# # ChangeLog for scripts/mkspec in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 19:26:53 Thu, 28 Mar 2002 18:17:40 GMT Joel Sherrill [afe5cac] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/gcc3newlib/HISTORY (added) * scripts/gcc3newlib/Makefile.am (added) * scripts/gcc3newlib/README (added) * scripts/gcc3newlib/base-g77.add (added) * scripts/gcc3newlib/base-gcc.add (added) * scripts/gcc3newlib/base-gcj.add (added) * scripts/gcc3newlib/gccnewlib.add (added) * scripts/gcc3newlib/gccnewlib.spec.in (added) * scripts/gcc3newlib/gccnewlib_c_only.spec.in (added) * scripts/gcc3newlib/target-g77.add (added) * scripts/gcc3newlib/target-gcc.add (added) * scripts/gcc3newlib/target-gcj.add (added) * scripts/gcc3newlib/target-objc.add (added) * scripts/mkgcc3newlibspec.in (added) * scripts/mkspec (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2001-03-28 Joel Sherrill * Per PR64 ... Wed, 20 Oct 1999 15:29:12 GMT Joel Sherrill [10629f7] * scripts/Makefile.am (added) * scripts/Makefile.in (added) * scripts/TODO (modified) * scripts/aclocal.m4 (added) * scripts/binutils/Makefile.am (added) * scripts/binutils/Makefile.in (added) * scripts/binutils/binutils.spec.in (added) * scripts/buildall (modified) * scripts/configure (added) * scripts/configure.in (added) * scripts/gccnewlib.spec.in (modified) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/Makefile.in (added) * scripts/gccnewlib/gccnewlib.spec.in (added) * scripts/gdb.spec.in (modified) * scripts/install-sh (added) * scripts/missing (added) * scripts/mkbinutilspec (modified) * scripts/mkbinutilspec.in (added) * scripts/mkgccnewlibspec (modified) * scripts/mkgccnewlibspec.in (added) * scripts/mkgdbspec (modified) * scripts/mkinstalldirs (added) * scripts/mkspec (modified) * scripts/rtems.spec.in (modified) * scripts/setup (added) * scripts/setup.cache (added) * scripts/setup.def (added) New version from Ralf. Tue, 19 Oct 1999 22:27:13 GMT Joel Sherrill [7815d96] * scripts/binutils.spec.in (modified) * scripts/buildall (added) * scripts/gccnewlib.spec.in (modified) * scripts/gdb.spec.in (modified) * scripts/mkbinutilspec (modified) * scripts/mkgdbspec (modified) * scripts/mkspec (modified) Left to build overnight. Mon, 18 Oct 1999 19:10:03 GMT Joel Sherrill [8c5e54b] * scripts/README (modified) * scripts/TODO (added) * scripts/binutils.spec.in (added) * scripts/gccnewlib.spec.in (added) * scripts/gdb.spec.in (added) * scripts/mkbinutils_subpackage_version (added) * scripts/mkbinutilspec (added) * scripts/mkgccnewlibspec (added) * scripts/mkgdbspec (added) * scripts/mkspec (modified) * scripts/mktoolspec (modified) * scripts/toolchain.spec.in (modified) Working on being able to cut RPMs. It now appears that the process ... Fri, 15 Oct 1999 14:11:02 GMT Joel Sherrill [18408af] * scripts/README (added) * scripts/mkbspspec (added) * scripts/mkrpms (added) * scripts/mkspec (added) * scripts/mktoolspec (added) * scripts/rtems.spec.in (added) * scripts/toolchain.spec.in (added) Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to ...
