (deleted) * scripts/gcc3newlib/base-gcj.add (deleted) * scripts/gcc3newlib/base-gnat.add (deleted) * scripts/gcc3newlib/gccnewlib.add (deleted) * scripts/gcc3newlib/header.add (deleted) * scripts/gcc3newlib/mkspec.in (deleted) * scripts/gcc3newlib/target-c++.add (deleted) * scripts/gcc3newlib/target-g77.add (deleted) * scripts/gcc3newlib/target-gcc.add (deleted) * scripts/gcc3newlib/target-gcj.add (deleted) * scripts/gcc3newlib/target-gnat.add (deleted) * scripts/gcc3newlib/target-objc.add (deleted) Remove. Tue, 12 Apr 2005 16:45:06 GMT Ralf Corsepius [c855b21] * scripts/ChangeLog (modified) * scripts/gccnewlib/mkspec.in (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:18:35 GMT Ralf Corsepius [b5402c6] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 16:18:14 GMT Ralf Corsepius [21e940b6] * scripts/README.cdn-X (modified) Minor updates. Tue, 12 Apr 2005 16:17:59 GMT Ralf Corsepius [327b340d] * scripts/Makefile.am (modified) * scripts/configure.ac (modified) Use gccnewlib/ instead of gcc3newlib/ Tue, 12 Apr 2005 15:46:33 GMT Ralf Corsepius [bcebcfe6] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 15:17:39 GMT Ralf Corsepius [664d8b71] * scripts/gccnewlib/.cvsignore (added) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-g77.add (added) * scripts/gccnewlib/base-gcc.add (added) * scripts/gccnewlib/base-gcj.add (added) * scripts/gccnewlib/base-gnat.add (added) * scripts/gccnewlib/gccnewlib.add (added) * scripts/gccnewlib/header.add (added) * scripts/gccnewlib/mkspec.in (added) * scripts/gccnewlib/target-c++.add (added) * scripts/gccnewlib/target-g77.add (added) * scripts/gccnewlib/target-gcc.add (added) * scripts/gccnewlib/target-gcj.add (added) * scripts/gccnewlib/target-gnat.add (added) * scripts/gccnewlib/target-objc.add (added) New. Tue, 12 Apr 2005 08:59:05 GMT Ralf Corsepius [ccf76fb] * scripts/ChangeLog (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/gdb/gdb.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:53:25 GMT Ralf Corsepius [9182195] * scripts/ChangeLog (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:46:58 GMT Ralf Corsepius [0c42d6d] * scripts/ChangeLog (modified) * scripts/setup (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:31:58 GMT Ralf Corsepius [e93fa77] * scripts/ChangeLog (modified) * scripts/binutils/target-binutils.add (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) * scripts/rtemsdoc/rtemsdoc.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:25:38 GMT Ralf Corsepius [e4c2a09] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:13:48 GMT Ralf Corsepius [28072168] * scripts/gcc3newlib/mkspec.in (modified) Fix stupid typo in previous patch. Tue, 12 Apr 2005 08:11:39 GMT Ralf Corsepius [76842bf2] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 08:11:11 GMT Ralf Corsepius [3cba822] * scripts/configure.ac (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) Use newlib_* instead of gcc3newlib_* for values from setup.*. Tue, 12 Apr 2005 07:51:18 GMT Ralf Corsepius [dad59e4] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 07:51:07 GMT Ralf Corsepius [c610055c] * scripts/configure.ac (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) Use gcc_* instead of gcc3_* for setup.* values. Tue, 12 Apr 2005 07:42:38 GMT Ralf Corsepius [c974e32] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 07:42:25 GMT Ralf Corsepius [f50f0cd] * scripts/binutils/binutils.add (modified) * scripts/gdb/gdb.add (modified) Sync %setup with gcc/gcc.add for consistency. Tue, 12 Apr 2005 06:38:14 GMT Ralf Corsepius [cf342037] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 06:37:51 GMT Ralf Corsepius [b64edb5b] * scripts/binutils/binutils.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) Apply patches in tool subdirs. Tue, 12 Apr 2005 06:28:08 GMT Ralf Corsepius [6c8b7db] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 06:26:25 GMT Ralf Corsepius [7b5b8d0] * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/mkspec.in (modified) Eliminate @PATCH2@, @PATCH4@. Tue, 12 Apr 2005 06:26:03 GMT Ralf Corsepius [0a80a16] * scripts/binutils/binutils.add (modified) * scripts/binutils/mkspec.in (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/mkspec.in (modified) Eliminate @PATCH2@. Tue, 12 Apr 2005 06:14:27 GMT Ralf Corsepius [9c3ea18] * scripts/ChangeLog (modified) 2005-04-12 Ralf Corsepius * ... Tue, 12 Apr 2005 06:14:08 GMT Ralf Corsepius [5c68bf8] * scripts/binutils/binutils.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) Add support for rpmbuild --with sources. Thu, 17 Mar 2005 13:42:17 GMT Ralf Corsepius [1a58b1f9] * scripts/ChangeLog (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/mkspec.in (modified) * scripts/gdb/target-gdb.add (modified) 2005-03-17 Ralf Corsepius * ... Sat, 12 Mar 2005 03:48:07 GMT Ralf Corsepius [c7a0121] * scripts/ChangeLog (modified) 2005-03-12 Ralf Corsepius * ... Sat, 12 Mar 2005 03:47:52 GMT Ralf Corsepius [65bb8c7] * scripts/binutils/target-binutils.add (modified) Preparations for binutils-2.16. Sat, 12 Mar 2005 03:47:21 GMT Ralf Corsepius [f7d3f2b] * scripts/binutils/binutils.add (modified) * scripts/binutils/mkspec.in (modified) * scripts/setup.def (modified) Add binutils_suffix. Thu, 24 Feb 2005 06:33:57 GMT Ralf Corsepius [233186a] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/mkspec.in (modified) * scripts/setup.def (modified) 2005-02-24 Ralf Corsepius * ... Wed, 16 Feb 2005 11:17:46 GMT Ralf Corsepius [693c35e] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2005-02-16 Ralf Corsepius * ... Fri, 04 Feb 2005 16:13:18 GMT Ralf Corsepius [b1e04829] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) 2005-02-04 Ralf Corsepius * ... Mon, 17 Jan 2005 08:59:41 GMT Ralf Corsepius [7f1a915] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2005-01-17 Ralf Corsepius * ... Wed, 12 Jan 2005 06:14:41 GMT Ralf Corsepius [83774d7] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2005-01-12 Ralf Corsepius * ... Wed, 05 Jan 2005 18:23:14 GMT Ralf Corsepius [9ea4207] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2005-01-05 Ralf Corsepius * ... Tue, 02 Nov 2004 16:19:05 GMT Joel Sherrill [925563f] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-11-02 Joel Sherrill * ... Fri, 29 Oct 2004 17:18:12 GMT Joel Sherrill [db1431e9] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/binutils/Makefile.am (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/setup.def (modified) 2004-10-29 Joel Sherrill * ... Wed, 29 Sep 2004 17:29:10 GMT Joel Sherrill [e4e9d60] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/buildall.in (modified) * scripts/buildalltar.in (modified) * scripts/cpukit/Makefile.am (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtemsdoc/.cvsignore (modified) * scripts/rtemsdoc/Makefile.am (modified) 2004-09-29 Joel Sherrill * ... Fri, 24 Sep 2004 06:32:10 GMT Ralf Corsepius [3e46c1cf] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * contrib/cygwin/configure.ac (modified) * contrib/freebsd/configure.ac (modified) * contrib/solaris/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * scripts/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Fix typo in previous change. Fri, 24 Sep 2004 05:54:59 GMT Ralf Corsepius [97891e5e] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/freebsd/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2004-09-24 Ralf Corsepius * ... Thu, 23 Sep 2004 06:27:34 GMT Ralf Corsepius [9a769860] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) 2004-09-23 Ralf Corsepius * ... Thu, 23 Sep 2004 06:22:14 GMT Ralf Corsepius [d81e17f] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-09-23 Ralf Corsepius * ... Thu, 23 Sep 2004 06:18:35 GMT Ralf Corsepius [956e450] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-09-23 Ralf Corsepius * ... Thu, 29 Jul 2004 09:50:23 GMT Ralf Corsepius [36712aa9] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-07-29 Ralf Corsepius * ... Mon, 24 May 2004 03:02:05 GMT Joel Sherrill [0a0961cf] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-05-23 Joel Sherrill * ... Mon, 24 May 2004 03:00:52 GMT Joel Sherrill [1ef71af] * scripts/ChangeLog (modified) * scripts/gcc3newlib/target-gnat.add (modified) 2004-05-23 Joel Sherrill * ... Tue, 18 May 2004 09:42:36 GMT Ralf Corsepius [92166f37] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/binutils.add (modified) 2004-05-18 Ralf Corsepius * ... Thu, 29 Apr 2004 15:20:24 GMT Ralf Corsepius [a99bf0a] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-04-29 Ralf Corsepius * ... Mon, 26 Apr 2004 09:00:14 GMT Ralf Corsepius [bfa87f30] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-04-26 Ralf Corsepius * ... Sat, 27 Mar 2004 03:16:25 GMT Ralf Corsepius [02c7c81] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-g77.add (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/base-gnat.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-c++.add (modified) * scripts/gcc3newlib/target-gcc.add (modified) * scripts/gcc3newlib/target-gcj.add (modified) 2004-03-26 Ralf Corsepius * ... Sat, 27 Mar 2004 02:51:19 GMT Ralf Corsepius [1dec74de] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) 2004-03-26 Ralf Corsepius * ... Thu, 25 Mar 2004 04:21:03 GMT Ralf Corsepius [e1908de] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-03-25 Ralf Corsepius * ... Thu, 18 Mar 2004 17:19:11 GMT Ralf Corsepius [82c123d] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-gcj.add (modified) * scripts/gcc3newlib/target-gnat.add (modified) 2004-03-18 Ralf Corsepius * ... Thu, 18 Mar 2004 11:35:27 GMT Ralf Corsepius [4ef10977] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/target-g77.add (modified) * scripts/gcc3newlib/target-objc.add (modified) 2004-03-18 Ralf Corsepius * ... Wed, 17 Mar 2004 17:54:27 GMT Ralf Corsepius [08b1e43] * scripts/ChangeLog (modified) * scripts/gcc3newlib/target-c++.add (modified) * scripts/gcc3newlib/target-gcc.add (modified) 2004-03-17 Ralf Corsepius * ... Wed, 17 Mar 2004 17:14:07 GMT Ralf Corsepius [40605a2] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-03-17 Ralf Corsepius * ... Mon, 15 Mar 2004 07:31:31 GMT Ralf Corsepius [c2cbaba] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) 2004-03-15 Ralf Corsepius * ... Tue, 24 Feb 2004 12:06:30 GMT Joel Sherrill [79f90ba] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-02-24 Joel Sherrill PR ... Mon, 23 Feb 2004 06:04:23 GMT Ralf Corsepius [8b2642c2] * scripts/ChangeLog (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) 2004-02-23 Ralf Corsepius * ... Fri, 20 Feb 2004 01:40:59 GMT Ralf Corsepius [4d327517] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Thu, 19 Feb 2004 14:19:15 GMT Joel Sherrill [2c7f0e3d] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2004-02-19 Joel Sherrill * ... Thu, 19 Feb 2004 12:13:42 GMT Joel Sherrill [074133a] * scripts/ChangeLog (modified) 2004-02-19 Joel Sherrill * ... Tue, 17 Feb 2004 19:09:57 GMT Joel Sherrill [90357e29] * scripts/ChangeLog (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2004-02-17 RTEMS * setup.def, gdb/base-gdb.add, ... Thu, 12 Feb 2004 15:17:52 GMT Ralf Corsepius [674ded3] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2004-02-12 Ralf Corsepius * ... Thu, 12 Feb 2004 15:00:11 GMT Ralf Corsepius [5333511] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/gccnewlib/.cvsignore (deleted) * scripts/gccnewlib/HISTORY (deleted) * scripts/gccnewlib/Makefile.am (deleted) * scripts/gccnewlib/README (deleted) * scripts/gccnewlib/base-chill.add (deleted) * scripts/gccnewlib/base-g77.add (deleted) * scripts/gccnewlib/base-gcc.add (deleted) * scripts/gccnewlib/base-gcj.add (deleted) * scripts/gccnewlib/gccnewlib.add (deleted) * scripts/gccnewlib/header.add (deleted) * scripts/gccnewlib/target-chill.add (deleted) * scripts/gccnewlib/target-g77.add (deleted) * scripts/gccnewlib/target-gcc.add (deleted) * scripts/gccnewlib/target-gcj.add (deleted) * scripts/gccnewlib/target-objc.add (deleted) * scripts/mkgccnewlibspec.in (deleted) 2004-02-12 Ralf Corsepius * ... Thu, 12 Feb 2004 14:32:16 GMT Ralf Corsepius [acf23e63] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-02-12 Ralf Corsepius * ... Thu, 12 Feb 2004 12:18:19 GMT Ralf Corsepius [e9e6b77] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-02-12 Ralf Corsepius * ... Tue, 10 Feb 2004 16:41:08 GMT Ralf Corsepius [beabcaf9] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/rtems/rtems-source.add (modified) * scripts/rtemsdoc/.cvsignore (modified) * scripts/rtemsdoc/Makefile.am (modified) * scripts/rtemsdoc/header.add (modified) * scripts/rtemsdoc/mkspec.in (deleted) * scripts/rtemsdoc/rtemsdoc.add (modified) * scripts/rtemsdoc/supplement.add.in (modified) * scripts/rtemsdoc/templ.add.in (modified) 2004-02-10 Ralf Corsepius * ... Mon, 09 Feb 2004 13:28:21 GMT Ralf Corsepius [d9d69d7] * scripts/ChangeLog (modified) * scripts/rtems/rtems-source.add (modified) 2004-02-09 Ralf Corsepius * ... Mon, 09 Feb 2004 13:21:24 GMT Ralf Corsepius [5d85028] * scripts/Makefile.am (modified) * scripts/common/common.add.in (modified) * scripts/configure.ac (modified) * scripts/rtems/rtems-source.add (added) 2004-02-09 Ralf Corsepius * ... Wed, 04 Feb 2004 16:38:25 GMT Ralf Corsepius [c0b267a] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) 2004-02-04 Ralf Corsepius * ... Wed, 28 Jan 2004 21:45:51 GMT Joel Sherrill [4e445522] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/buildall.in (modified) * scripts/buildalltar.in (modified) * scripts/cpukit/Makefile.am (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) 2004-01-28 RTEMS * buildall.in, buildalltar.in, ... Wed, 28 Jan 2004 21:19:49 GMT Joel Sherrill [e85312d] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/autotools/automake-rtems.spec.in (modified) * scripts/configure.ac (modified) * scripts/setup.def (modified) 2004-01-28 RTEMS * configure.ac: Enable OS versioning ... Tue, 13 Jan 2004 12:51:00 GMT Ralf Corsepius [f5d3cf6] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-01-13 Ralf Corsepius * ... Mon, 12 Jan 2004 06:03:17 GMT Ralf Corsepius [a1f0115d] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-01-12 Ralf Corsepius * ... Thu, 08 Jan 2004 16:49:25 GMT Joel Sherrill [daec7a9] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-01-08 Joel Sherrill * ... Wed, 07 Jan 2004 20:35:07 GMT Joel Sherrill [282180cc] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/buildall.in (modified) * scripts/buildalltar.in (modified) * scripts/cpukit/Makefile.am (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtemsdoc/.cvsignore (modified) * scripts/rtemsdoc/Makefile.am (modified) 2004-01-07 Joel Sherrill * ... Tue, 16 Dec 2003 13:53:52 GMT Joel Sherrill [587d22de] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2003-12-16 Joel Sherrill * ... Fri, 12 Dec 2003 03:28:02 GMT Ralf Corsepius [810720b6] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/tools/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2003-12-12 Ralf Corsepius * ... Thu, 11 Dec 2003 16:12:23 GMT Ralf Corsepius [eec8e59e] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/autotools/Makefile.am (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/autotools/automake-rtems.spec.in (modified) * scripts/binutils/Makefile.am (modified) * scripts/cpukit/Makefile.am (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtemsdoc/Makefile.am (modified) 2003-12-11 Ralf Corsepius * ... Mon, 17 Nov 2003 12:52:01 GMT Ralf Corsepius [61f41e2] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gnat.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2003-11-17 Ralf Corsepius * ... Thu, 30 Oct 2003 09:29:19 GMT Ralf Corsepius [3c8fa15] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2003-10-30 Ralf Corsepius * ... Thu, 23 Oct 2003 10:03:00 GMT Ralf Corsepius [c83a419a] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/mkspec.in (modified) 2003-10-23 Ralf Corsepius * ... Wed, 22 Oct 2003 19:57:43 GMT Ralf Corsepius [4be8e00] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2003-10-22 Ralf Corsepius * ...
